Need help with internet explorer
my pc is not working right
Post by miaculpe on 7th December 2012, 2:25 pm
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-18
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-19
ProfileImagePath REG_EXPAND_SZ C:\Windows\ServiceProfiles\LocalService
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-20
ProfileImagePath REG_EXPAND_SZ C:\Windows\ServiceProfiles\NetworkService
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-1934958083-1323608611-2999152696-1000
ProfileImagePath REG_EXPAND_SZ C:\Users\poppy
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-82-3006700770-424185619-1745488364-794895919-4004696415.bak
ProfileImagePath REG_EXPAND_SZ C:\Users\DefaultAppPool
SystemRoot REG_SZ C:\Windows
miaculpe
Joined Joined : 2012-12-07
OS OS : windows 7\NT
Points Points : 14640
Post by miaculpe on 7th December 2012, 2:36 pm
Starting up...
Running from: C:\Users\poppy\AppData\Local\Microsoft\Windows\Temporary Internet
Files\Content.IE5\D04IRGXG\Win32kDiag.exe
Log file at : C:\Users\poppy\Desktop\Win32kDiag.txt
WARNING: Could not get backup privileges!
Searching 'C:\Windows'...
Cannot access: C:\Windows\System32\LogFiles\WMI\RtBackup\EtwRTDiagLog.etl
miaculpe
Re: Need help with internet explorer
Post by Dr Jay on 8th December 2012, 7:15 pm
Hi there! Big Grin
ComboFix scan
Please download ComboFix by sUBs
Please save the file to your Desktop.
Important information about ComboFix
After the download:
  • Close any open browsers.
  • Very Important: Temporarily disable your anti-virus, script blocking and any anti-malware real-time protection before performing a scan. They can interfere with ComboFix or remove some of its embedded files which may cause "unpredictable results". [You must be registered and logged in to see this link.] if you don't know how.
  • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
  • Please do not attempt to re-connect your machine back to the Internet until ComboFix has completely finished.
  • If there is no Internet connection after running ComboFix, then restart your computer to restore back your connection.
Running ComboFix:
  • Double click on ComboFix.exe & follow the prompts.
  • When ComboFix finishes, it will produce a report for you.
  • Please post the report, which will launch or be found at "C:\Combo-Fix.txt" in your next reply.
Troubleshooting ComboFix
Safe Mode:
If you still cannot get ComboFix to run, try booting into Safe Mode, and run it there.
(To boot into Safe Mode, tap F8 after BIOS, and just before the Windows
logo appears. A list of options will appear, select "Safe Mode.")
Re-downloading:
If this doesn't work either, try the same method (above method), but try to download it again, except name
ComboFix.exe to iexplore.exe, explorer.exe, or winlogon.exe.
Malware is known for blocking all "user" processes, except for its whitelist of system important processes such as iexplore.exe, explorer.exe, winlogon.exe.
NOTE: If you encounter a message "illegal operation attempted on registry key that has been marked for deletion" and no programs will run - please just reboot and that will resolve that error.
Posts Posts : 13743
Points Points : 302211
