Having a problem with a Trojan Agent
Post by Rbadd3 on 3rd August 2012, 6:14 am
Hello all, i haven't been on here for awhile ( thank god) LOL. But i have a new virus in my Memory and files. Its called trojan agent/gen-faldesc. And i can't seem to get rid of it, so any help you can give would be greatly appreciated.
Thanks in advance, Rbadd3
Rbadd3
Joined Joined : 2010-05-24
OS OS : vista home premium
Points Points : 23908
Re: Having a problem with a Trojan Agent
Post by Superdave on 4th August 2012, 12:21 am
SUPERAntiSpyware
* If you encounter any problems while downloading the updates, manually download and unzip them from [You must be registered and logged in to see this link.]
•Scan for tracking cookies
Please leave the others unchecked
Please download Malwarebytes Anti-Malware from [You must be registered and logged in to see this link.]
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83191
Post by Rbadd3 on 6th August 2012, 5:13 am
Generated 08/04/2012 at 00:47 AM
Application Version : 4.46.1000
Core Rules Database Version : 8206
Trace Rules Database Version: 6018
Scan type : Complete Scan
Total Scan Time : 03:00:19
Memory items scanned : 716
Memory threats detected : 1
Registry items scanned : 11238
Registry threats detected : 0
File items scanned : 225807
File threats detected : 10
Trojan.Agent/Gen-Faldesc
C:\PROGRAM FILES (X86)\LEXMARK 6500 SERIES\LXDFCATS.DLL
Trojan.Agent/Gen-Faker
C:\PROGRAM FILES (X86)\V-GRABBER\UNINSTALL.EXE
Adware.Tracking Cookie
assets.porn.com [ C:\Users\Lisha\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\79D39S22 ]
cdn1.static.youporn.phncdn.com [ C:\Users\Lisha\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\79D39S22 ]
flash.xxxbunker.com [ C:\Users\Lisha\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\79D39S22 ]
h2porn.com [ C:\Users\Lisha\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\79D39S22 ]
media.trafficfactory.biz [ C:\Users\Lisha\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\79D39S22 ]
mediax.shufuni.com [ C:\Users\Lisha\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\79D39S22 ]
staticedge.hardsextube.com [ C:\Users\Lisha\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\79D39S22 ]
[You must be registered and logged in to see this link.] [ C:\Users\Lisha\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\79D39S22 ]
Results of screen317's Security Check
version 0.99.43
Windows Vista Service Pack 2 x64 (UAC is
enabled)
Internet Explorer 9
``````````````Antivirus/Firewall
Check:``````````````
Windows Security Center
service is not running! This report may not
be accurate!
avast! Antivirus
McAfee VirusScan
Antivirus up to date!
`````````Anti-malware/Other Utilities
Check:`````````
Malwarebytes Anti-Malware version
1.62.0.1300
TuneUp360
Toolbar Cleaner 1.0
TweakNow RegCleaner 2011
Java(TM) 6 Update 26
Java version out of Date!
Adobe Flash Player 11.0.1.152
Adobe Reader 9 Adobe Reader
out of Date!
Mozilla Firefox (14.0.1)
Google Chrome 20.0.1132.57
Google Chrome 21.0.1180.60
Google Chrome VisualElementsManifest.xml..
````````Process Check: objlist.exe by
Laurent````````
Norton ccSvcHst.exe
Malwarebytes Anti-Malware mbamservice.exe
Malwarebytes Anti-Malware mbamgui.exe
`````````````````System Health
check`````````````````
Total Fragmentation on Drive C: 0 %
````````````````````End of
Log``````````````````````
Results of screen317's Security Check version 0.99.43
Windows Vista Service Pack 2 x64 (UAC is enabled)
Internet Explorer 9
Windows Security Center service is not running! This report may not be accurate!
avast! Antivirus
McAfee VirusScan
Malwarebytes Anti-Malware version 1.62.0.1300
TuneUp360
Toolbar Cleaner 1.0
Adobe Reader 9 Adobe Reader out of Date!
Norton ccSvcHst.exe
McAfee VIRUSS~1 mcsysmon.exe
McAfee VirusScan McShield.exe
Alwil Software Avast5 AvastSvc.exe
Alwil Software Avast5 AvastUI.exe
MBAM keeps shutting down when i try to clean up the infections. So i couldn't send a log report.
Rbadd3
Post by Superdave on 6th August 2012, 7:35 pm
Update Your Java (JRE)
First [You must be registered and logged in to see this link.]
If your version is out of date install the newest version of the [You must be registered and logged in to see this link.].
Remove any old versions
1. Download [You must be registered and logged in to see this link.] and unzip the file to your Desktop.
3. Once complete exit JavaRA.
Additional Note: [You must be registered and logged in to see this link.] adds a service to improve the initial startup time of Java applets and applications. To disable the JQS service if you don't want to use it, go to Start > Control Panel > Java > Advanced > Miscellaneous and uncheck the box for Java Quick Starter. Click OK and reboot your computer.
Please try running in Safe Mode.
To prevent your anti-virus application interfering with ComboFix we need to disable it. See [You must be registered and logged in to see this link.] for a tutorial regarding how to do so if you are unsure.
Captain
Captain
Posts Posts : 4202
