Not able to Access sites anymore and will not load
Page 1 of 2 1, 2  Next
Post by Lynangeel on Tue 23 Apr 2013, 2:12 am
Having problems with regular sites that I can no longer access. Every time I put in pass word and user name it just keeps erasing the text and starting over. Also certain accounts will not load. Like facebook. Getting a yellow caution sign. When click on it it says "Big Pipe" is null or not an object. Have ran all kinds of scans and nothing comes up regarding viruses and such. Was told to download google chrome in order for certain things to work because my browser no longer supports certain programs. I did but didn't seem to help so took it off also. Thanks
Lynangeel
Rookie Surfer
Rookie Surfer
Operating System : XP
Re: Not able to Access sites anymore and will not load
Post by Superdave on Tue 23 Apr 2013, 9:18 am
What is your default browser?
  • Please close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Delete.
  • Confirm each time with OK
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
Link 1
Link 2
Tech Staff
Tech Staff
Post by Lynangeel on Wed 24 Apr 2013, 2:29 am
Internet explorer 8
Sorry not able to to get log from adwcleaner. The first time ran my avg deleted it as a threat. Ran it again and the computer didn't restart properly and log didn't show up and not able to get it from c:\
Malwarebytes Anti-Malware 1.75.0.1300
Database version: v2013.04.23.03
Windows XP Service Pack 3 x86 NTFS
LYNDA :: GENERAL1 [administrator]
4/23/2013 9:53:10 AM
mbam-log-2013-04-23 (09-53-10).txt
Scan type: Full scan (C:\|D:\|E:\|F:\|)
Scan options disabled: P2P
Objects scanned: 257189
Time elapsed: 1 hour(s), 17 minute(s), 47 second(s)
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 2
C:\Documents and Settings\All Users\Application Data\USTechSupport\Stub\279c82b77a94401f8e70192172d73c0a\FrameworkMSI.msi (Trojan.Agent.ED) -> Quarantined and deleted successfully.
C:\WINDOWS\Installer\fabf1e0.msi (Trojan.Agent.ED) -> Quarantined and deleted successfully.
(end)
Results of screen317's Security Check version 0.99.63
Internet Explorer 8
Windows Firewall Disabled!
AVG AntiVirus Free Edition 2013
Antivirus up to date!
SUPERAntiSpyware
Malwarebytes Anti-Malware version 1.75.0.1300
CCleaner
Java(TM) 6 Update 24
Java(TM) 7
Java version out of Date!
Adobe Flash Player 11.6.602.180
Adobe Reader 10.1.6 Adobe Reader out of Date!
Google Chrome 26.0.1410.64
AVG avgwdsvc.exe
AVG avgrsx.exe
AVG avgnsx.exe
AVG avgemc.exe
Total Fragmentation on Drive C:: 5%
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Superdave on Wed 24 Apr 2013, 5:02 am
You really should turn on your Windows Firewall.
Update Your Java (JRE)
First Verify your Java Version
If your version is out of date install the newest version of the Sun Java Runtime Environment.
Remove any old versions
1. Download JavaRa and unzip the file to your Desktop.
3. Once complete exit JavaRA.
Additional Note: The Java Quick Starter (JQS.exe) adds a service to improve the initial startup time of Java applets and applications. To disable the JQS service if you don't want to use it, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and reboot your computer.
Update your Adobe Reader. get.adobe.com/reader.
Be sure to uncheck the Free McAfee Security Scan so it isn't installed.
If your version of Windows defaults to you download folder you will need to copy it to your desktop.
Link 1
Link 2
Link 3
To prevent your anti-virus application interfering with ComboFix we need to disable it. See here for a tutorial regarding how to do so if you are unsure.
Tech Staff
Tech Staff
Post by Lynangeel on Wed 24 Apr 2013, 12:47 pm
Version: 4.8.9 (04.22.2013:1)
OS: Microsoft Windows XP x86
Ran by LYNDA on Tue 04/23/2013 at 20:39:14.82
~~~ Services
~~~ Registry Values
Successfully repaired: [Registry Value] HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}\\DisplayName
Successfully repaired: [Registry Value] HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}\\URL
~~~ Registry Keys
Successfully deleted: [Registry Key] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{84dc9f6c-c9a5-4c64-ab67-d6ef60f963c8}
Successfully deleted: [Registry Key] HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes\{D74B9A06-0A0B-4B21-93C8-51760C1BC71B}
Successfully deleted: [Registry Key] HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\SearchScopes\{84dc9f6c-c9a5-4c64-ab67-d6ef60f963c8}
~~~ Files
Successfully deleted: [File] "C:\WINDOWS\couponprinter.ocx"
~~~ Folders
Successfully deleted: [Folder] "C:\Documents and Settings\LYNDA\Application Data\drivercure"
Successfully deleted: [Folder] "C:\Documents and Settings\LYNDA\Application Data\fixcleaner"
Successfully deleted: [Folder] "C:\Documents and Settings\LYNDA\Local Settings\Application Data\shopping sidekick plugin"
Scan was completed on Tue 04/23/2013 at 20:42:52.75
End of JRT log
ComboFix 13-04-23.02 - LYNDA 04/23/2013 21:14:35.3.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1014.479 [GMT -7:00]
Running from: c:\documents and settings\LYNDA\Desktop\ComboFix.exe
AV: AVG AntiVirus Free Edition 2013 *Disabled/Updated* {17DDD097-36FF-435F-9E1B-52D74245D6BF}
FW: Outpost Firewall *Enabled* {8A20CA2A-9E02-4A64-923B-0A38208EB7FD}
---- Previous Run -------
c:\documents and settings\All Users\Application Data\TEMP
c:\windows\system32\Cache
c:\windows\system32\Cache\01fdeb06c6916001.fb
c:\windows\system32\Cache\209784db9d3e92d9.fb
c:\windows\system32\Cache\26c630d098e22dd5.fb
c:\windows\system32\Cache\272512937d9e61a4.fb
c:\windows\system32\Cache\287204568329e189.fb
c:\windows\system32\Cache\28bc8f716fd76a47.fb
c:\windows\system32\Cache\2c53092c95605355.fb
c:\windows\system32\Cache\2e9494bef18c1546.fb
c:\windows\system32\Cache\31a0997e9a5b5eb3.fb
c:\windows\system32\Cache\32c84fe32bb74d60.fb
c:\windows\system32\Cache\3917078cb68ec657.fb
c:\windows\system32\Cache\4179493e364a4820.fb
c:\windows\system32\Cache\590ba23ce359fd0c.fb
c:\windows\system32\Cache\610289e025a3ee9a.fb
c:\windows\system32\Cache\629a173f46078c61.fb
c:\windows\system32\Cache\651c5d3cdbfb8bd1.fb
c:\windows\system32\Cache\6c59ac5e7e7a3ad0.fb
c:\windows\system32\Cache\6d03dad1035885d3.fb
c:\windows\system32\Cache\95f567698be8a182.fb
c:\windows\system32\Cache\a8556537add6dfc5.fb
c:\windows\system32\Cache\ad10a52aff5e038d.fb
c:\windows\system32\Cache\b4124a28bf4ae530.fb
c:\windows\system32\Cache\c1fa887b03019701.fb
c:\windows\system32\Cache\c4d28dca2e7648be.fb
c:\windows\system32\Cache\c86aaf61020398ae.fb
c:\windows\system32\Cache\ca04c5bf9cf41e41.fb
c:\windows\system32\Cache\d201ef9910cd39de.fb
c:\windows\system32\Cache\d2e94710a5708128.fb
c:\windows\system32\Cache\d79b9dfe81484ec4.fb
c:\windows\system32\Cache\e0de16f883bea794.fb
c:\windows\system32\Cache\f308386bb2659098.fb
c:\windows\system32\Cache\f998975c9cc711ee.fb
c:\windows\system32\Cache\fdd4c88acd586878.fb
c:\windows\system32\PowerToyReadme.htm
c:\windows\system32\SETABB8.tmp
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Lynangeel on Wed 24 Apr 2013, 12:49 pm
((((((((((((((((((((((((( Files Created from 2013-03-24 to 2013-04-24 )))))))))))))))))))))))))))))))
2013-04-24 03:39 . 2013-04-24 03:39 -------- d-----w- c:\windows\ERUNT
2013-04-24 03:39 . 2013-04-24 03:39 -------- d-----w- C:\JRT
2013-04-24 03:01 . 2013-04-24 03:01 -------- d-----w- c:\program files\Common Files\Java
2013-04-24 03:01 . 2013-04-24 03:01 866720 ----a-w- c:\windows\system32\npDeployJava1.dll
2013-04-24 03:01 . 2013-04-24 03:01 94112 ----a-w- c:\windows\system32\WindowsAccessBridge.dll
2013-04-24 02:54 . 2013-04-24 02:54 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee
2013-04-19 03:43 . 2013-04-19 03:43 -------- d-----w- c:\documents and settings\LYNDA\Application Data\magicJackOutlookAddIn
2013-04-24 03:01 . 2011-07-05 18:33 144896 ----a-w- c:\windows\system32\javacpl.cpl
2013-04-24 03:01 . 2010-11-18 03:21 788896 ----a-w- c:\windows\system32\deployJava1.dll
2013-04-17 00:06 . 2012-06-13 21:18 691592 ----a-w- c:\windows\system32\FlashPlayerApp.exe
2013-04-17 00:06 . 2011-05-18 16:04 71048 ----a-w- c:\windows\system32\FlashPlayerCPLApp.cpl
2013-04-04 21:50 . 2011-04-24 01:42 22856 ----a-w- c:\windows\system32\drivers\mbam.sys
2013-03-08 08:36 . 2010-11-18 01:31 293376 ----a-w- c:\windows\system32\winsrv.dll
2013-03-07 01:32 . 2008-04-14 00:54 2149888 ----a-w- c:\windows\system32\ntoskrnl.exe
2013-03-07 00:50 . 2008-04-14 00:01 2028544 ----a-w- c:\windows\system32\ntkrnlpa.exe
2013-03-02 02:06 . 2010-11-18 01:31 916480 ----a-w- c:\windows\system32\wininet.dll
2013-03-02 02:06 . 2010-11-18 01:31 43520 ----a-w- c:\windows\system32\licmgr10.dll
2013-03-02 02:06 . 2010-11-18 01:31 1469440 ----a-w- c:\windows\system32\inetcpl.cpl
2013-03-02 01:25 . 2010-11-18 01:31 1867264 ----a-w- c:\windows\system32\win32k.sys
2013-03-02 01:08 . 2010-11-18 01:31 385024 ----a-w- c:\windows\system32\html.iec
2013-03-01 17:32 . 2011-12-23 20:32 22328 ----a-w- c:\windows\system32\drivers\avgidsshimx.sys
2013-02-27 07:56 . 2010-11-18 02:41 2067456 ----a-w- c:\windows\system32\mstscax.dll
2013-02-27 06:40 . 2011-12-23 20:32 208184 ----a-w- c:\windows\system32\drivers\avgidsdriverx.sys
2013-02-19 07:54 . 2012-09-04 17:18 33112 ----a-w- c:\windows\system32\drivers\avgtpx86.sys
2013-02-14 10:52 . 2011-02-10 14:54 182072 ----a-w- c:\windows\system32\drivers\avgtdix.sys
2013-02-12 00:32 . 2010-11-18 01:31 12928 ----a-w- c:\windows\system32\drivers\usb8023.sys
2013-02-08 11:37 . 2011-03-01 21:25 96568 ----a-w- c:\windows\system32\drivers\avgmfx86.sys
2013-02-08 11:37 . 2012-09-21 11:46 245048 ----a-w- c:\windows\system32\drivers\avglogx.sys
2013-02-08 11:37 . 2012-04-19 11:50 60216 ----a-w- c:\windows\system32\drivers\avgidshx.sys
2013-02-08 11:37 . 2011-01-07 13:41 170808 ----a-w- c:\windows\system32\drivers\avgldx86.sys
2013-02-08 11:37 . 2011-01-19 11:32 39224 ----a-w- c:\windows\system32\drivers\avgrkx86.sys
2013-02-05 17:54 . 2013-02-05 17:54 0 ----a-w- c:\windows\system32\drivers\etqrjsby(2).sys
2013-01-31 06:18 . 2013-01-31 06:18 0 ----a-w- c:\windows\system32\drivers\mbamswissarmy(2).sys
2013-01-26 03:55 . 2010-11-18 01:31 552448 ----a-w- c:\windows\system32\oleaut32.dll
------- Sigcheck -------
Note: Unsigned files aren't necessarily malware.
[-] 2008-08-21 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\system32\ReinstallBackups\0005\DriverFiles\i386\atapi.sys
[-] 2008-04-14 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\atapi.sys
[-] 2008-04-14 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\atapi.sys
[-] 2008-04-14 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\system32\drivers\atapi.sys
[-] 2008-04-14 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\system32\ReinstallBackups\0014\DriverFiles\i386\atapi.sys
[-] 2008-08-21 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\asyncmac.sys
[-] 2008-08-21 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\asyncmac.sys
[-] 2008-08-21 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\system32\drivers\asyncmac.sys
[-] 2008-08-21 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\ERDNT\cache\beep.sys
[-] 2008-08-21 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\system32\dllcache\beep.sys
[-] 2008-08-21 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\system32\drivers\beep.sys
[-] 2008-08-21 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\kbdclass.sys
[-] 2008-08-21 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\system32\drivers\kbdclass.sys
[-] 2008-08-21 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\ndis.sys
[-] 2008-08-21 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ndis.sys
[-] 2008-08-21 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ndis.sys
[-] 2008-08-21 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\ntfs.sys
[-] 2008-08-21 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\I386\NTFS.SYS
[-] 2008-08-21 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ntfs.sys
[-] 2008-08-21 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ntfs.sys
[-] 2008-08-21 . 73C1E1F395918BC2C6DD67AF7591A3AD . 2944 . . [5.1.2600.0] . . c:\windows\ERDNT\cache\null.sys
[-] 2008-08-21 . 73C1E1F395918BC2C6DD67AF7591A3AD . 2944 . . [5.1.2600.0] . . c:\windows\system32\dllcache\null.sys
[-] 2008-08-21 . 73C1E1F395918BC2C6DD67AF7591A3AD . 2944 . . [5.1.2600.0] . . c:\windows\system32\drivers\null.sys
[-] 2008-06-20 . AD978A1B783B5719720CFF204B666C8E . 361600 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB2509553\SP3QFE\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\ERDNT\cache\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\system32\dllcache\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\system32\drivers\tcpip.sys
[-] 2012-07-06 . CFD4E51402DA9838B5A04AE680AF54A0 . 78336 . . [5.1.2600.6260] . . c:\windows\SoftwareDistribution\Download\4a0e4531b96faf560594eec84d879de6\sp3gdr\browser.dll
[-] 2012-07-06 . CFD4E51402DA9838B5A04AE680AF54A0 . 78336 . . [5.1.2600.6260] . . c:\windows\system32\browser.dll
[-] 2012-07-06 . CFD4E51402DA9838B5A04AE680AF54A0 . 78336 . . [5.1.2600.6260] . . c:\windows\system32\dllcache\browser.dll
[-] 2012-07-06 . FC6D1D80588D371F0321E15A75B2F8F2 . 78336 . . [5.1.2600.6260] . . c:\windows\$hf_mig$\KB2705219\SP3QFE\browser.dll
[-] 2012-07-06 . FC6D1D80588D371F0321E15A75B2F8F2 . 78336 . . [5.1.2600.6260] . . c:\windows\SoftwareDistribution\Download\4a0e4531b96faf560594eec84d879de6\sp3qfe\browser.dll
[-] 2008-08-21 . A06CE3399D16DB864F55FAEB1F1927A9 . 77824 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB2705219$\browser.dll
[-] 2008-08-21 . A06CE3399D16DB864F55FAEB1F1927A9 . 77824 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\browser.dll
[-] 2008-08-21 . BF2466B3E18E970D8A976FB95FC1CA85 . 13312 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\lsass.exe
[-] 2008-08-21 . BF2466B3E18E970D8A976FB95FC1CA85 . 13312 . . [5.1.2600.5512] . . c:\windows\system32\lsass.exe
[-] 2008-08-21 . BF2466B3E18E970D8A976FB95FC1CA85 . 13312 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\lsass.exe
[-] 2008-08-21 . 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE . 198144 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\netman.dll
[-] 2008-08-21 . 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE . 198144 . . [5.1.2600.5512] . . c:\windows\system32\netman.dll
[-] 2008-08-21 . 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE . 198144 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\netman.dll
[-] 2008-08-21 12:00 . 1280A158C722FA95A80FB7AEBE78FA7D . 792064 . . [2001.12.4414.700] . . c:\windows\ERDNT\cache\comres.dll
[-] 2008-08-21 12:00 . 1280A158C722FA95A80FB7AEBE78FA7D . 792064 . . [2001.12.4414.700] . . c:\windows\system32\comres.dll
[-] 2008-08-21 12:00 . 1280A158C722FA95A80FB7AEBE78FA7D . 792064 . . [2001.12.4414.700] . . c:\windows\system32\dllcache\comres.dll
[-] 2008-08-21 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\ERDNT\cache\qmgr.dll
[-] 2008-08-21 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\system32\qmgr.dll
[-] 2008-08-21 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\system32\dllcache\qmgr.dll
[-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\ERDNT\cache\rpcss.dll
[-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\system32\rpcss.dll
[-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\system32\dllcache\rpcss.dll
[-] 2009-02-09 . 9222562D44021B988B9F9F62207FB6F2 . 401408 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\rpcss.dll
[-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\ERDNT\cache\services.exe
[-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\system32\services.exe
[-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\system32\dllcache\services.exe
[-] 2009-02-06 . 020CEAAEDC8EB655B6506B8C70D53BB6 . 110592 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\services.exe
[-] 2010-08-17 . 258DD5D4283FD9F9A7166BE9AE45CE73 . 58880 . . [5.1.2600.6024] . . c:\windows\$hf_mig$\KB2347290\SP3QFE\spoolsv.exe
[-] 2010-08-17 . 60784F891563FB1B767F70117FC2428F . 58880 . . [5.1.2600.6024] . . c:\windows\ERDNT\cache\spoolsv.exe
[-] 2010-08-17 . 60784F891563FB1B767F70117FC2428F . 58880 . . [5.1.2600.6024] . . c:\windows\system32\spoolsv.exe
[-] 2010-08-17 . 60784F891563FB1B767F70117FC2428F . 58880 . . [5.1.2600.6024] . . c:\windows\system32\dllcache\spoolsv.exe
[-] 2008-08-21 . ED0EF0A136DEC83DF69F04118870003E . 507904 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\winlogon.exe
[-] 2008-08-21 . ED0EF0A136DEC83DF69F04118870003E . 507904 . . [5.1.2600.5512] . . c:\windows\system32\winlogon.exe
[-] 2008-08-21 . ED0EF0A136DEC83DF69F04118870003E . 507904 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\winlogon.exe
[-] 2008-08-21 . 23C74D75E36E7158768DD63D92789A91 . 75264 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ipsec.sys
[-] 2008-08-21 . 23C74D75E36E7158768DD63D92789A91 . 75264 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ipsec.sys
[-] 2010-08-23 . 93AFB83FBC1F9443CAC722FCA63D73BF . 617472 . . [5.82] . . c:\windows\ERDNT\cache\comctl32.dll
[-] 2010-08-23 . 93AFB83FBC1F9443CAC722FCA63D73BF . 617472 . . [5.82] . . c:\windows\system32\comctl32.dll
[-] 2010-08-23 . 93AFB83FBC1F9443CAC722FCA63D73BF . 617472 . . [5.82] . . c:\windows\system32\dllcache\comctl32.dll
[-] 2010-08-23 . 736B12B725AEB2B07F0241A9F680CB10 . 1054208 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
[-] 2008-08-21 . AEF3D788DBF40C7C4D204EA45EB0C505 . 921088 . . [6.0] . . c:\windows\I386\ASMS\6000\MSFT\WINDOWS\COMMON\CONTROLS\COMCTL32.DLL
[-] 2008-08-21 . AEF3D788DBF40C7C4D204EA45EB0C505 . 921088 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.0.0_x-ww_1382d70a\comctl32.dll
[-] 2008-08-21 . BD38D1EBE24A46BD3EDA059560AFBA12 . 1054208 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
[-] 2008-08-21 . 3D4E199942E29207970E04315D02AD3B . 62464 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\cryptsvc.dll
[-] 2008-08-21 . 3D4E199942E29207970E04315D02AD3B . 62464 . . [5.1.2600.5512] . . c:\windows\system32\cryptsvc.dll
[-] 2008-08-21 . 3D4E199942E29207970E04315D02AD3B . 62464 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\cryptsvc.dll
[-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\ERDNT\cache\es.dll
[-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\system32\es.dll
[-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\system32\dllcache\es.dll
[-] 2008-07-07 20:23 . F17F6226BDC0CD5F0BEF0DAF84D29BEC . 253952 . . [2001.12.4414.706] . . c:\windows\$hf_mig$\KB950974\SP3QFE\es.dll
[-] 2008-08-21 . 0DA85218E92526972A821587E6A8BF8F . 110080 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\imm32.dll
[-] 2008-08-21 . 0DA85218E92526972A821587E6A8BF8F . 110080 . . [5.1.2600.5512] . . c:\windows\system32\imm32.dll
[-] 2008-08-21 . 0DA85218E92526972A821587E6A8BF8F . 110080 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\imm32.dll
[-] 2012-10-03 . 6FE42512AB1B89F32A7407F261B1D2D0 . 990208 . . [5.1.2600.6293] . . c:\windows\system32\kernel32.dll
[-] 2012-10-03 . 6FE42512AB1B89F32A7407F261B1D2D0 . 990208 . . [5.1.2600.6293] . . c:\windows\system32\dllcache\kernel32.dll
[-] 2012-10-03 . 6CBFEEB384F04681AF75F495AA48DD32 . 991744 . . [5.1.2600.6293] . . c:\windows\$hf_mig$\KB2758857\SP3QFE\kernel32.dll
[-] 2009-03-21 . B921FB870C9AC0D509B2CCABBBBE95F3 . 989696 . . [5.1.2600.5781] . . c:\windows\$NtUninstallKB2758857$\kernel32.dll
[-] 2009-03-21 . B921FB870C9AC0D509B2CCABBBBE95F3 . 989696 . . [5.1.2600.5781] . . c:\windows\ERDNT\cache\kernel32.dll
[-] 2009-03-21 . DA11D9D6ECBDF0F93436A4B7C13F7BEC . 991744 . . [5.1.2600.5781] . . c:\windows\$hf_mig$\KB959426\SP3QFE\kernel32.dll
[-] 2008-08-21 . 2DC5A8019E2387987905F77C664E4BE2 . 19968 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\linkinfo.dll
[-] 2008-08-21 . 2DC5A8019E2387987905F77C664E4BE2 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\linkinfo.dll
[-] 2008-08-21 . 2DC5A8019E2387987905F77C664E4BE2 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\linkinfo.dll
[-] 2008-08-21 . 012DF358CEBAA23ACB26D82077820817 . 22016 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\lpk.dll
[-] 2008-08-21 . 012DF358CEBAA23ACB26D82077820817 . 22016 . . [5.1.2600.5512] . . c:\windows\system32\lpk.dll
[-] 2008-08-21 . 012DF358CEBAA23ACB26D82077820817 . 22016 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\lpk.dll
[-] 2013-03-02 . 85FE43A44239E406D7BB9513569D4D00 . 6012416 . . [8.00.6001.19412] . . c:\windows\SoftwareDistribution\Download\5dd0b02c82ca92ea3c2da6ad75887354\SP3GDR\mshtml.dll
[-] 2013-03-02 . 85FE43A44239E406D7BB9513569D4D00 . 6012416 . . [8.00.6001.19412] . . c:\windows\system32\mshtml.dll
[-] 2013-03-02 . 85FE43A44239E406D7BB9513569D4D00 . 6012416 . . [8.00.6001.19412] . . c:\windows\system32\dllcache\mshtml.dll
[-] 2013-03-02 . 990F4518E1607F445969C12F014E4E29 . 6013440 . . [8.00.6001.23480] . . c:\windows\$hf_mig$\KB2817183-IE8\SP3QFE\mshtml.dll
[-] 2013-03-02 . 990F4518E1607F445969C12F014E4E29 . 6013440 . . [8.00.6001.23480] . . c:\windows\SoftwareDistribution\Download\5dd0b02c82ca92ea3c2da6ad75887354\SP3QFE\mshtml.dll
[-] 2013-03-01 . 937091E40652C6B1B6C1A71EB90C08E1 . 6011392 . . [8.00.6001.19403] . . c:\windows\ie8updates\KB2817183-IE8\mshtml.dll
[-] 2013-03-01 . AE3A26C04C794E5451ADF6872F7D48F4 . 6012928 . . [8.00.6001.23471] . . c:\windows\$hf_mig$\KB2809289-IE8\SP3QFE\mshtml.dll
[-] 2013-01-09 . 99E9E2606FB13ADB711935FE8E8E29C1 . 6011904 . . [8.00.6001.23468] . . c:\windows\$hf_mig$\KB2792100-IE8\SP3QFE\mshtml.dll
[-] 2013-01-08 . 727C9E97CB26879C17A30484C2C76E98 . 6010368 . . [8.00.6001.19400] . . c:\windows\ie8updates\KB2809289-IE8\mshtml.dll
[-] 2013-01-06 . BDF6CC938C0644FE3643BC0D6A678E26 . 6009856 . . [8.00.6001.19394] . . c:\windows\ie8updates\KB2792100-IE8\mshtml.dll
[-] 2013-01-06 . 14FD1CAEFB6D2749019AC2F54859568C . 6011392 . . [8.00.6001.23462] . . c:\windows\$hf_mig$\KB2799329-IE8\SP3QFE\mshtml.dll
[-] 2012-11-13 . 02D8509E2362D777DEBFFC05C022CBF2 . 6010880 . . [8.00.6001.23461] . . c:\windows\$hf_mig$\KB2761465-IE8\SP3QFE\mshtml.dll
[-] 2012-11-12 . 9C46E5C82F94D9AEDD2CE798F0DF1158 . 6008832 . . [8.00.6001.19393] . . c:\windows\ie8updates\KB2799329-IE8\mshtml.dll
[-] 2012-08-28 . DF3C3CA94CBC9DE07AC3EB49440A8D45 . 6008832 . . [8.00.6001.19328] . . c:\windows\ie8updates\KB2761465-IE8\mshtml.dll
[-] 2012-08-28 . CF6B381C3518AB328382429CAE206D64 . 6010368 . . [8.00.6001.23415] . . c:\windows\$hf_mig$\KB2744842-IE8\SP3QFE\mshtml.dll
[-] 2012-07-02 . 13D2E016B784730A98F24D6E5BEED22F . 6008320 . . [8.00.6001.19298] . . c:\windows\ie8updates\KB2744842-IE8\mshtml.dll
[-] 2012-07-02 . 13D2E016B784730A98F24D6E5BEED22F . 6008320 . . [8.00.6001.19298] . . c:\windows\SoftwareDistribution\Download\06af2d630217aa32a4f6f6b9c5c1a3ba\SP3GDR\mshtml.dll
[-] 2012-07-02 . DF599AC52B62DE001E42D36F92B45E68 . 6010368 . . [8.00.6001.23385] . . c:\windows\$hf_mig$\KB2722913-IE8\SP3QFE\mshtml.dll
[-] 2012-07-02 . DF599AC52B62DE001E42D36F92B45E68 . 6010368 . . [8.00.6001.23385] . . c:\windows\SoftwareDistribution\Download\06af2d630217aa32a4f6f6b9c5c1a3ba\SP3QFE\mshtml.dll
[-] 2012-05-11 . 886B62A906B3967CBBF0FD2C833A30BF . 6007808 . . [8.00.6001.19258] . . c:\windows\ie8updates\KB2722913-IE8\mshtml.dll
[-] 2012-05-11 . 55F148B94246A77FB4AC33346671CAC8 . 6009344 . . [8.00.6001.23345] . . c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\mshtml.dll
[-] 2012-03-01 . DADE53318D8E5335EE2E1745F1C3FC4D . 5978624 . . [8.00.6001.19222] . . c:\windows\ie8updates\KB2699988-IE8\mshtml.dll
[-] 2012-03-01 . 5DBB0C997AD276BCE9D30CD609BDBF67 . 5980672 . . [8.00.6001.23318] . . c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\mshtml.dll
[-] 2011-12-17 . A9259CD226283CD4F798C00909754A94 . 5979136 . . [8.00.6001.19190] . . c:\windows\ie8updates\KB2675157-IE8\mshtml.dll
[-] 2011-12-17 . 49B88A833ECA99EFBFFC5AAE5CC998ED . 5980160 . . [8.00.6001.23286] . . c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\mshtml.dll
[-] 2011-11-04 . DD8D655E1881B70A5259A23A6018A6C2 . 5978112 . . [8.00.6001.19170] . . c:\windows\ie8updates\KB2647516-IE8\mshtml.dll
[-] 2011-11-04 . 699421E2E1313C18671A703953CAE14B . 5978624 . . [8.00.6001.23266] . . c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\mshtml.dll
[-] 2011-10-03 . 4963CB503600FC3BCBDBFBA51FBA1FAC . 5971456 . . [8.00.6001.19154] . . c:\windows\ie8updates\KB2618444-IE8\mshtml.dll
[-] 2011-10-03 . 1240A6B7B470BED0AA6C9FEC7AB0EA26 . 5972992 . . [8.00.6001.23250] . . c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\mshtml.dll
[-] 2011-07-25 . 23B3C8E9F3F280180573569253CE98AB . 5969920 . . [8.00.6001.19120] . . c:\windows\ie8updates\KB2586448-IE8\mshtml.dll
[-] 2011-07-25 . BCE7CCEBAD6C8955D2B4C3B246BD0E57 . 5971456 . . [8.00.6001.23216] . . c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\mshtml.dll
[-] 2011-05-30 . 22BA5235EA846EDA87F68A1DCC2BFCF9 . 5964800 . . [8.00.6001.19088] . . c:\windows\ie8updates\KB2559049-IE8\mshtml.dll
[-] 2011-05-30 . D0B1DB576941CB0B6669B8752FFAC79A . 5967360 . . [8.00.6001.23181] . . c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\mshtml.dll
[-] 2011-02-22 . 3422847AA07E37076A87D0B7D5044DC6 . 5964800 . . [8.00.6001.23141] . . c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\mshtml.dll
[-] 2011-02-22 . C2EF2335F1B6C2BE20A67D9098F6C9A1 . 5962240 . . [8.00.6001.19046] . . c:\windows\ERDNT\cache\mshtml.dll
[-] 2011-02-22 . C2EF2335F1B6C2BE20A67D9098F6C9A1 . 5962240 . . [8.00.6001.19046] . . c:\windows\ie8updates\KB2530548-IE8\mshtml.dll
[-] 2009-03-08 . D469A0EBA2EF5C6BEE8065B7E3196E5E . 5937152 . . [8.00.6001.18702] . . c:\windows\ie8updates\KB2497640-IE8\mshtml.dll
[-] 2008-08-21 . A706E122B398FE1AB85CB9B75D044223 . 3066880 . . [6.00.2900.5512] . . c:\windows\ie8\mshtml.dll
[-] 2008-08-21 . 355EDBB4D412B01F1740C17E3F50FA00 . 343040 . . [7.0.2600.5512] . . c:\windows\ERDNT\cache\msvcrt.dll
[-] 2008-08-21 . 4200BE3808F6406DBE45A7B88DAE5035 . 322560 . . [7.0.2600.0] . . c:\windows\I386\ASMS\7000\MSFT\WINDOWS\MSWINCRT\MSVCRT.DLL
[-] 2008-08-21 . 355EDBB4D412B01F1740C17E3F50FA00 . 343040 . . [7.0.2600.5512] . . c:\windows\system32\msvcrt.dll
[-] 2008-08-21 . 355EDBB4D412B01F1740C17E3F50FA00 . 343040 . . [7.0.2600.5512] . . c:\windows\system32\dllcache\msvcrt.dll
[-] 2008-08-21 . 4200BE3808F6406DBE45A7B88DAE5035 . 322560 . . [7.0.2600.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.0.0_x-ww_2726e76a\msvcrt.dll
[-] 2008-08-21 . D7075E95AA599EE77B7A89D39296BD3D . 343040 . . [7.0.2600.5512] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.2600.5512_x-ww_3fd60d63\msvcrt.dll
[-] 2008-06-20 . FCEE5FCB99F7C724593365C706D28388 . 245248 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB2509553\SP3QFE\mswsock.dll
[-] 2008-06-20 . 943337D786A56729263071623BBB9DE5 . 245248 . . [5.1.2600.5625] . . c:\windows\ERDNT\cache\mswsock.dll
[-] 2008-06-20 . 943337D786A56729263071623BBB9DE5 . 245248 . . [5.1.2600.5625] . . c:\windows\system32\mswsock.dll
[-] 2008-06-20 . 943337D786A56729263071623BBB9DE5 . 245248 . . [5.1.2600.5625] . . c:\windows\system32\dllcache\mswsock.dll
[-] 2008-08-21 . 1B7F071C51B77C272875C3A23E1E4550 . 407040 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\netlogon.dll
[-] 2008-08-21 . 1B7F071C51B77C272875C3A23E1E4550 . 407040 . . [5.1.2600.5512] . . c:\windows\system32\netlogon.dll
[-] 2008-08-21 . 1B7F071C51B77C272875C3A23E1E4550 . 407040 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\netlogon.dll
[-] 2008-08-21 . 50A166237A0FA771261275A405646CC0 . 17408 . . [6.00.2900.5512] . . c:\windows\ERDNT\cache\powrprof.dll
[-] 2008-08-21 . 50A166237A0FA771261275A405646CC0 . 17408 . . [6.00.2900.5512] . . c:\windows\system32\powrprof.dll
[-] 2008-08-21 . 50A166237A0FA771261275A405646CC0 . 17408 . . [6.00.2900.5512] . . c:\windows\system32\dllcache\powrprof.dll
[-] 2008-08-21 . A86BB5E61BF3E39B62AB4C7E7085A084 . 181248 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\scecli.dll
[-] 2008-08-21 . A86BB5E61BF3E39B62AB4C7E7085A084 . 181248 . . [5.1.2600.5512] . . c:\windows\system32\scecli.dll
[-] 2008-08-21 . A86BB5E61BF3E39B62AB4C7E7085A084 . 181248 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\scecli.dll
[-] 2008-08-21 . 96E1C926F22EE1BFBAE82901A35F6BF3 . 5120 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\sfc.dll
[-] 2008-08-21 . 96E1C926F22EE1BFBAE82901A35F6BF3 . 5120 . . [5.1.2600.5512] . . c:\windows\system32\sfc.dll
[-] 2008-08-21 . 96E1C926F22EE1BFBAE82901A35F6BF3 . 5120 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\sfc.dll
[-] 2008-08-21 . 27C6D03BCDB8CFEB96B716F3D8BE3E18 . 14336 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\svchost.exe
[-] 2008-08-21 . 27C6D03BCDB8CFEB96B716F3D8BE3E18 . 14336 . . [5.1.2600.5512] . . c:\windows\system32\svchost.exe
[-] 2008-08-21 . 27C6D03BCDB8CFEB96B716F3D8BE3E18 . 14336 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\svchost.exe
[-] 2008-08-21 . 3CB78C17BB664637787C9A1C98F79C38 . 249856 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\tapisrv.dll
[-] 2008-08-21 . 3CB78C17BB664637787C9A1C98F79C38 . 249856 . . [5.1.2600.5512] . . c:\windows\system32\tapisrv.dll
[-] 2008-08-21 . 3CB78C17BB664637787C9A1C98F79C38 . 249856 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\tapisrv.dll
[-] 2008-08-21 . B26B135FF1B9F60C9388B4A7D16F600B . 578560 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\user32.dll
[-] 2008-08-21 . B26B135FF1B9F60C9388B4A7D16F600B . 578560 . . [5.1.2600.5512] . . c:\windows\system32\user32.dll
[-] 2008-08-21 . B26B135FF1B9F60C9388B4A7D16F600B . 578560 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\user32.dll
[-] 2008-08-21 . A93AEE1928A9D7CE3E16D24EC7380F89 . 26112 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\userinit.exe
[-] 2008-08-21 . A93AEE1928A9D7CE3E16D24EC7380F89 . 26112 . . [5.1.2600.5512] . . c:\windows\system32\userinit.exe
[-] 2008-08-21 . A93AEE1928A9D7CE3E16D24EC7380F89 . 26112 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\userinit.exe
[-] 2013-03-02 . DA5B96A293B006572209E5EAC9F3A045 . 916480 . . [8.00.6001.19412] . . c:\windows\SoftwareDistribution\Download\5dd0b02c82ca92ea3c2da6ad75887354\SP3GDR\wininet.dll
[-] 2013-03-02 . DA5B96A293B006572209E5EAC9F3A045 . 916480 . . [8.00.6001.19412] . . c:\windows\system32\wininet.dll
[-] 2013-03-02 . DA5B96A293B006572209E5EAC9F3A045 . 916480 . . [8.00.6001.19412] . . c:\windows\system32\dllcache\wininet.dll
[-] 2013-03-02 . 43EADBA9F3CD2A5F01B189BD95FCDE95 . 920064 . . [8.00.6001.23480] . . c:\windows\$hf_mig$\KB2817183-IE8\SP3QFE\wininet.dll
[-] 2013-03-02 . 43EADBA9F3CD2A5F01B189BD95FCDE95 . 920064 . . [8.00.6001.23480] . . c:\windows\SoftwareDistribution\Download\5dd0b02c82ca92ea3c2da6ad75887354\SP3QFE\wininet.dll
[-] 2013-02-05 . 5AACF4B4DEE1972B7952E8A747122232 . 916480 . . [8.00.6001.19401] . . c:\windows\ie8updates\KB2817183-IE8\wininet.dll
[-] 2013-02-05 . BE30BEF4C13065D09772F9895FCB9D22 . 920064 . . [8.00.6001.23469] . . c:\windows\$hf_mig$\KB2809289-IE8\SP3QFE\wininet.dll
[-] 2012-12-26 . D175F91A4C98B8848818C9B5089F88A2 . 916480 . . [8.00.6001.19394] . . c:\windows\ie8updates\KB2809289-IE8\wininet.dll
[-] 2012-12-26 . B8BEF9519A1B124DEAF94081F6C5A767 . 920064 . . [8.00.6001.23462] . . c:\windows\$hf_mig$\KB2792100-IE8\SP3QFE\wininet.dll
[-] 2012-11-01 . 9AD88EA663124336E88EB031F917CE20 . 916992 . . [8.00.6001.19389] . . c:\windows\ie8updates\KB2792100-IE8\wininet.dll
[-] 2012-11-01 . ACC92628CFFF9BB6F8886329888014A8 . 920064 . . [8.00.6001.23458] . . c:\windows\$hf_mig$\KB2761465-IE8\SP3QFE\wininet.dll
[-] 2012-08-28 . FF1C14BCA1A797CE45DD359FA2C9EDA8 . 916992 . . [8.00.6001.19328] . . c:\windows\ie8updates\KB2761465-IE8\wininet.dll
[-] 2012-08-28 . DCEA3B3193B7181CF818ECC4EAB30A66 . 920064 . . [8.00.6001.23415] . . c:\windows\$hf_mig$\KB2744842-IE8\SP3QFE\wininet.dll
[-] 2012-07-02 . C4300CB4D20B1159DC77E01E8A2525EC . 916992 . . [8.00.6001.19298] . . c:\windows\ie8updates\KB2744842-IE8\wininet.dll
[-] 2012-07-02 . C4300CB4D20B1159DC77E01E8A2525EC . 916992 . . [8.00.6001.19298] . . c:\windows\SoftwareDistribution\Download\06af2d630217aa32a4f6f6b9c5c1a3ba\SP3GDR\wininet.dll
[-] 2012-07-02 . EFB2241DE3AA6480521A16D0CB67B0EC . 920064 . . [8.00.6001.23385] . . c:\windows\$hf_mig$\KB2722913-IE8\SP3QFE\wininet.dll
[-] 2012-07-02 . EFB2241DE3AA6480521A16D0CB67B0EC . 920064 . . [8.00.6001.23385] . . c:\windows\SoftwareDistribution\Download\06af2d630217aa32a4f6f6b9c5c1a3ba\SP3QFE\wininet.dll
[-] 2012-05-16 . 6B1774334E2975AA60596E54F5EA1430 . 916992 . . [8.00.6001.19272] . . c:\windows\ie8updates\KB2722913-IE8\wininet.dll
[-] 2012-05-16 . 553AD35768CD27959391DD5AA82CEF6F . 920064 . . [8.00.6001.23359] . . c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\wininet.dll
[-] 2012-03-01 . 009E7B4C284F080608D7286484015EE5 . 916992 . . [8.00.6001.19222] . . c:\windows\ie8updates\KB2699988-IE8\wininet.dll
[-] 2012-03-01 . 4EC67FAB39F37626AD6D9895FC094ABF . 919552 . . [8.00.6001.23318] . . c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\wininet.dll
[-] 2011-12-17 . F362D50FBDC6E34918DF41BDE1770E5C . 916992 . . [8.00.6001.19190] . . c:\windows\ie8updates\KB2675157-IE8\wininet.dll
[-] 2011-12-17 . 84A48E9818E8440DDBFD8EEC37C8A937 . 919552 . . [8.00.6001.23286] . . c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\wininet.dll
[-] 2011-11-04 . 552263502EA8C24D301A0C43FF90B3ED . 916992 . . [8.00.6001.19165] . . c:\windows\ie8updates\KB2647516-IE8\wininet.dll
[-] 2011-11-04 . 4E4716CAF514717814D07113AD0425B6 . 919552 . . [8.00.6001.23261] . . c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\wininet.dll
[-] 2011-08-22 . 1A377838B4B468E37C3EEB5BAA24F925 . 916480 . . [8.00.6001.19131] . . c:\windows\ie8updates\KB2618444-IE8\wininet.dll
[-] 2011-08-22 . 19630AEBBFAEB06984CAB91848270AAF . 919552 . . [8.00.6001.23227] . . c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\wininet.dll
[-] 2011-06-23 . AF4EDDC6C0446FCE5681B5DED52B8F0E . 916480 . . [8.00.6001.19098] . . c:\windows\ie8updates\KB2586448-IE8\wininet.dll
[-] 2011-06-23 . 509CF67AE762A38E23A5455A0053853C . 919552 . . [8.00.6001.23192] . . c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\wininet.dll
[-] 2011-04-25 . CC951C2212A200475A587A440E0AA804 . 916480 . . [8.00.6001.19072] . . c:\windows\ie8updates\KB2559049-IE8\wininet.dll
[-] 2011-04-25 . 7F4F1697001B9E9A7924D219DC215903 . 919552 . . [8.00.6001.23165] . . c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\wininet.dll
[-] 2011-02-22 . A9FA95F0D7F511959AC721E4843E5967 . 919552 . . [8.00.6001.23139] . . c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\wininet.dll
[-] 2011-02-22 . F192D49EEFE297FA858B2C774BA2291D . 916480 . . [8.00.6001.19044] . . c:\windows\ERDNT\cache\wininet.dll
[-] 2011-02-22 . F192D49EEFE297FA858B2C774BA2291D . 916480 . . [8.00.6001.19044] . . c:\windows\ie8updates\KB2530548-IE8\wininet.dll
[-] 2009-03-08 . 6CE32F7778061CCC5814D5E0F282D369 . 914944 . . [8.00.6001.18702] . . c:\windows\ie8updates\KB2497640-IE8\wininet.dll
[-] 2008-08-21 . 7A4F775ABB2F1C97DEF3E73AFA2FAEDD . 666112 . . [6.00.2900.5512] . . c:\windows\ie8\wininet.dll
[-] 2008-08-21 . 2CCC474EB85CEAA3E1FA1726580A3E5A . 82432 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\ws2_32.dll
[-] 2008-08-21 . 2CCC474EB85CEAA3E1FA1726580A3E5A . 82432 . . [5.1.2600.5512] . . c:\windows\system32\ws2_32.dll
[-] 2008-08-21 . 2CCC474EB85CEAA3E1FA1726580A3E5A . 82432 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ws2_32.dll
[-] 2008-08-21 . 9789E95E1D88EEB4B922BF3EA7779C28 . 19968 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\ws2help.dll
[-] 2008-08-21 . 9789E95E1D88EEB4B922BF3EA7779C28 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\ws2help.dll
[-] 2008-08-21 . 9789E95E1D88EEB4B922BF3EA7779C28 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ws2help.dll
[-] 2008-08-21 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\explorer.exe
[-] 2008-08-21 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\ERDNT\cache\explorer.exe
[-] 2008-08-21 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\system32\dllcache\explorer.exe
[-] 2008-08-21 . 058710B720282CA82B909912D3EF28DB . 146432 . . [5.1.2600.5512] . . c:\windows\regedit.exe
[-] 2008-08-21 . 058710B720282CA82B909912D3EF28DB . 146432 . . [5.1.2600.5512] . . c:\windows\I386\REGEDIT.EXE
[-] 2008-08-21 . 058710B720282CA82B909912D3EF28DB . 146432 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\regedit.exe
[-] 2011-11-01 . 6BAD1BED9872E62049E487FB91AE2F3A . 1288704 . . [5.1.2600.6168] . . c:\windows\system32\ole32.dll
[-] 2011-11-01 . 6BAD1BED9872E62049E487FB91AE2F3A . 1288704 . . [5.1.2600.6168] . . c:\windows\system32\dllcache\ole32.dll
[-] 2011-11-01 . 7D9DDE1AB4B00DDB173F5A16E9206517 . 1289216 . . [5.1.2600.6168] . . c:\windows\$hf_mig$\KB2624667\SP3QFE\ole32.dll
[-] 2010-07-16 . 7A6A7900B5E322763430BA6FD9A31224 . 1288192 . . [5.1.2600.6010] . . c:\windows\ERDNT\cache\ole32.dll
[-] 2010-07-16 . 8D51FB47062F2A1A9EFECCEF338A4C46 . 1289216 . . [5.1.2600.6010] . . c:\windows\$hf_mig$\KB979687\SP3QFE\ole32.dll
[-] 2010-04-16 . 9E03DC5AB51CFD0190541CE2038D819D . 406016 . . [1.0420.2600.5969] . . c:\windows\ERDNT\cache\usp10.dll
[-] 2010-04-16 . 9E03DC5AB51CFD0190541CE2038D819D . 406016 . . [1.0420.2600.5969] . . c:\windows\system32\usp10.dll
[-] 2010-04-16 . 9E03DC5AB51CFD0190541CE2038D819D . 406016 . . [1.0420.2600.5969] . . c:\windows\system32\dllcache\usp10.dll
[-] 2010-04-16 . F8894BCC961D461674002B4BAE7AECC1 . 406016 . . [1.0420.2600.5969] . . c:\windows\$hf_mig$\KB981322\SP3QFE\usp10.dll
[-] 2008-04-14 . 9B9F1C38D559047B8AC0DBA2D5FEBDE9 . 4096 . . [5.3.2600.5512] . . c:\windows\system32\ksuser.dll
[-] 2008-04-14 . 9B9F1C38D559047B8AC0DBA2D5FEBDE9 . 4096 . . [5.3.2600.5512] . . c:\windows\system32\dllcache\ksuser.dll
[-] 2008-08-21 . 5F1D5F88303D4A4DBC8E5F97BA967CC3 . 15360 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\ctfmon.exe
[-] 2008-08-21 . 5F1D5F88303D4A4DBC8E5F97BA967CC3 . 15360 . . [5.1.2600.5512] . . c:\windows\system32\ctfmon.exe
[-] 2008-08-21 . 5F1D5F88303D4A4DBC8E5F97BA967CC3 . 15360 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ctfmon.exe
[-] 2009-07-27 . 99BC0B50F511924348BE19C7C7313BBF . 135168 . . [6.00.2900.5853] . . c:\windows\ERDNT\cache\shsvcs.dll
[-] 2009-07-27 . 99BC0B50F511924348BE19C7C7313BBF . 135168 . . [6.00.2900.5853] . . c:\windows\system32\shsvcs.dll
[-] 2009-07-27 . 99BC0B50F511924348BE19C7C7313BBF . 135168 . . [6.00.2900.5853] . . c:\windows\system32\dllcache\shsvcs.dll
[-] 2009-07-27 . 888CD7B39C37E13A2419BECFAAF0A28C . 135168 . . [6.00.2900.5853] . . c:\windows\$hf_mig$\KB971029\SP3QFE\shsvcs.dll
[-] 2008-08-21 . AFFC87E2501FCE8F09D4C10BA6421CCF . 4608 . . [5.1.2600.5512] . . c:\windows\system32\msimg32.dll
[-] 2008-08-21 . AFFC87E2501FCE8F09D4C10BA6421CCF . 4608 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\msimg32.dll
[-] 2008-08-21 . 3805DF0AC4296A34BA4BF93B346CC378 . 171008 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\srsvc.dll
[-] 2008-08-21 . 3805DF0AC4296A34BA4BF93B346CC378 . 171008 . . [5.1.2600.5512] . . c:\windows\system32\srsvc.dll
[-] 2008-08-21 . 3805DF0AC4296A34BA4BF93B346CC378 . 171008 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\srsvc.dll
[-] 2008-08-21 . F92E1076C42FCD6DB3D72D8CFE9816D5 . 13824 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\wscntfy.exe
[-] 2008-08-21 . F92E1076C42FCD6DB3D72D8CFE9816D5 . 13824 . . [5.1.2600.5512] . . c:\windows\system32\wscntfy.exe
[-] 2008-08-21 . F92E1076C42FCD6DB3D72D8CFE9816D5 . 13824 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\wscntfy.exe
[-] 2008-08-21 . 295D21F14C335B53CB8154E5B1F892B9 . 129024 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\xmlprov.dll
[-] 2008-08-21 . 295D21F14C335B53CB8154E5B1F892B9 . 129024 . . [5.1.2600.5512] . . c:\windows\system32\xmlprov.dll
[-] 2008-08-21 . 295D21F14C335B53CB8154E5B1F892B9 . 129024 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\xmlprov.dll
[-] 2010-12-09 . 15CE4DBC22FAB90B3CA5352AF1FFF81C . 718336 . . [5.1.2600.6055] . . c:\windows\$hf_mig$\KB2393802\SP3QFE\ntdll.dll
[-] 2010-12-09 . F8F0D25CA553E39DDE485D8FC7FCCE89 . 718336 . . [5.1.2600.6055] . . c:\windows\system32\ntdll.dll
[-] 2010-12-09 . F8F0D25CA553E39DDE485D8FC7FCCE89 . 718336 . . [5.1.2600.6055] . . c:\windows\system32\dllcache\ntdll.dll
[-] 2009-02-09 . B0913005EE3FC15D7F72472D0B8A30EB . 715264 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\ntdll.dll
[-] 2008-08-21 . 27D9ED8CB8B62D1E0A8E5ACE6CF52E2F . 706048 . . [5.1.2600.5512] . . c:\windows\I386\NTDLL.DLL
[-] 2008-08-21 . 27D9ED8CB8B62D1E0A8E5ACE6CF52E2F . 706048 . . [5.1.2600.5512] . . c:\windows\I386\SYSTEM32\NTDLL.DLL
[-] 2009-02-27 . 3F790874A85819E94574F3E7AF9C5806 . 177152 . . [5.1.2600.5768] . . c:\windows\system32\msctfime.ime
[-] 2009-02-27 . 3F790874A85819E94574F3E7AF9C5806 . 177152 . . [5.1.2600.5768] . . c:\windows\system32\dllcache\msctfime.ime
[-] 2009-02-27 . 30B7D847BA9075AA8E1122FB6AF3D1B5 . 177152 . . [5.1.2600.5768] . . c:\windows\$hf_mig$\KB961503\SP3QFE\msctfime.ime
[-] 2008-08-21 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\eventlog.dll
[-] 2008-08-21 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\system32\eventlog.dll
[-] 2008-08-21 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\eventlog.dll
[-] 2008-08-21 . 9DD07AF82244867CA36681EA2D29CE79 . 1614848 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\sfcfiles.dll
[-] 2008-08-21 . 9DD07AF82244867CA36681EA2D29CE79 . 1614848 . . [5.1.2600.5512] . . c:\windows\system32\sfcfiles.dll
[-] 2008-08-21 . 9DD07AF82244867CA36681EA2D29CE79 . 1614848 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\sfcfiles.dll
[-] 2008-08-21 . 5B19B557B0C188210A56A6B699D90B8F . 59904 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\regsvc.dll
[-] 2008-08-21 . 5B19B557B0C188210A56A6B699D90B8F . 59904 . . [5.1.2600.5512] . . c:\windows\system32\regsvc.dll
[-] 2008-08-21 . 5B19B557B0C188210A56A6B699D90B8F . 59904 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\regsvc.dll
[-] 2008-08-21 . 0A9A7365A1CA4319AA7C1D6CD8E4EAFA . 192512 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\schedsvc.dll
[-] 2008-08-21 . 0A9A7365A1CA4319AA7C1D6CD8E4EAFA . 192512 . . [5.1.2600.5512] . . c:\windows\system32\schedsvc.dll
[-] 2008-08-21 . 0A9A7365A1CA4319AA7C1D6CD8E4EAFA . 192512 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\schedsvc.dll
[-] 2008-08-21 . 0A5679B3714EDAB99E357057EE88FCA6 . 71680 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\ssdpsrv.dll
[-] 2008-08-21 . 0A5679B3714EDAB99E357057EE88FCA6 . 71680 . . [5.1.2600.5512] . . c:\windows\system32\ssdpsrv.dll
[-] 2008-08-21 . 0A5679B3714EDAB99E357057EE88FCA6 . 71680 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ssdpsrv.dll
[-] 2008-08-21 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\termsrv.dll
[-] 2008-08-21 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\system32\termsrv.dll
[-] 2008-08-21 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\termsrv.dll
[-] 2008-08-21 . 3CB32D3B8CBE79899D63280BB7A83CD9 . 344064 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\hnetcfg.dll
[-] 2008-08-21 . 3CB32D3B8CBE79899D63280BB7A83CD9 . 344064 . . [5.1.2600.5512] . . c:\windows\system32\hnetcfg.dll
[-] 2008-08-21 . 3CB32D3B8CBE79899D63280BB7A83CD9 . 344064 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\hnetcfg.dll
[-] 2008-08-21 . D8849F77C0B66226335A59D26CB4EDC6 . 167936 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\appmgmts.dll
[-] 2008-08-21 . D8849F77C0B66226335A59D26CB4EDC6 . 167936 . . [5.1.2600.5512] . . c:\windows\system32\appmgmts.dll
[-] 2008-08-21 . D8849F77C0B66226335A59D26CB4EDC6 . 167936 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\appmgmts.dll
[-] 2008-08-21 . 9859C0F6936E723E4892D7141B1327D5 . 11648 . . [5.1.2600.0] . . c:\windows\ERDNT\cache\acpiec.sys
[-] 2008-08-21 . 9859C0F6936E723E4892D7141B1327D5 . 11648 . . [5.1.2600.0] . . c:\windows\system32\drivers\acpiec.sys
[-] 2008-04-14 06:09 . 8BED39E3C35D6A489438B8141717A557 . 142592 . . [5.1.2601.3142] . . c:\windows\ERDNT\cache\aec.sys
[-] 2008-04-14 06:09 . 8BED39E3C35D6A489438B8141717A557 . 142592 . . [5.1.2601.3142] . . c:\windows\system32\dllcache\aec.sys
[-] 2008-04-14 06:09 . 8BED39E3C35D6A489438B8141717A557 . 142592 . . [5.1.2601.3142] . . c:\windows\system32\drivers\aec.sys
[-] 2008-08-21 . 3BB22519A194418D5FEC05D800A19AD0 . 36608 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\ip6fw.sys
[-] 2008-08-21 . 3BB22519A194418D5FEC05D800A19AD0 . 36608 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ip6fw.sys
[-] 2008-08-21 . 3BB22519A194418D5FEC05D800A19AD0 . 36608 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ip6fw.sys
[-] 2010-09-18 07:18 . 842900DEDBC8E3E8DBCCCB298FD88F65 . 953856 . . [4.1.6151] . . c:\windows\$hf_mig$\KB2387149\SP3QFE\mfc40u.dll
[-] 2010-09-18 06:53 . E76A5C202E68AF5A322D16B5A78F48B9 . 953856 . . [4.1.6151] . . c:\windows\ERDNT\cache\mfc40u.dll
[-] 2010-09-18 06:53 . E76A5C202E68AF5A322D16B5A78F48B9 . 953856 . . [4.1.6151] . . c:\windows\system32\mfc40u.dll
[-] 2010-09-18 06:53 . E76A5C202E68AF5A322D16B5A78F48B9 . 953856 . . [4.1.6151] . . c:\windows\system32\dllcache\mfc40u.dll
[-] 2008-08-21 . 986B1FF5814366D71E0AC5755C88F2D3 . 33792 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\msgsvc.dll
[-] 2008-08-21 . 986B1FF5814366D71E0AC5755C88F2D3 . 33792 . . [5.1.2600.5512] . . c:\windows\system32\msgsvc.dll
[-] 2008-08-21 . 986B1FF5814366D71E0AC5755C88F2D3 . 33792 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\msgsvc.dll
[-] 2008-08-21 12:00 . C7E39EA41233E9F5B86C8DA3A9F1E4A8 . 52224 . . [9.0.1.56] . . c:\windows\$NtUninstallWMFDist11$\mspmsnsv.dll
[-] 2008-08-21 12:00 . C7E39EA41233E9F5B86C8DA3A9F1E4A8 . 52224 . . [9.0.1.56] . . c:\windows\ERDNT\cache\mspmsnsv.dll
[-] 2006-10-19 05:47 . C51B4A5C05A5475708E3C81C7765B71D . 27136 . . [11.0.5721.5145] . . c:\windows\system32\mspmsnsv.dll
[-] 2006-10-19 05:47 . C51B4A5C05A5475708E3C81C7765B71D . 27136 . . [11.0.5721.5145] . . c:\windows\system32\dllcache\mspmsnsv.dll
[-] 2013-03-07 . 9EBEDA306E5EABDABCFF8B695FCD4CD6 . 2070016 . . [5.1.2600.6368] . . c:\windows\$hf_mig$\KB2813170\SP3QFE\ntkrnlpa.exe
[-] 2013-03-07 . 9EBEDA306E5EABDABCFF8B695FCD4CD6 . 2070016 . . [5.1.2600.6368] . . c:\windows\SoftwareDistribution\Download\16b4ee69c6084653d25b414351574d95\sp3qfe\ntkrnlpa.exe
[-] 2013-03-07 . 9ED39805DF38061BB031D0F2B20DFB77 . 2028544 . . [5.1.2600.6368] . . c:\windows\system32\ntkrnlpa.exe
[-] 2013-03-07 . 9C8E896FCF103F943EB3F405A974447D . 2070016 . . [5.1.2600.6368] . . c:\windows\Driver Cache\i386\ntkrnlpa.exe
[-] 2013-03-07 . 9C8E896FCF103F943EB3F405A974447D . 2070016 . . [5.1.2600.6368] . . c:\windows\SoftwareDistribution\Download\16b4ee69c6084653d25b414351574d95\sp3gdr\ntkrnlpa.exe
[-] 2013-03-07 . 9C8E896FCF103F943EB3F405A974447D . 2070016 . . [5.1.2600.6368] . . c:\windows\system32\dllcache\ntkrnlpa.exe
[-] 2013-01-07 . 1251D608DFCE4B6801AD27A59B74985C . 2069760 . . [5.1.2600.6335] . . c:\windows\$hf_mig$\KB2799494\SP3QFE\ntkrnlpa.exe
[-] 2013-01-07 . 2C9091C3350E369BBB2464AABE2FD7CA . 2027520 . . [5.1.2600.6335] . . c:\windows\$NtUninstallKB2813170$\ntkrnlpa.exe
[-] 2012-08-21 . B326D5E256D2F32B23E64F49DEBCE31B . 2069632 . . [5.1.2600.6284] . . c:\windows\$hf_mig$\KB2724197\SP3QFE\ntkrnlpa.exe
[-] 2012-08-21 . 61027EE2D9859A2B41D588D92F256CFB . 2027520 . . [5.1.2600.6284] . . c:\windows\$NtUninstallKB2799494$\ntkrnlpa.exe
[-] 2012-05-04 . 8E99A0CE02C1BEDA6C0935A4DDE9CEAA . 2069120 . . [5.1.2600.6223] . . c:\windows\$hf_mig$\KB2707511\SP3QFE\ntkrnlpa.exe
[-] 2012-05-04 . 87763BB6C95901818050E52C378C9E15 . 2026496 . . [5.1.2600.6223] . . c:\windows\$NtUninstallKB2724197$\ntkrnlpa.exe
[-] 2012-04-11 . 063A0F8A90D8E2B802E5243FE9AABCF3 . 2069120 . . [5.1.2600.6206] . . c:\windows\$hf_mig$\KB2676562\SP3QFE\ntkrnlpa.exe
[-] 2012-04-11 . 61CCE48F7BD00E0E4D5CDE206F2DDC1B . 2026496 . . [5.1.2600.6206] . . c:\windows\$NtUninstallKB2707511$\ntkrnlpa.exe
[-] 2011-10-25 . DB19FFF0C805664CB95062C027B11FE9 . 2069376 . . [5.1.2600.6165] . . c:\windows\$hf_mig$\KB2633171\SP3QFE\ntkrnlpa.exe
[-] 2011-10-25 . 36CAC3C8C4C10F4E21BFEABBFE7ACFFC . 2027008 . . [5.1.2600.6165] . . c:\windows\$NtUninstallKB2676562$\ntkrnlpa.exe
[-] 2010-12-10 . F67CD97282E0ABFAF91A9A1359B16F2D . 2069376 . . [5.1.2600.6055] . . c:\windows\$hf_mig$\KB2393802\SP3QFE\ntkrnlpa.exe
[-] 2010-12-09 . 9ED77E2307F6EC6F174C063C15AA3B8C . 2027008 . . [5.1.2600.6055] . . c:\windows\ERDNT\cache\ntkrnlpa.exe
[-] 2009-02-06 . 607352B9CB3D708C67F6039097801B5A . 2066176 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\ntkrnlpa.exe
[-] 2008-08-21 12:00 . 156F64A3345BD23C600655FB4D10BC08 . 435200 . . [5.1.2400.5512] . . c:\windows\ERDNT\cache\ntmssvc.dll
[-] 2008-08-21 12:00 . 156F64A3345BD23C600655FB4D10BC08 . 435200 . . [5.1.2400.5512] . . c:\windows\system32\ntmssvc.dll
[-] 2008-08-21 12:00 . 156F64A3345BD23C600655FB4D10BC08 . 435200 . . [5.1.2400.5512] . . c:\windows\system32\dllcache\ntmssvc.dll
[-] 2008-08-21 . 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 . 185856 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\upnphost.dll
[-] 2008-08-21 . 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 . 185856 . . [5.1.2600.5512] . . c:\windows\system32\upnphost.dll
[-] 2008-08-21 . 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 . 185856 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\upnphost.dll
[-] 2008-08-21 . 4D83ED8BDDEC431FC8AD907B47CFB6E3 . 367616 . . [5.3.2600.5512] . . c:\windows\ERDNT\cache\dsound.dll
[-] 2008-08-21 . 4D83ED8BDDEC431FC8AD907B47CFB6E3 . 367616 . . [5.3.2600.5512] . . c:\windows\system32\dsound.dll
[-] 2008-08-21 . 4D83ED8BDDEC431FC8AD907B47CFB6E3 . 367616 . . [5.3.2600.5512] . . c:\windows\system32\dllcache\dsound.dll
[-] 2008-08-21 . 0607CBC6FA20114CB491EFE4B2F9EFAD . 1689088 . . [5.03.2600.5512] . . c:\windows\ERDNT\cache\d3d9.dll
[-] 2008-08-21 . 0607CBC6FA20114CB491EFE4B2F9EFAD . 1689088 . . [5.03.2600.5512] . . c:\windows\system32\d3d9.dll
[-] 2008-08-21 . 0607CBC6FA20114CB491EFE4B2F9EFAD . 1689088 . . [5.03.2600.5512] . . c:\windows\system32\dllcache\d3d9.dll
[-] 2008-08-21 . A340CD71EB535A3DD751B5F28723E50C . 279552 . . [5.03.2600.5512] . . c:\windows\ERDNT\cache\ddraw.dll
[-] 2008-08-21 . A340CD71EB535A3DD751B5F28723E50C . 279552 . . [5.03.2600.5512] . . c:\windows\system32\ddraw.dll
[-] 2008-08-21 . A340CD71EB535A3DD751B5F28723E50C . 279552 . . [5.03.2600.5512] . . c:\windows\system32\dllcache\ddraw.dll
[-] 2008-08-21 12:00 . 5652F6CE1D9E9D8068B9D29BC21B5409 . 84992 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\olepro32.dll
[-] 2008-08-21 12:00 . 5652F6CE1D9E9D8068B9D29BC21B5409 . 84992 . . [5.1.2600.5512] . . c:\windows\system32\olepro32.dll
[-] 2008-08-21 12:00 . 5652F6CE1D9E9D8068B9D29BC21B5409 . 84992 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\olepro32.dll
[-] 2008-08-21 . DBE2B62353660ECCA0D75EA307A717E9 . 39936 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\perfctrs.dll
[-] 2008-08-21 . DBE2B62353660ECCA0D75EA307A717E9 . 39936 . . [5.1.2600.5512] . . c:\windows\system32\perfctrs.dll
[-] 2008-08-21 . DBE2B62353660ECCA0D75EA307A717E9 . 39936 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\perfctrs.dll
[-] 2008-08-21 . C7CE131408739B0B3A318BE2D0032719 . 18944 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\version.dll
[-] 2008-08-21 . C7CE131408739B0B3A318BE2D0032719 . 18944 . . [5.1.2600.5512] . . c:\windows\system32\version.dll
[-] 2008-08-21 . C7CE131408739B0B3A318BE2D0032719 . 18944 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\version.dll
[-] 2013-03-07 . 8C39722F8C291F1BBCCE80EE23065897 . 2149888 . . [5.1.2600.6368] . . c:\windows\system32\ntoskrnl.exe
[-] 2013-03-07 . 9FC16E5EBFE88F3C844FFE2E6CB7F1E8 . 2193536 . . [5.1.2600.6368] . . c:\windows\$hf_mig$\KB2813170\SP3QFE\ntoskrnl.exe
[-] 2013-03-07 . 9FC16E5EBFE88F3C844FFE2E6CB7F1E8 . 2193536 . . [5.1.2600.6368] . . c:\windows\SoftwareDistribution\Download\16b4ee69c6084653d25b414351574d95\sp3qfe\ntoskrnl.exe
[-] 2013-03-07 . 3FD65320312C8411B72E33DA8661D36A . 2193408 . . [5.1.2600.6368] . . c:\windows\Driver Cache\i386\ntoskrnl.exe
[-] 2013-03-07 . 3FD65320312C8411B72E33DA8661D36A . 2193408 . . [5.1.2600.6368] . . c:\windows\SoftwareDistribution\Download\16b4ee69c6084653d25b414351574d95\sp3gdr\ntoskrnl.exe
[-] 2013-03-07 . 3FD65320312C8411B72E33DA8661D36A . 2193408 . . [5.1.2600.6368] . . c:\windows\system32\dllcache\ntoskrnl.exe
[-] 2013-01-07 . AE2FEE63789F5DF6B19DD9A39E26D03E . 2193152 . . [5.1.2600.6335] . . c:\windows\$hf_mig$\KB2799494\SP3QFE\ntoskrnl.exe
[-] 2013-01-07 . DD5A89274B47499CCFF7ADCA3A3C560E . 2148864 . . [5.1.2600.6335] . . c:\windows\$NtUninstallKB2813170$\ntoskrnl.exe
[-] 2012-08-21 . ECA5980E1A78DBF9CB7F49F76791C0D1 . 2193024 . . [5.1.2600.6284] . . c:\windows\$hf_mig$\KB2724197\SP3QFE\ntoskrnl.exe
[-] 2012-08-21 . B9A14D5875CE262774388BD43BA56FF3 . 2148864 . . [5.1.2600.6284] . . c:\windows\$NtUninstallKB2799494$\ntoskrnl.exe
[-] 2012-05-04 . 099A0F80A563EBE935F4A9750F96C219 . 2192640 . . [5.1.2600.6223] . . c:\windows\$hf_mig$\KB2707511\SP3QFE\ntoskrnl.exe
[-] 2012-05-04 . AC4B3C4A6DC31867034C66663B9B8A38 . 2148352 . . [5.1.2600.6223] . . c:\windows\$NtUninstallKB2724197$\ntoskrnl.exe
[-] 2012-04-11 . 8D061BB825BC606C2B1C6F7452D1BAAA . 2192640 . . [5.1.2600.6206] . . c:\windows\$hf_mig$\KB2676562\SP3QFE\ntoskrnl.exe
[-] 2012-04-11 . A144D60B35E6DD14CCB9649B5E0D1092 . 2148352 . . [5.1.2600.6206] . . c:\windows\$NtUninstallKB2707511$\ntoskrnl.exe
[-] 2011-10-25 . 3B663B9B193D7E1DE39A466020F1FD91 . 2148864 . . [5.1.2600.6165] . . c:\windows\$NtUninstallKB2676562$\ntoskrnl.exe
[-] 2011-10-25 . F512C662874D7545E5BD8005E6800A44 . 2192768 . . [5.1.2600.6165] . . c:\windows\$hf_mig$\KB2633171\SP3QFE\ntoskrnl.exe
[-] 2010-12-09 . A531BBD3DE13121C1380ED7DC99082DB . 2192768 . . [5.1.2600.6055] . . c:\windows\$hf_mig$\KB2393802\SP3QFE\ntoskrnl.exe
[-] 2010-12-09 . 60E16152D847D7A7B7D3DA4C4B8E2120 . 2148864 . . [5.1.2600.6055] . . c:\windows\ERDNT\cache\ntoskrnl.exe
[-] 2009-02-08 . EFE8EACE83EAAD5849A7A548FB75B584 . 2189184 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\ntoskrnl.exe
[-] 2008-08-21 . 54AF4B1D5459500EF0937F6D33B1914F . 175104 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\w32time.dll
[-] 2008-08-21 . 54AF4B1D5459500EF0937F6D33B1914F . 175104 . . [5.1.2600.5512] . . c:\windows\system32\w32time.dll
[-] 2008-08-21 . 54AF4B1D5459500EF0937F6D33B1914F . 175104 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\w32time.dll
[-] 2008-08-21 . 8BAD69CBAC032D4BBACFCE0306174C30 . 333824 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\wiaservc.dll
[-] 2008-08-21 . 8BAD69CBAC032D4BBACFCE0306174C30 . 333824 . . [5.1.2600.5512] . . c:\windows\system32\wiaservc.dll
[-] 2008-08-21 . 8BAD69CBAC032D4BBACFCE0306174C30 . 333824 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\wiaservc.dll
[-] 2008-08-21 . 5C12660A97822F6E61576943B49AAAD6 . 18944 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\midimap.dll
[-] 2008-08-21 . 5C12660A97822F6E61576943B49AAAD6 . 18944 . . [5.1.2600.5512] . . c:\windows\system32\midimap.dll
[-] 2008-08-21 . 5C12660A97822F6E61576943B49AAAD6 . 18944 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\midimap.dll
[-] 2008-08-21 . 6F9BEF24C578D5D6740E080BEDD6A448 . 7680 . . [5.1.2600.5512] . . c:\windows\ERDNT\cache\rasadhlp.dll
[-] 2008-08-21 . 6F9BEF24C578D5D6740E080BEDD6A448 . 7680 . . [5.1.2600.5512] . . c:\windows\system32\rasadhlp.dll
[-] 2008-08-21 . 6F9BEF24C578D5D6740E080BEDD6A448 . 7680 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\rasadhlp.dll
[-] 2008-08-21 . 4E3D06D6E68EEDB52565080F55B460D3 . 19456 . . [5.1.2600.5512] . . c:\windows\system32\wshtcpip.dll
[-] 2008-08-21 . 4E3D06D6E68EEDB52565080F55B460D3 . 19456 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\wshtcpip.dll
Lynangeel
Rookie Surfer
Rookie Surfer
Operating System : XP
Re: Not able to Access sites anymore and will not load
Post by Lynangeel on Wed 24 Apr 2013, 12:53 pm
Note* empty entries & legit default entries are not shown
"cdloader"="c:\documents and settings\LYNDA\Application Data\mjusbsp\cdloader2.exe" [2012-02-01 50592]
"Advanced SystemCare 6"="c:\program files\IObit\Advanced SystemCare 6\ASCTray.exe" [2012-09-25 490880]
"SUPERAntiSpyware"="c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2012-11-01 4763008]
"DLCCCATS"="c:\windows\System32\spool\DRIVERS\W32X86\3\DLCCtime.dll" [2006-02-24 73728]
"OutpostMonitor"="c:\progra~1\Agnitum\OUTPOS~2\op_mon.exe" [2009-04-28 2374464]
"OutpostFeedBack"="c:\program files\Agnitum\Outpost Firewall\feedback.exe" [2009-04-28 428032]
"AVG_UI"="c:\program files\AVG\AVG2013\avgui.exe" [2013-03-14 4394032]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2013-03-12 253816]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2012-12-18 946352]
c:\documents and settings\LYNDA\Start Menu\Programs\Startup\
OpenOffice.org 3.3.lnk - c:\program files\OpenOffice.org 3\program\quickstart.exe [2010-12-13 1198592]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2011-07-19 113024]
BootExecute REG_MULTI_SZ \0
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\!SASCORE]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Secunia PSI Tray.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Secunia PSI Tray.lnk
backup=c:\windows\pss\Secunia PSI Tray.lnkCommon Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe ARM]
2012-12-18 19:08 946352 ----a-w- c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\cdloader]
2012-02-01 17:36 50592 ----a-w- c:\documents and settings\LYNDA\Application Data\mjusbsp\cdloader2.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
2008-08-21 12:00 15360 ----a-w- c:\windows\system32\ctfmon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\igfxhkcmd]
2006-03-24 03:13 77824 ----a-w- c:\windows\system32\hkcmd.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\igfxpers]
2006-03-24 03:17 118784 ----a-w- c:\windows\system32\igfxpers.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\igfxtray]
2006-03-24 03:17 94208 ----a-w- c:\windows\system32\igfxtray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
2008-04-14 13:42 1695232 ------w- c:\program files\Messenger\msmsgs.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\msnmsgr]
2010-04-17 05:12 3872080 ----a-w- c:\program files\Windows Live\Messenger\msnmsgr.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SoundMAXPnP]
2004-10-14 21:42 1404928 ----a-w- c:\program files\Analog Devices\Core\smax4pnp.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SunJavaUpdateSched]
2013-03-12 14:32 253816 ----a-w- c:\program files\Common Files\Java\Java Update\jusched.exe
"CiSvc"=3 (0x3)
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\AVG\\AVG2013\\avgmfapx.exe"=
"c:\\Program Files\\AVG\\AVG2013\\avgnsx.exe"=
"c:\\Program Files\\AVG\\AVG2013\\avgdiagex.exe"=
"c:\\Program Files\\AVG\\AVG2013\\avgemcx.exe"=
"c:\\Documents and Settings\\LYNDA\\Application Data\\mjusbsp\\magicJack.exe"=
"5985:TCP"= 5985:TCP:*:Disabled:Windows Remote Management
R0 AVGIDSHX;AVGIDSHX;c:\windows\system32\drivers\avgidshx.sys [4/19/2012 4:50 AM 60216]
R0 Avglogx;AVG Logging Driver;c:\windows\system32\drivers\avglogx.sys [9/21/2012 4:46 AM 245048]
R0 Avgrkx86;AVG Anti-Rootkit Driver;c:\windows\system32\drivers\avgrkx86.sys [1/19/2011 4:32 AM 39224]
R1 AVGIDSDriver;AVGIDSDriver;c:\windows\system32\drivers\avgidsdriverx.sys [12/23/2011 1:32 PM 208184]
R1 AVGIDSShim;AVGIDSShim;c:\windows\system32\drivers\avgidsshimx.sys [12/23/2011 1:32 PM 22328]
R1 Avgldx86;AVG AVI Loader Driver;c:\windows\system32\drivers\avgldx86.sys [1/7/2011 6:41 AM 170808]
R1 Avgtdix;AVG TDI Driver;c:\windows\system32\drivers\avgtdix.sys [2/10/2011 7:54 AM 182072]
R1 avgtp;avgtp;c:\windows\system32\drivers\avgtpx86.sys [9/4/2012 10:18 AM 33112]
R1 SandBox;SandBox;c:\windows\system32\drivers\SandBox.sys [12/15/2012 11:01 PM 704384]
R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [7/22/2011 9:27 AM 12880]
R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [7/12/2011 2:55 PM 67664]
R2 !SASCORE;SAS Core Service;c:\program files\SUPERAntiSpyware\SASCore.exe [7/11/2012 11:54 AM 116608]
R2 acssrv;Agnitum Client Security Service;c:\progra~1\Agnitum\OUTPOS~2\acs.exe [12/15/2012 11:34 PM 1195008]
R2 AdvancedSystemCareService6;Advanced SystemCare Service 6;c:\program files\IObit\Advanced SystemCare 6\ASCService.exe [11/18/2012 9:57 AM 464256]
R2 avgwd;AVG WatchDog;c:\program files\AVG\AVG2013\avgwdsvc.exe [2/19/2013 4:02 AM 282624]
R2 USTSScheduler;US Tech Support Scheduling Service;c:\program files\USTechSupport\SchedulerService\SchedulerService.exe [1/17/2013 10:48 AM 737600]
R3 afw;Agnitum firewall driver;c:\windows\system32\drivers\afw.sys [12/15/2012 10:58 PM 31128]
R3 afwcore;afwcore;c:\windows\system32\drivers\afwcore.sys [12/15/2012 11:01 PM 257432]
S2 AVGIDSAgent;AVGIDSAgent;c:\program files\AVG\AVG2013\avgidsagent.exe [2/27/2013 11:42 PM 4937264]
S2 msav;Moon Secure Antivirus Core; [x]
S2 Secunia Update Agent;Secunia Update Agent; [x]
S2 vToolbarUpdater14.2.0;vToolbarUpdater14.2.0;c:\program files\Common Files\AVG Secure Search\vToolbarUpdater\14.2.0\ToolbarUpdater.exe --> c:\program files\Common Files\AVG Secure Search\vToolbarUpdater\14.2.0\ToolbarUpdater.exe [?]
S3 AVG Security Toolbar Service;AVG Security Toolbar Service;c:\program files\AVG\AVG10\Toolbar\ToolbarBroker.exe [4/30/2011 1:32 AM 167264]
*NewlyCreated* - WS2IFSL
2013-04-24 c:\windows\Tasks\Adobe Flash Player Updater.job
- c:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe [2012-06-13 00:06]
2013-04-24 c:\windows\Tasks\ASC6_PerformanceMonitor.job
- c:\program files\IObit\Advanced SystemCare 6\Monitor.exe [2012-11-18 04:33]
2013-04-24 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2013-03-26 23:12]
Trusted Zone: walmartone.com\www
TCP: DhcpNameServer = 192.168.1.1 74.40.74.40
HKLM-Run-vProt - c:\program files\AVG Secure Search\vprot.exe
MSConfigStartUp-OutpostMonitor - c:\progra~1\Agnitum\OUTPOS~1\op_mon.exe
HKLM_ActiveSetup-{8A69D345-D564-463c-AFF1-A69D9E530F96} - c:\program files\Google\Chrome\Application\26.0.1410.64\Installer\chrmstp.exe
Rootkit scan 2013-04-23 21:22
DLCCCATS = rundll32 c:\windows\System32\spool\DRIVERS\W32X86\3\DLCCtime.dll,_RunDLLEntry@16???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil32_11_7_700_169_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\LocalServer32]
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil32_11_7_700_169_ActiveX.exe"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\TypeLib]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}]
@="IFlashBroker5"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\TypeLib]
"Version"="1.0"
- - - - - - - > 'explorer.exe'(1060)
Completion time: 2013-04-23 21:27:07
ComboFix-quarantined-files.txt 2013-04-24 04:27
Pre-Run: 23,549,149,184 bytes free
Post-Run: 23,544,684,544 bytes free
- - End Of File - - C23D90B2E89381EAD8DFB3D3E292ABDB
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Lynangeel on Wed 24 Apr 2013, 12:55 pm
also turned on windows firewall. It is always on. it somehow got turned off also have outpost Thanks
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Superdave on Thu 25 Apr 2013, 5:21 am
If you mean "Outpost Firewall" you should only run one Firewall on your computer due to conflicting issues.
Are you still being blocked on some sites?
SysProt Antirootkit
Download
SysProt Antirootkit from the link below (you will find it at the bottom
of the page under attachments, or you can get it from one of the
mirrors).
Unzip it into a folder on your desktop.
  • Double click Sysprot.exe to start the program.
  • Click on the Log tab.
  • In the Write to log box select the following items.
    • Process << Selected
    • Kernel Modules << Selected
    • SSDT << Selected
    • Kernel Hooks << Selected
    • IRP Hooks << NOT Selected
    • Ports << NOT Selected
    • Hidden Files << Selected
  • At the bottom of the page
    • Hidden Objects Only << Selected
  • Click on the Create Log button on the bottom right.
  • After a few seconds a new window should appear.
  • Select Scan Root Drive. Click on the Start button.
  • When it is complete a new window will appear to indicate that the scan is finished.
  • The log will be saved automatically in the same folder Sysprot.exe was extracted to. Open the text file and copy/paste the log here.
Tech Staff
Tech Staff
Post by Lynangeel on Thu 25 Apr 2013, 9:34 am
Well I am now able to most like facebook but the site I use for work still everytime I try to log in it it won't . maybe it's just that site . I can log on on another computer but not this one when I used to be able to.
SysProt AntiRootkit v1.0.1.0
by swatkat
No Hidden Processes found
Kernel Modules:
Module Name: \SystemRoot\System32\Drivers\dump_atapi.sys
Service Name: ---
Module Base: AA374000
Module End: AA38C000
Hidden: Yes
Module Name: \SystemRoot\System32\Drivers\dump_WMILIB.SYS
Service Name: ---
Module Base: F7BAE000
Module End: F7BB0000
Hidden: Yes
Module Name: \??\C:\WINDOWS\system32\Drivers\PROCEXP113.SYS
Service Name: ---
Module Base: F7C3A000
Module End: F7C3C000
Hidden: Yes
Module Name: \??\C:\DOCUME~1\LYNDA\LOCALS~1\Temp\catchme.sys
Service Name: catchme
Module Base: F79A6000
Module End: F79AE000
Hidden: Yes
SSDT:
Function Name: ZwAssignProcessToJobObject
Address: AA4F8A60
Driver Base: AA4D8000
Driver End: AA583000
Driver Name: \??\C:\WINDOWS\system32\drivers\SandBox.sys
Function Name: ZwClose
Address: AA4DDBF0
Function Name: ZwConnectPort
Address: AA4FA920
Function Name: ZwCreateFile
Address: AA4D9F60
Function Name: ZwCreateKey
Address: AA4E5090
Function Name: ZwCreateProcess
Address: AA4F12B0
Function Name: ZwCreateProcessEx
Address: AA4F1BB0
Function Name: ZwCreateSection
Address: AA4D8D10
Function Name: ZwCreateSymbolicLinkObject
Address: AA4E4E40
Function Name: ZwCreateThread
Address: AA4EFD70
Function Name: ZwDebugActiveProcess
Address: AA4FDF30
Function Name: ZwDeleteFile
Address: AA4E3B20
Function Name: ZwDeleteKey
Address: AA4E6900
Function Name: ZwDeleteValueKey
Address: AA4ED3A0
Function Name: ZwLoadDriver
Address: AA4EEBB0
Function Name: ZwMakeTemporaryObject
Address: AA4E46B0
Function Name: ZwNotifyChangeKey
Address: F79575D0
Driver Base: F7956000
Driver End: F795E000
Driver Name: \SystemRoot\system32\DRIVERS\avgidsshimx.sys
Function Name: ZwNotifyChangeMultipleKeys
Address: F7957700
Function Name: ZwOpenFile
Address: AA4DCC10
Function Name: ZwOpenKey
Address: AA4E5FC0
Function Name: ZwOpenProcess
Address: F7957010
Function Name: ZwOpenSection
Address: AA4D9580
Function Name: ZwOpenThread
Address: AA4F3060
Function Name: ZwProtectVirtualMemory
Address: AA4F9DA0
Function Name: ZwQueryDirectoryFile
Address: AA4DE8A0
Function Name: ZwQueryKey
Address: AA4E8750
Function Name: ZwQueryValueKey
Address: AA4E8FA0
Function Name: ZwQueueApcThread
Address: AA4F7ED0
Function Name: ZwRenameKey
Address: AA4EC590
Function Name: ZwReplaceKey
Address: AA4EA500
Function Name: ZwRequestPort
Address: AA4FCA50
Function Name: ZwRequestWaitReplyPort
Address: AA4FCD70
Function Name: ZwRestoreKey
Address: AA4EBD20
Function Name: ZwSaveKey
Address: AA4EAC80
Function Name: ZwSaveKeyEx
Address: AA4EB4D0
Function Name: ZwSecureConnectPort
Address: AA4FB480
Function Name: ZwSetContextThread
Address: AA4F7440
Function Name: ZwSetInformationDebugObject
Address: AA4FE520
Function Name: ZwSetInformationFile
Address: AA4DFBF0
Function Name: ZwSetSystemInformation
Address: AA4EE1C0
Function Name: ZwSetValueKey
Address: AA4E9820
Function Name: ZwSuspendProcess
Address: F7957300
Function Name: ZwSuspendThread
Address: F79573E0
Function Name: ZwSystemDebugControl
Address: AA4FD770
Function Name: ZwTerminateProcess
Address: AA58D640
Driver Base: AA583000
Driver End: AA5A5000
Driver Name: \??\C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS
Function Name: ZwTerminateThread
Address: F7957210
Function Name: ZwUnloadDriver
Address: AA4EF530
Function Name: ZwWriteVirtualMemory
Address: F79574D0
No Kernel Hooks found
No hidden files/folders found
Yes Outpost firewall which do you suggest I use?
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Superdave on Thu 25 Apr 2013, 10:24 am
Are you sure that your Firewall is not blocking it? Can you send me that link in a pm. I'll have a look at it.
If you paid for it you may as well use it.
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by Lynangeel on Fri 26 Apr 2013, 1:22 am
Now not able to access the internet. Noticed that my avg. virus protection had a yellow caution on it. I clicked on it and it says that my web browsing is not active nor is my email protection. I ran a scan it it detected 11 items which are all of the IRP hook origin. I am not able to restore my computer to previous settings. I tried getting online in safe mode and not able to do that either. Avg suggested to download the avg rescue cd but can't do that without getting online. Thanks
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Superdave on Fri 26 Apr 2013, 5:54 am
You will have to download this on another computer and transfer it to your computer using one of the methods I described in my first post.
Please download MiniToolBox to Desktop and run it.
Checkmark the following boxes:
  • Flush DNS
  • Report IE Proxy Settings
  • Reset IE Proxy Settings
  • List content of Hosts
  • List IP Configuration
  • Lst Last 10 Event Viewer Errors
  • List Users, Partitions and Memory Size
Click Go and copy/paste the log (Result.txt) into your next post.
Tech Staff
Tech Staff
Post by Lynangeel on Sat 27 Apr 2013, 1:36 pm
MiniToolBox by Farbar Version:21-04-2013
Ran by LYNDA (administrator) on 26-04-2013 at 22:30:09
Running from "G:\"
Microsoft Windows XP Service Pack 3 (X86)
Boot Mode: Normal
========================= Flush DNS: ===================================
Windows IP Configuration
An internal error occurred: The request is not supported.
Please contact Microsoft Product Support Services for further help.
Additional information: Unable to query host name.
========================= IE Proxy Settings: ==============================
Proxy is not enabled.
No Proxy Server is set.
"Reset IE Proxy Settings": IE Proxy Settings were reset.
========================= Hosts content: =================================
127.0.0.1 localhost
========================= IP Configuration: ================================
Broadcom NetXtreme 57xx Gigabit Controller = Local Area Connection (Connected)
# Interface IP Configuration
pushd interface ip
popd
# End of interface IP configuration
Server: UnKnown
Address: 127.0.0.1
Ping request could not find host google.com. Please check the name and try again.
Server: UnKnown
Address: 127.0.0.1
Ping request could not find host yahoo.com. Please check the name and try again.
Unable to contact IP driver, error code 2,
========================= Event log errors: ===============================
Application errors:
Error: (04/26/2013 10:03:08 AM) (Source: JavaQuickStarterService) (User: )
Description: Unable to create JQS API server: socket() failed (Socket error 10050)
Error: (04/26/2013 08:21:16 AM) (Source: Application Error) (User: )
Description: Faulting application DataCollection.exe, version 2.1.0.4741, faulting module DataCollection.exe, version 2.1.0.4741, fault address 0x0004d981.
Processing media-specific event for [DataCollection.exe!ws!]
Error: (04/26/2013 07:16:01 AM) (Source: Application Error) (User: )
Error: (04/26/2013 06:10:47 AM) (Source: Application Error) (User: )
Error: (04/26/2013 05:05:33 AM) (Source: Application Error) (User: )
Error: (04/26/2013 04:00:18 AM) (Source: Application Error) (User: )
Error: (04/25/2013 08:01:41 PM) (Source: JavaQuickStarterService) (User: )
Error: (04/25/2013 03:10:00 PM) (Source: JavaQuickStarterService) (User: )
Error: (04/25/2013 02:47:25 PM) (Source: crypt32) (User: )
Description: Failed auto update retrieval of third-party root list sequence number from: with error: The server name or address could not be resolved
Error: (04/25/2013 02:47:07 PM) (Source: JavaQuickStarterService) (User: )
System errors:
Error: (04/26/2013 10:30:17 PM) (Source: Service Control Manager) (User: )
Description: The Network Location Awareness (NLA) service depends on the TCP/IP Protocol Driver service which failed to start because of the following error:
%%2
Description: The TCP/IP Protocol Driver service failed to start due to the following error:
%%2
%%2
%%2
Error: (04/26/2013 10:30:16 PM) (Source: Service Control Manager) (User: )
%%2
%%2
Error: (04/26/2013 10:30:15 PM) (Source: Service Control Manager) (User: )
%%2
%%2
%%2
%%2
Microsoft Office Sessions:
Error: (04/26/2013 10:03:08 AM) (Source: JavaQuickStarterService)(User: )
Error: (04/26/2013 08:21:16 AM) (Source: Application Error)(User: )
Description: DataCollection.exe2.1.0.4741DataCollection.exe2.1.0.47410004d981
Error: (04/26/2013 07:16:01 AM) (Source: Application Error)(User: )
Error: (04/26/2013 06:10:47 AM) (Source: Application Error)(User: )
Error: (04/26/2013 05:05:33 AM) (Source: Application Error)(User: )
Error: (04/26/2013 04:00:18 AM) (Source: Application Error)(User: )
Error: (04/25/2013 08:01:41 PM) (Source: JavaQuickStarterService)(User: )
Error: (04/25/2013 03:10:00 PM) (Source: JavaQuickStarterService)(User: )
Error: (04/25/2013 02:47:25 PM) (Source: crypt32)(User: )
Description: [You must be registered and logged in to see this link.] server name or address could not be resolved
Error: (04/25/2013 02:47:07 PM) (Source: JavaQuickStarterService)(User: )
========================= Memory info: ===================================
Percentage of memory in use: 46%
Total physical RAM: 1014.07 MB
Available physical RAM: 544.66 MB
Total Pagefile: 2440.11 MB
Available Pagefile: 1870.38 MB
Total Virtual: 2047.88 MB
Available Virtual: 1979.36 MB
========================= Partitions: =====================================
1 Drive c: () (Fixed) (Total:37.24 GB) (Free:22.03 GB) NTFS
4 Drive f: (PHONE) (Removable) (Total:0.02 GB) (Free:0.02 GB) FAT
5 Drive g: (USB DISK) (Removable) (Total:0.48 GB) (Free:0.01 GB) FAT
========================= Users: ========================================
User accounts for \\GENERAL1
Administrator Guest HelpAssistant
LYNDA SUPPORT_388945a0
**** End of log ****
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Superdave on Sun 28 Apr 2013, 5:20 am
Can you send me that link in a pm. I'll have a look at it?
Tech Staff
Tech Staff
Post by Lynangeel on Sun 28 Apr 2013, 9:19 am
not understanding what link you want me to pm you. thanks
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Superdave on Sun 28 Apr 2013, 9:29 am
Lynangeel wrote:not understanding what link you want me to pm you. thanks
You mentioned that there was one particular site that you can't access. That's the link I would like you to send me in a pm. I would like to try it, if you don't mind.
Tech Staff
Tech Staff
Post by Superdave on Sun 28 Apr 2013, 11:04 am
I can't log into first-federal bank. Just a blank page but the WalMartone is ok. Let's try something else. Please do this even if you don't have the OS disk.Please tell me if the computer asks for a disk at some point.
Do you have an XP CD?
If so, place it in your CD ROM drive and follow the instructions below:
•Click on Start > Run and type sfc /scannow then press Enter (note the space between scf and /scannow)
*Let this run undisturbed until the window with the blue progress bar goes away
SFC - Which stands for System File Checker, retrieves the correct version of the file from %Systemroot%\System32\Dllcache or the Windows installation source files, and then replaces the incorrect file.
Tech Staff
Tech Staff
Post by Lynangeel on Sun 28 Apr 2013, 11:50 am
I am sorry for wasting your time on that crappy computer. I have a cd but the door won't open. Need to figure out why now our other good computer is not working right. Not loading sites as well. My husband uses it most and doesn't update things including the virus protection. I try to keep it up but I am usually worried about the other one the kids use. Thanks for your help
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Lynangeel on Sun 28 Apr 2013, 12:19 pm
Not able to load things also like system restore. already have malwarebytes on this computer and it doesn't show anything. will not let you download new versions of stuff.
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Superdave on Sun 28 Apr 2013, 1:04 pm
Please run SFC even if you don't have the disk and let me know what happens.
Tech Staff
Tech Staff
Post by Lynangeel on Sun 28 Apr 2013, 2:11 pm
Ran it and it didn't change anything
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Superdave on Mon 29 Apr 2013, 5:41 am
Have you tried re-setting your mode. Disconnect the power supply for at least 30 secs.
A good AV should update itself.
  • Download TDSSKiller and save it to your Desktop.
  • Extract its contents to your desktop.
  • Once extracted, open the TDSSKiller folder and doubleclick on TDSSKiller.exe to run the application, then on Start Scan.
  • If an infected file is detected, the default action will be Cure, click on Continue.
  • If a suspicious file is detected, the default action will be Skip, click on Continue.
  • It may ask you to reboot the computer to complete the process. Click on Reboot Now.
Note:It will also create a log in the C:\ directory..
Tech Staff
Tech Staff
Post by Lynangeel on Mon 29 Apr 2013, 9:57 am
yes I have done the modem thing but it isn't that . it says that is connection to the services besides the other computer wouldn't work if the modem has a problem. it runs off the same. when you try to log on it says to diagnose connection problems but when you click to do so it will not do anything. The computer that has no connection has avg on it and it does update itself and doesn't expire unless i take it off. The other computer that is now messing up that my husband uses has avast but it is the free version and it expires every year and when you don't renew it. you have no protection. an he let it expire and i did update it along with a couple other programs it was fine at first but the next day you cannot load anything and I unable to update a couple of the other programs that need it.
I ran the Tdsskiller didn't find anything
Lynangeel
Rookie Surfer
Rookie Surfer
Post by Superdave on Mon 29 Apr 2013, 11:01 am
Please download Farbar Service Scanner and run it on the computer with the issue.
  • Press "Scan".
  • It will create a log (FSS.txt) in the same directory the tool is run.
  • Please copy and paste the log to your reply.
Tech Staff
Tech Staff
Post by Sponsored content Today at 1:11 am
Page 1 of 2 1, 2  Next
