LG DVD Player and HP Printer do not work properly after Virus
Post by pointman on Sat Jun 30, 2012 9:48 pm
After correcting a maleware/virus problem (with the help of GeekPolice) on my desktop computer a few months ago my LG DVD player will only play certain DVDs. It will not play audio CD's or run installation CD's or DVD's. I've tried to reinstall the software but that doesn't correct the problem. Also my HP officejet all-in-one usb printer will only "print" now. I can't use the scan or copy functions from my desktop. When I try to reinstall the software it says the cable is not connected but I can print so it must be connected properly. All the printer functions work properly via wireless from my notebook so it is not a printer problem. The computer is running windows XP. I was not sure weather to post this as a software or hardware problem.
pointman
Posts Posts : 95
Joined Joined : 2010-01-02
OS OS : windows XP
Points Points : 26551
Re: LG DVD Player and HP Printer do not work properly after Virus
Post by Dr Jay on Wed Jul 04, 2012 10:55 am
It is likely that security settings are disallowing you to run certain devices or programs, mainly because of the malware.
Please navigate to this webpage: http://support.microsoft.com/kb/313222 and see the section "Fix it for me" and click the Microsoft Fix-It button. This will download a fix utility to repair the security settings on your computer, due to damages of malware or other harmful system changes. Install the file after download.
Posts Posts : 13713
Points Points : 302059
Post by pointman on Fri Jul 06, 2012 2:37 pm
I did not see a "fix it for me" section on this page. Should I go to the "other Support Sites"..."microsoft fix it solutions" and select one of the fixes there?
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Fri Jul 06, 2012 5:17 pm
Go to Start > Run, type in CMD and hit OK.
Type this in the Command Line and hit enter:
secedit /configure /cfg %windir%\repair\secsetup.inf /db secsetup.sdb /verbose
Should be a confirmation, and then reboot your system. Let me know if this worked.
Posts Posts : 13713
Post by pointman on Fri Jul 06, 2012 6:20 pm
I cannot tell any difference after running this. DVD player still will not recognize my installation CD's.
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Sat Jul 07, 2012 4:23 pm
Please download the latest version of Kaspersky GetSystemInfo (GSI) from Kaspersky and save it to your Desktop.
Note: please close all other applications running on your system.
Double click GetSystemInfo.exe to open it. It will display an agreement. Click on I Agree to continue.
Click the Settings button.
Set the slider to Maximum.
IMPORTANT! Then, click Customize - choose Driver / Ports tab and uncheck Scan Ports.
On the General tab, make sure all of the boxes are checked.
On the Misc tab, make sure all the checkboxes are checked.
Then, click OK on the windows that you launched.
It will begin scanning.
It will create a zip folder called GetSystemInfo_XXXXXXXXXXXXXX.zip on your Desktop.
It should automatically upload it to http://www.getsysteminfo.com. If it does not, then please submit it manually by going to the site and doing the upload process.
It will redirect to a page, where it will provide a sharing URL for specialists. Copy and paste the url of the GSI Parser report in your next reply.
Posts Posts : 13713
Post by pointman on Sat Jul 07, 2012 6:03 pm
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Sun Jul 08, 2012 10:38 am
I want to check for remnants of malware...
Download OTL.exe by OldTimer to your Desktop.
  • Click Quick Scan and let the program run uninterrupted.
  • Please post OTL.txt in your reply.
Posts Posts : 13713
Post by pointman on Sun Jul 08, 2012 2:50 pm
OTL logfile created on: 7/8/2012 10:32:50 AM - Run 1
OTL by OldTimer - Version 3.2.53.1 Folder = C:\Documents and Settings\Owner\Desktop
Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
3.00 Gb Total Physical Memory | 2.31 Gb Available Physical Memory | 77.13% Memory free
4.84 Gb Paging File | 4.23 Gb Available in Paging File | 87.36% Paging File free
Paging file location(s): C:\pagefile.sys 2046 4092 [binary data]
Drive C: | 298.08 Gb Total Space | 146.41 Gb Free Space | 49.12% Space Free | Partition Type: NTFS
Computer Name: QUADCORE | User Name: Owner | Logged in as Administrator.
Boot Mode: Normal | Scan Mode: Current user | Quick Scan
Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
PRC - [2012/07/08 10:24:55 | 000,595,968 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Owner\Desktop\OTL.exe
PRC - [2012/07/07 12:07:49 | 000,935,008 | ---- | M] () -- C:\Program Files\Common Files\AVG Secure Search\vToolbarUpdater\11.2.0\ToolbarUpdater.exe
PRC - [2012/07/07 12:07:42 | 001,107,552 | ---- | M] () -- C:\Program Files\AVG Secure Search\vprot.exe
PRC - [2012/06/19 18:46:36 | 011,324,352 | ---- | M] (Innovative Solutions) -- C:\Program Files\Innovative Solutions\DriverMax\drivermax.exe
PRC - [2012/05/17 18:07:03 | 000,932,528 | ---- | M] () -- C:\Documents and Settings\Owner\Application Data\Spotify\Data\SpotifyWebHelper.exe
PRC - [2012/03/22 08:24:21 | 000,180,648 | ---- | M] (Google Inc.) -- C:\Program Files\Google\Update\1.3.21.111\GoogleCrashHandler.exe
PRC - [2012/03/06 19:15:17 | 004,241,512 | ---- | M] (AVAST Software) -- C:\Program Files\AVAST Software\Avast\AvastUI.exe
PRC - [2012/03/06 19:15:14 | 000,044,768 | ---- | M] (AVAST Software) -- C:\Program Files\AVAST Software\Avast\AvastSvc.exe
PRC - [2012/02/07 18:43:01 | 000,160,328 | ---- | M] (Siber Systems) -- C:\Program Files\Siber Systems\AI RoboForm\robotaskbaricon.exe
PRC - [2011/12/11 22:42:19 | 000,161,664 | ---- | M] (Oracle Corporation) -- C:\Program Files\Java\jre7\bin\jqs.exe
PRC - [2011/11/01 12:33:56 | 002,531,104 | ---- | M] (Emsi Software GmbH) -- C:\Program Files\Online Armor\oaui.exe
PRC - [2011/11/01 12:33:54 | 004,363,040 | ---- | M] (Emsi Software GmbH) -- C:\Program Files\Online Armor\oasrv.exe
PRC - [2011/11/01 12:33:52 | 001,163,800 | ---- | M] (Emsi Software GmbH) -- C:\Program Files\Online Armor\oahlp.exe
PRC - [2011/11/01 12:33:52 | 000,207,936 | ---- | M] (Emsi Software GmbH) -- C:\Program Files\Online Armor\oacat.exe
PRC - [2011/08/25 18:53:00 | 000,013,672 | ---- | M] (Intuit Inc.) -- C:\Program Files\Common Files\Intuit\Update Service v4\IntuitUpdateService.exe
PRC - [2008/04/13 20:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2007/03/09 11:09:58 | 000,063,712 | ---- | M] (Adobe Systems Incorporated) -- C:\Program Files\Adobe\Photoshop Album Starter Edition\3.2\Apps\apdproxy.exe
PRC - [2006/12/12 11:46:54 | 000,020,480 | ---- | M] (Creative Technology Ltd) -- C:\WINDOWS\system32\Ctxfihlp.exe
PRC - [2006/12/12 11:46:52 | 000,019,456 | ---- | M] (Creative Technology Ltd) -- C:\WINDOWS\system32\CtHelper.exe
PRC - [2006/12/12 11:43:58 | 000,842,240 | ---- | M] (Creative Technology Ltd) -- C:\WINDOWS\system32\CTxfispi.exe
PRC - [2006/09/21 16:34:56 | 000,495,616 | ---- | M] (Bluebeam Software, Inc.) -- C:\Program Files\Common Files\Bluebeam Software\Brewery\V45\Printer Support\MicroBrew2.exe
PRC - [2005/11/04 18:07:56 | 000,049,152 | ---- | M] (Creative Technology Ltd.) -- C:\Program Files\Creative\Shared Files\Module Loader\DLLML.exe
========== Modules (No Company Name) ==========
MOD - [2012/07/08 04:12:22 | 001,781,248 | ---- | M] () -- C:\Program Files\AVAST Software\Avast\defs\12070800\algo.dll
MOD - [2012/07/07 13:24:00 | 001,781,248 | ---- | M] () -- C:\Program Files\AVAST Software\Avast\defs\12070701\algo.dll
MOD - [2012/07/07 12:07:50 | 000,132,704 | ---- | M] () -- C:\Program Files\Common Files\AVG Secure Search\SiteSafetyInstaller\11.2.0\SiteSafety.dll
MOD - [2012/07/07 12:07:49 | 000,935,008 | ---- | M] () -- C:\Program Files\Common Files\AVG Secure Search\vToolbarUpdater\11.2.0\ToolbarUpdater.exe
MOD - [2012/07/07 12:07:42 | 001,107,552 | ---- | M] () -- C:\Program Files\AVG Secure Search\vprot.exe
MOD - [2012/06/14 18:13:14 | 000,008,648 | ---- | M] () -- C:\Program Files\Innovative Solutions\DriverMax\sync.dll
MOD - [2012/06/14 03:21:26 | 000,221,696 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.ServiceProce#\2516a49d10f4418f72e1c25f691815a8\System.ServiceProcess.ni.dll
MOD - [2012/06/14 03:19:42 | 000,165,376 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Bluebeam.Utilities\7ec26942fb3f80f26766d6ddca228a04\Bluebeam.Utilities.ni.dll
MOD - [2012/06/14 03:19:41 | 000,316,416 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Bluebeam.Registrati#\2b5f2d859d513016de7cc92f13877af3\Bluebeam.Registration.ni.dll
MOD - [2012/06/14 03:18:08 | 012,433,920 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\01abbadafaf265d9f4ac9bbb247acb98\System.Windows.Forms.ni.dll
MOD - [2012/06/14 03:17:58 | 001,592,320 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Drawing\d86f2038209a4cf0d0f5b30f6375c9b2\System.Drawing.ni.dll
MOD - [2012/06/14 03:14:30 | 013,197,824 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\54d61af44b1dedee6aea0d1bbc46b13a\System.Windows.Forms.ni.dll
MOD - [2012/06/14 03:08:24 | 001,666,048 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Drawing\4a668799513e369a54fdab8b3f74de92\System.Drawing.ni.dll
MOD - [2012/05/17 18:07:03 | 000,932,528 | ---- | M] () -- C:\Documents and Settings\Owner\Application Data\Spotify\Data\SpotifyWebHelper.exe
MOD - [2012/05/13 03:24:55 | 000,762,368 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Runtime.Remo#\0f9d7198d2c0a3953fb59b1aca0d35f7\System.Runtime.Remoting.ni.dll
MOD - [2012/05/13 03:24:53 | 000,786,944 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.EnterpriseSe#\26ee061618887d629a9f7072970ffb85\System.EnterpriseServices.ni.dll
MOD - [2012/05/13 03:24:52 | 000,646,656 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Transactions\ce2aa3a5e89c326055ac8e2a309232f7\System.Transactions.ni.dll
MOD - [2012/05/13 03:16:18 | 007,953,408 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System\e4b5afc4da43b1c576f9322f9f2e1bfe\System.ni.dll
MOD - [2012/05/13 03:16:09 | 011,492,352 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\mscorlib\e337c89bc9f81b69d7237aa70e935900\mscorlib.ni.dll
MOD - [2012/05/13 03:06:45 | 006,798,336 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Data\9f5111b0b58258c3a4bbcfb8bf27374c\System.Data.ni.dll
MOD - [2012/05/13 03:06:37 | 007,052,800 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Core\14ba6251d6ec84c9579ed3d3e10b30c1\System.Core.ni.dll
MOD - [2012/05/13 03:06:33 | 005,618,176 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Xml\5ee8bf77e7b3e25cdbff6e1c299574fe\System.Xml.ni.dll
MOD - [2012/05/13 03:06:29 | 000,980,480 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Configuration\0c8e950df17a0abec10888e8ad966cbe\System.Configuration.ni.dll
MOD - [2012/05/13 03:06:24 | 009,090,560 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System\6f399163bb35597da7141ccdb7f39d16\System.ni.dll
MOD - [2012/05/13 03:06:15 | 014,412,800 | ---- | M] () -- C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\mscorlib\3953b1d8b9b57e4957bff8f58145384e\mscorlib.ni.dll
MOD - [2011/09/27 07:23:00 | 000,087,912 | ---- | M] () -- C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
MOD - [2011/09/27 07:22:40 | 001,242,472 | ---- | M] () -- C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
MOD - [2010/05/05 20:56:46 | 000,002,560 | ---- | M] () -- C:\WINDOWS\CTXFIRES.DLL
MOD - [2008/03/31 13:33:15 | 000,335,872 | ---- | M] () -- C:\WINDOWS\assembly\GAC_MSIL\Bluebeam.Brewery\1.0.2455.27691__0c673d50796bb708\Bluebeam.Brewery.dll
MOD - [2005/11/02 10:54:48 | 002,945,024 | R--- | M] () -- C:\WINDOWS\system32\BGP851c.dll
MOD - [2005/06/07 09:10:50 | 000,070,656 | ---- | M] () -- C:\WINDOWS\system32\CTMMACTL.DLL
SRV - File not found [Auto | Stopped] -- C:\DOCUME~1\Owner\LOCALS~1\Temp\020653~1.EXE C:\PROGRA~1\COMMON~1\McAfee\INSTAL~1\cleanup.ini -- (0206531322785919mcinstcleanup) McAfee Application Installer Cleanup (0206531322785919)
SRV - [2012/07/07 12:07:49 | 000,935,008 | ---- | M] () [Auto | Running] -- C:\Program Files\Common Files\AVG Secure Search\vToolbarUpdater\11.2.0\ToolbarUpdater.exe -- (vToolbarUpdater11.2.0)
SRV - [2012/06/26 11:20:01 | 000,250,056 | ---- | M] (Adobe Systems Incorporated) [On_Demand | Stopped] -- C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe -- (AdobeFlashPlayerUpdateSvc)
SRV - [2012/03/06 19:15:14 | 000,044,768 | ---- | M] (AVAST Software) [Auto | Running] -- C:\Program Files\AVAST Software\Avast\AvastSvc.exe -- (avast! Antivirus)
SRV - [2011/12/11 22:42:19 | 000,161,664 | ---- | M] (Oracle Corporation) [Auto | Running] -- C:\Program Files\Java\jre7\bin\jqs.exe -- (JavaQuickStarterService)
SRV - [2011/11/01 12:33:54 | 004,363,040 | ---- | M] (Emsi Software GmbH) [Auto | Running] -- C:\Program Files\Online Armor\oasrv.exe -- (SvcOnlineArmor)
SRV - [2011/11/01 12:33:52 | 000,207,936 | ---- | M] (Emsi Software GmbH) [Auto | Running] -- C:\Program Files\Online Armor\oacat.exe -- (OAcat)
SRV - [2011/08/25 18:53:00 | 000,013,672 | ---- | M] (Intuit Inc.) [Auto | Running] -- C:\Program Files\Common Files\Intuit\Update Service v4\IntuitUpdateService.exe -- (IntuitUpdateServiceV4)
SRV - [2010/08/23 20:21:40 | 000,013,672 | ---- | M] (Intuit Inc.) [Disabled | Stopped] -- C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe -- (IntuitUpdateService)
SRV - [2010/06/30 03:31:50 | 000,315,392 | ---- | M] (Alcatel-Lucent) [Disabled | Stopped] -- C:\Program Files\Common Files\Motive\McciServiceHost.exe -- (McciServiceHost)
SRV - [2009/02/02 02:33:18 | 000,317,440 | ---- | M] (Amazon.com) [Disabled | Stopped] -- C:\Program Files\Amazon\Amazon Games & Software Downloader\AmazonGSDownloaderService.exe -- (Amazon Download Agent)
SRV - [2008/04/03 15:46:03 | 000,085,096 | ---- | M] (Autodesk) [Disabled | Stopped] -- C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe -- (Autodesk Licensing Service)
SRV - [2006/11/03 19:19:58 | 000,013,592 | ---- | M] (Microsoft Corporation) [Disabled | Stopped] -- C:\Program Files\Windows Defender\MsMpEng.exe -- (WinDefend)
SRV - [2005/09/30 19:22:50 | 000,096,341 | ---- | M] (Canon Inc.) [Disabled | Stopped] -- C:\Program Files\Canon\CAL\CALMAIN.exe -- (CCALib8)
SRV - [2003/04/30 11:04:00 | 000,331,776 | ---- | M] (Cyber Power System Inc.) [Disabled | Stopped] -- C:\PowerPanel\upssrv.exe -- (CyberPowerUPS)
DRV - File not found [Kernel | On_Demand | Stopped] -- -- (WDICA)
DRV - File not found [Kernel | On_Demand | Stopped] -- -- (PDRFRAME)
DRV - File not found [Kernel | On_Demand | Stopped] -- -- (PDRELI)
DRV - File not found [Kernel | On_Demand | Stopped] -- -- (PDFRAME)
DRV - File not found [Kernel | On_Demand | Stopped] -- -- (PDCOMP)
DRV - File not found [Kernel | System | Stopped] -- -- (PCIDump)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\PROGRA~1\COMMON~1\Motive\MRESP50a64.SYS -- (MRESP50a64)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\PROGRA~1\COMMON~1\Motive\MREMP50a64.SYS -- (MREMP50a64)
DRV - File not found [Kernel | System | Stopped] -- -- (lbrtfdc)
DRV - File not found [Kernel | System | Stopped] -- -- (i2omgmt)
DRV - File not found [Kernel | On_Demand | Stopped] -- system32\DRIVERS\HPZipr12.sys -- (HPZipr12)
DRV - File not found [Kernel | On_Demand | Stopped] -- system32\DRIVERS\HPZid412.sys -- (HPZid412)
DRV - File not found [Kernel | System | Stopped] -- -- (Changer)
DRV - File not found [Kernel | Unavailable | Unknown] -- globalroot\C:\WINDOWS\system32\drivers\196415.sys -- (196415)
DRV - [2012/03/06 19:03:51 | 000,612,184 | ---- | M] (AVAST Software) [File_System | System | Running] -- C:\WINDOWS\System32\drivers\aswSnx.sys -- (aswSnx)
DRV - [2012/03/06 19:03:38 | 000,337,880 | ---- | M] (AVAST Software) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\aswSP.sys -- (aswSP)
DRV - [2012/03/06 19:02:00 | 000,035,672 | ---- | M] (AVAST Software) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\aswRdr.sys -- (aswRdr)
DRV - [2012/03/06 19:01:53 | 000,053,848 | ---- | M] (AVAST Software) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\aswTdi.sys -- (aswTdi)
DRV - [2012/03/06 19:01:39 | 000,095,704 | ---- | M] (AVAST Software) [File_System | Auto | Running] -- C:\WINDOWS\System32\drivers\aswmon2.sys -- (aswMon2)
DRV - [2012/03/06 19:01:30 | 000,020,696 | ---- | M] (AVAST Software) [File_System | Auto | Running] -- C:\WINDOWS\System32\drivers\aswFsBlk.sys -- (aswFsBlk)
DRV - [2012/03/06 18:58:29 | 000,024,920 | ---- | M] (AVAST Software) [Kernel | System | Running] -- C:\WINDOWS\System32\drivers\aavmker4.sys -- (Aavmker4)
DRV - [2011/11/01 12:34:28 | 000,040,296 | ---- | M] () [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\oahlp32.sys -- (oahlpXX)
DRV - [2011/11/01 12:34:10 | 000,029,464 | ---- | M] (Emsisoft) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\OAnet.sys -- (OAnet)
DRV - [2011/11/01 12:34:08 | 000,205,864 | ---- | M] () [File_System | System | Running] -- C:\WINDOWS\system32\drivers\OADriver.sys -- (OADevice)
DRV - [2011/11/01 12:34:08 | 000,025,192 | ---- | M] (Emsisoft) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\OAmon.sys -- (OAmon)
DRV - [2010/06/30 03:32:04 | 000,020,096 | ---- | M] (Printing Communications Assoc., Inc. (PCAUSA)) [Kernel | On_Demand | Stopped] -- C:\Program Files\Common Files\Motive\MRESP50.sys -- (MRESP50)
DRV - [2010/06/30 03:31:44 | 000,021,248 | ---- | M] (Printing Communications Assoc., Inc. (PCAUSA)) [Kernel | On_Demand | Stopped] -- C:\Program Files\Common Files\Motive\MREMP50.sys -- (MREMP50)
DRV - [2010/05/05 22:24:34 | 000,347,144 | ---- | M] (Creative Technology Ltd) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ctdvda2k.sys -- (ctdvda2k)
DRV - [2009/10/15 11:05:54 | 000,016,000 | ---- | M] (SysNucleus) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\udsstub.sys -- (udsstub)
DRV - [2008/04/13 14:36:42 | 000,063,744 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mf.sys -- (mf)
DRV - [2008/03/27 19:31:44 | 000,008,413 | ---- | M] (RealNetworks, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\System32\drivers\mcstrm.sys -- (MCSTRM)
DRV - [2007/06/18 04:01:28 | 000,514,560 | ---- | M] (Creative Technology Ltd) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ctaud2k.sys -- (ctaud2k) Creative Audio Driver (WDM)
DRV - [2007/05/10 13:33:58 | 000,048,640 | ---- | M] (JMicron Technology Corp.) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\jraid.sys -- (JRAID)
DRV - [2007/04/12 15:04:40 | 004,397,568 | R--- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\RtkHDAud.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
DRV - [2007/03/15 18:12:04 | 000,038,656 | R--- | M] (Attansic Technology corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\atl01_xp.sys -- (AtcL001)
DRV - [2006/12/19 09:36:54 | 001,160,504 | ---- | M] (Creative Technology Ltd) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ha20x2k.sys -- (ha20x2k)
DRV - [2006/12/19 09:36:46 | 000,090,936 | ---- | M] (Creative Technology Ltd) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\emupia2k.sys -- (emupia)
DRV - [2006/12/19 09:36:42 | 000,156,984 | ---- | M] (Creative Technology Ltd) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ctsfm2k.sys -- (ctsfm2k)
DRV - [2006/12/19 09:36:36 | 000,014,648 | ---- | M] (Creative Technology Ltd) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ctprxy2k.sys -- (ctprxy2k)
DRV - [2006/12/19 09:36:32 | 000,128,312 | ---- | M] (Creative Technology Ltd.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ctoss2k.sys -- (ossrv)
DRV - [2006/12/19 09:35:40 | 000,511,288 | ---- | M] (Creative Technology Ltd) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ctac32k.sys -- (ctac32k)
DRV - [2004/11/22 18:36:39 | 000,018,003 | ---- | M] (Motive, Inc.) [Kernel | On_Demand | Stopped] -- C:\Program Files\Common Files\Motive\MRENDIS5.sys -- (MRENDIS5)
DRV - [2004/11/22 18:36:34 | 000,019,345 | ---- | M] (Motive, Inc.) [Kernel | On_Demand | Stopped] -- C:\Program Files\Common Files\Motive\MREMPR5.sys -- (MREMPR5)
DRV - [2004/08/14 04:00:00 | 000,005,810 | R--- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ASACPI.sys -- (MTsensor)
DRV - [2001/01/16 15:46:08 | 000,050,576 | ---- | M] (HP) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\hppadt40.sys -- (dot4)
DRV - [2001/01/16 15:44:36 | 000,017,872 | ---- | M] (HP) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\hppausb0.sys -- (dot4usb)
DRV - [2001/01/16 14:43:34 | 000,015,792 | ---- | M] (HP) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\hppaprt0.sys -- (Dot4Print)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Bar = http://red.clientapps.yahoo.com/customize/ie/defaults/sb/yme/*http://www.yahoo.com/ext/search/search.html
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,CustomSearch = http://red.clientapps.yahoo.com/customize/ie/defaults/cs/yme/*http://www.yahoo.com/ext/search/search.html
IE - HKLM\..\SearchScopes,DefaultScope = {6A1806CD-94D4-4689-BA73-E35EA1EA9990}
IE - HKLM\..\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: "URL" = http://search.live.com/results.aspx?q={searchTerms}&src={referrer:source?}
IE - HKLM\..\SearchScopes\{0B4A10D1-FBD6-451d-BFDA-F03252B05984}: "URL" = http://slirsredirect.search.aol.com/slirs_http/sredir?sredir=2706&query={searchTerms}&invocationType=TB50TRie7
IE - HKLM\..\SearchScopes\{6A1806CD-94D4-4689-BA73-E35EA1EA9990}: "URL" = http://www.google.com/search?q={searchTerms}&rls=com.microsoft:{language}:{referrer:source?}&ie={inputEncoding}&oe={outputEncoding}&sourceid=ie7
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,AlwaysUseDefaultPrinter = yes
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Secondary_Page_URL = http://www.att.net [binary data]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchDefaultBranded = 1
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Secondary Start Pages = http://www.att.net/ [binary data]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = http://www.msn.com/?ocid=iehp
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache AcceptLangs = en-US
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache_TIMESTAMP = EC 33 21 52 7D 5C CD 01 [binary data]
IE - HKCU\..\URLSearchHook: {472734EA-242A-422b-ADF8-83D1E48CC825} - No CLSID value found
IE - HKCU\..\URLSearchHook: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
IE - HKCU\..\SearchScopes,DefaultScope = {6A1806CD-94D4-4689-BA73-E35EA1EA9990}
IE - HKCU\..\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: "URL" = http://www.bing.com/search?q={searchTerms}&src=IE-SearchBox&FORM=IE8SRC
IE - HKCU\..\SearchScopes\{0B4A10D1-FBD6-451d-BFDA-F03252B05984}: "URL" = http://slirsredirect.search.aol.com/slirs_http/sredir?sredir=2706&query={searchTerms}&invocationType=TB50TRie7
IE - HKCU\..\SearchScopes\{20A635E7-1E4F-417A-B13A-1B78A45710AC}: "URL" = http://search.yahoo.com/search?p={searchTerms}&ei=utf-8&fr=chr-yie8eb
IE - HKCU\..\SearchScopes\{34D2BA0D-EE4A-41E8-B176-CB5CD0638CFC}: "URL" = http://www.att.net/s/s.dll?spage=search%2Fwebresults.htm&advanced=1&vl={searchTerms}&vlsel=1&vp=&vpsel=1&vy=&vysel=1&ve=&vesel=any®ion=&lang=&format=&domain=&safe=&numresults=10&submit2=Search+Yahoo
IE - HKCU\..\SearchScopes\{6A1806CD-94D4-4689-BA73-E35EA1EA9990}: "URL" = http://www.google.com/search?q={searchTerms}&rls=com.microsoft:{language}:{referrer:source?}&ie={inputEncoding}&oe={outputEncoding}&sourceid=ie7&rlz=1I7GGIT_en
IE - HKCU\..\SearchScopes\{944AEDFC-8760-4A01-9723-211C8713BA76}: "URL" = http://rover.ebay.com/rover/1/711-43047-14818-1/4?satitle={selection}
IE - HKCU\..\SearchScopes\{95B7759C-8C7F-4BF1-B163-73684A933233}: "URL" = http://isearch.avg.com/search?cid={C9E7698F-D4DB-44AF-B82F-FFDC804C1B0E}&mid=17b6845efe5447d08246d1542683b391-e9ea9444453b9dabeb7f18711eb0648d668780d2&lang=en&ds=is015&pr=sa&d=2012-07-07 12:07:52&v=11.1.0.12&sap=dsp&q={searchTerms}
IE - HKCU\..\SearchScopes\{AAA76455-D8B2-4C81-B98E-0827CE8052ED}: "URL" = http://search.yahoo.com/search?p={searchTerms}&ei=utf-8&fr=b1ie7
IE - HKCU\..\SearchScopes\{DECA3892-BA8F-44b8-A993-A466AD694AE4}: "URL" = http://search.yahoo.com/search?fr=mcafee&p={searchTerms}
========== FireFox ==========
FF - user.js - File not found
FF - HKLM\Software\MozillaPlugins\@adobe.com/FlashPlayer: C:\WINDOWS\system32\Macromed\Flash\NPSWF32_11_3_300_262.dll ()
FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=: File not found
FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=1.0: C:\Program Files\iTunes\Mozilla Plugins\npitunes.dll ()
FF - HKLM\Software\MozillaPlugins\@avg.com/AVG SiteSafety plugin,version=11.0.0.1,application/x-avg-sitesafety-plugin: C:\Program Files\Common Files\AVG Secure Search\SiteSafetyInstaller\11.2.0\\npsitesafety.dll ()
FF - HKLM\Software\MozillaPlugins\@consona.com/ScriptRunner: C:\Program Files\Common Files\supportsoft\bin\nptgctlsr.dll (SupportSoft, Inc.)
FF - HKLM\Software\MozillaPlugins\@consona.com/SmartIssue: C:\Program Files\Common Files\supportsoft\bin\nptgctlsi.dll (SupportSoft, Inc.)
FF - HKLM\Software\MozillaPlugins\@emusic.com/dlm-plugin: C:\Program Files\eMusic Download Manager\plugin\npemusic.dll (eMusic.com)
FF - HKLM\Software\MozillaPlugins\@garmin.com/GpsControl: C:\Program Files\Garmin GPS Plugin\npGarmin.dll (GARMIN Corp.)
FF - HKLM\Software\MozillaPlugins\@Google.com/GoogleEarthPlugin: C:\Program Files\Google\Google Earth\plugin\npgeplugin.dll (Google)
FF - HKLM\Software\MozillaPlugins\@java.com/JavaPlugin: C:\Program Files\Java\jre7\bin\new_plugin\npjp2.dll (Oracle Corporation)
FF - HKLM\Software\MozillaPlugins\@Microsoft.com/NpCtrl,version=1.0: c:\Program Files\Microsoft Silverlight\4.1.10329.0\npctrl.dll ( Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@Microsoft.com/NpWinExt,version=5.0: C:\Program Files\MSN Toolbar\Platform\5.0.1449.0\npwinext.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/WPF,version=3.5: c:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\NPWPF.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@Motive.com/NpMotive,version=1.0: C:\Program Files\Common Files\Motive\npMotive.dll (Alcatel-Lucent)
FF - HKLM\Software\MozillaPlugins\@pack.google.com/Google Updater;version=14: C:\Program Files\Google\Google Updater\2.4.2432.1652\npCIDetect14.dll (Google)
FF - HKLM\Software\MozillaPlugins\@real.com/RhapsodyPlayerEngine,version=1.0: C:\Program Files\Real\RhapsodyPlayerEngine\nprhapengine.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@tools.google.com/Google Update;version=3: C:\Program Files\Google\Update\1.3.21.111\npGoogleUpdate3.dll (Google Inc.)
FF - HKLM\Software\MozillaPlugins\@tools.google.com/Google Update;version=9: C:\Program Files\Google\Update\1.3.21.111\npGoogleUpdate3.dll (Google Inc.)
FF - HKLM\Software\MozillaPlugins\Adobe Reader: C:\Program Files\Adobe\Reader 10.0\Reader\AIR\nppdf32.dll (Adobe Systems Inc.)
FF - HKCU\Software\MozillaPlugins\@adobe.com/FlashPlayer: C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll File not found
FF - HKCU\Software\MozillaPlugins\@emusic.com/dlm-plugin: C:\Program Files\eMusic Download Manager\plugin\npemusic.dll (eMusic.com)
FF - HKCU\Software\MozillaPlugins\@facebook.com/FBPlugin,version=1.0.1: C:\Documents and Settings\Owner\Application Data\Facebook\npfbplugin_1_0_1.dll ( )
FF - HKCU\Software\MozillaPlugins\@facebook.com/FBPlugin,version=1.0.3: C:\Documents and Settings\Owner\Application Data\Facebook\npfbplugin_1_0_3.dll ( )
FF - HKCU\Software\MozillaPlugins\@real.com/RhapsodyPlayerEngine: C:\Documents and Settings\Owner\Application Data\nprhapengine.dll File not found
FF - HKCU\Software\MozillaPlugins\amazon.com/AmazonMP3DownloaderPlugin: C:\Program Files\Amazon\MP3 Downloader\npAmazonMP3DownloaderPlugin.dll (Amazon.com, Inc.)
FF - HKEY_LOCAL_MACHINE\software\mozilla\eMusic Download Manager\Extensions\\Components: C:\Program Files\eMusic Download Manager\xulrunner\components [2012/05/31 15:30:36 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\eMusic Download Manager\Extensions\\Plugins: C:\Program Files\eMusic Download Manager\xulrunner\plugins [2012/05/31 15:30:36 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\paypalfirefoxplugin@orbiscom: C:\Program Files\PayPal\PayPal Plug-In [2009/07/20 13:41:08 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\wrc@avast.com: C:\Program Files\AVAST Software\Avast\WebRep\FF [2012/04/22 18:35:35 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{22119944-ED35-4ab1-910B-E619EA06A115}: C:\Program Files\Siber Systems\AI RoboForm\Firefox [2012/02/07 18:52:02 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\smartwebprinting@hp.com: C:\Program Files\HP\Digital Imaging\Smart Web Printing\MozillaAddOn3 [2012/04/11 17:44:33 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\msntoolbar@msn.com: C:\Program Files\MSN Toolbar\Platform\5.0.1449.0\Firefox [2012/04/11 17:44:54 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{27182e60-b5f3-411c-b545-b44205977502}: C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\firefoxextension\SearchHelperExtension\ [2012/04/12 03:10:39 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\avg@toolbar: C:\Documents and Settings\All Users\Application Data\AVG Secure Search\11.1.0.12\ [2012/07/07 12:08:12 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Firefox 11.0\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2012/06/21 13:18:31 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Firefox 11.0\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2012/05/31 15:30:36 | 000,000,000 | ---D | M]
FF - HKEY_CURRENT_USER\software\mozilla\Firefox\Extensions\\smartwebprinting@hp.com: C:\Program Files\HP\Digital Imaging\Smart Web Printing\MozillaAddOn3 [2012/04/11 17:44:33 | 000,000,000 | ---D | M]
[2009/01/12 18:12:33 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Owner\Application Data\Mozilla\Extensions
[2012/06/29 14:48:50 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Owner\Application Data\Mozilla\Firefox\Profiles\sbvr156n.default\extensions
[2011/06/19 11:21:46 | 000,000,000 | ---D | M] (Google Toolbar for Firefox) -- C:\Documents and Settings\Owner\Application Data\Mozilla\Firefox\Profiles\sbvr156n.default\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}
[2009/01/12 18:13:16 | 000,000,000 | ---D | M] ("AOL Toolbar") -- C:\Documents and Settings\Owner\Application Data\Mozilla\Firefox\Profiles\sbvr156n.default\extensions\{7affbfae-c4e2-4915-8c0f-00fa3ec610a1}
[2012/06/29 14:48:42 | 000,000,000 | ---D | M] (OneClickDownloader) -- C:\Documents and Settings\Owner\Application Data\Mozilla\Firefox\Profiles\sbvr156n.default\extensions\OneClickDownload@OneClickDownload.com
[2012/06/29 14:48:51 | 000,000,000 | ---D | M] (Yontoo) -- C:\Documents and Settings\Owner\Application Data\Mozilla\Firefox\Profiles\sbvr156n.default\extensions\plugin@yontoo.com
[2012/02/06 15:53:55 | 000,000,000 | ---D | M] (No name found) -- C:\Program Files\Mozilla Firefox\extensions
[2010/01/06 10:34:58 | 000,000,000 | ---D | M] (eMusic - Apple iTunes Support) -- C:\PROGRAM FILES\EMUSIC DOWNLOAD MANAGER\XULRUNNER\EXTENSIONS\DLM_ITUNES@EMUSIC.COM
[2010/01/06 10:34:58 | 000,000,000 | ---D | M] (eMusic - Nullsoft Winamp Support) -- C:\PROGRAM FILES\EMUSIC DOWNLOAD MANAGER\XULRUNNER\EXTENSIONS\DLM_WINAMP@EMUSIC.COM
[2010/01/06 10:34:59 | 000,000,000 | ---D | M] (eMusic - Microsoft Media Player Support) -- C:\PROGRAM FILES\EMUSIC DOWNLOAD MANAGER\XULRUNNER\EXTENSIONS\DLM_WMP@EMUSIC.COM
[2012/06/21 13:18:31 | 000,097,208 | ---- | M] (Mozilla Foundation) -- C:\Program Files\mozilla firefox\components\browsercomps.dll
[2011/03/18 14:32:12 | 000,091,552 | ---- | M] (Coupons, Inc.) -- C:\Program Files\mozilla firefox\plugins\npCouponPrinter.dll
[2011/12/11 22:42:19 | 000,611,224 | ---- | M] (Oracle Corporation) -- C:\Program Files\mozilla firefox\plugins\npdeployJava1.dll
[2007/02/04 23:02:56 | 001,642,496 | ---- | M] (LizardTech) -- C:\Program Files\mozilla firefox\plugins\npdjvu.dll
[2011/03/18 14:32:14 | 000,091,552 | ---- | M] (Coupons, Inc.) -- C:\Program Files\mozilla firefox\plugins\npMozCouponPrinter.dll
[2012/07/07 12:07:38 | 000,003,750 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\avg-secure-search.xml
[2012/06/21 13:18:27 | 000,002,252 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\bing.xml
[2012/06/21 13:18:27 | 000,002,040 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\twitter.xml
========== Chrome ==========
CHR - Extension: No name found = C:\Documents and Settings\Owner\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\icmlaeflemplmjndnaapfdbbnpncnbda\6.0.1374_0\
O1 HOSTS File: ([2011/12/01 20:45:00 | 000,000,027 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O2 - BHO: (AT&&T Toolbar) - {4E7BD74F-2B8D-469E-94BE-FD60BB9AAE29} - C:\Program Files\ATTToolbar\ATTToolbar.dll (AT&T)
O2 - BHO: (Reg Error: Value error.) - {724d43a9-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\roboform.dll (Siber Systems Inc.)
O2 - BHO: (no name) - {8E5E2654-AD2D-48bf-AC2D-D17F00898D06} - No CLSID value found.
O2 - BHO: (AVG Security Toolbar) - {95B7759C-8C7F-4BF1-B163-73684A933233} - C:\Program Files\AVG Secure Search\11.1.0.12\AVG Secure Search_toolbar.dll ()
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.7.7227.1100\swg.dll (Google Inc.)
O2 - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre7\bin\jp2ssv.dll (Oracle Corporation)
O2 - BHO: (OToolbarHelper Class) - {EAD3A971-6A23-4246-8691-C9244E858967} - C:\Program Files\PayPal\PayPal Plug-In\PayPalHelper.dll ()
O2 - BHO: (Yontoo) - {FD72061E-9FDE-484D-A58A-0BAB4151CAD8} - C:\Program Files\Yontoo\YontooIEClient.dll (Yontoo LLC)
O3 - HKLM\..\Toolbar: (AT&&T Toolbar) - {4E7BD74F-2B8D-469E-94BE-FD60BB9AAE29} - C:\Program Files\ATTToolbar\ATTToolbar.dll (AT&T)
O3 - HKLM\..\Toolbar: (&RoboForm) - {724d43a0-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\roboform.dll (Siber Systems Inc.)
O3 - HKLM\..\Toolbar: (no name) - {8E5E2654-AD2D-48bf-AC2D-D17F00898D06} - No CLSID value found.
O3 - HKLM\..\Toolbar: (AVG Security Toolbar) - {95B7759C-8C7F-4BF1-B163-73684A933233} - C:\Program Files\AVG Secure Search\11.1.0.12\AVG Secure Search_toolbar.dll ()
O3 - HKLM\..\Toolbar: (PayPal Plug-In) - {DC0F2F93-27FA-4f84-ACAA-9416F90B9511} - C:\Program Files\PayPal\PayPal Plug-In\OToolbar.dll ()
O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (AT&&T Toolbar) - {4E7BD74F-2B8D-469E-94BE-FD60BB9AAE29} - C:\Program Files\ATTToolbar\ATTToolbar.dll (AT&T)
O3 - HKCU\..\Toolbar\WebBrowser: (&RoboForm) - {724D43A0-0D85-11D4-9908-00400523E39A} - C:\Program Files\Siber Systems\AI RoboForm\roboform.dll (Siber Systems Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O4 - HKLM..\Run: [@OnlineArmor GUI] C:\Program Files\Online Armor\OAui.exe (Emsi Software GmbH)
O4 - HKLM..\Run: [Adobe Photo Downloader] C:\Program Files\Adobe\Photoshop Album Starter Edition\3.2\Apps\apdproxy.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [APSDaemon] C:\Program Files\Common Files\Apple\Apple Application Support\APSDaemon.exe (Apple Inc.)
O4 - HKLM..\Run: [AudioDrvEmulator] C:\Program Files\Creative\Shared Files\Module Loader\DLLML.exe (Creative Technology Ltd.)
O4 - HKLM..\Run: [avast] C:\Program Files\AVAST Software\Avast\avastUI.exe (AVAST Software)
O4 - HKLM..\Run: [CTHelper] C:\WINDOWS\System32\CtHelper.exe (Creative Technology Ltd)
O4 - HKLM..\Run: [CTxfiHlp] C:\WINDOWS\System32\Ctxfihlp.exe (Creative Technology Ltd)
O4 - HKLM..\Run: [HP AutoIndexer] C:\Program Files\Hewlett-Packard\LaserJet All-in-one\hppautoindexer.exe File not found
O4 - HKLM..\Run: [HP SchedIndexer] C:\Program Files\Hewlett-Packard\LaserJet All-in-one\hppschedindexer.exe File not found
O4 - HKLM..\Run: [MicroBrew] C:\Program Files\Common Files\Bluebeam Software\Brewery\V45\Printer Support\MicroBrew2.exe (Bluebeam Software, Inc.)
O4 - HKLM..\Run: [PbAdminACAD] C:\Program Files\Bluebeam Software\Pushbutton PDF\PbMngr5.exe (Bluebeam Software, Inc.)
O4 - HKLM..\Run: [vProt] C:\Program Files\AVG Secure Search\vprot.exe ()
O4 - HKCU..\Run: [DriverMax] C:\Program Files\Innovative Solutions\DriverMax\drivermax.exe (Innovative Solutions)
O4 - HKCU..\Run: [DriverMax_RESTART] C:\Program Files\Innovative Solutions\DriverMax\drivermax.exe (Innovative Solutions)
O4 - HKCU..\Run: [RoboForm] C:\Program Files\Siber Systems\AI RoboForm\RoboTaskBarIcon.exe (Siber Systems)
O4 - HKCU..\Run: [Spotify Web Helper] C:\Documents and Settings\Owner\Application Data\Spotify\Data\SpotifyWebHelper.exe ()
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
O8 - Extra context menu item: Customize Menu - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComCustomizeIEMenu.html ()
O8 - Extra context menu item: Fill Forms - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComFillForms.html ()
O8 - Extra context menu item: RoboForm Toolbar - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
O8 - Extra context menu item: Save Forms - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComSavePass.html ()
O9 - Extra Button: Fill Forms - {320AF880-6646-11D3-ABEE-C5DBF3571F46} - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComFillForms.html ()
O9 - Extra 'Tools' menuitem : Fill Forms - {320AF880-6646-11D3-ABEE-C5DBF3571F46} - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComFillForms.html ()
O9 - Extra Button: Save - {320AF880-6646-11D3-ABEE-C5DBF3571F49} - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComSavePass.html ()
O9 - Extra 'Tools' menuitem : Save Forms - {320AF880-6646-11D3-ABEE-C5DBF3571F49} - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComSavePass.html ()
O9 - Extra Button: RoboForm - {724d43aa-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
O9 - Extra 'Tools' menuitem : RoboForm Toolbar - {724d43aa-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
O10 - Protocol_Catalog9\Catalog_Entries\000000000004 - C:\Program Files\Bonjour\mdnsNSP.dll File not found
O10 - Protocol_Catalog9\Catalog_Entries\000000000005 - C:\Program Files\Bonjour\mdnsNSP.dll File not found
O15 - HKCU\..Trusted Domains: intuit.com ([ttlc] https in Trusted sites)
O16 - DPF: {01113300-3E00-11D2-8470-0060089874ED} http://echat.bellsouth.net/sdccommon/download/tgctlcm.cab (Support.com Configuration Class)
O16 - DPF: {02BCC737-B171-4746-94C9-0D8A0B2C0089} http://office.microsoft.com/sites/production/ieawsdc32.cab (Microsoft Office Template and Media Control)
O16 - DPF: {03A89EFD-E023-8600-A22D-45F77558EB4C} https://content.ilinc.com/clientdownload/download/ilinci86.dll (ILINCInstall86 Class)
O16 - DPF: {10E0E75E-6701-4134-9D95-C0942ED1F1C8} http://www1.snapfish.com/SnapfishOutlookImport.cab (Snapfish Outlook Import ActiveX Control)
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} C:\Program Files\Yahoo!\Common\Yinsthelper.dll (Installation Support)
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} http://www1.snapfish.com/SnapfishActivia.cab (Snapfish Activia)
O16 - DPF: {49232000-16E4-426C-A231-62846947304B} https://wimpro.cce.hp.com/ChatEntry/downloads/sysinfo.cab (SysData Class)
O16 - DPF: {493ACF15-5CD9-4474-82A6-91670C3DD66E} http://www.linkedin.com/cab/LinkedInContactFinderControl.cab (LinkedIn ContactFinderControl)
O16 - DPF: {5D637FAD-E202-48D1-8F18-5B9C459BD1E3} http://www.evite.com/html/imageUpload/ImageUploader5.cab (Image Uploader Control)
O16 - DPF: {6C269571-C6D7-4818-BCA4-32A035E8C884} http://ccfiles.creative.com/Web/softwareupdate/su/ocx/15102/CTSUEng.cab (Creative Software AutoUpdate)
O16 - DPF: {6D2EF4B4-CB62-4C0B-85F3-B79C236D702C} http://www.facebook.com/controls/contactx.dll (ContactExtractor Class)
O16 - DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} http://download.eset.com/special/eos/OnlineScanner.cab (Reg Error: Key error.)
O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} http://upload.facebook.com/controls/2009.07.28_v5.5.8.1/FacebookPhotoUploader55.cab (Facebook Photo Uploader 5 Control)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.7.0/jinstall-1_7_0_01-windows-i586.cab (Java Plug-in 1.7.0_01)
O16 - DPF: {A1662FB6-39BE-41BB-ACDC-0448FB1B5817} http://images3.pnimedia.com/ProductAssets/costcous/activex/v3_0_0_5/PhotoCenter_ActiveX_Control.cab (Photo Upload Plugin Class)
O16 - DPF: {A796D216-2DE1-4EA8-BABB-FE6E7C959098} http://www.hp.com/cpso-support-new/SDD/hpsddObjSigned.cab (HPSDDX Class)
O16 - DPF: {B9940246-4344-4D1B-BD82-DBAF7E657FF9} http://telluridemountainproperties-east.viewnetcam.com:50000/SysCamInst.cab (AudioClient Control)
O16 - DPF: {CAFEEFAC-0017-0000-0001-ABCDEFFEDCBA} http://java.sun.com/update/1.7.0/jinstall-1_7_0_01-windows-i586.cab (Java Plug-in 1.7.0_01)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.7.0/jinstall-1_7_0_01-windows-i586.cab (Java Plug-in 1.7.0_01)
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab (Shockwave Flash Object)
O16 - DPF: {D4B68B83-8710-488B-A692-D74B50BA558E} http://ccfiles.creative.com/Web/softwareupdate/ocx/15113/CTPIDPDE.cab (Creative Software AutoUpdate Support Package 2)
O16 - DPF: {E06E2E99-0AA1-11D4-ABA6-0060082AA75C} https://redvector.webex.com/client/T27LB/training/ieatgpc.cab (GpcContainer Class)
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab (Reg Error: Key error.)
O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} http://ccfiles.creative.com/Web/softwareupdate/ocx/110926/CTPID.cab (Creative Software AutoUpdate Support Package)
O16 - DPF: Garmin Communicator Plug-In https://static.garmincdn.com/gcp/ie/2.9.3.0/GarminAxControl.CAB (Reg Error: Key error.)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.254
O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{F60DCFF1-1651-438B-B98E-C6DF61103019}: DhcpNameServer = 192.168.1.254
O18 - Protocol\Handler\viprotocol {B658800C-F66E-4EF3-AB85-6C0C227862A9} - C:\Program Files\Common Files\AVG Secure Search\ViProtocolInstaller\11.2.0\ViProtocol.dll ()
O20 - HKLM Winlogon: UserInit - (C:\WINDOWS\system32\userinit.exe) - C:\WINDOWS\system32\userinit.exe (Microsoft Corporation)
O24 - Desktop WallPaper: C:\Documents and Settings\Owner\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O24 - Desktop BackupWallPaper: C:\Documents and Settings\Owner\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O28 - HKLM ShellExecuteHooks: {091EB208-39DD-417D-A5DD-7E2C2D8FB9CB} - C:\Program Files\Windows Defender\MpShHook.dll (Microsoft Corporation)
O28 - HKLM ShellExecuteHooks: {4F07DA45-8170-4859-9B5F-037EF2970034} - C:\Program Files\Online Armor\oaevent.dll (Emsi Software GmbH)
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2008/03/24 18:04:19 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O34 - HKLM BootExecute: (autocheck autochk *)
O35 - HKCU\..exefile [open] -- "%1" %*
O37 - HKCU\...exe [@ = exefile] -- "%1" %*
O38 - SubSystems\\Windows: (ServerDll=winsrv:UserServerDllInitialization,3)
O38 - SubSystems\\Windows: (ServerDll=winsrv:ConServerDllInitialization,2)
[2012/07/08 10:24:47 | 000,595,968 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Owner\Desktop\OTL.exe
[2012/07/07 13:52:21 | 000,708,960 | ---- | C] (Kaspersky Lab) -- C:\Documents and Settings\Owner\Desktop\GetSystemInfo.exe
[2012/07/07 12:25:54 | 000,081,920 | ---- | C] (Windows (R) Codename Longhorn DDK provider) -- C:\WINDOWS\System32\drivers\NmPar.sys
[2012/07/07 12:20:52 | 000,016,000 | ---- | C] (SysNucleus) -- C:\WINDOWS\System32\drivers\udsstub.sys
[2012/07/07 12:08:46 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Owner\Local Settings\Application Data\Innovative Solutions
[2012/07/07 12:08:46 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\DriverMax
[2012/07/07 12:08:38 | 000,000,000 | ---D | C] -- C:\Program Files\Innovative Solutions
[2012/07/07 12:08:16 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Owner\Local Settings\Application Data\AVG Secure Search
[2012/07/07 12:07:53 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Owner\Application Data\AVG Secure Search
[2012/07/07 12:07:53 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\AVG Secure Search
[2012/07/07 12:07:45 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\AVG Secure Search
[2012/07/07 12:07:40 | 000,000,000 | ---D | C] -- C:\Program Files\AVG Secure Search
[2012/07/07 12:06:48 | 000,000,000 | -H-D | C] -- C:\Documents and Settings\All Users\Application Data\Common Files
[2012/06/29 14:53:59 | 000,000,000 | ---D | C] -- C:\Program Files\1ClickDownload
[2012/06/29 14:48:49 | 000,000,000 | ---D | C] -- C:\Program Files\Yontoo
[2012/06/29 14:48:45 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Tarma Installer
[2012/06/14 17:12:29 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\iTunes
[2012/06/14 17:11:37 | 000,000,000 | ---D | C] -- C:\Program Files\iPod
[2012/06/14 17:11:30 | 000,000,000 | ---D | C] -- C:\Program Files\iTunes
[2012/06/13 17:23:23 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\Moviemaker
[2012/06/13 17:03:17 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Owner\Local Settings\Application Data\WMTools Downloaded Files
[2012/07/08 10:33:50 | 000,000,422 | -H-- | M] () -- C:\WINDOWS\tasks\User_Feed_Synchronization-{3DB9A020-3481-434C-BCEC-AC02BC5A62CB}.job
[2012/07/08 10:33:00 | 000,000,830 | ---- | M] () -- C:\WINDOWS\tasks\Adobe Flash Player Updater.job
[2012/07/08 10:29:00 | 000,000,884 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2012/07/08 08:29:01 | 000,000,880 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2012/07/08 01:41:00 | 000,000,330 | -H-- | M] () -- C:\WINDOWS\tasks\MP Scheduled Scan.job
[2012/07/07 16:11:24 | 000,013,646 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2012/07/07 16:08:54 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2012/07/07 16:08:01 | 000,064,756 | ---- | M] () -- C:\WINDOWS\System32\DVCState-{00000005-00000000-00000001-00001102-00000005-002C1102}.rfx
[2012/07/07 16:08:01 | 000,054,724 | ---- | M] () -- C:\WINDOWS\System32\BMXStateBkp-{00000005-00000000-00000001-00001102-00000005-002C1102}.rfx
[2012/07/07 16:08:01 | 000,054,724 | ---- | M] () -- C:\WINDOWS\System32\BMXState-{00000005-00000000-00000001-00001102-00000005-002C1102}.rfx
[2012/07/07 16:08:01 | 000,001,080 | ---- | M] () -- C:\WINDOWS\System32\settingsbkup.sfm
[2012/07/07 16:08:01 | 000,001,080 | ---- | M] () -- C:\WINDOWS\System32\settings.sfm
[2012/07/07 14:02:43 | 000,785,121 | ---- | M] () -- C:\Documents and Settings\Owner\Desktop\GetSystemInfo_QUADCORE_Owner_2012_07_07_13_54_00.zip
[2012/07/07 13:52:35 | 000,708,960 | ---- | M] (Kaspersky Lab) -- C:\Documents and Settings\Owner\Desktop\GetSystemInfo.exe
[2012/07/07 13:27:00 | 000,000,868 | ---- | M] () -- C:\WINDOWS\tasks\Google Software Updater.job
[2012/07/07 12:22:19 | 000,475,714 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
[2012/07/07 12:22:19 | 000,077,716 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
[2012/07/07 12:08:46 | 000,000,887 | ---- | M] () -- C:\Documents and Settings\Owner\Desktop\DriverMax.lnk
[2012/07/06 14:07:58 | 000,309,992 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
[2012/07/06 14:01:38 | 003,153,920 | ---- | M] () -- C:\Documents and Settings\Owner\secsetup.sdb
[2012/06/30 15:19:20 | 000,000,116 | ---- | M] () -- C:\WINDOWS\NeroDigital.ini
[2012/06/30 08:31:06 | 000,001,813 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Google Chrome.lnk
[2012/06/29 14:46:59 | 000,279,008 | ---- | M] () -- C:\Documents and Settings\Owner\Desktop\LG_DVD_Writer_Solution_Power_DVD__PowerProducer__Nero_Express_Aruzeo.exe
[2012/06/29 14:02:09 | 000,237,732 | ---- | M] () -- C:\WINDOWS\hpwins20.dat
[2012/06/28 15:27:02 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
[2012/06/26 20:39:00 | 002,062,688 | ---- | M] () -- C:\Documents and Settings\Owner\My Documents\Mydogcantswim.wmv
[2012/06/25 17:16:00 | 003,709,593 | ---- | M] () -- C:\Documents and Settings\Owner\My Documents\Pool_party.wmv
[2012/06/22 09:33:00 | 003,641,344 | ---- | M] () -- C:\Documents and Settings\Owner\My Documents\New Obama Army Drill Team.wmv
[2012/06/20 14:01:00 | 002,013,507 | ---- | M] () -- C:\Documents and Settings\Owner\My Documents\Don't backtalk your Momma.wmv
[2012/06/18 14:21:13 | 000,870,128 | ---- | M] () -- C:\WINDOWS\System32\mcs.rma
[2012/06/18 14:21:13 | 000,000,004 | ---- | M] () -- C:\WINDOWS\System32\A18EBC
[2012/06/17 14:18:32 | 000,047,616 | ---- | M] () -- C:\Documents and Settings\Owner\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2012/06/15 11:08:00 | 005,782,903 | ---- | M] () -- C:\Documents and Settings\Owner\My Documents\ANGRY_BLACK_MAN.wmv
[2012/06/14 17:12:29 | 000,001,542 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\iTunes.lnk
[2012/06/14 03:06:08 | 000,001,374 | ---- | M] () -- C:\WINDOWS\imsins.BAK
[2012/07/07 13:55:46 | 000,785,121 | ---- | C] () -- C:\Documents and Settings\Owner\Desktop\GetSystemInfo_QUADCORE_Owner_2012_07_07_13_54_00.zip
[2012/07/07 12:08:46 | 000,000,887 | ---- | C] () -- C:\Documents and Settings\Owner\Desktop\DriverMax.lnk
[2012/07/06 13:28:54 | 003,153,920 | ---- | C] () -- C:\Documents and Settings\Owner\secsetup.sdb
[2012/06/29 14:46:50 | 000,279,008 | ---- | C] () -- C:\Documents and Settings\Owner\Desktop\LG_DVD_Writer_Solution_Power_DVD__PowerProducer__Nero_Express_Aruzeo.exe
[2012/06/26 20:39:00 | 002,062,688 | ---- | C] () -- C:\Documents and Settings\Owner\My Documents\Mydogcantswim.wmv
[2012/06/25 17:16:00 | 003,709,593 | ---- | C] () -- C:\Documents and Settings\Owner\My Documents\Pool_party.wmv
[2012/06/22 09:33:00 | 003,641,344 | ---- | C] () -- C:\Documents and Settings\Owner\My Documents\New Obama Army Drill Team.wmv
[2012/06/20 14:01:00 | 002,013,507 | ---- | C] () -- C:\Documents and Settings\Owner\My Documents\Don't backtalk your Momma.wmv
[2012/06/15 11:08:00 | 005,782,903 | ---- | C] () -- C:\Documents and Settings\Owner\My Documents\ANGRY_BLACK_MAN.wmv
[2012/06/14 17:12:29 | 000,001,542 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\iTunes.lnk
[2012/04/30 16:10:52 | 000,060,304 | ---- | C] () -- C:\Documents and Settings\Owner\g2mdlhlpx.exe
[2012/04/11 17:38:41 | 000,237,732 | ---- | C] () -- C:\WINDOWS\hpwins20.dat
[2012/04/11 17:38:41 | 000,001,678 | ---- | C] () -- C:\WINDOWS\hpwmdl20.dat
[2012/03/19 10:14:17 | 002,515,466 | ---- | C] () -- C:\Documents and Settings\LocalService\Local Settings\Application Data\WPFFontCache_v0400-S-1-5-21-823518204-2049760794-725345543-1003-0.dat
[2012/03/19 10:14:16 | 000,260,090 | ---- | C] () -- C:\Documents and Settings\LocalService\Local Settings\Application Data\WPFFontCache_v0400-System.dat
[2012/03/09 15:35:19 | 000,000,590 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\Microsoft.SqlServer.Compact.400.32.bc
[2012/02/16 00:19:20 | 000,003,072 | ---- | C] () -- C:\WINDOWS\System32\iacenc.dll
[2011/12/12 16:21:41 | 000,205,864 | ---- | C] () -- C:\WINDOWS\System32\drivers\OADriver.sys
[2011/12/12 16:21:41 | 000,040,296 | ---- | C] () -- C:\WINDOWS\System32\drivers\oahlp32.sys
[2011/11/27 18:42:41 | 000,000,112 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\18iMfb.dat
[2011/11/27 11:35:10 | 000,015,330 | -HS- | C] () -- C:\Documents and Settings\Owner\Local Settings\Application Data\1w15mg3p30e624
[2011/11/27 11:35:10 | 000,015,330 | -HS- | C] () -- C:\Documents and Settings\All Users\Application Data\1w15mg3p30e624
[2011/07/15 15:00:07 | 000,077,349 | ---- | C] () -- C:\WINDOWS\hpqins05.dat.temp
[2011/06/30 16:32:37 | 000,019,518 | ---- | C] () -- C:\WINDOWS\hpqins13.dat
[2011/06/14 12:55:59 | 000,237,689 | ---- | C] () -- C:\WINDOWS\hpwins20.dat.temp
[2011/06/14 12:55:58 | 000,001,678 | ---- | C] () -- C:\WINDOWS\hpwmdl20.dat.temp
[2011/04/02 12:37:32 | 000,000,000 | ---- | C] () -- C:\WINDOWS\hpqEmlSz.INI
[2010/12/09 08:38:52 | 000,000,664 | ---- | C] () -- C:\WINDOWS\System32\d3d9caps.dat
[2010/09/28 22:52:32 | 000,070,556 | -H-- | C] () -- C:\WINDOWS\System32\mlfcache.dat
[2008/08/26 17:56:07 | 000,000,000 | ---- | C] () -- C:\Documents and Settings\Owner\LOG
[2008/03/27 12:12:15 | 000,047,616 | ---- | C] () -- C:\Documents and Settings\Owner\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2008/03/26 15:01:19 | 000,000,128 | ---- | C] () -- C:\Documents and Settings\Owner\Local Settings\Application Data\fusioncache.dat
[2010/10/08 11:36:07 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\AIM
[2009/02/19 15:04:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Amazon
[2009/04/25 12:12:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\AT&T
[2009/07/16 15:29:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\ATTToolbar
[2008/09/03 14:59:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Autodesk
[2011/12/12 16:05:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\AVAST Software
[2012/07/07 12:11:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\AVG Secure Search
[2008/05/09 15:58:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\avg7
[2008/03/31 13:35:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Bluebeam Software
[2012/07/07 12:06:48 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\Common Files
[2008/03/26 10:36:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Eagle Point Software
[2011/12/12 17:15:08 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\OnlineArmor
[2012/01/07 16:44:30 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\PC Drivers HeadQuarters
[2008/03/28 10:37:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\RoboForm
[2012/06/29 14:48:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Tarma Installer
[2011/12/02 14:17:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\TEMP
[2010/01/04 13:32:03 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Viewpoint
[2009/07/20 13:37:14 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\WholeSecurity
[2012/01/05 21:05:22 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Yahoo
[2009/03/21 10:47:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{00D89592-F643-4D8D-8F0F-AFAE0F14D4C3}
[2010/05/08 12:29:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{429CAD59-35B1-4DBC-BB6D-1DB246563521}
[2009/10/10 18:04:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{755AC846-7372-4AC8-8550-C52491DAA8BD}
[2009/04/25 08:04:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
[2010/10/08 11:40:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\acccore
[2012/03/29 23:31:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\Amazon
[2009/04/25 12:12:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\AT&T
[2009/06/28 10:23:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\ATTToolbar
[2008/09/03 14:59:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\Autodesk
[2009/03/30 12:23:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\AutoSync for Yahoo
[2012/07/07 12:07:53 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\AVG Secure Search
[2008/05/09 15:57:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\AVG7
[2010/04/08 13:31:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\com.adobe.px.Uploader.4C35C4D325D350FE0114230CBADCA2DDD0AC8D25.1
[2011/09/19 20:42:44 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\com.pandora.desktop.FB9956FD96E03239939108614098AD95535EE674.1
[2010/01/06 10:35:03 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\eMusic
[2010/04/12 20:39:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\Facebook
[2011/01/27 17:29:49 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\GARMIN
[2009/05/12 13:04:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\GoodSync
[2008/03/31 11:31:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\Leadertech
[2008/09/18 11:32:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\MyPublisher
[2011/12/12 16:22:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\OnlineArmor
[2009/03/30 12:23:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\PushSyncData
[2008/05/08 17:51:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\Snapfish
[2012/06/18 11:22:08 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\Spotify
[2008/04/22 09:02:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\Uniblue
[2010/01/04 13:22:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\uTorrent
[2010/10/21 13:55:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Owner\Application Data\webex
[2012/07/08 01:41:00 | 000,000,330 | -H-- | M] () -- C:\WINDOWS\Tasks\MP Scheduled Scan.job
[2012/07/08 10:33:50 | 000,000,422 | -H-- | M] () -- C:\WINDOWS\Tasks\User_Feed_Synchronization-{3DB9A020-3481-434C-BCEC-AC02BC5A62CB}.job
@Alternate Data Stream - 109 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:DFC5A2B2
pointman
Posts Posts : 95
Joined Joined : 2010-01-02
OS OS : windows XP
Points Points : 26551
Re: LG DVD Player and HP Printer do not work properly after Virus
Post by Dr Jay on Mon Jul 09, 2012 9:39 pm
OTL Fix
Please run OTL
  • Under the Custom Scans/Fixes box at the bottom, copy and paste in the following:
    :OTL
    :commands
    [emptytemp]
    [reboot]
  • Then click the Run Fix button at the top.
  • Note: The fix for OTL automatically hides your Desktop and Start menu so the fix can be completed. Do not be alerted, this is normal.
  • Please do not exit the program. It might take a while to fix, but allow it to run. If it asks to reboot the computer, allow it to reboot. If the program freezes, and the computer fails to reboot - let me know.
    Lastly, post the contents of the log. (Located at C:\_OTL\Moved Files)
MS-Tool Diagnostic
Go to this page, and click on the Run now button: http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
It will run a diagnostic to tell you why you cannot play media, etc.
Posts Posts : 13713
Points Points : 302059
Post by pointman on Tue Jul 10, 2012 3:19 am
The program did freeze and failed to reboot. I did manual reboot. I will wait to hear from you before I run the MS- Tool.
All processes killed
========== OTL ==========
Error: No service named 196415 was found to stop!
Registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\196415 deleted successfully.
File globalroot\C:\WINDOWS\system32\drivers\196415.sys not found.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\\DefaultScope| /E : value set successfully!
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\\DefaultScope| /E : value set successfully!
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{95B7759C-8C7F-4BF1-B163-73684A933233}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{95B7759C-8C7F-4BF1-B163-73684A933233}\ not found.
ADS C:\Documents and Settings\All Users\Application Data\TEMP:DFC5A2B2 deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Internet Explorer\Restrictions\ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\HonorAutoRunSetting deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoDriveAutoRun deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoDriveTypeAutoRun deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoDrives deleted successfully.
Registry key HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Control Panel\ deleted successfully.
Registry value HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoDriveTypeAutoRun deleted successfully.
Registry value HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoDriveAutoRun deleted successfully.
Registry value HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoDrives deleted successfully.
[EMPTYTEMP]
User: All Users
User: Default User
->Temporary Internet Files folder emptied: 33170 bytes
->Flash cache emptied: 56468 bytes
User: Dummy
->Temporary Internet Files folder emptied: 67 bytes
User: LocalService
->Temp folder emptied: 66016 bytes
->Temporary Internet Files folder emptied: 32902 bytes
->Java cache emptied: 0 bytes
User: NetworkService
->Temp folder emptied: 173160 bytes
->Temporary Internet Files folder emptied: 52047894 bytes
->Java cache emptied: 12054 bytes
->Flash cache emptied: 45084 bytes
User: New Folder
User: Owner
->Temp folder emptied: 5037301401 bytes
->Temporary Internet Files folder emptied: 239129833 bytes
->Java cache emptied: 64305 bytes
->FireFox cache emptied: 57642799 bytes
->Google Chrome cache emptied: 92430081 bytes
->Apple Safari cache emptied: 0 bytes
->Flash cache emptied: 59693 bytes
%systemroot% .tmp files removed: 0 bytes
Windows Temp folder emptied: 138675748 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 228544804 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
RecycleBin emptied: 1756665371 bytes
Total Files Cleaned = 7,251.00 mb
OTL by OldTimer - Version 3.2.53.1 log created on 07092012_224616
pointman
Posts Posts : 95
OS OS : windows XP
Post by pointman on Tue Jul 10, 2012 3:35 am
I did not send the extras file from the OTL initial scan. Just in case you need it.
OTL Extras logfile created on: 7/8/2012 10:32:50 AM - Run 1
OTL by OldTimer - Version 3.2.53.1 Folder = C:\Documents and Settings\Owner\Desktop
Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
3.00 Gb Total Physical Memory | 2.31 Gb Available Physical Memory | 77.13% Memory free
4.84 Gb Paging File | 4.23 Gb Available in Paging File | 87.36% Paging File free
Paging file location(s): C:\pagefile.sys 2046 4092 [binary data]
Drive C: | 298.08 Gb Total Space | 146.41 Gb Free Space | 49.12% Space Free | Partition Type: NTFS
Computer Name: QUADCORE | User Name: Owner | Logged in as Administrator.
Boot Mode: Normal | Scan Mode: Current user | Quick Scan
Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
.cpl [@ = cplfile] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
.url [@ = InternetShortcut] -- rundll32.exe ieframe.dll,OpenURL %l
.html [@ = htmlfile] -- Reg Error: Key error. File not found
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
cplfile [cplopen] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
InternetShortcut [open] -- rundll32.exe ieframe.dll,OpenURL %l
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
Directory [AddToPlaylistVLC] -- "C:\Program Files\VideoLAN\VLC\vlc.exe" --started-from-file --playlist-enqueue "%1" ()
Directory [PlayWithVLC] -- "C:\Program Files\VideoLAN\VLC\vlc.exe" --started-from-file --no-playlist-enqueue "%1" ()
Directory [Print_Directory_Listing] -- Printdir.bat "%1" ()
"FirstRunDisabled" = 1
"UpdatesDisableNotify" = 0
"AntiVirusOverride" = 1
"FirewallOverride" = 1
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"DisableMonitoring" = 1
"DisableSR" = 0
"Start" = 4
"Start" = 2
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
"DisableNotifications" = 1
"EnableFirewall" = 0
"DoNotAllowExceptions" = 0
"139:TCP" = 139:TCP:*:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:*:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:*:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:*:Enabled:@xpsp2res.dll,-22002
"1900:UDP" = 1900:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22007
"2869:TCP" = 2869:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22008
"139:TCP" = 139:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22002
"C:\Program Files\HP\Digital Imaging\bin\hpofxm08.exe" = C:\Program Files\HP\Digital Imaging\bin\hpofxm08.exe:*:Enabled:hpofxm08.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hposfx08.exe" = C:\Program Files\HP\Digital Imaging\bin\hposfx08.exe:*:Enabled:hposfx08.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hposid01.exe" = C:\Program Files\HP\Digital Imaging\bin\hposid01.exe:*:Enabled:hposid01.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpfcCopy.exe" = C:\Program Files\HP\Digital Imaging\bin\hpfcCopy.exe:*:Enabled:hpfccopy.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpzwiz01.exe" = C:\Program Files\HP\Digital Imaging\bin\hpzwiz01.exe:*:Enabled:hpzwiz01.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpoews01.exe" = C:\Program Files\HP\Digital Imaging\bin\hpoews01.exe:*:Enabled:hpoews01.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpiscnapp.exe" = C:\Program Files\HP\Digital Imaging\bin\hpiscnapp.exe:*:Enabled:hpiscnapp.exe -- (Hewlett-Packard Co.)
"C:\Program Files\Common Files\HP\Digital Imaging\bin\hpqPhotoCrm.exe" = C:\Program Files\Common Files\HP\Digital Imaging\bin\hpqPhotoCrm.exe:*:Enabled:hpqphotocrm.exe -- (Hewlett-Packard Development Co. L.P.)
"C:\Program Files\HP\Digital Imaging\bin\hpqsudi.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqsudi.exe:*:Enabled:hpqsudi.exe -- (Hewlett-Packard Development Co. L.P.)
"C:\Program Files\HP\Digital Imaging\bin\hpqpsapp.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqpsapp.exe:*:Enabled:hpqpsapp.exe -- (Hewlett-Packard Development Co. L.P.)
"C:\Program Files\HP\Digital Imaging\bin\hpofxs08.exe" = C:\Program Files\HP\Digital Imaging\bin\hpofxs08.exe:*:Enabled:hpofxs08.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpqfxt08.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqfxt08.exe:*:Enabled:hpqfxt08.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpqpse.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqpse.exe:*:Enabled:hpqpse.exe -- (Hewlett-Packard Development Co. L.P.)
"C:\Program Files\HP\Digital Imaging\bin\hpqgplgtupl.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqgplgtupl.exe:*:Enabled:hpqgplgtupl.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpqusgm.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqusgm.exe:*:Enabled:hpqusgm.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\Digital Imaging\bin\hpqusgh.exe" = C:\Program Files\HP\Digital Imaging\bin\hpqusgh.exe:*:Enabled:hpqusgh.exe -- (Hewlett-Packard Co.)
"C:\Program Files\HP\HP Software Update\hpwucli.exe" = C:\Program Files\HP\HP Software Update\hpwucli.exe:*:Enabled:hpwucli.exe -- (Hewlett-Packard)
"C:\Program Files\HP\Digital Imaging\Smart Web Printing\SmartWebPrintExe.exe" = C:\Program Files\HP\Digital Imaging\Smart Web Printing\SmartWebPrintExe.exe:*:Enabled:smartwebprintexe.exe -- (Hewlett-Packard Co.)
"C:\Program Files\Yahoo!\Yahoo! Music Engine\YahooMusicEngine.exe" = C:\Program Files\Yahoo!\Yahoo! Music Engine\YahooMusicEngine.exe:*:Enabled:Yahoo! Music Engine
"C:\Program Files\TurboTax\Home & Business 2007\32bit\ttax.exe" = C:\Program Files\TurboTax\Home & Business 2007\32bit\ttax.exe:LocalSubNet:Enabled:TurboTax -- (Intuit, Inc.)
"C:\Program Files\TurboTax\Home & Business 2007\32bit\updatemgr.exe" = C:\Program Files\TurboTax\Home & Business 2007\32bit\updatemgr.exe:LocalSubNet:Enabled:TurboTax Update Manager -- (Intuit, Inc.)
"C:\Program Files\TurboTax\Business 2007\32bit\ttax.exe" = C:\Program Files\TurboTax\Business 2007\32bit\ttax.exe:LocalSubNet:Enabled:TurboTax -- (Intuit, Inc.)
"C:\Program Files\TurboTax\Business 2007\32bit\updatemgr.exe" = C:\Program Files\TurboTax\Business 2007\32bit\updatemgr.exe:LocalSubNet:Enabled:TurboTax Update Manager -- (Intuit, Inc.)
"C:\Program Files\TurboTax\Deluxe 2007\32bit\ttax.exe" = C:\Program Files\TurboTax\Deluxe 2007\32bit\ttax.exe:LocalSubNet:Enabled:TurboTax -- (Intuit, Inc.)
"C:\Program Files\TurboTax\Deluxe 2007\32bit\updatemgr.exe" = C:\Program Files\TurboTax\Deluxe 2007\32bit\updatemgr.exe:LocalSubNet:Enabled:TurboTax Update Manager -- (Intuit, Inc.)
"C:\Program Files\Common Files\AOL\Loader\aolload.exe" = C:\Program Files\Common Files\AOL\Loader\aolload.exe:*:Enabled:AOL Loader -- (AOL Inc.)
"C:\Program Files\ATT-HSI\McciBrowser.exe" = C:\Program Files\ATT-HSI\McciBrowser.exe:*:Enabled:motivebrowser.exe -- (Motive Communications, Inc.)
"C:\Program Files\Common Files\Motive\McciServiceHost.exe" = C:\Program Files\Common Files\Motive\McciServiceHost.exe:*:Enabled:McciServiceHost -- (Alcatel-Lucent)
"C:\Program Files\Rhapsody\rhapsody.exe" = C:\Program Files\Rhapsody\rhapsody.exe:*:Enabled:RealNetworks Rhapsody -- (Rhapsody International Inc.)
"C:\Program Files\AIM\aim.exe" = C:\Program Files\AIM\aim.exe:*:Enabled:AIM -- (AOL Inc.)
"C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe" = C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe:LocalSubNet:Disabled:Intuit Update Shared Downloads Server -- (Intuit Inc.)
"C:\Program Files\Common Files\Intuit\Update Service v4\IntuitUpdateService.exe" = C:\Program Files\Common Files\Intuit\Update Service v4\IntuitUpdateService.exe:LocalSubNet:Disabled:Intuit Update v4 Shared Downloads Server -- (Intuit Inc.)
"C:\Documents and Settings\Owner\Local Settings\temp\7zS6468\HPDiagnosticCoreUI.exe" = C:\Documents and Settings\Owner\Local Settings\temp\7zS6468\HPDiagnosticCoreUI.exe:*:Enabled:HPSAPS -- (Hewlett-Packard)
"C:\Documents and Settings\Owner\Local Settings\temp\7zS0E31\HPDiagnosticCoreUI.exe" = C:\Documents and Settings\Owner\Local Settings\temp\7zS0E31\HPDiagnosticCoreUI.exe:*:Enabled:HPSAPS -- (Hewlett-Packard)
"C:\Documents and Settings\Owner\Application Data\Spotify\spotify.exe" = C:\Documents and Settings\Owner\Application Data\Spotify\spotify.exe:*:Enabled:Spotify -- (Spotify Ltd)
"C:\Program Files\Common Files\Apple\Apple Application Support\WebKit2WebProcess.exe" = C:\Program Files\Common Files\Apple\Apple Application Support\WebKit2WebProcess.exe:*:Enabled:WebKit -- (Apple Inc.)
"{05BDC796-3451-4F81-B91D-E98F7ADA76C2}" = TurboTax 2010 WinPerTaxSupport
"{06A1D88C-E102-4527-AF70-29FFD7AF215A}" = Scan
"{06E6E30D-B498-442F-A943-07DE41D7F785}" = Microsoft Search Enhancement Pack
"{08234a0d-cf39-4dca-99f0-0c5cb496da81}" = Bing Bar
"{0840B4D6-7DD1-4187-8523-E6FC0007EFB7}" = Windows Live ID Sign-in Assistant
"{097CDB1E-07C9-40F1-9972-F0F9F3A287E4}" = Network
"{0E64B098-8018-4256-BA23-C316A43AD9B0}" = QuickTime
"{105CFC7C-6992-11D5-BD9D-000102C10FD8}" = Lizardtech DjVu Control
"{117F771F-EA62-437B-AA3C-65F77B1E4C63}" = AT&T Quick Fix Client
"{122ADF8C-DDA1-480C-9936-C88F2825B265}" = Apple Application Support
"{14374622-0900-4056-BA06-C87C900AF9E6}" = QuickBooks Pro 2005
"{1458BB78-1DC5-4BC0-B9A3-2B644F5A8105}" = DeviceDiscovery
"{150B6201-E9E6-4DFB-960E-CCBD53FBDDED}" = HPProductAssistant
"{180D45DA-5140-48D4-BDEA-8B9CE3A6D9A4}" = TurboTax 2008 WinBizTaxSupport
"{18F11181-EA1A-42AE-AF89-4867C7F7A6FA}" = Sound Blaster X-Fi
"{1EBB57D4-63FF-87CC-A0F0-D73982CF6008}" = Adobe Media Player
"{1F698102-5739-441E-96F0-74F4EA540F06}" = Attansic Ethernet Utility
"{26A24AE4-039D-4CA4-87B4-2F83217001FF}" = Java(TM) 7 Update 1
"{292F0F52-B62D-4E71-921B-89A682402201}" = Toolbox
"{293B2D75-5735-4DFE-8642-F0EDEE9EB064}" = TurboTax 2010 wgaiper
"{29521505-F489-4822-ADFA-32C6DEE4F114}" = TurboTax 2008 WinPerUserEducation
"{2CD6BBA0-17C8-4789-9B9B-B36F7E815F6A}" = DWG TrueView 2007
"{2DFF31F9-7893-4922-AF66-C9A1EB4EBB31}" = Rhapsody Player Engine
"{2EFA4E4C-7B5F-48F7-A1C0-1AA882B7A9C3}" = HP Update
"{302BF4A9-0AEB-41A6-8838-A9497F07B508}" = The Options Toolbox v5.0
"{3700194C-C5DD-439A-BE06-A66960CA4C70}" = MSVCSetup
"{374256A0-EAA2-012B-AD60-000000000000}" = TurboTax 2009 wgaiper
"{3782EC09-4000-475E-8A59-9CABD6F03B4C}" = TurboTax 2010 WinPerFedFormset
"{3881DB80-EAA2-012B-ADAE-000000000000}" = TurboTax 2009 WinPerFedFormset
"{38975F50-EAA2-012B-ADB4-000000000000}" = TurboTax 2009 WinPerReleaseEngine
"{38A34630-EAA2-012B-ADB6-000000000000}" = TurboTax 2009 WinPerTaxSupport
"{3A1B5D40-41E9-43FA-8C7B-A8667F5586EF}" = JMB36X Raid Configurer
"{3C3901C5-3455-3E0A-A214-0B093A5070A6}" = Microsoft .NET Framework 4 Client Profile
"{3C5A81D0-EAA2-012B-AE9F-000000000000}" = TurboTax 2009 wrapper
"{4945F319-A24D-454C-A411-F3689987315D}" = HP OfficeJet J4600 All-In-One Series
"{4AEBD86C-C82E-401A-9AA0-8B8AF7A5A3CA}" = TurboTax 2008 WinBizFedFormset
"{4F2FCCCF-29F3-44B9-886F-6D16F8417522}" = TurboTax 2010 wrapper
"{4F7177E9-2B54-48B4-AAFD-03FA1F87A542}" = Bing Bar Platform
"{5545EEE1-FA36-4F76-B6BE-5696E7F4E2D6}" = VBA (2627.01)
"{56D4C8A0-6126-11DD-AD8B-0800200C9A66}" = TurboTax 2008 WinBizUserEducation
"{5783F2D7-4001-0409-0002-0060B0CE6BBA}" = AutoCAD 2006 - English
"{5783F2D7-6000-0409-0002-0060B0CE6BBA}" = AutoCAD Civil 3D 2008
"{596ECF31-381D-406D-9C22-6B805C3D7A8F}" = TurboTax 2011 wgaiper
"{5A3C1721-F8ED-11E0-8AFB-B8AC6F97B88E}" = Google Earth
"{5B025634-7D5B-4B8D-BE2A-7943C1CF2D5D}" = Status
"{5BB4D7C1-52F2-4BFD-9E40-0D419E2E3021}" = bpd_scan
"{5E1FABE9-AE91-4C7F-B10E-083A7FD54E9A}" = Hydraflow Hydrographs 2004
"{681B698F-C997-42C3-B184-B489C6CA24C9}" = HPPhotoSmartDiscLabelContent1
"{6AD9F5F3-5BD0-4000-BD9C-B536CF86D988}" = iTunes
"{6F340107-F9AA-47C6-B54C-C3A19F11553F}" = Hewlett-Packard ACLM.NET v1.1.0.0
"{710BF966-43C8-4216-A8EC-BC4E169FF7C1}" = MobileMe Control Panel
"{73317C31-2B6E-4B88-9865-B97C1331A39D}" = PayPal Plug-In
"{7570F1CA-016D-46AC-B586-CD74645EFB52}" = TurboTax 2008 WinPerFedFormset
"{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}" = Apple Software Update
"{79155F2B-9895-49D7-8612-D92580E0DE5B}" = Bonjour
"{7CCEBC24-62DB-4280-A8EC-BFA49F167920}" = Software Update for Web Folders
"{7DD9A065-2C86-4A9F-A5FF-796EC1B99DCA}" = AnswerWorks 4.0 Runtime - English
"{81D049A4-E8C6-49FC-995D-C25181C15C14}" = Bluebeam PDF Revu v4.7.1
"{846B5DED-DC8C-4E1A-B5B4-9F5B39A0CACE}" = HPDiagnosticAlert
"{84F1DE76-C48C-4281-87A0-CC9548D1E7F9}" = Rhapsody Player Engine
"{86CE85E6-DBAC-3FFD-B977-E4B79F83C909}" = Microsoft Visual C++ 2008 Redistributable - KB2467174 - x86 9.0.30729.5570
"{88214092-836F-4E22-A5AC-569AC9EE6A0F}" = TurboTax 2008 WinPerReleaseEngine
"{889DF117-14D1-44EE-9F31-C5FB5D47F68B}" = Yontoo 1.10.02
"{8EE94FD8-5F52-4463-A340-185D16328158}" = WebReg
"{8F1ADE4D-EFAC-4F5A-B346-23C2687FAF50}" = Apple Mobile Device Support
"{8FF6F5CA-4E30-4E3B-B951-204CAAA2716A}" = SmartWebPrinting
"{91110409-6000-11D3-8CFE-0050048383C9}" = Microsoft Office XP Professional
"{9294F169-72EE-4D74-AE92-CA25F64B4FF8}" = Fax
"{92A51949-EE4C-466D-AAF0-99E74A49A63F}" = DocMgr
"{988B65CC-416C-43A6-9BE7-187415D77BF4}" = TurboTax 2008 wgasbpm
"{98B672F2-857C-4CC9-A25D-6B218077F4F6}" = Yahoo! Autosync
"{9B362566-EC1B-4700-BB9C-EC661BDE2175}" = DocProc
"{9BE518E6-ECC6-35A9-88E4-87755C07200F}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
"{9DF0BE48-16F0-4E36-814D-9B4FDFFAF25F}" = PayPal Plug-In
"{9E5A03E3-6246-4920-9630-0527D5DA9B07}" = AnswerWorks 5.0 English Runtime
"{A02A2C67-9079-11D3-80EB-00C04F2CB01C}" = Eagle Point
"{A06275F4-324B-4E85-95E6-87B2CD729401}" = Windows Defender
"{A436F67F-687E-4736-BD2B-537121A804CF}" = HP Product Detection
"{A525E00B-6609-442E-9DCD-64453C233E8D}" = TurboTax 2010 WinPerReleaseEngine
"{A654A805-41D9-40C7-AA46-4AF04F044D61}" = Adobe® Photoshop® Album Starter Edition 3.2
"{A80FA752-C491-4ED9-ABF0-4278563160B2}" = 32 Bit HP CIO Components Installer
"{AC35A885-0F8F-4857-B7DA-6E8DFB43E6B3}" = HPSSupply
"{AC76BA86-7AD7-1033-7B44-AA1000000001}" = Adobe Reader X (10.1.3)
"{AC76BA86-7AD7-5464-3428-800000000003}" = Spelling Dictionaries Support For Adobe Reader 8
"{AEB9948B-4FF2-47C9-990E-47014492A0FE}" = MSXML 6.0 Parser
"{B1102A25-3AA3-446B-AA0F-A699B07A02FD}" = Garmin USB Drivers
"{B1DB1AD8-C07E-4052-81A1-D2930232BA70}" = TurboTax 2008 wrapper
"{B23726CF-68BF-41A6-A4EB-72F12F87FE05}" = TurboTax 2008 WinPerTaxSupport
"{B26B00DA-2E5D-4CF2-83C5-911198C0F009}" = GoodSync
"{B4FEA924-630D-11D4-B78E-005004566E4D}" = ViewSonic Monitor Drivers
"{B629CD93-A629-4A9F-8B6E-218E741A316E}" = BPDSoftware_Ini
"{B6C2466E-D773-4EF5-9350-9D3D68F668BE}" = TurboTax 2008 WinBizProgramHelp
"{B95B1BA9-F887-4B3C-8D3A-CCD4C4675120}" = Microsoft Default Manager
"{BB3447F6-9553-4AA9-960E-0DB5310C5779}" = GPBaseService2
"{BC5DD87B-0143-4D14-AAE6-97109614DC6B}" = SolutionCenter
"{BD7204BA-DD64-499E-9B55-6A282CDF4FA4}" = Destinations
"{BEEFC4F8-2909-48B3-AFAA-55D3533FDEDD}" = Creative MediaSource 5
"{C779648B-410E-4BBA-B75B-5815BCEFE71D}" = Safari
"{CAF5B770-082F-40C4-853D-3973BB81BDAA}" = TurboTax 2011 WinPerTaxSupport
"{CCF6F57B-F6B4-4508-BF45-63AAC9DE416A}" = Quicken 2010
"{CCFFC1DA-7A65-4C1B-98DC-3F7861F50254}" = TurboTax 2008 wrapper
"{CD31E63D-47FD-491C-8117-CF201D0AFAB5}" = TrayApp
"{CDEFD989-469E-421D-A8B1-EC7AB25C8CB2}" = TurboTax 2008 wgaiper
"{D360FA88-17C8-4F14-B67F-13AAF9607B12}" = MarketResearch
"{D79113E7-274C-470B-BD46-01B10219DF6A}" = HPPhotosmartEssential
"{DBCC73BA-C69A-4BF5-B4BF-F07501EE7039}" = AnswerWorks 5.0 English Runtime
"{DC3065BF-95B4-42C5-B47D-0B713CDA75D0}" = Creative Zen Vision M
"{DCE9C52A-95DD-4075-9FC6-3313FB8748A5}" = BPDSoftware
"{E031338C-839D-4EDD-9537-99B653C39D81}" = Autodesk MapGuide(R) Viewer ActiveX Control Release 6.5
"{E3E3C2C5-B78F-560D-01C0-A9F11945D17B}" = Pandora
"{E3E71D07-CD27-46CB-8448-16D4FB29AA13}" = Microsoft WSE 3.0 Runtime
"{E463E171-4082-4744-A466-F7CBE8502789}" = TurboTax 2011 WinPerReleaseEngine
"{E55B00B0-9DBF-4EE1-AC1D-5DEBE12BD097}" = Autodesk Vault 2008
"{E6D9BC25-0DBC-4368-8E4A-7DEE80661CD9}" = TurboTax 2008 WinPerProgramHelp
"{EC6DE9B9-B599-3DCF-A47E-64322198B31C}" = Adobe Photoshop.com Uploader
"{EE556A3E-EB37-4392-9637-BAA8EC2F47FA}" = TurboTax 2011 wrapper
"{EFF87108-C9D0-43F1-BEE1-28DA87778F1A}" = Garmin Communicator Plugin
"{F8D8A515-3D81-431D-BCBB-9EBA3CFE0987}" = TurboTax 2008 WinBizReleaseEngine
"{FA0FF682-CC70-4C57-93CD-E276F3E7537E}" = BufferChm
"{FACF203E-0F4D-489A-B80C-D185253C8FCB}" = Autodesk Design Review 2008
"{FAD3D68B-2F9C-459B-AA79-C04B9090FD72}" = TurboTax 2011 WinPerFedFormset
"{FC47C7A5-BE63-11D5-B7C9-005004566E4D}" = ViewSonic Windows XP Signed Files
"{FDB3B167-F4FA-461D-976F-286304A57B2A}" = Adobe AIR
"1ClickDownload" = 1ClickDownloader
"45A7283175C62FAC673F913C1F532C5361F97841" = Windows Driver Package - Garmin (grmnusb) GARMIN Devices (03/08/2007 2.2.1.0)
"ActiveTouchMeetingClient" = WebEx
"Adobe Acrobat 4.0" = Adobe Acrobat 4.0
"Adobe AIR" = Adobe AIR
"Adobe Flash Player ActiveX" = Adobe Flash Player 11 ActiveX
"Adobe Flash Player Plugin" = Adobe Flash Player 11 Plugin
"Adobe® Photoshop® Album Starter Edition 3.2" = Adobe® Photoshop® Album Starter Edition 3.2
"AI RoboForm" = AI RoboForm (All Users)
"AIM_7" = AIM 7
"Amazon Games & Software Downloader_is1" = Amazon Games & Software Downloader
"Amazon MP3 Downloader" = Amazon MP3 Downloader 1.0.15
"AT&T Wireless Connection Tool" = AT&T Wireless Connection Tool
"AtcL1" = Attansic L1 Gigabit Ethernet Driver
"ATT-SST" = AT&T Self Support Tool
"ATTToolbar" = AT&T Toolbar
"Audacity_is1" = Audacity 1.2.6
"Audit Support Center" = Audit Support Center 1.0
"AutoCAD Civil 3D 2008" = AutoCAD Civil 3D 2008
"Autodesk DWF Viewer" = Autodesk DWF Viewer
"Autodesk Vault 2008" = Autodesk Vault 2008
"avast" = avast! Free Antivirus
"AVG Secure Search" = AVG Security Toolbar
"CAL" = Canon Camera Access Library
"CameraWindowDVC5" = Canon Camera Window DC_DV 5 for ZoomBrowser EX
"CameraWindowDVC6" = Canon Camera Window DC_DV 6 for ZoomBrowser EX
"CameraWindowMC" = Canon Camera Window MC 6 for ZoomBrowser EX
"Canon G.726 WMP-Decoder" = Canon G.726 WMP-Decoder
"com.adobe.amp.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1" = Adobe Media Player
"com.adobe.px.Uploader.4C35C4D325D350FE0114230CBADCA2DDD0AC8D25.1" = Adobe Photoshop.com Uploader
"com.pandora.desktop.FB9956FD96E03239939108614098AD95535EE674.1" = Pandora
"Coupon Printer for Windows5.0.0.1" = Coupon Printer for Windows
"Creative Removable Disk Manager" = Creative Removable Disk Manager
"Creative Software AutoUpdate" = Creative Software AutoUpdate
"CSCLIB" = Canon Camera Support Core Library
"CyberPower PowerPanel" = PowerPanel
"DMX5_is1" = DriverMax 6
"eMusic Download Manager" = eMusic Download Manager 4.1.3.1
"EOS Utility" = Canon Utilities EOS Utility
"Google Chrome" = Google Chrome
"Google Updater" = Google Updater
"HP Document Manager" = HP Document Manager 2.0
"HP Imaging Device Functions" = HP Imaging Device Functions 14.0
"HP Photosmart Essential" = HP Photosmart Essential 3.5
"HP Smart Web Printing" = HP Smart Web Printing 4.60
"HP Solution Center & Imaging Support Tools" = HP Solution Center 14.0
"HPExtendedCapabilities" = HP Customer Participation Program 14.0
"HPOCR" = OCR Software by I.R.I.S. 14.0
"InstallShield_{81D049A4-E8C6-49FC-995D-C25181C15C14}" = Bluebeam PDF Revu v4.7.1
"MosChip Technology" = MosChip Multi-IO Controller
"MovieEditTask" = Canon MovieEdit Task for ZoomBrowser EX
"Mozilla Firefox 11.0 (x86 en-US)" = Mozilla Firefox 11.0 (x86 en-US)
"MyPublisher" = MyPublisher
"NeroMultiInstaller!UninstallKey" = Nero Suite
"NetMos Technology" = NetMos Multi-IO Controller
"NVIDIA Drivers" = NVIDIA Drivers
"OnlineArmor_is1" = Online Armor 5.1
"PhotoStitch" = Canon Utilities PhotoStitch
"RAW Image Task" = Canon RAW Image Task for ZoomBrowser EX
"RemoteCaptureTask" = Canon RemoteCapture Task for ZoomBrowser EX
"Revo Uninstaller" = Revo Uninstaller 1.92
"Rhapsody" = Rhapsody
"Shop for HP Supplies" = Shop for HP Supplies
"SoftwareUpdUtility" = Download Updater (AOL LLC)
"SysInfo" = Creative System Information
"TurboTax 2008" = TurboTax 2008
"TurboTax 2009" = TurboTax 2009
"TurboTax 2010" = TurboTax 2010
"TurboTax 2011" = TurboTax 2011
"TurboTax Business 2007" = TurboTax Business 2007
"TurboTax Business 2008" = TurboTax Business 2008
"TurboTax Deluxe 2007" = TurboTax Deluxe 2007
"TurboTax Home & Business 2007" = TurboTax Home & Business 2007
"VLC media player" = VLC media player 1.1.11
"Yahoo! Companion" = Yahoo! Toolbar
"Yahoo! Toolbar" = Yahoo! Toolbar
"ZoomBrowser EX" = Canon Utilities ZoomBrowser EX
"f031ef6ac137efc5" = Dell Driver Download Manager
"Facebook Plug-In" = Facebook Plug-In
"GoToMeeting" = GoToMeeting 5.1.0.880
"Move Networks Player - IE" = Move Networks Media Player for Internet Explorer
"Spotify" = Spotify
========== Last 20 Event Log Errors ==========
[ Application Events ]
Error - 6/13/2012 9:16:40 PM | Computer Name = QUADCORE | Source = Application Hang | ID = 1002
Description = Hanging application iexplore.exe, version 8.0.6001.18702, hang module
hungapp, version 0.0.0.0, hang address 0x00000000.
Error - 6/14/2012 3:35:29 AM | Computer Name = QUADCORE | Source = .NET Runtime Optimization Service | ID = 1103
Description = .NET Runtime Optimization Service (clr_optimization_v2.0.50727_32)
- Tried to start a service that wasn't the latest version of CLR Optimization service.
Will shutdown
Error - 6/15/2012 10:59:45 AM | Computer Name = QUADCORE | Source = Application Hang | ID = 1002
Error - 6/20/2012 8:18:39 PM | Computer Name = QUADCORE | Source = Application Hang | ID = 1002
Error - 6/22/2012 9:27:14 AM | Computer Name = QUADCORE | Source = Application Hang | ID = 1002
Description = Hanging application OUTLOOK.EXE, version 10.0.6863.0, hang module
Error - 6/22/2012 9:27:34 AM | Computer Name = QUADCORE | Source = Application Hang | ID = 1002
Error - 6/30/2012 7:24:27 PM | Computer Name = QUADCORE | Source = Application Hang | ID = 1002
Error - 7/6/2012 9:10:53 AM | Computer Name = QUADCORE | Source = Application Hang | ID = 1002
Error - 7/7/2012 2:58:17 PM | Computer Name = QUADCORE | Source = Application Hang | ID = 1002
Error - 7/7/2012 10:13:23 PM | Computer Name = QUADCORE | Source = Application Error | ID = 1000
Description = Faulting application drivermax.exe, version 6.34.0.343, faulting module
kernel32.dll, version 5.1.2600.5781, fault address 0x00012afb.
[ System Events ]
Error - 7/7/2012 12:21:44 PM | Computer Name = QUADCORE | Source = Service Control Manager | ID = 7011
Description = Timeout (30000 milliseconds) waiting for a transaction response from
the stisvc service.
Error - 7/7/2012 12:25:40 PM | Computer Name = QUADCORE | Source = SRService | ID = 104
Description = The System Restore initialization process failed.
Error - 7/7/2012 12:25:40 PM | Computer Name = QUADCORE | Source = Service Control Manager | ID = 7023
Description = The System Restore Service service terminated with the following error:
%%2
Error - 7/7/2012 1:34:14 PM | Computer Name = QUADCORE | Source = NETLOGON | ID = 3095
Description = This computer is configured as a member of a workgroup, not as a member
of a domain. The Netlogon service does not need to run in this configuration.
Error - 7/7/2012 1:35:24 PM | Computer Name = QUADCORE | Source = SRService | ID = 104
Error - 7/7/2012 1:35:42 PM | Computer Name = QUADCORE | Source = Service Control Manager | ID = 7023
%%2
Error - 7/7/2012 4:09:34 PM | Computer Name = QUADCORE | Source = NETLOGON | ID = 3095
Error - 7/7/2012 4:10:34 PM | Computer Name = QUADCORE | Source = SRService | ID = 104
Error - 7/7/2012 4:10:51 PM | Computer Name = QUADCORE | Source = Service Control Manager | ID = 7023
%%2
Error - 7/7/2012 6:17:58 PM | Computer Name = QUADCORE | Source = PlugPlayManager | ID = 12
Description = The device 'HP LaserJet 4V' (LPTENUM\Hewlett-PackardHP_LaserJet_4V\5&368dfd43&0&LPT1.4)
disappeared from the system without first being prepared for removal.
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Tue Jul 10, 2012 10:23 am
No problems. Try the fix-it/diagnostic tool now please.
Posts Posts : 13713
Post by pointman on Tue Jul 10, 2012 4:12 pm
Okay, tried the MS fixit tool. It did not detect a problem with the DVD so no fix was applied. The DVD player still does not work. Should I unplug it and uninstall/reinstall?
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Tue Jul 10, 2012 7:47 pm
Try that and see how it goes, please. That would be a good troubleshooting step.
Posts Posts : 13713
Post by pointman on Wed Jul 11, 2012 8:36 pm
from the device mgr. I unstalled the dvd player and then unplugged the dvd ribbon and then rebooted. I then shut down and attached the ribbon back to the dvd and booted back up. Dvd reinstalled automatically. however there was no change in the dvd operation or the printer. not sure what to try next...any ideas?
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Thu Jul 12, 2012 7:27 pm
Are the devices installed in USB? Just the printer?
Or are they all ported to the motherboard directly?
Posts Posts : 13713
Post by pointman on Thu Jul 12, 2012 7:33 pm
Printer is usb and dvd is connected to MB directly.
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Fri Jul 13, 2012 10:28 am
Go Start and then to Run,
Type in: sfc /scannow
Click OK.
Have Windows CD/DVD handy.
If System File Checker (sfc) finds any errors, it may ask you for the CD/DVD.
If sfc does not find any errors in Windows XP, it will simply quit, without any message.
If you don't have Windows CD....
Go Start and then Run
type in regedit and click OK
Navigate to the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup
On the right hand side, find: SourcePath
It probably has an entry pointing to your CD-ROM drive, usually D and that is why it is asking for the XP CD.
All we need to do is change it to: C:
Now, double click the SourcePath setting and a new box will pop up.
Change the drive letter from your CD drive to your root drive, usually C:
Close Registry Editor.
Now restart your computer and try sfc /scannow again!
After the first run, reboot your computer. Do a second run. Now the scan and fix is finished.
Posts Posts : 13713
Post by pointman on Tue Jul 17, 2012 5:53 pm
When I run the sfc /scannow I get a message that "files that are required for windows to run properly must be copied to the DLL cache. Insert Windows XP CD." When I insert my windows XP cd I get the message "cd inserted is the wrong cd; either I have wrong cd or cdrom is not operating properly." (I have the right cd.) I tried checking the sourcepath drive letter and it is already C:
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Wed Jul 18, 2012 8:46 pm
Okay. Since you have to let the fix system look for what's on the CD, please change the sourcepath to whatever drive letter your CD-ROM drive is.
Posts Posts : 13713
Post by pointman on Thu Jul 19, 2012 9:04 pm
changed source letter from c: to D: and re-ran sfc /scannow. I inserted windows xp cd when prompted and still get the message that I have inserted the wrong cd. I am sure i am inserting the right windows cd. (I only have one.) dvd player will still play a couple of my music video dvds but thats all.
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Sat Jul 21, 2012 4:38 pm
Do you know what the brand (make/model) is? I can check compatibility...
Posts Posts : 13713
Post by pointman on Sat Jul 21, 2012 4:55 pm
LG DVDRW LS 20X H55LK LightScribe
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Mon Jul 23, 2012 8:15 pm
Thanks for that. More questions...
Have you attempted any of this in Safe Mode?
Do you have more than one drive on the computer?
Did you modify any settings in the Registry or BIOS for the drive?
Posts Posts : 13713
Post by pointman on Tue Jul 24, 2012 10:29 pm
No haven't tried safe mode.
only one drive
I haven't modified any registry settings that I know of.
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Wed Jul 25, 2012 4:58 pm
All of the evidence leads to a failing drive. We could continue running fixes till we're blue in the face, but when a drive fails...it's done.
Usually, in this case, if you have LG support repair it, (if not under warranty), you'll pay an arm and a leg to replace the burning mechanism. Same type of stuff I went through, except my issue was more VCR/DVD recorder problem.
Price of new drive: $40-80 USD
Price of mechanism: $60-260 depending on brand popularity
Cost of replacing mechanism (tiresome): $60-200 depending on experience of techie.
As you can see, a new drive is the best option.
I'm sorry it came to this, as I wouldn't recommend you to pay anything unless if necessary.
Let me know what you do.
Posts Posts : 13713
Post by pointman on Thu Jul 26, 2012 1:27 am
Ok, that was my thinking also. I will probably just replace it. Thanks for all your help.
pointman
Posts Posts : 95
OS OS : windows XP
Post by Dr Jay on Thu Jul 26, 2012 4:28 pm
You're welcome. Only glad to help. Smile
Posts Posts : 13713
