Firewall will not load
Post by Menessis on Sun 25 Nov 2012, 11:55 am
Deer GeekPolice;
Looks like I have a bigger problem then I thought. I was in the middle of trying to figure out why I can't get an old XP machine to network with Wiin7. I was sure everything was set right. I decided to go look at what ports firewall had open. But I can't get into the firewall at all. After looking for the service I found that it isn't even there.
I found your web site in a search and read through this post.
http://www.GeekPolice.net/t27045-windows-7-64bit-windows-firewall-will-not-load#184069
I followed along and ran the virus scan. It found 2. Then I did the fix by downloading "Seven". I did all that. Now the service is there but it won't start.
So I have decided to hand it over to the GeekPolice!
Menessis
Menessis
Unborn
Unborn
Operating System : Win7 64
Re: Firewall will not load
Post by Menessis on Sun 25 Nov 2012, 11:57 am
One other thing. In the process of trying different things to get that xp machine to see the win7 machine I had turned the firewall on and off many times. This has just happened. Don't know if that means anything or not.
Menssis
Menessis
Unborn
Unborn
Post by Menessis on Tue 27 Nov 2012, 9:23 am
There must still be a virus at work. I can't even get FireFox to run properly. And the FireWall service is gone again!
Help!!!!!!!!
Menessis
Menessis
Unborn
Unborn
Post by Menessis on Tue 27 Nov 2012, 11:49 am
I ran Malwarebytes and it found 16 problems. Running ESET again now. So far it has found 2 copies of "JS/securityDisabler.A.Gen application"!
Malbytes pops up and tells me that it has stopped "awetp.exe" from accessing the internet. I google that exe and come up with nothing?
I ran Trojan Remover and it killed something?? But that awetp.exe is still there.
Menessis
Menessis
Unborn
Unborn
Post by Sponsored content Today at 4:31 am
