adware problem
adware problem
Post by 3dsoundz on Sat 13 Oct 2012, 12:56 pm
I got sting by adware n its not letting me do any kind of google search
3dsoundz
Rookie Surfer
Rookie Surfer
Operating System : win xp sp3
Re: adware problem
Post by Rodel Ituralde on Sat 13 Oct 2012, 1:59 pm
Hello, and welcome to GeekPolice.
I'm Rodel Ituralde and I will be helping you with your computer issues.
Please note the following information about the malware forum:
  • Only Tech Officers, Global Moderators, Administrators, and Malware Advisors are allowed to give advice on removing malware from your computer.
  • From this point on, please do not make any more changes to your computer.
  • Please do not ask for help elsewhere (in this site or other sites). Doing so can result in system changes, which may not show up in the logs you post.
  • If you have already asked for help somewhere, please post the link to the topic you were helped.
  • Lastly, please keep in mind that we are volunteers.
I am a student and will need to get approval prior to each step. I will return shortly with the first step.
Rodel Ituralde
Senior Surfer
Senior Surfer
Operating System : Windows 7 Home Edition 32-bit, Windows 7 Home Edition 64-bit and Ubuntu 10.4
Re: adware problem
Post by Rodel Ituralde on Sun 14 Oct 2012, 9:12 pm
Hello 3dsoundz.
Please download OTL.exe by OldTimer to your Desktop.
  • Click Run Scan and let the program run uninterrupted.
Please read carefully and follow these steps.
  • Download TDSSKiller and save it to your Desktop.
  • Extract its contents to your desktop.
  • Once extracted, open the TDSSKiller folder and doubleclick on TDSSKiller.exe to run the application, then on Start Scan.
  • If an infected file is detected, the default action will be Cure, click on Continue.
  • If a suspicious file is detected, the default action will be Skip, click on Continue.
  • It may ask you to reboot the computer to complete the process. Click on Reboot Now.
  • If no reboot is require, click on Report. A log file should appear. Please copy and paste the contents of that file here.
  • If a reboot is required, the report can also be found in your root directory, (usually C:\ folder) in the form of "TDSSKiller.[Version]_[Date]_[Time]_log.txt". Please copy and paste the contents the report here.
In your reply please post:
  • OTL.txt.
  • Extras.txt.
  • TDSSKiller log.
Rodel Ituralde
Senior Surfer
Senior Surfer
Re: adware problem
Post by Rodel Ituralde on Sun 04 Nov 2012, 9:35 am
3dsoundz, do you still require help?
Rodel Ituralde
Senior Surfer
Senior Surfer
Re: adware problem
Post by Sponsored content Today at 4:15 pm
