no network connection using VMware Player
Post by Penz on Wed Oct 17, 2012 3:34 am
Would like some advice please,
I have been using vmware player for just a few weeks and have had no problem with network connection up until last week when I did some changes (Windows re-activation and removals using 'Hijack This'. I have obviously deleted lots of stuff I am not suppose to delete as I have had nothing but pc problems ever since.
My host machine is Windows XP SP3
Guest OS is Scientific Linux
When I go to verify which processes are running it only shows vmnat.exe running but not vmnetdhcp.exe so I try to see if I can install vmnetdhcp.exe but get the pop-up window message "DllRegisterServer entry point was not found".
I am new to all of this and certainly not tech savvy so if someone would be kind enough to suggestion where I should go from here that will be much appreciated thanks.....
Penz
OS : XP SP3
# Likes : 0
