Audio starts at bootup, system crashing
Post by mcp1959 on Wed 04 Sep 2013, 1:22 pm
I have a friend staying at my house, using his laptop on my wireless network.  Two days ago his laptop began behaving strangely and crashing.  The next morning, when he booted it up, multiple audio sources began playing without him starting them, and his laptop slowed to a crawl and then crashed.   He had no kind of protection on his laptop (?!?).  He ran Malwarebytes and found 41 items.  He corrected those and then ran Avast and found a couple files infected.  Now he is getting continuous messages from Avast regarding malicious URLs blocked.    I also received an email from Comcast stating a computer on my network has a bot.  I have told him that once this problem is corrected he is never to have his laptop on my wifi w/o permanent antivirus and malware protection.  Your help is greatly needed and appreciated.
One more question.  I am fully protected w/paid Avast antivirus and use mutiple firewall and anti-malware programs.  Should his laptop be off my network until this issue is resolved?  Again, thank you.
mcp1959
Operating System : XP
Re: Audio starts at bootup, system crashing
Post by Superdave on Thu 05 Sep 2013, 10:28 am
Hello and welcome to Computer Hope Forum. My name is Dave. I will be helping you out with your particular problem on your computer.
Just to be on the safe side please download these scanners and transfer them to the laptop via USB memory stick of CD.
  • Please close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Delete.
  • Confirm each time with OK
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
Link 1
Link 2
Tech Staff
Tech Staff
Post by mcp1959 on Sat 07 Sep 2013, 11:55 am
Hi Dave,
Sorry for the late reply, but my friend bought a new laptop and is ditching the infected one. Sorry to have bothered you, but thanks for your quick reply to original post.
thanks,
mike
mcp1959
Post by Superdave on Sat 07 Sep 2013, 12:26 pm
mcp1959 wrote:Hi Dave,
thanks,
mike
No problem. He can probably wiped the harddrive on that laptop and re-sell it.
Tech Staff
Tech Staff
Post by Sponsored content Today at 9:51 am
