Need help removing virus
Post by bigbonthabeat on Wed Oct 10, 2012 1:16 am
pc smart cleaner? virus
and yontoo
help
bigbonthabeat
Posts Posts : 51
Joined Joined : 2010-12-11
Points Points : 22507
Re: Need help removing virus
Post by Rodel Ituralde on Wed Oct 10, 2012 3:50 am
Hello, and welcome to GeekPolice.
I'm Rodel Ituralde and I will be helping you with your computer issues.
Please note the following information about the malware forum:
  • Only Tech Officers, Global Moderators, Administrators, and Malware Advisors are allowed to give advice on removing malware from your computer.
  • From this point on, please do not make any more changes to your computer.
  • Please do not ask for help elsewhere (in this site or other sites). Doing so can result in system changes, which may not show up in the logs you post.
  • If you have already asked for help somewhere, please post the link to the topic you were helped.
  • Lastly, please keep in mind that we are volunteers.
I am a student and will need to get approval prior to each step. I will return shortly with the first step.
Rodel Ituralde
Posts Posts : 387
Joined Joined : 2011-01-27
OS OS : Windows 7 Home Edition 32-bit, Windows 7 Home Edition 64-bit and Ubuntu 10.4
Protection Protection : avast!, SpywareBlaster, MBAM
Points Points : 22982
Post by Rodel Ituralde on Wed Oct 10, 2012 8:42 pm
Hello bigbonthabeat. Smile
Please download [You must be registered and logged in to see this link.] by OldTimer to your Desktop.
  • Click Run Scan and let the program run uninterrupted.
Next, please download [You must be registered and logged in to see this link.] by Xplode onto your Desktop.
  • Double click on AdwCleaner.exe to run the tool.
  • Click on Search.
  • A logfile will automatically open after the scan has finished.
  • You can find the logfile at C:\AdwCleaner[R1].txt as well.
Finally, please download [You must be registered and logged in to see this link.] to your Desktop.
  • Quit all running programs.
  • For Vista/Seven, right-click>Run as administrator.
  • When prompted, type 2 and validate.
  • The RKreport.txt shall be generated next to the executable.
  • If the program is blocked, do not hesitate to try several times. If it
    really does not work (it could happen), rename it to winlogon.exe
Please post the contents of the RKreport.txt in your next reply.
In your reply please post the contents of the following (you may need to use multiple posts):
  • OTL.txt.
  • Extras.txt.
  • AdwCleaner[R1].txt.
  • RKreport.txt.
Rodel Ituralde
Posts Posts : 387
Post by Rodel Ituralde on Sat Nov 03, 2012 10:35 pm
bigbonthabeat, do you still require help?
Rodel Ituralde
Posts Posts : 387
