LG DVD Player and HP Printer do not work properly after Virus
Re: LG DVD Player and HP Printer do not work properly after Virus
Post by pointman on 24th July 2012, 10:29 pm
No haven't tried safe mode.
only one drive
I haven't modified any registry settings that I know of.
pointman
Posts Posts : 95
Joined Joined : 2010-01-02
OS OS : windows XP
Points Points : 26601
Post by Dr Jay on 25th July 2012, 4:58 pm
All of the evidence leads to a failing drive. We could continue running fixes till we're blue in the face, but when a drive fails...it's done.
Usually, in this case, if you have LG support repair it, (if not under warranty), you'll pay an arm and a leg to replace the burning mechanism. Same type of stuff I went through, except my issue was more VCR/DVD recorder problem.
Price of new drive: $40-80 USD
Price of mechanism: $60-260 depending on brand popularity
Cost of replacing mechanism (tiresome): $60-200 depending on experience of techie.
As you can see, a new drive is the best option.
I'm sorry it came to this, as I wouldn't recommend you to pay anything unless if necessary.
Let me know what you do.
Posts Posts : 14309
Points Points : 302960
Post by pointman on 26th July 2012, 1:27 am
Ok, that was my thinking also. I will probably just replace it. Thanks for all your help.
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on 26th July 2012, 4:28 pm
You're welcome. Only glad to help. Smile
Posts Posts : 14309
