Had problem, not sure if fixed, Still some problems
Post by MJ1 on 6th August 2013, 5:50 pm
Originally, virus/spyware hijacked firefox browser, computer was really slow, and virus blocked me from using IOBIT malware fighter or windows defender. So I ran 3 antiviruses AVG (online ESET and one other), ran Malwarebytes (which found something and deleted it), plus some other anti -spyware stuff.
Its now running much faster but still won't allow IOBIT or Windows defender, so I went to delete IOBIT and it says IMFShellEXT.dll can't be deleted as its in use by another program. Please help.
I tried to post the ADW info 4 times here but it would go to a 500 Internal server error.
I now realize it will only take smaller posts, so have attached the ADW.
Problems also with the attachment as it is giving me an error if I try to add a text file over 62kb - so I am adding the first part if you need more I will attach the other 2 parts.
MJ1
Posts Posts : 66
Joined Joined : 2010-01-22
OS OS : Windows 8 64 bit
Points Points : 26036
Re: Had problem, not sure if fixed, Still some problems
Post by Superdave on 6th August 2013, 7:24 pm
Please do not attach your logs unless absolutely necessary. Copy and paste them in your reply(ies) You may have to split them into two or more posts if they're large.
You're not supposed to delete programs. Check in All Programs to see if IOBIT has it's own uninstaller. If not, go to Control Panel, Programs and Features and try installing it there.
Remove the Adware:
  • Please close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Delete.
  • Confirm each time with OK
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
•Temporarily disable your Antivirus and any Antispyware real time protection before performing a scan. Click [You must be registered and logged in to see this link.] link to see a list of security programs that should be disabled and how to disable them.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83211
Post by MJ1 on 6th August 2013, 7:55 pm
# AdwCleaner v2.306 - Logfile created 08/06/2013 at 12:46:19
# Updated 19/07/2013 by Xplode
# Operating system : Windows 7 Home Premium Service Pack 1 (64 bits)
# User : Lee - LEE-PC
# Boot Mode : Normal
# Running from : C:\Users\Lee\Downloads\adwcleaner.exe
# Option [Delete]
***** [Services] *****
Stopped & Deleted : Application Updater
***** [Files / Folders] *****
Deleted on reboot : C:\Program Files (x86)\Common Files\AVG Secure Search
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\04s8hdh7.oldlap\extensions\wtxpcom@mybrowserbar.com
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\245qjfwk.default\extensions\wtxpcom@mybrowserbar.com
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\647bilz0.spirit\extensions\wtxpcom@mybrowserbar.com
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\9b9wxj9e.maybe\extensions\wtxpcom@mybrowserbar.com
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\y4ng5py9.LittleComp\extensions\wtxpcom@mybrowserbar.com
File Deleted : C:\Program Files (x86)\Mozilla Firefox\searchplugins\avg-secure-search.xml
File Deleted : C:\Program Files (x86)\Mozilla Firefox\searchplugins\fcmdSrch.xml
File Deleted : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\searchplugins\Askcom.xml
Folder Deleted : C:\Program Files (x86)\Application Updater
Folder Deleted : C:\Program Files (x86)\AVG Secure Search
Folder Deleted : C:\Program Files (x86)\Common Files\spigot
Folder Deleted : C:\Program Files (x86)\Common Files\Wondershare
Folder Deleted : C:\Program Files (x86)\Conduit
Folder Deleted : C:\Program Files (x86)\IObit Apps Toolbar
Folder Deleted : C:\Program Files (x86)\Wondershare
Folder Deleted : C:\ProgramData\Ask
Folder Deleted : C:\ProgramData\AVG Secure Search
Folder Deleted : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Wondershare
Folder Deleted : C:\ProgramData\Wondershare
Folder Deleted : C:\Users\Lee\AppData\Local\AVG Secure Search
Folder Deleted : C:\Users\Lee\AppData\Local\Conduit
Folder Deleted : C:\Users\Lee\AppData\Local\Google\Chrome\User Data\Default\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
Folder Deleted : C:\Users\Lee\AppData\Local\Wajam
Folder Deleted : C:\Users\Lee\AppData\Local\Wondershare
Folder Deleted : C:\Users\Lee\AppData\LocalLow\AVG Secure Search
Folder Deleted : C:\Users\Lee\AppData\LocalLow\Conduit
Folder Deleted : C:\Users\Lee\AppData\LocalLow\Search Settings
Folder Deleted : C:\Users\Lee\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Wajam
Folder Deleted : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\647bilz0.spirit\StumbleUpon
Folder Deleted : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\ConduitCommon
Folder Deleted : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\extensions\crossriderapp21154@crossrider.com
Folder Deleted : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\jetpack
Folder Deleted : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\Smartbar
Folder Deleted : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\StumbleUpon
Folder Deleted : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\y4ng5py9.LittleComp\extensions\staged
Folder Deleted : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\y4ng5py9.LittleComp\extensions\toolbar@ask.com
Folder Deleted : C:\Users\Lee\AppData\Roaming\OpenCandy
Folder Deleted : C:\Users\Lee\AppData\Roaming\Wondershare
***** [Registry] *****
Key Deleted : HKCU\Software\AppDataLow\Software\Conduit
Key Deleted : HKCU\Software\AppDataLow\Software\Search Settings
Key Deleted : HKCU\Software\AppDataLow\Software\SmartBar
Key Deleted : HKCU\Software\AVG Secure Search
Key Deleted : HKCU\Software\Conduit
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{03EB0E9C-7A91-4381-A220-9B52B641CDB1}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{03EB0E9C-7A91-4381-A220-9B52B641CDB1}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Deleted : HKCU\Software\Search Settings
Key Deleted : HKCU\Software\Softonic
Key Deleted : HKCU\Software\Wajam
Key Deleted : HKCU\Software\YahooPartnerToolbar
Key Deleted : HKLM\Software\Application Updater
Key Deleted : HKLM\Software\AVG Secure Search
Key Deleted : HKLM\Software\AVG Security Toolbar
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{1FAEE6D5-34F4-42AA-8025-3FD8F3EC4634}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{1FDFF5A2-7BB1-48E1-8081-7236812B12B2}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{4D076AB4-7562-427A-B5D2-BD96E19DEE56}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{5B1881D1-D9C7-46DF-B041-1E593282C7D0}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{BB711CB0-C70B-482E-9852-EC05EBD71DBB}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{D616A4A2-7B38-4DBC-9093-6FE7A4A21B17}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\priam_bho.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\ScriptHelper.EXE
Key Deleted : HKLM\SOFTWARE\Classes\AppID\secman.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\ViProtocol.DLL
Key Deleted : HKLM\SOFTWARE\Classes\PROTOCOLS\Handler\viprotocol
Key Deleted : HKLM\SOFTWARE\Classes\ScriptHelper.ScriptHelperApi
Key Deleted : HKLM\SOFTWARE\Classes\ScriptHelper.ScriptHelperApi.1
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{09C554C3-109B-483C-A06B-F14172F1A947}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{11549FE4-7C5A-4C17-9FC3-56FC5162A994}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{74FB6AFD-DD77-4CEB-83BD-AB2B63E63C93}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{92E5039E-FF1E-4AFB-8F24-87592D20C383}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{9C049BA6-EA47-4AC3-AED6-A66D8DC9E1D8}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{C2AC8A0E-E48E-484B-A71C-C7A937FAAB94}
Key Deleted : HKLM\SOFTWARE\Classes\ViProtocol.ViProtocolOLE
Key Deleted : HKLM\SOFTWARE\Classes\ViProtocol.ViProtocolOLE.1
Key Deleted : HKLM\SOFTWARE\Classes\wajam.WajamDownloader
Key Deleted : HKLM\SOFTWARE\Classes\wajam.WajamDownloader.1
Key Deleted : HKLM\Software\Conduit
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Extensions\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\apntoolbarinstaller_RASAPI32
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\apntoolbarinstaller_RASMANCS
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\facemoods_RASAPI32
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\facemoods_RASMANCS
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\wajam_install_RASAPI32
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\wajam_install_RASMANCS
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\WajamUpdater_RASAPI32
Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\WajamUpdater_RASMANCS
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{C6FDD0C3-266A-4DC3-B459-28C697C44CDC}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{F25AF245-4A81-40DC-92F9-E9021F207706}
Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@avg.com/AVG SiteSafety plugin,version=11.0.0.1,application/x-avg-sitesafety-plugin
Key Deleted : HKLM\Software\Search Settings
Key Deleted : HKLM\Software\Wajam
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{03EB0E9C-7A91-4381-A220-9B52B641CDB1}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{20E1481B-E285-4ABC-ADC7-AE24842B81CD}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{3C471948-F874-49F5-B338-4F214A2EE0B1}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{826D7151-8D99-434B-8540-082B8C2AE556}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{933B95E2-E7B7-4AD9-B952-7AC336682AE3}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{B658800C-F66E-4EF3-AB85-6C0C227862A9}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{F25AF245-4A81-40DC-92F9-E9021F207706}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{0194532A-A99C-4337-937E-2A452C8957BE}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{03E2A1F3-4402-4121-8B35-733216D61217}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{9E3B11F6-4179-4603-A71B-A55F4BCB0BEC}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{A9379648-F6EB-4F65-A624-1C10411A15D0}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{C401D2CE-DC27-45C7-BC0C-8E6EA7F085D6}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{F16AB1DB-15C0-4456-A29E-4DF24FB9E3D2}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{E7DF6BFF-55A5-4EB7-A673-4ED3E9456D39}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{F25AF245-4A81-40DC-92F9-E9021F207706}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{03EB0E9C-7A91-4381-A220-9B52B641CDB1}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{95B7759C-8C7F-4BF1-B163-73684A933233}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG Secure Search
Key Deleted : HKLM\SYSTEM\CurrentControlSet\Services\Eventlog\Application\WajamUpdater
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{0194532A-A99C-4337-937E-2A452C8957BE}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{03E2A1F3-4402-4121-8B35-733216D61217}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{9E3B11F6-4179-4603-A71B-A55F4BCB0BEC}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{A9379648-F6EB-4F65-A624-1C10411A15D0}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{C401D2CE-DC27-45C7-BC0C-8E6EA7F085D6}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{F16AB1DB-15C0-4456-A29E-4DF24FB9E3D2}
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{F25AF245-4A81-40DC-92F9-E9021F207706}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{03EB0E9C-7A91-4381-A220-9B52B641CDB1}]
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{0BDA0769-FD72-49F4-9266-E1FB004F4D8F}]
Value Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [SearchSettings]
Value Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [vProt]
Value Deleted : HKLM\SOFTWARE\Mozilla\Firefox\Extensions [Avg@toolbar]
Value Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{03EB0E9C-7A91-4381-A220-9B52B641CDB1}]
Value Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{95B7759C-8C7F-4BF1-B163-73684A933233}]
***** [Internet Browsers] *****
-\\ Internet Explorer v10.0.9200.16635
Replaced : [HKLM\SOFTWARE\Microsoft\Internet Explorer\Search - SearchAssistant] = [You must be registered and logged in to see this link.] --> [You must be registered and logged in to see this link.]
-\\ Mozilla Firefox v22.0 (en-US)
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\04s8hdh7.oldlap\prefs.js
C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\04s8hdh7.oldlap\user.js ... Deleted !
[OK] File is clean.
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\245qjfwk.default\prefs.js
C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\245qjfwk.default\user.js ... Deleted !
[OK] File is clean.
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\647bilz0.spirit\prefs.js
C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\647bilz0.spirit\user.js ... Deleted !
[OK] File is clean.
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\9b9wxj9e.maybe\prefs.js
[OK] File is clean.
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\prefs.js
Deleted : user_pref("CT3035596..clientLogIsEnabled", true);
Deleted : user_pref("CT3035596..clientLogServiceUrl", "hxxp://clientlog.users.conduit.com/ClientDiagnostics.as[...]
Deleted : user_pref("CT3035596..uninstallLogServiceUrl", "hxxp://uninstall.users.conduit.com/Uninstall.asmx/Re[...]
Deleted : user_pref("CT3035596.AboutPrivacyUrl", "hxxp://www.conduit.com/privacy/Default.aspx");
Deleted : user_pref("CT3035596.CT3035596", "CT3035596");
Deleted : user_pref("CT3035596.CurrentServerDate", "20-7-2011");
Deleted : user_pref("CT3035596.DialogsAlignMode", "LTR");
Deleted : user_pref("CT3035596.DialogsGetterLastCheckTime", "Tue Jul 19 2011 23:39:56 GMT-0600 (Mountain Dayli[...]
Deleted : user_pref("CT3035596.DownloadReferralCookieData", "{\"BannerName\":\"\",\"BannerTypeId\":\"\",\"Bann[...]
Deleted : user_pref("CT3035596.FirstServerDate", "20-7-2011");
Deleted : user_pref("CT3035596.FirstTime", true);
Deleted : user_pref("CT3035596.FirstTimeFF3", true);
Deleted : user_pref("CT3035596.FixPageNotFoundErrors", false);
Deleted : user_pref("CT3035596.GroupingServerCheckInterval", 1440);
Deleted : user_pref("CT3035596.GroupingServiceUrl", "hxxp://grouping.services.conduit.com/");
Deleted : user_pref("CT3035596.HasUserGlobalKeys", true);
Deleted : user_pref("CT3035596.HomePageProtectorEnabled", false);
Deleted : user_pref("CT3035596.Initialize", true);
Deleted : user_pref("CT3035596.InitializeCommonPrefs", true);
Deleted : user_pref("CT3035596.InstallationAndCookieDataSentCount", 1);
Deleted : user_pref("CT3035596.InstalledDate", "Tue Jul 19 2011 23:39:58 GMT-0600 (Mountain Daylight Time)");
Deleted : user_pref("CT3035596.IsAlertDBUpdated", true);
Deleted : user_pref("CT3035596.IsGrouping", false);
Deleted : user_pref("CT3035596.IsInitSetupIni", true);
Deleted : user_pref("CT3035596.IsMulticommunity", false);
Deleted : user_pref("CT3035596.IsOpenThankYouPage", true);
Deleted : user_pref("CT3035596.IsOpenUninstallPage", true);
Deleted : user_pref("CT3035596.IsProtectorsInit", true);
Deleted : user_pref("CT3035596.LanguagePackLastCheckTime", "Tue Jul 19 2011 23:39:58 GMT-0600 (Mountain Daylig[...]
Deleted : user_pref("CT3035596.LanguagePackReloadIntervalMM", 1440);
Deleted : user_pref("CT3035596.LanguagePackServiceUrl", "hxxp://translation.users.conduit.com/Translation.ashx[...]
Deleted : user_pref("CT3035596.LastLogin_3.5.0.12", "Tue Jul 19 2011 23:39:55 GMT-0600 (Mountain Daylight Time[...]
Deleted : user_pref("CT3035596.LatestVersion", "3.3.3.2");
Deleted : user_pref("CT3035596.Locale", "en");
Deleted : user_pref("CT3035596.MCDetectTooltipHeight", "83");
Deleted : user_pref("CT3035596.MCDetectTooltipUrl", "hxxp://@EB_INSTALL_LINK@/rank/tooltip/?version=1");
Deleted : user_pref("CT3035596.MCDetectTooltipWidth", "295");
Deleted : user_pref("CT3035596.MyStuffEnabledAtInstallation", true);
Deleted : user_pref("CT3035596.OriginalFirstVersion", "3.5.0.12");
Deleted : user_pref("CT3035596.SearchEngineBeforeUnload", "googe.ca");
Deleted : user_pref("CT3035596.SearchFromAddressBarIsInit", true);
Deleted : user_pref("CT3035596.SearchFromAddressBarUrl", "hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT303[...]
Deleted : user_pref("CT3035596.SearchInNewTabEnabled", true);
Deleted : user_pref("CT3035596.SearchInNewTabIntervalMM", 1440);
Deleted : user_pref("CT3035596.SearchInNewTabLastCheckTime", "Tue Jul 19 2011 23:39:56 GMT-0600 (Mountain Dayl[...]
Deleted : user_pref("CT3035596.SearchInNewTabServiceUrl", "hxxp://newtab.conduit-hosting.com/newtab/?ctid=EB_T[...]
Deleted : user_pref("CT3035596.SearchInNewTabUsageUrl", "hxxp://Usage.Hosting.conduit-services.com/UsageServic[...]
Deleted : user_pref("CT3035596.SearchProtectorEnabled", false);
Deleted : user_pref("CT3035596.SearchProtectorToolbarDisabled", true);
Deleted : user_pref("CT3035596.ServiceMapLastCheckTime", "Tue Jul 19 2011 23:39:52 GMT-0600 (Mountain Daylight[...]
Deleted : user_pref("CT3035596.SettingsLastCheckTime", "Tue Jul 19 2011 23:39:54 GMT-0600 (Mountain Daylight T[...]
Deleted : user_pref("CT3035596.SettingsLastUpdate", "1310989086");
Deleted : user_pref("CT3035596.ThirdPartyComponentsInterval", 504);
Deleted : user_pref("CT3035596.ThirdPartyComponentsLastCheck", "Tue Jul 19 2011 23:39:52 GMT-0600 (Mountain Da[...]
Deleted : user_pref("CT3035596.ThirdPartyComponentsLastUpdate", "1246786978");
Deleted : user_pref("CT3035596.ToolbarShrinkedFromSetup", false);
Deleted : user_pref("CT3035596.TrusteLinkUrl", "hxxp://trust.conduit.com/CT3035596");
Deleted : user_pref("CT3035596.TrustedApiDomains", "conduit.com,conduit-hosting.com,conduit-services.com,clien[...]
Deleted : user_pref("CT3035596.UserID", "UN70485632756481128");
Deleted : user_pref("CT3035596.ValidationData_Toolbar", 2);
Deleted : user_pref("CT3035596.WeatherNetwork", "");
Deleted : user_pref("CT3035596.WeatherPollDate", "Wed Jul 20 2011 00:40:02 GMT-0600 (Mountain Daylight Time)")[...]
Deleted : user_pref("CT3035596.WeatherUnit", "C");
Deleted : user_pref("CT3035596.alertChannelId", "1427173");
Deleted : user_pref("CT3035596.components.1000034", false);
Deleted : user_pref("CT3035596.components.1000082", false);
Deleted : user_pref("CT3035596.components.1000515", false);
Deleted : user_pref("CT3035596.generalConfigFromLogin", "{\"ApiMaxAlerts\":\"12\",\"SocialDomains\":\"social.c[...]
Deleted : user_pref("CT3035596.globalFirstTimeInfoLastCheckTime", "Tue Jul 19 2011 23:39:55 GMT-0600 (Mountain[...]
Deleted : user_pref("CT3035596.homepageProtectorEnableByLogin", true);
Deleted : user_pref("CT3035596.initDone", true);
Deleted : user_pref("CT3035596.isAppTrackingManagerOn", true);
Deleted : user_pref("CT3035596.myStuffEnabled", true);
Deleted : user_pref("CT3035596.myStuffPublihserMinWidth", 400);
Deleted : user_pref("CT3035596.myStuffSearchUrl", "hxxp://Apps.conduit.com/search?q=SEARCH_TERM&SearchSourceOr[...]
Deleted : user_pref("CT3035596.myStuffServiceIntervalMM", 1440);
Deleted : user_pref("CT3035596.myStuffServiceUrl", "hxxp://mystuff.conduit-services.com/MyStuffService.ashx?Co[...]
Deleted : user_pref("CT3035596.searchProtectorDialogDelayInSec", 10);
Deleted : user_pref("CT3035596.searchProtectorEnableByLogin", true);
Deleted : user_pref("CT3035596.testingCtid", "");
Deleted : user_pref("CT3035596.toolbarAppMetaDataLastCheckTime", "Tue Jul 19 2011 23:39:55 GMT-0600 (Mountain [...]
Deleted : user_pref("CT3035596.toolbarContextMenuLastCheckTime", "Tue Jul 19 2011 23:40:03 GMT-0600 (Mountain [...]
Deleted : user_pref("CT3035596.usagesFlag", 2);
Deleted : user_pref("CT3072253.ENABALE_HISTORY", "{\"dataType\":\"string\",\"data\":\"true\"}");
Deleted : user_pref("CT3072253.ENABLE_RETURN_WEB_SEARCH_ON_THE_PAGE", "{\"dataType\":\"string\",\"data\":\"tru[...]
Deleted : user_pref("CT3072253.FirstTime", "true");
Deleted : user_pref("CT3072253.FirstTimeFF3", "true");
Deleted : user_pref("CT3072253.UserID", "UN79232100691103210");
Deleted : user_pref("CT3072253.addressBarTakeOverEnabledInHidden", "true");
Deleted : user_pref("CT3072253.autoDisableScopes", -1);
Deleted : user_pref("CT3072253.cbcountry_001", "CA");
Deleted : user_pref("CT3072253.cbfirsttime", "Thu Aug 02 2012 21:54:09 GMT-0600 (Mountain Daylight Time)");
Deleted : user_pref("CT3072253.defaultSearch", "FALSE");
Deleted : user_pref("CT3072253.embeddedsData", "[{\"appId\":\"129571859753931591\",\"apiPermissions\":{\"cross[...]
Deleted : user_pref("CT3072253.enableAlerts", "always");
Deleted : user_pref("CT3072253.enableSearchFromAddressBar", "FALSE");
Deleted : user_pref("CT3072253.firstTimeDialogOpened", "true");
Deleted : user_pref("CT3072253.fixPageNotFoundError", "true");
Deleted : user_pref("CT3072253.fixPageNotFoundErrorInHidden", "true");
Deleted : user_pref("CT3072253.fixUrls", true);
Deleted : user_pref("CT3072253.installId", "fftC3F9.tmp.exe");
Deleted : user_pref("CT3072253.installType", "XPE");
Deleted : user_pref("CT3072253.isEnableAllDialogs", "{\"dataType\":\"string\",\"data\":\"true\"}");
Deleted : user_pref("CT3072253.isNewTabEnabled", true);
Deleted : user_pref("CT3072253.isPerformedSmartBarTransition", "true");
Deleted : user_pref("CT3072253.isToolbarShrinked", "{\"dataType\":\"string\",\"data\":\"false\"}");
Deleted : user_pref("CT3072253.isWelcomPage", "{\"dataType\":\"boolean\",\"data\":\"true\"}");
Deleted : user_pref("CT3072253.navigationAliasesJson", "{\"EB_SEARCH_TERM\":\"hxxp://dl.rutracker.org/forum/dl[...]
Deleted : user_pref("CT3072253.openThankYouPage", "true");
Deleted : user_pref("CT3072253.openUninstallPage", "FALSE");
Deleted : user_pref("CT3072253.search.searchAppId", "129571859753931591");
Deleted : user_pref("CT3072253.search.searchCount", "0");
Deleted : user_pref("CT3072253.searchInNewTabEnabledInHidden", "true");
Deleted : user_pref("CT3072253.selectToSearchBoxEnabled", "{\"dataType\":\"string\",\"data\":\"true\"}");
Deleted : user_pref("CT3072253.serviceLayer_service_login_isFirstLoginInvoked", "{\"dataType\":\"boolean\",\"d[...]
Deleted : user_pref("CT3072253.serviceLayer_service_login_loginCount", "{\"dataType\":\"number\",\"data\":\"3\[...]
Deleted : user_pref("CT3072253.serviceLayer_service_toolbarGrouping_activeCTID", "{\"dataType\":\"string\",\"d[...]
Deleted : user_pref("CT3072253.serviceLayer_service_toolbarGrouping_activeDownloadUrl", "{\"dataType\":\"strin[...]
Deleted : user_pref("CT3072253.serviceLayer_service_toolbarGrouping_activeToolbarName", "{\"dataType\":\"strin[...]
Deleted : user_pref("CT3072253.serviceLayer_service_toolbarGrouping_invoked", "{\"dataType\":\"string\",\"data[...]
Deleted : user_pref("CT3072253.serviceLayer_services_appTrackingFirstTime_lastUpdate", "1343966047106");
Deleted : user_pref("CT3072253.serviceLayer_services_appTracking_lastUpdate", "1343966048743");
Deleted : user_pref("CT3072253.serviceLayer_services_appsMetadata_lastUpdate", "1343966047160");
Deleted : user_pref("CT3072253.serviceLayer_services_gottenAppsContextMenu_lastUpdate", "1343966048940");
Deleted : user_pref("CT3072253.serviceLayer_services_login_10.10.20.14_lastUpdate", "1343969054033");
Deleted : user_pref("CT3072253.serviceLayer_services_otherAppsContextMenu_lastUpdate", "1343966048855");
Deleted : user_pref("CT3072253.serviceLayer_services_searchAPI_lastUpdate", "1343966046033");
Deleted : user_pref("CT3072253.serviceLayer_services_serviceMap_lastUpdate", "1343966045488");
Deleted : user_pref("CT3072253.serviceLayer_services_toolbarContextMenu_lastUpdate", "1343966048908");
Deleted : user_pref("CT3072253.serviceLayer_services_toolbarSettings_lastUpdate", "1343969053859");
Deleted : user_pref("CT3072253.serviceLayer_services_translation_lastUpdate", "1343966047184");
Deleted : user_pref("CT3072253.settingsINI", true);
Deleted : user_pref("CT3072253.shouldFirstTimeDialog", "false");
Deleted : user_pref("CT3072253.smartbar.CTID", "CT3072253");
Deleted : user_pref("CT3072253.smartbar.Uninstall", "0");
Deleted : user_pref("CT3072253.smartbar.isHidden", true);
Deleted : user_pref("CT3072253.smartbar.toolbarName", "uTorrentControl2 ");
Deleted : user_pref("CT3072253.toolbarBornServerTime", "3-8-2012");
Deleted : user_pref("CT3072253.toolbarCurrentServerTime", "3-8-2012");
Deleted : user_pref("CT3072253.toolbarDisabled", "true");
Deleted : user_pref("CT3072253.url_history0001", "hxxp://www.blackhatteam.com/f51/get-the-best-video-producer-[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://alerts.conduit-services.com/root/1427173/1422828/CA", "\"1-1[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://appsmetadata.toolbar.conduit-services.com/?ctid=CT3035596", [...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://contextmenu.toolbar.conduit-services.com/?name=GottenApps&lo[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://contextmenu.toolbar.conduit-services.com/?name=OtherApps&loc[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://contextmenu.toolbar.conduit-services.com/?name=SharedApps&lo[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://contextmenu.toolbar.conduit-services.com/?name=Toolbar&local[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://dynamicdialogs.alert.conduit-services.com/alert/dlg.pkg", "\[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://dynamicdialogs.toolbar.conduit-services.com/DLG.pkg?ver=3.5.[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://servicemap.conduit-services.com/Toolbar/?ownerId=CT3035596",[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://settings.toolbar.search.conduit.com/root/CT3035596/CT3035596[...]
Deleted : user_pref("CommunityToolbar.ETag.hxxp://translation.toolbar.conduit-services.com/?locale=en", "\"634[...]
Deleted : user_pref("CommunityToolbar.LatestLibsPath", "file:///C:\\Users\\Lee\\AppData\\Roaming\\Mozilla\\Fir[...]
Deleted : user_pref("CommunityToolbar.LatestToolbarVersionInstalled", "3.5.0.12");
Deleted : user_pref("CommunityToolbar.SearchFromAddressBarSavedUrl", "");
Deleted : user_pref("CommunityToolbar.ToolbarsList", "CT3035596");
Deleted : user_pref("CommunityToolbar.ToolbarsList2", "CT3035596");
Deleted : user_pref("CommunityToolbar.ToolbarsList4", "CT3035596");
Deleted : user_pref("CommunityToolbar.globalUserId", "b81f8734-4a32-4230-b269-7f7dcaeaa615");
Deleted : user_pref("CommunityToolbar.isAlertUrlAddedToFeedItemTable", true);
Deleted : user_pref("CommunityToolbar.isClickActionAddedToFeedItemTable", true);
Deleted : user_pref("CommunityToolbar.notifications.alertDialogsGetterLastCheckTime", "Tue Jul 19 2011 23:39:5[...]
Deleted : user_pref("CommunityToolbar.notifications.alertEnabled", false);
Deleted : user_pref("CommunityToolbar.notifications.alertInfoInterval", 60);
Deleted : user_pref("CommunityToolbar.notifications.alertInfoLastCheckTime", "Tue Jul 19 2011 23:40:05 GMT-060[...]
Deleted : user_pref("CommunityToolbar.notifications.clientsServerUrl", "hxxp://alert.client.conduit.com");
Deleted : user_pref("CommunityToolbar.notifications.firstTimeAlertShown", true);
Deleted : user_pref("CommunityToolbar.notifications.locale", "en");
Deleted : user_pref("CommunityToolbar.notifications.loginIntervalMin", 1440);
Deleted : user_pref("CommunityToolbar.notifications.loginLastCheckTime", "Tue Jul 19 2011 23:39:53 GMT-0600 (M[...]
Deleted : user_pref("CommunityToolbar.notifications.loginLastUpdateTime", "1305622559");
Deleted : user_pref("CommunityToolbar.notifications.messageShowTimeSec", 20);
Deleted : user_pref("CommunityToolbar.notifications.servicesServerUrl", "hxxp://alert.services.conduit.com");
Deleted : user_pref("CommunityToolbar.notifications.showTrayIcon", false);
Deleted : user_pref("CommunityToolbar.notifications.userCloseIntervalMin", 300);
Deleted : user_pref("CommunityToolbar.notifications.userId", "23b29836-45aa-43c0-bfd9-e56f231976f0");
Deleted : user_pref("extensions.crossriderapp21154.21154.InstallationThankYouPage", false);
Deleted : user_pref("extensions.crossriderapp21154.21154.InstallationTime", 1375051903);
Deleted : user_pref("extensions.crossriderapp21154.21154.active", true);
Deleted : user_pref("extensions.crossriderapp21154.21154.addressbar", "");
Deleted : user_pref("extensions.crossriderapp21154.21154.addressbarenhanced", "");
Deleted : user_pref("extensions.crossriderapp21154.21154.asyncdb_dbWasSet", true);
Deleted : user_pref("extensions.crossriderapp21154.21154.asyncinternaldb_dbWasSet", true);
Deleted : user_pref("extensions.crossriderapp21154.21154.backgroundjs", "\n\n/********************************[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.backgroundver", 26);
Deleted : user_pref("extensions.crossriderapp21154.21154.can_run_bg_code", true);
Deleted : user_pref("extensions.crossriderapp21154.21154.certdomaininstaller", "");
Deleted : user_pref("extensions.crossriderapp21154.21154.changeprevious", false);
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FS_button_status.expiration", "Fri Feb 01 2030[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FS_button_status.value", "1");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519028475.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519028475.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519028546.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519028546.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375051903760.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375051903760.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519045481.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519045481.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519045592.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519045592.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519120605.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519120605.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750521380313.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750521380313.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750521962804.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750521962804.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750522829145.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750522829145.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750523188596.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750523188596.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750536521467.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750536521467.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750537069766.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750537069766.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750543429331.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750543429331.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750543648412.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750543648412.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750547165197.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750547165197.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750555767625.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750555767625.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750556201146.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750556201146.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750560059446.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750560059446.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750564396396.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750564396396.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750581782154.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750581782154.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750582995435.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750582995435.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750585949045.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750585949045.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750587392695.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750587392695.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750588364336.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750588364336.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750590111646.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750590111646.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750590565326.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750590565326.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750590769746.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750590769746.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750591216516.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750591216516.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750593978187.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750593978187.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750594889326.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750594889326.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750605595456.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750605595456.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750606752846.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750606752846.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750608013517.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750608013517.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750608863938.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750608863938.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750613319585.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750613319585.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750625420834.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750625420834.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750638508283.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750638508283.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750638890884.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750638890884.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750644674483.expiration", "Fri Feb 01[...]
MJ1
Posts Posts : 66
Post by MJ1 on 6th August 2013, 7:56 pm
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750644674483.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750646433414.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750646433414.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750649236563.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750649236563.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750649850954.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750649850954.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750650868865.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750650868865.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750657499465.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750657499465.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750665814884.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750665814884.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750667478805.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750667478805.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750667823936.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750667823936.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750668159756.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750668159756.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750668460096.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750668460096.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750668817216.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750668817216.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750669509386.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750669509386.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750669953976.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750669953976.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750670146066.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750670146066.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750670841626.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750670841626.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750671561506.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750671561506.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750672406426.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750672406426.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750672793357.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750672793357.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750673322416.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750673322416.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750693982577.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750693982577.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750696682798.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750696682798.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750699222258.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750699222258.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750699776699.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750699776699.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137507017833010.expiration", "Fri Feb 0[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137507017833010.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137507112879211.expiration", "Fri Feb 0[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137507112879211.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137507116744912.expiration", "Fri Feb 0[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137507116744912.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750712763225.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750712763225.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750714109405.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750714109405.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750727974206.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750727974206.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750732265683.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750732265683.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750732986754.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750732986754.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750736980454.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750736980454.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750748295944.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750748295944.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750748533124.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750748533124.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750767128425.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750767128425.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750769627915.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750769627915.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750769939506.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750769939506.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750773866647.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750773866647.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750778398238.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750778398238.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750781182096.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750781182096.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750783390014.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750783390014.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750783562255.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750783562255.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750784513655.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750784513655.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750785759826.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750785759826.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750789965107.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750789965107.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750796325259.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750796325259.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375081709893.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375081709893.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750817273521.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750817273521.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750817489112.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750817489112.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750819245293.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750819245293.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750821548754.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750821548754.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750822210725.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750822210725.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750825377746.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750825377746.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375083851050.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375083851050.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375122324429.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375122324429.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751226959301.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751226959301.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751261451761.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751261451761.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751267416382.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751267416382.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751272823093.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751272823093.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751274245384.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751274245384.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751277774254.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751277774254.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751294878634.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751294878634.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751295824195.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751295824195.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751296001876.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751296001876.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751296274576.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751296274576.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751301845775.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751301845775.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751302120695.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751302120695.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751303992266.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751303992266.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304179837.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304179837.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304198888.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304198888.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304249049.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304249049.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137513042530010.expiration", "Fri Feb 0[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137513042530010.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304639326.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304639326.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304685017.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304685017.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304687788.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304687788.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304906635.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304906635.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304950756.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304950756.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304953597.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751304953597.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751305061315.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751305061315.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751305100616.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751305100616.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751305116337.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751305116337.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751305318948.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751305318948.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751306301124.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751306301124.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751313506002.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751313506002.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751313698893.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751313698893.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751314950054.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751314950054.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751317338421.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751317338421.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375133802248.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375133802248.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751342636961.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751342636961.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751342800162.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751342800162.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751343063013.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751343063013.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751344525594.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751344525594.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751355530973.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751355530973.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375136114283.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375136114283.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375136159042.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375136159042.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751361719821.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751361719821.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751394702502.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751394702502.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751400126233.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751400126233.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751408271342.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751408271342.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751408343353.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751408343353.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751409072624.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751409072624.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751413075202.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751413075202.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751414066783.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751414066783.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751416365992.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751416365992.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751417736942.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751417736942.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751427609231.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751427609231.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751430453162.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751430453162.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751431824833.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751431824833.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751436771712.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751436771712.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751437095213.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751437095213.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751439162071.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751439162071.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751440398952.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751440398952.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375146514047.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375146514047.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375146554321.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375146554321.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375146683221.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375146683221.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751466946811.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751466946811.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375147109822.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375147109822.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751475570951.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751475570951.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375148895358.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375148895358.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751546816731.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751546816731.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751548742302.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751548742302.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751553051992.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751553051992.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751560106452.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751560106452.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375157375995.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375157375995.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751577897561.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751577897561.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751579474252.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751579474252.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751586761173.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751586761173.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751587040394.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751587040394.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751592769494.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751592769494.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751593474605.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751593474605.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751597322476.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751597322476.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751600704456.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751600704456.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751602726256.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751602726256.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751603369887.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751603369887.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751618276357.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751618276357.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751618416037.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751618416037.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751618688597.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751618688597.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751619902167.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751619902167.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751620483827.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751620483827.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751620666157.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751620666157.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751621213935.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751621213935.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751622095106.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751622095106.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751622410196.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751622410196.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751627486306.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751627486306.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751628095216.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751628095216.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751628259966.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751628259966.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751628870126.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751628870126.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751630379756.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751630379756.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751630944477.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751630944477.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751634608687.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751634608687.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751636535737.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751636535737.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751639161207.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751639161207.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751639411968.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751639411968.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751643070578.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751643070578.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751643421938.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751643421938.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751643719408.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751643719408.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751644590638.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751644590638.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751645438319.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751645438319.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751646870979.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751646870979.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751649016759.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751649016759.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137516510990310.expiration", "Fri Feb 0[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137516510990310.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751656370296.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751656370296.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751657195397.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751657195397.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751658283188.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751658283188.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751658877328.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751658877328.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751659286528.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751659286528.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751660174636.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751660174636.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751661288916.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751661288916.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751661710226.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751661710226.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751662110656.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751662110656.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751662683876.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751662683876.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751664165816.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751664165816.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751664609416.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751664609416.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751664832486.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751664832486.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751665206906.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751665206906.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751665874026.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751665874026.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751666354526.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751666354526.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751666548457.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751666548457.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751668210327.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751668210327.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751668841567.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751668841567.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751669299018.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751669299018.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751670144566.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751670144566.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751672212776.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751672212776.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751672619924.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751672619924.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751673357692.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751673357692.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751673776702.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751673776702.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751674771021.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751674771021.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751676455942.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751676455942.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751676630292.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751676630292.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751676918272.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751676918272.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751677308242.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751677308242.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751679135932.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751679135932.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751682475601.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751682475601.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751683878451.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751683878451.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751685910612.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751685910612.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751688586012.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751688586012.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751689174603.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751689174603.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751691304844.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751691304844.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751691920115.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751691920115.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751695161655.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751695161655.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751695541993.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751695541993.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751696746593.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751696746593.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751697729823.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751697729823.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751700079342.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751700079342.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751701463401.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751701463401.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751701605232.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751701605232.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375194378623.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375194378623.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751944394441.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751944394441.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751945050571.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751945050571.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751949047071.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751949047071.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751951511702.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751951511702.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751979964313.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751979964313.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751981215984.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751981215984.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375198510940.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375198510940.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751989587961.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751989587961.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751989965792.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751989965792.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752128252363.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752128252363.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752135385344.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752135385344.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752144294444.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752144294444.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752148863662.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752148863662.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752149908313.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752149908313.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752153284404.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752153284404.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752172494175.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752172494175.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752175272904.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752175272904.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752177682664.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752177682664.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752179427484.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752179427484.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752179780634.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752179780634.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752181871985.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752181871985.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752183450426.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752183450426.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752184902667.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752184902667.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752189076628.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752189076628.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752191623199.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752191623199.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752197676414.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752197676414.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752198715765.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752198715765.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752202805146.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752202805146.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752204126495.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752204126495.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752220984074.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752220984074.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752221379965.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752221379965.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752229461295.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752229461295.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752256120184.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752256120184.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752256398904.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752256398904.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752256915225.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752256915225.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752258328715.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752258328715.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752260254385.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752260254385.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752261326025.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752261326025.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752264373666.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752264373666.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752278090697.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752278090697.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752279597917.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752279597917.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752281685708.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752281685708.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752282737159.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752282737159.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137522867927410.expiration", "Fri Feb 0[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel137522867927410.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752295385697.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752295385697.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375230087999.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375230087999.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375231552546.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375231552546.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752315965691.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752315965691.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752325867392.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752325867392.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752351708422.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752351708422.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752351833033.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752351833033.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752364202903.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752364202903.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752364844294.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752364844294.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752375746945.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752375746945.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752439086152.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752439086152.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752439957682.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752439957682.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752441862283.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752441862283.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752445987874.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752445987874.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752448103425.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752448103425.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752458781505.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752458781505.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752467931506.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752467931506.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752473027285.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752473027285.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752487807345.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752487807345.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752494430496.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752494430496.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752495868687.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752495868687.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752498267608.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752498267608.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752499650465.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752499650465.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752503592006.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752503592006.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752508559987.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752508559987.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752514358515.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752514358515.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752514773236.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752514773236.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752514860457.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752514860457.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375295180086.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375295180086.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752952339321.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752952339321.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752954487731.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752954487731.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752958103762.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752958103762.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752965165423.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752965165423.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752968832292.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752968832292.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752971599383.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752971599383.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752980561813.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13752980561813.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375323881032.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375323881032.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753254163261.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753254163261.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753262973102.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753262973102.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753268764213.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753268764213.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753278624364.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753278624364.value", "0");
MJ1
Posts Posts : 66
Joined Joined : 2010-01-22
OS OS : Windows 8 64 bit
Points Points : 26036
Re: Had problem, not sure if fixed, Still some problems
Post by MJ1 on 6th August 2013, 8:02 pm
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753279870715.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753279870715.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753290006195.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753290006195.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753293798234.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753293798234.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753297308275.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753297308275.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753298745466.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753298745466.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753299145347.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753299145347.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753322734737.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753322734737.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753348302728.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753348302728.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753355881314.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753355881314.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753365641942.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753365641942.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753369158403.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753369158403.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753369873942.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753369873942.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753374702962.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753374702962.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753376645732.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753376645732.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753384352311.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753384352311.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753385347402.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753385347402.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753385885022.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753385885022.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753386291423.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753386291423.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753386615693.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753386615693.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753387464464.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753387464464.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753387591395.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753387591395.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753388722933.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753388722933.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753389363344.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753389363344.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753390176142.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753390176142.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753391516353.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753391516353.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753392339854.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753392339854.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753392560024.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753392560024.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753396523555.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753396523555.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753396941996.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753396941996.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375377042811.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375377042811.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753771765891.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753771765891.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375379542190.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375379542190.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375380482995.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375380482995.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753807106571.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753807106571.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753808263592.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753808263592.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753815111123.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753815111123.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753817382774.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753817382774.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753825611815.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753825611815.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753831514935.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753831514935.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753849542196.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753849542196.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753853415115.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753853415115.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753871473442.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753871473442.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753871677503.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753871677503.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753873267994.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753873267994.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753873681765.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753873681765.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753875900296.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753875900296.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753877334816.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753877334816.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753884153517.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753884153517.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753884470417.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753884470417.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753888612748.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753888612748.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753895217427.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753895217427.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753895548857.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753895548857.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753899987228.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753899987228.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753900402729.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753900402729.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375393917161.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375393917161.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375393917176.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375393917176.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753939843111.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753939843111.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753940443892.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753940443892.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375395373427.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375395373427.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753954532071.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753954532071.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753962286402.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753962286402.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753962353853.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753962353853.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753964004833.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753964004833.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753975881091.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753975881091.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753977016072.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753977016072.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753981521532.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13753981521532.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754023031142.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754023031142.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754027122423.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754027122423.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375402869589.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375402869589.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375403061695.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375403061695.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375403149770.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375403149770.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375418654790.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375418654790.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754186712621.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754186712621.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375418709102.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375418709102.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375419786125.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375419786125.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375420261402.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375420261402.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375420277601.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375420277601.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754207552371.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754207552371.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754208195441.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754208195441.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754219543952.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754219543952.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754220116383.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754220116383.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754222548444.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754222548444.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754222729695.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754222729695.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754223582516.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754223582516.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754227878197.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754227878197.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375426368415.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375426368415.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754264968281.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754264968281.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754265103082.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754265103082.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754279759371.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754279759371.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754283881392.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754283881392.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375466145496.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375466145496.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754664117541.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754664117541.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375466833948.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375466833948.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754675234741.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754675234741.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754675938892.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754675938892.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754678473731.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754678473731.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754678938162.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754678938162.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754681428301.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754681428301.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754685868091.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754685868091.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754686172332.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754686172332.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754686549913.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754686549913.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754695551221.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754695551221.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754697367651.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754697367651.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375471381478.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375471381478.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375488342551.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375488342551.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754884677271.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754884677271.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754885738952.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754885738952.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754891744802.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754891744802.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754893374993.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754893374993.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754898515574.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754898515574.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754899168284.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754899168284.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754904539783.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754904539783.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754906128833.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754906128833.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754906441194.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754906441194.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754907131515.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754907131515.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754909641525.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754909641525.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754910871096.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754910871096.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754914222176.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754914222176.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754923448726.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754923448726.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754925045997.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754925045997.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754925251468.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754925251468.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754926494772.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754926494772.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754937373643.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754937373643.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754937677251.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754937677251.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754939027652.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754939027652.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754939793871.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754939793871.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754939848192.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754939848192.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754939957451.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754939957451.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754940611722.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13754940611722.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375502142583.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375502142583.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375503613309.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375503613309.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755079750211.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755079750211.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755080230642.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755080230642.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755095158341.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755095158341.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755095224262.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755095224262.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755108120313.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755108120313.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755112217514.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755112217514.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375534378472.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375534378472.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375534378654.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375534378654.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375534379682.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375534379682.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755349100211.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755349100211.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755357523232.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755357523232.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375535783635.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375535783635.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755358767291.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755358767291.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375586967912.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375586967912.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755870320741.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755870320741.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755878349022.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755878349022.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755878607893.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755878607893.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755904317623.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755904317623.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755928495251.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755928495251.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375593521688.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375593521688.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375594421566.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375594421566.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755947434901.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13755947434901.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375595638988.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375595638988.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375663930343.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375663930343.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375663930358.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375663930358.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756643089121.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756643089121.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756643365192.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756643365192.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756650945522.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756650945522.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756651411123.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756651411123.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756657114973.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756657114973.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756751274493.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756751274493.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756769826062.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756769826062.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756771684463.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756771684463.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756781351894.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756781351894.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756784088945.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756784088945.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756790548896.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756790548896.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756799239787.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756799239787.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756814350385.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756814350385.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756814679225.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756814679225.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756815602156.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756815602156.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756818508307.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756818508307.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756819679002.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13756819679002.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375718809318.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375718809318.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375770759037.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375770759037.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375770759517.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375770759517.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757708229761.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757708229761.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757723987732.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757723987732.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757725123003.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757725123003.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757729814723.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757729814723.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757745161463.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757745161463.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757751691882.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757751691882.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757752716243.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757752716243.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757756178294.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757756178294.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757757893484.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757757893484.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757758186305.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757758186305.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757762331065.expiration", "Fri Feb 01[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13757762331065.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375800613448.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375800613448.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375803811302.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375803811302.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375803811404.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375803811404.value", "0");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.InstallationTime.expiration", "Fri Feb 01 2030[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.InstallationTime.value", "1375051903");
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.first_load.expiration", "Fri Feb 01 2030 00:00[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.cookie.first_load.value", "1");
Deleted : user_pref("extensions.crossriderapp21154.21154.description", "We make it easy to follow a collection[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.domain", "");
Deleted : user_pref("extensions.crossriderapp21154.21154.enablesearch", false);
Deleted : user_pref("extensions.crossriderapp21154.21154.homepage", "");
Deleted : user_pref("extensions.crossriderapp21154.21154.iframe", false);
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.InstallerIdentifiers.expiration", "Fri Feb[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.InstallerIdentifiers.value", "%7B%22instal[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_appVer.expiration", "Fri Feb 01 [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_appVer.value", "112");
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_lastVersion.expiration", "Fri Fe[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_lastVersion.value", "36");
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_meta.expiration", "Fri Feb 01 20[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_meta.value", "%7B%22followscout.[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_nextCheck.expiration", "Tue Aug [...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_nextCheck.value", "true");
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_queue.expiration", "Fri Feb 01 2[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_queue.value", "%7B%7D");
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_remote_resources.expiration", "F[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_remote_resources.value", "%7B%22[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193325.expiration", "Mo[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193325.value", "%22@med[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193327.expiration", "Sa[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193327.value", "%22data[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193328.expiration", "Sa[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193328.value", "%22data[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193329.expiration", "Sa[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193329.value", "%22data[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193330.expiration", "Sa[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193330.value", "%22data[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193331.expiration", "Sa[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193331.value", "%22data[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193332.expiration", "Mo[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193332.value", "%22data[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193333.expiration", "Mo[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193333.value", "%22data[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193334.expiration", "Mo[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193334.value", "%22data[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193335.expiration", "Sa[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193335.value", "%22data[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193336.expiration", "Sa[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193336.value", "%22@med[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.installer.expiration", "Fri Feb 01 2030 00[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.internaldb.installer.value", "%7B%22InstallerIdentifi[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.js", "\n\n /****************************************[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.manifesturl", "");
Deleted : user_pref("extensions.crossriderapp21154.21154.name", "Follow");
Deleted : user_pref("extensions.crossriderapp21154.21154.newtab", "");
Deleted : user_pref("extensions.crossriderapp21154.21154.opensearch", "");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_1.code", "appAPI._cr_config={appID:fun[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_1.name", "base");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_1.ver", 6);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_13.code", "(function(a){a.selectedText[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_13.name", "CrossriderAppUtils");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_13.ver", 3);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_14.code", "if(typeof(appAPI)===\"undef[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_14.name", "CrossriderUtils");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_14.ver", 8);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_16.code", "if((typeof isBackground===\[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_16.name", "FFAppAPIWrapper");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_16.ver", 9);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_17.code", "if(typeof window!==\"undefi[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_17.name", "jQuery");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_17.ver", 4);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_21.code", "var CrossriderDebugManager=[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_21.name", "debug");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_21.ver", 4);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_22.code", "(function(a){appAPI.queueMa[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_22.name", "resources");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_22.ver", 4);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_28.code", "var CrossriderInitializerPl[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_28.name", "initializer");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_28.ver", 3);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_4.code", "var jQuery = $jquery_171 = $[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_4.name", "jquery_1_7_1");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_4.ver", 4);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_47.code", "(function(){appAPI.ready=fu[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_47.name", "resources_background");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_47.ver", 3);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_6.code", "appAPI.sidebar=(function(x){[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_6.name", "sidebar");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_6.ver", 2);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_64.code", "(function(){var h=\"__CR_EM[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_64.name", "appApiMessage");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_64.ver", 2);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_72.code", "if(appAPI.__should_activate[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_72.name", "appApiValidation");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_72.ver", 3);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_78.code", "if(typeof jQuery!==\"undefi[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_78.name", "CrossriderInfo");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_78.ver", 3);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_98.code", "(function(){var b=\"cr_\"+a[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_98.name", "omniCommands");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_98.ver", 2);
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins_lists.plugins_0", "4,14,78,16,64,47,72,98");
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins_lists.plugins_1", "17,14,78,13,16,64,4,1,21,2[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.plugins_lists.plugins_5", "4,14,78,13,16,64,47,72");
Deleted : user_pref("extensions.crossriderapp21154.21154.pluginsurl", "hxxps://w9u6a2p6.ssl.hwcdn.net/plugin/a[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.pluginsversion", 36);
Deleted : user_pref("extensions.crossriderapp21154.21154.publisher", "follow.net");
Deleted : user_pref("extensions.crossriderapp21154.21154.searchstatus", 0);
Deleted : user_pref("extensions.crossriderapp21154.21154.setnewtab", false);
Deleted : user_pref("extensions.crossriderapp21154.21154.thankyou", "hxxps://app.follow.net/installed-extensio[...]
Deleted : user_pref("extensions.crossriderapp21154.21154.updateinterval", 360);
Deleted : user_pref("extensions.crossriderapp21154.21154.ver", 112);
Deleted : user_pref("extensions.crossriderapp21154.apps", "21154");
Deleted : user_pref("extensions.crossriderapp21154.bic", "140277aef9f3f93a6bbdcb0ec0df9251");
Deleted : user_pref("extensions.crossriderapp21154.cid", 21154);
Deleted : user_pref("extensions.crossriderapp21154.firstrun", false);
Deleted : user_pref("extensions.crossriderapp21154.hadappinstalled", true);
Deleted : user_pref("extensions.crossriderapp21154.installationdate", 1375051903);
Deleted : user_pref("extensions.crossriderapp21154.lastcheck", 22930009);
Deleted : user_pref("extensions.crossriderapp21154.lastcheckitem", 22930064);
Deleted : user_pref("extensions.crossriderapp21154.modetype", "production");
Deleted : user_pref("extensions.crossriderapp21154.reportInstall", true);
Deleted : user_pref("extensions.crossriderapp21154.statsDailyCounter", 29);
Deleted : user_pref("extensions.enabledAddons", "beta%40linkdiagnosis.com:2.3.6,kgen%40elitwork.com:0.8.1,onsi[...]
Deleted : user_pref("extensions.wajam.trace_log", "1359498664571 - onItemAdded - Error Message: response.sendR[...]
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\y4ng5py9.LittleComp\prefs.js
C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\y4ng5py9.LittleComp\user.js ... Deleted !
Deleted : user_pref("browser.search.defaultengine", "Ask.com");
Deleted : user_pref("browser.search.order.1", "Ask.com");
Deleted : user_pref("extensions.asktb.cbid", "AU");
Deleted : user_pref("extensions.asktb.default-channel-url-mask", "hxxp://www.ask.com/web?q={query}&o={o}&l={l}[...]
Deleted : user_pref("extensions.asktb.dtid", "YYYYYYYYCA");
Deleted : user_pref("extensions.asktb.fresh-install", false);
Deleted : user_pref("extensions.asktb.l", "dis");
Deleted : user_pref("extensions.asktb.last-config-req", "1286952108816");
Deleted : user_pref("extensions.asktb.locale", "en_US");
Deleted : user_pref("extensions.asktb.o", "1665");
Deleted : user_pref("extensions.asktb.overlay-reloaded-using-restart", true);
Deleted : user_pref("extensions.asktb.qsrc", "2871");
Deleted : user_pref("extensions.asktb.r", "5");
Deleted : user_pref("extensions.asktb.search-plugin-suggestions-url", "hxxp://ss.websearch.ask.com/query?qsrc=[...]
Deleted : user_pref("extensions.asktb.search-suggestions-enabled", true);
MJ1
Posts Posts : 66
Post by MJ1 on 6th August 2013, 8:03 pm
-\\ Google Chrome v28.0.1500.95
File : C:\Users\Lee\AppData\Local\Google\Chrome\User Data\Default\Preferences
[OK] File is clean.
AdwCleaner[R1].txt - [153524 octets] - [06/08/2013 10:28:47]
AdwCleaner[R2].txt - [153586 octets] - [06/08/2013 11:17:51]
AdwCleaner[S1].txt - [156786 octets] - [06/08/2013 12:46:19]
########## EOF - C:\AdwCleaner[S1].txt - [156848 octets] ##########
Version: 5.3.4 (08.06.2013:1)
OS: Windows 7 Home Premium x64
Ran by Lee on 06/08/2013 at 13:33:01.36
~~~ Services
~~~ Registry Values
~~~ Registry Keys
Successfully deleted: [Registry Key] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{92B7BE94-5234-4405-BF0B-EA3C1329E8F7}
Successfully deleted: [Registry Key] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{D83ACFC6-F78F-4CBB-BB4D-FBF4000E9C52}
~~~ Files
~~~ Folders
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{00119447-4863-4A7D-9860-462E2B6489B4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0012604E-C740-4077-8764-C8E64D409F74}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{005B6D2F-8CA8-4648-86AE-027AF7795243}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{009E2BFD-4852-4800-ABE9-6A6E038BBD4C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0122BB6C-3B25-4804-B804-808E87B521D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{01572EF8-6F16-496B-86FD-FBD5B6B89872}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{019CCB33-80ED-4EF1-9EBD-ED18653CF42F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{01A2FC85-D74D-4779-9CC4-D3CF39C1DC5F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{01AB11EE-6086-4DE3-8272-2A3151B80CD1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{02106096-D66B-4889-9DE2-4DA777777A27}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0211E368-9093-4BB2-B953-B732F7EC35BC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{023311F0-0BFF-4327-AE57-A98B00CEC9DF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{02695F47-761B-4384-A061-B71EAA67C198}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{027F03AD-973E-457F-BB13-404B6B512C7F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0335A0C1-CEB7-4353-AA2F-7F76A20328BF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{038396F3-B8DD-4BB1-A9A9-30F3BA1563E5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{038741F2-E68D-4D43-8D3C-8CA64CBC78EB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{03A9C567-B2C5-42A5-800A-9FA30ED31EE1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{03EC3CC5-FD36-440A-93B5-1AB0320F8064}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{03F230E3-95AA-428E-A5A7-F49538FCC5DE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{03FD3F54-CBD5-4254-B557-AB25933A349F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{042FED11-5393-481A-898B-6C64BEC884BF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{043DA002-FCAB-42CB-B921-EA5E7D3C239D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{04457584-CABF-4EE0-B47D-37FC8B92A557}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0483B978-4D70-4739-83F1-3693E04A2D0F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0495B7DA-7272-457B-872E-EF5F867AAC47}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{04BBC0CF-D037-4CE6-ABC8-7888776376B0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{04D69777-5F0B-4BDF-B0E3-9A8A3E15D373}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{05E1D2E8-D355-4C86-9179-452E3B89A4D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{060BADB5-026D-4EBC-ABC0-CB8B6CA94431}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0629C5C8-8397-47C8-91BD-E6415CA3400E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{06A0C671-F19F-4271-8A2A-83F72ED90B68}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{06F6F658-5074-4984-BA4B-D84877A7AB57}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{074203B8-4AB5-4BBE-B19B-674721942101}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{077C5C45-1427-4633-9646-5B4D9661A855}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{07898DCF-3C98-4BD7-9534-CBE3574E00EC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{079891A0-5C5B-4A32-BA39-76E6F2F78DBD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{07DD0289-6B4D-4D31-ADF1-01F7C8BD3DB8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0815A3B3-59E1-44EA-B592-E198546D3451}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{08932531-1723-432F-8A7A-9814C0B0D863}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{08AD8CB6-EC02-4A34-9CF4-E3E2F86578B5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{08D3C7A9-387E-4F81-A2CF-95A8D958F135}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{08FC9243-F52E-4303-BD1A-D5AE914FED03}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{094E4E42-2EE7-42A7-9B16-3287F8A8C418}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{09838A30-27F4-4736-8324-607544D6DC24}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{09A68611-644F-49D1-B1B1-9F588680F790}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0A0419D6-0B49-497F-9ADC-C56696D4EBD0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0A254663-6B3A-41A7-8671-2CC6D642C120}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0A48966E-B600-4629-9D3A-9604D02276B3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0A4E4FF4-FAFB-4AC0-96AD-E530D09F6924}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0A8A469D-3E28-4057-B9C4-D5C6399E0EE1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0AF05EC1-02EC-475B-B033-B3D9CD825A9A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0B06DE53-34C7-442A-8222-B6C091186D54}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0B186168-E1B5-4220-9C3B-958D69E931A7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0B8DB0DC-C318-4539-AA8C-66C9F44B2FCD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0B978A6B-0C6F-4853-ADCA-43972EC67971}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0BD697A4-AAA1-4E8B-9969-44AAEE758E17}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0BD8C8D0-3A80-4550-A1EC-8CC3824ABB81}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0C21EEDE-A018-47AB-BE83-5DB09694A010}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0C338428-56A6-47AD-ADFC-2B53FD3D9CD6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0C92CBB0-A2B2-43B5-A948-3CB45A9C5E9A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0CA44B17-1112-41A8-AF08-C2AA04355B49}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0D17D28B-535B-44A7-A264-6F6CC85CAC23}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0D3FF72C-CACA-403A-9370-7910DE800120}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0D41ECCF-2AA0-4761-B1A8-205C9E8C095C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0DC84FD4-CD5A-4F0F-B6D2-B6C8178E8F50}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0E20BF44-6DBB-4F77-9337-F4B207AF2FCE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0E4B2B61-9832-4CC3-97AC-2496844E0DD7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0E4CEBDC-D0F6-4694-B7A8-C4479FF69CE0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0E67A70E-66BA-45C4-86CC-02A8E483AA2E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0E6EE195-7A82-4AD0-A627-7E9DEA5B8E3E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0E99A8A6-8EB7-434C-94E3-BC5A81E6FFA3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0EFE3270-3F9A-442A-9375-2C5F03808793}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0F0B603D-600F-4FB5-AED8-1493CAA07BF4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0F4C5355-0578-478D-B446-048F6A6FBE2A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0F5E24D6-FAF2-4107-B9D9-5A7AF94C007F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0F67808B-1F0F-42B2-9415-24EF49FAFB34}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0F6A2370-A6ED-49B4-B861-86ACB21AEB1A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0F788F7C-8F10-4838-B176-0F6B32CE6240}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0F93A630-2709-4E79-B54C-09B5FB41B1C8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0FBC39AE-95FB-46D4-877A-240D9FBB359D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0FD8E092-E4B5-4369-B867-4529FE7F9D19}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0FE988B0-18B5-48E4-B023-832F45CFA409}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{0FEDE94B-7A52-474A-9E30-0B7F38E0BF18}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{10365244-F896-474F-83AF-78882E9661BA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{10539EBA-EF94-42EF-B6A2-9C1AD16F838D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1072C62C-D63B-4485-A7A7-83FEFD3EA4A0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{109A578A-7F17-4498-8B18-D3AC9126C128}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{10AEE734-D518-4B84-9F14-74B8EC7E7C6C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1123D407-F8C8-4901-AA86-BB91F13DF1E2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{11A74810-9124-4D5C-8BD4-4F8B03C3E1AE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{11B60A28-7937-410F-81F5-4087477D9352}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{11FBB4ED-97D1-4FF6-ADB4-3D688F4E033B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{121472DF-A8EF-445F-A787-351186DF5469}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1250115B-030B-4E63-9E69-A17300B4C405}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1262DC0F-5545-4244-A023-B25C7529882C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{12666292-7135-4D77-B09C-61EB744FBFC8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{12A80AA7-30D1-48A1-8621-B73A7C426967}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{132CB505-B3EA-4BEA-9BA7-7228F9DF942D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1330BC39-1062-44DE-8D2B-A949FDF51937}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{133CB496-0790-47F3-B6E8-F131F4102177}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{13774146-D63F-4E8B-B881-8DEE154B2D30}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{13A11A4F-8C00-49EE-9AF6-21EDAF8555AD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{13AE4F3C-883B-4C13-B43D-C2D4F1CFF9A4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1422E822-2969-41FC-A36C-F3A7E663C0CC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{142B1A90-29BB-4FDF-926B-F4F7CC69444B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{14349BBC-021B-453E-93F1-86D0B4AD65F5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{14D45CF8-293E-4687-94E8-FF2360B635EC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1567E3ED-E1F7-4824-A4AC-E2A9A8985DB8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1605202B-317B-41A5-BCC4-963CF1F4F7BE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{161B601D-06E1-411D-9178-33C87E6D21CF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{162231CF-0390-4522-A5CE-EED5C560CEF2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{16454F15-AFAA-47F8-89F7-62F6F61A5BB4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1687F731-2928-41F4-A22D-84A115C17D46}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{16A973BF-3BB8-4B76-A2B2-E5E9B176D48D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{16B89C9C-373F-4484-ADF7-1440647C4FA9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{17055CC1-5B42-482B-B94E-E117EB83451D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{172F9E09-11D0-496A-BE9D-F08B5A1F8F70}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{17495987-864F-4C53-9F01-298BEAB4671C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{175F13E0-9AD2-4BAB-AABC-7963B85D6DF3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1770B459-5C51-4A4E-AC17-827EDC13D530}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{17D42D6A-B03F-4402-9C99-78D2F79A744B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{17F26C59-C09A-4717-8B95-73BA09BF683C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{18281D67-8481-4E64-9283-5CC6C39D3AAD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1870A7F3-183C-4C5A-9628-1CDD717437E5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1886120E-F582-4B27-95C7-9ECB733CC393}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{189B40B0-2365-4260-A55D-CDC07B7B4BA6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{189DBDA5-D5A0-4EFC-85CA-3627E7A62B98}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{18B0C04C-F43A-455D-992F-80997750B683}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{18D622A2-D29F-44E3-8934-17DE9051C219}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{18D82F0F-29F4-474E-85C9-C7327D117B77}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{18DB6E60-B47A-4586-AD84-5C94A367928B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{193D6B07-2BA0-49C7-A130-E1912EA5563E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{193D7938-A04F-40F9-BD0D-866ED9B531D4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{19434A64-058D-4E8A-BC85-F247743A026E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{197DAB3A-8001-47C7-A52D-4BFBCF9C6D90}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{19D0E178-8589-4135-9A24-A5BFDE1F7424}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1A7F66A3-E668-441D-BAE1-1C7013591936}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1B1DE966-23A1-4B68-B4D5-8192578E9B08}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1B27646F-3442-4BDD-89CD-7E7AD72E093E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1B63B805-2862-4DBE-845C-1667D991D693}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1B82B87E-09E0-49CF-B1B5-98F09B4B56FD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1B86CDF0-F199-41AC-8F50-36006CE12CE8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1B95866B-9567-40A8-BB62-CA5B8D7E1DD4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1BA5DE8F-E16C-4A69-8E6D-7451A42D8680}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1C9CFBB7-73A4-4DC8-BBDD-EF349018BEF3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1D2B7E9A-B689-4BAA-81F6-1CCDC0FAF35A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1D61C3D7-727F-4D53-8AAE-3D7BC657657E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1D683DCB-3CEB-47F0-A06A-63BD3A527780}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1D9CF796-C992-4652-8BB9-0FDECFC79EF1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1DDE1B82-B5EC-4BB8-A27A-B36E32248BA9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1DE7ECEE-99AF-48CC-91BA-2F9B893D0C1C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1E903E6C-6AE6-4383-83FD-3E912856A3D0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1EA50D7B-5786-462C-AD37-BE86DA98EB6C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1EA88CFB-71EF-46C1-A219-1E81D0799B22}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1ECFD947-5A51-44C5-8209-3BBC4C94F635}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{1F71F420-21CC-4EBA-8D2F-FD5CDA7126F4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2071E49B-B83C-4F1E-95D4-1832C17CB967}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{20BEE341-5686-4959-86B6-BFAD6C30A4BC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{210E9C7E-709B-4AB4-9D08-CCF79AD679FB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{211F8B9F-7F74-48BE-8785-8EE87901443F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{21784B94-BDEA-467C-AA56-C7E8E2617BCC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{218DEBF1-5B75-47D5-A54F-359F422E8567}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2193BC88-33C6-4A18-9CAB-FEA1A760013A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{21EC0244-E7FE-417E-9D1D-15FB5DB56CA4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{21FC7F93-15BA-4A85-AF38-104A6046932B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{220FCB29-02EF-413B-BAA3-972C7DFC6B01}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{221798A1-A7F8-4A5C-B64F-72A598FD71B0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2228963F-FEE1-4B12-BFF7-CD35BF19F6D3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{224468F5-1508-45DF-8AC0-99D15B5DB280}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2249C033-9A05-438B-8277-3DDBA6AFF725}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{22D4A290-CE8D-4BAA-9AB4-96754739A831}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{22D6785B-D3F4-43FC-A75D-6DC09635858F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{233EE161-713D-481E-B02B-C8365E377F41}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{239730BA-9B3B-4E69-AE96-D76841FF5015}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{239892BB-7C5F-4859-AF87-7A8A2F874929}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{23A28A32-ECE6-4C8E-8EBF-158B6422EE7C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{23C523F5-C027-41F1-A937-9F15442639A7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{23C7E5FE-DBA0-4F3A-8843-486071764AED}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{23FB9C3D-C338-4E0D-B64A-0E51B396B756}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{24930A68-CAC5-4B91-B7F9-963BDAE700DA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{24AD0398-9FDA-48F4-8824-6C191A9DA56F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{251AD544-EB30-4D4D-A607-A63F7DDBFC29}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{252B2B15-46C9-4EB0-BB56-C7F80B6B095F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2566898E-A76C-4815-A179-E8C77F8BE3C1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2583A658-2387-47A6-AA3C-AE0C6070B2E7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{25B62502-09D7-4138-9D53-8C2471682282}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{25BA15DF-500A-4EE3-9950-443B2EDD778B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{25BA98C5-8BFD-4FB1-BA8C-F339F2C4CADA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{25DCB319-AC44-4C43-A29F-A4A48F74D9FB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{25E72608-9665-4C56-9BCC-84599BF56B0D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{26053632-3F33-4A84-AE39-AFE113EC3FA6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{260D9AB6-E49F-4C83-9E9C-0772F8C0D011}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{263742F3-30BF-4896-BC52-63EEAEBB3249}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{263B83D7-FE60-43EB-B92B-112BC08B10B9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{263FE1B5-DE6A-482C-A494-D84C46DFAA80}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{268C709C-8971-4A95-BE8A-CC326371648E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{26AC5B60-AC25-46A6-B601-A55DC3F91754}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{26B80268-048D-42DC-850C-93C2E7F31386}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{26C6B260-6840-4A48-B29F-A301091070DC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{26DE5647-C065-421D-95FB-1AC0C154095C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2757FFE6-7B29-4205-98E1-E1B1D9FF89C5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{278C6DB9-1E52-4B16-8B6C-4753B76EA81C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{27AF1160-8C2E-415C-B40D-0B93649C51C8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{28379ACF-D111-46BB-8050-FB3D743BB6EB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{28866E40-80A7-4FFF-8854-BB9EEC84BCBD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{28C261D9-A8B4-40DB-9E3C-F5374CA47495}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2903B12D-857C-40DC-AE3E-AA8E8F132E36}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{29599E48-1A61-4374-92F9-9A9F793642C3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{296B2284-5372-4CDD-B5AB-D70844266A88}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{297586DA-1FF7-4580-AA20-905A1ADE08B9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{29879B02-101C-4FCA-AC67-E4EB58CCBF83}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{29F0B338-56F6-4284-B4D4-1D79B97069F0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{29F4C6E3-6C6B-493A-AC00-D9EE4069F70C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{29F5541A-5B32-40E5-A2EC-7E09EA59B0FE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2A04F069-FEAC-44F9-80B8-231FD9A82D17}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2A11C855-58C6-4E7E-9412-9746500F81A3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2A2DD3C8-A125-4465-A8CB-8436BDDAC60D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2A536D60-4E88-4D2B-AA5F-E46C702D229A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2AB402D3-177F-4B3B-A5AA-EECC2CADEE59}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2AEF93BC-BA1E-4092-93D2-51869E10C982}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2B066249-21C0-4D9F-8435-0FCE437B8CB7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2B583B49-009B-437C-9F7E-4DFB56BBE21B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2B64D005-0864-4930-A391-CD33632835CF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2B651E5C-23F4-48C6-BA57-C3B17816CA18}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2BDD8096-1755-4342-BED7-C5141BD0D027}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2C11FC0A-C968-49CA-8546-F6CB3076847A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2C9F8342-4B47-4EFA-8C8D-B6CD7662FF5B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2D1682E0-940E-4852-8411-9A292DE9B790}
MJ1
Posts Posts : 66
Joined Joined : 2010-01-22
OS OS : Windows 8 64 bit
Points Points : 26036
Re: Had problem, not sure if fixed, Still some problems
Post by MJ1 on 6th August 2013, 8:06 pm
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2D43AA9B-7B87-428D-B54C-4E74B2BD2290}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2D59341D-3ADF-473F-A089-D1C6A73C70B2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2D648CAD-ED91-4173-B6EF-F77A4438A9A1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2DD5E96E-D685-40E9-966D-10CC38C455E8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2E11E71F-D188-4ADE-AA3E-D6BA9856F306}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2E50F459-0525-4115-A629-7BCB6563D13A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2E6F4827-4323-43C1-8809-BCB178033E15}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2EC5F406-9E61-4D18-8377-83E0794A0BC5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2EE9330A-3287-4ECE-BFC0-AF423E02C5DB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2F26DDE0-DB62-445D-A7BE-4D50B12724CB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2F28FF86-8E79-4C73-AB96-FB81B661B485}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2F9EF9B4-E6FC-4CC1-BEE5-C90E47182957}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{2FD1ECE8-5EE9-4741-A8E0-2FE39A6A9B64}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{30060333-96A3-419A-A046-509ABC5F7E24}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{304A8049-3ABB-44EA-BA7D-C5F715B843AD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{30523DA0-D7D7-4D91-9262-35B62C9DAB0A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{31106020-D3D5-4DE1-B1F0-4645264E05E4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3117ED14-39CA-4BBF-92B2-8A8F7FC35645}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{313BAEF3-AC64-4D8D-B1F4-6B17CB24A90F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{31494D93-839C-4C2A-8775-D5B6942FBF95}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3150D294-4632-4E23-9412-3EA2D25969A2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{31606386-E01E-452E-8401-6A66EB365426}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{31B475A1-9120-4783-9059-06584CC0E93B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{31CA0839-C4B8-4992-85D7-E50E84B1AC43}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{32109E8E-30BC-426B-9FA3-C813BD659F10}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{32405C7D-6874-4F9B-89D0-114F54840B99}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3265E238-3831-4548-AA85-FF5C694C7B9C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{327418CE-9445-4FAE-92B2-4467E1570F42}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{327993CB-4442-44B0-AC93-8406C9E98B36}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{32A0852E-94AE-401B-B80F-513DEF03CF6F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{32CDFF8B-77C0-47E0-9208-7BB764C6EBDE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{32F70307-8407-4BAA-9C8B-03D53EB46107}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3302B193-5D8F-44B4-8370-5C3AC28C666E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{330885CD-5111-400B-996D-577248D222D6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{333BE025-885B-4677-871F-D9ED152208A8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{33545530-D0A3-48FF-A867-07A58F329371}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3368DEA0-B7B7-41C5-BCA2-6EEDD1752E09}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{33867C77-11E0-4475-9756-29042FAAFB65}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{339F8C4F-EEF1-41C5-AEBD-F8B7E5315F41}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{33C408B5-8946-4885-A6BD-1739402321B8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{33CFEC63-B3B8-4719-B638-4E3E60881B3C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{33ED8403-2E64-4F60-BA0A-1E4B8159A662}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{343214D4-96FB-482F-8715-EB8EE031965B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3434E244-522A-451B-99CC-D00C6BEBF0FF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{34517C73-27AF-4A6B-BEC9-AAEF9D8E04A4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3452AC12-18C2-4BDD-AFA0-F5ACFF0F4828}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{345A0011-DC12-4C9A-8534-A801F7E4437A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{34A43BEE-1C36-4725-9A4D-C5710C3CF97E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{34D154BB-2BC6-456F-8B15-37227933E4D7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{34D4F5E8-A315-4171-8D5E-4D65DB1CE9FD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{34DE2270-41AF-4DCE-ABD2-2778F05893EF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{34ECA2E6-964D-4B50-AA9B-EB0110E3DFBC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{35B5521F-CC03-4EC3-A06A-1E58C8C6E529}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{35D2C9E5-E019-4D69-B960-AAB836C6383C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{35DE75E8-20BD-4309-BDD4-712D2F79474F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{35F121E4-9674-480E-AFFB-020980024364}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{36191B4E-2AF7-48F8-8044-A47EFB1581E8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{36D0F9A4-DE54-4A13-9293-F339BE98B0AF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{36F39DF2-1AAB-49E2-94DF-CA4D93AFB8A5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3703FAE6-9FE7-4DB3-80EB-325323E755C7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3720F1D9-9BB5-492C-9E58-E87ED03F860C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{375247BC-D7CB-40D2-A1F7-7C635B783EC6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{382573D2-58F6-4B08-93D7-E50FDA23AC3F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{384CC866-4695-4945-8A55-0AC7F96C4E46}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{387D0B89-A255-4761-A7C9-2FB1A934AFD3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3937945A-2267-4B47-8C08-4DCE0DDD193E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{399D2720-58C0-4B2F-9507-8D337B4F6921}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{39C5E4F4-82F0-4C93-9F78-BE22877C45F5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3A087CF2-9561-468A-ABC0-E1A6D4E72C15}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3A26E052-CCA4-47E7-8D12-D34002423AAA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3A418A6B-F6CE-472D-AA6F-828E925DB6DD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3A7938E9-6511-44B3-80D1-03453C6725FD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3AB53D93-CB21-4157-8083-FBC6D5C9D25E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3AC6B98C-F070-49A0-9448-F338E578CC57}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3B7FFF37-68E3-463D-AC1D-181B2D45BB08}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3B9139F9-A2E4-409B-9397-AE2950F78D59}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3BC90C29-2890-40D0-BAB6-374E6C985DE2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3BD5B640-26BF-4FF4-AE01-F5CF0186BC62}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3C80BE96-ECB1-414F-84B9-57D4314982A8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3C93029E-2E77-4FEA-963D-F319AF375408}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3D1FFA2E-B3FF-4B8C-9BBD-09B1D8E22B3B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3D2B4FF8-580E-47EF-A0CE-DC73F1B795E0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3DA79BDA-7EAD-4FCE-AE86-2681765F6F8A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3DB5E6E8-9122-4C54-998A-B37DDD381C6A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3DD37B2A-FD3C-43D7-BCA7-C2923F72182F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3DF2EB88-9409-459C-8672-1DBFB6078815}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3E01DF1C-7A61-4258-8F72-8DB69681FAF5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3E3F4AAC-156E-4547-BE11-5CBA96B8D1D5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3E435A70-7969-412D-AF23-C49AAADEBE44}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3ECF54AB-4404-4D4A-8A39-7CB9A2E87700}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3EE68865-2971-452D-B53F-8DE674091636}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3F043FFB-6D7C-4FFD-9CCD-D38D2FBA8D30}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3F0BE1E8-16AA-45E2-BE02-12B70546D115}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3FB9C225-6359-4A79-8678-420F6886AA45}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3FD8C16C-A32A-4EFF-B286-632A96E89920}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3FDB76BE-05D2-4A7F-8CB6-24F817F6545A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{3FDDFE6F-8E4D-4D93-80E8-A8B08B92110C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{40C231F2-506B-4E6F-BCDE-4EA2AF364316}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{40D202A8-B081-42A0-AD73-8FE57F8D9462}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{40E05A04-4AC1-40DE-864C-85E075C1DD9B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{412E5068-209D-44C5-B854-ABDF424DA5D3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{414CC3FD-D65B-487D-9A5D-023CDFFEF66E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{419B973E-A7A8-4BFE-8260-1B8EC2254930}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{42470721-E26E-4627-B1E6-9E43FEFC26AD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4258EE59-E894-4360-AD62-811424021669}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{42AD8EEC-D52C-41B1-BF9D-F819FE11EF83}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{435AAD16-83B6-46CE-9998-B3E73C470FBC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{43882461-E51D-4C05-AB50-03026570830C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{439A8C54-BF57-417B-BFBA-5D39E94B78D3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{43AD60B0-8CA5-400F-8C3B-4F56FA65EA84}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{43CCE609-3E93-450A-BDDF-9CF966F537BD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{43DFDF7B-1A1A-4B85-92F3-0242962C7A8D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{43F90B47-1F39-40CA-A50C-4B02DBA0ABB4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{452D6236-945D-49A3-A741-5B0130623CED}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{45DF5542-E4CD-4581-AEC5-1447446C0BF8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{45E2C05E-C1DA-4ABF-BE52-D01A905897DF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{45EB26BC-9F6B-43A1-BDB1-1DB899EDAC23}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{45F2543F-C1E4-40F1-9AEB-B492BA5507A3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{45F2D9A7-0228-4257-ADD7-87ECF6355C2A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{460D80F0-5593-4574-A352-F82110C533C5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{461F51B1-AC38-4C0B-A6B9-C475BB477A93}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{46724275-6859-412F-A888-1EA1C8984A97}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{46D66843-C96B-4F64-8A53-0BF7F9058C15}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{47AF2F1E-E398-487C-93D6-A7423EDC096F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{47CBF58E-06E5-4124-8D0D-540D7AE10260}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{47DEDBD3-6F60-433C-AC5E-4CCB48FEDCF1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4804FD9D-A252-4F97-BF4E-E1BFB804CCC6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4823D40A-7FE0-4832-953D-7642AB86481C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{484FAB96-2E31-42E2-98D6-B30487649F4F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{488180C5-36B7-4D22-9F45-8F8F0E4DCB27}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{48F093C6-4173-46B2-9B87-93F6E3238951}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{491C8CB8-B3C6-4B05-A7BA-AC2BC6C1667A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4936D377-12C2-4211-B6DD-A935C19AE960}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{49C8AB7D-1525-423F-89BC-171F52FAB858}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{49E89CF4-EDF1-49B6-80D1-F6B537D14AF9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4A7DE475-E925-4D8E-8F8D-B8B64479A305}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4A9953AF-5582-4D4A-87D6-8336F1EF8321}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4AC90631-D656-46C3-AE36-D31E939644CF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4ACD5257-AA58-41E1-904B-A577BDEE8A14}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4B366C22-AC26-4F4E-989D-E53AC36509B6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4B37E750-5338-4BC5-9068-F6F1A6C91EDB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4B4468B9-CD1D-4E96-BD8D-C6E2FF9D84E6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4BAD4AB0-C617-42C4-B6B1-2714DCA67C40}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4C50B0CE-9ADA-4268-869B-328E064D7439}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4C628835-1DDE-425D-BBC9-B871A8915922}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4C6C9FDF-F86A-4E17-8149-AE773C4B5CD4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4CC29F83-300E-49AD-B2F8-E437D4DE3391}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4D2125A3-2A16-4B68-9F83-AB1B248956CC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4D465FB5-5FC0-4A6F-8C78-96CCD79CB4FC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4D890777-626D-4FB0-BBC5-2B68420316A2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4D8E4539-2660-4589-87B9-62FEE5498DCE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4D9D4EA4-FCA0-4845-972A-67BC99F7102E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4DA7B679-62FD-4BFF-AE38-855A1EABA2D8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4DCFD6D9-6E1B-4FA8-86F3-1A415B63A9BC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4DF52901-3BCF-460E-B68A-A9856C719E32}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4E212C33-A0B1-4C6B-9527-219BB7F5B170}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4E4711E9-FA57-4931-A950-B755A85B5DA7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4EE93130-2B6D-4350-A0D4-DDFDCF7E51A3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4EEA1C28-F213-4A6C-A557-0E42DC227381}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4F3C8474-3A67-4895-96C8-1A818B99B882}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4F41717D-66F6-4719-BD3F-945980142177}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4F4900D1-715B-4782-8EFB-D8DAEF65A448}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4F843E38-DD58-4845-A296-C9E52A666FEA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{4FCC2B89-092E-4BA8-B174-3CED45B6C586}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{501B01D7-E276-4B8B-86F7-E47025808BFF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{505E750B-8060-4F06-87E6-0E9581E5EECD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5083CA1C-245E-4DA1-81DC-7FA1158B7D22}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5087C444-C179-446B-BECD-01FBEEBC5642}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{50E35BA3-380D-420C-B62F-11FC61688092}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{50ED6AD2-F266-4761-BD7B-B315557EA912}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{514B01B3-6746-419F-90B8-758BE265874B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5151C9F5-0C1B-4709-AD5F-4149E535B4EC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{518716ED-2FE0-47D6-8F56-775DD90F7701}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{518D4B3D-9D90-47C2-9E21-072628D201B4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{51A252BE-3D5B-4B1C-B73A-62646255F013}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{51B542DB-B1A4-4064-8B2E-83DE01B861CE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{51E6EDEF-CC56-4DDA-BD62-0AC74F6AA88C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{52024D04-E174-402A-A5D8-CEB82A6AE5A2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{521A051E-F10D-42DB-9356-4AB7E1B4316F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{523D4790-BA25-43BB-A1F0-E3AD099D4202}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{52778B48-A773-4681-8C13-8FAFAC40309C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{529DE1BC-867E-42FC-866A-528C3F04AB07}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{52C8587F-BBD0-40A0-AF03-E82A64E3C03C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{53237A3A-1C73-456D-9839-4BA0F80C0C03}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{532A5564-F5B1-4988-9898-79CF04C647F1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{53380898-B18D-421A-8018-15CF4B0919D0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5342E327-75D3-4C75-883F-CEE3E279858A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{538A6E3F-3870-4D30-9965-E2154EBF9E08}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{539880AD-C7F8-426A-BFF3-A02F3ACA5409}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5398B90D-4B50-462D-B489-3D84582C4485}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{53A87B7A-8FAF-4698-B76D-A32452964506}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{53EE64FC-E589-42BE-BE8E-F5973EF6A88A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5424C3A5-7FF9-492E-9C11-29188AA0EF44}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5429FFF4-CF83-4749-919D-D74101C98114}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{544263C1-0A75-4050-B9F8-325CA52734A3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{546463CC-00BF-465C-B159-5349A2E15B2C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{547A8D18-6C8D-4368-B663-A8E8063424FF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{549CDAAE-1368-4795-93BC-C90C99F25BAF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{54E5D9CD-B7F8-49D7-B132-E7B6138F30E9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{55072B97-8C47-4BA7-B6AC-2B03AB0A06AD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{555B3DD1-B4FA-40A3-80C5-6076822352B9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{556BFE47-F02B-4CE5-B218-1A85E0B8636A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{55841223-831C-4819-BB73-0EC862EF9232}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{55ADD4FF-9A8E-434D-BDD3-5473EEB63000}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{560F042E-CB68-42CC-B3AE-E4CEBB7494B8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{56100FCF-758C-463E-B7FA-D8ED2620E055}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{569990FC-6DA6-411B-BE94-6BDD4027D130}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{56FEE9FE-1A7E-42F9-9399-07B23859BF48}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5707FFF3-667C-4321-8BD9-9ADBB75995F3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5720ED46-554A-42A2-8BE1-8CC82E6BDE00}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{57252E59-B142-4A53-995E-914B882FDD78}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{574E5F50-8BCF-4581-A938-A53E56F857CE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5765813E-322F-446A-AE5C-E1E6CF97E21D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{57B45DCF-6DA3-4AB6-BC75-48427A10F2EA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{57DE66C9-8B31-4511-9145-60881C07FF9F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{57F54021-BAEF-4516-9BE7-882264275FCF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5827FFE0-EA6C-4C75-B5D9-F2162F750DD1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{582C2CD1-4B2F-41DC-8BCC-309FB9C8FE5A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5832B03B-9B93-4956-BCFE-432CC71DF0FF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{58641418-C204-4633-B2A4-BF15639BB86C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{592790D2-2C9D-44D0-A46E-A9F6B3D56895}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{592E1C4C-74EB-4790-956F-A95F40F1DBD1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5949690C-2BCF-4EE4-9F6F-77A0E1D66AEF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{597E6880-3EFE-4993-85CA-7A888BBA2FF7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{59DF8226-53D2-4C57-B2C8-03E16DEDCAB5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5A4F2E21-6F67-4D29-A8A2-A63482707FE0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5A528DAB-331F-44D2-9224-1677AFDF0819}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5A843878-0D54-4519-A97A-37D20D71098E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5A99C95C-CAAB-4C10-A260-3AEE433EDF0F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5AD64CAA-A37F-42E2-B2B1-47CB1C276FC0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5AE7D990-0ACA-40F0-B419-5B558AD62940}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5B68C9F3-53AA-4528-9BE5-CB7B86451F07}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5B6A80D0-7D52-4BDA-81F7-F9ECAB7486D3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5B6FB2F6-CEDE-48F3-AA90-4002F2B59B99}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5B727C5C-3463-4905-A72E-869E0BE130FC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5B8C37E4-8692-4340-A3C8-D33E3A58313F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5B98D4E6-F7B5-4017-9CD7-F2E8ED149572}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5BD2F9DC-9746-4BA6-82E1-883F22BBF8FD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5BD55808-40D2-40B0-9747-806F37002CCE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5BECA927-62F8-429C-8FFA-7C4102CF57EA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5C4FC3D2-2FCC-47EE-9237-F404D4EBC5E4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5CC9C31B-2A08-46F1-8B93-E951FDDDF885}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5D070632-3D06-4AEE-A9DD-2DA6891FA1E2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5D16EAA4-F639-41B4-9270-48D8B9A3ED3B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5D547EEC-01FF-4374-9F88-1E4AB679CA2F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5D65C60E-A8A4-4EE9-8CA6-A69BFC156D14}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5E2F0837-C28E-4C07-A126-E96597CA9CA7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5E2F9F1B-D58C-4387-ACA4-09F520E7B5A0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5E358B97-0998-4F66-88E5-C56818F6C669}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5E4FD435-5A36-4CB4-9ADB-7D4B173B1B74}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5E990384-4298-44EC-A32A-6ECBE87816C2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5EAEEC2E-C7B7-47E4-9B09-16AF3FCCF358}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5EC21DCF-121A-4767-A823-622C358C58FD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5ECD3742-A450-4D2C-B8AC-7FC49CD8C7E5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5F6F1A0A-0E8F-4935-BC0F-3E9A99636E5D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5F897F21-4A5A-4BCE-8C58-9F1DC6A9B880}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{5FC344AE-DDDC-4F99-B9F2-FBC429FD40B2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{60186139-4E38-4A4D-81A8-3FC7D8110638}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{602D43E8-183F-47F3-9018-3E2683EC933D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6086EE4C-4329-478A-B7E7-548EA8AAA7AC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{609E323F-0790-45B0-914D-3909C0EAFF6E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{60B4DCE8-F2D8-4C28-BDD6-50CAC8E79346}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{60D960C7-45AF-4CF5-A604-F435254C7A0D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{60E97123-C12A-4D06-9243-1FF4ACBD1BDA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{60FCBF73-1AD2-4B5F-888A-F389AD38B87F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{61112640-1033-4486-8E1B-35EBB32064FC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{61DAC12F-811C-4A8B-B256-0F9592B0163F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{61DC7424-1FB2-4E6F-AD79-4CA63480EF21}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6203B8A7-C16C-4A52-8633-5608D74A0685}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{621857EA-F507-4058-96C4-004385B8CE8E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6244EAD5-47E0-4429-983A-F6E522FD0091}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{62821D23-3B31-4358-A2C5-41C4E37584C8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6296E78A-190F-49AB-B1D7-6E644929B543}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{62A6A4AC-64ED-49C8-886A-0BD17F8B45D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{630E7F9F-43A8-419D-8003-ED4BDB63BC75}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{632B304D-58A9-43DB-89F2-4C55DED953A1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{635F7736-C25D-4763-AA63-BA24B52DCDC1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6361F29E-9073-4070-9343-5771216B64BD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6386CD6A-1968-4CF7-863A-CA09A1132332}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6389A854-EAB8-43CA-B36E-0E69844731F6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6393F01A-F36B-447F-A432-FF27288BA0EC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{63B4C9AC-707C-47EC-AFD6-537AA8AB712A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{63BBF3CD-C9B8-4E86-BA9E-0E684D321C00}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{642CC7DD-6099-4F6B-8B8F-F20D444F1768}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{643EFA66-D602-4F9E-8B65-C42DD06A1EA0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6442C0F0-9121-4C7F-A18B-D5E6619A60BF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{645EA103-D278-437D-A4BB-610D4AECA215}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{64616710-3A26-4D21-B4A1-6B20EFDF5297}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{64AB1860-0530-4EDC-80F7-A0EBDDE3C6E5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{64C81F40-C2C8-48C8-B098-D97C9BBE1421}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{652D63BE-66D3-49B8-BF3E-E43B639BF02F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{65330EA6-86F0-4FB0-B361-5B9BF6F83268}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6534D4B8-C5E0-4FBC-B99B-B7E52F4E16A8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{654820A6-758B-469B-AD0D-7E79A71612F2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{65528173-4857-41A1-BE34-02C2B392B273}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{658929AF-1A8C-41B5-94B5-A377BDE65732}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{65BDF0E6-3A62-4153-B87F-274D4393703F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{663083A2-EEFE-431D-8C36-820A9C79AD0A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6651FA48-4BA0-4AEA-92C5-EF205587DF08}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6663C9F9-EC26-4595-8E6C-5AF63ECC4F8A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{66A423B1-4B34-4446-BB58-4166CA0AB1B3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{66A7F70D-57F6-4E1C-81CA-DD0C6E6EFC75}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{66D733A1-E14D-4A00-93E3-DEC2D47C39C6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{66D75436-CB24-4E54-991F-609D2FA8FBDF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6717160F-9EAF-4DF9-998B-2A835C95A5D8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{678FC94F-5891-4ED9-9929-DCA5894DE9E1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{67E90C65-1CE9-4462-B41B-65E9966BD005}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{681FDFED-41CB-4DF3-8406-2C3156E56AF6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{683B9B08-EB6B-4C0F-BDAD-391B3DA78BEB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{684430A4-D554-4DDB-A80A-BF731669EFFE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{686362AB-ED25-42B0-B002-DD4A880E98D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{69006BA1-B1EC-48FB-89AE-9A28EA32EE4B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6908F792-19F8-41F7-8737-BFAAE7EB7BF8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{691B2B28-614D-4683-9390-C916D66C0614}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6945AB6E-FA39-4E8C-942A-7A2EF5A32502}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{69507E12-95F8-4881-A1D7-627CD72B1685}
MJ1
Posts Posts : 66
Post by MJ1 on 6th August 2013, 8:08 pm
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{698944BE-94AF-46F5-80FA-19FE1447479C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{69A208C3-A466-49F4-8999-731434D418B5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{69D89F4E-D71D-4983-B461-37169C007113}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{69DB8F22-4EF8-484E-956B-95B6128A2FBA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{69E0C226-4719-4D25-89CE-CCD8CBA31FBB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{69FBF5F3-69D1-4FFB-9DB2-02E5ECF9A419}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6A054455-6C51-413A-A2B0-402F4460ECB5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6A84B248-AC6A-4D6A-AA4C-FA97C8FA55DB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6B05906C-6C27-4D3F-BC8B-8FDF3590036D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6B0EC58D-9687-4117-B09A-1449ADAE1617}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6B191AF2-C14A-4492-B5DB-EE5CF55B9EC9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6B534E91-154C-4F99-AA4F-A5EBE8C3C245}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6B7DA4BB-3D28-46DB-ADC8-5F53CB0FF835}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6BE37E8B-CAE5-4705-A409-E4C24BC1CC59}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6C043401-0CDB-4E12-896F-BF0B878A277F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6C1656AC-9D50-40AB-AD38-40E7EB8D90C4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6C1A5A85-331F-4970-8D5C-86EA5AD52729}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6C8B8A62-2E0D-4D4A-A233-80A75CE028EE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6CED5644-7499-4E19-9D3D-0AA4BF9D06FB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6CEF7B8A-869A-4A20-A0B4-54BBB3301AA2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6D0AB37A-9E24-4DE0-BA44-3A76EAD3CF12}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6D320456-5A85-4900-A211-ECA95108C800}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6D37C909-A0A6-413C-9F39-4660779F87DC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6D37F6E7-3CDE-4D6F-A501-C4FAA435A772}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6D8C0819-0F7A-4711-B104-1AC3D5AD6ECB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6DCC8BEB-FE0E-4608-9DC4-ADD30BD7D124}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6E1AED37-985C-4CD9-B734-F9DCC17CEFCB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6E45B6DB-2F55-4C32-B67D-EA2B1BF6026C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6EB3B0F1-B3C6-42A8-9526-D7C3EEA3D551}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6EC5CD61-DAC1-4C54-B129-7673C8E0304E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6ECEF90F-7440-4F74-B10B-5F860DC049B3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6EECB48B-061B-4DD9-9436-0CE29852C6EE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6F1A3865-5783-4BAE-AC44-0C5F9F8EB5C2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6F7C1011-D213-429A-8D6B-284BAED8D994}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6F89A116-5292-4633-9891-E32E30C27F39}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6FA48034-CE28-4FCB-9B76-9FF245FB4B6C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6FABE254-B874-48A4-8282-42DFB55A17B0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{6FD1B0EE-584A-4001-9DE0-59B3E0A4F12B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7038AED4-F42B-4F72-AF46-C7FCFC9FC0E0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{70CF2ADF-0104-4AFC-8F2E-1FD3DFF5511D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{70E15E99-082E-4DEE-B38A-F0F3432D2E4B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7121A358-1B12-41A5-A7BD-899FC5B067D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{715EED85-03B2-4527-AE5A-6C9A48A10D81}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{716BA144-1F7B-494D-A0F3-FD9CEC992289}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{718550F3-C0EB-413D-9951-1FFC95DF3109}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{71A02E5A-2783-46B2-9EA5-33C6AC7C4DD0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{71D743AF-B14A-4B53-89F8-D5C11911024D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{724A04D3-F472-4DEF-97DA-0E823D433688}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{72572018-7DF7-401E-BE1B-DBC5B01F127F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{726CA9AF-7248-4882-A66E-179588972331}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{72B9F74F-4555-4918-88E5-5227D92A071F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{72C973D2-10CC-483A-979C-079BF9C0B93F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{72E1C717-2F90-4FB8-B839-1E366092A34A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{730C05AF-4B40-4EA5-80EE-37BD19E27938}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7343E126-456D-4DF1-AFBB-84C8AEB08F58}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{73453369-2A64-432A-95B4-A57BC293464E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7388018A-ED84-41D8-A14B-B56599DA673E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7447A3FE-0777-4BDD-AC97-F0CB9060A0D7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{74B0C0B3-B30D-489F-9AA7-2DF58B7E2A67}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{74C0DC90-3260-4193-99DE-77AA65829D45}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{74E598D9-3E6F-46F3-BF28-99EF764228E0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{74FB0FDF-FE6D-49DB-A05E-827A9412650D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{75759F78-1C05-4353-AF26-A40A0B10A1D8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7579641D-6F57-4253-9343-FDE2C91F8B2B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7585EBB5-2A64-49FB-91AB-7E4AC5FC4D24}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{76084BB5-061B-4B90-AF74-E2B64EFE8108}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{760AD9EB-12DC-4708-AA91-AD97F4DB3B76}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{76A16B30-B184-4A59-A97A-C1EFB5B897BB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{76B78ABA-B667-4BFC-AAFD-AD6BB4DB8F88}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{76C673B4-DD32-414C-A4E0-99B38006F9A6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{76C9BB95-5180-4A56-8F52-B1F9C7FDD7B0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7744B005-C45A-4D33-9D89-2840B30A8CF8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{775AE982-7F40-4FCC-A7C1-AB90C8249157}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7789E1E1-9F1B-412D-8EB7-ABE5C2ED2B69}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{77AFEBDC-F36D-452B-B15F-B520C9B217AF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{77B09B78-7B77-4B45-8C11-D7612DB212A7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{77CAA521-81B6-44A0-8CF9-01EB1848DEAE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{781042A8-1A6E-4346-989F-FD943C412CC4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7836984B-82A0-4D76-99CA-820DE27B6615}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{78447A61-EA64-4764-9A4B-6B5758A16484}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7855B17A-E8F6-4531-ADB4-7A17EBE98E68}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{78AACB28-BC35-4D38-AD33-97CC13646233}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{792D7C7E-12E3-40DD-9AD3-0E21F4701FF3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{797AE9E3-A9E1-419C-8F09-9C6AA2B7EC06}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7983B2FA-48B6-42A9-8117-8C2BE5F1E309}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7A3DF309-F4C9-438A-B0FF-12F892846A8A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7A42A04A-BD09-4898-A5BE-A8F27B6A49A3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7A667CD2-7BE8-47D6-BA83-4417C2D7BBB3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7ACAC129-CEB7-407C-A901-024EB13C33F7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7AE1C087-3BB5-4190-B472-CABD90713971}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7AFA97B7-269B-4B3D-B06B-32B3961323DB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7B3CD83F-C3E9-48B6-963B-7EFD1E5DDA04}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7B6BC43F-9101-444C-9DD0-9D76412B0984}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7B781098-CDC6-4BCC-9819-0897326DA736}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7BB70B75-5285-46DB-8424-A2CBB65E52A4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7BBFE94D-10C3-4D57-9BC3-A875BB1ED9FA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7BCEBCB0-96D0-4445-9208-787FE2B5A940}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7C15E26B-4E9E-46B5-B69B-9EFFF6988059}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7C1CCE70-34A1-421F-A974-8D5056FA1FFD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7C2B62B8-07AD-476B-8273-AF78A41170A8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7C6A8B63-8B27-47B0-B985-6824716CA084}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7C99472B-F37A-4166-8D65-130D5F1E11CC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7CB43CBD-D480-434A-B9E9-28D38F15A51E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7D09DE78-C83F-4E5D-933D-AD145C050CA5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7D0A1D61-9CEF-4C71-92B7-6D36019F38CB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7D7159A1-2A20-4E67-B14D-480BE2B90E44}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7DBBF18C-7B09-4047-B1B6-6938C85D5C9F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7DD26CE1-B56B-4B0B-A806-33AD1BF676F4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7E1CF613-4D22-4BAB-ACC5-051396338B9A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7E441D01-FDE3-479A-9EF9-74724BD14FFA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7E53505A-0585-49BC-A848-0D991393E522}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7EA30F38-2219-44A3-9434-2E334979B652}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7EB23C32-DC7B-48ED-8AD6-3B42BB3D2004}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7EE5F564-4E9D-405A-9EB4-7DA30CD68863}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7F86C791-23CC-487A-BC43-3090F6FBC7B2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7F901265-8296-4000-85D7-5B11A797918E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7F961D34-606F-4BDF-8751-56F8E0FE6B5B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7FAFD831-AADE-4172-816B-4E04C91EA93A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7FD1CAB9-B040-46DA-8BCC-3CB078EDF8A3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{7FF92C06-B440-47A6-BAE5-70691CF56F70}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{800D6517-B55C-4ABF-98AC-A0CFBDAEF1E7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{801CBC14-2AC7-493E-B603-ADEB647D691A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{80451602-7392-41A1-BD60-09A94417F21C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8091C238-7438-476E-92CF-7C82F075BFC8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{80B784E4-C391-4658-9A7E-46A0B36F22BB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{81151D14-99E8-48E1-9A70-6EF32FCFBB40}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{812E086B-68A0-472C-8E1B-CAB134E4B864}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{814EA224-851C-44BB-AA12-631714F4F5C4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{821DB1AE-5D5E-4E9C-9E79-ED700155F22E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{82218F52-DAFA-4C9E-8359-53ECA7B4A1ED}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{827F4FB9-6E15-440C-B23E-A762BBA5750C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8282AF94-C1DD-41EB-8A44-011425C421E2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8284BDBB-BA6D-4B5F-97C4-6646856A0B84}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{82D92FB1-0DD9-4D01-8119-967A3C663904}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{82DF7BC1-5997-4CF0-BCAD-B9C4034CA6FA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{82E8F03E-D99D-4315-8EC3-C9D80E6786D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{82EC12FC-0D1F-489F-BDC7-DDD03BF1768E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{830EEA40-BFC6-4AB7-A14C-1A8ADEBB8440}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8316F4C6-1636-4207-BC18-C303C32A4549}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8358716B-D18F-4D99-81A6-C3B653744350}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{848A88A6-5EF5-4F3D-A079-6C3653AFBC58}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{84CB5ADC-1792-4826-ADB9-952238E65F0E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{84D30570-194E-4B18-B95E-052F8CC5E8E4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8560706F-9409-4C01-8F39-586E57DF21CC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{857D8602-0C62-4633-AE4B-F70C9B71A2A0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{85CC078D-D71C-435D-A929-97C5E7ED5D42}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{85F723A4-5726-45E1-989E-0B8889C00E08}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8614015B-F9B5-48A0-AEC2-D4700518BFA6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{862264B3-C2C8-4F31-A459-7E85CF829891}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{86DADF91-B504-41F9-AEAF-8951B211D919}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{86F90F84-9172-4A0B-80AB-EEDDF6D807F2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{873DDBA9-97BB-41BC-9BEB-17395807FA2F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{881F930B-BD98-4619-9476-1D9A8176CED3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8840BCBF-2A48-474D-9CDA-676BAE10A18D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{888CC664-B686-454A-B277-232151141BE2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{88C001B1-C024-4FB3-BBBD-6965B942FC04}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{88DACB56-357C-4653-9183-1E53F26A1498}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{892738C4-0228-43A7-B6B5-F7ECA6E15CAF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{89A946ED-655F-414D-821F-53301E88EF2D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{89C0DEB7-E5F0-42F2-92F2-B736C52A9E49}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{89D41C81-8485-4F87-830E-8E41595733D5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{89F2A247-1A8D-49CD-A625-A08CED6B302B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8A1930D5-A5EF-4B34-BCED-946663AB9309}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8AEB7ADF-DC27-4705-80C3-6B3773B803BB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8AF3AC79-77C9-4CA6-BE07-57C9EC0505D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8B47F83B-D877-44DB-82D3-197FBD721D6B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8B7ECC65-FA31-433E-97BC-BDF0795365DB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8B98F1D8-D260-42F6-846D-578B50CADDB3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8BA67D41-BB6C-43B1-81D7-334FE818FBFB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8BA6CD6F-D967-4CA4-9A93-D79C76624D70}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8BB3F0DC-E4DA-4C7B-B8DB-B131DB69554E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8BCDEE91-9CAE-4C9C-B0ED-E853D084F21C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8BD1B728-C43C-40B3-8DEF-A8E0FBB07F86}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8C0EB677-B179-453E-8844-143CFD094EEA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8CAE59EF-786A-4CB6-ABB8-910BB8A20DDA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8CECD564-AB81-4416-AB1C-07AB48EDDB0D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8D201CD8-91AE-4EB4-95A8-DCC7A73B5967}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8D7B667A-48DF-4CF3-9D76-7984401CF030}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8E1C9F7A-1547-4EE3-93DE-D1CF24F54663}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8E325BF8-9542-4039-80BE-0BC95057E907}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8E59F4BE-EE20-45A1-A6A7-3ADCBB781860}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8E5A7C12-11AF-4C92-A2B2-80360C2FF32D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8EBBD31E-2BE2-47B8-929E-D6E2D71638AF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8F10F7E1-3190-4BEB-94FB-159106AB08C1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8F33964C-50B7-4580-A101-DD27187352BD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8F44557A-914E-44E2-912F-0FD111F3D5BF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8F62EF8B-52E2-489A-805F-7D20E6835452}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8F695A71-F264-470A-B22D-D651AF7D76EA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8F75B193-E0A7-462E-ADB1-78F3A38A6836}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8FB61131-F99D-4C85-8ECE-0A0FECD701E9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8FCA4479-91CC-428F-B278-03AB72210131}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8FE1C019-9B32-4EC1-A0AE-00E1E66C3963}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{8FF5A5DC-894C-430F-8F74-73660A9CCBAB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9076C4FC-5D5D-4FC5-ACAF-72DD25AE7D3D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{90C22DC1-95F9-4BB2-86D8-E84563791FF3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{90DC2577-CE68-4E18-9784-C840851D8277}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{90DFC736-F2D4-42B9-900A-5CF968C63D9B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9129213C-8A6B-4725-A8C8-3AE39412E215}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{914037BE-E737-4260-BE02-C412AB0B949E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{91C5811C-8941-45AA-B540-39DA584D04A2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{91E1B370-F862-4249-92DE-F9D64F1778FD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{91EA74C6-EFB8-4801-8DA2-82F7790BF01F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9217A754-FB4F-4C75-905E-B2F14D739CB8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{92613A54-A4D1-48A8-9C51-EFAA19C695C0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{92D09D4A-B7B1-47C4-80B4-BFD1A51AE925}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{92EEC71C-380B-481D-88F6-27BB328DB174}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{92FB08E2-C58B-4D5D-8430-73DE4A7905B5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{92FD7FB9-4D79-4E06-B156-313AC5E0BED4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{930F6FEF-C26E-436E-9CF4-E478701DF52F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9352F82A-2EA4-4F67-9FC8-B974F3731155}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{93575802-A585-45F8-B864-10F1AD20599A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{93766AAF-7EDB-429A-B6AF-C351F6985C3C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{937EE218-0698-4BC1-BF1B-1C07813BAB87}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{93F7AB93-3309-4D4E-831A-957B0221C5F9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{94234B34-439B-4C79-A66D-2FEB02778F3E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{944270E6-71BA-40CF-B0E4-A18CBEED01BC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{94C1539E-488C-44E8-A708-068441229F56}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{95239AB6-13C5-4356-8E4B-6EED48C818C7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{95240B8C-70F0-4CA0-8A60-086E5F5273D2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9535BAB2-113B-4987-A5F4-3BDAD9D2E84C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9545E371-5ACD-477A-B4C4-1396D6D35C7D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{954DD364-F3F8-46F3-952B-591FDCC7EFCB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{95E8A47B-61A2-4475-864E-C4D5E4E82DB1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{95FC8167-75BB-4E89-BF28-69CDC5920DA1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{96140620-66E0-4151-B492-25EFE36833A7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{966D450B-86DE-4FDC-900F-E357F6286271}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{97556F3F-903D-4320-A5BC-2DC336C082F4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{97593E34-23A8-4A04-A7F7-8FC6F283FD7B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{97687BF9-29EC-49B8-B725-6E8220290CD4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{97792B35-4C0F-4AC0-9102-414D88D69836}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{97B9A607-EF00-4BB6-B756-3E08C2AD93C0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{98180690-2EF5-467C-853F-8187582F96B1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9853D387-A121-4533-A881-E2B5C6C2B977}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9862B8E5-7410-4F2D-9E64-189BBFEFD3A0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{98A64B01-FB81-4740-9BD0-5FE46DBCB4D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9924E0C5-F235-40A5-B879-791EB110BBF1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{99496662-AF94-482C-8EE2-BB64679A4729}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{997BBA49-5E8F-414F-8908-40D2D58D8681}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{99B849DE-A8B8-4362-8664-7955EBD23986}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{99BF472B-D79F-4A92-BFD1-1E954B0AB83E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{99F62617-B2A5-4EE4-96BC-4292184AFA05}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9A04172A-7D72-4B40-9D2C-6F4B8D634EE8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9A117ACD-2A22-444E-996D-024EC799F19D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9A31C40D-64E6-45A4-81C0-71EF9641E115}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9A3A5915-0E0E-4BD4-82E3-603E3E9A1F73}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9A974FA9-E4C8-4B5F-887F-730165387457}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9B0530C3-9075-46F5-9FE1-20A9CBC4E63C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9B0A0829-C4CE-4785-B22A-490DD5ED35A2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9BDED303-DB66-47FF-A185-CC46EAD3E4E4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9C536126-5287-4417-97EC-5651F4AA4DB4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9C69DD32-7ABD-48E1-B08D-51E971DACED3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9C9D666E-56A2-4DCA-954C-6458D08FF879}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9C9DECA1-297A-4142-8805-58CF165E5AEE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9CB15BAD-2B8C-4C3B-823E-7B5C46AFBCAF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9D045BFE-F47B-43FE-AC80-3048EDCBDCE5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9D2524A4-FD00-46B6-A35C-C5B1E2C21C47}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9D466992-CEC3-4A97-82F1-F0A61376F2FC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9D5FE3F2-51BC-4AA7-8185-8B3DD4F0D104}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9D6601B2-4971-4683-9E1A-6BEA8C4C7828}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9D81540D-51EE-492A-A9DC-13348895CB7B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9DAFD461-7D71-463F-921E-E2C5BC60C011}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9E8BBD2E-A505-479F-B915-1F4A96A678EA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9E8E06DB-49C7-4ADE-8F65-5B163C930204}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9EA034DD-5B9B-45AC-AAF4-6ADEBEC23930}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9EE7853D-A7EB-45AE-9E7A-6CDB10EB786A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{9F6B9230-D7B4-4207-A63B-2F5490B7D863}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A0104D87-4465-48C5-B15D-2BEB26357280}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A03ED538-8900-4C82-A2D7-ED32A5C5E75F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A0B862D2-4089-4B5C-9DC5-F3D0A891EA44}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A0E12BDD-BA4D-47B3-B9A5-A6EFA611B461}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A109B68F-48A5-4B46-9D3F-99A08CDAC591}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A15AA366-F346-43C0-94B8-7168A42982D5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A16A5E87-4340-44C9-ADED-5B837887D2F4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A194C615-A4D0-44B2-85A9-FDE2C471EB62}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A1B70DEA-FB51-467D-8125-666FE9A3C0C5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A1D0C59E-3132-414B-A3AC-B72766B21250}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A1D0EE95-CB01-42A7-A35C-D458D961AB54}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A1DADED4-187A-4352-B9C8-A02D1426C835}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A221CA13-F007-4D81-ADBF-2AF707A9D4AD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A22B6D2E-2C5B-4D49-83BD-3EF787C03920}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A2307829-108D-4739-AC7A-DBB5538D18C8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A235F6E8-4A3D-427A-A572-D6583F2DE17E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A23C1CF9-17B0-4563-BE3D-35ADC55424E0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A2595524-C324-4D97-93E3-8FFA02730ECA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A267E53D-A5DF-4AA3-9359-7947B384595F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A26E9D0D-83A3-4EE0-96FB-F97E29A1298E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A2A95C6A-C044-43CD-ADBE-0AABBC429923}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A2C7E8E8-A088-40DA-9AF7-C50794DCCEE3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A309B9FE-EEFF-4DEE-B561-6A24DB53BD83}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A351D8ED-F423-4A9D-B4FD-756CA6698BA6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A391B157-4A7F-490E-9560-4C8F85519EA2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A396B516-70CD-4009-B933-F9DC80B2E612}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A4501168-CCF5-42B3-AF09-D3DA8A6E92E8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A460FE7E-4E4C-4476-A0E1-825E6E6A5F5C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A4A5A214-FC4F-4956-8E10-7F784B99F43D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A4DF4AD4-3E58-4226-A39F-B9828FD9B8AA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A4E734F0-A78A-4D4A-AC21-2BC92E7B791A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A531AE41-313C-48E9-B239-D9FF22B22C07}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A5C71E5E-A3A9-4166-B7B5-C268D03ACC89}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A5DFD93A-B1D3-4528-823F-2E4AC5143F06}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A5E82D0B-AFF9-4ED1-8B0B-63B7BFD86674}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A60D3FC6-B6B5-40AE-8A8A-ACCCF53169A5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A625FA78-078E-4AA7-BDCE-2538E2F9B7DE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A655866A-3078-45D7-8DA7-538D1493784C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A666B3FD-ACF9-415D-85D6-D16E1C7A698F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A682D16A-A3DA-4DAB-85DF-4DFB10A9E97B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A71451B2-B14D-4462-97D1-48737433EE0B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A787E198-AD66-4692-88E6-70D510AC5FC8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A7ECED2E-BAFF-4769-A3DF-68A958EFF652}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A8BEF69D-5C8A-4DDE-87EE-5483FD141CE0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A8DB676A-737C-4F6C-95F3-554FC05E2BFE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A8E747AE-72A0-436C-B4D7-B494866B076F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A8E8462C-E723-483C-8563-0CA7AD97BA7E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A8F4C6D2-45DF-473A-88E4-C7A1AAA5B709}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A9086634-15BF-4D1A-8CFA-EE2187C9DC24}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A9265FE7-8C72-451D-8C78-630F59B7C69C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A9CD6852-C7A3-4ED9-9354-303F5EA4D49D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{A9FA1612-46F6-4B15-BD46-2C54E698FC48}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AA21AED4-690A-4D8E-BF1A-04117CA6F5E1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AA2BB80B-FFE3-4FCF-A117-FE04EB918845}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AA4E8ED7-46A2-44B0-BB9A-3E3C6F7CA56D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AB1386DD-18C0-4E3C-95DE-5A59F3148114}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AB5F5ED4-12F3-4CE5-9470-598696CB27F4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AB69C91E-C251-4891-9B50-CE9AFEC520BA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ABADFC1F-435D-4F7B-8DAB-3AEDF62BC2A9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ABD4B443-0028-45B1-AEE8-2B7C4C42E339}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AC23235E-AA21-4B05-9665-F2D3FF7855A0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AC2F0584-4F8F-4F5A-BFF6-F450A3DC3A9A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AC492366-F4FB-4CAA-A409-B2937D1CD7B5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AC61ADFF-9D8E-459C-9624-386AAE8CA72B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AC88F3E6-4646-42D2-9FB9-7B16E533E881}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ACA57EEA-F1CF-41E9-B972-A1C97CF9E7E1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ACBF7AE9-853A-4385-A90E-76E39CE23486}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ADA51B60-68D3-47F0-A39B-C65CCDB87612}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ADA8FA8D-E0D1-48C6-9464-34ACA0FB33A9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ADBCD373-888D-4481-B790-17028AED1C0F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ADDDAFF2-EE3B-4C08-9E70-6E66FEEA942C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ADE99466-2543-476A-95AE-FF6EEE565A1A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ADF45CD5-A5AB-430B-9A51-B5E7F71CB687}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ADF6AEA3-37FE-412D-93A0-4E43B740A02D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AE5C1C04-F89C-4263-8F80-28E043CE959F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AE5F651D-D4AE-41B0-8D4A-1D6F27F3FB3F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AE8155A8-20A7-47B0-AC07-1BDD9F53DA80}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AEED70F5-1265-4488-A254-DD89EE4A853F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AF2A0D1C-FC5C-4FC1-9F1D-BBCDEDD333FA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AF3B5966-7BCC-4D76-8FFC-435CB6402A79}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AF466630-75AF-410A-82B7-B98B8614B57D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AF77CFC3-EF80-4478-B4D2-1CC6F3520291}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AF918265-B536-41E3-9EF5-A0BB10DAF446}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AFB682D2-681F-4C17-BA12-F7061C7C1D0B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AFC18AE9-7A9D-4AD2-83F1-51C7F6EE14AD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{AFCC25F7-AD4D-4C75-BBE9-473D8271E833}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B06CA70A-66D7-4572-86F9-EA013519B080}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B06FA613-CAB3-4B14-BEA3-89B52A28B8C5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B081BDF1-0154-4122-891F-EB2D435AF03D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B1157E7A-A22C-4B0E-A7E7-03DBA8B997E4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B1265430-0CAD-4969-8FC0-4380AD072898}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B12B93CB-21BC-4E5E-B61F-19147B1EFF8E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B199AFF7-F3F5-4C72-AFA2-3FA94336C036}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B2412B16-2E19-448E-8243-99D58F3C6C0E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B24D70E4-3DF8-47D3-A5D9-67BB1379D0E2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B24F712F-8EFF-4B6D-B752-67DF3E040378}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B2CDF1BB-9D58-47D3-8504-2CE5BE705872}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B2E79E94-103A-429B-A25D-168DECCA4682}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B3144EE5-0716-4F93-A588-68D12DA30DAC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B31555A7-2A20-4D87-9581-36CA00AADF8D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B348917E-E2A8-4FE1-813C-45A8A81A8385}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B36A26AB-89E9-4E38-8144-E732F7728CF7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B3948E41-6B07-44C3-A798-BA3D95871A6D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B3D44E98-FE37-4EDD-B432-5BF15390032E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B4032B7C-A420-4109-A3E7-70B31C08A96D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B43F9CF1-9697-4B32-B4CE-357FF59388F8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B45CA1CF-92FC-49CC-A144-8C8BB327AF2C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B4CA9128-03A8-48F2-9E47-0EE6E5DAEE7C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B4EE447A-071D-4092-ADB1-30D8C83C42C8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B50492F5-16D7-4819-8F98-46636FDCAE53}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B50A0705-406D-45FC-96DD-E7A76A9A2AB3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B5335848-A422-4D11-A224-014BED4BB667}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B53AB80C-81D1-4303-9BA0-D3157928D37D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B569C941-087D-4AA4-91E4-8041C435AB57}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B5CA4BB0-262E-46FA-ABF7-5D95432BEB21}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B5F64D21-6881-432F-BC46-7C594DBF0EEA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B5FB3051-6F83-419D-B510-76134B254349}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B601D308-776D-4C2B-B99B-F1653F4DF162}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B62DFCCC-6F0E-4E16-89E0-C160663223E0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B653499D-4A69-491D-A624-C6876EA8FA61}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B6A11CB6-B07C-4FE7-8F54-E935EDA28782}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B6A17F99-7EE5-4946-BE02-24F5A4743B3A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B6D6A773-CA68-4B41-A29C-BD5418C29968}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B7185E90-97F8-4FDC-AC8B-E2A5882E212B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B7631FD2-61F1-449C-9270-A54D7A844A55}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B7A24495-1BE8-4D28-875F-0E96BE48EBFF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B825CDC2-9E3A-4E1F-A1F8-FA47CD11AD94}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B89DBF12-3F5A-4B8C-B2E1-C963818D80DD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B8AF5E0A-0028-4860-BFA2-5C2D003545B6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B8EFEDBD-43E9-4060-B4BA-654C2DD81DEC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B90E5B3C-8D1F-4650-AE99-1F6630D97133}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B9114FEC-6BA5-4225-AD8F-C1781C63388C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B977A386-52B6-43A8-8F68-7AF92E90FE60}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B988F4FE-E1E2-4BDF-B05C-7CA6FEED1186}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B9A79251-8BB0-48B9-833C-C2DA200CFA4F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{B9EC5EF6-2DD8-4586-8A12-7E22A61F7108}
MJ1
Posts Posts : 66
Joined Joined : 2010-01-22
OS OS : Windows 8 64 bit
Points Points : 26036
Re: Had problem, not sure if fixed, Still some problems
Post by MJ1 on 6th August 2013, 8:09 pm
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BA1497F0-6A43-4DC9-A49B-904E5E05C3E9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BA478144-226D-4A63-A339-3868C04707FC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BA549094-2AC5-48C7-9CFF-57CF2D1BC15A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BA877575-4224-46A4-B170-D9D20C0060F1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BA91D9F9-093A-4133-ACE4-B070A03864F9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BA960236-747C-4F03-AC0D-E7FBF1737DBE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BAB7E7EC-98F6-471C-9406-19BCA719F4DA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BB35D19A-467D-4EA0-91D0-1B2AF629B5D0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BB403381-B8D3-44D2-A06C-93456FF64024}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BB473091-76A7-483D-AE37-04E3D663C72E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BBB24438-B2E6-48A7-929B-FFE897D30219}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BBBD45E0-E6B5-47A1-AC0B-5CBA6D807557}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BBE12F19-7307-4ACC-8929-BBADCC290255}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BBF18D9F-F016-475D-B164-CDA1F03ECA07}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BC24B19C-5E8B-46F3-BF37-03E4B2DD37AD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BC2B617F-3509-48A6-A097-D88424871520}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BC58E900-6AC1-4700-9085-F759D5939EF7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BC8571B2-9FD9-47A7-B7FA-21668B1002BF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BCB4E3A1-0229-4999-9A35-29608B5DBF70}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BCD8A12E-E253-4D92-A1B3-79077F032957}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BCE77757-DFDD-4F94-902F-F3EBE06BAF8F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BCEB52DB-ED72-4A55-A526-9FEB77296022}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BD984E62-6474-4E4D-9C99-CC2CD8DA6FA6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BDBFDBCE-4AAE-4793-8CF1-447AC21391C5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BDCEE3CD-6587-4B22-933E-7EAE27614249}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BDF623E3-D938-4F59-8446-1A6F9B62CA30}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BE6361CE-6450-4C76-BD51-99AE11353605}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BE642027-61B7-4DE4-9A14-3DAA2CEE41E9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BE72C523-3065-46B5-965C-BBE10C2DF1A9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BE76C1A0-61A7-43C5-9F4D-794FC69DFF1A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BF1E1BB2-F011-4603-9DFA-57B83E5531E5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BF3BBD28-E14C-4453-947E-FD7809D91F43}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BF93487E-A197-41DB-9CCC-81E42C097AA4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BF9B9482-107D-4750-8234-F4E530CE27F9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BFE0166D-54B5-465F-8FC3-AE8E47D5F6CF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{BFEAC0F4-F0FE-4A80-BEC3-8DA91D254ADD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C048D4E4-BA89-4D31-B643-6749EEE32814}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C0537680-2BE9-4945-8C97-7B12578C8E4A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C0B46587-B9A6-41A0-824C-6736D19C1631}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C0E5BFE0-2FFE-4661-B221-0DDBD2EA5E0E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C10FCCB7-AF6F-430B-BD89-60498CBB827D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C10FE4CC-1240-4A09-9D1C-85EF2FBB8FF4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C1571C65-37DA-4478-9206-468E7626CE89}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C198598C-D926-4A95-8D69-1365B9225115}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C1BA98E4-0EE3-40DD-8184-6FFD48A3A7EC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C1EAB468-253A-434E-A790-FF40997BD9FF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C206C178-73C6-491F-ACA5-B5E577EAD446}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C227D0B1-2097-453C-A6DE-A5482F7FCCBB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C24AB269-32FE-401A-87A3-06B02D0F0652}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C29ADCB2-1DCF-43FC-B3D3-915AFFF135F5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C30951A4-036A-4D25-98E6-90B7D25781EF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C3EB04CF-679D-46B5-9865-2B4CBDEBB01F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C3ECC747-270D-4F4B-87DE-B00FF09ED248}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C4649653-F098-499D-8825-9997A0F35E3F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C476C188-4E5D-4FC6-8633-8EE173C5450B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C4B36743-D61B-420F-9D85-E65C7F5081EF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C4C53599-0592-4D18-8850-168236A2BC2B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C51D86C8-B1B6-4E8E-A34E-4187545FA64F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C5299FEC-7A95-48E4-AE16-8C93962B2B22}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C54A9F55-13F0-42C2-BBD8-580348FD841F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C5733F99-B422-4995-8809-3A1F21AD8EBA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C5D41808-58A7-49F2-A9EC-899D556A0310}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C5E8CFEB-A5D1-4E68-92EF-824CDC49F74A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C615FEEF-E513-4984-8A67-E5146D21EBD7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C70E1D82-9F56-48BF-B9FE-5D1AAD137E8D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C735CF43-0D29-4D6D-A8E8-DA93E9D83CE2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C7A9FAC2-BBD1-41CB-9212-E7CA5BDDA925}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C7F5D8D5-294F-4E71-AFCE-208BF249286B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C8467703-4507-4BA5-9D7F-F4DFB73AB79E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C8A6B9DB-5435-4C69-B971-9FDD7C36EC2D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C8CF0F50-452B-4EC4-B7BB-DE1C7C1FEF8D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C932C754-B4AE-41B7-AA0C-99C1B9A9A2FD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C97740A8-948F-43EF-9676-9533B3E7C646}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{C9F8A3D6-7DC7-4A03-B551-5CBCBCE4CED2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CA13AE7E-C85A-4BE2-9B89-D50B30C3C2CC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CA2C1825-FC77-4FE3-BF14-AFE3D9221EED}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CA39B291-F943-4604-B8DC-23506C2B7A55}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CA4C8BC6-F057-4715-BF41-6AA071D74D67}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CA623C96-EF20-4E23-B031-F9666434A574}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CA861713-7433-41A3-B4EC-AF2E1A15E8F9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CA8B9461-7AA0-4424-89EC-86D432831DED}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CAB4CBB2-8EE0-4E40-AEFD-BE4A188EC1A5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CAE8799B-CD46-4A75-B1BB-5C236CCA24F0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CB1C0003-14A4-422C-8B3F-9DD117069FC7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CBDAA883-D7D9-4DBC-A4FD-B2FB248C4C89}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CBF0480E-D9BD-4C61-9449-EE96E49CF750}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CBFBE359-EEB2-4F82-94EE-37B3CE2D4D36}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CC4572C1-1B12-4DE8-A67E-3FFF1299D7EA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CC92D246-C3D6-4209-B4C8-6E29FE8F1F40}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CD18146C-67C8-4839-9E42-F07403FD1D4C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CD4A70FA-A35A-47E7-9FAE-C47424D637F0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CD658A4E-B62D-4C5B-85E0-C94F6A0F646C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CD831CAB-CD93-4A37-B4C4-433F0D195152}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CE0261C8-A9EF-4E95-BB9F-9F7528DF01C7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CE13C6CA-0F92-4EDF-92C1-F52B2529C3D4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CE1D336E-7743-4717-ADAA-FFBCA30EBC43}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CE2AD853-F531-4696-891F-73B48127C642}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CEAC4427-8747-495F-8010-115A4D5940E4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CEC68AA4-31BF-4666-BEEC-A8295310577C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CED4BBBA-DC53-4725-9911-E0B44D85195A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CED80589-072E-434A-9D25-50CD92C92306}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CF1B9746-C49C-4D99-87C6-4BD026255AFE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CF287F40-30C8-4170-820E-719B44F52B21}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CF2F5007-8F3E-4C5D-89C9-308748D5E747}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CF56EE25-2D3D-43F8-B803-99211481AD25}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{CF5AE2D0-B9B9-4C8E-8870-5826EF159DE7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D02EA363-2D47-4802-A3D8-09B69330A43F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D069067C-6AB6-4207-9D17-D2A6EF2DC133}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D08E268B-36B6-48DC-9AD6-31491BE13D54}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D093272F-1F09-43CC-822B-B8C5E62B1171}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D1186C5D-A584-409B-891B-5E1A006B8819}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D13E67C8-6697-43D7-BD1F-527A8E0AF6FA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D1714C91-BA17-4EFB-AE69-9C17C55B5731}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D19C274E-C897-4DFA-8321-1416B852BEA0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D1A446A7-203A-4CF0-A0A1-39EEB8B92FE7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D1D72EDC-D469-4369-A9FB-B6A6568FAFD8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D2070A57-358B-4A89-BBF9-967A6D1D2AD7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D22DF741-708E-4189-8AB4-9F0B6E91FA0A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D24F58E1-5BF3-42F3-A967-87A95AA3C863}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D2734628-644B-4DAF-97DD-657E9F51F1C8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D297A741-B5C0-4442-A361-3996E3E09B85}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D2F498BA-6F21-434D-BB92-C9DD47F8F703}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D33E7724-68B6-4F98-A9D8-4E309EA68184}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D36DB1FC-929E-481D-9D87-86450299735F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D37311AC-E19B-4984-93AC-9570E4D8669E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D3A10033-3081-47D1-B96C-9A28021091F6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D3B8DA57-FFDF-48A6-A264-CA363D20C5B4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D3BE76A8-FC08-43AE-9F0F-A42F42C21BAA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D3BF3E78-3F3C-4E6B-B244-F60BBB18295D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D3E6C0FC-D666-4FC6-BC05-115249197914}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D4021DF1-79E0-4E86-AF62-B32B8D917B4C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D4130F1F-B20A-4D16-BAE6-B8817729556A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D486BA75-124F-4FBC-94A1-072CBC0D2967}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D4E46C79-1BFB-4A4D-9202-A4B8068452C3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D506A359-0139-4979-A148-464660464B7E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D5451F56-4A0D-4468-9804-D27B82186C9F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D55E1D2C-7673-4B9B-81CC-3108A9336186}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D5BDAC0A-FCB3-40F8-BC1A-1B8F6E635195}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D5BDC2F6-E159-4AE9-BD39-0632C3FE3FFC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D5FEA8F9-6F07-4BB5-BE58-1D65E5C45F34}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D64183FF-541D-42CE-8A63-E5736A51AD0E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D6510FF3-ED1D-4E64-B6C6-5CEAF51AEE85}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D6C85574-D762-4C28-B233-7B93CE9A7135}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D70A9D23-CFB2-4B85-A2D7-B3EB84852F7F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D78A23F1-CC82-4C79-928B-96BC48CF43A9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D78F4832-486A-4780-A9E0-061C6E9177BF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D8438E80-789E-471D-9AE9-E811FDF81D10}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D84B08F2-4413-459B-AE60-F5B95FE41DFD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D86FC66E-5C18-4406-BE23-C9DA135A1D95}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D8A007A1-81FD-4DD3-9C04-BE32243F5A83}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D91B0E3B-B882-4A7C-BEAD-1F09EA2C8E03}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D92A9104-F3AD-4A29-BF8D-BCD62B175720}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D95D6DC0-9F44-4BF0-BA4A-A5C4BEEC121C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{D9E9EEAE-A3E7-48AA-8788-E5748D00DE7F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DA225CB8-6E83-4A97-A5BC-EAED4C0EE6D5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DA5B188E-9071-4D65-8C6A-6824ABB4BF45}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DA60239F-A3FF-46DE-9180-7D1552B9120A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DA8E0C4B-80FC-4D91-A0B4-72E8A2DBBA05}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DAC97BFF-441E-4B9C-904B-200D1243C439}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DAF8C5D2-7A45-4AAF-BD90-F7C956A65A28}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DB1E4808-3037-4226-AA83-E24BEA3BDC38}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DB4003CB-E13F-4292-ABBC-3891B12F1D69}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DB7EAD4C-5E7D-4521-B4C8-7846DDA72294}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DB7F04E3-373B-4B38-B32E-CAB8FF97916F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DB96888B-5F6B-4D68-A5BE-010E95C2662C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DB96B5C9-8B7A-46D1-9B8D-B6723EB92C5F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DBA1CA0C-86DA-4AC3-B5D0-299D58F13F8D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DBDEF4F7-065A-4110-B041-91E86E91E136}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DC259C59-961E-4435-AAA7-A461496FE546}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DC6198D3-AAB7-4B10-908E-1177CC5AEEA3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DC6D5F04-E4B5-428F-B0EB-E90B18496D02}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DC91994C-6183-4E20-A14C-C1D94EF142F9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DC965B6D-2D36-4FB8-9475-DD6EB8469214}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DD197123-DDB0-4B8F-9D2D-37AB8A4A7863}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DD7AD372-0752-479A-BEF9-17F4D742D423}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DDAA69B1-F76A-42B2-96C1-D19509EA4695}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DDD87EC1-2E74-4E7F-A266-D2EEADEDED32}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DDE77C78-C2D5-4A1A-951F-9158F2172855}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DDF09198-CAEB-4EB2-894C-35DDA2FF30F4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DE315B1B-FC84-4AF3-BA6D-6BBAE48B06AA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DE34887E-F8E6-4DF0-BED7-12AE8D1900AC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DE36D2B5-B3F5-4801-A89C-BEE5B0F9581B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DE599141-A800-450C-B5F2-758CB00B6D7F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DE5EE876-5FB5-481A-B0A9-983543656D6C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DE7D0154-8F57-4031-89D5-D0D26E27A0D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DE93B1AE-1DA4-4D50-B772-FBBFAB1B61D5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DECC98CC-6306-4B9C-B457-DA2ADF81B8DE}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DEEA7EB2-2080-4B7B-984B-7777C15907A1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DEEF5AFA-DAE1-4ED9-B89F-D4664F05D8FD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DF514697-3C31-411B-A3D9-4D31FA2E14C0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{DF776E1E-28A2-438C-924E-7C3D015CAF5A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E00024AF-F928-49C5-9562-F07273FC3C22}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E06F48E6-A6BE-4A26-842E-E5A90061354E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E080A6DF-2A7A-4571-AFFA-F75C2D44E432}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E08962F7-E375-4287-AC75-C8BD624CFBBF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E093F172-16D2-4051-857F-6E4539AA4682}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E11D4E7C-CCFC-47D2-9D51-7A5432975C27}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E1370778-68D5-4CB3-AA69-A6DDBA8C04F3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E1457611-0E3D-446B-AEF9-0F7C1A38D4EC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E14E97D0-D2F5-45B6-B5D6-6CA4A6FB12BA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E1897065-3191-40B3-9C16-356A06A8194C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E1DA6C9A-D5B6-46E0-AE19-A1506DCE4792}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E1E9A1A3-39A3-4C38-8CC6-45CBAF92571D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E20B7ABF-AD5A-4B71-8DD6-92FD1A4556B8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E20F3A55-0321-43FB-97D9-95B51BD88B35}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E22ECD65-5547-4A42-A472-01F567EE0FB3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E25C2D53-9527-4BDF-B181-2CA2FDD912D3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E26681AD-3600-4D5E-BAC0-BF5D80829AE3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E26827E5-C83D-4CAC-AF22-94AC83E2AC5F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E2A331E8-8E60-4B57-B34E-B852C16246DB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E2A88DA8-AEF7-4EB2-BCA9-AD8862CB1EB2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E2B7E2EC-BE02-404A-A871-D9E1623ED6FD}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E2F06CFE-3C6F-4847-97CA-7B6259F4D417}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E3F05ADC-30EB-4346-9A5A-AFA6DB56A0B7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E45F39FD-719E-449D-9BFE-60D2D58E7564}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E49D2D06-25A0-4B5E-B6E3-7972107C1687}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E52A54BF-8F80-4257-AC36-E32597C927F4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E52F8152-1253-4DF3-94D9-3F1614A4B5B7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E53532D9-E5CC-4A7A-A383-F5E60B5DE3D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E5A5D2B4-87E4-4B69-9BB3-32330A797836}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E5BD4190-0228-4375-8796-08F04EED63B0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E5EDFA95-E8F3-40A9-B404-8FF1990D9990}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E5F6F34D-B091-4527-97FA-E4A3A72D3D2B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E641E2C4-50AA-4297-8A7D-A855B48167AC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E6B17DC8-0049-4827-A16E-5B1EC5CBD749}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E6B78AC2-5010-45C7-8318-AD37116FC23E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E6D22440-E0A1-4257-96BA-1955BAC9BA53}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E7025A07-F26A-4357-8EA4-1A5520552EEB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E72E112C-BDE2-4C39-9BCE-85DB4779A1E2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E7311432-FB1D-4B77-BB4A-22B1D25285F2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E760E39E-92BB-40B7-9D92-5F71FBC4FD28}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E7A6D7B5-FAA0-4ADC-B2DF-A754D5F876D7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E7C4A9D2-9619-464A-8CF8-3C6C6AC38BE6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E7CC1CA1-BA5E-4C4B-A28B-BCEB6794B49C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E834E170-8C03-4E2B-B15C-1BB77F487B71}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E84F8717-5D83-472B-BDBD-122A8D10A042}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E864FA97-55B0-4D5C-9E38-D88A299BDAB0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E874051D-DE3E-4761-84B4-BF2112F79684}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E87CA0B9-342A-4CD0-B4E5-021E89476A25}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E8F8F4D9-2A85-4C6A-B46E-E8C922ED7022}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E925429B-75BE-44A0-86CF-8D2F0B5868B2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E934F9DE-1C4C-41CA-8317-B167D1AC6384}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E9398B7F-9E97-4321-AACB-76B528D7DD56}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E948F37B-ED1F-4DF1-82E9-5D0BBF156785}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E96B34AE-F63C-43EF-8E12-206AB26AD140}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E9B02BCD-C30C-448A-81DC-E0B4FB27DC1B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E9BAF92B-5E5A-4668-AE71-D81D6705CAC5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{E9DACBE8-A39D-4D12-B014-980DE11E49D6}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EA26D04C-E03C-4631-850F-068A4627806E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EA510864-4280-44D1-BBB5-6F619E4F736E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EA92ECD8-AABB-4068-AEDD-40B7DBB86A3E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EAC2415E-7055-42FE-8CBC-802166E15FFA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EAEB2C6C-EBE6-43CD-9F1E-01C6A8BE7919}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EBE4C68A-5CF4-4C1B-8B43-044543CAA922}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EBEB487E-DE99-4844-9BDC-37AAA0603F1C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EBEBEA94-ED4A-480F-A9A7-F28A54EB7EE3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EC883619-5741-44E5-A590-7E8B08568CC9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ECF6DFE3-C6E2-4E1E-AFF8-FE511C33F293}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ED655A66-A918-45FF-B881-1715B8DD88EF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ED674F09-B58A-44AC-92A8-4AF26A303DF3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{ED880270-AEBE-49D4-844C-C962FF42D4CB}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EDAF7D9D-FD4F-459F-8115-3A995A2383EC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EE362B08-B53F-4EFD-8F9F-D7A1C2376F59}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EE5AC9ED-FB89-4689-B42F-0DFCC530D632}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EEB54DF3-090F-444C-9649-C19189B20024}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EEE6F9E3-A1BA-4D00-A14D-3086E321745C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EF01E624-6535-4233-94E9-4D300A89E65E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EF22D696-1835-4B0A-84E9-DD90E4BCBB45}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EF5FB869-E4E0-42FD-B3AB-7623EDCD5443}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EF9AA754-8EB7-44EA-83AB-2F69B93B215E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{EFB0046C-3F82-4D56-91B5-04AA55D880A1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F02948F7-89D8-4A9F-9C9B-A7FDE22C44E3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F0FAB24E-A114-4704-9743-366AB3BD7A84}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F1246BC3-0FEF-4F12-9A39-0801801A33D5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F13C51F0-6ACB-4AF0-9646-12A47494BAC4}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F15CB7AD-4E6C-4494-8D67-A96C1A804C80}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F173D2FF-A4FF-4A15-98F3-3133F9EAC276}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F181268C-0CB3-40EA-B277-4D7D2138AEF1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F200772B-CEEC-49D4-92E2-BFACCEF207B1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F223B42F-F519-440C-B291-0D69CCA6CFD2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F3ABBA0A-7758-493A-A7C6-E3774B464595}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F3C23AE7-7BA2-4C29-909F-AB48C3364363}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F3CDD706-3038-4FC1-B3B7-D3D24F766D38}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F3D695E4-2007-4B14-A2EB-E1CB9AA0761B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F40194F8-C41C-44D9-B680-E539F57D902B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F42BB566-3EA1-45A8-A355-559C6BDA1E3E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F446C34E-9D69-4B20-B07C-04E772EEC131}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F450CED0-E7D1-4998-A884-36CC2AF0A193}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F455CF8E-4CFD-4165-83B2-028A0DE45CE5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F45BD56B-02F7-4564-845C-89B486D95F76}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F472A4FA-41B9-482A-B635-DAD670E81887}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F4946371-2945-4ADD-9C4D-6154819C5E48}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F4972E82-394A-4EEB-9CFF-E652AFEB4438}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F4ABA6AB-AB79-4648-8854-E3A9BEB71731}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F4DF60FC-9341-4146-BC3A-5D09CC327DAC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F4F04E66-6105-43E2-8847-FA7ECA712780}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F5217531-DD28-48D9-B3CD-3E8E3E71C01D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F53C611B-EB70-40D3-9562-EC85F9506A21}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F5E738B7-2D32-4BD2-9634-657AB5569323}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F675D9CD-751D-4E0C-80A9-43D8CF1EFFF5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F684F162-40DE-42C0-8CBE-13C96EE64B16}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F69D8EFF-93C9-4103-A9EE-48A02208A595}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F6CFD84E-185A-498A-8236-6DB975DC340D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F7048FC2-BB44-4FD5-B221-56D23E274DBC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F70D6BAB-C840-434A-A5E8-AC97EA02E316}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F72CCB1F-5BD7-4E78-9512-F0A745F7EE64}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F77DAB0D-7726-4F4B-B099-7CB8E4038D54}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F7C65ECD-9108-42C2-9B74-AE4A354440D8}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F7D60438-E549-4B87-9E49-42DE3CB2AC9C}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F7D6DE5A-BBF3-4E4F-BA92-163E4BA54BEA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F7DE297B-2382-4CBB-A29F-FE3C3DD880DC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F7E673CE-1449-4AF5-BABF-B9F2F413D8BC}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F7FCE777-D58C-4A7D-8E94-F68203941A3E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F81CBFA9-55FC-4437-9BB1-F611483063DF}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F87C723B-695E-4EDB-B6EA-3CDBE8B3D76E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F893142C-0290-4397-9763-6805DAB84EA3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F90C00A0-EF56-431E-80D9-7696BA3D9A48}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F913150E-F423-490E-8DAB-92DE9F54B57D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F957A9E1-8D19-48BD-94C7-B7D360088710}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F97BA5CF-81A6-4F71-9231-B5F3E8437AB3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F9D22FE5-0FC6-409D-B908-EE13F79F951F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F9EBA8F7-A157-4400-842C-CC0F433BFC40}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F9EBC6DB-5A27-425D-95F6-49C5D37E32B5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{F9EDFECE-400D-4F1C-B70E-4714CD23D05F}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FA3E8F24-36C0-44A3-A83A-2947900FBB2E}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FA44E0C8-31F5-40B0-8E5F-8A4E585085B0}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FA4F3164-715C-4955-AF4F-4D065F5B8673}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FAF34530-C5E8-42DD-9A7E-A3032FDEE794}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FB12F390-5F07-41A7-95B0-589D517E5FA9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FB8046FF-CFB4-492D-B415-2102E13FD416}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FB9EB398-CBDF-4A98-901C-A76F6C390995}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FBA5DE13-5EA6-41BA-A5BB-4B61408233A7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FBB4AB66-59B9-4834-869F-C9EF829176D9}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FBB77EF4-6164-411A-B1B7-C72CDE5BFF63}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FBDA73C8-6E1F-4BA5-84AE-13A7B5732A2B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FBEFBE67-9743-4AF3-8C65-A35E3D51C3B2}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FC420246-9C35-4661-8E8D-01862C6046D1}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FC43D7D0-60F7-41E1-82E8-DBD40A1B5DDA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FC5B00E4-7698-4CDD-973C-353F09D78333}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FCAF5019-483F-4485-A501-A94FDC581DF3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FCC693E9-3E5E-4DEF-9E81-2B7BC5266B94}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FD0551CE-1086-4E09-B2C0-5A2EF80A6580}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FD692FCD-32A7-45E9-8D82-DBC2C019A632}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FDBCA66A-6254-4013-9516-37C2ABEF9C3A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FDF5F444-6CE7-4B54-B9FF-0645906F10EA}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FDFEE3A7-59B6-4F9B-9ADC-87D69E3C673D}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FE513EE6-067B-4586-932E-DB124B0AC217}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FE952E7B-8F5D-4B20-AA99-BD2B0E90D29A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FEDB04FA-77DC-4ADB-9B4A-3A40D219F4F7}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FEE1700A-D84D-4E56-9972-1C9094BF4D98}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FF0F5DBE-316F-4E62-943D-85D4EF7000C5}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FF3C361C-0353-413C-8AAB-99F84F9C74A3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FF58AB7D-6114-43A6-B1D7-1823740B7A4A}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FF58E280-4ACF-4055-823F-69FEA6CA7183}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FF6CE4A2-1757-4858-8C6D-F59BFA6C5CD3}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FFCED7B7-AA73-45A5-A4B9-2C68720A526B}
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{FFFCD020-1255-4D87-8D90-C40C294FD73D}
MJ1
Posts Posts : 66
Post by MJ1 on 6th August 2013, 8:11 pm
~~~ FireFox
Successfully deleted: [File] "C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\fu1bbvtd.default\extensions\jid0-alFZKx8TTaZXKErGGA4i8VSf5rE@jetpack.xpi"
Failed to delete: [Folder] C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\647bilz0.spirit\extensions\iobit@mybrowserbar.com
Failed to delete: [Folder] C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\04s8hdh7.oldlap\extensions\iobit@mybrowserbar.com
Failed to delete: [Folder] C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\y4ng5py9.LittleComp\extensions\iobit@mybrowserbar.com
Failed to delete: [Folder] C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\9b9wxj9e.maybe\extensions\iobit@mybrowserbar.com
Failed to delete: [Folder] C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\647bilz0.spirit\extensions\wtxpcom@mybrowserbar.com
Failed to delete: [Folder] C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\04s8hdh7.oldlap\extensions\wtxpcom@mybrowserbar.com
Failed to delete: [Folder] C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\y4ng5py9.LittleComp\extensions\wtxpcom@mybrowserbar.com
Failed to delete: [Folder] C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\9b9wxj9e.maybe\extensions\wtxpcom@mybrowserbar.com
Successfully deleted the following from C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\fu1bbvtd.default\prefs.js
user_pref("extensions.crossrider.bic", "140277aef9f3f93a6bbdcb0ec0df9251");
user_pref("extensions.seoquake.params.0.icon", "AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7PT7/3zF6/9Ptu//RbHx/0227/+Tzvb/9vv5/97
user_pref("extensions.seoquake.params.1.icon", "AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7PT7/3zF6/9Ptu//RbHx/0227/+Tzvb/9vv5/97
user_pref("extensions.seoquake.params.108.icon", "AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAQAQAABMLAAATCwAAAAAAAAAAAAD//////////////////////////////////////////
user_pref("extensions.seoquake.params.2.icon", "AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7PT7/3zF6/9Ptu//RbHx/0227/+Tzvb/9vv5/97
user_pref("extensions.seoquake.params.3.icon", "AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7PT7/3zF6/9Ptu//RbHx/0227/+Tzvb/9vv5/97
user_pref("extensions.seoquake.params.37.icon", "AAABAAEAEBAAAAAAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAQAQAAAAAAAAAAAAAAAAAAAAAAAD///8B////Af///wHp6en/ubm5/4ODg/+JiYn/YmJi/8
user_pref("extensions.seoquake.params.370.icon", "AAABAAEAEBAAAAAAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAQAQAAAAAAAAAAAAAAAAAAAAAAAD///8B////Af///wHp6en/ubm5/4ODg/+JiYn/YmJi/
user_pref("extensions.seoquake.params.51.icon", "AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAAAQAABILAAASCwAAAAAAAAAAAACgoKB+oKCg56CgoP+goKD/oKCg/6CgoP+goKD/oKCg/6
user_pref("google.toolbar.button_option.cached.gtbSearchBlogs", "user_pref("google.toolbar.button_option.cached.gtbSearchPhotos", "user_pref("google.toolbar.button_option.cached.gtbSearchScholar", "user_pref("google.toolbar.button_option.cached.gtbstoolbar-google-com_CTK0Y7F4MTG6NKYH03WT-xml", "user_pref("google.toolbar.button_option.cached.gtbstoolbar-google-com_J66T77NJDBMW4FEUU7FA-xml", "user_pref("google.toolbar.button_option.cached.gtbuwww-yvoschaap-com_3KM2W26H33IAEB3EEYM9-xml", "user_pref("google.toolbar.search-icon", "data:image/x-icon;base64,AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7PT7/3zF6/9Ptu//RbHx/
Successfully deleted the following from C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\647bilz0.spirit\prefs.js
user_pref("google.toolbar.button_option.cached.gtbSearchBlogs", "user_pref("google.toolbar.button_option.cached.gtbSearchPhotos", "user_pref("google.toolbar.button_option.cached.gtbSearchScholar", "user_pref("google.toolbar.button_option.cached.gtbstoolbar-google-com_CTK0Y7F4MTG6NKYH03WT-xml", "user_pref("google.toolbar.button_option.cached.gtbstoolbar-google-com_J66T77NJDBMW4FEUU7FA-xml", "user_pref("google.toolbar.search-icon", "data:image/x-icon;base64,AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7PT7/3zF6/9Ptu//RbHx/
Successfully deleted the following from C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\04s8hdh7.oldlap\prefs.js
user_pref("extensions.personas.current", "{\"id\":\"15312\",\"name\":\"Killalea\",\"category\":\"Scenery\",\"description\":\"Beach\",\"author\":\"waterboy2528\",\"username\":\
user_pref("extensions.seoquake.params.108.icon", "AAABAAIAEBAAAAAAAABoBQAAJgAAACAgAAAAAAAAqAgAAI4FAAAoAAAAEAAAACAAAAABAAgAAAAAAEABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP///wAGgvsA63YdA
user_pref("extensions.seoquake.params.37.icon", "AAABAAEAEBAAAAEAGABoAwAAFgAAACgAAAAQAAAAIAAAAAEAGAAAAAAAAAAAABMLAAATCwAAAAAAAAAAAACfd02fd02eeE6ed0ugdkuieE2feEyfd02id0yceEihd0
user_pref("google.toolbar.button_option.cached.gtbSearchBooks", "user_pref("google.toolbar.button_option.cached.gtbSearchCalendar", "user_pref("google.toolbar.button_option.cached.gtbSearchDocs", "user_pref("google.toolbar.button_option.cached.gtbSearchFinance", "user_pref("google.toolbar.button_option.cached.gtbSearchPatents", "user_pref("google.toolbar.button_option.cached.gtbSearchPhotos", "user_pref("google.toolbar.button_option.cached.gtbSearchScholar", "user_pref("google.toolbar.button_option.cached.gtbSearchVideo", "user_pref("google.toolbar.button_option.cached.gtbstoolbar-google-com_CTK0Y7F4MTG6NKYH03WT-xml", "user_pref("google.toolbar.button_option.cached.gtbstoolbar-google-com_J66T77NJDBMW4FEUU7FA-xml", "user_pref("google.toolbar.search-icon", "data:image/x-icon;base64,AAABAAEAEBAAAAEAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7PT7/3zF6/9Ptu//RbHx/
Successfully deleted the following from C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\y4ng5py9.LittleComp\prefs.js
user_pref("avg.toolbar.buttons_icon", ",,chrome://avg/skin/safesurf.png,chrome://avg/skin/safesurf.png,chrome://avg/skin/safesearch.png,chrome://avg/skin/avglinks.png,chrome:/
Emptied folder: C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\fu1bbvtd.default\minidumps [44 files]
~~~ Chrome
Successfully deleted: [Folder] C:\Users\Lee\appdata\local\Google\Chrome\User Data\Default\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
~~~ Event Viewer Logs were cleared
Scan was completed on 06/08/2013 at 13:39:54.59
End of JRT log
THE LAST SECURITY CHECK WOULDn'tRUN
I am on Windows 7 64 bit
UNSUPPORTED OPERATING SYSTEM! ABORTED!
DAVE,
THANKS Very much. Please tell the owner of the forum that I keep getting an internal server error if I try to just post over about 60 kb at a time and he should look into that.
MJ1
Posts Posts : 66
Post by Superdave on 7th August 2013, 12:17 am
Please tell the owner of the forum that I keep getting an internal server error if I try to just post over about 60 kb at a time and he should look into that..
I know there is a restriction on the size but I'm not sure how much. I'll try to contact them.
If your version of Windows defaults to you download folder you will need to copy it to your desktop.
To prevent your anti-virus application interfering with ComboFix we need to disable it. See [You must be registered and logged in to see this link.] for a tutorial regarding how to do so if you are unsure.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83211
Post by MJ1 on 7th August 2013, 5:00 am
BIG PROBLEMS
Combo fix made my computer unuseable. I had to go back to a restore point before I ran ADW Cleaner.
Where is the download link for ADW Cleaner, I'm afraid to download it from the internet - in case of a virus.
PLEASE HELP ASAP
MJ1
Posts Posts : 66
Post by MJ1 on 7th August 2013, 5:03 am
Its OK I found ADW Cleaner and will rerun it and Junk removal tool and then post
MJ1
Posts Posts : 66
Post by MJ1 on 8th August 2013, 4:19 am
# AdwCleaner v2.306 - Logfile created 08/06/2013 at 23:07:01
# Updated 19/07/2013 by Xplode
# Operating system : Windows 7 Home Premium Service Pack 1 (64 bits)
# User : Lee - LEE-PC
# Boot Mode : Normal
# Running from : C:\Users\Lee\Desktop\adwcleaner.exe
# Option [Search]
***** [Services] *****
Found : Application Updater
***** [Files / Folders] *****
Folder Found : C:\Program Files (x86)\Application Updater
Folder Found : C:\Program Files (x86)\AVG Secure Search
Folder Found : C:\Program Files (x86)\Common Files\AVG Secure Search
Folder Found : C:\Program Files (x86)\Common Files\spigot
Folder Found : C:\Program Files (x86)\Common Files\Wondershare
Folder Found : C:\Program Files (x86)\Conduit
Folder Found : C:\Program Files (x86)\IObit Apps Toolbar
Folder Found : C:\Program Files (x86)\Wondershare
Folder Found : C:\ProgramData\AVG Secure Search
Folder Found : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Wondershare
Folder Found : C:\Users\Lee\AppData\Local\Google\Chrome\User Data\Default\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
Folder Found : C:\Users\Lee\AppData\LocalLow\Conduit
Folder Found : C:\Users\Lee\AppData\LocalLow\Search Settings
Folder Found : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\04s8hdh7.oldlap\extensions\wtxpcom@mybrowserbar.com
Folder Found : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\245qjfwk.default\extensions\wtxpcom@mybrowserbar.com
Folder Found : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\647bilz0.spirit\extensions\wtxpcom@mybrowserbar.com
Folder Found : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\647bilz0.spirit\StumbleUpon
Folder Found : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\9b9wxj9e.maybe\extensions\wtxpcom@mybrowserbar.com
Folder Found : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\ConduitCommon
Folder Found : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\StumbleUpon
Folder Found : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\y4ng5py9.LittleComp\extensions\toolbar@ask.com
Folder Found : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\y4ng5py9.LittleComp\extensions\wtxpcom@mybrowserbar.com
Folder Found : C:\Users\Lee\AppData\Roaming\OpenCandy
Folder Found : C:\Users\Lee\AppData\Roaming\Wondershare
***** [Registry] *****
Key Found : HKCU\Software\AppDataLow\Software\Conduit
Key Found : HKCU\Software\AppDataLow\Software\Search Settings
Key Found : HKCU\Software\AppDataLow\Software\SmartBar
Key Found : HKCU\Software\AVG Secure Search
Key Found : HKCU\Software\Conduit
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{03EB0E9C-7A91-4381-A220-9B52B641CDB1}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{03EB0E9C-7A91-4381-A220-9B52B641CDB1}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Found : HKCU\Software\Search Settings
Key Found : HKCU\Software\Softonic
Key Found : HKCU\Software\Wajam
Key Found : HKCU\Software\YahooPartnerToolbar
Key Found : HKLM\Software\Application Updater
Key Found : HKLM\Software\AVG Secure Search
Key Found : HKLM\Software\AVG Security Toolbar
Key Found : HKLM\SOFTWARE\Classes\AppID\{1FAEE6D5-34F4-42AA-8025-3FD8F3EC4634}
Key Found : HKLM\SOFTWARE\Classes\AppID\{1FDFF5A2-7BB1-48E1-8081-7236812B12B2}
Key Found : HKLM\SOFTWARE\Classes\AppID\{4D076AB4-7562-427A-B5D2-BD96E19DEE56}
Key Found : HKLM\SOFTWARE\Classes\AppID\{5B1881D1-D9C7-46DF-B041-1E593282C7D0}
Key Found : HKLM\SOFTWARE\Classes\AppID\{BB711CB0-C70B-482E-9852-EC05EBD71DBB}
Key Found : HKLM\SOFTWARE\Classes\AppID\{D616A4A2-7B38-4DBC-9093-6FE7A4A21B17}
Key Found : HKLM\SOFTWARE\Classes\AppID\priam_bho.DLL
Key Found : HKLM\SOFTWARE\Classes\AppID\ScriptHelper.EXE
Key Found : HKLM\SOFTWARE\Classes\AppID\secman.DLL
Key Found : HKLM\SOFTWARE\Classes\AppID\ViProtocol.DLL
Key Found : HKLM\SOFTWARE\Classes\PROTOCOLS\Handler\viprotocol
Key Found : HKLM\SOFTWARE\Classes\ScriptHelper.ScriptHelperApi
Key Found : HKLM\SOFTWARE\Classes\ScriptHelper.ScriptHelperApi.1
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{09C554C3-109B-483C-A06B-F14172F1A947}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{11549FE4-7C5A-4C17-9FC3-56FC5162A994}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{74FB6AFD-DD77-4CEB-83BD-AB2B63E63C93}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{92E5039E-FF1E-4AFB-8F24-87592D20C383}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{9C049BA6-EA47-4AC3-AED6-A66D8DC9E1D8}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{C2AC8A0E-E48E-484B-A71C-C7A937FAAB94}
Key Found : HKLM\SOFTWARE\Classes\ViProtocol.ViProtocolOLE
Key Found : HKLM\SOFTWARE\Classes\ViProtocol.ViProtocolOLE.1
Key Found : HKLM\SOFTWARE\Classes\wajam.WajamDownloader
Key Found : HKLM\SOFTWARE\Classes\wajam.WajamDownloader.1
Key Found : HKLM\Software\Conduit
Key Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Extensions\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\apntoolbarinstaller_RASAPI32
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\apntoolbarinstaller_RASMANCS
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\facemoods_RASAPI32
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\facemoods_RASMANCS
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\wajam_install_RASAPI32
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\wajam_install_RASMANCS
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\WajamUpdater_RASAPI32
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\WajamUpdater_RASMANCS
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{C6FDD0C3-266A-4DC3-B459-28C697C44CDC}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{F25AF245-4A81-40DC-92F9-E9021F207706}
Key Found : HKLM\SOFTWARE\MozillaPlugins\@avg.com/AVG SiteSafety plugin,version=11.0.0.1,application/x-avg-sitesafety-plugin
Key Found : HKLM\Software\Search Settings
Key Found : HKLM\Software\Wajam
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{03EB0E9C-7A91-4381-A220-9B52B641CDB1}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{20E1481B-E285-4ABC-ADC7-AE24842B81CD}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{3C471948-F874-49F5-B338-4F214A2EE0B1}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{826D7151-8D99-434B-8540-082B8C2AE556}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{933B95E2-E7B7-4AD9-B952-7AC336682AE3}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{B658800C-F66E-4EF3-AB85-6C0C227862A9}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{F25AF245-4A81-40DC-92F9-E9021F207706}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{0194532A-A99C-4337-937E-2A452C8957BE}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{03E2A1F3-4402-4121-8B35-733216D61217}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{9E3B11F6-4179-4603-A71B-A55F4BCB0BEC}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{A9379648-F6EB-4F65-A624-1C10411A15D0}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{C401D2CE-DC27-45C7-BC0C-8E6EA7F085D6}
Key Found : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{F16AB1DB-15C0-4456-A29E-4DF24FB9E3D2}
Key Found : HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
Key Found : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{E7DF6BFF-55A5-4EB7-A673-4ED3E9456D39}
Key Found : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{F25AF245-4A81-40DC-92F9-E9021F207706}
Key Found : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{03EB0E9C-7A91-4381-A220-9B52B641CDB1}
Key Found : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{95B7759C-8C7F-4BF1-B163-73684A933233}
Key Found : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Found : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG Secure Search
Key Found : HKLM\SYSTEM\CurrentControlSet\Services\Eventlog\Application\WajamUpdater
Key Found : HKLM\SOFTWARE\Classes\CLSID\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Found : HKLM\SOFTWARE\Classes\Interface\{0194532A-A99C-4337-937E-2A452C8957BE}
Key Found : HKLM\SOFTWARE\Classes\Interface\{03E2A1F3-4402-4121-8B35-733216D61217}
Key Found : HKLM\SOFTWARE\Classes\Interface\{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
Key Found : HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Key Found : HKLM\SOFTWARE\Classes\Interface\{9E3B11F6-4179-4603-A71B-A55F4BCB0BEC}
Key Found : HKLM\SOFTWARE\Classes\Interface\{A9379648-F6EB-4F65-A624-1C10411A15D0}
Key Found : HKLM\SOFTWARE\Classes\Interface\{C401D2CE-DC27-45C7-BC0C-8E6EA7F085D6}
Key Found : HKLM\SOFTWARE\Classes\Interface\{F16AB1DB-15C0-4456-A29E-4DF24FB9E3D2}
Key Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{F25AF245-4A81-40DC-92F9-E9021F207706}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Value Found : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{03EB0E9C-7A91-4381-A220-9B52B641CDB1}]
Value Found : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{0BDA0769-FD72-49F4-9266-E1FB004F4D8F}]
Value Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [vProt]
Value Found : HKLM\SOFTWARE\Mozilla\Firefox\Extensions [Avg@toolbar]
Value Found : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{03EB0E9C-7A91-4381-A220-9B52B641CDB1}]
Value Found : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{95B7759C-8C7F-4BF1-B163-73684A933233}]
***** [Internet Browsers] *****
-\\ Internet Explorer v10.0.9200.16635
[HKLM\SOFTWARE\Microsoft\Internet Explorer\Search - SearchAssistant] = [You must be registered and logged in to see this link.]
-\\ Mozilla Firefox v22.0 (en-US)
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\04s8hdh7.oldlap\prefs.js
[OK] File is clean.
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\245qjfwk.default\prefs.js
[OK] File is clean.
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\647bilz0.spirit\prefs.js
[OK] File is clean.
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\9b9wxj9e.maybe\prefs.js
[OK] File is clean.
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\fu1bbvtd.default\prefs.js
Found : user_pref("CT3035596..clientLogIsEnabled", true);
Found : user_pref("CT3035596..clientLogServiceUrl", "hxxp://clientlog.users.conduit.com/ClientDiagnostics.as[...]
Found : user_pref("CT3035596..uninstallLogServiceUrl", "hxxp://uninstall.users.conduit.com/Uninstall.asmx/Re[...]
Found : user_pref("CT3035596.AboutPrivacyUrl", "hxxp://www.conduit.com/privacy/Default.aspx");
Found : user_pref("CT3035596.CT3035596", "CT3035596");
Found : user_pref("CT3035596.CurrentServerDate", "20-7-2011");
Found : user_pref("CT3035596.DialogsAlignMode", "LTR");
Found : user_pref("CT3035596.DialogsGetterLastCheckTime", "Tue Jul 19 2011 23:39:56 GMT-0600 (Mountain Dayli[...]
Found : user_pref("CT3035596.DownloadReferralCookieData", "{\"BannerName\":\"\",\"BannerTypeId\":\"\",\"Bann[...]
Found : user_pref("CT3035596.FirstServerDate", "20-7-2011");
Found : user_pref("CT3035596.FirstTime", true);
Found : user_pref("CT3035596.FirstTimeFF3", true);
Found : user_pref("CT3035596.FixPageNotFoundErrors", false);
Found : user_pref("CT3035596.GroupingServerCheckInterval", 1440);
Found : user_pref("CT3035596.GroupingServiceUrl", "hxxp://grouping.services.conduit.com/");
Found : user_pref("CT3035596.HasUserGlobalKeys", true);
Found : user_pref("CT3035596.HomePageProtectorEnabled", false);
Found : user_pref("CT3035596.Initialize", true);
Found : user_pref("CT3035596.InitializeCommonPrefs", true);
Found : user_pref("CT3035596.InstallationAndCookieDataSentCount", 1);
Found : user_pref("CT3035596.InstalledDate", "Tue Jul 19 2011 23:39:58 GMT-0600 (Mountain Daylight Time)");
Found : user_pref("CT3035596.IsAlertDBUpdated", true);
Found : user_pref("CT3035596.IsGrouping", false);
Found : user_pref("CT3035596.IsInitSetupIni", true);
Found : user_pref("CT3035596.IsMulticommunity", false);
Found : user_pref("CT3035596.IsOpenThankYouPage", true);
Found : user_pref("CT3035596.IsOpenUninstallPage", true);
Found : user_pref("CT3035596.IsProtectorsInit", true);
Found : user_pref("CT3035596.LanguagePackLastCheckTime", "Tue Jul 19 2011 23:39:58 GMT-0600 (Mountain Daylig[...]
Found : user_pref("CT3035596.LanguagePackReloadIntervalMM", 1440);
Found : user_pref("CT3035596.LanguagePackServiceUrl", "hxxp://translation.users.conduit.com/Translation.ashx[...]
Found : user_pref("CT3035596.LastLogin_3.5.0.12", "Tue Jul 19 2011 23:39:55 GMT-0600 (Mountain Daylight Time[...]
Found : user_pref("CT3035596.LatestVersion", "3.3.3.2");
Found : user_pref("CT3035596.Locale", "en");
Found : user_pref("CT3035596.MCDetectTooltipHeight", "83");
Found : user_pref("CT3035596.MCDetectTooltipUrl", "hxxp://@EB_INSTALL_LINK@/rank/tooltip/?version=1");
Found : user_pref("CT3035596.MCDetectTooltipWidth", "295");
Found : user_pref("CT3035596.MyStuffEnabledAtInstallation", true);
Found : user_pref("CT3035596.OriginalFirstVersion", "3.5.0.12");
Found : user_pref("CT3035596.SearchEngineBeforeUnload", "googe.ca");
Found : user_pref("CT3035596.SearchFromAddressBarIsInit", true);
Found : user_pref("CT3035596.SearchFromAddressBarUrl", "hxxp://search.conduit.com/ResultsExt.aspx?ctid=CT303[...]
Found : user_pref("CT3035596.SearchInNewTabEnabled", true);
Found : user_pref("CT3035596.SearchInNewTabIntervalMM", 1440);
Found : user_pref("CT3035596.SearchInNewTabLastCheckTime", "Tue Jul 19 2011 23:39:56 GMT-0600 (Mountain Dayl[...]
Found : user_pref("CT3035596.SearchInNewTabServiceUrl", "hxxp://newtab.conduit-hosting.com/newtab/?ctid=EB_T[...]
Found : user_pref("CT3035596.SearchInNewTabUsageUrl", "hxxp://Usage.Hosting.conduit-services.com/UsageServic[...]
Found : user_pref("CT3035596.SearchProtectorEnabled", false);
Found : user_pref("CT3035596.SearchProtectorToolbarDisabled", true);
Found : user_pref("CT3035596.ServiceMapLastCheckTime", "Tue Jul 19 2011 23:39:52 GMT-0600 (Mountain Daylight[...]
Found : user_pref("CT3035596.SettingsLastCheckTime", "Tue Jul 19 2011 23:39:54 GMT-0600 (Mountain Daylight T[...]
Found : user_pref("CT3035596.SettingsLastUpdate", "1310989086");
Found : user_pref("CT3035596.ThirdPartyComponentsInterval", 504);
Found : user_pref("CT3035596.ThirdPartyComponentsLastCheck", "Tue Jul 19 2011 23:39:52 GMT-0600 (Mountain Da[...]
Found : user_pref("CT3035596.ThirdPartyComponentsLastUpdate", "1246786978");
Found : user_pref("CT3035596.ToolbarShrinkedFromSetup", false);
Found : user_pref("CT3035596.TrusteLinkUrl", "hxxp://trust.conduit.com/CT3035596");
Found : user_pref("CT3035596.TrustedApiDomains", "conduit.com,conduit-hosting.com,conduit-services.com,clien[...]
Found : user_pref("CT3035596.UserID", "UN70485632756481128");
Found : user_pref("CT3035596.ValidationData_Toolbar", 2);
Found : user_pref("CT3035596.WeatherNetwork", "");
Found : user_pref("CT3035596.WeatherPollDate", "Wed Jul 20 2011 00:40:02 GMT-0600 (Mountain Daylight Time)")[...]
Found : user_pref("CT3035596.WeatherUnit", "C");
Found : user_pref("CT3035596.alertChannelId", "1427173");
Found : user_pref("CT3035596.components.1000034", false);
Found : user_pref("CT3035596.components.1000082", false);
Found : user_pref("CT3035596.components.1000515", false);
Found : user_pref("CT3035596.generalConfigFromLogin", "{\"ApiMaxAlerts\":\"12\",\"SocialDomains\":\"social.c[...]
Found : user_pref("CT3035596.globalFirstTimeInfoLastCheckTime", "Tue Jul 19 2011 23:39:55 GMT-0600 (Mountain[...]
Found : user_pref("CT3035596.homepageProtectorEnableByLogin", true);
Found : user_pref("CT3035596.initDone", true);
Found : user_pref("CT3035596.isAppTrackingManagerOn", true);
Found : user_pref("CT3035596.myStuffEnabled", true);
Found : user_pref("CT3035596.myStuffPublihserMinWidth", 400);
Found : user_pref("CT3035596.myStuffSearchUrl", "hxxp://Apps.conduit.com/search?q=SEARCH_TERM&SearchSourceOr[...]
Found : user_pref("CT3035596.myStuffServiceIntervalMM", 1440);
Found : user_pref("CT3035596.myStuffServiceUrl", "hxxp://mystuff.conduit-services.com/MyStuffService.ashx?Co[...]
Found : user_pref("CT3035596.searchProtectorDialogDelayInSec", 10);
Found : user_pref("CT3035596.searchProtectorEnableByLogin", true);
Found : user_pref("CT3035596.testingCtid", "");
Found : user_pref("CT3035596.toolbarAppMetaDataLastCheckTime", "Tue Jul 19 2011 23:39:55 GMT-0600 (Mountain [...]
Found : user_pref("CT3035596.toolbarContextMenuLastCheckTime", "Tue Jul 19 2011 23:40:03 GMT-0600 (Mountain [...]
Found : user_pref("CT3035596.usagesFlag", 2);
Found : user_pref("CT3072253.ENABALE_HISTORY", "{\"dataType\":\"string\",\"data\":\"true\"}");
Found : user_pref("CT3072253.ENABLE_RETURN_WEB_SEARCH_ON_THE_PAGE", "{\"dataType\":\"string\",\"data\":\"tru[...]
Found : user_pref("CT3072253.FirstTime", "true");
Found : user_pref("CT3072253.FirstTimeFF3", "true");
Found : user_pref("CT3072253.UserID", "UN79232100691103210");
Found : user_pref("CT3072253.addressBarTakeOverEnabledInHidden", "true");
Found : user_pref("CT3072253.autoDisableScopes", -1);
Found : user_pref("CT3072253.cbcountry_001", "CA");
Found : user_pref("CT3072253.cbfirsttime", "Thu Aug 02 2012 21:54:09 GMT-0600 (Mountain Daylight Time)");
Found : user_pref("CT3072253.defaultSearch", "FALSE");
Found : user_pref("CT3072253.embeddedsData", "[{\"appId\":\"129571859753931591\",\"apiPermissions\":{\"cross[...]
Found : user_pref("CT3072253.enableAlerts", "always");
Found : user_pref("CT3072253.enableSearchFromAddressBar", "FALSE");
Found : user_pref("CT3072253.firstTimeDialogOpened", "true");
Found : user_pref("CT3072253.fixPageNotFoundError", "true");
Found : user_pref("CT3072253.fixPageNotFoundErrorInHidden", "true");
Found : user_pref("CT3072253.fixUrls", true);
Found : user_pref("CT3072253.installId", "fftC3F9.tmp.exe");
Found : user_pref("CT3072253.installType", "XPE");
Found : user_pref("CT3072253.isEnableAllDialogs", "{\"dataType\":\"string\",\"data\":\"true\"}");
Found : user_pref("CT3072253.isNewTabEnabled", true);
Found : user_pref("CT3072253.isPerformedSmartBarTransition", "true");
Found : user_pref("CT3072253.isToolbarShrinked", "{\"dataType\":\"string\",\"data\":\"false\"}");
Found : user_pref("CT3072253.isWelcomPage", "{\"dataType\":\"boolean\",\"data\":\"true\"}");
Found : user_pref("CT3072253.navigationAliasesJson", "{\"EB_SEARCH_TERM\":\"hxxp://dl.rutracker.org/forum/dl[...]
Found : user_pref("CT3072253.openThankYouPage", "true");
Found : user_pref("CT3072253.openUninstallPage", "FALSE");
Found : user_pref("CT3072253.search.searchAppId", "129571859753931591");
Found : user_pref("CT3072253.search.searchCount", "0");
Found : user_pref("CT3072253.searchInNewTabEnabledInHidden", "true");
Found : user_pref("CT3072253.selectToSearchBoxEnabled", "{\"dataType\":\"string\",\"data\":\"true\"}");
Found : user_pref("CT3072253.serviceLayer_service_login_isFirstLoginInvoked", "{\"dataType\":\"boolean\",\"d[...]
Found : user_pref("CT3072253.serviceLayer_service_login_loginCount", "{\"dataType\":\"number\",\"data\":\"3\[...]
Found : user_pref("CT3072253.serviceLayer_service_toolbarGrouping_activeCTID", "{\"dataType\":\"string\",\"d[...]
Found : user_pref("CT3072253.serviceLayer_service_toolbarGrouping_activeDownloadUrl", "{\"dataType\":\"strin[...]
Found : user_pref("CT3072253.serviceLayer_service_toolbarGrouping_activeToolbarName", "{\"dataType\":\"strin[...]
Found : user_pref("CT3072253.serviceLayer_service_toolbarGrouping_invoked", "{\"dataType\":\"string\",\"data[...]
Found : user_pref("CT3072253.serviceLayer_services_appTrackingFirstTime_lastUpdate", "1343966047106");
Found : user_pref("CT3072253.serviceLayer_services_appTracking_lastUpdate", "1343966048743");
Found : user_pref("CT3072253.serviceLayer_services_appsMetadata_lastUpdate", "1343966047160");
Found : user_pref("CT3072253.serviceLayer_services_gottenAppsContextMenu_lastUpdate", "1343966048940");
Found : user_pref("CT3072253.serviceLayer_services_login_10.10.20.14_lastUpdate", "1343969054033");
Found : user_pref("CT3072253.serviceLayer_services_otherAppsContextMenu_lastUpdate", "1343966048855");
Found : user_pref("CT3072253.serviceLayer_services_searchAPI_lastUpdate", "1343966046033");
Found : user_pref("CT3072253.serviceLayer_services_serviceMap_lastUpdate", "1343966045488");
Found : user_pref("CT3072253.serviceLayer_services_toolbarContextMenu_lastUpdate", "1343966048908");
Found : user_pref("CT3072253.serviceLayer_services_toolbarSettings_lastUpdate", "1343969053859");
Found : user_pref("CT3072253.serviceLayer_services_translation_lastUpdate", "1343966047184");
Found : user_pref("CT3072253.settingsINI", true);
Found : user_pref("CT3072253.shouldFirstTimeDialog", "false");
Found : user_pref("CT3072253.smartbar.CTID", "CT3072253");
Found : user_pref("CT3072253.smartbar.Uninstall", "0");
Found : user_pref("CT3072253.smartbar.isHidden", true);
Found : user_pref("CT3072253.smartbar.toolbarName", "uTorrentControl2 ");
Found : user_pref("CT3072253.toolbarBornServerTime", "3-8-2012");
Found : user_pref("CT3072253.toolbarCurrentServerTime", "3-8-2012");
Found : user_pref("CT3072253.toolbarDisabled", "true");
Found : user_pref("CT3072253.url_history0001", "hxxp://www.blackhatteam.com/f51/get-the-best-video-producer-[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://alerts.conduit-services.com/root/1427173/1422828/CA", "\"1-1[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://appsmetadata.toolbar.conduit-services.com/?ctid=CT3035596", [...]
Found : user_pref("CommunityToolbar.ETag.hxxp://contextmenu.toolbar.conduit-services.com/?name=GottenApps&lo[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://contextmenu.toolbar.conduit-services.com/?name=OtherApps&loc[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://contextmenu.toolbar.conduit-services.com/?name=SharedApps&lo[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://contextmenu.toolbar.conduit-services.com/?name=Toolbar&local[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://dynamicdialogs.alert.conduit-services.com/alert/dlg.pkg", "\[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://dynamicdialogs.toolbar.conduit-services.com/DLG.pkg?ver=3.5.[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://servicemap.conduit-services.com/Toolbar/?ownerId=CT3035596",[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://settings.toolbar.search.conduit.com/root/CT3035596/CT3035596[...]
Found : user_pref("CommunityToolbar.ETag.hxxp://translation.toolbar.conduit-services.com/?locale=en", "\"634[...]
Found : user_pref("CommunityToolbar.LatestLibsPath", "file:///C:\\Users\\Lee\\AppData\\Roaming\\Mozilla\\Fir[...]
Found : user_pref("CommunityToolbar.LatestToolbarVersionInstalled", "3.5.0.12");
Found : user_pref("CommunityToolbar.SearchFromAddressBarSavedUrl", "");
Found : user_pref("CommunityToolbar.ToolbarsList", "CT3035596");
Found : user_pref("CommunityToolbar.ToolbarsList2", "CT3035596");
Found : user_pref("CommunityToolbar.ToolbarsList4", "CT3035596");
Found : user_pref("CommunityToolbar.globalUserId", "b81f8734-4a32-4230-b269-7f7dcaeaa615");
Found : user_pref("CommunityToolbar.isAlertUrlAddedToFeedItemTable", true);
Found : user_pref("CommunityToolbar.isClickActionAddedToFeedItemTable", true);
Found : user_pref("CommunityToolbar.notifications.alertDialogsGetterLastCheckTime", "Tue Jul 19 2011 23:39:5[...]
Found : user_pref("CommunityToolbar.notifications.alertEnabled", false);
Found : user_pref("CommunityToolbar.notifications.alertInfoInterval", 60);
Found : user_pref("CommunityToolbar.notifications.alertInfoLastCheckTime", "Tue Jul 19 2011 23:40:05 GMT-060[...]
Found : user_pref("CommunityToolbar.notifications.clientsServerUrl", "hxxp://alert.client.conduit.com");
Found : user_pref("CommunityToolbar.notifications.firstTimeAlertShown", true);
Found : user_pref("CommunityToolbar.notifications.locale", "en");
Found : user_pref("CommunityToolbar.notifications.loginIntervalMin", 1440);
Found : user_pref("CommunityToolbar.notifications.loginLastCheckTime", "Tue Jul 19 2011 23:39:53 GMT-0600 (M[...]
Found : user_pref("CommunityToolbar.notifications.loginLastUpdateTime", "1305622559");
Found : user_pref("CommunityToolbar.notifications.messageShowTimeSec", 20);
Found : user_pref("CommunityToolbar.notifications.servicesServerUrl", "hxxp://alert.services.conduit.com");
Found : user_pref("CommunityToolbar.notifications.showTrayIcon", false);
Found : user_pref("CommunityToolbar.notifications.userCloseIntervalMin", 300);
Found : user_pref("CommunityToolbar.notifications.userId", "23b29836-45aa-43c0-bfd9-e56f231976f0");
Found : user_pref("extensions.crossriderapp21154.21154.InstallationThankYouPage", false);
Found : user_pref("extensions.crossriderapp21154.21154.InstallationTime", 1375051903);
Found : user_pref("extensions.crossriderapp21154.21154.active", true);
Found : user_pref("extensions.crossriderapp21154.21154.addressbar", "");
Found : user_pref("extensions.crossriderapp21154.21154.addressbarenhanced", "");
Found : user_pref("extensions.crossriderapp21154.21154.asyncdb_dbWasSet", true);
Found : user_pref("extensions.crossriderapp21154.21154.asyncinternaldb_dbWasSet", true);
Found : user_pref("extensions.crossriderapp21154.21154.backgroundjs", "\n\n/********************************[...]
Found : user_pref("extensions.crossriderapp21154.21154.backgroundver", 26);
Found : user_pref("extensions.crossriderapp21154.21154.can_run_bg_code", true);
Found : user_pref("extensions.crossriderapp21154.21154.certdomaininstaller", "");
Found : user_pref("extensions.crossriderapp21154.21154.changeprevious", false);
Found : user_pref("extensions.crossriderapp21154.21154.cookie.FS_button_status.expiration", "Fri Feb 01 2030[...]
Found : user_pref("extensions.crossriderapp21154.21154.cookie.FS_button_status.value", "1");
Found : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13750519028475.expiration", "Fri Feb 01[...]
Found : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751656370296.expiration", "Fri Feb 01[...]
Found : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel13751656370296.value", "0");
Found : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375803811302.expiration", "Fri Feb 01 [...]
Found : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375803811302.value", "0");
Found : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375803811404.expiration", "Fri Feb 01 [...]
Found : user_pref("extensions.crossriderapp21154.21154.cookie.FSpanel1375803811404.value", "0");
Found : user_pref("extensions.crossriderapp21154.21154.cookie.InstallationTime.expiration", "Fri Feb 01 2030[...]
Found : user_pref("extensions.crossriderapp21154.21154.cookie.InstallationTime.value", "1375051903");
Found : user_pref("extensions.crossriderapp21154.21154.cookie.first_load.expiration", "Fri Feb 01 2030 00:00[...]
Found : user_pref("extensions.crossriderapp21154.21154.cookie.first_load.value", "1");
Found : user_pref("extensions.crossriderapp21154.21154.description", "We make it easy to follow a collection[...]
Found : user_pref("extensions.crossriderapp21154.21154.domain", "");
Found : user_pref("extensions.crossriderapp21154.21154.enablesearch", false);
Found : user_pref("extensions.crossriderapp21154.21154.homepage", "");
Found : user_pref("extensions.crossriderapp21154.21154.iframe", false);
Found : user_pref("extensions.crossriderapp21154.21154.internaldb.InstallerIdentifiers.expiration", "Fri Feb[...]
Found : user_pref("extensions.crossriderapp21154.21154.internaldb.Resources_resource_193336.value", "%22@med[...]
Found : user_pref("extensions.crossriderapp21154.21154.internaldb.installer.expiration", "Fri Feb 01 2030 00[...]
Found : user_pref("extensions.crossriderapp21154.21154.internaldb.installer.value", "%7B%22InstallerIdentifi[...]
Found : user_pref("extensions.crossriderapp21154.21154.js", "\n\n /****************************************[...]
Found : user_pref("extensions.crossriderapp21154.21154.manifesturl", "");
Found : user_pref("extensions.crossriderapp21154.21154.name", "Follow");
Found : user_pref("extensions.crossriderapp21154.21154.newtab", "");
Found : user_pref("extensions.crossriderapp21154.21154.opensearch", "");
Found : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_1.code", "appAPI._cr_config={appID:fun[...]
Found : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_1.name", "base");
Found : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_72.ver", 3);
Found : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_78.code", "if(typeof jQuery!==\"undefi[...]
Found : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_78.name", "CrossriderInfo");
Found : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_78.ver", 3);
Found : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_98.code", "(function(){var b=\"cr_\"+a[...]
Found : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_98.name", "omniCommands");
Found : user_pref("extensions.crossriderapp21154.21154.plugins.plugin_98.ver", 2);
Found : user_pref("extensions.crossriderapp21154.21154.plugins_lists.plugins_0", "4,14,78,16,64,47,72,98");
Found : user_pref("extensions.crossriderapp21154.21154.plugins_lists.plugins_1", "17,14,78,13,16,64,4,1,21,2[...]
Found : user_pref("extensions.crossriderapp21154.21154.plugins_lists.plugins_5", "4,14,78,13,16,64,47,72");
Found : user_pref("extensions.crossriderapp21154.21154.pluginsurl", "hxxps://w9u6a2p6.ssl.hwcdn.net/plugin/a[...]
Found : user_pref("extensions.crossriderapp21154.21154.pluginsversion", 36);
Found : user_pref("extensions.crossriderapp21154.21154.publisher", "follow.net");
Found : user_pref("extensions.crossriderapp21154.21154.searchstatus", 0);
Found : user_pref("extensions.crossriderapp21154.21154.setnewtab", false);
Found : user_pref("extensions.crossriderapp21154.21154.thankyou", "hxxps://app.follow.net/installed-extensio[...]
Found : user_pref("extensions.crossriderapp21154.21154.updateinterval", 360);
Found : user_pref("extensions.crossriderapp21154.21154.ver", 112);
Found : user_pref("extensions.crossriderapp21154.apps", "21154");
Found : user_pref("extensions.crossriderapp21154.bic", "140277aef9f3f93a6bbdcb0ec0df9251");
Found : user_pref("extensions.crossriderapp21154.cid", 21154);
Found : user_pref("extensions.crossriderapp21154.firstrun", false);
Found : user_pref("extensions.crossriderapp21154.hadappinstalled", true);
Found : user_pref("extensions.crossriderapp21154.installationdate", 1375051903);
Found : user_pref("extensions.crossriderapp21154.lastcheck", 22930009);
Found : user_pref("extensions.crossriderapp21154.lastcheckitem", 22930064);
Found : user_pref("extensions.crossriderapp21154.modetype", "production");
Found : user_pref("extensions.crossriderapp21154.reportInstall", true);
Found : user_pref("extensions.crossriderapp21154.statsDailyCounter", 29);
Found : user_pref("extensions.enabledAddons", "beta%40linkdiagnosis.com:2.3.6,kgen%40elitwork.com:0.8.1,onsi[...]
Found : user_pref("extensions.wajam.trace_log", "1359498664571 - onItemAdded - Error Message: response.sendR[...]
File : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\y4ng5py9.LittleComp\prefs.js
Found : user_pref("browser.search.defaultengine", "Ask.com");
Found : user_pref("browser.search.order.1", "Ask.com");
Found : user_pref("extensions.asktb.cbid", "AU");
Found : user_pref("extensions.asktb.default-channel-url-mask", "hxxp://www.ask.com/web?q={query}&o={o}&l={l}[...]
Found : user_pref("extensions.asktb.dtid", "YYYYYYYYCA");
Found : user_pref("extensions.asktb.fresh-install", false);
Found : user_pref("extensions.asktb.l", "dis");
Found : user_pref("extensions.asktb.last-config-req", "1286952108816");
Found : user_pref("extensions.asktb.locale", "en_US");
Found : user_pref("extensions.asktb.o", "1665");
Found : user_pref("extensions.asktb.overlay-reloaded-using-restart", true);
Found : user_pref("extensions.asktb.qsrc", "2871");
Found : user_pref("extensions.asktb.r", "5");
Found : user_pref("extensions.asktb.search-plugin-suggestions-url", "hxxp://ss.websearch.ask.com/query?qsrc=[...]
Found : user_pref("extensions.asktb.search-suggestions-enabled", true);
-\\ Google Chrome v28.0.1500.95
File : C:\Users\Lee\AppData\Local\Google\Chrome\User Data\Default\Preferences
[OK] File is clean.
AdwCleaner[R3].txt - [151952 octets] - [06/08/2013 23:07:01]
AdwCleaner[S1].txt - [156895 octets] - [06/08/2013 12:46:19]
########## EOF - C:\AdwCleaner[R3].txt - [152076 octets] ##########
IT DELETED ALL THE CROSSRIDER STUFF - LIKE ABOVE - I just didn't want the post to be so long.
MJ1
Posts Posts : 66
Joined Joined : 2010-01-22
OS OS : Windows 8 64 bit
Points Points : 26036
Re: Had problem, not sure if fixed, Still some problems
Post by MJ1 on 8th August 2013, 4:20 am
Version: 5.3.4 (08.06.2013:1)
OS: Windows 7 Home Premium x64
Ran by Lee on 06/08/2013 at 23:16:07.75
~~~ Services
~~~ Registry Values
~~~ Registry Keys
Successfully deleted: [Registry Key] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{92B7BE94-5234-4405-BF0B-EA3C1329E8F7}
Successfully deleted: [Registry Key] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{D83ACFC6-F78F-4CBB-BB4D-FBF4000E9C52}
~~~ Files
~~~ Folders
Successfully deleted: [Empty Folder] C:\Users\Lee\appdata\local\{19561FA0-1883-4F37-A071-38E812A38773}
~~~ FireFox
Emptied folder: C:\Users\Lee\AppData\Roaming\mozilla\firefox\profiles\fu1bbvtd.default\minidumps [2 files]
~~~ Chrome
Scan was completed on 06/08/2013 at 23:23:37.52
End of JRT log
MJ1
Posts Posts : 66
Post by Superdave on 8th August 2013, 10:12 pm
Remove the Adware:
  • Please close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Delete.
  • Confirm each time with OK
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
  • Download [You must be registered and logged in to see this link.] on the desktop
  • Close all the running programs
  • Windows Vista/7 users: right click on RogueKiller.exe, click Run as Administrator
  • Otherwise just double-click on RogueKiller.exe
  • Pre-scan will start. Let it finish.
  • Click on SCAN button.
  • A report (RKreport.txt) should open. Post its content in your next reply. (RKreport could also be found on your desktop)
  • If RogueKiller has been blocked, do not hesitate to try a few times more. If really won't run, rename it to winlogon.exe (or winlogon.com) and try again
Captain
Captain
Posts Posts : 4202
Post by MJ1 on 8th August 2013, 10:52 pm
# AdwCleaner v2.306 - Logfile created 08/08/2013 at 16:33:04
# Running from : C:\Users\Lee\Desktop\anti virus\adwcleaner.exe
# Option [Delete]
Deleted on reboot : C:\Program Files (x86)\Common Files\AVG Secure Search
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\04s8hdh7.oldlap\extensions\wtxpcom@mybrowserbar.com
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\245qjfwk.default\extensions\wtxpcom@mybrowserbar.com
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\647bilz0.spirit\extensions\wtxpcom@mybrowserbar.com
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\9b9wxj9e.maybe\extensions\wtxpcom@mybrowserbar.com
Deleted on reboot : C:\Users\Lee\AppData\Roaming\Mozilla\Firefox\Profiles\y4ng5py9.LittleComp\extensions\wtxpcom@mybrowserbar.com
[OK] Registry is clean.
[OK] File is clean.
[OK] File is clean.
[OK] File is clean.
[OK] File is clean.
[OK] File is clean.
[OK] File is clean.
[OK] File is clean.
AdwCleaner[R3].txt - [152123 octets] - [06/08/2013 23:07:01]
AdwCleaner[R4].txt - [2249 octets] - [08/08/2013 16:32:10]
AdwCleaner[S2].txt - [2210 octets] - [08/08/2013 16:33:04]
########## EOF - C:\AdwCleaner[S2].txt - [2270 octets] ##########
RogueKiller V8.6.5 [Aug 5 2013] by Tigzy
mail : tigzyRKgmailcom
Feedback : [You must be registered and logged in to see this link.]
Website : [You must be registered and logged in to see this link.]
Blog : [You must be registered and logged in to see this link.]
Operating System : Windows 7 (6.1.7601 Service Pack 1) 64 bits version
Started in : Normal mode
User : Lee [Admin rights]
Mode : Scan -- Date : 08/08/2013 16:47:01
| ARK || FAK || MBR |
¤¤¤ Bad processes : 0 ¤¤¤
¤¤¤ Registry Entries : 10 ¤¤¤
[RUN][SUSP PATH] HKCU\[...]\Run : Google Update ("C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe" /c [7]) -> FOUND
[RUN][SUSP PATH] HKUS\S-1-5-21-778683235-4113038535-2645213809-1000\[...]\Run : Google Update ("C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe" /c [7]) -> FOUND
[HJ POL] HKCU\[...]\System : DisableTaskMgr (0) -> FOUND
[HJ POL] HKCU\[...]\System : DisableRegistryTools (0) -> FOUND
[HJ POL] HKLM\[...]\System : DisableTaskMgr (0) -> FOUND
[HJ POL] HKLM\[...]\System : DisableRegistryTools (0) -> FOUND
[HJ POL] HKLM\[...]\Wow6432Node\[...]\System : DisableTaskMgr (0) -> FOUND
[HJ POL] HKLM\[...]\Wow6432Node\[...]\System : DisableRegistryTools (0) -> FOUND
[HJ DESK] HKLM\[...]\NewStartPanel : {59031a47-3f72-44a7-89c5-5595fe6b30ee} (1) -> FOUND
[HJ DESK] HKLM\[...]\NewStartPanel : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> FOUND
¤¤¤ Scheduled tasks : 6 ¤¤¤
[V1][SUSP PATH] ROC_REG_JAN_DELETE.job : C:\ProgramData\AVG January 2013 Campaign\ROC.exe - /DELETE_FROM_SYSTEM=1 [7] -> FOUND
[V1][SUSP PATH] GoogleUpdateTaskUserS-1-5-21-778683235-4113038535-2645213809-1000UA.job : C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe - /ua /installsource scheduler [7][x] -> FOUND
[V1][SUSP PATH] GoogleUpdateTaskUserS-1-5-21-778683235-4113038535-2645213809-1000Core.job : C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe - /c [7] -> FOUND
[V2][SUSP PATH] GoogleUpdateTaskUserS-1-5-21-778683235-4113038535-2645213809-1000Core : C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe - /c [7] -> FOUND
[V2][SUSP PATH] GoogleUpdateTaskUserS-1-5-21-778683235-4113038535-2645213809-1000UA : C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe - /ua /installsource scheduler [7][x] -> FOUND
[V2][SUSP PATH] ROC_REG_JAN_DELETE : C:\ProgramData\AVG January 2013 Campaign\ROC.exe - /DELETE_FROM_SYSTEM=1 [7] -> FOUND
¤¤¤ Startup Entries : 0 ¤¤¤
¤¤¤ Web browsers : 3 ¤¤¤
[FF][PROXY] fu1bbvtd.default : user_pref("network.proxy.hxxp", "72.64.146.135"); -> FOUND
[FF][PROXY] fu1bbvtd.default : user_pref("network.proxy.hxxp_port", 8080); -> FOUND
[FF][PROXY] fu1bbvtd.default : user_pref("network.proxy.type", 4); -> FOUND
¤¤¤ Particular Files / Folders: ¤¤¤
¤¤¤ Driver : [NOT LOADED 0x0] ¤¤¤
¤¤¤ External Hives: ¤¤¤
¤¤¤ Infection : ¤¤¤
¤¤¤ HOSTS File: ¤¤¤
--> %SystemRoot%\System32\drivers\etc\hosts
¤¤¤ MBR Check: ¤¤¤
+++++ PhysicalDrive0: SAMSUNG HM641JI SATA Disk Device +++++
--- User ---
[MBR] 152119d5095f36dd5e9d641eabbd95d
[BSP] 41e57188139b0569d5455402cfb9a252 : Windows 7/8 MBR Code
Partition table:
0 - [XXXXXX] ACER (0x27) [VISIBLE] Offset (sectors): 2048 | Size: 22528 Mo
1 - [ACTIVE] NTFS (0x07) [VISIBLE] Offset (sectors): 46139392 | Size: 100 Mo
2 - [XXXXXX] NTFS (0x07) [VISIBLE] Offset (sectors): 46344192 | Size: 235520 Mo
3 - [XXXXXX] EXTEN-LBA (0x0f) [VISIBLE] Offset (sectors): 528689152 | Size: 352330 Mo
User = LL1 ... OK!
User = LL2 ... OK!
Finished : << RKreport[0]_S_08082013_164701.txt >>
MJ1
Posts Posts : 66
Post by Superdave on 8th August 2013, 10:57 pm
Please run RogueKiller again and delete those items.
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Captain
Captain
Posts Posts : 4202
Post by MJ1 on 9th August 2013, 6:30 am
Thanks so much for all your help!!
Mode : Remove -- Date : 08/08/2013 18:03:42
| ARK || FAK || MBR |
[RUN][SUSP PATH] HKCU\[...]\Run : Google Update ("C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe" /c [7]) -> DELETED
[RUN][SUSP PATH] HKUS\S-1-5-21-778683235-4113038535-2645213809-1000\[...]\Run : Google Update ("C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe" /c [7]) -> [0x2] The system cannot find the file specified.
[HJ POL] HKCU\[...]\System : DisableTaskMgr (0) -> DELETED
[HJ POL] HKCU\[...]\System : DisableRegistryTools (0) -> DELETED
[HJ POL] HKLM\[...]\System : DisableTaskMgr (0) -> DELETED
[HJ POL] HKLM\[...]\System : DisableRegistryTools (0) -> DELETED
[HJ POL] HKLM\[...]\Wow6432Node\[...]\System : DisableTaskMgr (0) -> [0x2] The system cannot find the file specified.
[HJ POL] HKLM\[...]\Wow6432Node\[...]\System : DisableRegistryTools (0) -> [0x2] The system cannot find the file specified.
[HJ DESK] HKLM\[...]\NewStartPanel : {59031a47-3f72-44a7-89c5-5595fe6b30ee} (1) -> REPLACED (0)
[HJ DESK] HKLM\[...]\NewStartPanel : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> REPLACED (0)
[V1][SUSP PATH] ROC_REG_JAN_DELETE.job : C:\ProgramData\AVG January 2013 Campaign\ROC.exe - /DELETE_FROM_SYSTEM=1 [7] -> DELETED
[V1][SUSP PATH] GoogleUpdateTaskUserS-1-5-21-778683235-4113038535-2645213809-1000UA.job : C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe - /ua /installsource scheduler [7][x] -> DELETED
[V1][SUSP PATH] GoogleUpdateTaskUserS-1-5-21-778683235-4113038535-2645213809-1000Core.job : C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe - /c [7] -> DELETED
[V2][SUSP PATH] GoogleUpdateTaskUserS-1-5-21-778683235-4113038535-2645213809-1000Core : C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe - /c [7] -> DELETED
[V2][SUSP PATH] GoogleUpdateTaskUserS-1-5-21-778683235-4113038535-2645213809-1000UA : C:\Users\Lee\AppData\Local\Google\Update\GoogleUpdate.exe - /ua /installsource scheduler [7][x] -> ERROR DELETING TASK
[V2][SUSP PATH] ROC_REG_JAN_DELETE : C:\ProgramData\AVG January 2013 Campaign\ROC.exe - /DELETE_FROM_SYSTEM=1 [7] -> ERROR DELETING TASK
¤¤¤ Infection : ¤¤¤
¤¤¤ HOSTS File: ¤¤¤
¤¤¤ MBR Check: ¤¤¤
--- User ---
[MBR] 152119d5095f36dd5e9d641eabdbd95d
Partition table:
User = LL1 ... OK!
User = LL2 ... OK!
Finished : << RKreport[0]_D_08082013_180342.txt >>
ESET
C:\Users\Lee\Documents\ABC37\Sales Copy Pro $7\SalesCopyPro\Software\SalesCopyPro.exe Win32/Packed.Themida.AAG trojan cleaned by deleting - quarantined
MJ1
Posts Posts : 66
Post by MJ1 on 9th August 2013, 7:57 am
Just ran Rogue killer again
Mode : Scan -- Date : 08/09/2013 01:53:00
| ARK || FAK || MBR |
¤¤¤ Registry Entries : 0 ¤¤¤
¤¤¤ Scheduled tasks : 0 ¤¤¤
¤¤¤ Web browsers : 0 ¤¤¤
¤¤¤ Infection :  ¤¤¤
¤¤¤ HOSTS File: ¤¤¤
¤¤¤ MBR Check: ¤¤¤
--- User ---
Partition table:
User = LL1 ... OK!
User = LL2 ... OK!
Finished : << RKreport[0]_S_08092013_015300.txt >>
RKreport[0]_D_08082013_180342.txt;RKreport[0]_S_08082013_164701.txt;RKreport[0]_S_08082013_180823.txt
MJ1
Posts Posts : 66
Post by Superdave on 9th August 2013, 2:51 pm
And now the ESET scan.
Captain
Captain
Posts Posts : 4202
Post by MJ1 on 10th August 2013, 2:36 am
I had posted the ESET scan above - it is so short you probably missed it.
ESET
MJ1
Posts Posts : 66
Post by Superdave on 10th August 2013, 10:22 pm
How's your computer working now? Any other issues before we clean up?
Captain
Captain
Posts Posts : 4202
Post by MJ1 on 12th August 2013, 1:00 am
It's working great. Thanks very much!!
MJ1
Posts Posts : 66
Post by Superdave on 12th August 2013, 1:18 am
Great, we can do some cleanup and be finished.
To set a new Restore Point.
Click Start button , click Control Panel, click System and Maintenance, and then clicking System. In the left pane, click System Protection. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. To turn off System Protection for a hard disk, clear the check box next to the disk, and then click OK. Reboot to Normal Mode.
Click the Start button , click Control Panel, click System and Maintenance, and then click System.
To turn on System Protection for a hard disk, select the check box next to the disk, and then click OK.
This will give you a new, clean Restore Point.
Go to [You must be registered and logged in to see this link.] and get all critical updates.
I suggest using [You must be registered and logged in to see this link.]. WOT is a free Internet security addon for your browser. It will keep you safe from online scams, identity theft, spyware, spam, viruses and unreliable shopping sites. WOT warns you before you interact with a risky website. It's easy and it's free.
[You must be registered and logged in to see this link.]- Secure your Internet Explorer to make it harder for ActiveX programs to run on your computer. Also stop certain cookies from being added to your computer when running Mozilla based browsers like Firefox.
* [You must be registered and logged in to see this link.] from Spyware and Malware
* If you don't know what ActiveX controls are, see [You must be registered and logged in to see this link.]
Protect yourself against spyware using the Immunize feature in [You must be registered and logged in to see this link.] Guide: [You must be registered and logged in to see this link.] to prevent spyware infection in real-time. Note: To ensure you have the latest Immunizations always update Spybot - Search & Destroy before Immunizing. [You must be registered and logged in to see this link.]
Check out [You must be registered and logged in to see this link.] for tips and free tools to help keep you safe in the future.
Also see [You must be registered and logged in to see this link.] for free cleaning/maintenance tools to help keep your computer running smoothly.
Safe Surfing!
Captain
Captain
Posts Posts : 4202
Post by MJ1 on 12th August 2013, 2:59 am
Thanks again.
I'll finish it up and hopefully won't be back anytime soon.
God Bless You
MJ1
Posts Posts : 66
Post by Superdave on 12th August 2013, 7:04 pm
I will lock this thread. If you need it re-opened, please send me a pm.
Captain
Captain
Posts Posts : 4202
