Serious Issue, Need help please...
Post by wooowooo on Thu 15 Aug 2013, 1:35 am
This computer gets so slow you can't do anything. I am not sure what is going on. Please take a look and help. I have enclosed the 3 scan logs below. Thanks in advance.
adw:
# AdwCleaner v3.000 - Report created14/08/2013at01:31:59
# Updated 13/08/2013 by Xplode
# Operating System : Microsoft Windows XP Service Pack 3 (32 bits)
# Username : Station - USER-EF1572EA42
# Running from : C:\Documents and Settings\Station\Desktop\adwcleaner.exe
***** [ Services ] *****
***** [ Files / Folders ] *****
Folder Deleted : C:\Documents and Settings\All Users\Application Data\boost_interprocess
Folder Deleted : C:\Documents and Settings\All Users\Application Data\Viewpoint
Folder Deleted : C:\DOCUME~1\Station\LOCALS~1\Temp\AirInstaller
Folder Deleted : C:\Documents and Settings\Station\Application Data\Viewpoint
***** [ Shortcuts ] *****
***** [ Registry ] *****
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{0E3A2ABE-A449-4B98-9F60-1B4B56FC7D26}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{1E6F8D5A-ADD1-4D13-9474-E93CB3A33A64}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{3E1070CF-AD16-42E1-99C6-A6CAC453C634}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{4C06AA53-0EC2-4C46-AD95-2438EA177D7D}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{54DD3197-E6DB-432D-AC39-2B08C3034744}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{899AA96C-A74E-46B3-A815-349D84F44552}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{98447D7E-01EE-4BC4-893B-B8FBB080C6EC}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{CC45D147-2309-4FC7-B4CF-7B3CA6F87EBE}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{D7861D39-E9E8-449F-A466-BFED73CDD2A3}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{E62F2185-9495-422C-B8A0-AC5E23AA5EA8}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{1422EC71-AEF4-421F-98DC-1FEF299BB124}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{E2B9E510-EC1B-4806-AF06-FC9231980E3C}
Value Deleted : HKLM\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List [C:\Program Files\Mudlogging Systems\MControl\Version 2.6.3\mcontrol.exe]
***** [ Browsers ] *****
-\\ Internet Explorer v8.0.6001.18702
Setting Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Search [CustomizeSearch] - [You must be registered and logged in to see this link.]
Setting Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Search [SearchAssistant] - [You must be registered and logged in to see this link.]
-\\ Mozilla Firefox v22.0 (en-US)
[ File : C:\Documents and Settings\Station\Application Data\Mozilla\Firefox\Profiles\jziphf31.default\prefs.js ]
[OK] No bad entry found.
AdwCleaner[0].txt - [2504 octets] - [14/08/2013 01:32:00]
########## EOF - C:\AdwCleaner\AdwCleaner[0].txt - [2563 octets] ##########
malware
Malwarebytes Anti-Malware (Trial) 1.75.0.1300
Database version: v2013.08.12.07
Windows XP Service Pack 3 x86 NTFS
Station :: USER-EF1572EA42 [administrator]
Protection: Enabled
8/14/2013 1:45:59 AM
MBAM-log-2013-08-14 (04-07-12).txt
Scan type: Full scan (C:\|E:\|)
Scan options disabled: P2P
Objects scanned: 252164
Time elapsed: 2 hour(s), 20 minute(s), 54 second(s)
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 1
C:\System Volume Information\_restore{48A46F19-9EE6-46E7-B9D2-9EEC1552C69E}\RP1287\A0126086.exe (PUP.Optional.AirInstaller) -> No action taken.
(end)
sec check
Results of screen317's Security Check version 0.99.72
Internet Explorer 8
Windows Firewall Disabled!
Avira Free Antivirus
Microsoft Security Essentials
Avira successfully updated!
Malwarebytes Anti-Malware version 1.75.0.1300
Java 7 Update 25
Java(TM) SE Runtime Environment 6 Update 1
Java(TM) 6 Update 7
Adobe Flash Player 11.8.800.94
Adobe Reader 8 Adobe Reader out of Date!
Mozilla Firefox 22.0 Firefox out of Date!
Microsoft Security Essentials MSMpEng.exe
Microsoft Security Essentials msseces.exe
Malwarebytes Anti-Malware mbamservice.exe
Malwarebytes Anti-Malware mbamgui.exe
Malwarebytes Anti-Malware mbam.exe
Avira Antivir avgnt.exe
Avira Antivir avguard.exe
Malwarebytes' Anti-Malware mbamscheduler.exe
Total Fragmentation on Drive C:: 7%
wooowooo
Rookie Surfer
Rookie Surfer
Operating System : xp
Re: Serious Issue, Need help please...
Post by Superdave on Thu 15 Aug 2013, 6:21 am
Please run MBAM again and remove the infections.
The Security check shows you have two AV's on your computer; Avira Free Antivirus and Microsoft Security Essentials. You must make sure that only one AV is enabled at any time on your computer otherwise, they will conflict.
If your version of Windows defaults to you download folder you will need to copy it to your desktop.
Link 1
Link 2
Link 3
To prevent your anti-virus application interfering with ComboFix we need to disable it. See here for a tutorial regarding how to do so if you are unsure.
Tech Staff
Tech Staff
Post by wooowooo on Thu 15 Aug 2013, 9:47 pm
Thanks much!
Database version: v2013.08.14.02
Protection: Enabled
8/15/2013 12:38:26 AM
mbam-log-2013-08-15 (00-38-26).txt
Objects scanned: 253302
Time elapsed: 1 hour(s), 49 minute(s), 58 second(s)
Folders Detected: 0
Files Detected: 1
C:\System Volume Information\_restore{48A46F19-9EE6-46E7-B9D2-9EEC1552C69E}\RP1287\A0126086.exe (PUP.Optional.AirInstaller) -> Quarantined and deleted successfully.
(end)
Version: 5.4.5 (08.13.2013:1)
OS: Microsoft Windows XP x86
Ran by Station on Thu 08/15/2013 at 5:01:01.43
~~~ Services
~~~ Registry Values
Successfully repaired: [Registry Value] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}\\DisplayName
Successfully repaired: [Registry Value] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}\\URL
Successfully repaired: [Registry Value] HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}\\DisplayName
Successfully repaired: [Registry Value] HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}\\URL
~~~ Registry Keys
Successfully deleted: [Registry Key] HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Successfully deleted: [Registry Key] HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
~~~ Files
~~~ Folders
~~~ FireFox
Emptied folder: C:\Documents and Settings\Station\Application Data\mozilla\firefox\profiles\jziphf31.default\minidumps [3 files]
Scan was completed on Thu 08/15/2013 at 5:04:27.85
End of JRT log
ComboFix 13-08-14.02 - Station 08/15/2013 5:17.1.2 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.503.243 [GMT -5:00]
Running from: c:\documents and settings\Station\Desktop\ComboFix.exe
AV: Avira Desktop *Disabled/Updated* {AD166499-45F9-482A-A743-FDD3350758C7}
AV: Microsoft Security Essentials *Disabled/Updated* {EDB4FA23-53B8-4AFA-8C5D-99752CCA7095}
c:\documents and settings\All Users\Application Data\TEMP
c:\documents and settings\All Users\SPL411.tmp
c:\documents and settings\Station\WINDOWS
c:\windows\SET405.tmp
c:\windows\SET4B9.tmp
c:\windows\system32\_004465_.tmp.dll
c:\windows\system32\_004466_.tmp.dll
c:\windows\system32\_004467_.tmp.dll
c:\windows\system32\_004468_.tmp.dll
c:\windows\system32\_004475_.tmp.dll
c:\windows\system32\_004476_.tmp.dll
c:\windows\system32\_004477_.tmp.dll
c:\windows\system32\_004478_.tmp.dll
c:\windows\system32\_004480_.tmp.dll
c:\windows\system32\_004481_.tmp.dll
c:\windows\system32\_004484_.tmp.dll
c:\windows\system32\_004485_.tmp.dll
c:\windows\system32\_004487_.tmp.dll
c:\windows\system32\_004488_.tmp.dll
c:\windows\system32\_004489_.tmp.dll
c:\windows\system32\_004491_.tmp.dll
c:\windows\system32\_004492_.tmp.dll
c:\windows\system32\_004494_.tmp.dll
c:\windows\system32\_004495_.tmp.dll
c:\windows\system32\_004499_.tmp.dll
c:\windows\system32\_004500_.tmp.dll
c:\windows\system32\_004502_.tmp.dll
c:\windows\system32\_004505_.tmp.dll
c:\windows\system32\_004507_.tmp.dll
c:\windows\system32\_004508_.tmp.dll
c:\windows\system32\_004509_.tmp.dll
c:\windows\system32\_004510_.tmp.dll
c:\windows\system32\_004511_.tmp.dll
c:\windows\system32\_004514_.tmp.dll
c:\windows\system32\_004515_.tmp.dll
c:\windows\system32\_004516_.tmp.dll
c:\windows\system32\_004517_.tmp.dll
c:\windows\system32\_004518_.tmp.dll
c:\windows\system32\_004523_.tmp.dll
c:\windows\system32\_004525_.tmp.dll
c:\windows\system32\_004526_.tmp.dll
c:\windows\system32\ctfmon(2).exe
c:\windows\system32\ctfmon(3).exe
c:\windows\system32\HFX308.tmp
c:\windows\system32\HFX3A4.tmp
c:\windows\system32\SET1C4.tmp
c:\windows\system32\SET1C5.tmp
c:\windows\system32\SET1C7.tmp
c:\windows\system32\SET1C9.tmp
c:\windows\system32\SET1CB.tmp
c:\windows\system32\SET1D2.tmp
c:\windows\system32\SET1D3.tmp
c:\windows\system32\SET1D6.tmp
c:\windows\system32\SET1E1.tmp
c:\windows\system32\SET1E3.tmp
c:\windows\system32\SET1E4.tmp
c:\windows\system32\SET1E5.tmp
c:\windows\system32\SET1E6.tmp
c:\windows\system32\SET1E7.tmp
c:\windows\system32\SET1E9.tmp
c:\windows\system32\SET1EA.tmp
c:\windows\system32\SET1EB.tmp
c:\windows\system32\SET1EE.tmp
c:\windows\system32\SET1F5.tmp
c:\windows\system32\SET1F6.tmp
c:\windows\system32\SET1F7.tmp
c:\windows\system32\SET1FA.tmp
c:\windows\system32\SET1FC.tmp
c:\windows\system32\SET1FD.tmp
c:\windows\system32\SET203.tmp
c:\windows\system32\SET206.tmp
c:\windows\system32\SET207.tmp
c:\windows\system32\SET209.tmp
c:\windows\system32\SET20E.tmp
c:\windows\system32\SET20F.tmp
c:\windows\system32\SET210.tmp
c:\windows\system32\SET211.tmp
c:\windows\system32\SET212.tmp
c:\windows\system32\SET218.tmp
c:\windows\system32\SET21D.tmp
c:\windows\system32\SET21E.tmp
c:\windows\system32\SET221.tmp
c:\windows\system32\SET224.tmp
c:\windows\system32\SET225.tmp
c:\windows\system32\SET22C.tmp
c:\windows\system32\SET22D.tmp
c:\windows\system32\SET22F.tmp
c:\windows\system32\SET232.tmp
c:\windows\system32\SET23C.tmp
c:\windows\system32\SET23D.tmp
c:\windows\system32\SET240.tmp
c:\windows\system32\SET242.tmp
c:\windows\system32\SET243.tmp
c:\windows\system32\SET245.tmp
c:\windows\system32\SET246.tmp
c:\windows\system32\SET247.tmp
c:\windows\system32\SET24B.tmp
c:\windows\system32\SET257.tmp
c:\windows\system32\SET25C.tmp
c:\windows\system32\SET25E.tmp
c:\windows\system32\SET260.tmp
c:\windows\system32\SET263.tmp
c:\windows\system32\SET266.tmp
c:\windows\system32\SET267.tmp
c:\windows\system32\SET26C.tmp
c:\windows\system32\SET270.tmp
c:\windows\system32\SET271.tmp
c:\windows\system32\SET277.tmp
c:\windows\system32\SET278.tmp
c:\windows\system32\SET279.tmp
c:\windows\system32\SET281.tmp
c:\windows\system32\SET287.tmp
c:\windows\system32\SET288.tmp
c:\windows\system32\SET289.tmp
c:\windows\system32\SET28A.tmp
c:\windows\system32\SET28C.tmp
c:\windows\system32\SET292.tmp
c:\windows\system32\SET29E.tmp
c:\windows\system32\SET2A0.tmp
c:\windows\system32\SET2A2.tmp
c:\windows\system32\SET2A3.tmp
c:\windows\system32\SET2A4.tmp
c:\windows\system32\SET2B1.tmp
c:\windows\system32\SET2B2.tmp
c:\windows\system32\SET2B5.tmp
c:\windows\system32\SET2B7.tmp
c:\windows\system32\SET2BA.tmp
c:\windows\system32\SET2BE.tmp
c:\windows\system32\SET2BF.tmp
c:\windows\system32\SET2C0.tmp
c:\windows\system32\SET2C1.tmp
c:\windows\system32\SET2C2.tmp
c:\windows\system32\SET2C3.tmp
c:\windows\system32\SET2C4.tmp
c:\windows\system32\SET2C5.tmp
c:\windows\system32\SET2C6.tmp
c:\windows\system32\SET2C7.tmp
c:\windows\system32\SET2C9.tmp
c:\windows\system32\SET2CA.tmp
c:\windows\system32\SET2CB.tmp
c:\windows\system32\SET2CC.tmp
c:\windows\system32\SET2CD.tmp
c:\windows\system32\SET2CE.tmp
c:\windows\system32\SET2D0.tmp
c:\windows\system32\SET2D1.tmp
c:\windows\system32\SET2D2.tmp
c:\windows\system32\SET2D3.tmp
c:\windows\system32\SET2D4.tmp
c:\windows\system32\SET2D5.tmp
c:\windows\system32\SET2D6.tmp
c:\windows\system32\SET2D7.tmp
c:\windows\system32\SET2D8.tmp
c:\windows\system32\SET2D9.tmp
c:\windows\system32\SET2DA.tmp
c:\windows\system32\SET2DB.tmp
c:\windows\system32\SET2DC.tmp
c:\windows\system32\SET2DD.tmp
c:\windows\system32\SET2DE.tmp
c:\windows\system32\SET2DF.tmp
c:\windows\system32\SET2E0.tmp
c:\windows\system32\SET2E2.tmp
c:\windows\system32\SET2E3.tmp
c:\windows\system32\SET2E4.tmp
c:\windows\system32\SET2E6.tmp
c:\windows\system32\SET2E7.tmp
c:\windows\system32\SET2E8.tmp
c:\windows\system32\SET2E9.tmp
c:\windows\system32\SET2EA.tmp
c:\windows\system32\SET2EB.tmp
c:\windows\system32\SET2EC.tmp
c:\windows\system32\SET2ED.tmp
c:\windows\system32\SET2EE.tmp
c:\windows\system32\SET2EF.tmp
c:\windows\system32\SET2F0.tmp
c:\windows\system32\SET2F1.tmp
c:\windows\system32\SET2F2.tmp
c:\windows\system32\SET2F3.tmp
c:\windows\system32\SET2F4.tmp
c:\windows\system32\SET2F5.tmp
c:\windows\system32\SET2F6.tmp
c:\windows\system32\SET2F7.tmp
c:\windows\system32\SET2F8.tmp
c:\windows\system32\SET2F9.tmp
c:\windows\system32\SET2FA.tmp
c:\windows\system32\SET2FB.tmp
c:\windows\system32\SET2FC.tmp
c:\windows\system32\SET2FD.tmp
c:\windows\system32\SET2FE.tmp
c:\windows\system32\SET2FF.tmp
c:\windows\system32\SET300.tmp
c:\windows\system32\SET301.tmp
c:\windows\system32\SET302.tmp
c:\windows\system32\SET303.tmp
c:\windows\system32\SET304.tmp
c:\windows\system32\SET306.tmp
c:\windows\system32\SET309.tmp
c:\windows\system32\SET30A.tmp
c:\windows\system32\SET30B.tmp
c:\windows\system32\SET30C.tmp
c:\windows\system32\SET30D.tmp
c:\windows\system32\SET30E.tmp
c:\windows\system32\SET30F.tmp
c:\windows\system32\SET310.tmp
c:\windows\system32\SET311.tmp
c:\windows\system32\SET312.tmp
c:\windows\system32\SET313.tmp
c:\windows\system32\SET314.tmp
c:\windows\system32\SET315.tmp
c:\windows\system32\SET316.tmp
c:\windows\system32\SET317.tmp
c:\windows\system32\SET318.tmp
c:\windows\system32\SET319.tmp
c:\windows\system32\SET31A.tmp
c:\windows\system32\SET31B.tmp
c:\windows\system32\SET31C.tmp
c:\windows\system32\SET31D.tmp
c:\windows\system32\SET31E.tmp
c:\windows\system32\SET31F.tmp
c:\windows\system32\SET320.tmp
c:\windows\system32\SET321.tmp
c:\windows\system32\SET322.tmp
c:\windows\system32\SET323.tmp
c:\windows\system32\SET324.tmp
c:\windows\system32\SET325.tmp
c:\windows\system32\SET326.tmp
c:\windows\system32\SET327.tmp
c:\windows\system32\SET328.tmp
c:\windows\system32\SET329.tmp
c:\windows\system32\SET32A.tmp
c:\windows\system32\SET32B.tmp
c:\windows\system32\SET32C.tmp
c:\windows\system32\SET32D.tmp
c:\windows\system32\SET32E.tmp
c:\windows\system32\SET32F.tmp
c:\windows\system32\SET330.tmp
c:\windows\system32\SET331.tmp
c:\windows\system32\SET332.tmp
c:\windows\system32\SET333.tmp
c:\windows\system32\SET334.tmp
c:\windows\system32\SET335.tmp
c:\windows\system32\SET336.tmp
c:\windows\system32\SET337.tmp
c:\windows\system32\SET338.tmp
c:\windows\system32\SET339.tmp
c:\windows\system32\SET33A.tmp
c:\windows\system32\SET33B.tmp
c:\windows\system32\SET33C.tmp
c:\windows\system32\SET33D.tmp
c:\windows\system32\SET33E.tmp
c:\windows\system32\SET33F.tmp
c:\windows\system32\SET340.tmp
c:\windows\system32\SET342.tmp
c:\windows\system32\SET343.tmp
c:\windows\system32\SET344.tmp
c:\windows\system32\SET345.tmp
c:\windows\system32\SET346.tmp
c:\windows\system32\SET347.tmp
c:\windows\system32\SET348.tmp
c:\windows\system32\SET349.tmp
c:\windows\system32\SET34A.tmp
c:\windows\system32\SET34B.tmp
c:\windows\system32\SET34C.tmp
c:\windows\system32\SET34D.tmp
c:\windows\system32\SET34E.tmp
c:\windows\system32\SET34F.tmp
c:\windows\system32\SET350.tmp
c:\windows\system32\SET352.tmp
c:\windows\system32\SET353.tmp
c:\windows\system32\SET354.tmp
c:\windows\system32\SET355.tmp
c:\windows\system32\SET356.tmp
c:\windows\system32\SET357.tmp
c:\windows\system32\SET358.tmp
c:\windows\system32\SET359.tmp
c:\windows\system32\SET35A.tmp
c:\windows\system32\SET35B.tmp
c:\windows\system32\SET35D.tmp
c:\windows\system32\SET35E.tmp
c:\windows\system32\SET35F.tmp
c:\windows\system32\SET360.tmp
c:\windows\system32\SET361.tmp
c:\windows\system32\SET362.tmp
c:\windows\system32\SET363.tmp
c:\windows\system32\SET364.tmp
c:\windows\system32\SET365.tmp
c:\windows\system32\SET366.tmp
c:\windows\system32\SET367.tmp
c:\windows\system32\SET368.tmp
c:\windows\system32\SET369.tmp
c:\windows\system32\SET36A.tmp
c:\windows\system32\SET36B.tmp
c:\windows\system32\SET36C.tmp
c:\windows\system32\SET36D.tmp
c:\windows\system32\SET36E.tmp
c:\windows\system32\SET36F.tmp
c:\windows\system32\SET370.tmp
c:\windows\system32\SET371.tmp
c:\windows\system32\SET372.tmp
c:\windows\system32\SET373.tmp
c:\windows\system32\SET374.tmp
c:\windows\system32\SET375.tmp
c:\windows\system32\SET376.tmp
c:\windows\system32\SET377.tmp
c:\windows\system32\SET378.tmp
c:\windows\system32\SET379.tmp
c:\windows\system32\SET37A.tmp
c:\windows\system32\SET37C.tmp
c:\windows\system32\SET37D.tmp
c:\windows\system32\SET37E.tmp
c:\windows\system32\SET37F.tmp
c:\windows\system32\SET380.tmp
c:\windows\system32\SET382.tmp
c:\windows\system32\SET383.tmp
c:\windows\system32\SET384.tmp
c:\windows\system32\SET386.tmp
c:\windows\system32\SET387.tmp
c:\windows\system32\SET388.tmp
c:\windows\system32\SET389.tmp
c:\windows\system32\SET38A.tmp
c:\windows\system32\SET38B.tmp
c:\windows\system32\SET38C.tmp
c:\windows\system32\SET38D.tmp
c:\windows\system32\SET38E.tmp
c:\windows\system32\SET38F.tmp
c:\windows\system32\SET390.tmp
c:\windows\system32\SET391.tmp
c:\windows\system32\SET392.tmp
c:\windows\system32\SET393.tmp
c:\windows\system32\SET394.tmp
c:\windows\system32\SET395.tmp
c:\windows\system32\SET396.tmp
c:\windows\system32\SET397.tmp
c:\windows\system32\SET398.tmp
c:\windows\system32\SET399.tmp
c:\windows\system32\SET39A.tmp
c:\windows\system32\SET39B.tmp
c:\windows\system32\SET39C.tmp
c:\windows\system32\SET39D.tmp
c:\windows\system32\SET39E.tmp
c:\windows\system32\SET39F.tmp
c:\windows\system32\SET3A0.tmp
c:\windows\system32\SET3A1.tmp
c:\windows\system32\SET3A2.tmp
c:\windows\system32\SET3A5.tmp
c:\windows\system32\SET3A6.tmp
c:\windows\system32\SET3A7.tmp
c:\windows\system32\SET3A8.tmp
c:\windows\system32\SET3A9.tmp
c:\windows\system32\SET3AA.tmp
c:\windows\system32\SET3AB.tmp
c:\windows\system32\SET3AC.tmp
c:\windows\system32\SET3AD.tmp
c:\windows\system32\SET3AE.tmp
c:\windows\system32\SET3AF.tmp
c:\windows\system32\SET3B0.tmp
c:\windows\system32\SET3B2.tmp
c:\windows\system32\SET3B3.tmp
c:\windows\system32\SET3B4.tmp
c:\windows\system32\SET3B5.tmp
c:\windows\system32\SET3B6.tmp
c:\windows\system32\SET3B7.tmp
c:\windows\system32\SET3B8.tmp
c:\windows\system32\SET3B9.tmp
c:\windows\system32\SET3BA.tmp
c:\windows\system32\SET3BB.tmp
c:\windows\system32\SET3BC.tmp
c:\windows\system32\SET3BD.tmp
c:\windows\system32\SET3BE.tmp
c:\windows\system32\SET3BF.tmp
c:\windows\system32\SET3C0.tmp
c:\windows\system32\SET3C1.tmp
c:\windows\system32\SET3C2.tmp
c:\windows\system32\SET3C3.tmp
c:\windows\system32\SET3C4.tmp
c:\windows\system32\SET3C5.tmp
c:\windows\system32\SET3C6.tmp
c:\windows\system32\SET3C7.tmp
c:\windows\system32\SET3C8.tmp
c:\windows\system32\SET3C9.tmp
c:\windows\system32\SET3CA.tmp
c:\windows\system32\SET3CB.tmp
c:\windows\system32\SET3CC.tmp
c:\windows\system32\SET3CF.tmp
c:\windows\system32\SET3D0.tmp
c:\windows\system32\SET3D1.tmp
c:\windows\system32\SET3D2.tmp
c:\windows\system32\SET3D3.tmp
c:\windows\system32\SET3D5.tmp
c:\windows\system32\SET3D6.tmp
c:\windows\system32\SET3D7.tmp
c:\windows\system32\SET3D8.tmp
c:\windows\system32\SET3D9.tmp
c:\windows\system32\SET3DA.tmp
c:\windows\system32\SET3DB.tmp
c:\windows\system32\SET3DC.tmp
c:\windows\system32\SET3DD.tmp
c:\windows\system32\SET3DE.tmp
c:\windows\system32\SET3DF.tmp
c:\windows\system32\SET3E0.tmp
c:\windows\system32\SET3E1.tmp
c:\windows\system32\SET3E2.tmp
c:\windows\system32\SET3E3.tmp
c:\windows\system32\SET3E4.tmp
c:\windows\system32\SET3E5.tmp
c:\windows\system32\SET3E6.tmp
c:\windows\system32\SET3E7.tmp
c:\windows\system32\SET3E8.tmp
c:\windows\system32\SET3E9.tmp
c:\windows\system32\SET3EA.tmp
c:\windows\system32\SET3EB.tmp
c:\windows\system32\SET3EC.tmp
c:\windows\system32\SET3ED.tmp
c:\windows\system32\SET3EE.tmp
c:\windows\system32\SET3F0.tmp
c:\windows\system32\SET3F1.tmp
c:\windows\system32\SET3F2.tmp
c:\windows\system32\SET3F3.tmp
c:\windows\system32\SET3F4.tmp
c:\windows\system32\SET3F5.tmp
c:\windows\system32\SET3F6.tmp
c:\windows\system32\SET3F7.tmp
c:\windows\system32\SET3F8.tmp
c:\windows\system32\SET3F9.tmp
c:\windows\system32\SET3FA.tmp
c:\windows\system32\SET3FB.tmp
c:\windows\system32\SET3FC.tmp
c:\windows\system32\SET3FD.tmp
c:\windows\system32\SET3FF.tmp
c:\windows\system32\SET400.tmp
c:\windows\system32\SET401.tmp
c:\windows\system32\SET402.tmp
c:\windows\system32\SET406.tmp
c:\windows\system32\SET407.tmp
c:\windows\system32\SET433.tmp
c:\windows\system32\SET43A.tmp
c:\windows\system32\SET43B.tmp
c:\windows\system32\SET43C.tmp
c:\windows\system32\SET43F.tmp
c:\windows\system32\SET440.tmp
c:\windows\system32\SET443.tmp
c:\windows\system32\SET445.tmp
c:\windows\system32\SET446.tmp
c:\windows\system32\SET447.tmp
c:\windows\system32\SET44A.tmp
c:\windows\system32\SET44C.tmp
c:\windows\system32\SET451.tmp
c:\windows\system32\SET452.tmp
c:\windows\system32\SET45A.tmp
c:\windows\system32\SET461.tmp
c:\windows\system32\SET466.tmp
c:\windows\system32\SET469.tmp
c:\windows\system32\SET46C.tmp
c:\windows\system32\SET46E.tmp
c:\windows\system32\SET472.tmp
c:\windows\system32\SET474.tmp
c:\windows\system32\SET475.tmp
c:\windows\system32\SET476.tmp
c:\windows\system32\SET479.tmp
c:\windows\system32\SET47A.tmp
c:\windows\system32\SET47E.tmp
c:\windows\system32\SET47F.tmp
c:\windows\system32\SET488.tmp
c:\windows\system32\SET48B.tmp
c:\windows\system32\SET48F.tmp
c:\windows\system32\SET491.tmp
c:\windows\system32\SET493.tmp
c:\windows\system32\SET62.tmp
c:\windows\system32\SET66.tmp
c:\windows\system32\SET6E.tmp
((((((((((((((((((((((((( Files Created from 2013-07-15 to 2013-08-15 )))))))))))))))))))))))))))))))
2013-08-15 10:00 . 2013-08-15 10:00 -------- d-----w- c:\windows\ERUNT
2013-08-15 07:58 . 2013-07-02 04:54 7143960 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{104E4682-0ED0-4187-89A2-B33535826871}\mpengine.dll
2013-08-14 08:07 . 2013-07-02 04:54 7143960 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\Backup\mpengine.dll
2013-08-14 06:23 . 2013-08-14 06:39 -------- d-----w- C:\AdwCleaner
2013-08-11 16:27 . 2013-08-11 16:27 -------- d-----w- c:\documents and settings\Station\Local Settings\Application Data\Sun
2013-08-11 14:53 . 2013-08-11 14:53 -------- d-----w- c:\documents and settings\Station\Application Data\Avira
2013-08-11 14:36 . 2013-08-11 14:26 37352 ----a-w- c:\windows\system32\drivers\avkmgr.sys
2013-08-11 14:36 . 2013-08-11 14:26 135136 ----a-w- c:\windows\system32\drivers\avipbb.sys
2013-08-11 14:36 . 2013-08-11 14:26 84744 ----a-w- c:\windows\system32\drivers\avgntflt.sys
2013-08-11 14:35 . 2013-08-11 14:39 -------- d-----w- c:\documents and settings\All Users\Application Data\Avira
2013-08-11 14:35 . 2013-08-11 14:35 -------- d-----w- c:\program files\Avira
2013-08-10 15:02 . 2013-08-12 15:15 2472 ----a-w- c:\windows\system32\regHiveData.bin
2013-08-10 12:05 . 2013-08-10 14:33 -------- d-----w- c:\windows\SystemRepair
2013-08-10 11:57 . 2013-08-10 11:57 -------- d-----w- c:\documents and settings\Station\Application Data\AOL
2013-08-10 11:57 . 2013-08-10 11:57 -------- d-----w- c:\documents and settings\All Users\Application Data\AOL Computer Checkup
2013-08-10 11:50 . 2013-08-10 11:50 -------- d-----w- C:\temp
2013-08-10 11:50 . 2013-08-10 15:27 -------- d-----w- c:\program files\AOL Computer Checkup
2013-08-10 11:46 . 2013-08-10 11:56 -------- d-----w- c:\documents and settings\Station\Downloads
2013-08-09 10:06 . 2013-08-09 10:06 -------- d-----w- c:\documents and settings\Station\Application Data\Malwarebytes
2013-08-09 10:06 . 2013-08-09 10:06 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2013-08-09 10:06 . 2013-08-09 10:06 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2013-08-09 10:06 . 2013-04-04 19:50 22856 ----a-w- c:\windows\system32\drivers\mbam.sys
2013-08-06 13:41 . 2013-08-06 13:41 867240 ----a-w- c:\windows\system32\npDeployJava1.dll
2013-08-06 13:41 . 2013-08-06 13:41 94632 ----a-w- c:\windows\system32\WindowsAccessBridge.dll
2013-08-06 13:35 . 2013-08-06 13:35 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee
2013-08-03 12:42 . 2013-08-03 12:42 -------- d-----w- c:\windows\system32\Adobe
2013-07-28 21:40 . 2013-07-28 21:40 -------- d-----w- c:\documents and settings\Station\Local Settings\Application Data\Mozilla
2013-07-28 21:40 . 2013-07-28 21:40 -------- d-----w- c:\program files\Mozilla Maintenance Service
2013-07-28 20:56 . 2013-07-28 20:56 -------- d-----w- C:\logs
2013-07-26 14:30 . 2013-05-02 15:28 238872 ------w- c:\windows\system32\MpSigStub.exe
2013-07-26 13:40 . 2013-07-26 13:40 -------- d-----w- c:\program files\Microsoft Security Client
2013-08-06 13:41 . 2007-06-11 04:59 144896 ----a-w- c:\windows\system32\javacpl.cpl
2013-08-06 13:41 . 2011-08-08 17:46 789416 -c--a-w- c:\windows\system32\deployJava1.dll
2013-07-28 21:49 . 2013-01-08 22:28 692104 -c--a-w- c:\windows\system32\FlashPlayerApp.exe
2013-07-28 21:49 . 2011-08-04 18:13 71048 -c--a-w- c:\windows\system32\FlashPlayerCPLApp.cpl
2013-06-19 02:50 . 2013-06-19 02:50 211560 ----a-w- c:\windows\system32\drivers\MpFilter.sys
2013-06-08 04:55 . 2004-08-04 12:00 385024 ----a-w- c:\windows\system32\html.iec
2013-06-07 21:56 . 2004-08-04 12:00 920064 ----a-w- c:\windows\system32\wininet.dll
2013-06-07 21:56 . 2004-08-04 12:00 43520 ----a-w- c:\windows\system32\licmgr10.dll
2013-06-07 21:56 . 2004-08-04 12:00 1469440 ------w- c:\windows\system32\inetcpl.cpl
2013-06-04 07:23 . 2004-08-04 12:00 562688 ----a-w- c:\windows\system32\qedit.dll
2013-06-04 01:40 . 2011-08-17 09:33 1876736 ----a-w- c:\windows\system32\win32k.sys
2008-03-09 11:15 . 2008-03-09 11:15 4506256 -c--a-w- c:\program files\LimeWireWin.exe
"RTHDCPL"="RTHDCPL.EXE" [2005-05-04 14396416]
"lxdcamon"="c:\program files\Lexmark 1300 Series\lxdcamon.exe" [2007-04-30 20480]
"MSC"="c:\program files\Microsoft Security Client\msseces.exe" [2013-07-18 995184]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2013-03-12 253816]
"MakiwaraNotify"="c:\program files\AOL Computer Checkup\sdccont.exe" [2013-03-13 82296]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2011-08-31 40368]
"avgnt"="c:\program files\Avira\AntiVir Desktop\avgnt.exe" [2013-08-11 345144]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MsMpSvc]
"EnableFirewall"= 0 (0x0)
"c:\\WINDOWS\\system32\\dpvsetup.exe"=
"c:\\WINDOWS\\system32\\lxdccoms.exe"=
"c:\\Program Files\\Lexmark 1300 Series\\lxdcamon.exe"=
"c:\\Program Files\\Lexmark 1300 Series\\App4R.exe"=
"c:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\lxdctime.exe"=
"c:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\lxdcpswx.exe"=
"c:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\lxdcjswx.exe"=
"5001:TCP"= 5001:TCP:MSI MControl Port 5001
"22:TCP"= 22:TCP:MSI SCP Port 22
"3389:TCP"= 3389:TCP:@xpsp2res.dll,-22009
R1 MpKsl047669a3;MpKsl047669a3;c:\documents and settings\All Users\Application Data\Microsoft\Microsoft Antimalware\Definition Updates\{99349241-8D41-49F8-BEC1-A2AD8306123C}\MpKsl047669a3.sys [x]
R2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [2010-02-18 135664]
R2 lxdcCATSCustConnectService;lxdcCATSCustConnectService;c:\windows\System32\spool\DRIVERS\W32X86\3\\lxdcserv.exe [2007-05-25 99248]
R2 MBAMScheduler;MBAMScheduler;c:\program files\Malwarebytes' Anti-Malware\mbamscheduler.exe [2013-04-04 418376]
R3 gupdatem;Google Update Service (gupdatem);c:\program files\Google\Update\GoogleUpdate.exe [2010-02-18 135664]
R3 MBAMSwissArmy;MBAMSwissArmy;c:\windows\system32\drivers\mbamswissarmy.sys [x]
R4 AntiVirWebService;Avira Web Protection;c:\program files\Avira\AntiVir Desktop\AVWEBGRD.EXE [2013-08-11 589368]
S1 avkmgr;avkmgr;c:\windows\system32\DRIVERS\avkmgr.sys [2013-08-11 37352]
S2 AntiVirSchedulerService;Avira Scheduler;c:\program files\Avira\AntiVir Desktop\sched.exe [2013-08-11 84024]
S2 AOL Computer Checkup;AOL Computer Checkup;c:\program files\AOL Computer Checkup\SDCService.exe [2013-03-13 584568]
S2 lxdc_device;lxdc_device;c:\windows\system32\lxdccoms.exe [2007-05-25 537520]
S2 MBAMService;MBAMService;c:\program files\Malwarebytes' Anti-Malware\mbamservice.exe [2013-04-04 701512]
S3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [2013-04-04 22856]
*NewlyCreated* - WS2IFSL
2013-08-15 c:\windows\Tasks\Adobe Flash Player Updater.job
- c:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe [2013-01-08 21:49]
2013-08-15 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-02-18 22:25]
2013-08-15 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2013-08-13 c:\windows\Tasks\MainUIModule_AOL_Computer Checkup_{BDA49F87-1626-484F-AB5B-41EA29B28AD7}.job
- c:\program files\AOL Computer Checkup\sdcCont.exe [2013-03-13 04:41]
2013-08-15 c:\windows\Tasks\Microsoft Antimalware Scheduled Scan.job
- c:\program files\Microsoft Security Client\MpCmdRun.exe [2013-07-18 21:49]
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_950DF09FAB501E03.dll/cmsidewiki.html
LSP: c:\program files\Avira\AntiVir Desktop\avsda.dll
TCP: DhcpNameServer = 192.168.123.254
FF - ProfilePath - c:\documents and settings\Station\Application Data\Mozilla\Firefox\Profiles\jziphf31.default\
HKLM-Run-lxdcmon.exe - c:\program files\Lexmark 1300 Series\lxdcmon.exe
AddRemove-LogView 7 - c:\progra~1\RockWare\LogView7\UNWISE.EXE
Rootkit scan 2013-08-15 05:33
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil32_11_7_700_224_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\LocalServer32]
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil32_11_7_700_224_ActiveX.exe"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\TypeLib]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}]
@="IFlashBroker5"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\TypeLib]
"Version"="1.0"
- - - - - - - > 'lsass.exe'(768)
- - - - - - - > 'explorer.exe'(2288)
c:\program files\Microsoft Security Client\MsMpEng.exe
c:\program files\Avira\AntiVir Desktop\avguard.exe
c:\program files\Java\jre7\bin\jqs.exe
c:\windows\RTHDCPL.EXE
c:\program files\Avira\AntiVir Desktop\avshadow.exe
Completion time: 2013-08-15 05:42:22 - machine was rebooted
ComboFix-quarantined-files.txt 2013-08-15 10:42
Pre-Run: 65,645,334,528 bytes free
Post-Run: 65,721,589,760 bytes free
- - End Of File - - 20ECE7EDCBA9C02F8A6CF9970309FEAB
8F558EB6672622401DA993E1E865C861
wooowooo
Rookie Surfer
Rookie Surfer
Post by Superdave on Fri 16 Aug 2013, 6:26 am
SysProt Antirootkit
Download
SysProt Antirootkit from the link below (you will find it at the bottom
of the page under attachments, or you can get it from one of the
mirrors).
Unzip it into a folder on your desktop.
  • Double click Sysprot.exe to start the program.
  • Click on the Log tab.
  • In the Write to log box select the following items.
    • Process << Selected
    • Kernel Modules << Selected
    • SSDT << Selected
    • Kernel Hooks << Selected
    • IRP Hooks << NOT Selected
    • Ports << NOT Selected
    • Hidden Files << Selected
  • At the bottom of the page
    • Hidden Objects Only << Selected
  • Click on the Create Log button on the bottom right.
  • After a few seconds a new window should appear.
  • Select Scan Root Drive. Click on the Start button.
  • When it is complete a new window will appear to indicate that the scan is finished.
  • The log will be saved automatically in the same folder Sysprot.exe was extracted to. Open the text file and copy/paste the log here.
  • Download RogueKiller on the desktop
  • Close all the running programs
  • Windows Vista/7 users: right click on RogueKiller.exe, click Run as Administrator
  • Otherwise just double-click on RogueKiller.exe
  • Pre-scan will start. Let it finish.
  • Click on SCAN button.
  • A report (RKreport.txt) should open. Post its content in your next reply. (RKreport could also be found on your desktop)
  • If RogueKiller has been blocked, do not hesitate to try a few times more. If really won't run, rename it to winlogon.exe (or winlogon.com) and try again
Tech Staff
Tech Staff
Post by wooowooo on Fri 16 Aug 2013, 10:39 pm
Thanks.
SysProt AntiRootkit v1.0.1.0
by swatkat
No Hidden Processes found
Kernel Modules:
Module Name: Combo-Fix.sys
Service Name: ---
Module Base: F8622000
Module End: F8631000
Hidden: Yes
Module Name: \SystemRoot\System32\Drivers\dump_atapi.sys
Service Name: ---
Module Base: A8296000
Module End: A82AE000
Hidden: Yes
Module Name: \SystemRoot\System32\Drivers\dump_WMILIB.SYS
Service Name: ---
Module Base: F8B34000
Module End: F8B36000
Hidden: Yes
Module Name: \??\C:\ComboFix\catchme.sys
Service Name: catchme
Module Base: A933A000
Module End: A9342000
Hidden: Yes
Module Name: \??\C:\WINDOWS\system32\Drivers\PROCEXP113.SYS
Service Name: ---
Module Base: F8AEA000
Module End: F8AEC000
Hidden: Yes
SSDT:
Function Name: ZwClose
Address: F8C46DFC
Driver Base: 0
Driver End: 0
Driver Name: _unknown_
Function Name: ZwCreateKey
Address: F8C46DB6
Driver Base: 0
Driver End: 0
Function Name: ZwCreateSection
Address: F8C46E06
Driver Base: 0
Driver End: 0
Function Name: ZwCreateThread
Address: F8C46DAC
Driver Base: 0
Driver End: 0
Function Name: ZwDeleteKey
Address: F8C46DBB
Driver Base: 0
Driver End: 0
Function Name: ZwDeleteValueKey
Address: F8C46DC5
Driver Base: 0
Driver End: 0
Function Name: ZwDuplicateObject
Address: F8C46DF7
Driver Base: 0
Driver End: 0
Function Name: ZwLoadKey
Address: F8C46DCA
Driver Base: 0
Driver End: 0
Function Name: ZwOpenProcess
Address: F8C46D98
Driver Base: 0
Driver End: 0
Function Name: ZwOpenThread
Address: F8C46D9D
Driver Base: 0
Driver End: 0
Function Name: ZwQueryValueKey
Address: F8C46E1F
Driver Base: 0
Driver End: 0
Function Name: ZwReplaceKey
Address: F8C46DD4
Driver Base: 0
Driver End: 0
Function Name: ZwRequestWaitReplyPort
Address: F8C46E10
Driver Base: 0
Driver End: 0
Function Name: ZwRestoreKey
Address: F8C46DCF
Driver Base: 0
Driver End: 0
Function Name: ZwSetContextThread
Address: F8C46E0B
Driver Base: 0
Driver End: 0
Function Name: ZwSetSecurityObject
Address: F8C46E15
Driver Base: 0
Driver End: 0
Function Name: ZwSetValueKey
Address: F8C46DC0
Driver Base: 0
Driver End: 0
Function Name: ZwSystemDebugControl
Address: F8C46E1A
Driver Base: 0
Driver End: 0
Function Name: ZwTerminateProcess
Address: F8C46DA7
Driver Base: 0
Driver End: 0
No Kernel Hooks found
Hidden files/folders:
Object: C:\Documents and Settings\Station\Local Settings\Application Data\Microsoft\Messenger\kahleesmith@yahoo.com\SharingMetadata\lez174u@hotmail.com\DFSR\Staging\CS{E414B05D-D04C-7090-4170-1BD746317038}\01\10-{E414B05D-D04C-7090-4170-1BD746317038}-v1-{27F67BC4
Status: Hidden
Object: C:\Documents and Settings\Station\Local Settings\Application Data\Microsoft\Messenger\kahleesmith@yahoo.com\SharingMetadata\lez174u@hotmail.com\DFSR\Staging\CS{E414B05D-D04C-7090-4170-1BD746317038}\11\11-{27F67BC4-42B9-470F-9773-2C82A8465F3E}-v11-{27F67BC
Status: Hidden
Object: C:\Documents and Settings\Station\Local Settings\Application Data\Microsoft\Messenger\kahleesmith@yahoo.com\SharingMetadata\lez174u@hotmail.com\DFSR\Staging\CS{E414B05D-D04C-7090-4170-1BD746317038}\11\11-{F660EA45-23A3-4513-A096-DDB655C35EEE}-v11-{F660EA4
Status: Hidden
Object: C:\Documents and Settings\Station\Local Settings\Application Data\Microsoft\Messenger\kahleesmith@yahoo.com\SharingMetadata\lez174u@hotmail.com\DFSR\Staging\CS{E414B05D-D04C-7090-4170-1BD746317038}\12\12-{27F67BC4-42B9-470F-9773-2C82A8465F3E}-v12-{27F67BC
Status: Hidden
Object: C:\Documents and Settings\Station\Local Settings\Application Data\Microsoft\Messenger\kahleesmith@yahoo.com\SharingMetadata\lez174u@hotmail.com\DFSR\Staging\CS{E414B05D-D04C-7090-4170-1BD746317038}\12\12-{F660EA45-23A3-4513-A096-DDB655C35EEE}-v12-{F660EA4
Status: Hidden
Object: C:\Documents and Settings\Station\Local Settings\Application Data\Microsoft\Messenger\kahleesmith@yahoo.com\SharingMetadata\lez174u@hotmail.com\DFSR\Staging\CS{E414B05D-D04C-7090-4170-1BD746317038}\13\13-{27F67BC4-42B9-470F-9773-2C82A8465F3E}-v13-{27F67BC
Status: Hidden
Object: C:\Documents and Settings\Station\Local Settings\Application Data\Microsoft\Messenger\kahleesmith@yahoo.com\SharingMetadata\lez174u@hotmail.com\DFSR\Staging\CS{E414B05D-D04C-7090-4170-1BD746317038}\13\13-{F660EA45-23A3-4513-A096-DDB655C35EEE}-v13-{F660EA4
Status: Hidden
Object: C:\Documents and Settings\Station\Local Settings\Application Data\Microsoft\Messenger\kahleesmith@yahoo.com\SharingMetadata\lez174u@hotmail.com\DFSR\Staging\CS{E414B05D-D04C-7090-4170-1BD746317038}\18\18-{27F67BC4-42B9-470F-9773-2C82A8465F3E}-v18-{27F67BC
Status: Hidden
Object: C:\Qoobox\BackEnv\AppData.folder.dat
Status: Access denied
Object: C:\Qoobox\BackEnv\Cache.folder.dat
Object: C:\Qoobox\BackEnv\Cookies.folder.dat
Object: C:\Qoobox\BackEnv\Desktop.folder.dat
Object: C:\Qoobox\BackEnv\Favorites.folder.dat
Object: C:\Qoobox\BackEnv\History.folder.dat
Object: C:\Qoobox\BackEnv\LocalAppData.folder.dat
Object: C:\Qoobox\BackEnv\LocalSettings.folder.dat
Object: C:\Qoobox\BackEnv\Music.folder.dat
Object: C:\Qoobox\BackEnv\NetHood.folder.dat
Object: C:\Qoobox\BackEnv\Personal.folder.dat
Object: C:\Qoobox\BackEnv\Pictures.folder.dat
Object: C:\Qoobox\BackEnv\PrintHood.folder.dat
Object: C:\Qoobox\BackEnv\Profiles.Folder.dat
Object: C:\Qoobox\BackEnv\Profiles.Folder.folder.dat
Object: C:\Qoobox\BackEnv\Programs.folder.dat
Object: C:\Qoobox\BackEnv\Recent.folder.dat
Object: C:\Qoobox\BackEnv\SendTo.folder.dat
Object: C:\Qoobox\BackEnv\SetPath.bat
Object: C:\Qoobox\BackEnv\StartMenu.folder.dat
Object: C:\Qoobox\BackEnv\StartUp.folder.dat
Object: C:\Qoobox\BackEnv\SysPath.dat
Object: C:\Qoobox\BackEnv\Templates.folder.dat
Object: C:\Qoobox\BackEnv\VikPev00
RogueKiller V8.6.5 [Aug 5 2013] by Tigzy
mail : tigzyRKgmailcom
Feedback : [You must be registered and logged in to see this link.]
Website : [You must be registered and logged in to see this link.]
Blog : [You must be registered and logged in to see this link.]
Operating System : Windows XP (5.1.2600 Service Pack 3) 32 bits version
Started in : Normal mode
User : Station [Admin rights]
Mode : Scan -- Date : 08/16/2013 06:35:39
| ARK || FAK || MBR |
¤¤¤ Bad processes : 0 ¤¤¤
¤¤¤ Registry Entries : 3 ¤¤¤
[HJ POL] HKLM\[...]\System : DisableRegistryTools (0) -> FOUND
[HJ SMENU] HKCU\[...]\Advanced : Start_ShowRecentDocs (0) -> FOUND
[HJ DESK] HKLM\[...]\NewStartPanel : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> FOUND
¤¤¤ Scheduled tasks : 0 ¤¤¤
¤¤¤ Startup Entries : 0 ¤¤¤
¤¤¤ Web browsers : 0 ¤¤¤
¤¤¤ Particular Files / Folders: ¤¤¤
¤¤¤ Driver : [LOADED] ¤¤¤
[Address] SSDT[25] : NtClose @ 0x8056F8D7 -> HOOKED (Unknown @ 0xF8C46DFC)
[Address] SSDT[41] : NtCreateKey @ 0x80578ACE -> HOOKED (Unknown @ 0xF8C46DB6)
[Address] SSDT[50] : NtCreateSection @ 0x8056DB66 -> HOOKED (Unknown @ 0xF8C46E06)
[Address] SSDT[53] : NtCreateThread @ 0x80584D59 -> HOOKED (Unknown @ 0xF8C46DAC)
[Address] SSDT[63] : NtDeleteKey @ 0x8059978F -> HOOKED (Unknown @ 0xF8C46DBB)
[Address] SSDT[65] : NtDeleteValueKey @ 0x805983AE -> HOOKED (Unknown @ 0xF8C46DC5)
[Address] SSDT[68] : NtDuplicateObject @ 0x8057F1A9 -> HOOKED (Unknown @ 0xF8C46DF7)
[Address] SSDT[98] : NtLoadKey @ 0x805D526B -> HOOKED (Unknown @ 0xF8C46DCA)
[Address] SSDT[122] : NtOpenProcess @ 0x8057F956 -> HOOKED (Unknown @ 0xF8C46D98)
[Address] SSDT[128] : NtOpenThread @ 0x805E484F -> HOOKED (Unknown @ 0xF8C46D9D)
[Address] SSDT[177] : NtQueryValueKey @ 0x80572F2A -> HOOKED (Unknown @ 0xF8C46E1F)
[Address] SSDT[193] : NtReplaceKey @ 0x8065738E -> HOOKED (Unknown @ 0xF8C46DD4)
[Address] SSDT[200] : NtRequestWaitReplyPort @ 0x8057D153 -> HOOKED (Unknown @ 0xF8C46E10)
[Address] SSDT[204] : NtRestoreKey @ 0x80656F25 -> HOOKED (Unknown @ 0xF8C46DCF)
[Address] SSDT[213] : NtSetContextThread @ 0x806363E9 -> HOOKED (Unknown @ 0xF8C46E0B)
[Address] SSDT[237] : NtSetSecurityObject @ 0x8059DDEB -> HOOKED (Unknown @ 0xF8C46E15)
[Address] SSDT[247] : NtSetValueKey @ 0x805800A4 -> HOOKED (Unknown @ 0xF8C46DC0)
[Address] SSDT[255] : NtSystemDebugControl @ 0x80651C59 -> HOOKED (Unknown @ 0xF8C46E1A)
[Address] SSDT[257] : NtTerminateProcess @ 0x8058E8D1 -> HOOKED (Unknown @ 0xF8C46DA7)
[Address] Shadow SSDT[549] : NtUserSetWindowsHookEx -> HOOKED (Unknown @ 0xF8C46E2E)
[Address] Shadow SSDT[552] : NtUserSetWinEventHook -> HOOKED (Unknown @ 0xF8C46E33)
¤¤¤ External Hives: ¤¤¤
¤¤¤ Infection : ¤¤¤
¤¤¤ HOSTS File: ¤¤¤
--> %SystemRoot%\System32\drivers\etc\hosts
127.0.0.1 localhost
¤¤¤ MBR Check: ¤¤¤
+++++ PhysicalDrive0: HDS728080PLA380 +++++
--- User ---
[MBR] 734ddf7b31ae16d8f72667c3e03763a8
[BSP] dcde2a7c71139517e486d21e60ea0bf2 : Windows XP MBR Code
Partition table:
0 - [ACTIVE] NTFS (0x07) [VISIBLE] Offset (sectors): 63 | Size: 78520 Mo
User = LL1 ... OK!
User = LL2 ... OK!
+++++ PhysicalDrive1: HDS728080PLA380 +++++
--- User ---
[MBR] 659cd89007d3026cf8251ab66a999f1b
[BSP] df4f83c1f72e36823a12b0dfc7617313 : Empty MBR Code
Partition table:
0 - [XXXXXX] FAT32 (0x0b) [VISIBLE] Offset (sectors): 32 | Size: 3818 Mo
User = LL1 ... OK!
Error reading LL2 MBR!
Finished : << RKreport[0]_S_08162013_063539.txt >>
wooowooo
Rookie Surfer
Rookie Surfer
Post by Superdave on Sat 17 Aug 2013, 5:54 am
Please run RogueKiller again and delete those items.
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by wooowooo on Sun 18 Aug 2013, 1:31 am
Thanks for all the help. Here are the requested files.
all ok
# version=8
# OnlineScanner.ocx=1.0.0.6920
# api_version=3.0.2
# EOSSerial=599e1c32fe786f44ab1aad334914b981
# engine=14806
# end=finished
# remove_checked=true
# archives_checked=true
# unwanted_checked=true
# unsafe_checked=true
# antistealth_checked=true
# utc_time=2013-08-17 01:32:16
# local_time=2013-08-17 08:32:16 (-0600, Central Daylight Time)
# country="United States"
# lang=1033
# compatibility_mode=1799 16775165 100 95 0 0 0 0
# compatibility_mode=5892 16777213 88 94 978686 4896220 0 0
# scanned=57239
# found=2
# cleaned=2
# scan_time=5724
sh=4B553651EF610C0614F8393D6C25ABA0A8F09ECA ft=1 fh=92ef1bb072edf568 vn="a variant of Win32/Bundled.Toolbar.Ask.D application (cleaned by deleting (after the next restart) - quarantined)" ac=C fn="C:\Program Files\Avira\AntiVir Desktop\offercast_avirav7_.exe"
sh=EA30F0E44560AD115C15C8C8DBE1BE4F653979D9 ft=1 fh=9e481ab720508ce7 vn="a variant of Win32/Bundled.Toolbar.Ask application (cleaned by deleting - quarantined)" ac=C fn="C:\System Volume Information\_restore{48A46F19-9EE6-46E7-B9D2-9EEC1552C69E}\RP1286\A0126067.exe"
Mode : Remove -- Date : 08/17/2013 06:36:45
| ARK || FAK || MBR |
[HJ POL] HKLM\[...]\System : DisableRegistryTools (0) -> DELETED
[HJ SMENU] HKCU\[...]\Advanced : Start_ShowRecentDocs (0) -> REPLACED (1)
[HJ DESK] HKLM\[...]\NewStartPanel : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> REPLACED (0)
[Address] SSDT[25] : NtClose @ 0x8056F8D7 -> HOOKED (Unknown @ 0xF8BFB70C)
[Address] SSDT[41] : NtCreateKey @ 0x80578ACE -> HOOKED (Unknown @ 0xF8BFB6C6)
[Address] SSDT[50] : NtCreateSection @ 0x8056DB66 -> HOOKED (Unknown @ 0xF8BFB716)
[Address] SSDT[53] : NtCreateThread @ 0x80584D59 -> HOOKED (Unknown @ 0xF8BFB6BC)
[Address] SSDT[63] : NtDeleteKey @ 0x8059978F -> HOOKED (Unknown @ 0xF8BFB6CB)
[Address] SSDT[65] : NtDeleteValueKey @ 0x805983AE -> HOOKED (Unknown @ 0xF8BFB6D5)
[Address] SSDT[68] : NtDuplicateObject @ 0x8057F1A9 -> HOOKED (Unknown @ 0xF8BFB707)
[Address] SSDT[98] : NtLoadKey @ 0x805D526B -> HOOKED (Unknown @ 0xF8BFB6DA)
[Address] SSDT[122] : NtOpenProcess @ 0x8057F956 -> HOOKED (Unknown @ 0xF8BFB6A8)
[Address] SSDT[128] : NtOpenThread @ 0x805E484F -> HOOKED (Unknown @ 0xF8BFB6AD)
[Address] SSDT[177] : NtQueryValueKey @ 0x80572F2A -> HOOKED (Unknown @ 0xF8BFB72F)
[Address] SSDT[193] : NtReplaceKey @ 0x8065738E -> HOOKED (Unknown @ 0xF8BFB6E4)
[Address] SSDT[200] : NtRequestWaitReplyPort @ 0x8057D153 -> HOOKED (Unknown @ 0xF8BFB720)
[Address] SSDT[204] : NtRestoreKey @ 0x80656F25 -> HOOKED (Unknown @ 0xF8BFB6DF)
[Address] SSDT[213] : NtSetContextThread @ 0x806363E9 -> HOOKED (Unknown @ 0xF8BFB71B)
[Address] SSDT[237] : NtSetSecurityObject @ 0x8059DDEB -> HOOKED (Unknown @ 0xF8BFB725)
[Address] SSDT[247] : NtSetValueKey @ 0x805800A4 -> HOOKED (Unknown @ 0xF8BFB6D0)
[Address] SSDT[255] : NtSystemDebugControl @ 0x80651C59 -> HOOKED (Unknown @ 0xF8BFB72A)
[Address] SSDT[257] : NtTerminateProcess @ 0x8058E8D1 -> HOOKED (Unknown @ 0xF8BFB6B7)
[Address] Shadow SSDT[549] : NtUserSetWindowsHookEx -> HOOKED (Unknown @ 0xF8BFB73E)
[Address] Shadow SSDT[552] : NtUserSetWinEventHook -> HOOKED (Unknown @ 0xF8BFB743)
¤¤¤ Infection : ¤¤¤
¤¤¤ HOSTS File: ¤¤¤
127.0.0.1 localhost
¤¤¤ MBR Check: ¤¤¤
--- User ---
Partition table:
User = LL1 ... OK!
User = LL2 ... OK!
--- User ---
Partition table:
User = LL1 ... OK!
Finished : << RKreport[0]_D_08172013_063645.txt >>
RKreport[0]_S_08172013_063530.txt
wooowooo
Rookie Surfer
Rookie Surfer
Post by Superdave on Sun 18 Aug 2013, 3:56 am
That looks good. How's your computer running before we clean up?
Tech Staff
Tech Staff
Post by wooowooo on Sun 18 Aug 2013, 8:40 am
So much better!
wooowooo
Rookie Surfer
Rookie Surfer
Post by Superdave on Sun 18 Aug 2013, 11:59 am
Good, now we can cleanup.
To uninstall ComboFix
Go to Microsoft Windows Update and get all critical updates.
SpywareBlaster- Secure your Internet Explorer to make it harder for ActiveX programs to run on your computer. Also stop certain cookies from being added to your computer when running Mozilla based browsers like Firefox.
* Using SpywareBlaster to protect your computer from Spyware and Malware
* If you don't know what ActiveX controls are, see here
Protect yourself against spyware using the Immunize feature in Spybot - Search & Destroy. Guide: Use Spybot's Immunize Feature to prevent spyware infection in real-time. Note: To ensure you have the latest Immunizations always update Spybot - Search & Destroy before Immunizing. Spybot - Search & Destroy FAQ
Safe Surfing!
Tech Staff
Tech Staff
Post by wooowooo on Tue 20 Aug 2013, 2:46 am
Thank you so much for your time and service.
wooowooo
Rookie Surfer
Rookie Surfer
Post by Superdave on Tue 20 Aug 2013, 6:24 am
You're welcome. I will lock this thread. If you need it re-opened, please send me a pm.
Tech Staff
Tech Staff
Post by Sponsored content Today at 9:46 pm
