Help required to remove www_getwindow.info tool bar
Solved Help required to remove www_getwindow.info tool bar
Post by Chrisgal on Tue Oct 08, 2013 8:19 am
Results of screen317's Security Check version 0.99.74
Windows 7 Service Pack 1 x64 (UAC is enabled)
Internet Explorer 10
Windows Firewall Enabled!
avast! Antivirus
Antivirus up to date!
Spybot - Search & Destroy
Malwarebytes Anti-Malware version 1.75.0.1300
SparkTrust PC Cleaner Plus
Adobe Flash Player 11.8.800.168
Adobe Reader 10.1.8 Adobe Reader out of Date!
Google Chrome 28.0.1500.71
Spybot Teatimer.exe is disabled!
AVAST Software Avast AvastSvc.exe
AVAST Software Avast AvastUI.exe
Total Fragmentation on Drive C: 0%
Malwarebytes Anti-Malware 1.75.0.1300
Database version: v2013.10.08.03
Windows 7 Service Pack 1 x64 NTFS
Internet Explorer 10.0.9200.16686
User :: USER-PC [administrator]
08/10/2013 09:26:27
MBAM-log-2013-10-08 (10-19-20).txt
Scan type: Full scan (C:\|)
Scan options disabled: P2P
Objects scanned: 470070
Time elapsed: 52 minute(s), 29 second(s)
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 8
HKCR\CLSID\{33119133-0854-469d-807A-171568457991} (PUP.Optional.FunWebProducts.A) -> No action taken.
HKCR\CLSID\{13119113-0854-469d-807A-171568457991} (PUP.Optional.FunWebProducts.A) -> No action taken.
HKCR\MapsGalaxy_39.SkinLauncher.1 (PUP.Optional.FunWebProducts.A) -> No action taken.
HKCR\MapsGalaxy_39.SkinLauncher (PUP.Optional.FunWebProducts.A) -> No action taken.
HKCR\TypeLib\{03119103-0854-469d-807A-171568457991} (PUP.Optional.FunWebProducts.A) -> No action taken.
HKCR\Interface\{23119123-0854-469D-807A-171568457991} (PUP.Optional.FunWebProducts.A) -> No action taken.
HKCR\MapsGalaxy_39.SkinLauncherSettings.1 (PUP.Optional.FunWebProducts.A) -> No action taken.
HKCR\MapsGalaxy_39.SkinLauncherSettings (PUP.Optional.FunWebProducts.A) -> No action taken.
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 3
C:\Program Files (x86)\MapsGalaxy_39\bar\1.bin\39sknlcr.dll (PUP.Optional.FunWebProducts.A) -> No action taken.
C:\Users\User\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RC14BKH8\spyware doctor setup.exe (PUP.Soft32Downloader) -> No action taken.
C:\Users\User\Desktop\ZipExtractorSetup.exe (PUP.Optional.InstallCore) -> No action taken.
(end)
Chrisgal
OS : Windows 7
# Likes : 0
Solved Re: Help required to remove www_getwindow.info tool bar
Post by Superdave on Tue Oct 08, 2013 6:38 pm
Please download [You must be registered and logged in to see this link.]by Xplode onto your Desktop.
  • Please close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Delete.
  • Confirm each time with OK
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
Please run MBAM again, make sure all the infections are checked and select "Remove selected".
•Temporarily disable your Antivirus and any Antispyware real time protection before performing a scan. Click [You must be registered and logged in to see this link.]link to see a list of security programs that should be disabled and how to disable them.
Captain
Captain
OS : Windows 8.1 and a dual-boot with XP Home SP3
# Likes : 0
Post by Chrisgal on Wed Oct 09, 2013 6:23 am
Thank you for your help. It is very much appreciated.
Cleaner v3.006 - Report created 09/10/2013 at 07:17:02
# Updated 01/10/2013 by Xplode
# Operating System : Windows 7 Home Premium Service Pack 1 (64 bits)
# Username : User - USER-PC
# Running from : C:\Users\User\Desktop\adwcleaner.exe
# Option : Clean
***** [ Services ] *****
Service Deleted : BCUService
***** [ Files / Folders ] *****
Folder Deleted : C:\Program Files (x86)\DeviceVM
Folder Deleted : C:\Program Files (x86)\mapsgalaxy_39
Folder Deleted : C:\Program Files (x86)\uTorrentControl2
Folder Deleted : C:\Users\User\AppData\Local\Bundled software uninstaller
Folder Deleted : C:\Users\User\AppData\LocalLow\alotappbar
Folder Deleted : C:\Users\User\AppData\LocalLow\Conduit
Folder Deleted : C:\Users\User\AppData\LocalLow\Delta
Folder Deleted : C:\Users\User\AppData\LocalLow\PriceGong
Folder Deleted : C:\Users\User\AppData\LocalLow\uTorrentControl2
Folder Deleted : C:\Users\User\AppData\Roaming\CheckPoint\ZoneAlarm LTD Toolbar
Folder Deleted : C:\Users\User\AppData\Roaming\DriverCure
Folder Deleted : C:\Users\User\AppData\Roaming\PerformerSoft
Folder Deleted : C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\Extensions\dgjkhjdcljddbedokogakmmdjgnbeanf
Folder Deleted : C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
Folder Deleted : C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\Extensions\mocblcnaofikinigmceddfghppkkjbog
Folder Deleted : C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\Extensions\pflphaooapbgpeakohlggbpidpppgdff
File Deleted : C:\END
File Deleted : C:\Users\Public\Desktop\Babylon.lnk
File Deleted : C:\Windows\System32\roboot64.exe
File Deleted : C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_igdhbblpcellaljokkpfhcjlagemhgjl_0.localstorage
***** [ Shortcuts ] *****
***** [ Registry ] *****
Value Deleted : HKLM\SOFTWARE\Mozilla\Firefox\Extensions [39ffxtbr@MapsGalaxy_39.com]
Value Deleted : HKCU\Software\Mozilla\Firefox\Extensions [pluswinks@PlusWinks]
Value Deleted : HKLM\SOFTWARE\Mozilla\Firefox\Extensions [pluswinks@PlusWinks]
Value Deleted : HKCU\Software\Mozilla\Firefox\Extensions [speedanalysis02@SpeedAnalysis.com]
Value Deleted : HKLM\SOFTWARE\Mozilla\Firefox\Extensions [speedanalysis02@SpeedAnalysis.com]
Key Deleted : HKLM\SOFTWARE\Google\Chrome\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
Key Deleted : HKLM\SOFTWARE\Google\Chrome\Extensions\mocblcnaofikinigmceddfghppkkjbog
Key Deleted : HKLM\SOFTWARE\Google\Chrome\Extensions\niapdbllcanepiiimjjndipklodoedlc
Key Deleted : HKCU\Software\Google\Chrome\Extensions\pflphaooapbgpeakohlggbpidpppgdff
Key Deleted : HKLM\SOFTWARE\Google\Chrome\Extensions\pflphaooapbgpeakohlggbpidpppgdff
Key Deleted : [x64] HKLM\SOFTWARE\Google\Chrome\Extensions\pflphaooapbgpeakohlggbpidpppgdff
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\grusskartencenter.com
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\EscDomains\grusskartencenter.com
Key Deleted : HKLM\SOFTWARE\Classes\AddressBarSearch.SearchHook
Key Deleted : HKLM\SOFTWARE\Classes\AddressBarSearch.SearchHook.1
Key Deleted : HKLM\SOFTWARE\Classes\AppID\escort.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\escortApp.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\escortEng.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\escorTlbr.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\esrv.EXE
Key Deleted : HKLM\SOFTWARE\Classes\AppID\secman.DLL
Key Deleted : HKLM\SOFTWARE\Classes\driverscanner
Key Deleted : HKLM\SOFTWARE\Classes\escort.escortIEPane
Key Deleted : HKLM\SOFTWARE\Classes\escort.escortIEPane.1
Key Deleted : HKLM\SOFTWARE\Classes\esrv.mysearchdialESrvc
Key Deleted : HKLM\SOFTWARE\Classes\esrv.mysearchdialESrvc.1
Key Deleted : HKLM\SOFTWARE\Classes\Prod.cap
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\apnstub_RASAPI32
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\apnstub_RASMANCS
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\Iminent_RASAPI32
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\Iminent_RASMANCS
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\MyBabylontb_RASAPI32
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\MyBabylontb_RASMANCS
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\SnapDo_RASAPI32
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\SnapDo_RASMANCS
Value Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [BCU]
Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@checkpoint.com/FFApi
Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@MapsGalaxy_39.com/Plugin
Key Deleted : HKLM\SOFTWARE\Classes\Toolbar.CT3072253
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{09C554C3-109B-483C-A06B-F14172F1A947}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{4D076AB4-7562-427A-B5D2-BD96E19DEE56}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{4E1E9D45-8BF9-4139-915C-9F83CC3D5921}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{B12E99ED-69BD-437C-86BE-C862B9E5444D}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{D7EE8177-D51E-4F89-92B6-83EA2EC40800}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{EA28B360-05E0-4F93-8150-02891F1D8D3C}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{02054E11-5113-4BE3-8153-AA8DFB5D3761}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{826D7151-8D99-434B-8540-082B8C2AE556}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{AE07101B-46D4-4A98-AF68-0333EA26E113}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{687578B9-7132-4A7A-80E4-30EE31099E03}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{D4AAF2A6-F6D1-49A5-BA1A-B20735DF1955}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{021B4049-F57D-4565-A693-FD3B04786BFA}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{0362AA09-808D-48E9-B360-FB51A8CBCE09}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{06844020-CD0B-3D3D-A7FE-371153013E49}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{0ADC01BB-303B-3F8E-93DA-12C140E85460}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{10D3722F-23E6-3901-B6C1-FF6567121920}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{1675E62B-F911-3B7B-A046-EB57261212F3}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{192929F2-9273-3894-91B0-F54671C4C861}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{2932897E-3036-43D9-8A64-B06447992065}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{2DE92D29-A042-3C37-BFF8-07C7D8893EFA}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{32B80AD6-1214-45F4-994E-78A5D482C000}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{3A8E103F-B2B7-3BEF-B3B0-88E29B2420E4}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{478CE5D3-D38E-3FFE-8DBE-8C4A0F1C4D8D}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{48B7DA4E-69ED-39E3-BAD5-3E3EFF22CFB0}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{5982F405-44E4-3BBB-BAC4-CF8141CBBC5C}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{5D8C3CC3-3C05-38A1-B244-924A23115FE9}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{641593AF-D9FD-30F7-B783-36E16F7A2E08}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{711FC48A-1356-3932-94D8-A8B733DBC7E4}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{72227B7F-1F02-3560-95F5-592E68BACC0C}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{7B5E8CE3-4722-4C0E-A236-A6FF731BEF37}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{890D4F59-5ED0-3CB4-8E0E-74A5A86E7ED0}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{8C68913C-AC3C-4494-8B9C-984D87C85003}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{8D019513-083F-4AA5-933F-7D43A6DA82C4}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{923F6FB8-A390-370E-A0D2-DD505432481D}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{9BBB26EF-B178-35D6-9D3D-B485F4279FE5}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{A62DDBE0-8D2A-339A-B089-8CBCC5CD322A}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{A82AD04D-0B8E-3A49-947B-6A69A8A9C96D}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{ADEB3CC9-A05D-4FCC-BD09-9025456AA3EA}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{B06D4521-D09C-3F41-8E39-9D784CCA2A75}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{C06DAD42-6F39-4CE1-83CC-9A8B9105E556}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{C2E799D0-43A5-3477-8A98-FC5F3677F35C}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{D16107CD-2AD5-46A8-BA59-303B7C32C500}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{D25B101F-8188-3B43-9D85-201F372BC205}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{D2BA7595-5E44-3F1E-880F-03B3139FA5ED}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{D35F5C81-17D9-3E1C-A1FC-4472542E1D25}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{D8FA96CA-B250-312C-AF34-4FF1DD72589D}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{DAFC1E63-3359-416D-9BC2-E7DCA6F7B0F3}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{DC5E5C44-80FD-3697-9E65-9F286D92F3E7}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{E1B4C9DE-D741-385F-981E-6745FACE6F01}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{E7B623F5-9715-3F9F-A671-D1485A39F8A2}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{ED916A7B-7C68-3198-B87D-2DABC30A5587}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{EFA1BDB2-BB3D-3D9A-8EB5-D0D22E0F64F4}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{F4CBF4DD-F8FE-35BA-BB7E-68304DAAB70B}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{FC32005D-E27C-32E0-ADFA-152F598B75E7}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{2BF2028E-3F3C-4C05-AB45-B2F1DCFE0759}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{4E1E9D45-8BF9-4139-915C-9F83CC3D5921}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{77AA6435-2488-4A94-9FE5-49519DD2ED9B}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{D7EE8177-D51E-4F89-92B6-83EA2EC40800}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{DB538320-D3C5-433C-BCA9-C4081A054FCF}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{8F0B76E1-4E46-427B-B55B-B90593468AC6}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{AE07101B-46D4-4A98-AF68-0333EA26E113}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{687578B9-7132-4A7A-80E4-30EE31099E03}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{D4AAF2A6-F6D1-49A5-BA1A-B20735DF1955}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{6E45F3E8-2683-4824-A6BE-08108022FB36}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{687578B9-7132-4A7A-80E4-30EE31099E03}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{8F0B76E1-4E46-427B-B55B-B90593468AC6}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{D4AAF2A6-F6D1-49A5-BA1A-B20735DF1955}
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B5AF4FDD-1426-417E-916B-28C8626904B8}
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{0EF91EBD-3044-43D3-B648-CA7EDE70859A}
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{006EE092-9658-4FD6-BD8E-A21A348E59F5}
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{364EA597-E728-4CE4-BB4A-ED846EF47970}]
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{AE07101B-46D4-4A98-AF68-0333EA26E113}]
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{687578B9-7132-4A7A-80E4-30EE31099E03}]
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{687578B9-7132-4A7A-80E4-30EE31099E03}]
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks [{687578B9-7132-4A7A-80E4-30EE31099E03}]
Key Deleted : [x64] HKLM\SOFTWARE\Classes\CLSID\{AE07101B-46D4-4A98-AF68-0333EA26E113}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{021B4049-F57D-4565-A693-FD3B04786BFA}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{0362AA09-808D-48E9-B360-FB51A8CBCE09}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{06844020-CD0B-3D3D-A7FE-371153013E49}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{0ADC01BB-303B-3F8E-93DA-12C140E85460}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{10D3722F-23E6-3901-B6C1-FF6567121920}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{1675E62B-F911-3B7B-A046-EB57261212F3}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{192929F2-9273-3894-91B0-F54671C4C861}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{23119123-0854-469D-807A-171568457991}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{2932897E-3036-43D9-8A64-B06447992065}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{2DE92D29-A042-3C37-BFF8-07C7D8893EFA}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{32B80AD6-1214-45F4-994E-78A5D482C000}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{3A8E103F-B2B7-3BEF-B3B0-88E29B2420E4}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{478CE5D3-D38E-3FFE-8DBE-8C4A0F1C4D8D}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{48B7DA4E-69ED-39E3-BAD5-3E3EFF22CFB0}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{5982F405-44E4-3BBB-BAC4-CF8141CBBC5C}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{5D8C3CC3-3C05-38A1-B244-924A23115FE9}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{641593AF-D9FD-30F7-B783-36E16F7A2E08}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{711FC48A-1356-3932-94D8-A8B733DBC7E4}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{72227B7F-1F02-3560-95F5-592E68BACC0C}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{7B5E8CE3-4722-4C0E-A236-A6FF731BEF37}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{890D4F59-5ED0-3CB4-8E0E-74A5A86E7ED0}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{8C68913C-AC3C-4494-8B9C-984D87C85003}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{8D019513-083F-4AA5-933F-7D43A6DA82C4}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{923F6FB8-A390-370E-A0D2-DD505432481D}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{9BBB26EF-B178-35D6-9D3D-B485F4279FE5}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{A62DDBE0-8D2A-339A-B089-8CBCC5CD322A}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{A82AD04D-0B8E-3A49-947B-6A69A8A9C96D}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{ADEB3CC9-A05D-4FCC-BD09-9025456AA3EA}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{B06D4521-D09C-3F41-8E39-9D784CCA2A75}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{C06DAD42-6F39-4CE1-83CC-9A8B9105E556}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{C2E799D0-43A5-3477-8A98-FC5F3677F35C}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{D16107CD-2AD5-46A8-BA59-303B7C32C500}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{D25B101F-8188-3B43-9D85-201F372BC205}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{D2BA7595-5E44-3F1E-880F-03B3139FA5ED}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{D35F5C81-17D9-3E1C-A1FC-4472542E1D25}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{D8FA96CA-B250-312C-AF34-4FF1DD72589D}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{DAFC1E63-3359-416D-9BC2-E7DCA6F7B0F3}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{DC5E5C44-80FD-3697-9E65-9F286D92F3E7}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{E1B4C9DE-D741-385F-981E-6745FACE6F01}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{E7B623F5-9715-3F9F-A671-D1485A39F8A2}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{ED916A7B-7C68-3198-B87D-2DABC30A5587}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{EFA1BDB2-BB3D-3D9A-8EB5-D0D22E0F64F4}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{F4CBF4DD-F8FE-35BA-BB7E-68304DAAB70B}
Key Deleted : [x64] HKLM\SOFTWARE\Classes\Interface\{FC32005D-E27C-32E0-ADFA-152F598B75E7}
Value Deleted : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{AE07101B-46D4-4A98-AF68-0333EA26E113}]
Key Deleted : HKCU\Software\BI
Key Deleted : HKCU\Software\DeviceVM
Key Deleted : HKCU\Software\filescout
Key Deleted : HKCU\Software\Iminent
Key Deleted : HKCU\Software\performersoft llc
Key Deleted : HKCU\Software\AppDataLow\Toolbar
Key Deleted : HKCU\Software\AppDataLow\Software\Crossrider
Key Deleted : HKCU\Software\AppDataLow\Software\MapsGalaxy_39
Key Deleted : HKCU\Software\AppDataLow\Software\PriceGong
Key Deleted : HKCU\Software\AppDataLow\Software\uTorrentControl2
Key Deleted : HKLM\Software\DataMngr
Key Deleted : HKLM\Software\DeviceVM
Key Deleted : HKLM\Software\Iminent
Key Deleted : HKLM\Software\InstallCore
Key Deleted : HKLM\Software\MapsGalaxy_39
Key Deleted : HKLM\Software\SoftwareUpdater
Key Deleted : HKLM\Software\Uniblue\DriverScanner
Key Deleted : HKLM\Software\uTorrentControl2
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SearchTheWebARP
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\uTorrentControl2 Toolbar
Key Deleted : [x64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ZoneAlarm LTD Toolbar
***** [ Browsers ] *****
-\\ Internet Explorer v10.0.9200.16720
Setting Restored : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Main [Start Page]
AdwCleaner[R0].txt - [17900 octets] - [09/10/2013 07:14:37]
AdwCleaner[S0].txt - [17675 octets] - [09/10/2013 07:17:02]
########## EOF - C:\AdwCleaner\AdwCleaner[S0].txt - [17736 octets] ##########
Version: 6.0.4 (10.06.2013:1)
OS: Windows 7 Home Premium x64
Ran by User on 09/10/2013 at 8:28:31.90
~~~ Services
~~~ Registry Values
Successfully repaired: [Registry Value] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchURL\\Default
Successfully repaired: [Registry Value] HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\searchURL\\Default
~~~ Registry Keys
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\mapsgalaxy_39.pseudotransparentplugin
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\mapsgalaxy_39.pseudotransparentplugin.1
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\mapsgalaxy_39.settingsplugin
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\mapsgalaxy_39.settingsplugin.1
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\protector_dll.protectorbho
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\protector_dll.protectorbho.1
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\CLSID\{173A5778-34BF-48A2-8A5E-6963CE922FED}
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\CLSID\{4B7D0B0C-CFF3-49C5-9BC3-FFABC031C822}
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\CLSID\{9B58A6CE-B337-43D5-9C2F-8C6D92FBA094}
Successfully deleted: [Registry Key] HKEY_CLASSES_ROOT\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8FFE}
Successfully deleted: [Registry Key] HKEY_CURRENT_USER\Software\sparktrust
Successfully deleted: [Registry Key] HKEY_LOCAL_MACHINE\Software\sparktrust
~~~ Files
~~~ Folders
Successfully deleted: [Folder] "C:\ProgramData\sparktrust"
Successfully deleted: [Folder] "C:\Users\User\AppData\Roaming\pluswinks"
Successfully deleted: [Folder] "C:\Users\User\AppData\Roaming\sparktrust"
Successfully deleted: [Folder] "C:\Program Files (x86)\myfree codec"
Successfully deleted: [Folder] "C:\Program Files (x86)\smartinline"
Successfully deleted: [Folder] "C:\Program Files (x86)\sparktrust"
Successfully deleted: [Folder] "C:\Users\User\AppData\Roaming\microsoft\windows\start menu\programs\sparktrust"
Successfully deleted: [Empty Folder] C:\Users\User\appdata\local\{236CD94A-B3F1-4A03-A365-A3CB68114245}
Successfully deleted: [Empty Folder] C:\Users\User\appdata\local\{5FE31F2A-2CFB-4018-AC92-F6E9723F9878}
~~~ Event Viewer Logs were cleared
Scan was completed on 09/10/2013 at 8:36:48.08
End of JRT log
Chrisgal
OS : Windows 7
# Likes : 0
Post by Superdave on Wed Oct 09, 2013 7:24 pm
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Captain
Captain
# Likes : 0
Post by Chrisgal on Thu Oct 10, 2013 6:06 am
:\Windows\SysWOW64\drivers\RKHit.sys Win32/Adware.SpywareCease application
C:\Program Files (x86)\FK_Monitor\freeklogger.exe a variant of Win32/KeyLogger.Gratis.A application cleaned by deleting - quarantined
C:\Qoobox\Quarantine\C\Program Files (x86)\Spyware Cease\opfile.dll.vir Win32/Adware.SpywareCease application cleaned by deleting - quarantined
C:\Qoobox\Quarantine\C\Program Files (x86)\Spyware Cease\RkHitApi.dll.vir Win32/Adware.SpywareCease.AA application cleaned by deleting - quarantined
C:\Qoobox\Quarantine\C\Program Files (x86)\Spyware Cease\SCHelper.exe.vir Win32/Adware.SpywareCease.AD application cleaned by deleting - quarantined
C:\Qoobox\Quarantine\C\Program Files (x86)\Spyware Cease\SpywareCease.exe.vir a variant of Win32/Adware.SpywareCease application cleaned by deleting - quarantined
C:\Qoobox\Quarantine\C\Program Files (x86)\Spyware Cease\Update.exe.vir Win32/Adware.SpywareCease.AD application cleaned by deleting - quarantined
C:\Qoobox\Quarantine\C\Program Files (x86)\Spyware Cease\ussafe.dll.vir a variant of Win32/Adware.SpywareCease.AC application cleaned by deleting - quarantined
C:\Windows\System32\drivers\RKHit.sys Win32/Adware.SpywareCease application cleaned by deleting - quarantined
Chrisgal
OS : Windows 7
# Likes : 0
Post by Chrisgal on Thu Oct 10, 2013 6:40 am
THIS IS LOOKING GOOD - I THINK IT MAY BE SORTEDBig Grin
Chrisgal
OS : Windows 7
# Likes : 0
Post by Superdave on Thu Oct 10, 2013 10:28 pm
THIS IS LOOKING GOOD - I THINK IT MAY BE SORTED .
I take it that your problem has been resolved. In that case, let's do some cleanup.
Go to [You must be registered and logged in to see this link.] and get all critical updates.
I suggest using [You must be registered and logged in to see this link.]. WOT is a free Internet security addon for your browser. It will keep you safe from online scams, identity theft, spyware, spam, viruses and unreliable shopping sites. WOT warns you before you interact with a risky website. It's easy and it's free.
Check out [You must be registered and logged in to see this link.] for tips and free tools to help keep you safe in the future.
Captain
Captain
# Likes : 0
Post by Chrisgal on Fri Oct 11, 2013 6:26 am
Dave, Thanks very much for your help. You are a star:thx:
Chrisgal
OS : Windows 7
# Likes : 0
Post by Superdave on Fri Oct 11, 2013 7:15 pm
You're welcome. I will lock this thread. If you need it re-opened, please send me a pm.
Captain
Captain
# Likes : 0
