Virus Issues? Help to ID please
Post by blknblu on Sun Sep 08, 2013 3:24 pm
I have a DELL dimension running XP pro and have picked up a virus which has disabled System Restore and my internet connection for which I have been using a USB wireless adapter (Netgear) My antiVirus software (ParetoLogic) cannot completley remove it it says the file is Win32/Alureon.
I have downloaded the removal tool to a USB thumb drive from my laptop but the dektop Dell wont see or install the thumb drive.
Any suggestions would be appreciated. First Post,Thanks
blknblu
Posts Posts : 4
Joined Joined : 2013-09-08
OS OS : xp pro
Points Points : 11878
Re: Virus Issues? Help to ID please
Post by Superdave on Sun Sep 08, 2013 7:04 pm
Hello and welcome to Computer Hope Forum. My name is Dave. I will be helping you out with your particular problem on your computer.
You may have to use a CD to transfer the programs if it won't recognize your USB ports.
Please download [You must be registered and logged in to see this link.]by Xplode onto your Desktop.
  • Please close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Delete.
  • Confirm each time with OK
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
Please download Malwarebytes Anti-Malware from [You must be registered and logged in to see this link.]
•Temporarily disable your Antivirus and any Antispyware real time protection before performing a scan. Click [You must be registered and logged in to see this link.] link to see a list of security programs that should be disabled and how to disable them.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83161
Post by blknblu on Sat Sep 14, 2013 2:07 pm
Dave, Thanks for the reply. I am on the road all week and will follow up with you suggestions.
blknblu
Posts Posts : 4
OS OS : xp pro
Post by blknblu on Sat Sep 14, 2013 5:26 pm
Dave, Working on it but encountering issues.
Downloaded ADW cleaner and ran scan
saved log file but can't seem to open file from CD with laptop running Windows 7, also saved file as a Word file but can't read or transfer from CD.
Infected PC has no internet
is connected directly to my DSL modem and has link light
Checked connectivity with laptop
Downloaded Antimalware Bytes to CD-RW and then to infected PC and ran.
Database is over 161 days old and can't update from infected PC
During scan message pop up, Antimalware service executable encountered a problem and needs to close, scan still seems to be running under the pop up window. If I close the pop up system becomes unresponsive and freezes
Disabled Microsoft Security Essentials
My Pareto Logic seems to be in Quarantine by ADW cleaner.
JRT opens in CMD prompt. ? pathway.
Rerunning Malware at this time and will let it complete with the pop up open. Any suggestions at this time?
blknblu
Posts Posts : 4
OS OS : xp pro
Post by Superdave on Sat Sep 14, 2013 6:30 pm
During scan message pop up, Antimalware service executable encountered a problem and needs to close, scan still seems to be running under the pop up window. If I close the pop up system becomes unresponsive and freezes.
Please try running it an Safe Mode with Networking. Don't worry if it's not updated at this time.
Captain
Captain
Posts Posts : 4202
Post by blknblu on Sat Sep 14, 2013 7:11 pm
Thanks, Will do.
blknblu
Posts Posts : 4
OS OS : xp pro
