avast antivirus problem
Solved avast antivirus problem
Post by nikolay2013 on Thu 01 Aug 2013, 11:05 am
There's a problem with a avast antivirus Ive taken a full system scan 1 hour long the result was
"Some files could not be scanned".
So I go into my control panel.
And clicked the update, after that I clicked repair. So I
took another avast antivirus full system scan,
this one was 30 minutes, it said the same result...
"Some files could not be scanned". So, im just hoping one of you guys can help me out?
Also, I cannot apply the following action's:
Repair, Move to chest, Delete, Do nothing
(Nevermind uninstalled avast)
Rookie Surfer
Rookie Surfer
Operating System : Windows 8 x64
Solved Re: avast antivirus problem
Post by Jan2011 on Mon 05 Aug 2013, 11:44 pm
Could be the files are password protected.
Is there any more information in the error message?
Advanced Surfer
Advanced Surfer
Operating System : xp
