wireless card not reading networks
Post by johnrd on 2nd September 2012, 12:59 am
Heeeellllp Smile
Hi all, I am using windows 8 preview because my computer crashed a couple months ago and I couldn't find my Win 7 key since I bought a refurbed Gateway NV52. For months all was well but all of the sudden I stopped getting an internet connection, both hard wire and wireless. I went to device mgr and figured out that my Broadcom adapter was disabled so now I am golden on hardwire.. I have searched forum after forum and I still cannot figure out why my wireless adapter card isn't working. I go into the device mgr and it shows me its enabled and properties says its working properly. My NV has a touch switch to activate the radio and that is on. I have two other computers (1 wired and the other wireless) and a wireless tablet that work so I know its not my router. Also I cant search for other networks much less see my own other than when Its hard wired. Airplane mode is off so I know that isn't messing anything...
My adapter is Atheros AR5B93. Any one have any ideas why I can't connect wirelessly or see my network?
johnrd
Joined Joined : 2012-09-02
OS OS : windows 8
Points Points : 15603
Re: wireless card not reading networks
Post by T0k3n on 2nd September 2012, 2:57 pm
Try uninstalling and reloading the wireless driver from the Gateway support site.
NV52 Series
T0k3n
Posts Posts : 50
Joined Joined : 2011-10-25
Protection Protection : MSE,Windows Firewall
Points Points : 19212
