Mysterious Problems With My Computer
Post by Slica on Sun 07 Apr 2013, 12:09 pm
Problems include:
-I get a message saying my security settings will not allow me to download both AdwCleaner nor Security Check. Cannot open them either.
-When I "Restore Last Session" I end up getting a million google pages loading nearly locking up my computer.
-Comcast Constant Guard keeps telling me there is a bot detected, but when I try to go to the site it tells me the page is no longer available.
Luckily I do have Malwarebytes already on here, and under full scan, I got:
Malwarebytes Anti-Malware 1.70.0.1100
Database version: v2013.04.06.05
Windows 7 Service Pack 1 x64 NTFS
Internet Explorer 9.0.8112.16421
Mary :: MUSICBOX [administrator]
4/6/2013 6:52:20 PM
mbam-log-2013-04-06 (18-52-20).txt
Scan type: Full scan (C:\|Q:\|)
Scan options disabled: P2P
Objects scanned: 542763
Time elapsed: 2 hour(s), 5 minute(s), 25 second(s)
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 0
(end)
Under Quick Scan earlier I got:
4/6/2013 5:40:16 PM
mbam-log-2013-04-06 (17-40-16).txt
Scan type: Quick scan
Objects scanned: 249523
Time elapsed: 7 minute(s), 35 second(s)
Memory Processes Detected: 1
C:\Windows\svchost.exe (Trojan.Agent) -> 2508 -> Delete on reboot.
Folders Detected: 0
Files Detected: 1
C:\Windows\svchost.exe (Trojan.Agent) -> Delete on reboot.
(end)
Thoughts? Any help would be appreciated. Im hoping itsa virus and not a hardware issue.
Slica
Operating System : Windows XP
Re: Mysterious Problems With My Computer
Post by Superdave on Mon 08 Apr 2013, 9:18 am
Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
Save Rkill to your desktop.
There are 7 different versions. If one of them won't run then download and try to run the other one.
Vista and Win7 users need to right click Rkill and choose Run as Administrator
You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
* Rkill.exe
* Rkill.com
* Rkill.scr
* WiNlOgOn.exe
* uSeRiNiT.exe
* iExplore.exe
* eXplorer.exe
Once you've gotten one of them to run then try to immediately run the following.
Please try to run adwCleaner and Security Check now.
If your version of Windows defaults to you download folder you will need to copy it to your desktop.
Link 1
Link 2
Link 3
To prevent your anti-virus application interfering with ComboFix we need to disable it. See here for a tutorial regarding how to do so if you are unsure.
Tech Staff
Tech Staff
Post by Slica on Mon 08 Apr 2013, 3:26 pm
I should note after doing this my laptop suddenly crashed 2 or 3 times...with a blue screen saying "not less or equal". Heres AdwCleaner's log, though.
# AdwCleaner v2.200 - Logfile created 04/08/2013 at 00:11:11
# Updated 02/04/2013 by Xplode
# Operating system : Windows 7 Home Premium Service Pack 1 (64 bits)
# User : Mary - MUSICBOX
# Boot Mode : Normal
# Running from : C:\Users\Mary\Desktop\adwcleaner.exe
# Option [Delete]
***** [Services] *****
Stopped & Deleted : Application Updater
***** [Files / Folders] *****
Folder Deleted : C:\Program Files (x86)\Application Updater
Folder Deleted : C:\Program Files (x86)\Common Files\spigot
Folder Deleted : C:\Users\Mary\AppData\Local\Temp\boost_interprocess
Folder Deleted : C:\Users\Mary\AppData\LocalLow\Search Settings
***** [Registry] *****
Key Deleted : HKCU\Software\APN PIP
Key Deleted : HKCU\Software\AppDataLow\Software\Search Settings
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{F3FEE66E-E034-436A-86E4-9690573BEE8A}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{F3FEE66E-E034-436A-86E4-9690573BEE8A}
Key Deleted : HKCU\Software\Search Settings
Key Deleted : HKCU\Software\Softonic
Key Deleted : HKLM\Software\Application Updater
Key Deleted : HKLM\Software\Freeze.com
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Deleted : HKLM\Software\PIP
Key Deleted : HKLM\Software\Search Settings
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{F3FEE66E-E034-436A-86E4-9690573BEE8A}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{79FB5FC8-44B9-4AF5-BADD-CCE547F953E5}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{F3FEE66E-E034-436A-86E4-9690573BEE8A}
Key Deleted : HKLM\SOFTWARE\Software
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{F3FEE66E-E034-436A-86E4-9690573BEE8A}]
Value Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [SearchSettings]
Value Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{EF99BD32-C1FB-11D2-892F-0090271D4F88}]
Value Deleted : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{F3FEE66E-E034-436A-86E4-9690573BEE8A}]
***** [Internet Browsers] *****
-\\ Internet Explorer v9.0.8112.16464
[OK] Registry is clean.
AdwCleaner[S1].txt - [3222 octets] - [08/04/2013 00:11:12]
########## EOF - C:\AdwCleaner[S1].txt - [3282 octets] ##########
Slica
Post by Slica on Mon 08 Apr 2013, 3:39 pm
Security Check's Scan:
Results of screen317's Security Check version 0.99.62
Windows 7 Service Pack 1 x64 (UAC is disabled!)
Internet Explorer 9
Windows Security Center service is not running! This report may not be accurate!
Windows Firewall Disabled!
Norton Internet Security
WMI entry may not exist for antivirus; attempting automatic update.
Malwarebytes Anti-Malware version 1.70.0.1100
Java(TM) 6 Update 39
Java version out of Date!
Adobe Flash Player 11.6.602.180
Adobe Reader XI
Google Chrome 25.0.1364.152
Google Chrome 25.0.1364.172
Google Chrome 26.0.1410.43
Google Chrome plugins...
Norton ccSvcHst.exe
Total Fragmentation on Drive C: 1%
Slica
Post by Superdave on Tue 09 Apr 2013, 4:22 am
click Start, right click My Computer and click manage. answer the Elevation prompt, if asked. Double click Services and Applications on the left and single click Services. look for Security Center. click Start. hopefully you wont get an error. right click Security Center in services where it says startup type, choose automatic
Update Your Java (JRE)
First Verify your Java Version
If your version is out of date install the newest version of the Sun Java Runtime Environment.
Remove any old versions
1. Download JavaRa and unzip the file to your Desktop.
3. Once complete exit JavaRA.
Additional Note: The Java Quick Starter (JQS.exe) adds a service to improve the initial startup time of Java applets and applications. To disable the JQS service if you don't want to use it, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and reboot your computer.
You also should turn on your Windows Firewall.
Were you able to run ComboFix?
Tech Staff
Tech Staff
Post by Slica on Wed 10 Apr 2013, 4:02 am
Ok I did all that. I keep getting a "Bot Detection" from Comcast Constant Guard and its getting annoying. I also cant open any pdf files.
Should I still try combofix?
Slica
Post by Slica on Wed 10 Apr 2013, 5:02 am
I tried Combofix but it crashed my computer.
Im officially out of ideas. System Restore, maybe?
Slica
Post by Superdave on Wed 10 Apr 2013, 5:27 am
Save these instructions so you can have access to them while in Safe Mode.
Please click here to download AVP Tool by Kaspersky.
  • Save it to your desktop.
  • Reboot your computer into SafeMode. You can do this by restarting your computer and continually tapping the F8 key until a menu appears. Use your up arrow key to highlight SafeMode then hit enter.
  • Click Next to continue.
  • Accept the License agreement and click on next.
  • It will, by default, install it to your desktop folder. Click Next.
  • Under Automatic scan make sure these are checked.
  • Hidden Startup Objects
  • System Memory
  • Disk Boot Sectors.
  • My Computer.
Leave the rest of the settings as they appear as default.
•Then click on Scan at the to right hand Corner.
•It will automatically Neutralize any objects found.
•If some objects are left un-neutralized then click the button that says Neutralize all
•If it says it cannot be neutralized then choose the delete option when prompted.
•After that is done click on the reports button at the bottom and save it to file name it Kas.
•Save it somewhere convenient like your desktop and just post only the detected Virus\malware in the report it will be at the very top under Detected post those results in your next reply.
Tech Staff
Tech Staff
Post by Sponsored content Today at 1:10 am
