External hard drive problem
Post by dtb on 3rd November 2012, 1:47 pm
Hi guys. I am having a problem with one of my external hard drives. Suddenly and without notice and on all 3 of my computers the drive stopped working. I cannot even see the drive appear on mycomputer when I plug the thing in. The power light comes on and I use various OS's and the thing is invisible on all of them. Can anyone out there help me?
dtb
Posts Posts : 20
Joined Joined : 2009-06-27
Points Points : 27373
Re: External hard drive problem
Post by Jan2011 on 3rd November 2012, 2:15 pm
Sure sounds like the drive has failed. It may be just the enclosure or the power supply for the device. If it's the enclosure, you can remove the actual hard drive that is inside the enclousure and attah it to another enclosure. What model is it?
One thing you can easily do it to swap out the USB cable (assuming it connects via a USB cable).
Jan2011
Posts Posts : 616
Joined Joined : 2011-01-17
Points Points : 25595
Post by dtb on 28th January 2013, 11:15 am
Thanks for the reply.
I took the hard drive out and put it in an enclosure, nothing happened. I downloaded and ran icare recovery which only allowed me to save 10 files. So, I know the info is on the hard drive but cannot access it. Any more ideas anyone?
dtb
Posts Posts : 20
Post by Jan2011 on 28th January 2013, 1:17 pm
Can you see the drive in Disk Management?
To check, connect the drive to one of your computers. I see you have XP, so using an XP computer, right click on My Computer, to to MANAGE. From there, go to Disk Management. See if the drive shows up and check the status.
Also see if the drive shows up in My Computer. If it does, right click on it and go to PROPERTIES. Go to the TOOLS tab and click on ERROR-CHECKING. Check the two boxes - automatically fix file system errors and Scan for and attempt recovery of bad sectors. Click Start.
Jan2011
Posts Posts : 616
Post by dtb on 28th January 2013, 2:16 pm
Hi again. Yes, it see's the hard drive in Disk Management. It says the drive is healthy.
When I try error checking on the hard drive nothing happens. I can tick the two boxes, auto fix file system errors and Scan, but nothing happens. The window just disappears.
dtb
Posts Posts : 20
Post by Jan2011 on 28th January 2013, 2:34 pm
I've seen something similar a few months ago. Nearest I could figure is that the Master Table File got corrupted. I was not able to fix it. I had to recover all the files with a recovery program and reformat the drive.
My notes show that Disk Management reported that the drive was a healthy 80 GB drive with 0 used and 0 available.
I think I used this utility to try to rebuild the MTF from the mirror, but it didn't work.
Jan2011
Posts Posts : 616
Post by dtb on 28th January 2013, 11:50 pm
Thanks again. I think I shall need to go down the same road. Thanks for all your help.
dtb
Posts Posts : 20
Post by iaanhayden on 22nd March 2013, 12:39 pm
The user may have to format the hard propel to recover from the external hard drive malfunction; although, he will lose all the data stored in the hard propel. But the problem is retrieving the facts and figures from the corrupted hard drive. There is not anything to be concerned about, as professional data recovery service companies often have good external hard drive recovery advice, but it can arrive at a cost.
iaanhayden
Posts Posts : 6
Joined Joined : 2013-03-12
OS OS : window
Points Points : 13736
