Ongoing problem with Malware,Trojans....Help?
Post by sinister9128 on Sun 05 Aug 2012, 5:19 am
Hi
I'm a noob here but do have some experience in removing malware/viruses, however every single step I have tried has failed. Malwarebytes was able to find 3 trojans (removed), also used ESET's online scanner which found another trojan (removed). Everything worked great for about 2 days, then redirects through Firefox began again. I have no plug-ins downloaded to Firefox, so that does not seem to be the issue. Came here, did the recommended scans and I need help
I've attached the scan texts as the site tells me it makes this message too long to post.
sinister9128
Operating System : 7
Re: Ongoing problem with Malware,Trojans....Help?
Post by Superdave on Sun 05 Aug 2012, 11:44 am
What AV are you running on that computer?
* Open OTL
* Copy and Paste the following text in the codebox into the Custom Scans/Fixes window.
:OTL
IE:[b]64bit:[/b] - HKLM\..\SearchScopes,DefaultScope = {9BB47C17-9C68-4BB3-B188-DD9AF0FD2101}
IE:[b]64bit:[/b] - HKLM\..\SearchScopes\{2BAA28F1-5CC5-4BDF-A75C-32EC21069736}: "URL" = http://www.bing.com/search?q={searchTerms}&form=DLCDF8&pc=MDDC&src=IE-SearchBox
IE:[b]64bit:[/b] - HKLM\..\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2101}: "URL" = http://www.searchqu.com/web?src=ieb&appid=289&systemid=101&sr=0&q={searchTerms}
IE - HKLM\..\URLSearchHook:  - No CLSID value found
IE - HKLM\..\SearchScopes,DefaultScope = {9BB47C17-9C68-4BB3-B188-DD9AF0FD2101}
IE - HKLM\..\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2101}: "URL" = http://www.searchqu.com/web?src=ieb&appid=289&systemid=101&sr=0&q={searchTerms}
IE - HKLM\..\SearchScopes\{E948CB57-0C36-4228-A175-17D40B1310B8}: "URL" = http://www.bing.com/search?q={searchTerms}&form=DLCDF8&pc=MDDC&src=IE-SearchBox
IE - HKCU\..\URLSearchHook:  - No CLSID value found
IE - HKCU\..\SearchScopes\{180780f0-b348-4b44-8210-94a8f3ee15b2}: "URL" = http://search.comcast.net/search/?cat=Web&con=toolbar&q={searchTerms}
IE - HKCU\..\SearchScopes\{3AADD526-7A0E-45FD-B7C0-4BA3FF25A9B3}: "URL" = http://search.yahoo.com/search?p={searchTerms}&ei=utf-8&fr=chr-yie9
IE - HKCU\..\SearchScopes\{95B7759C-8C7F-4BF1-B163-73684A933233}: "URL" = http://isearch.avg.com/search?cid={D0812B3F-FDBF-46E1-835A-3355D55E8948}&mid=9113713cfa0247d08da175f39d4bd00b-4bde9bba95cd82cacae746a9384fef7e5b561d2d&lang=en&ds=st011&pr=sa&d=2012-07-01 23:35:08&v=11.1.0.12&sap=dsp&q={searchTerms}
IE - HKCU\..\SearchScopes\{B2DE18E2-FC72-4DED-AABF-7482E8E12BD3}: "URL" = http://www.flickr.com/search/?q={searchTerms}
IE - HKCU\..\SearchScopes\{CF1893BD-9F76-4642-B708-6AF2D4CA647E}: "URL" = http://delicious.com/search?p={searchTerms}
:COMMANDS
[resethosts]
[purity]
[start explorer]
* Click Run Fix
* OTLI2 may ask to reboot the machine. Please do so if asked.
* Click OK
* A report will open. Copy and Paste that report in your next reply.
Link 1
Link 2
Link 3
To prevent your anti-virus application interfering with ComboFix we need to disable it. See here for a tutorial regarding how to do so if you are unsure.
Tech Staff
Tech Staff
Post by sinister9128 on Sun 05 Aug 2012, 2:43 pm
Hi Dave,
Here is the OTL Log:
========== OTL ==========
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\\DefaultScope| /E : value set successfully!
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{2BAA28F1-5CC5-4BDF-A75C-32EC21069736}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{2BAA28F1-5CC5-4BDF-A75C-32EC21069736}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2101}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2101}\ not found.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks\\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{E948CB57-0C36-4228-A175-17D40B1310B8}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E948CB57-0C36-4228-A175-17D40B1310B8}\ not found.
Registry value HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks\\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{180780f0-b348-4b44-8210-94a8f3ee15b2}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{180780f0-b348-4b44-8210-94a8f3ee15b2}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{3AADD526-7A0E-45FD-B7C0-4BA3FF25A9B3}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{3AADD526-7A0E-45FD-B7C0-4BA3FF25A9B3}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{95B7759C-8C7F-4BF1-B163-73684A933233}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{95B7759C-8C7F-4BF1-B163-73684A933233}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{B2DE18E2-FC72-4DED-AABF-7482E8E12BD3}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{B2DE18E2-FC72-4DED-AABF-7482E8E12BD3}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CF1893BD-9F76-4642-B708-6AF2D4CA647E}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CF1893BD-9F76-4642-B708-6AF2D4CA647E}\ not found.
C:\Windows\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
OTL by OldTimer - Version 3.2.55.0 log created on 08042012_224620
I ran ComboFix but after it restarted my system it didn't produce a log at all. Should I run it again? Also, I did open Firefox and surf through a few of the previous problems pages and have had no redirects. I know this isn't proof everything is entirely fixed, however, it's something. Thanks again.
Last edited by sinister9128 on Sun 05 Aug 2012, 2:48 pm; edited 1 time in total (Reason for editing : Mistyped)
sinister9128
Post by sinister9128 on Mon 06 Aug 2012, 7:47 am
Just a quick update, after a few hours of no occurrences, that has changed as of this morning. My first use of Google today produced another redirect. It's not happening nearly as much as before, but it's still there. Just thought I should let you know.
sinister9128
Post by Superdave on Mon 06 Aug 2012, 10:12 am
You should be able to find it at C:\ Combofix. Just look for a txt file. If you can't find it, please run it again. What AV are your running on that computer?
Tech Staff
Tech Staff
Post by sinister9128 on Mon 06 Aug 2012, 12:50 pm
Ok, I reran ComboFix, here is the log:
ComboFix 12-08-05.02 - Imagine 08/05/2012 20:25:15.2.2 - x64
Microsoft Windows 7 Home Premium 6.1.7601.1.1252.1.1033.18.4056.2622 [GMT -5:00]
Running from: c:\users\Imagine\Downloads\ComboFix.exe
SP: Windows Defender *Disabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
c:\windows\assembly\GAC_32\Desktop.ini
c:\windows\assembly\GAC_64\Desktop.ini
c:\windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\@
c:\windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\L\00000004.@
c:\windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\L\201d3dde
c:\windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\U\00000004.@
c:\windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\U\00000008.@
c:\windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\U\000000cb.@
c:\windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\U\80000000.@
c:\windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\U\80000032.@
c:\windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\U\80000064.@
---- Previous Run -------
c:\users\Imagine\AppData\Local\Diagnostics\DataSafeOnline\oyljjw.dll
c:\users\Imagine\AppData\Roaming\0ad
c:\users\Imagine\AppData\Roaming\0ad\config\user.cfg
c:\users\Imagine\AppData\Roaming\Microsoft\Windows\Recent\GamesTorrent.url
c:\windows\svchost.exe
c:\windows\SysWow64\404Fix.exe
c:\windows\SysWow64\Agent.OMZ.Fix.exe
c:\windows\SysWow64\dumphive.exe
c:\windows\SysWow64\IEDFix.C.exe
c:\windows\SysWow64\IEDFix.exe
c:\windows\SysWow64\o4Patch.exe
c:\windows\SysWow64\SrchSTS.exe
c:\windows\SysWow64\tmp.reg
c:\windows\SysWow64\VACFix.exe
c:\windows\SysWow64\VCCLSID.exe
c:\windows\SysWow64\WS2Fix.exe
Infected copy of c:\windows\system32\Services.exe was found and disinfected
Restored copy from - c:\windows\winsxs\amd64_microsoft-windows-s..s-servicecontroller_31bf3856ad364e35_6.1.7600.16385_none_2b54b20ee6fa07b1\services.exe
((((((((((((((((((((((((( Files Created from 2012-07-06 to 2012-08-06 )))))))))))))))))))))))))))))))
2012-08-06 01:36 . 2012-08-06 01:36 -------- d-----w- c:\users\Slick\AppData\Local\temp
2012-08-06 01:36 . 2012-08-06 01:36 -------- d-----w- c:\users\Guest\AppData\Local\temp
2012-08-06 01:36 . 2012-08-06 01:36 -------- d-----w- c:\users\Default\AppData\Local\temp
2012-08-05 03:07 . 2012-08-05 03:07 -------- d-----w- C:\_OTL
2012-08-04 18:52 . 2012-08-04 18:52 -------- d-----w- c:\users\Imagine\AppData\Roaming\Ludia
2012-08-04 18:52 . 2012-08-04 18:52 -------- d-----w- c:\programdata\Ludia
2012-08-04 18:52 . 2012-08-04 18:52 -------- d-----w- c:\program files (x86)\Hells Kitchen
2012-08-04 18:49 . 2012-08-04 18:49 -------- d-----w- c:\program files (x86)\bfgclient
2012-08-04 18:48 . 2012-08-04 18:52 -------- d-----w- C:\BigFishGamesCache
2012-07-29 07:46 . 2012-07-29 07:46 -------- d-----w- c:\programdata\GFI Software
2012-07-28 08:12 . 2012-07-28 08:12 -------- d-----w- C:\TDSSKiller_Quarantine
2012-07-27 05:14 . 2012-07-27 05:14 -------- d-----w- c:\users\Imagine\AppData\Local\Downloaded Installations
2012-07-27 05:13 . 2012-07-27 05:13 -------- d-----w- c:\users\Imagine\AppData\Local\adawarebp
2012-07-27 05:12 . 2012-07-27 05:12 -------- d-----w- c:\users\Imagine\AppData\Roaming\SUPERAntiSpyware.com
2012-07-27 05:12 . 2012-07-27 05:12 -------- d-----w- c:\program files\SUPERAntiSpyware
2012-07-27 05:12 . 2012-07-27 05:12 -------- d-----w- c:\programdata\SUPERAntiSpyware.com
2012-07-22 21:01 . 2009-07-14 01:14 20480 ------w- c:\windows\bymcxopb.sot
2012-07-21 08:44 . 2012-07-21 08:44 -------- d-----w- c:\users\Imagine\AppData\Roaming\funkitron
2012-07-21 07:03 . 2012-07-21 07:03 -------- d-----w- c:\windows\Sun
2012-07-21 02:42 . 2012-06-29 10:04 9133488 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{37681A3F-4F3F-4A60-8825-4DEF2AF502B5}\mpengine.dll
2012-07-19 09:51 . 2012-07-19 09:51 -------- d-----w- c:\programdata\HipSoft
2012-07-18 22:55 . 2012-07-19 05:43 -------- d-----w- c:\programdata\MumboJumbo
2012-07-18 22:52 . 2012-07-18 22:52 -------- d-----w- c:\users\Imagine\AppData\Roaming\InstallShield
2012-07-18 22:28 . 2012-07-22 21:03 -------- d-----w- C:\Remote Programs
2012-07-18 17:19 . 2012-07-18 17:19 -------- d-----w- c:\users\Imagine\AppData\Local\Xfinity.com
2012-07-15 09:00 . 2012-07-18 04:34 -------- d-----w- c:\programdata\Wild Tangent
2012-07-15 07:44 . 2012-07-19 05:12 -------- d-----w- c:\users\Imagine\AppData\Roaming\iWin
2012-07-15 05:34 . 2012-07-15 05:34 -------- d-----w- c:\program files (x86)\Bethesda Softworks
2012-07-15 05:20 . 2007-09-22 20:48 9976832 ----a-w- c:\users\Imagine\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Firaxis Games\Sid Meier's Civilization 4 - Warlords\Civ4Warlords.exe
2012-07-15 05:12 . 2006-05-21 13:13 10567680 ----a-w- c:\users\Imagine\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Firaxis Games\Sid Meier's Civilization 4\Civilization4.exe
2012-07-15 04:54 . 2012-07-18 22:52 -------- d-----w- c:\users\Imagine\AppData\Roaming\InstallShield Installation Information
2012-07-15 04:54 . 2012-07-15 04:54 -------- d-----w- c:\users\Imagine\AppData\Roaming\Firaxis Games
2012-07-15 04:54 . 2005-05-26 20:34 3767504 ----a-w- c:\windows\system32\d3dx9_26.dll
2012-07-15 04:54 . 2005-05-26 20:34 2297552 ----a-w- c:\windows\SysWow64\d3dx9_26.dll
2012-07-15 04:03 . 2012-07-15 04:03 52736 ----a-w- c:\windows\ipuninst.exe
2012-07-15 04:03 . 2012-07-15 04:03 -------- d-----w- c:\program files\BlackIsle
2012-07-13 13:06 . 2012-07-13 13:06 -------- d-----w- c:\users\Imagine\AppData\Roaming\Hoyle FaceCreator
2012-07-13 13:06 . 2012-07-18 08:04 -------- d-----w- c:\users\Imagine\AppData\Roaming\Hoyle Puzzle and Board Games
2012-07-13 13:05 . 2012-07-18 22:48 -------- d-----w- c:\program files (x86)\Encore
2012-07-11 05:13 . 2012-06-12 03:08 3148800 ----a-w- c:\windows\system32\win32k.sys
2012-07-11 03:07 . 2012-06-02 11:57 96768 ----a-w- c:\windows\system32\mshtmled.dll
2012-07-11 03:07 . 2012-06-02 11:57 2382848 ----a-w- c:\windows\system32\mshtml.tlb
2012-07-11 03:07 . 2012-06-02 08:16 2382848 ----a-w- c:\windows\SysWow64\mshtml.tlb
2012-07-11 03:07 . 2012-06-02 12:52 174200 ----a-w- c:\program files\Internet Explorer\sqmapi.dll
2012-07-11 03:07 . 2012-06-02 09:08 140920 ----a-w- c:\program files (x86)\Internet Explorer\sqmapi.dll
2012-07-11 02:33 . 2012-06-06 06:06 2004480 ----a-w- c:\windows\system32\msxml6.dll
2012-07-11 02:33 . 2012-06-06 06:06 1881600 ----a-w- c:\windows\system32\msxml3.dll
2012-07-11 02:33 . 2012-06-06 05:05 1390080 ----a-w- c:\windows\SysWow64\msxml6.dll
2012-07-11 02:33 . 2012-06-06 05:05 1236992 ----a-w- c:\windows\SysWow64\msxml3.dll
2012-07-11 02:33 . 2010-06-26 03:55 2048 ----a-w- c:\windows\system32\msxml3r.dll
2012-07-11 02:33 . 2010-06-26 03:24 2048 ----a-w- c:\windows\SysWow64\msxml3r.dll
2012-07-10 07:46 . 2012-07-10 07:46 -------- d-sh--w- c:\windows\SysWow64\%APPDATA%
2012-07-10 02:35 . 2012-07-11 02:19 -------- d-----w- c:\program files (x86)\Common Files\Steam
2012-07-09 23:55 . 2012-07-09 23:55 -------- d-----w- c:\program files\LucasArts
2012-07-09 23:55 . 2001-09-05 10:18 225280 ----a-w- c:\program files (x86)\Common Files\InstallShield\IScript\iscript.dll
2012-07-09 23:55 . 2001-09-05 10:14 176128 ----a-w- c:\program files (x86)\Common Files\InstallShield\Engine\6\Intel 32\iuser.dll
2012-07-09 23:55 . 2001-09-05 10:18 77824 ----a-w- c:\program files (x86)\Common Files\InstallShield\Engine\6\Intel 32\ctor.dll
2012-07-09 23:55 . 2001-09-05 10:13 32768 ----a-w- c:\program files (x86)\Common Files\InstallShield\Engine\6\Intel 32\objectps.dll
2012-08-06 01:37 . 2011-04-11 15:39 4194304 ----a-w- c:\windows\ServiceProfiles\NetworkService\msmqlog.bin
2012-07-19 03:13 . 2011-06-27 18:07 737072 ----a-w- c:\programdata\Microsoft\eHome\Packages\SportsV2\SportsTemplateCore-2\Microsoft.MediaCenter.Sports.UI.dll
2012-07-19 03:13 . 2011-06-27 18:06 4283672 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCEClientUX\UpdateableMarkup-2\markup.dll
2012-07-19 03:13 . 2011-06-27 18:06 42776 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCEClientUX\dSM-2\StartResources.dll
2012-07-19 03:13 . 2011-12-05 05:11 539984 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCESpotlight\MCESpotlight-2\SpotlightResources.dll
2012-07-11 03:40 . 2010-03-27 16:48 59701280 ----a-w- c:\windows\system32\MRT.exe
2012-07-06 07:01 . 2011-05-21 17:31 737072 ----a-w- c:\programdata\Microsoft\eHome\Packages\SportsV2\SportsTemplateCore\Microsoft.MediaCenter.Sports.UI.dll
2012-07-06 07:01 . 2011-05-21 17:31 4283672 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCEClientUX\UpdateableMarkup\markup.dll
2012-07-06 07:01 . 2011-05-21 17:31 42776 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCEClientUX\dSM\StartResources.dll
2012-07-03 18:46 . 2011-04-23 08:21 24904 ----a-w- c:\windows\system32\drivers\mbam.sys
2012-07-02 04:48 . 2012-06-04 22:25 426184 ----a-w- c:\windows\SysWow64\FlashPlayerApp.exe
2012-07-02 04:48 . 2011-08-09 21:23 70344 ----a-w- c:\windows\SysWow64\FlashPlayerCPLApp.cpl
2012-06-16 04:17 . 2011-05-21 17:31 539984 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCESpotlight\MCESpotlight\SpotlightResources.dll
2012-06-12 23:21 . 2012-06-12 23:21 967 ----a-w- c:\windows\ScUnin.pif
2012-06-12 23:21 . 2012-06-12 23:21 68096 ----a-w- c:\windows\ScUnin.exe
2012-06-03 04:55 . 2012-06-03 04:55 476960 ----a-w- c:\windows\SysWow64\npdeployJava1.dll
2012-06-03 04:55 . 2011-02-11 16:22 472864 ----a-w- c:\windows\SysWow64\deployJava1.dll
2012-06-02 22:19 . 2012-06-24 08:10 38424 ----a-w- c:\windows\system32\wups.dll
2012-06-02 22:19 . 2012-06-24 08:10 2428952 ----a-w- c:\windows\system32\wuaueng.dll
2012-06-02 22:19 . 2012-06-24 08:10 57880 ----a-w- c:\windows\system32\wuauclt.exe
2012-06-02 22:19 . 2012-06-24 08:10 44056 ----a-w- c:\windows\system32\wups2.dll
2012-06-02 22:19 . 2012-06-24 08:10 701976 ----a-w- c:\windows\system32\wuapi.dll
2012-06-02 22:15 . 2012-06-24 08:10 2622464 ----a-w- c:\windows\system32\wucltux.dll
2012-06-02 22:15 . 2012-06-24 08:10 99840 ----a-w- c:\windows\system32\wudriver.dll
2012-06-02 20:19 . 2012-06-24 08:10 186752 ----a-w- c:\windows\system32\wuwebv.dll
2012-06-02 20:15 . 2012-06-24 08:10 36864 ----a-w- c:\windows\system32\wuapp.exe
2012-05-31 17:25 . 2012-06-28 00:53 279656 ------w- c:\windows\system32\MpSigStub.exe
2012-05-31 04:10 . 2012-07-02 04:34 126944 ----a-w- c:\windows\system32\drivers\scdemu.sys
"SpybotSD TeaTimer"="c:\program files (x86)\Spybot - Search & Destroy\TeaTimer.exe" [2009-03-05 2260480]
"SUPERAntiSpyware"="c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2012-07-09 5661056]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
"PDVDDXSrv"="c:\program files (x86)\CyberLink\PowerDVD DX\PDVDDXSrv.exe" [2009-06-25 140520]
"SunJavaUpdateSched"="c:\program files (x86)\Common Files\Java\Java Update\jusched.exe" [2012-01-18 254696]
"QuickTime Task"="c:\program files (x86)\QuickTime\QTTask.exe" [2012-04-19 421888]
"Malwarebytes' Anti-Malware"="c:\program files (x86)\Malwarebytes' Anti-Malware\mbamgui.exe" [2012-07-03 462920]
"PWRISOVM.EXE"="c:\program files (x86)\PowerISO\PWRISOVM.EXE" [2012-05-31 336992]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\RunOnce]
"c:\program files (x86)\Dell DataSafe Local Backup\Components\DSUpdate\DSUpdate.exe"="c:\program files (x86)\Dell DataSafe Local Backup\Components\DSUpdate\DSUpdate.exe" [2011-10-21 559616]
c:\users\Default User\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
Dell Dock First Run.lnk - c:\program files\Dell\DellDock\DellDock.exe [2009-9-21 1316192]
"ConsentPromptBehaviorAdmin"= 5 (0x5)
"ConsentPromptBehaviorUser"= 3 (0x3)
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\drivers32]
"mixer"=wdmaud.drv
Security Packages REG_MULTI_SZ kerberos msv1_0 schannel wdigest tspkg pku2u livessp
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\!SASCORE]
@="Driver"
R1 SBRE;SBRE;c:\windows\system32\drivers\SBREdrv.sys [x]
R3 MozillaMaintenance;Mozilla Maintenance Service;c:\program files (x86)\Mozilla Maintenance Service\maintenanceservice.exe [2012-07-19 113120]
R3 PCDSRVC{1E208CE0-FB7451FF-06020101}_0;PCDSRVC{1E208CE0-FB7451FF-06020101}_0 - PCDR Kernel Mode Service Helper Driver;c:\program files\dell support center\pcdsrvc_x64.pkms [2010-11-18 25072]
R3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\tsusbflt.sys [2010-11-20 59392]
R3 USBAAPL64;Apple Mobile USB Driver;c:\windows\system32\Drivers\usbaapl64.sys [2010-04-20 50688]
R3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe [2010-04-20 1255736]
R4 wlcrasvc;Windows Live Mesh remote connections service;c:\program files\Windows Live\Mesh\wlcrasvc.exe [2010-09-22 57184]
S0 PxHlpa64;PxHlpa64;c:\windows\System32\Drivers\PxHlpa64.sys [2009-07-09 55280]
S1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\SASDIFSV64.SYS [2011-07-22 14928]
S1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL64.SYS [2011-07-12 12368]
S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys [2009-07-14 59904]
S2 !SASCORE;SAS Core Service;c:\program files\SUPERAntiSpyware\SASCORE64.EXE [2011-08-11 140672]
S2 DockLoginService;Dock Login Service;c:\program files\Dell\DellDock\DockLogin.exe [2009-06-09 155648]
S2 MBAMService;MBAMService;c:\program files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe [2012-07-03 655944]
S2 SBSDWSCService;SBSD Security Center Service;c:\program files (x86)\Spybot - Search & Destroy\SDWinSec.exe [2009-01-26 1153368]
S2 SftService;SoftThinks Agent Service;c:\program files (x86)\Dell DataSafe Local Backup\sftservice.EXE [2011-08-18 1692480]
S3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [2012-07-03 24904]
S3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\system32\Drivers\RtsUStor.sys [2009-05-08 215552]
S3 vwifimp;Microsoft Virtual WiFi Miniport Service;c:\windows\system32\DRIVERS\vwifimp.sys [2009-07-14 17920]
S3 yukonw7;NDIS6.2 Miniport Driver for Marvell Yukon Ethernet Controller;c:\windows\system32\DRIVERS\yk62x64.sys [2009-09-28 395264]
2012-08-06 c:\windows\Tasks\PCDoctorBackgroundMonitorTask.job
- c:\program files\Dell Support Center\uaclauncher.exe [2010-11-18 15:13]
2012-08-06 c:\windows\Tasks\SystemToolsDailyTest.job
- c:\program files\Dell Support Center\pcdrcui.exe [2010-11-18 15:13]
--------- X64 Entries -----------
"Apoint"="c:\program files\DellTPad\Apoint.exe" [2009-01-23 305664]
"SysTrayApp"="c:\program files\IDT\WDM\sttray64.exe" [2009-06-29 444416]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2009-06-30 165912]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2009-06-30 385560]
"Persistence"="c:\windows\system32\igfxpers.exe" [2009-06-30 365080]
"Broadcom Wireless Manager UI"="c:\program files\Dell\Dell Wireless WLAN Card\WLTRAY.exe" [2009-07-17 4968960]
"QuickSet"="c:\program files\Dell\QuickSet\QuickSet.exe" [2009-07-02 3180624]
"IAAnotif"="c:\program files (x86)\Intel\Intel Matrix Storage Manager\iaanotif.exe" [2009-06-05 186904]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
"LoadAppInit_DLLs"=0x1
uLocal Page = c:\windows\system32\blank.htm
mLocal Page = c:\windows\SysWOW64\blank.htm
IE: E&xport to Microsoft Excel - c:\progra~2\MICROS~2\Office12\EXCEL.EXE/3000
Trusted Zone: intuit.com\ttlc
TCP: DhcpNameServer = 75.75.75.75 75.75.76.76
FF - ProfilePath - c:\users\Imagine\AppData\Roaming\Mozilla\Firefox\Profiles\qfgjd40b.default-1340353282062\
FF - prefs.js: browser.search.selectedEngine - Google
FF - prefs.js: network.proxy.type - 4
URLSearchHooks-{3B81079D-2AC9-425f-A494-A1C7D93AFA3C} - (no file)
URLSearchHooks-{687578b9-7132-4a7a-80e4-30ee31099e03} - (no file)
Toolbar-Locked - (no file)
Toolbar-10 - (no file)
Wow6432Node-HKCU-Run-DataSafeOnline - c:\users\Imagine\AppData\Local\Diagnostics\DataSafeOnline\oyljjw.dll
WebBrowser-{E7DF6BFF-55A5-4EB7-A673-4ED3E9456D39} - (no file)
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\PCDSRVC{1E208CE0-FB7451FF-06020101}_0]
"ImagePath"="\??\c:\program files\dell support center\pcdsrvc_x64.pkms"
[HKEY_USERS\.Default\Software\Microsoft\Internet Explorer\Approved Extensions]
@Denied: (2) (LocalSystem)
"{18DF081C-E8AD-4283-A596-FA578C2EBDC3}"=hex:51,66,7a,6c,4c,1d,38,12,72,0b,cc,
1c,9f,a6,ed,07,da,80,b9,17,89,70,f9,d7
"{53707962-6F74-2D53-2644-206D7942484F}"=hex:51,66,7a,6c,4c,1d,38,12,0c,7a,63,
57,46,21,3d,68,59,52,63,2d,7c,1c,0c,5b
"{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}"=hex:51,66,7a,6c,4c,1d,38,12,d5,94,07,
72,c2,98,42,03,c9,fd,97,9a,f4,87,69,57
"{9030D464-4C02-4ABF-8ECC-5164760863C6}"=hex:51,66,7a,6c,4c,1d,38,12,0a,d7,23,
94,30,02,d1,0f,f1,da,12,24,73,56,27,d2
"{9FDDE16B-836F-4806-AB1F-1455CBEFF289}"=hex:51,66,7a,6c,4c,1d,38,12,05,e2,ce,
9b,5d,cd,68,0d,d4,09,57,15,ce,b1,b6,9d
"{DBC80044-A445-435B-BC74-9C25C1C588A9}"=hex:51,66,7a,6c,4c,1d,38,12,2a,03,db,
df,77,ea,35,06,c3,62,df,65,c4,9b,cc,bd
"{FDAD4DA1-61A2-4FD8-9C17-86F7AC245081}"=hex:51,66,7a,6c,4c,1d,38,12,cf,4e,be,
f9,90,2f,b6,0a,e3,01,c5,b7,a9,7a,14,95
"{FF059E31-CC5A-4E2E-BF3B-96E929D65503}"=hex:51,66,7a,6c,4c,1d,38,12,5f,9d,16,
fb,68,82,40,0b,c0,2d,d5,a9,2c,88,11,17
"{BDEADE7F-C265-11D0-BCED-00A0C90AB50F}"=hex:51,66,7a,6c,4c,1d,38,12,11,dd,f9,
b9,57,8c,be,54,c3,fb,43,e0,cc,54,f1,1b
[HKEY_USERS\.Default\Software\Microsoft\Internet Explorer\ApprovedExtensionsMigration]
"Timestamp"=hex:ef,f4,91,44,65,66,cd,01
[HKEY_USERS\.Default\Software\Microsoft\Internet Explorer\User Preferences]
"88D7D0879DAB32E14DE5B3A805A34F98AFF34F5977"=hex:01,00,00,00,d0,8c,9d,df,01,15,
d1,11,8c,7a,00,c0,4f,c2,97,eb,01,00,00,00,79,9a,9a,ab,3a,48,41,41,a8,ee,f7,\
"2D53CFFC5C1A3DD2E97B7979AC2A92BD59BC839E81"=hex:01,00,00,00,d0,8c,9d,df,01,15,
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil32_11_3_300_257_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil32_11_3_300_257_ActiveX.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
@="Shockwave Flash Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash32_11_3_300_257.ocx"
"ThreadingModel"="Apartment"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
@="ShockwaveFlash.ShockwaveFlash.11"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash32_11_3_300_257.ocx, 1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
@="{D27CDB6B-AE6D-11cf-96B8-444553540000}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="ShockwaveFlash.ShockwaveFlash"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
@="Macromedia Flash Factory Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
@="FlashFactory.FlashFactory.1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="FlashFactory.FlashFactory"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
@="IFlashBroker4"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\McAfee]
"SymbolicLinkValue"=hex(6):5c,00,72,00,65,00,67,00,69,00,73,00,74,00,72,00,79,
00,5c,00,6d,00,61,00,63,00,68,00,69,00,6e,00,65,00,5c,00,53,00,6f,00,66,00,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\DbgagD\1*]
"value"="?\06\00\03\07**u"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
@Denied: (Full) (Everyone)
c:\program files (x86)\Intel\Intel Matrix Storage Manager\IAANTMon.exe
c:\program files (x86)\Dell DataSafe Local Backup\COMPONENTS\SCHEDULER\STSERVICE.EXE
Completion time: 2012-08-05 20:44:30 - machine was rebooted
ComboFix-quarantined-files.txt 2012-08-06 01:44
Pre-Run: 117,462,867,968 bytes free
Post-Run: 117,562,662,912 bytes free
- - End Of File - - 02C5457AE0E74512C7800DDD45267323
This computer currently has no AV protection. Our McAfee expired last month and I am just starting a new job, with no check until the 17th. I can't renew it until that time
sinister9128
Post by Superdave on Tue 07 Aug 2012, 6:41 am
Here's a list of free AV's. You need to install an AV pronto. I prefer MSE
Remember to only install one antivirus!
1) Avast! Home Edition
2) AVG Free Edition
3) Avira AntiVir Personal
4) Microsoft Security Essentials for Windows Vista\Windows 7 - 64 bit Download
4-a) Microsoft Security Essentials for Windows XP
5) Comodo Antivirus (Uncheck during installation "Install Comodo SafeSurf..", Make Comodo my default search provider" and "Make Comodo Search my homepage" if you choose this one)
6) PC Tools AntiVirus Free Edition
7) ThreatFire
It is strongly recommended that you run only one antivirus program at a time. Having more than one antivirus program active in memory uses additional resources and can result in program conflicts and false virus alerts. If you choose to install more than one antivirus program on your computer, then only one of them should be active in memory at a time.
Please download Rooter and Save it to your desktop.
  • Double click it to start the tool.Vista and Windows7 run as administrator.
  • Click Scan.
  • Eventually, a Notepad file containing the report will open, also found at C:\Rooter.txt. Post that log in your next reply.
Tech Staff
Tech Staff
Post by sinister9128 on Tue 07 Aug 2012, 10:38 am
Ok, AV is now active on the computer and here is the Rooter log:
Rooter.exe (v1.0.2) by Eric_71
SeDebugPrivilege granted successfully ...
Windows 7 Home Edition (6.1.7601) Service Pack 1
[32_bits] - Intel64 Family 6 Model 23 Stepping 10, GenuineIntel
[wscsvc] (Security Center) RUNNING (state:4)
[MpsSvc] RUNNING (state:4)
Windows Firewall -> Enabled
Windows Defender -> Enabled
User Account Control (UAC) -> Enabled
Internet Explorer 9.0.8112.16421
Mozilla Firefox 14.0.1 (en-US)
C:\ [Fixed-NTFS] .. ( Total:283 Go - Free:108 Go )
D:\ [CD_Rom]
E:\ [CD_Rom]
Scan : 18:36.44
Path : C:\Users\Imagine\Downloads\Rooter.exe
User : Imagine ( Administrator -> YES )
----------------------\\ Processes
Locked [System Process] (0)
Locked System (4)
______ ????????? (400)
______ ????????? (488)
______ ????????? (548)
______ ????????? (564)
______ ????????? (612)
______ ????????? (636)
______ ????????? (648)
______ ????????? (656)
______ ????????? (792)
______ ????????? (872)
______ ????????? (956)
______ ????????? (1020)
______ ????????? (412)
______ ????????? (500)
Locked audiodg.exe (944)
______ ????????? (1112)
______ C:\Program Files\Dell\DellDock\DockLogin.exe (1164)
______ ????????? (1276)
______ ????????? (1376)
______ ????????? (1400)
______ ????????? (1412)
______ ????????? (1420)
______ ????????? (1520)
______ ????????? (1576)
______ ????????? (1740)
______ ????????? (1760)
______ ????????? (1812)
______ ????????? (1900)
______ C:\Program Files (x86)\Dell DataSafe Local Backup\sftservice.EXE (1980)
______ ????????? (2036)
______ ????????? (1156)
______ ????????? (2088)
______ C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAANTMon.exe (2140)
______ C:\Program Files (x86)\Spybot - Search & Destroy\SDWinSec.exe (2208)
______ ????????? (2280)
______ ????????? (2688)
______ ????????? (2264)
______ ????????? (1924)
______ C:\Program Files (x86)\Dell DataSafe Local Backup\COMPONENTS\SCHEDULER\STSERVICE.EXE (3060)
______ ????????? (3776)
______ ????????? (3792)
______ ????????? (3804)
______ ????????? (3824)
______ ????????? (3852)
______ ????????? (3860)
______ ????????? (3868)
______ C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAAnotif.exe (3904)
______ C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe (3912)
______ C:\Program Files (x86)\CyberLink\PowerDVD DX\PDVDDXSrv.exe (4060)
______ C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe (4072)
______ ????????? (4444)
______ ????????? (4572)
______ ????????? (4664)
______ ????????? (4688)
______ ????????? (4728)
______ ????????? (5144)
______ C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe (5572)
______ ????????? (5644)
______ C:\Program Files (x86)\Mozilla Firefox\firefox.exe (6012)
______ C:\Program Files (x86)\Mozilla Firefox\plugin-container.exe (4828)
______ C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_262.exe (3840)
______ C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_262.exe (6120)
______ ????????? (6116)
______ ????????? (4160)
______ ????????? (4200)
______ ????????? (6476)
______ ????????? (976)
______ ????????? (776)
______ ????????? (6764)
______ ????????? (2472)
______ ????????? (2000)
______ ????????? (888)
______ C:\Users\Imagine\Downloads\Rooter.exe (6304)
----------------------\\ Device\Harddisk0\
\Device\Harddisk0 [Sectors : 63 x 512 Bytes]
\Device\Harddisk0\Partition1 (Start_Offset:32256 | Length:41094144)
\Device\Harddisk0\Partition2 --[ MBR ]-- (Start_Offset:41943040 | Length:15728640000)
\Device\Harddisk0\Partition3 (Start_Offset:15770583040 | Length:304301301760)
----------------------\\ Scheduled Tasks
C:\Windows\Tasks\PCDoctorBackgroundMonitorTask.job
C:\Windows\Tasks\SA.DAT
C:\Windows\Tasks\SCHEDLGU.TXT
C:\Windows\Tasks\SystemToolsDailyTest.job
----------------------\\ Registry
----------------------\\ Files & Folders
----------------------\\ Scan completed at 18:36.54
C:\Rooter$\Rooter.txt - (06/08/2012 | 18:36.54)
sinister9128
Post by Superdave on Tue 07 Aug 2012, 11:01 am
Re-run MBAM:
Please re-open Malwarebytes, click the Update tab, and click Check for Updates. Then, click the Scanner tab, select Perform Quick Scan, and press Scan. Remove selected, and post the log in your next reply..
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by sinister9128 on Tue 07 Aug 2012, 2:56 pm
Ok, Malwarebytes:
Malwarebytes Anti-Malware 1.62.0.1300
Database version: v2012.08.06.13
Windows 7 Service Pack 1 x64 NTFS
Imagine :: SLICK-PC [administrator]
8/6/2012 07:04:07 PM
mbam-log-2012-08-06 (19-04-07).txt
Scan type: Quick scan
Scan options disabled: P2P
Objects scanned: 234377
Time elapsed: 4 minute(s), 43 second(s)
Memory Processes Detected: 0
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 0
(end)
Eset found 7 threats:
C:\Qoobox\Quarantine\C\Windows\Installer\{887202d4-3af8-888f-30e5-b3fb3c2a1f41}\U\00000008.@.vir Win64/Agent.BA
trojan cleaned by deleting - quarantined
C:\TDSSKiller_Quarantine\28.07.2012_03.11.41\mbr0000\tdlfs0000\tsk0000.dta Win64/Olmarik.AK trojan cleaned by deleting
- quarantined
C:\TDSSKiller_Quarantine\28.07.2012_03.11.41\mbr0000\tdlfs0000\tsk0001.dta Win32/Olmarik.AYH trojan cleaned by
C:\TDSSKiller_Quarantine\28.07.2012_03.11.41\mbr0000\tdlfs0000\tsk0002.dta Win64/Olmarik.AL trojan cleaned by deleting
- quarantined
C:\Users\Imagine\AppData\Local\Google\Chrome\User Data\Default\Default\aaggdjdfgedcdaggdbdjddgcdedcdjdg\background.html
Win32/BHO.OEI trojan cleaned by deleting - quarantined
C:\Users\Imagine\AppData\Roaming\Mozilla\Firefox\Profiles\7b9pmvso.default\extensions\dclxqkizsa@dclxqkizsa.org.xpi
JS/Redirector.NCA trojan deleted - quarantined
C:\Users\Imagine\AppData\Roaming\Mozilla\Firefox\Profiles\qfgjd40b.default-1340353282062\extensions
\dclxqkizsa@dclxqkizsa.org.xpi JS/Redirector.NCA trojan deleted - quarantined
sinister9128
Post by Superdave on Wed 08 Aug 2012, 9:09 am
Your computer should be clean. Are there any other issues before we clean up?
Tech Staff
Tech Staff
Post by sinister9128 on Wed 08 Aug 2012, 3:48 pm
No, everything is working great now. Thank you for all your help
sinister9128
Post by Superdave on Thu 09 Aug 2012, 9:08 am
Good, let's cleanup.
To remove all of the tools we used and the files and folders they created do the following:
Double click OTL.exe.
  • Click the CleanUp button.
  • Select Yes when the "Begin cleanup Process?" prompt appears.
Clean out your temporary internet files and temp files.
Download TFC by OldTimer to your desktop.
Double-click TFC.exe to run it.
Note: If you are running on Vista, right-click on the file and choose Run As Administrator
TFC will close all programs when run, so make sure you have saved all your work before you begin.
* Click the Start button to begin the cleaning process.
* Depending on how often you clean temp files, execution time should be anywhere from a few seconds to a minute or two.
* Please let TFC run uninterrupted until it is finished.
Once TFC is finished it should restart your computer. If it does not, please manually restart the computer yourself to ensure a complete cleaning.
To set a new Restore Point.
Click Start button , click Control Panel, click System and Maintenance, and then clicking System. In the left pane, click System Protection. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. To turn off System Protection for a hard disk, clear the check box next to the disk, and then click OK. Reboot to Normal Mode.
Click the Start button , click Control Panel, click System and Maintenance, and then click System.
To turn on System Protection for a hard disk, select the check box next to the disk, and then click OK.
This will give you a new, clean Restore Point.
Use the Secunia Software Inspector to check for out of date software.
•Click Start Now
•Check the box next to Enable thorough system inspection.
•Click Start
•Allow the scan to finish and scroll down to see if any updates are needed.
•Update anything listed.
Go to Microsoft Windows Update and get all critical updates.
SpywareBlaster- Secure your Internet Explorer to make it harder for ActiveX programs to run on your computer. Also stop certain cookies from being added to your computer when running Mozilla based browsers like Firefox.
* Using SpywareBlaster to protect your computer from Spyware and Malware
* If you don't know what ActiveX controls are, see here
Protect yourself against spyware using the Immunize feature in Spybot - Search & Destroy. Guide: Use Spybot's Immunize Feature to prevent spyware infection in real-time. Note: To ensure you have the latest Immunizations always update Spybot - Search & Destroy before Immunizing. Spybot - Search & Destroy FAQ
Safe Surfing!
Tech Staff
Tech Staff
Post by Sponsored content Today at 4:16 pm
