Help required smart repair HDD
Page 2 of 2 Previous  1, 2
Post by wildfly73 on Fri 20 Apr 2012, 6:55 am
Iv tried using GeekPolice Smart repair HDD removal guide, links to malwarebytes from the guide do not work on my infected computer but will on an unifected friends laptop. So downloaded malwarebytes to a USB and uploaded to my computer. icon appeares on desktop but does not function when clicked on. Even tried renaming malwarebytes but this not worked to. Seems like im locked out of C drive. Also opening internet explorer and typing in a website address it gets redirected to a ad or useless search engine. Plus the @ key no longer produces an @ when shift and @ are pressed. In Start menue all programmes are empty and desk top is blank (no icons showing) Still have access to IBOS.
Really in need of some help with this. Worst malware infection iv experienced.
Many Thanks
Stephen.
Last edited by wildfly73 on Fri 20 Apr 2012, 7:31 am; edited 1 time in total (Reason for editing : clarification/additional info)
wildfly73
Operating System : windows xp Home Edition 2002 service pack 3
Re: Help required smart repair HDD
Post by wildfly73 on Tue 01 May 2012, 6:38 am
Yes it will boot in normal mode. However, desktop is blank (empty blue screen) on the right handside of taskbar icons visable and functioning. In Start menu Programmes are visable but when hovering curser all show empty and are non functioning. Also run/command bar, my computer, my documents, control panel options are all apscent from the start menu.
After running the unhide fix, internet capability and task bar icons were restored to normal functioning.
wildfly73
Post by Superdave on Tue 01 May 2012, 9:07 am
  • Download TDSSKiller and save it to your Desktop.
  • Extract its contents to your desktop.
  • Once extracted, open the TDSSKiller folder and doubleclick on TDSSKiller.exe to run the application, then on Start Scan.
  • If an infected file is detected, the default action will be Cure, click on Continue.
  • If a suspicious file is detected, the default action will be Skip, click on Continue.
  • It may ask you to reboot the computer to complete the process. Click on Reboot Now.
Note:It will also create a log in the C:\ directory..
Tech Staff
Tech Staff
TDSSkiller log 1 & 2
Post by wildfly73 on Wed 02 May 2012, 5:39 am
Hello, i ran TDDS in Windows Recovery Environment. During the initialization process of TDSSkiller two error messages occured. Carnt initialize log and carnt load driver. However, TDSS still did a scan and detected threat Rootkit.Boot.SST.b Physicaldrive:\Device\Harddisk0\DR0 Malware object high risk cured on reboot.
TDSSkiller log1
20:27:51.0656 2152 TDSS rootkit removing tool 2.7.33.0 Apr 24 2012 18:43:43
20:27:51.0937 2152 ============================================================
20:27:51.0937 2152 Current date / time: 2012/05/01 20:27:51.0937
20:27:51.0937 2152 SystemInfo:
20:27:51.0937 2152
20:27:51.0937 2152 OS Version: 5.1.2600 ServicePack: 3.0
20:27:51.0937 2152 Product type: Workstation
20:27:51.0937 2152 ComputerName: YOUR-4AD98E1252
20:27:51.0937 2152 UserName: Stephen
20:27:51.0937 2152 Windows directory: C:\WINDOWS
20:27:51.0937 2152 System windows directory: C:\WINDOWS
20:27:51.0937 2152 Processor architecture: Intel x86
20:27:51.0937 2152 Number of processors: 2
20:27:51.0937 2152 Page size: 0x1000
20:27:51.0937 2152 Boot type: Normal boot
20:27:54.0109 2152 Drive \Device\Harddisk0\DR0 - Size: 0x25433D6000 (149.05 Gb), SectorSize: 0x200, Cylinders: 0x4C01, SectorsPerTrack: 0x3F, TracksPerCylinder: 0xFF, Type 'K0', Flags 0x00000054
20:27:54.0203 2152 ============================================================
20:27:54.0203 2152 \Device\Harddisk0\DR0:
20:27:54.0218 2152 MBR partitions:
20:27:54.0218 2152 \Device\Harddisk0\DR0\Partition0: MBR, Type 0x7, StartLBA 0x3F, BlocksNum 0x12A18A82
20:27:54.0218 2152 ============================================================
20:27:54.0312 2152 C: <-> \Device\Harddisk0\DR0\Partition0
20:27:54.0312 2152 ============================================================
20:27:54.0312 2152 Initialize success
20:28:01.0218 3796 ============================================================
20:28:01.0218 3796 Scan started
20:28:01.0218 3796 Mode: Manual;
20:28:01.0656 3796 61883 (914a9709fc3bf419ad2f85547f2a4832) C:\WINDOWS\system32\DRIVERS\61883.sys
20:28:01.0656 3796 61883 - ok
20:28:01.0656 3796 Abiosdsk - ok
20:28:01.0671 3796 abp480n5 - ok
20:28:01.0718 3796 ACPI (8fd99680a539792a30e97944fdaecf17) C:\WINDOWS\system32\DRIVERS\ACPI.sys
20:28:01.0718 3796 ACPI - ok
20:28:01.0765 3796 ACPIEC (9859c0f6936e723e4892d7141b1327d5) C:\WINDOWS\system32\drivers\ACPIEC.sys
20:28:01.0765 3796 ACPIEC - ok
20:28:01.0921 3796 AdobeActiveFileMonitor (f487ee1425d9533aef4b1d991fc5abbe) C:\Program Files\Adobe\Photoshop Elements 3.0\PhotoshopElementsFileAgent.exe
20:28:01.0921 3796 AdobeActiveFileMonitor - ok
20:28:02.0062 3796 AdobeFlashPlayerUpdateSvc (0d4c486a24a711a45fd83acdf4d18506) C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
20:28:02.0062 3796 AdobeFlashPlayerUpdateSvc - ok
20:28:02.0062 3796 adpu160m - ok
20:28:02.0156 3796 aec (8bed39e3c35d6a489438b8141717a557) C:\WINDOWS\system32\drivers\aec.sys
20:28:02.0156 3796 aec - ok
20:28:02.0218 3796 AFD (1e44bc1e83d8fd2305f8d452db109cf9) C:\WINDOWS\System32\drivers\afd.sys
20:28:02.0218 3796 AFD - ok
20:28:02.0218 3796 Aha154x - ok
20:28:02.0234 3796 aic78u2 - ok
20:28:02.0234 3796 aic78xx - ok
20:28:02.0296 3796 alcan5wn (0940030d5a5869067ccc03e3b0b8dec7) C:\WINDOWS\system32\DRIVERS\alcan5wn.sys
20:28:02.0296 3796 alcan5wn - ok
20:28:02.0328 3796 alcaudsl (4c9577888c53243e2991456f510488a1) C:\WINDOWS\system32\DRIVERS\alcaudsl.sys
20:28:02.0328 3796 alcaudsl - ok
20:28:02.0359 3796 Alerter (a9a3daa780ca6c9671a19d52456705b4) C:\WINDOWS\system32\alrsvc.dll
20:28:02.0359 3796 Alerter - ok
20:28:02.0390 3796 ALG (8c515081584a38aa007909cd02020b3d) C:\WINDOWS\System32\alg.exe
20:28:02.0390 3796 ALG - ok
20:28:02.0390 3796 AliIde - ok
20:28:02.0406 3796 amsint - ok
20:28:02.0515 3796 Apple Mobile Device (2e3e53a6aef23e24f402c7855b9b1542) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
20:28:02.0515 3796 Apple Mobile Device - ok
20:28:02.0531 3796 AppMgmt - ok
20:28:02.0578 3796 Arp1394 (b5b8a80875c1dededa8b02765642c32f) C:\WINDOWS\system32\DRIVERS\arp1394.sys
20:28:02.0578 3796 Arp1394 - ok
20:28:02.0640 3796 ASAPIW2k (4f9cbbf95e8f7a0d4c0edcfe3b78102e) C:\WINDOWS\system32\drivers\ASAPIW2k.sys
20:28:02.0640 3796 ASAPIW2k - ok
20:28:02.0656 3796 asc - ok
20:28:02.0656 3796 asc3350p - ok
20:28:02.0671 3796 asc3550 - ok
20:28:02.0812 3796 aspnet_state (e1a1206a4fb19b675e947b29ccd25fba) C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\aspnet_state.exe
20:28:02.0843 3796 aspnet_state - ok
20:28:02.0875 3796 AsyncMac (b153affac761e7f5fcfa822b9c4e97bc) C:\WINDOWS\system32\DRIVERS\asyncmac.sys
20:28:02.0875 3796 AsyncMac - ok
20:28:02.0906 3796 atapi (9f3a2f5aa6875c72bf062c712cfa2674) C:\WINDOWS\system32\DRIVERS\atapi.sys
20:28:02.0906 3796 atapi - ok
20:28:02.0921 3796 Atdisk - ok
20:28:03.0000 3796 Ati HotKey Poller (8911ecc589539b2a71b09b65bc67b3b6) C:\WINDOWS\system32\Ati2evxx.exe
20:28:03.0000 3796 Ati HotKey Poller - ok
20:28:03.0046 3796 ati2mtag (1a12941c75be2003286c7787f21a7f81) C:\WINDOWS\system32\DRIVERS\ati2mtag.sys
20:28:03.0078 3796 ati2mtag - ok
20:28:03.0140 3796 Atmarpc (9916c1225104ba14794209cfa8012159) C:\WINDOWS\system32\DRIVERS\atmarpc.sys
20:28:03.0140 3796 Atmarpc - ok
20:28:03.0171 3796 AudioSrv (def7a7882bec100fe0b2ce2549188f9d) C:\WINDOWS\System32\audiosrv.dll
20:28:03.0171 3796 AudioSrv - ok
20:28:03.0203 3796 audstub (d9f724aa26c010a217c97606b160ed68) C:\WINDOWS\system32\DRIVERS\audstub.sys
20:28:03.0203 3796 audstub - ok
20:28:03.0234 3796 Avc (f8e6956a614f15a0860474c5e2a7de6b) C:\WINDOWS\system32\DRIVERS\avc.sys
20:28:03.0234 3796 Avc - ok
20:28:03.0265 3796 Beep (da1f27d85e0d1525f6621372e7b685e9) C:\WINDOWS\system32\drivers\Beep.sys
20:28:03.0265 3796 Beep - ok
20:28:03.0343 3796 BITS (574738f61fca2935f5265dc4e5691314) C:\WINDOWS\system32\qmgr.dll
20:28:03.0515 3796 BITS - ok
20:28:03.0718 3796 Bonjour Service (5ab58c337ac65837fe404462ad6265ab) C:\Program Files\Bonjour\mDNSResponder.exe
20:28:03.0718 3796 Bonjour Service - ok
20:28:03.0781 3796 Browser (a06ce3399d16db864f55faeb1f1927a9) C:\WINDOWS\System32\browser.dll
20:28:03.0781 3796 Browser - ok
20:28:03.0781 3796 catchme - ok
20:28:03.0828 3796 cbidf2k (90a673fc8e12a79afbed2576f6a7aaf9) C:\WINDOWS\system32\drivers\cbidf2k.sys
20:28:03.0828 3796 cbidf2k - ok
20:28:03.0859 3796 CCDECODE (0be5aef125be881c4f854c554f2b025c) C:\WINDOWS\system32\DRIVERS\CCDECODE.sys
20:28:03.0859 3796 CCDECODE - ok
20:28:03.0875 3796 cd20xrnt - ok
20:28:03.0906 3796 Cdaudio (c1b486a7658353d33a10cc15211a873b) C:\WINDOWS\system32\drivers\Cdaudio.sys
20:28:03.0906 3796 Cdaudio - ok
20:28:03.0968 3796 Cdfs (c885b02847f5d2fd45a24e219ed93b32) C:\WINDOWS\system32\drivers\Cdfs.sys
20:28:03.0968 3796 Cdfs - ok
20:28:04.0031 3796 Cdrom (1f4260cc5b42272d71f79e570a27a4fe) C:\WINDOWS\system32\DRIVERS\cdrom.sys
20:28:04.0031 3796 Cdrom - ok
20:28:04.0046 3796 Changer - ok
20:28:04.0078 3796 CiSvc (1cfe720eb8d93a7158a4ebc3ab178bde) C:\WINDOWS\system32\cisvc.exe
20:28:04.0078 3796 CiSvc - ok
20:28:04.0125 3796 ClipSrv (34cbe729f38138217f9c80212a2a0c82) C:\WINDOWS\system32\clipsrv.exe
20:28:04.0125 3796 ClipSrv - ok
20:28:04.0171 3796 CLTNetCnService - ok
20:28:04.0171 3796 CmdIde - ok
20:28:04.0171 3796 COMSysApp - ok
20:28:04.0187 3796 Cpqarray - ok
20:28:04.0234 3796 CryptSvc (3d4e199942e29207970e04315d02ad3b) C:\WINDOWS\System32\cryptsvc.dll
20:28:04.0234 3796 CryptSvc - ok
20:28:04.0250 3796 dac2w2k - ok
20:28:04.0250 3796 dac960nt - ok
20:28:04.0328 3796 DcomLaunch (6b27a5c03dfb94b4245739065431322c) C:\WINDOWS\system32\rpcss.dll
20:28:04.0343 3796 DcomLaunch - ok
20:28:04.0406 3796 Dhcp (5e38d7684a49cacfb752b046357e0589) C:\WINDOWS\System32\dhcpcsvc.dll
20:28:04.0406 3796 Dhcp - ok
20:28:04.0437 3796 Disk (044452051f3e02e7963599fc8f4f3e25) C:\WINDOWS\system32\DRIVERS\disk.sys
20:28:04.0437 3796 Disk - ok
20:28:04.0437 3796 dmadmin - ok
20:28:04.0500 3796 dmboot (d992fe1274bde0f84ad826acae022a41) C:\WINDOWS\system32\drivers\dmboot.sys
20:28:04.0515 3796 dmboot - ok
20:28:04.0562 3796 dmio (7c824cf7bbde77d95c08005717a95f6f) C:\WINDOWS\system32\drivers\dmio.sys
20:28:04.0562 3796 dmio - ok
20:28:04.0593 3796 dmload (e9317282a63ca4d188c0df5e09c6ac5f) C:\WINDOWS\system32\drivers\dmload.sys
20:28:04.0593 3796 dmload - ok
20:28:04.0625 3796 dmserver (57edec2e5f59f0335e92f35184bc8631) C:\WINDOWS\System32\dmserver.dll
20:28:04.0625 3796 dmserver - ok
20:28:04.0671 3796 DMusic (8a208dfcf89792a484e76c40e5f50b45) C:\WINDOWS\system32\drivers\DMusic.sys
20:28:04.0671 3796 DMusic - ok
20:28:04.0734 3796 Dnscache (5f7e24fa9eab896051ffb87f840730d2) C:\WINDOWS\System32\dnsrslvr.dll
20:28:04.0734 3796 Dnscache - ok
20:28:04.0796 3796 Dot3svc (0f0f6e687e5e15579ef4da8dd6945814) C:\WINDOWS\System32\dot3svc.dll
20:28:04.0796 3796 Dot3svc - ok
20:28:04.0796 3796 dpti2o - ok
20:28:04.0812 3796 drmkaud (8f5fcff8e8848afac920905fbd9d33c8) C:\WINDOWS\system32\drivers\drmkaud.sys
20:28:04.0812 3796 drmkaud - ok
20:28:04.0843 3796 DrvAgent32 (651554e483712b708ede864d0ca1aa73) C:\WINDOWS\system32\Drivers\DrvAgent32.sys
20:28:04.0843 3796 DrvAgent32 - ok
20:28:04.0875 3796 EapHost (2187855a7703adef0cef9ee4285182cc) C:\WINDOWS\System32\eapsvc.dll
20:28:04.0875 3796 EapHost - ok
20:28:05.0093 3796 eeCtrl (31c959319ef45b548d2111e338412270) C:\Program Files\Common Files\Symantec Shared\EENGINE\eeCtrl.sys
20:28:05.0093 3796 eeCtrl - ok
20:28:05.0171 3796 ERSvc (bc93b4a066477954555966d77fec9ecb) C:\WINDOWS\System32\ersvc.dll
20:28:05.0171 3796 ERSvc - ok
20:28:05.0234 3796 Eventlog (65df52f5b8b6e9bbd183505225c37315) C:\WINDOWS\system32\services.exe
20:28:05.0234 3796 Eventlog - ok
20:28:05.0281 3796 EventSystem (d4991d98f2db73c60d042f1aef79efae) C:\WINDOWS\system32\es.dll
20:28:05.0281 3796 EventSystem - ok
20:28:05.0375 3796 Fastfat (38d332a6d56af32635675f132548343e) C:\WINDOWS\system32\drivers\Fastfat.sys
20:28:05.0375 3796 Fastfat - ok
20:28:05.0437 3796 FastUserSwitchingCompatibility (99bc0b50f511924348be19c7c7313bbf) C:\WINDOWS\System32\shsvcs.dll
20:28:05.0437 3796 FastUserSwitchingCompatibility - ok
20:28:05.0500 3796 Fdc (92cdd60b6730b9f50f6a1a0c1f8cdc81) C:\WINDOWS\system32\drivers\Fdc.sys
20:28:05.0500 3796 Fdc - ok
20:28:05.0562 3796 Fips (d45926117eb9fa946a6af572fbe1caa3) C:\WINDOWS\system32\drivers\Fips.sys
20:28:05.0562 3796 Fips - ok
20:28:05.0593 3796 Flpydisk (9d27e7b80bfcdf1cdd9b555862d5e7f0) C:\WINDOWS\system32\drivers\Flpydisk.sys
20:28:05.0593 3796 Flpydisk - ok
20:28:05.0625 3796 FltMgr (b2cf4b0786f8212cb92ed2b50c6db6b0) C:\WINDOWS\system32\drivers\fltmgr.sys
20:28:05.0640 3796 FltMgr - ok
20:28:05.0671 3796 Fs_Rec (3e1e2bd4f39b0e2b7dc4f4d2bcc2779a) C:\WINDOWS\system32\drivers\Fs_Rec.sys
20:28:05.0671 3796 Fs_Rec - ok
20:28:05.0687 3796 Ftdisk (6ac26732762483366c3969c9e4d2259d) C:\WINDOWS\system32\DRIVERS\ftdisk.sys
20:28:05.0703 3796 Ftdisk - ok
20:28:05.0750 3796 GEARAspiWDM (4ac51459805264affd5f6fdfb9d9235f) C:\WINDOWS\system32\Drivers\GEARAspiWDM.sys
20:28:05.0750 3796 GEARAspiWDM - ok
20:28:05.0812 3796 Gpc (0a02c63c8b144bd8c86b103dee7c86a2) C:\WINDOWS\system32\DRIVERS\msgpc.sys
20:28:05.0812 3796 Gpc - ok
20:28:05.0921 3796 gusvc (34b56a3c195aee6ae11001d277acc83e) C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
20:28:05.0921 3796 gusvc - ok
20:28:05.0953 3796 HdAudAddService (2a013e7530beab6e569faa83f517e836) C:\WINDOWS\system32\drivers\HdAudio.sys
20:28:05.0968 3796 HdAudAddService - ok
20:28:06.0015 3796 HDAudBus (573c7d0a32852b48f3058cfd8026f511) C:\WINDOWS\system32\DRIVERS\HDAudBus.sys
20:28:06.0015 3796 HDAudBus - ok
20:28:06.0078 3796 helpsvc (4fcca060dfe0c51a09dd5c3843888bcd) C:\WINDOWS\PCHealth\HelpCtr\Binaries\pchsvc.dll
20:28:06.0078 3796 helpsvc - ok
20:28:06.0125 3796 HidServ (deb04da35cc871b6d309b77e1443c796) C:\WINDOWS\System32\hidserv.dll
20:28:06.0140 3796 HidServ - ok
20:28:06.0171 3796 hidusb (ccf82c5ec8a7326c3066de870c06daf1) C:\WINDOWS\system32\DRIVERS\hidusb.sys
20:28:06.0171 3796 hidusb - ok
20:28:06.0187 3796 hkmsvc (8878bd685e490239777bfe51320b88e9) C:\WINDOWS\System32\kmsvc.dll
20:28:06.0187 3796 hkmsvc - ok
20:28:06.0187 3796 hpn - ok
20:28:06.0218 3796 HPZid412 (9f1d80908658eb7f1bf70809e0b51470) C:\WINDOWS\system32\DRIVERS\HPZid412.sys
20:28:06.0218 3796 HPZid412 - ok
20:28:06.0234 3796 HPZipr12 (f7e3e9d50f9cd3de28085a8fdaa0a1c3) C:\WINDOWS\system32\DRIVERS\HPZipr12.sys
20:28:06.0234 3796 HPZipr12 - ok
20:28:06.0250 3796 HPZius12 (cf1b7951b4ec8d13f3c93b74bb2b461b) C:\WINDOWS\system32\DRIVERS\HPZius12.sys
20:28:06.0250 3796 HPZius12 - ok
20:28:06.0312 3796 HSFHWBS2 (128ef741b2293c36810561092b566b1c) C:\WINDOWS\system32\DRIVERS\HSFHWBS2.sys
20:28:06.0312 3796 HSFHWBS2 - ok
20:28:06.0359 3796 HSF_DP (9a0d0c461ef2b3d80cb7875b4b995e47) C:\WINDOWS\system32\DRIVERS\HSF_DP.sys
20:28:06.0390 3796 HSF_DP - ok
20:28:06.0468 3796 HTTP (f80a415ef82cd06ffaf0d971528ead38) C:\WINDOWS\system32\Drivers\HTTP.sys
20:28:06.0468 3796 HTTP - ok
20:28:06.0515 3796 HTTPFilter (6100a808600f44d999cebdef8841c7a3) C:\WINDOWS\System32\w3ssl.dll
20:28:06.0515 3796 HTTPFilter - ok
20:28:06.0515 3796 i2omgmt - ok
20:28:06.0531 3796 i2omp - ok
20:28:06.0578 3796 i8042prt (4a0b06aa8943c1e332520f7440c0aa30) C:\WINDOWS\system32\drivers\i8042prt.sys
20:28:06.0578 3796 i8042prt - ok
20:28:06.0593 3796 Imapi (083a052659f5310dd8b6a6cb05edcf8e) C:\WINDOWS\system32\DRIVERS\imapi.sys
20:28:06.0593 3796 Imapi - ok
20:28:06.0671 3796 ImapiService (30deaf54a9755bb8546168cfe8a6b5e1) C:\WINDOWS\system32\imapi.exe
20:28:06.0671 3796 ImapiService - ok
20:28:06.0687 3796 ini910u - ok
20:28:06.0828 3796 IntcAzAudAddService (44792ccbc7b41b42ec068c6416d17de1) C:\WINDOWS\system32\drivers\RtkHDAud.sys
20:28:06.0890 3796 IntcAzAudAddService - ok
20:28:07.0031 3796 IntelIde (b5466a9250342a7aa0cd1fba13420678) C:\WINDOWS\system32\DRIVERS\intelide.sys
20:28:07.0031 3796 IntelIde - ok
20:28:07.0093 3796 intelppm (8c953733d8f36eb2133f5bb58808b66b) C:\WINDOWS\system32\DRIVERS\intelppm.sys
20:28:07.0093 3796 intelppm - ok
20:28:07.0125 3796 Ip6Fw (3bb22519a194418d5fec05d800a19ad0) C:\WINDOWS\system32\drivers\ip6fw.sys
20:28:07.0125 3796 Ip6Fw - ok
20:28:07.0156 3796 IpFilterDriver (731f22ba402ee4b62748adaf6363c182) C:\WINDOWS\system32\DRIVERS\ipfltdrv.sys
20:28:07.0156 3796 IpFilterDriver - ok
20:28:07.0187 3796 IpInIp (b87ab476dcf76e72010632b5550955f5) C:\WINDOWS\system32\DRIVERS\ipinip.sys
20:28:07.0187 3796 IpInIp - ok
20:28:07.0234 3796 IpNat (cc748ea12c6effde940ee98098bf96bb) C:\WINDOWS\system32\DRIVERS\ipnat.sys
20:28:07.0234 3796 IpNat - ok
20:28:07.0359 3796 iPod Service (630d74599070824af3dc63a894adcdfc) C:\Program Files\iPod\bin\iPodService.exe
20:28:07.0375 3796 iPod Service - ok
20:28:07.0437 3796 IPSec (23c74d75e36e7158768dd63d92789a91) C:\WINDOWS\system32\DRIVERS\ipsec.sys
20:28:07.0437 3796 IPSec - ok
20:28:07.0468 3796 IRENUM (c93c9ff7b04d772627a3646d89f7bf89) C:\WINDOWS\system32\DRIVERS\irenum.sys
20:28:07.0468 3796 IRENUM - ok
20:28:07.0500 3796 isapnp (05a299ec56e52649b1cf2fc52d20f2d7) C:\WINDOWS\system32\DRIVERS\isapnp.sys
20:28:07.0500 3796 isapnp - ok
20:28:07.0640 3796 JavaQuickStarterService (9aa67569d5257462e230767510b0c815) C:\Program Files\Java\jre6\bin\jqs.exe
20:28:07.0640 3796 JavaQuickStarterService - ok
20:28:07.0656 3796 Kbdclass (463c1ec80cd17420a542b7f36a36f128) C:\WINDOWS\system32\DRIVERS\kbdclass.sys
20:28:07.0656 3796 Kbdclass - ok
20:28:07.0718 3796 kbdhid (9ef487a186dea361aa06913a75b3fa99) C:\WINDOWS\system32\DRIVERS\kbdhid.sys
20:28:07.0718 3796 kbdhid - ok
20:28:07.0828 3796 kmixer (692bcf44383d056aed41b045a323d378) C:\WINDOWS\system32\drivers\kmixer.sys
20:28:07.0890 3796 kmixer - ok
20:28:07.0937 3796 KSecDD (b467646c54cc746128904e1654c750c1) C:\WINDOWS\system32\drivers\KSecDD.sys
20:28:07.0937 3796 KSecDD - ok
20:28:08.0171 3796 KService (70ceefe43cb746dd04a884c84a7ebaa3) C:\Program Files\Kontiki\KService.exe
20:28:08.0281 3796 KService - ok
20:28:08.0468 3796 lanmanserver (3a7c3cbe5d96b8ae96ce81f0b22fb527) C:\WINDOWS\System32\srvsvc.dll
20:28:08.0468 3796 lanmanserver - ok
20:28:08.0531 3796 lanmanworkstation (a8888a5327621856c0cec4e385f69309) C:\WINDOWS\System32\wkssvc.dll
20:28:08.0562 3796 lanmanworkstation - ok
20:28:08.0781 3796 Lavasoft Ad-Aware Service (ea38136981c61c571d52c380daad46ef) C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
20:28:08.0875 3796 Lavasoft Ad-Aware Service - ok
20:28:08.0937 3796 Lavasoft Kernexplorer (6c4a3804510ad8e0f0c07b5be3d44ddb) C:\Program Files\Lavasoft\Ad-Aware\KernExplorer.sys
20:28:08.0937 3796 Lavasoft Kernexplorer - ok
20:28:09.0031 3796 Lbd (336abe8721cbc3110f1c6426da633417) C:\WINDOWS\system32\DRIVERS\Lbd.sys
20:28:09.0031 3796 Lbd - ok
20:28:09.0031 3796 lbrtfdc - ok
20:28:09.0109 3796 LiveUpdate Notice Ex - ok
20:28:09.0187 3796 LiveUpdate Notice Service (2d1389e05a807d956829f44bd4b60389) C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
20:28:09.0203 3796 LiveUpdate Notice Service - ok
20:28:09.0265 3796 LmHosts (a7db739ae99a796d91580147e919cc59) C:\WINDOWS\System32\lmhsvc.dll
20:28:09.0265 3796 LmHosts - ok
20:28:09.0328 3796 LVUSBSta (a730fc8671a60666d6e877c544dd7cd4) C:\WINDOWS\system32\drivers\lvusbsta.sys
20:28:09.0328 3796 LVUSBSta - ok
20:28:09.0468 3796 McComponentHostService (f453d1e6d881e8f8717e20ccd4199e85) C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe
20:28:09.0468 3796 McComponentHostService - ok
20:28:09.0484 3796 mdmxsdk (5110edd87e2508f02b922e83a2487dfc) C:\WINDOWS\system32\DRIVERS\mdmxsdk.sys
20:28:09.0484 3796 mdmxsdk - ok
20:28:09.0515 3796 Messenger (986b1ff5814366d71e0ac5755c88f2d3) C:\WINDOWS\System32\msgsvc.dll
20:28:09.0515 3796 Messenger - ok
20:28:09.0562 3796 mnmdd (4ae068242760a1fb6e1a44bf4e16afa6) C:\WINDOWS\system32\drivers\mnmdd.sys
20:28:09.0562 3796 mnmdd - ok
20:28:09.0625 3796 mnmsrvc (d18f1f0c101d06a1c1adf26eed16fcdd) C:\WINDOWS\system32\mnmsrvc.exe
20:28:09.0625 3796 mnmsrvc - ok
20:28:09.0687 3796 Modem (dfcbad3cec1c5f964962ae10e0bcc8e1) C:\WINDOWS\system32\drivers\Modem.sys
20:28:09.0687 3796 Modem - ok
20:28:09.0750 3796 Mouclass (35c9e97194c8cfb8430125f8dbc34d04) C:\WINDOWS\system32\DRIVERS\mouclass.sys
20:28:09.0750 3796 Mouclass - ok
20:28:09.0812 3796 mouhid (b1c303e17fb9d46e87a98e4ba6769685) C:\WINDOWS\system32\DRIVERS\mouhid.sys
20:28:09.0812 3796 mouhid - ok
20:28:09.0875 3796 MountMgr (a80b9a0bad1b73637dbcbba7df72d3fd) C:\WINDOWS\system32\drivers\MountMgr.sys
20:28:09.0875 3796 MountMgr - ok
20:28:09.0875 3796 mraid35x - ok
20:28:09.0921 3796 MRxDAV (11d42bb6206f33fbb3ba0288d3ef81bd) C:\WINDOWS\system32\DRIVERS\mrxdav.sys
20:28:09.0921 3796 MRxDAV - ok
20:28:10.0000 3796 MRxSmb (7d304a5eb4344ebeeab53a2fe3ffb9f0) C:\WINDOWS\system32\DRIVERS\mrxsmb.sys
20:28:10.0000 3796 MRxSmb - ok
20:28:10.0078 3796 MSDTC (a137f1470499a205abbb9aafb3b6f2b1) C:\WINDOWS\system32\msdtc.exe
20:28:10.0078 3796 MSDTC - ok
20:28:10.0125 3796 MSDV (1477849772712bac69c144dcf2c9ce81) C:\WINDOWS\system32\DRIVERS\msdv.sys
20:28:10.0125 3796 MSDV - ok
20:28:10.0140 3796 Msfs (c941ea2454ba8350021d774daf0f1027) C:\WINDOWS\system32\drivers\Msfs.sys
20:28:10.0140 3796 Msfs - ok
20:28:10.0140 3796 MSIServer - ok
20:28:10.0171 3796 MSKSSRV (d1575e71568f4d9e14ca56b7b0453bf1) C:\WINDOWS\system32\drivers\MSKSSRV.sys
20:28:10.0171 3796 MSKSSRV - ok
20:28:10.0187 3796 MSPCLOCK (325bb26842fc7ccc1fcce2c457317f3e) C:\WINDOWS\system32\drivers\MSPCLOCK.sys
20:28:10.0187 3796 MSPCLOCK - ok
20:28:10.0203 3796 MSPQM (bad59648ba099da4a17680b39730cb3d) C:\WINDOWS\system32\drivers\MSPQM.sys
20:28:10.0203 3796 MSPQM - ok
20:28:10.0234 3796 mssmbios (af5f4f3f14a8ea2c26de30f7a1e17136) C:\WINDOWS\system32\DRIVERS\mssmbios.sys
20:28:10.0234 3796 mssmbios - ok
20:28:10.0281 3796 MSTEE (e53736a9e30c45fa9e7b5eac55056d1d) C:\WINDOWS\system32\drivers\MSTEE.sys
20:28:10.0281 3796 MSTEE - ok
20:28:10.0328 3796 Mup (de6a75f5c270e756c5508d94b6cf68f5) C:\WINDOWS\system32\drivers\Mup.sys
20:28:10.0328 3796 Mup - ok
20:28:10.0359 3796 NABTSFEC (5b50f1b2a2ed47d560577b221da734db) C:\WINDOWS\system32\DRIVERS\NABTSFEC.sys
20:28:10.0359 3796 NABTSFEC - ok
20:28:10.0406 3796 napagent (0102140028fad045756796e1c685d695) C:\WINDOWS\System32\qagentrt.dll
20:28:10.0406 3796 napagent - ok
20:28:10.0453 3796 NDIS (1df7f42665c94b825322fae71721130d) C:\WINDOWS\system32\drivers\NDIS.sys
20:28:10.0468 3796 NDIS - ok
20:28:10.0500 3796 NdisIP (7ff1f1fd8609c149aa432f95a8163d97) C:\WINDOWS\system32\DRIVERS\NdisIP.sys
20:28:10.0500 3796 NdisIP - ok
20:28:10.0546 3796 NdisTapi (0109c4f3850dfbab279542515386ae22) C:\WINDOWS\system32\DRIVERS\ndistapi.sys
20:28:10.0546 3796 NdisTapi - ok
20:28:10.0562 3796 Ndisuio (f927a4434c5028758a842943ef1a3849) C:\WINDOWS\system32\DRIVERS\ndisuio.sys
20:28:10.0562 3796 Ndisuio - ok
20:28:10.0593 3796 NdisWan (edc1531a49c80614b2cfda43ca8659ab) C:\WINDOWS\system32\DRIVERS\ndiswan.sys
20:28:10.0593 3796 NdisWan - ok
20:28:10.0609 3796 NDProxy (9282bd12dfb069d3889eb3fcc1000a9b) C:\WINDOWS\system32\drivers\NDProxy.sys
20:28:10.0609 3796 NDProxy - ok
20:28:10.0625 3796 NetBIOS (5d81cf9a2f1a3a756b66cf684911cdf0) C:\WINDOWS\system32\DRIVERS\netbios.sys
20:28:10.0625 3796 NetBIOS - ok
20:28:10.0671 3796 NetBT (74b2b2f5bea5e9a3dc021d685551bd3d) C:\WINDOWS\system32\DRIVERS\netbt.sys
20:28:10.0671 3796 NetBT - ok
20:28:10.0734 3796 NetDDE (b857ba82860d7ff85ae29b095645563b) C:\WINDOWS\system32\netdde.exe
20:28:10.0734 3796 NetDDE - ok
20:28:10.0734 3796 NetDDEdsdm (b857ba82860d7ff85ae29b095645563b) C:\WINDOWS\system32\netdde.exe
20:28:10.0734 3796 NetDDEdsdm - ok
20:28:10.0765 3796 Netlogon (bf2466b3e18e970d8a976fb95fc1ca85) C:\WINDOWS\system32\lsass.exe
20:28:10.0765 3796 Netlogon - ok
20:28:10.0796 3796 Netman (13e67b55b3abd7bf3fe7aae5a0f9a9de) C:\WINDOWS\System32\netman.dll
20:28:10.0796 3796 Netman - ok
20:28:10.0859 3796 NIC1394 (e9e47cfb2d461fa0fc75b7a74c6383ea) C:\WINDOWS\system32\DRIVERS\nic1394.sys
20:28:10.0859 3796 NIC1394 - ok
20:28:10.0921 3796 Nla (943337d786a56729263071623bbb9de5) C:\WINDOWS\System32\mswsock.dll
20:28:10.0937 3796 Nla - ok
20:28:10.0984 3796 nmwcd (696b37ea78f9d9767a2f18ba0304a51a) C:\WINDOWS\system32\drivers\nmwcd.sys
20:28:10.0984 3796 nmwcd - ok
20:28:11.0015 3796 nmwcdc (bbb6010fc01d9239d88fcdf133e03ff0) C:\WINDOWS\system32\drivers\nmwcdc.sys
20:28:11.0015 3796 nmwcdc - ok
20:28:11.0031 3796 nmwcdcj (4c3726467d67483f054c88f058e9c153) C:\WINDOWS\system32\drivers\nmwcdcj.sys
20:28:11.0031 3796 nmwcdcj - ok
20:28:11.0046 3796 nmwcdcm (4c3726467d67483f054c88f058e9c153) C:\WINDOWS\system32\drivers\nmwcdcm.sys
20:28:11.0046 3796 nmwcdcm - ok
20:28:11.0062 3796 Npfs (3182d64ae053d6fb034f44b6def8034a) C:\WINDOWS\system32\drivers\Npfs.sys
20:28:11.0062 3796 Npfs - ok
20:28:11.0156 3796 Ntfs (78a08dd6a8d65e697c18e1db01c5cdca) C:\WINDOWS\system32\drivers\Ntfs.sys
20:28:11.0156 3796 Ntfs - ok
20:28:11.0171 3796 NtLmSsp (bf2466b3e18e970d8a976fb95fc1ca85) C:\WINDOWS\system32\lsass.exe
20:28:11.0171 3796 NtLmSsp - ok
20:28:11.0218 3796 NtmsSvc (156f64a3345bd23c600655fb4d10bc08) C:\WINDOWS\system32\ntmssvc.dll
20:28:11.0234 3796 NtmsSvc - ok
20:28:11.0281 3796 Null (73c1e1f395918bc2c6dd67af7591a3ad) C:\WINDOWS\system32\drivers\Null.sys
20:28:11.0281 3796 Null - ok
20:28:11.0328 3796 NwlnkFlt (b305f3fad35083837ef46a0bbce2fc57) C:\WINDOWS\system32\DRIVERS\nwlnkflt.sys
20:28:11.0328 3796 NwlnkFlt - ok
20:28:11.0343 3796 NwlnkFwd (c99b3415198d1aab7227f2c88fd664b9) C:\WINDOWS\system32\DRIVERS\nwlnkfwd.sys
20:28:11.0343 3796 NwlnkFwd - ok
20:28:11.0359 3796 ohci1394 (ca33832df41afb202ee7aeb05145922f) C:\WINDOWS\system32\DRIVERS\ohci1394.sys
20:28:11.0359 3796 ohci1394 - ok
20:28:11.0390 3796 Parport (5575faf8f97ce5e713d108c2a58d7c7c) C:\WINDOWS\system32\drivers\Parport.sys
20:28:11.0390 3796 Parport - ok
20:28:11.0437 3796 PartMgr (beb3ba25197665d82ec7065b724171c6) C:\WINDOWS\system32\drivers\PartMgr.sys
20:28:11.0437 3796 PartMgr - ok
20:28:11.0484 3796 ParVdm (70e98b3fd8e963a6a46a2e6247e0bea1) C:\WINDOWS\system32\drivers\ParVdm.sys
20:28:11.0484 3796 ParVdm - ok
20:28:11.0500 3796 PCI (a219903ccf74233761d92bef471a07b1) C:\WINDOWS\system32\DRIVERS\pci.sys
20:28:11.0500 3796 PCI - ok
20:28:11.0500 3796 PCIDump - ok
20:28:11.0515 3796 PCIIde (ccf5f451bb1a5a2a522a76e670000ff0) C:\WINDOWS\system32\drivers\PCIIde.sys
20:28:11.0531 3796 PCIIde - ok
20:28:11.0578 3796 PCLEPCI (1bebe7de8508a02650cdce45c664c2a2) C:\WINDOWS\system32\drivers\pclepci.sys
20:28:11.0578 3796 PCLEPCI - ok
20:28:11.0625 3796 Pcmcia (9e89ef60e9ee05e3f2eef2da7397f1c1) C:\WINDOWS\system32\drivers\Pcmcia.sys
20:28:11.0625 3796 Pcmcia - ok
20:28:11.0625 3796 PDCOMP - ok
20:28:11.0640 3796 PDFRAME - ok
20:28:11.0640 3796 PDRELI - ok
20:28:11.0656 3796 PDRFRAME - ok
20:28:11.0656 3796 perc2 - ok
20:28:11.0671 3796 perc2hib - ok
20:28:11.0859 3796 PhotoshopElementsDeviceConnect (e9ca440fe7a5957eb2eb0c587958dd29) C:\Program Files\Adobe\Photoshop Elements 3.0\PhotoshopElementsDeviceConnect.exe
20:28:11.0859 3796 PhotoshopElementsDeviceConnect - ok
20:28:11.0906 3796 PID_0928 (5bd2c6d982481d548107c602e7ccfbbc) C:\WINDOWS\system32\DRIVERS\LV561AV.SYS
20:28:11.0921 3796 PID_0928 - ok
20:28:11.0953 3796 PIXMCV (5c08d25808a7ed574102ea832fbb1400) C:\WINDOWS\system32\Drivers\pixmcvc.sys
20:28:11.0968 3796 PIXMCV - ok
20:28:11.0984 3796 PIXMCVA (2cecad203aded777e8a46e2a01971147) C:\WINDOWS\system32\Drivers\pixmcva.sys
20:28:11.0984 3796 PIXMCVA - ok
20:28:12.0015 3796 PIXMCVV (2bdeef8b900e18de526ae8586ce6c680) C:\WINDOWS\system32\Drivers\pixmcvv.sys
20:28:12.0015 3796 PIXMCVV - ok
20:28:12.0046 3796 PlugPlay (65df52f5b8b6e9bbd183505225c37315) C:\WINDOWS\system32\services.exe
20:28:12.0062 3796 PlugPlay - ok
20:28:12.0125 3796 Pml Driver HPZ12 (2d091a99624fb9e7eef0a86d872ec0c3) C:\WINDOWS\system32\HPZipm12.exe
20:28:12.0125 3796 Pml Driver HPZ12 - ok
20:28:12.0171 3796 PolicyAgent (bf2466b3e18e970d8a976fb95fc1ca85) C:\WINDOWS\system32\lsass.exe
20:28:12.0171 3796 PolicyAgent - ok
20:28:12.0234 3796 PptpMiniport (efeec01b1d3cf84f16ddd24d9d9d8f99) C:\WINDOWS\system32\DRIVERS\raspptp.sys
20:28:12.0234 3796 PptpMiniport - ok
20:28:12.0265 3796 PRISM_A02 (c383926d4ba41afbca592b2ad1fe4109) C:\WINDOWS\system32\DRIVERS\PRISMA02.sys
20:28:12.0265 3796 PRISM_A02 - ok
20:28:12.0265 3796 ProtectedStorage (bf2466b3e18e970d8a976fb95fc1ca85) C:\WINDOWS\system32\lsass.exe
20:28:12.0281 3796 ProtectedStorage - ok
20:28:12.0328 3796 PSched (09298ec810b07e5d582cb3a3f9255424) C:\WINDOWS\system32\DRIVERS\psched.sys
20:28:12.0328 3796 PSched - ok
20:28:12.0375 3796 Ptilink (80d317bd1c3dbc5d4fe7b1678c60cadd) C:\WINDOWS\system32\DRIVERS\ptilink.sys
20:28:12.0390 3796 Ptilink - ok
20:28:12.0421 3796 PxHelp20 (153d02480a0a2f45785522e814c634b6) C:\WINDOWS\system32\Drivers\PxHelp20.sys
20:28:12.0468 3796 PxHelp20 - ok
20:28:12.0484 3796 ql1080 - ok
20:28:12.0484 3796 Ql10wnt - ok
20:28:12.0500 3796 ql12160 - ok
20:28:12.0500 3796 ql1240 - ok
20:28:12.0515 3796 ql1280 - ok
20:28:12.0562 3796 RasAcd (fe0d99d6f31e4fad8159f690d68ded9c) C:\WINDOWS\system32\DRIVERS\rasacd.sys
20:28:12.0562 3796 RasAcd - ok
20:28:12.0609 3796 RasAuto (ad188be7bdf94e8df4ca0a55c00a5073) C:\WINDOWS\System32\rasauto.dll
20:28:12.0609 3796 RasAuto - ok
20:28:12.0656 3796 Rasl2tp (11b4a627bc9614b885c4969bfa5ff8a6) C:\WINDOWS\system32\DRIVERS\rasl2tp.sys
20:28:12.0656 3796 Rasl2tp - ok
20:28:12.0718 3796 RasMan (76a9a3cbeadd68cc57cda5e1d7448235) C:\WINDOWS\System32\rasmans.dll
20:28:12.0718 3796 RasMan - ok
20:28:12.0750 3796 RasPppoe (5bc962f2654137c9909c3d4603587dee) C:\WINDOWS\system32\DRIVERS\raspppoe.sys
20:28:12.0750 3796 RasPppoe - ok
20:28:12.0750 3796 Raspti (fdbb1d60066fcfbb7452fd8f9829b242) C:\WINDOWS\system32\DRIVERS\raspti.sys
20:28:12.0765 3796 Raspti - ok
20:28:12.0796 3796 Rdbss (7ad224ad1a1437fe28d89cf22b17780a) C:\WINDOWS\system32\DRIVERS\rdbss.sys
20:28:12.0796 3796 Rdbss - ok
20:28:12.0859 3796 RDPCDD (4912d5b403614ce99c28420f75353332) C:\WINDOWS\system32\DRIVERS\RDPCDD.sys
20:28:12.0859 3796 RDPCDD - ok
20:28:12.0906 3796 RDPWD (5b3055daa788bd688594d2f5981f2a83) C:\WINDOWS\system32\drivers\RDPWD.sys
20:28:12.0921 3796 RDPWD - ok
20:28:12.0968 3796 RDSessMgr (3c37bf86641bda977c3bf8a840f3b7fa) C:\WINDOWS\system32\sessmgr.exe
20:28:12.0968 3796 RDSessMgr - ok
20:28:13.0031 3796 redbook (f828dd7e1419b6653894a8f97a0094c5) C:\WINDOWS\system32\DRIVERS\redbook.sys
20:28:13.0046 3796 redbook - ok
20:28:13.0078 3796 RemoteAccess (7e699ff5f59b5d9de5390e3c34c67cf5) C:\WINDOWS\System32\mprdim.dll
20:28:13.0078 3796 RemoteAccess - ok
20:28:13.0140 3796 RpcLocator (aaed593f84afa419bbae8572af87cf6a) C:\WINDOWS\system32\locator.exe
20:28:13.0140 3796 RpcLocator - ok
20:28:13.0218 3796 RpcSs (6b27a5c03dfb94b4245739065431322c) C:\WINDOWS\System32\rpcss.dll
20:28:13.0234 3796 RpcSs - ok
20:28:13.0312 3796 RSVP (471b3f9741d762abe75e9deea4787e47) C:\WINDOWS\system32\rsvp.exe
20:28:13.0312 3796 RSVP - ok
20:28:13.0375 3796 RTL8023xp (7f0413bdd7d53eb4c7a371e7f6f84df1) C:\WINDOWS\system32\DRIVERS\Rtlnicxp.sys
20:28:13.0375 3796 RTL8023xp - ok
20:28:13.0421 3796 rtl8139 (d507c1400284176573224903819ffda3) C:\WINDOWS\system32\DRIVERS\RTL8139.SYS
20:28:13.0421 3796 rtl8139 - ok
20:28:13.0468 3796 SamSs (bf2466b3e18e970d8a976fb95fc1ca85) C:\WINDOWS\system32\lsass.exe
20:28:13.0468 3796 SamSs - ok
20:28:13.0468 3796 SCardSvr - ok
20:28:13.0546 3796 Schedule (0a9a7365a1ca4319aa7c1d6cd8e4eafa) C:\WINDOWS\system32\schedsvc.dll
20:28:13.0546 3796 Schedule - ok
20:28:13.0593 3796 Secdrv (90a3935d05b494a5a39d37e71f09a677) C:\WINDOWS\system32\DRIVERS\secdrv.sys
20:28:13.0593 3796 Secdrv - ok
20:28:13.0640 3796 seclogon (cbe612e2bb6a10e3563336191eda1250) C:\WINDOWS\System32\seclogon.dll
20:28:13.0640 3796 seclogon - ok
20:28:13.0656 3796 SENS (7fdd5d0684eca8c1f68b4d99d124dcd0) C:\WINDOWS\system32\sens.dll
20:28:13.0656 3796 SENS - ok
20:28:13.0671 3796 serenum (0f29512ccd6bead730039fb4bd2c85ce) C:\WINDOWS\system32\DRIVERS\serenum.sys
20:28:13.0671 3796 serenum - ok
20:28:13.0718 3796 Serial (cca207a8896d4c6a0c9ce29a4ae411a7) C:\WINDOWS\system32\DRIVERS\serial.sys
20:28:13.0718 3796 Serial - ok
20:28:13.0906 3796 ServiceLayer (019ab047b932ad277a4da2673e5cc19c) C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
20:28:13.0906 3796 ServiceLayer - ok
20:28:13.0968 3796 Sfloppy (8e6b8c671615d126fdc553d1e2de5562) C:\WINDOWS\system32\drivers\Sfloppy.sys
20:28:13.0968 3796 Sfloppy - ok
20:28:14.0046 3796 SharedAccess (83f41d0d89645d7235c051ab1d9523ac) C:\WINDOWS\System32\ipnathlp.dll
20:28:14.0046 3796 SharedAccess - ok
20:28:14.0109 3796 ShellHWDetection (99bc0b50f511924348be19c7c7313bbf) C:\WINDOWS\System32\shsvcs.dll
20:28:14.0109 3796 ShellHWDetection - ok
20:28:14.0109 3796 Simbad - ok
20:28:14.0156 3796 SLIP (866d538ebe33709a5c9f5c62b73b7d14) C:\WINDOWS\system32\DRIVERS\SLIP.sys
20:28:14.0156 3796 SLIP - ok
20:28:14.0171 3796 SONYPVU1 (a1eceeaa5c5e74b2499eb51d38185b84) C:\WINDOWS\system32\DRIVERS\SONYPVU1.SYS
20:28:14.0171 3796 SONYPVU1 - ok
20:28:14.0187 3796 Sparrow - ok
20:28:14.0234 3796 splitter (ab8b92451ecb048a4d1de7c3ffcb4a9f) C:\WINDOWS\system32\drivers\splitter.sys
20:28:14.0234 3796 splitter - ok
20:28:14.0296 3796 Spooler (60784f891563fb1b767f70117fc2428f) C:\WINDOWS\system32\spoolsv.exe
20:28:14.0296 3796 Spooler - ok
20:28:14.0312 3796 sr (76bb022c2fb6902fd5bdd4f78fc13a5d) C:\WINDOWS\system32\DRIVERS\sr.sys
20:28:14.0312 3796 sr - ok
20:28:14.0375 3796 srservice (3805df0ac4296a34ba4bf93b346cc378) C:\WINDOWS\system32\srsvc.dll
20:28:14.0390 3796 srservice - ok
20:28:14.0437 3796 Srv (47ddfc2f003f7f9f0592c6874962a2e7) C:\WINDOWS\system32\DRIVERS\srv.sys
20:28:14.0437 3796 Srv - ok
20:28:14.0484 3796 SSDPSRV (0a5679b3714edab99e357057ee88fca6) C:\WINDOWS\System32\ssdpsrv.dll
20:28:14.0484 3796 SSDPSRV - ok
20:28:14.0562 3796 stisvc (8bad69cbac032d4bbacfce0306174c30) C:\WINDOWS\system32\wiaservc.dll
20:28:14.0578 3796 stisvc - ok
20:28:14.0640 3796 streamip (77813007ba6265c4b6098187e6ed79d2) C:\WINDOWS\system32\DRIVERS\StreamIP.sys
20:28:14.0640 3796 streamip - ok
20:28:14.0671 3796 swenum (3941d127aef12e93addf6fe6ee027e0f) C:\WINDOWS\system32\DRIVERS\swenum.sys
20:28:14.0671 3796 swenum - ok
20:28:14.0687 3796 swmidi (8ce882bcc6cf8a62f2b2323d95cb3d01) C:\WINDOWS\system32\drivers\swmidi.sys
20:28:14.0687 3796 swmidi - ok
20:28:14.0687 3796 SwPrv - ok
20:28:14.0703 3796 symc810 - ok
20:28:14.0703 3796 symc8xx - ok
20:28:14.0718 3796 sym_hi - ok
20:28:14.0718 3796 sym_u3 - ok
20:28:14.0765 3796 sysaudio (8b83f3ed0f1688b4958f77cd6d2bf290) C:\WINDOWS\system32\drivers\sysaudio.sys
20:28:14.0765 3796 sysaudio - ok
20:28:14.0890 3796 SysmonLog (c7abbc59b43274b1109df6b24d617051) C:\WINDOWS\system32\smlogsvc.exe
20:28:14.0890 3796 SysmonLog - ok
20:28:15.0000 3796 TapiSrv (3cb78c17bb664637787c9a1c98f79c38) C:\WINDOWS\System32\tapisrv.dll
20:28:15.0000 3796 TapiSrv - ok
20:28:15.0078 3796 Tcpip (9aefa14bd6b182d61e3119fa5f436d3d) C:\WINDOWS\system32\DRIVERS\tcpip.sys
20:28:15.0078 3796 Tcpip - ok
20:28:15.0140 3796 TDPIPE (6471a66807f5e104e4885f5b67349397) C:\WINDOWS\system32\drivers\TDPIPE.sys
20:28:15.0140 3796 TDPIPE - ok
20:28:15.0140 3796 TDTCP (c56b6d0402371cf3700eb322ef3aaf61) C:\WINDOWS\system32\drivers\TDTCP.sys
20:28:15.0140 3796 TDTCP - ok
20:28:15.0187 3796 TermDD (88155247177638048422893737429d9e) C:\WINDOWS\system32\DRIVERS\termdd.sys
20:28:15.0187 3796 TermDD - ok
20:28:15.0265 3796 TermService (ff3477c03be7201c294c35f684b3479f) C:\WINDOWS\System32\termsrv.dll
20:28:15.0281 3796 TermService - ok
20:28:15.0390 3796 Themes (99bc0b50f511924348be19c7c7313bbf) C:\WINDOWS\System32\shsvcs.dll
20:28:15.0390 3796 Themes - ok
20:28:15.0406 3796 TosIde - ok
20:28:15.0484 3796 TrkWks (55bca12f7f523d35ca3cb833c725f54e) C:\WINDOWS\system32\trkwks.dll
20:28:15.0500 3796 TrkWks - ok
20:28:15.0531 3796 TVICHW32 (e266683fc95abdec17cd378564e1b54b) C:\WINDOWS\system32\DRIVERS\TVICHW32.SYS
20:28:15.0531 3796 TVICHW32 - ok
20:28:15.0546 3796 Udfs (5787b80c2e3c5e2f56c2a233d91fa2c9) C:\WINDOWS\system32\drivers\Udfs.sys
20:28:15.0546 3796 Udfs - ok
20:28:15.0562 3796 ultra - ok
20:28:15.0625 3796 Update (402ddc88356b1bac0ee3dd1580c76a31) C:\WINDOWS\system32\DRIVERS\update.sys
20:28:15.0640 3796 Update - ok
20:28:15.0703 3796 upnphost (1ebafeb9a3fbdc41b8d9c7f0f687ad91) C:\WINDOWS\System32\upnphost.dll
20:28:15.0703 3796 upnphost - ok
20:28:15.0734 3796 UPS (05365fb38fca1e98f7a566aaaf5d1815) C:\WINDOWS\System32\ups.exe
20:28:15.0734 3796 UPS - ok
20:28:15.0796 3796 USBAAPL (f340199e8cb097e1acd58a967c665919) C:\WINDOWS\system32\Drivers\usbaapl.sys
20:28:15.0796 3796 USBAAPL - ok
20:28:15.0828 3796 usbccgp (173f317ce0db8e21322e71b7e60a27e8) C:\WINDOWS\system32\DRIVERS\usbccgp.sys
20:28:15.0828 3796 usbccgp - ok
20:28:15.0843 3796 usbehci (65dcf09d0e37d4c6b11b5b0b76d470a7) C:\WINDOWS\system32\DRIVERS\usbehci.sys
20:28:15.0843 3796 usbehci - ok
20:28:15.0906 3796 usbhub (1ab3cdde553b6e064d2e754efe20285c) C:\WINDOWS\system32\DRIVERS\usbhub.sys
20:28:15.0921 3796 usbhub - ok
20:28:15.0968 3796 usbprint (a717c8721046828520c9edf31288fc00) C:\WINDOWS\system32\DRIVERS\usbprint.sys
20:28:15.0968 3796 usbprint - ok
20:28:16.0000 3796 usbscan (a0b8cf9deb1184fbdd20784a58fa75d4) C:\WINDOWS\system32\DRIVERS\usbscan.sys
20:28:16.0000 3796 usbscan - ok
20:28:16.0031 3796 usbser (1c888b000c2f9492f4b15b5b6b84873e) C:\WINDOWS\system32\DRIVERS\usbser.sys
20:28:16.0031 3796 usbser - ok
20:28:16.0062 3796 usbsermpt (caad3467fbfae8a380f67e9c7150a85e) C:\WINDOWS\system32\DRIVERS\usbsermpt.sys
20:28:16.0062 3796 usbsermpt - ok
20:28:16.0062 3796 usbstor (a32426d9b14a089eaa1d922e0c5801a9) C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS
20:28:16.0078 3796 usbstor - ok
20:28:16.0125 3796 usbuhci (26496f9dee2d787fc3e61ad54821ffe6) C:\WINDOWS\system32\DRIVERS\usbuhci.sys
20:28:16.0125 3796 usbuhci - ok
20:28:16.0156 3796 VgaSave (0d3a8fafceacd8b7625cd549757a7df1) C:\WINDOWS\System32\drivers\vga.sys
20:28:16.0156 3796 VgaSave - ok
20:28:16.0156 3796 ViaIde - ok
20:28:16.0203 3796 VolSnap (4c8fcb5cc53aab716d810740fe59d025) C:\WINDOWS\system32\drivers\VolSnap.sys
20:28:16.0203 3796 VolSnap - ok
20:28:16.0281 3796 VSS (7a9db3a67c333bf0bd42e42b8596854b) C:\WINDOWS\System32\vssvc.exe
20:28:16.0281 3796 VSS - ok
20:28:16.0312 3796 W32Time (54af4b1d5459500ef0937f6d33b1914f) C:\WINDOWS\system32\w32time.dll
20:28:16.0328 3796 W32Time - ok
20:28:16.0375 3796 Wanarp (e20b95baedb550f32dd489265c1da1f6) C:\WINDOWS\system32\DRIVERS\wanarp.sys
20:28:16.0390 3796 Wanarp - ok
20:28:16.0390 3796 WDICA - ok
20:28:16.0406 3796 wdmaud (6768acf64b18196494413695f0c3a00f) C:\WINDOWS\system32\drivers\wdmaud.sys
20:28:16.0406 3796 wdmaud - ok
20:28:16.0468 3796 WebClient (77a354e28153ad2d5e120a5a8687bc06) C:\WINDOWS\System32\webclnt.dll
20:28:16.0468 3796 WebClient - ok
20:28:16.0578 3796 winachsf (ce545a84bf3411e7516fa8da51ad9d93) C:\WINDOWS\system32\DRIVERS\HSF_CNXT.sys
20:28:16.0593 3796 winachsf - ok
20:28:16.0703 3796 WinDefend (f45dd1e1365d857dd08bc23563370d0e) C:\Program Files\Windows Defender\MsMpEng.exe
20:28:16.0703 3796 WinDefend - ok
20:28:16.0812 3796 winmgmt (2d0e4ed081963804ccc196a0929275b5) C:\WINDOWS\system32\wbem\WMIsvc.dll
20:28:16.0828 3796 winmgmt - ok
20:28:16.0906 3796 WLSetupSvc (94a85e956a065e23e0010a6a7826243b) C:\Program Files\Windows Live\installer\WLSetupSvc.exe
20:28:16.0906 3796 WLSetupSvc - ok
20:28:16.0937 3796 WmdmPmSN (c51b4a5c05a5475708e3c81c7765b71d) C:\WINDOWS\system32\MsPMSNSv.dll
20:28:16.0937 3796 WmdmPmSN - ok
20:28:17.0000 3796 WmiApSrv (e0673f1106e62a68d2257e376079f821) C:\WINDOWS\system32\wbem\wmiapsrv.exe
20:28:17.0000 3796 WmiApSrv - ok
20:28:17.0156 3796 WMPNetworkSvc (f74e3d9a7fa9556c3bbb14d4e5e63d3b) C:\Program Files\Windows Media Player\WMPNetwk.exe
20:28:17.0187 3796 WMPNetworkSvc - ok
20:28:17.0234 3796 wscsvc (7c278e6408d1dce642230c0585a854d5) C:\WINDOWS\system32\wscsvc.dll
20:28:17.0250 3796 wscsvc - ok
20:28:17.0296 3796 WSTCODEC (c98b39829c2bbd34e454150633c62c78) C:\WINDOWS\system32\DRIVERS\WSTCODEC.SYS
20:28:17.0296 3796 WSTCODEC - ok
20:28:17.0328 3796 wuauserv (35321fb577cdc98ce3eb3a3eb9e4610a) C:\WINDOWS\system32\wuauserv.dll
20:28:17.0328 3796 wuauserv - ok
20:28:17.0390 3796 WudfPf (50eb9e21963b4f06fd010d007d54351b) C:\WINDOWS\system32\DRIVERS\WudfPf.sys
20:28:17.0390 3796 WudfPf - ok
20:28:17.0421 3796 WudfRd (6e209664bdea8a15b5e8e480d6c607c2) C:\WINDOWS\system32\DRIVERS\wudfrd.sys
20:28:17.0421 3796 WudfRd - ok
20:28:17.0468 3796 WudfSvc (ae93084d2d236887ba56467ae42b4955) C:\WINDOWS\System32\WUDFSvc.dll
20:28:17.0468 3796 WudfSvc - ok
20:28:17.0531 3796 WZCSVC (81dc3f549f44b1c1fff022dec9ecf30b) C:\WINDOWS\System32\wzcsvc.dll
20:28:17.0546 3796 WZCSVC - ok
20:28:17.0578 3796 xmlprov (295d21f14c335b53cb8154e5b1f892b9) C:\WINDOWS\System32\xmlprov.dll
20:28:17.0593 3796 xmlprov - ok
20:28:17.0625 3796 MBR (0x1B8) (8f558eb6672622401da993e1e865c861) \Device\Harddisk0\DR0
20:28:17.0796 3796 \Device\Harddisk0\DR0 - ok
20:28:17.0796 3796 Boot (0x1200) (72df94b034316e55cad91980b1e3bfa6) \Device\Harddisk0\DR0\Partition0
20:28:17.0796 3796 \Device\Harddisk0\DR0\Partition0 - ok
20:28:17.0796 3796 ============================================================
20:28:17.0796 3796 Scan finished
20:28:17.0812 3752 Detected object count: 0
20:28:17.0812 3752 Actual detected object count: 0
20:41:28.0421 2948 Deinitialize success
TDSSkiller log 2
23:31:18.0796 2036 TDSS rootkit removing tool 2.7.33.0 Apr 24 2012 18:43:43
23:31:19.0000 2036 ============================================================
23:31:19.0000 2036 Current date / time: 2012/05/01 23:31:19.0000
23:31:19.0000 2036 SystemInfo:
23:31:19.0000 2036
23:31:19.0000 2036 OS Version: 5.1.2600 ServicePack: 3.0
23:31:19.0000 2036 Product type: Workstation
23:31:19.0000 2036 ComputerName: YOUR-4AD98E1252
23:31:19.0000 2036 UserName: Stephen
23:31:19.0000 2036 Windows directory: C:\WINDOWS
23:31:19.0000 2036 System windows directory: C:\WINDOWS
23:31:19.0000 2036 Processor architecture: Intel x86
23:31:19.0000 2036 Number of processors: 2
23:31:19.0000 2036 Page size: 0x1000
23:31:19.0000 2036 Boot type: Normal boot
23:31:21.0453 2036 Drive \Device\Harddisk0\DR0 - Size: 0x25433D6000 (149.05 Gb), SectorSize: 0x200, Cylinders: 0x4C01, SectorsPerTrack: 0x3F, TracksPerCylinder: 0xFF, Type 'K0', Flags 0x00000054
23:31:21.0484 2036 ============================================================
23:31:21.0484 2036 \Device\Harddisk0\DR0:
23:31:21.0531 2036 MBR partitions:
23:31:21.0531 2036 \Device\Harddisk0\DR0\Partition0: MBR, Type 0x7, StartLBA 0x3F, BlocksNum 0x12A18A82
23:31:21.0531 2036 ============================================================
23:31:21.0578 2036 C: <-> \Device\Harddisk0\DR0\Partition0
23:31:21.0578 2036 ============================================================
23:31:21.0578 2036 Initialize success
23:31:29.0500 2024 Deinitialize success
wildfly73
Post by wildfly73 on Wed 02 May 2012, 5:53 am
Hello, after running TDSSkiller i feel we have made good progress. i rebooted without Windows Recovery Environment. I was now able to download SAS! Below are two SAS scan logs 1st quick scan 2nd complete scan.
SUPERAntiSpyware Scan Log
Generated 05/01/2012 at 09:17 PM
Application Version : 5.0.1148
Core Rules Database Version : 8535
Trace Rules Database Version: 6347
Scan type : Quick Scan
Total Scan Time : 00:24:52
Operating System Information
Windows XP Home Edition 32-bit, Service Pack 3 (Build 5.01.2600)
Memory items scanned : 529
Memory threats detected : 0
Registry items scanned : 29850
Registry threats detected : 0
File items scanned : 17724
File threats detected : 522
Trojan.Agent/Gen-FakeAntiSpy
C:\DOCUMENTS AND SETTINGS\ALL USERS\APPLICATION DATA\JL6SVP0H5ESLEV.EXE
C:\WINDOWS\Prefetch\JL6SVP0H5ESLEV.EXE-2DDEBA6B.pf
PUP.Whitesmoke
C:\Program Files\WHITESMOKE
Adware.Tracking Cookie
C:\Documents and Settings\Stephen\Cookies\stephen@006.free-counters.co[2].txt [ /006.free-counters.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@112.2o7[2].txt [ /112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@122.2o7[2].txt [ /122.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@122.2o7[3].txt [ /122.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@192com.112.2o7[1].txt [ /192com.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@2012-thecountdown[1].txt [ /2012-thecountdown ]
C:\Documents and Settings\Stephen\Cookies\stephen@247realmedia[2].txt [ /247realmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@2o7[2].txt [ /2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@77tracking[1].txt [ /77tracking ]
C:\Documents and Settings\Stephen\Cookies\stephen@a1.interclick[2].txt [ /a1.interclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@account.live[2].txt [ /account.live ]
C:\Documents and Settings\Stephen\Cookies\stephen@accounts.google[3].txt [ /accounts.google ]
C:\Documents and Settings\Stephen\Cookies\stephen@ad.360yield[1].txt [ /ad.360yield ]
C:\Documents and Settings\Stephen\Cookies\stephen@ad.adperium[1].txt [ /ad.adperium ]
C:\Documents and Settings\Stephen\Cookies\stephen@ad.bodybuilding[2].txt [ /ad.bodybuilding ]
C:\Documents and Settings\Stephen\Cookies\stephen@ad.pitattomatch[1].txt [ /ad.pitattomatch ]
C:\Documents and Settings\Stephen\Cookies\stephen@ad.yieldmanager[1].txt [ /ad.yieldmanager ]
C:\Documents and Settings\Stephen\Cookies\stephen@ad.zanox[2].txt [ /ad.zanox ]
C:\Documents and Settings\Stephen\Cookies\stephen@ad1.emediate[1].txt [ /ad1.emediate ]
C:\Documents and Settings\Stephen\Cookies\stephen@adbrite[1].txt [ /adbrite ]
C:\Documents and Settings\Stephen\Cookies\stephen@adform[1].txt [ /adform ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.ad4game[2].txt [ /ads.ad4game ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.adap[2].txt [ /ads.adap ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.anm.co[2].txt [ /ads.anm.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.aol.co[1].txt [ /ads.aol.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.associatedcontent[1].txt [ /ads.associatedcontent ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.audience2media[2].txt [ /ads.audience2media ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.audience2media[3].txt [ /ads.audience2media ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.bleepingcomputer[2].txt [ /ads.bleepingcomputer ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.blogtalkradio[2].txt [ /ads.blogtalkradio ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.blogtalkradio[3].txt [ /ads.blogtalkradio ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.carocean.co[1].txt [ /ads.carocean.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.ctasnet[2].txt [ /ads.ctasnet ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.foodbuzz[2].txt [ /ads.foodbuzz ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.gmodules[2].txt [ /ads.gmodules ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.monster[1].txt [ /ads.monster ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.monster[2].txt [ /ads.monster ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.moviemaker[1].txt [ /ads.moviemaker ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.nsi-ltd[2].txt [ /ads.nsi-ltd ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.ogdenpubs[1].txt [ /ads.ogdenpubs ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.pubmatic[2].txt [ /ads.pubmatic ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.raasnet[1].txt [ /ads.raasnet ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.roiserver[2].txt [ /ads.roiserver ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.simonandschuster[1].txt [ /ads.simonandschuster ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.telegraph.co[1].txt [ /ads.telegraph.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.torrentreactor[2].txt [ /ads.torrentreactor ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.uknetguide.co[1].txt [ /ads.uknetguide.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.verticalscope[1].txt [ /ads.verticalscope ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.viddler[2].txt [ /ads.viddler ]
C:\Documents and Settings\Stephen\Cookies\stephen@ads.widgetbucks[2].txt [ /ads.widgetbucks ]
C:\Documents and Settings\Stephen\Cookies\stephen@adsenserecipe[1].txt [ /adsenserecipe ]
C:\Documents and Settings\Stephen\Cookies\stephen@adserver.adtechus[1].txt [ /adserver.adtechus ]
C:\Documents and Settings\Stephen\Cookies\stephen@adserver.adtechus[2].txt [ /adserver.adtechus ]
C:\Documents and Settings\Stephen\Cookies\stephen@adtech.staticwhich.co[2].txt [ /adtech.staticwhich.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@adtech.staticwhich.co[3].txt [ /adtech.staticwhich.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@adtech[1].txt [ /adtech ]
C:\Documents and Settings\Stephen\Cookies\stephen@advertising[1].txt [ /advertising ]
C:\Documents and Settings\Stephen\Cookies\stephen@advertstream[2].txt [ /advertstream ]
C:\Documents and Settings\Stephen\Cookies\stephen@adviva[1].txt [ /adviva ]
C:\Documents and Settings\Stephen\Cookies\stephen@adxpose[1].txt [ /adxpose ]
C:\Documents and Settings\Stephen\Cookies\stephen@adxpose[2].txt [ /adxpose ]
C:\Documents and Settings\Stephen\Cookies\stephen@aimfar.solution.weborama[1].txt [ /aimfar.solution.weborama ]
C:\Documents and Settings\Stephen\Cookies\stephen@aimfar.solution.weborama[2].txt [ /aimfar.solution.weborama ]
C:\Documents and Settings\Stephen\Cookies\stephen@airfrance.bannerfactory[1].txt [ /airfrance.bannerfactory ]
C:\Documents and Settings\Stephen\Cookies\stephen@allyours.virginmedia[2].txt [ /allyours.virginmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@amazonmerchants.122.2o7[1].txt [ /amazonmerchants.122.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@amazonmerchants.122.2o7[2].txt [ /amazonmerchants.122.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@andomedia[1].txt [ /andomedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@anrtx.tacoda[1].txt [ /anrtx.tacoda ]
C:\Documents and Settings\Stephen\Cookies\stephen@apmebf[2].txt [ /apmebf ]
C:\Documents and Settings\Stephen\Cookies\stephen@askavetquestion[2].txt [ /askavetquestion ]
C:\Documents and Settings\Stephen\Cookies\stephen@at.atwola[2].txt [ /at.atwola ]
C:\Documents and Settings\Stephen\Cookies\stephen@atdmt[1].txt [ /atdmt ]
C:\Documents and Settings\Stephen\Cookies\stephen@atdmt[3].txt [ /atdmt ]
C:\Documents and Settings\Stephen\Cookies\stephen@audience2media[1].txt [ /audience2media ]
C:\Documents and Settings\Stephen\Cookies\stephen@audience2media[2].txt [ /audience2media ]
C:\Documents and Settings\Stephen\Cookies\stephen@audience2media[3].txt [ /audience2media ]
C:\Documents and Settings\Stephen\Cookies\stephen@audit.median[1].txt [ /audit.median ]
C:\Documents and Settings\Stephen\Cookies\stephen@azjmp[2].txt [ /azjmp ]
C:\Documents and Settings\Stephen\Cookies\stephen@baa.solution.weborama[2].txt [ /baa.solution.weborama ]
C:\Documents and Settings\Stephen\Cookies\stephen@banners.bgmaps[2].txt [ /banners.bgmaps ]
C:\Documents and Settings\Stephen\Cookies\stephen@bannersng.yell[1].txt [ /bannersng.yell ]
C:\Documents and Settings\Stephen\Cookies\stephen@bannersng.yell[2].txt [ /bannersng.yell ]
C:\Documents and Settings\Stephen\Cookies\stephen@bittorrent.click-new-download[1].txt [ /bittorrent.click-new-download ]
C:\Documents and Settings\Stephen\Cookies\stephen@bizrate[1].txt [ /bizrate ]
C:\Documents and Settings\Stephen\Cookies\stephen@bluestreak[2].txt [ /bluestreak ]
C:\Documents and Settings\Stephen\Cookies\stephen@bmuk.burstnet[2].txt [ /bmuk.burstnet ]
C:\Documents and Settings\Stephen\Cookies\stephen@bmuk.burstnet[3].txt [ /bmuk.burstnet ]
C:\Documents and Settings\Stephen\Cookies\stephen@bookdiscountlinks.blogspot[1].txt [ /bookdiscountlinks.blogspot ]
C:\Documents and Settings\Stephen\Cookies\stephen@bravenet[2].txt [ /bravenet ]
C:\Documents and Settings\Stephen\Cookies\stephen@bravenet[3].txt [ /bravenet ]
C:\Documents and Settings\Stephen\Cookies\stephen@britannia.112.2o7[1].txt [ /britannia.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@bs.serving-sys[1].txt [ /bs.serving-sys ]
C:\Documents and Settings\Stephen\Cookies\stephen@bs.serving-sys[2].txt [ /bs.serving-sys ]
C:\Documents and Settings\Stephen\Cookies\stephen@burstbeacon[2].txt [ /burstbeacon ]
C:\Documents and Settings\Stephen\Cookies\stephen@burstnet[1].txt [ /burstnet ]
C:\Documents and Settings\Stephen\Cookies\stephen@burstnet[2].txt [ /burstnet ]
C:\Documents and Settings\Stephen\Cookies\stephen@c.gigcount[2].txt [ /c.gigcount ]
C:\Documents and Settings\Stephen\Cookies\stephen@care2.112.2o7[1].txt [ /care2.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@carsparefinder.co[1].txt [ /carsparefinder.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@casalemedia[2].txt [ /casalemedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@casalemedia[3].txt [ /casalemedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@click.cashengines[2].txt [ /click.cashengines ]
C:\Documents and Settings\Stephen\Cookies\stephen@click.fspeletters[1].txt [ /click.fspeletters ]
C:\Documents and Settings\Stephen\Cookies\stephen@click.fspeletters[2].txt [ /click.fspeletters ]
C:\Documents and Settings\Stephen\Cookies\stephen@click.fspeletters[4].txt [ /click.fspeletters ]
C:\Documents and Settings\Stephen\Cookies\stephen@click.jobsgopublic[1].txt [ /click.jobsgopublic ]
C:\Documents and Settings\Stephen\Cookies\stephen@click.jobsgopublic[2].txt [ /click.jobsgopublic ]
C:\Documents and Settings\Stephen\Cookies\stephen@click.mediadome[1].txt [ /click.mediadome ]
C:\Documents and Settings\Stephen\Cookies\stephen@click2.cashengines[2].txt [ /click2.cashengines ]
C:\Documents and Settings\Stephen\Cookies\stephen@clickbank[1].txt [ /clickbank ]
C:\Documents and Settings\Stephen\Cookies\stephen@clicks.laterooms[2].txt [ /clicks.laterooms ]
C:\Documents and Settings\Stephen\Cookies\stephen@clicks.laterooms[3].txt [ /clicks.laterooms ]
C:\Documents and Settings\Stephen\Cookies\stephen@clicktrk.laterooms[2].txt [ /clicktrk.laterooms ]
C:\Documents and Settings\Stephen\Cookies\stephen@clicktrk.laterooms[3].txt [ /clicktrk.laterooms ]
C:\Documents and Settings\Stephen\Cookies\stephen@collective-media[1].txt [ /collective-media ]
C:\Documents and Settings\Stephen\Cookies\stephen@collective-media[3].txt [ /collective-media ]
C:\Documents and Settings\Stephen\Cookies\stephen@collective-media[4].txt [ /collective-media ]
C:\Documents and Settings\Stephen\Cookies\stephen@condenast.112.2o7[1].txt [ /condenast.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@content.yieldmanager[2].txt [ /content.yieldmanager ]
C:\Documents and Settings\Stephen\Cookies\stephen@content.yieldmanager[4].txt [ /content.yieldmanager ]
C:\Documents and Settings\Stephen\Cookies\stephen@counter.hitslink[1].txt [ /counter.hitslink ]
C:\Documents and Settings\Stephen\Cookies\stephen@counter2.hitslink[1].txt [ /counter2.hitslink ]
C:\Documents and Settings\Stephen\Cookies\stephen@countercentral[1].txt [ /countercentral ]
C:\Documents and Settings\Stephen\Cookies\stephen@counters.gigya[1].txt [ /counters.gigya ]
C:\Documents and Settings\Stephen\Cookies\stephen@countrywidegrounds[1].txt [ /countrywidegrounds ]
C:\Documents and Settings\Stephen\Cookies\stephen@crackyoureggprogram[2].txt [ /crackyoureggprogram ]
C:\Documents and Settings\Stephen\Cookies\stephen@dc.tremormedia[1].txt [ /dc.tremormedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@directtrack[1].txt [ /directtrack ]
C:\Documents and Settings\Stephen\Cookies\stephen@discountshoestore.co[1].txt [ /discountshoestore.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@discountvitaminsandherbs[2].txt [ /discountvitaminsandherbs ]
C:\Documents and Settings\Stephen\Cookies\stephen@divx.112.2o7[1].txt [ /divx.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@dmtracker[1].txt [ /dmtracker ]
C:\Documents and Settings\Stephen\Cookies\stephen@dmtracker[2].txt [ /dmtracker ]
C:\Documents and Settings\Stephen\Cookies\stephen@dmtracker[3].txt [ /dmtracker ]
C:\Documents and Settings\Stephen\Cookies\stephen@doubleclick[1].txt [ /doubleclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@doubleclick[2].txt [ /doubleclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6aekicnajkdp.stats.esomniture[2].txt [ /e-2dj6aekicnajkdp.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6aekioncjkcq.stats.esomniture[2].txt [ /e-2dj6aekioncjkcq.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6aelisjc5afp.stats.esomniture[2].txt [ /e-2dj6aelisjc5afp.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wal4akajikp.stats.esomniture[2].txt [ /e-2dj6wal4akajikp.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6walyciczwho.stats.esomniture[1].txt [ /e-2dj6walyciczwho.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wdl4godjokq.stats.esomniture[1].txt [ /e-2dj6wdl4godjokq.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wdmyapazwgp.stats.esomniture[2].txt [ /e-2dj6wdmyapazwgp.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wfkielc5eeo.stats.esomniture[2].txt [ /e-2dj6wfkielc5eeo.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wfkoklcjscp.stats.esomniture[2].txt [ /e-2dj6wfkoklcjscp.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wglywgczabp.stats.esomniture[2].txt [ /e-2dj6wglywgczabp.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wjkokgc5kaq.stats.esomniture[2].txt [ /e-2dj6wjkokgc5kaq.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wjkygndzido.stats.esomniture[2].txt [ /e-2dj6wjkygndzido.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wjloqjajsdo.stats.esomniture[1].txt [ /e-2dj6wjloqjajsdo.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wjlyggcpekq.stats.esomniture[1].txt [ /e-2dj6wjlyggcpekq.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wmmighcjoko.stats.esomniture[1].txt [ /e-2dj6wmmighcjoko.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wnkyggd5oko.stats.esomniture[2].txt [ /e-2dj6wnkyggd5oko.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@e-2dj6wnmyqnc5sdq.stats.esomniture[1].txt [ /e-2dj6wnmyqnc5sdq.stats.esomniture ]
C:\Documents and Settings\Stephen\Cookies\stephen@eas.apm.emediate[2].txt [ /eas.apm.emediate ]
C:\Documents and Settings\Stephen\Cookies\stephen@eas.apm.emediate[3].txt [ /eas.apm.emediate ]
C:\Documents and Settings\Stephen\Cookies\stephen@eas.apm.emediate[4].txt [ /eas.apm.emediate ]
C:\Documents and Settings\Stephen\Cookies\stephen@ehg-tfl.hitbox[2].txt [ /ehg-tfl.hitbox ]
C:\Documents and Settings\Stephen\Cookies\stephen@emediate[2].txt [ /emediate ]
C:\Documents and Settings\Stephen\Cookies\stephen@emediate[3].txt [ /emediate ]
C:\Documents and Settings\Stephen\Cookies\stephen@emediate[4].txt [ /emediate ]
C:\Documents and Settings\Stephen\Cookies\stephen@enhance[2].txt [ /enhance ]
C:\Documents and Settings\Stephen\Cookies\stephen@euroclick[1].txt [ /euroclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@euroclick[2].txt [ /euroclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@eventbrite.122.2o7[1].txt [ /eventbrite.122.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@eventbrite.122.2o7[2].txt [ /eventbrite.122.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@everyclick[1].txt [ /everyclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@eyewonder[2].txt [ /eyewonder ]
C:\Documents and Settings\Stephen\Cookies\stephen@eyewonder[3].txt [ /eyewonder ]
C:\Documents and Settings\Stephen\Cookies\stephen@fastclick[2].txt [ /fastclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@find.myrecipes[2].txt [ /find.myrecipes ]
C:\Documents and Settings\Stephen\Cookies\stephen@findaspring[1].txt [ /findaspring ]
C:\Documents and Settings\Stephen\Cookies\stephen@findaspring[2].txt [ /findaspring ]
C:\Documents and Settings\Stephen\Cookies\stephen@findhorn[1].txt [ /findhorn ]
C:\Documents and Settings\Stephen\Cookies\stephen@findingjoymovie[1].txt [ /findingjoymovie ]
C:\Documents and Settings\Stephen\Cookies\stephen@fr.at.atwola[1].txt [ /fr.at.atwola ]
C:\Documents and Settings\Stephen\Cookies\stephen@friendlytrack[2].txt [ /friendlytrack ]
C:\Documents and Settings\Stephen\Cookies\stephen@googleads.g.doubleclick[1].txt [ /googleads.g.doubleclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@guyfinley.directtrack[2].txt [ /guyfinley.directtrack ]
C:\Documents and Settings\Stephen\Cookies\stephen@hearstmagazines.112.2o7[1].txt [ /hearstmagazines.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@herbdoc.112.2o7[1].txt [ /herbdoc.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@hitbox[2].txt [ /hitbox ]
C:\Documents and Settings\Stephen\Cookies\stephen@ilead.itrack[1].txt [ /ilead.itrack ]
C:\Documents and Settings\Stephen\Cookies\stephen@imrworldwide[2].txt [ /imrworldwide ]
C:\Documents and Settings\Stephen\Cookies\stephen@imrworldwide[3].txt [ /imrworldwide ]
C:\Documents and Settings\Stephen\Cookies\stephen@imrworldwide[4].txt [ /imrworldwide ]
C:\Documents and Settings\Stephen\Cookies\stephen@in.getclicky[1].txt [ /in.getclicky ]
C:\Documents and Settings\Stephen\Cookies\stephen@in.getclicky[2].txt [ /in.getclicky ]
C:\Documents and Settings\Stephen\Cookies\stephen@insightexpressai[1].txt [ /insightexpressai ]
C:\Documents and Settings\Stephen\Cookies\stephen@interclick[1].txt [ /interclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@invitemedia[1].txt [ /invitemedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@kantarmedia[2].txt [ /kantarmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@kiddicare.solution.weborama[2].txt [ /kiddicare.solution.weborama ]
C:\Documents and Settings\Stephen\Cookies\stephen@kontera[1].txt [ /kontera ]
C:\Documents and Settings\Stephen\Cookies\stephen@kontera[2].txt [ /kontera ]
C:\Documents and Settings\Stephen\Cookies\stephen@latestnews.virginmedia[1].txt [ /latestnews.virginmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@legolas-media[2].txt [ /legolas-media ]
C:\Documents and Settings\Stephen\Cookies\stephen@lfstmedia[1].txt [ /lfstmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@lfstmedia[2].txt [ /lfstmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@liveperson[1].txt [ /liveperson ]
C:\Documents and Settings\Stephen\Cookies\stephen@liveperson[3].txt [ /liveperson ]
C:\Documents and Settings\Stephen\Cookies\stephen@liveperson[4].txt [ /liveperson ]
C:\Documents and Settings\Stephen\Cookies\stephen@liveperson[5].txt [ /liveperson ]
C:\Documents and Settings\Stephen\Cookies\stephen@lstat.youku[2].txt [ /lstat.youku ]
C:\Documents and Settings\Stephen\Cookies\stephen@lucidmedia[2].txt [ /lucidmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@measussex.org[2].txt [ /measussex.org ]
C:\Documents and Settings\Stephen\Cookies\stephen@media.cardomain[1].txt [ /media.cardomain ]
C:\Documents and Settings\Stephen\Cookies\stephen@media.easyads[2].txt [ /media.easyads ]
C:\Documents and Settings\Stephen\Cookies\stephen@media.medhelp[1].txt [ /media.medhelp ]
C:\Documents and Settings\Stephen\Cookies\stephen@media.medhelp[3].txt [ /media.medhelp ]
C:\Documents and Settings\Stephen\Cookies\stephen@media.mercola[2].txt [ /media.mercola ]
C:\Documents and Settings\Stephen\Cookies\stephen@media6degrees[1].txt [ /media6degrees ]
C:\Documents and Settings\Stephen\Cookies\stephen@media6degrees[3].txt [ /media6degrees ]
C:\Documents and Settings\Stephen\Cookies\stephen@media6degrees[4].txt [ /media6degrees ]
C:\Documents and Settings\Stephen\Cookies\stephen@mediabrandsww[1].txt [ /mediabrandsww ]
C:\Documents and Settings\Stephen\Cookies\stephen@mediaforge[1].txt [ /mediaforge ]
C:\Documents and Settings\Stephen\Cookies\stephen@mediaplex[2].txt [ /mediaplex ]
C:\Documents and Settings\Stephen\Cookies\stephen@mediaweb.musicradio[1].txt [ /mediaweb.musicradio ]
C:\Documents and Settings\Stephen\Cookies\stephen@mercola.122.2o7[1].txt [ /mercola.122.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@microsoftsto.112.2o7[1].txt [ /microsoftsto.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@mm.chitika[2].txt [ /mm.chitika ]
C:\Documents and Settings\Stephen\Cookies\stephen@mm.chitika[3].txt [ /mm.chitika ]
C:\Documents and Settings\Stephen\Cookies\stephen@movies.virginmedia[1].txt [ /movies.virginmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@msnportal.112.2o7[1].txt [ /msnportal.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@msnportal.112.2o7[2].txt [ /msnportal.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@mtvn.112.2o7[1].txt [ /mtvn.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@mywebsearch[1].txt [ /mywebsearch ]
C:\Documents and Settings\Stephen\Cookies\stephen@naturalfoodfinder.co[1].txt [ /naturalfoodfinder.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@naturalfoodfinder.co[2].txt [ /naturalfoodfinder.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@naturalfoodfinder.co[4].txt [ /naturalfoodfinder.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@oneclickpharmacy.co[2].txt [ /oneclickpharmacy.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@onlineadtracker.co[2].txt [ /onlineadtracker.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@optimize.indieclick[2].txt [ /optimize.indieclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@oracle.112.2o7[1].txt [ /oracle.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@paypal.112.2o7[2].txt [ /paypal.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@paypal.112.2o7[3].txt [ /paypal.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@popuptraffic[1].txt [ /popuptraffic ]
C:\Documents and Settings\Stephen\Cookies\stephen@pro-market[2].txt [ /pro-market ]
C:\Documents and Settings\Stephen\Cookies\stephen@pro-market[3].txt [ /pro-market ]
C:\Documents and Settings\Stephen\Cookies\stephen@propertyfinder[1].txt [ /propertyfinder ]
C:\Documents and Settings\Stephen\Cookies\stephen@propertyfinder[2].txt [ /propertyfinder ]
C:\Documents and Settings\Stephen\Cookies\stephen@questionmarket[1].txt [ /questionmarket ]
C:\Documents and Settings\Stephen\Cookies\stephen@quote.airport-parking-discounts.co[2].txt [ /quote.airport-parking-discounts.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@r1-ads.ace.advertising[2].txt [ /r1-ads.ace.advertising ]
C:\Documents and Settings\Stephen\Cookies\stephen@r1-ads.ace.advertising[3].txt [ /r1-ads.ace.advertising ]
C:\Documents and Settings\Stephen\Cookies\stephen@realmedia[2].txt [ /realmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@revsci[1].txt [ /revsci ]
C:\Documents and Settings\Stephen\Cookies\stephen@revsci[2].txt [ /revsci ]
C:\Documents and Settings\Stephen\Cookies\stephen@rts.pgmediaserve[1].txt [ /rts.pgmediaserve ]
C:\Documents and Settings\Stephen\Cookies\stephen@ru4[2].txt [ /ru4 ]
C:\Documents and Settings\Stephen\Cookies\stephen@ru4[3].txt [ /ru4 ]
C:\Documents and Settings\Stephen\Cookies\stephen@search.virginmedia[2].txt [ /search.virginmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@server.lon.liveperson[2].txt [ /server.lon.liveperson ]
C:\Documents and Settings\Stephen\Cookies\stephen@server.lon.liveperson[3].txt [ /server.lon.liveperson ]
C:\Documents and Settings\Stephen\Cookies\stephen@serving-sys[1].txt [ /serving-sys ]
C:\Documents and Settings\Stephen\Cookies\stephen@smartadserver[2].txt [ /smartadserver ]
C:\Documents and Settings\Stephen\Cookies\stephen@socialmedia[1].txt [ /socialmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@specificclick[1].txt [ /specificclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@specificclick[2].txt [ /specificclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@spicesofindia.co[2].txt [ /spicesofindia.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@stat.aldi[1].txt [ /stat.aldi ]
C:\Documents and Settings\Stephen\Cookies\stephen@stat.dealtime[1].txt [ /stat.dealtime ]
C:\Documents and Settings\Stephen\Cookies\stephen@stat.dealtime[3].txt [ /stat.dealtime ]
C:\Documents and Settings\Stephen\Cookies\stephen@stat.youku[1].txt [ /stat.youku ]
C:\Documents and Settings\Stephen\Cookies\stephen@statcounter[1].txt [ /statcounter ]
C:\Documents and Settings\Stephen\Cookies\stephen@statcounter[3].txt [ /statcounter ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.dnnmetrics[1].txt [ /stats.dnnmetrics ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.free-rein[1].txt [ /stats.free-rein ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.manticoretechnology[1].txt [ /stats.manticoretechnology ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.matraxis[1].txt [ /stats.matraxis ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.matraxis[2].txt [ /stats.matraxis ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.matraxis[3].txt [ /stats.matraxis ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.mytraveline[2].txt [ /stats.mytraveline ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.paypal[2].txt [ /stats.paypal ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.paypal[3].txt [ /stats.paypal ]
C:\Documents and Settings\Stephen\Cookies\stephen@stats.paypal[4].txt [ /stats.paypal ]
C:\Documents and Settings\Stephen\Cookies\stephen@statse.webtrendslive[2].txt [ /statse.webtrendslive ]
C:\Documents and Settings\Stephen\Cookies\stephen@steelhousemedia[2].txt [ /steelhousemedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@steenbergs.co[1].txt [ /steenbergs.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@steenbergs.co[2].txt [ /steenbergs.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@steenbergs.co[3].txt [ /steenbergs.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@superstats[1].txt [ /superstats ]
C:\Documents and Settings\Stephen\Cookies\stephen@surveymonkey.122.2o7[1].txt [ /surveymonkey.122.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@tacoda.at.atwola[1].txt [ /tacoda.at.atwola ]
C:\Documents and Settings\Stephen\Cookies\stephen@tacoda.at.atwola[3].txt [ /tacoda.at.atwola ]
C:\Documents and Settings\Stephen\Cookies\stephen@target.tangomedia.co[2].txt [ /target.tangomedia.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@thefind.co[2].txt [ /thefind.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@tiscali.propertyfinder[1].txt [ /tiscali.propertyfinder ]
C:\Documents and Settings\Stephen\Cookies\stephen@toplist[2].txt [ /toplist ]
C:\Documents and Settings\Stephen\Cookies\stephen@track.adform[2].txt [ /track.adform ]
C:\Documents and Settings\Stephen\Cookies\stephen@track.omguk[1].txt [ /track.omguk ]
C:\Documents and Settings\Stephen\Cookies\stephen@track.omguk[3].txt [ /track.omguk ]
C:\Documents and Settings\Stephen\Cookies\stephen@tracker.roitesting[1].txt [ /tracker.roitesting ]
C:\Documents and Settings\Stephen\Cookies\stephen@tracker.roitesting[2].txt [ /tracker.roitesting ]
C:\Documents and Settings\Stephen\Cookies\stephen@tracking.dc-storm[2].txt [ /tracking.dc-storm ]
C:\Documents and Settings\Stephen\Cookies\stephen@tracking.liveyourtruth[1].txt [ /tracking.liveyourtruth ]
C:\Documents and Settings\Stephen\Cookies\stephen@tracking.summitmedia.co[1].txt [ /tracking.summitmedia.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@tracking.vcab[2].txt [ /tracking.vcab ]
C:\Documents and Settings\Stephen\Cookies\stephen@tradedoubler[2].txt [ /tradedoubler ]
C:\Documents and Settings\Stephen\Cookies\stephen@trafficking.nabbr[2].txt [ /trafficking.nabbr ]
C:\Documents and Settings\Stephen\Cookies\stephen@trafficmp[2].txt [ /trafficmp ]
C:\Documents and Settings\Stephen\Cookies\stephen@tribalfusion[1].txt [ /tribalfusion ]
C:\Documents and Settings\Stephen\Cookies\stephen@tuiactivity.112.2o7[1].txt [ /tuiactivity.112.2o7 ]
C:\Documents and Settings\Stephen\Cookies\stephen@tvguide.virginmedia[2].txt [ /tvguide.virginmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@uk.at.atwola[1].txt [ /uk.at.atwola ]
C:\Documents and Settings\Stephen\Cookies\stephen@user.lucidmedia[1].txt [ /user.lucidmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@virginmedia[1].txt [ /virginmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@virginmedia[2].txt [ /virginmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@w3counter[2].txt [ /w3counter ]
C:\Documents and Settings\Stephen\Cookies\stephen@weather.virginmedia[1].txt [ /weather.virginmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@weborama[1].txt [ /weborama ]
C:\Documents and Settings\Stephen\Cookies\stephen@worldnakedbikeride[2].txt [ /worldnakedbikeride ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.burstbeacon ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.burstnet ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.clicksafe.lloydstsb ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.clicktoviewlink ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.countryside-jobs ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.discountshoestore.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.dover-parking-discounts.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.everyclick ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.findingjoymovie ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.googleadservices ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.grapeshot-media ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.hardtofindseminars ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.hxtrack ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.ist-track ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.measussex.org ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.onetruemedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.petmedia.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.stats.tso.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.steenbergs.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.sublimemedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.thefind.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@[You must be registered and logged in to see this link.] [ /www.virginmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@xiti[1].txt [ /xiti ]
C:\Documents and Settings\Stephen\Cookies\stephen@xiti[2].txt [ /xiti ]
C:\Documents and Settings\Stephen\Cookies\stephen@xiti[3].txt [ /xiti ]
C:\Documents and Settings\Stephen\Cookies\stephen@xm.xtendmedia[1].txt [ /xm.xtendmedia ]
C:\Documents and Settings\Stephen\Cookies\stephen@yadro[1].txt [ /yadro ]
C:\Documents and Settings\Stephen\Cookies\stephen@yourcounty.co[1].txt [ /yourcounty.co ]
C:\Documents and Settings\Stephen\Cookies\stephen@zedo[1].txt [ /zedo ]
C:\Documents and Settings\Stephen\Cookies\ZLUCGGPX.txt [ /media.mercola.com ]
C:\Documents and Settings\Stephen\Cookies\EUJNT3NW.txt [ /interclick.com ]
C:\Documents and Settings\Stephen\Cookies\6O9RURKM.txt [ /delivery.ads-littlestarmedia.co.uk ]
C:\Documents and Settings\Stephen\Cookies\D8MCF4LZ.txt [ /questionmarket.com ]
C:\Documents and Settings\Stephen\Cookies\7RBZ9CY7.txt [ /mediaservices-d.openxenterprise.com ]
C:\Documents and Settings\Stephen\Cookies\66QW8P3N.txt [ /ad.yieldmanager.com ]
C:\Documents and Settings\Stephen\Cookies\BJOWQJPC.txt [ /gnosticmedia.com ]
C:\Documents and Settings\Stephen\Cookies\OY68EX60.txt [ /www.googleadservices.com ]
C:\Documents and Settings\Stephen\Cookies\S3VTVX07.txt [ /tracking.3gnet.de ]
C:\Documents and Settings\Stephen\Cookies\FC68IJD6.txt [ /legolas-media.com ]
C:\Documents and Settings\Stephen\Cookies\0GBEM90R.txt [ /2o7.net ]
C:\Documents and Settings\Stephen\Cookies\YEW9YKTC.txt [ /invitemedia.com ]
C:\Documents and Settings\Stephen\Cookies\FJCOO34X.txt [ /virginmedia.com ]
C:\Documents and Settings\Stephen\Cookies\VORMJKGR.txt [ /media6degrees.com ]
C:\Documents and Settings\Stephen\Cookies\5FTN808R.txt [ /adtech.de ]
C:\Documents and Settings\Stephen\Cookies\I8LML8P8.txt [ /e-2dj6aekococ5odq.stats.esomniture.com ]
C:\Documents and Settings\Stephen\Cookies\8CW79HDY.txt [ /burstnet.com ]
C:\Documents and Settings\Stephen\Cookies\IFM5V843.txt [ /tracker.roitesting.com ]
C:\Documents and Settings\Stephen\Cookies\7HNDII1V.txt [ /revsci.net ]
C:\Documents and Settings\Stephen\Cookies\KOOCAAC7.txt [ /in.getclicky.com ]
C:\Documents and Settings\Stephen\Cookies\G2P2JQVR.txt [ /tacoda.at.atwola.com ]
C:\Documents and Settings\Stephen\Cookies\V31FBQRS.txt [ /dmtracker.com ]
C:\Documents and Settings\Stephen\Cookies\3MZDMT97.txt [ /andomedia.com ]
C:\Documents and Settings\Stephen\Cookies\3VSVFVI8.txt [ /server.iad.liveperson.net ]
C:\Documents and Settings\Stephen\Cookies\P8AOZV07.txt [ /msnbc.112.2o7.net ]
C:\Documents and Settings\Stephen\Cookies\WJSNMMHC.txt [ /imrworldwide.com ]
C:\Documents and Settings\Stephen\Cookies\CCR7N9LC.txt [ /lucidmedia.com ]
C:\Documents and Settings\Stephen\Cookies\MYX256Z3.txt [ /at.atwola.com ]
C:\Documents and Settings\Stephen\Cookies\W8WVUCFP.txt [ /paypal.112.2o7.net ]
C:\Documents and Settings\Stephen\Cookies\PADJOJTG.txt [ /www.googleadservices.com ]
C:\Documents and Settings\Stephen\Cookies\1EDENWSQ.txt [ /doubleclick.net ]
C:\Documents and Settings\Stephen\Cookies\D59LEHMN.txt [ /serving-sys.com ]
C:\Documents and Settings\Stephen\Cookies\2K818SGT.txt [ /e-2dj6wal4akajikp.stats.esomniture.com ]
C:\Documents and Settings\Stephen\Cookies\M2RLN91W.txt [ /eas.apm.emediate.eu ]
C:\Documents and Settings\Stephen\Cookies\NL6SQ93K.txt [ /ads.undertone.com ]
C:\Documents and Settings\Stephen\Cookies\0IDJ9NB1.txt [ /www.burstnet.com ]
C:\Documents and Settings\Stephen\Cookies\3G0A5CPS.txt [ /liveperson.net ]
C:\Documents and Settings\Stephen\Cookies\0GFDJQ7O.txt [ /liveperson.net ]
C:\Documents and Settings\Stephen\Cookies\PHBZFSON.txt [ /mediaplex.com ]
C:\Documents and Settings\Stephen\Cookies\YJ3A2GTX.txt [ /statse.webtrendslive.com ]
C:\Documents and Settings\Stephen\Cookies\5YCFRG4R.txt [ /bs.serving-sys.com ]
C:\Documents and Settings\Stephen\Cookies\0C898PTC.txt [ /counter.hitslink.com ]
C:\Documents and Settings\Stephen\Cookies\988Y2864.txt [ /hc2.humanclick.com ]
C:\Documents and Settings\Stephen\Cookies\T3EY5KFL.txt [ /www.googleadservices.com ]
C:\Documents and Settings\Stephen\Cookies\HD2JCADY.txt [ /ad.360yield.com ]
C:\Documents and Settings\Stephen\Cookies\LQO7CZ9Z.txt [ /ru4.com ]
C:\Documents and Settings\Stephen\Cookies\ULHUXVB3.txt [ /atdmt.com ]
C:\Documents and Settings\Stephen\Cookies\CM4LIMIJ.txt [ /ads.pubmatic.com ]
C:\Documents and Settings\Stephen\Cookies\9HBO7XD5.txt [ /bizrate.com ]
C:\Documents and Settings\Stephen\Cookies\T5B1O5OX.txt [ /statcounter.com ]
C:\Documents and Settings\Stephen\Cookies\D7GDQZKE.txt [ /apmebf.com ]
C:\Documents and Settings\Stephen\Cookies\7TO6KKYF.txt [ /advertising.com ]
C:\Documents and Settings\Stephen\Cookies\PR5YV9TJ.txt [ /adbrite.com ]
C:\Documents and Settings\Stephen\Cookies\MKSQ3I3M.txt [ /specificclick.net ]
C:\Documents and Settings\Stephen\Cookies\UDJJO1HQ.txt [ /tribalfusion.com ]
C:\Documents and Settings\Stephen\Cookies\26LJVH3T.txt [ /stat.onestat.com ]
C:\Documents and Settings\Stephen\Cookies\DZ3D2MCS.txt [ /accounts.google.com ]
C:\Documents and Settings\Stephen\Cookies\N5P71FIA.txt [ /zedo.com ]
C:\Documents and Settings\Stephen\Cookies\TUBRUNAB.txt [ /casalemedia.com ]
C:\Documents and Settings\Stephen\Cookies\7R6JOVBI.txt [ /adviva.net ]
C:\Documents and Settings\Stephen\Cookies\E9CM4V39.txt [ /fastclick.net ]
C:\Documents and Settings\Stephen\Cookies\9MOAI84G.txt [ /www.googleadservices.com ]
C:\Documents and Settings\Stephen\Cookies\SKI5B6E3.txt [ /e-2dj6wjnyglcjckp.stats.esomniture.com ]
C:\Documents and Settings\Stephen\Cookies\M0P9BG58.txt [ /click.expandsearchanswers.com ]
C:\Documents and Settings\Stephen\Cookies\HOE3SUZB.txt [ /www.steenbergs.co.uk ]
C:\Documents and Settings\Stephen\Cookies\CAI0AW0K.txt [ /steenbergs.co.uk ]
C:\Documents and Settings\Stephen\Cookies\NSBY4JHR.txt [ /hc2.humanclick.com ]
C:\Documents and Settings\Stephen\Cookies\54Q7IS5V.txt [ /www.googleadservices.com ]
C:\Documents and Settings\Stephen\Cookies\J5F2W0HX.txt [ /ox-d.fondnessmedia.com ]
C:\Documents and Settings\Stephen\Cookies\VBAH1ILU.txt [ /adserver.adtechus.com ]
C:\Documents and Settings\Stephen\Cookies\G1JYUNM5.txt [ /uk.at.atwola.com ]
C:\Documents and Settings\Stephen\Cookies\440I8ARJ.txt [ /tradedoubler.com ]
C:\Documents and Settings\Stephen\Cookies\VQT8GKC7.txt [ /liveperson.net ]
C:\Documents and Settings\Stephen\Cookies\NX9CRI82.txt [ /network.realmedia.com ]
C:\Documents and Settings\Stephen\Cookies\U6TUVRJB.txt [ /www.googleadservices.com ]
C:\Documents and Settings\Stephen\Cookies\W7STGVJG.txt [ /rotator.adjuggler.com ]
C:\Documents and Settings\Stephen\Cookies\MHNY10HL.txt [ /realmedia.com ]
C:\Documents and Settings\Stephen\Cookies\YDKG5YL3.txt [ /audience2media.com ]
C:\Documents and Settings\Stephen\Cookies\Z0U4IBL4.txt [ /www.googleadservices.com ]
C:\Documents and Settings\Stephen\Cookies\X1JLTMWO.txt [ /xm.xtendmedia.com ]
C:\Documents and Settings\Stephen\Cookies\EQ1XSG2W.txt [ /kaspersky.122.2o7.net ]
C:\Documents and Settings\Stephen\Cookies\OX0HWOZF.txt [ /tracking.onefeed.co.uk ]
C:\Documents and Settings\Stephen\Cookies\TYS122QX.txt [ /dc.tremormedia.com ]
C:\Documents and Settings\Stephen\Cookies\ZBKONQW5.txt [ /steelhousemedia.com ]
C:\Documents and Settings\Stephen\Cookies\5GGBRHO8.txt [ /tacoda.net ]
C:\Documents and Settings\Stephen\Cookies\EEG7B7D7.txt [ /mm.chitika.net ]
C:\Documents and Settings\Stephen\Cookies\KJ1G2WW8.txt [ /www.googleadservices.com ]
C:\Documents and Settings\Stephen\Cookies\ZWB7TUHE.txt [ /googleads.g.doubleclick.net ]
C:\Documents and Settings\Stephen\Cookies\CKYQIDKM.txt [ /yadro.ru ]
C:\Documents and Settings\Stephen\Cookies\D8B3J4II.txt [ /ads.lycos.com ]
C:\Documents and Settings\Stephen\Cookies\8NB6PRD4.txt [ /adxpose.com ]
C:\Documents and Settings\Stephen\Cookies\I8JE0P6H.txt [ /smartadserver.com ]
C:\Documents and Settings\Stephen\Cookies\WC85T96I.txt [ /ad.zanox.com ]
C:\Documents and Settings\Stephen\Cookies\4PZA74CV.txt [ /amazon-adsystem.com ]
C:\Documents and Settings\Stephen\Cookies\BN6AX8RY.txt [ /ads.pointroll.com ]
C:\Documents and Settings\Stephen\Cookies\MDUSWHZ5.txt [ /pointroll.com ]
C:\Documents and Settings\Stephen\Cookies\4R9ZQZAD.txt [ /cn.clickable.net ]
C:\Documents and Settings\Stephen\Cookies\EGPQ3E9T.txt [ /collective-media.net ]
C:\Documents and Settings\Stephen\Cookies\Z5C08TX3.txt [ /ads.bleepingcomputer.com ]
C:\Documents and Settings\Stephen\Cookies\R6TOMNVY.txt [ /ads.msv-inc.com ]
C:\Documents and Settings\Stephen\Cookies\XDHP2X24.txt [ /www.clicksafe.lloydstsb.com ]
C:\Documents and Settings\Stephen\Cookies\B3TSU2RP.txt [ /eas4.emediate.eu ]
C:\Documents and Settings\Stephen\Cookies\YIMI17D6.txt [ /www.grapeshot-media.net ]
C:\Documents and Settings\Stephen\Cookies\R0YSVW4T.txt [ /armanicouture.solution.weborama.fr ]
C:\Documents and Settings\Stephen\Cookies\9N9VHOK8.txt [ /247realmedia.com ]
C:\Documents and Settings\Stephen\Cookies\PJXG18GE.txt [ /ads.saymedia.com ]
C:\Documents and Settings\Stephen\Cookies\JRYKGXAG.txt [ /weborama.fr ]
C:\Documents and Settings\Stephen\Cookies\2RHL9QT1.txt [ /pro-market.net ]
C:\Documents and Settings\Stephen\Cookies\7Z1Z5IAJ.txt [ /kontera.com ]
C:\Documents and Settings\Stephen\Cookies\V75X03RU.txt [ /www.countrycottagescotswolds.co.uk ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\HRPGHB11.txt [ Cookie:administrator@atdmt.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\QNN5TT4T.txt [ Cookie:administrator@apmebf.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\32PLDIYG.txt [ Cookie:administrator@adtech.de/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\BIAWNEUW.txt [ Cookie:administrator@media6degrees.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\38BLAGGW.txt [ Cookie:administrator@tradedoubler.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\HQ4P7091.txt [ Cookie:administrator@adsonar.com/adserving ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\OJ6X4H4U.txt [ Cookie:administrator@adserver.adtechus.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\A2ZZ6AM4.txt [ Cookie:administrator@ru4.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\SQKCBMFP.txt [ Cookie:administrator@adbrite.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\JN9OAQH1.txt [ Cookie:administrator@specificclick.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\Q1HRCUKW.txt [ Cookie:administrator@revsci.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\Q5CIGGPZ.txt [ Cookie:administrator@tribalfusion.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\1E9GDYPB.txt [ Cookie:administrator@tacoda.at.atwola.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\AOBLX1SK.txt [ Cookie:administrator@eas4.emediate.eu/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\KLEDR8KE.txt [ Cookie:administrator@at.atwola.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\3M2DI6A1.txt [ Cookie:administrator@pro-market.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\8PA9V0L0.txt [ Cookie:administrator@adxpose.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\JVFTMGUB.txt [ Cookie:administrator@lucidmedia.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\43B8RPXM.txt [ Cookie:administrator@onlineadtracker.co.uk/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\0Q20RZTO.txt [ Cookie:administrator@dc.tremormedia.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\FY6HR7Y4.txt [ Cookie:administrator@adformdsp.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\CZZQUQDQ.txt [ Cookie:administrator@server.adformdsp.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\0TJTZNJS.txt [ Cookie:administrator@atwola.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\RSGZ79JZ.txt [ Cookie:administrator@interclick.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\F49O77ID.txt [ Cookie:administrator@click.expandsearchanswers.com/ads-clicktrack/click/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\K7ZC2JDW.txt [ Cookie:administrator@doubleclick.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\QOYZVO3M.txt [ Cookie:administrator@adup.rotator.hadj7.adjuggler.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\HS6SS9W0.txt [ Cookie:administrator@questionmarket.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\AFEXYQQB.txt [ Cookie:administrator@serving-sys.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\FGGUJJXY.txt [ Cookie:administrator@fastclick.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\686KBOR8.txt [ Cookie:administrator@audience2media.com/servlet/ajrotator/track/pt1103192 ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\GUDBMSZI.txt [ Cookie:administrator@mediaplex.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\WCL3GY34.txt [ Cookie:administrator@advertising.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\T1JZKD4C.txt [ Cookie:administrator@collective-media.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\ATE19RRW.txt [ Cookie:administrator@ar.atwola.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\BN2T2VQY.txt [ Cookie:administrator@zedo.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\D7B8PX1L.txt [ Cookie:administrator@ad.yieldmanager.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\Y2R9FCPW.txt [ Cookie:administrator@yieldmanager.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\C7KH88QX.txt [ Cookie:administrator@liveperson.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\8WW6KRIX.txt [ Cookie:administrator@[You must be registered and logged in to see this link.] ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\FZKTCT0U.txt [ Cookie:administrator@find.seekgreen.co.uk/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\36G8ECAS.txt [ Cookie:administrator@micklemedia.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\0NCZ6X5V.txt [ Cookie:administrator@247realmedia.com/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\TIGAG463.txt [ Cookie:administrator@sales.liveperson.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\WRJTMPZV.txt [ Cookie:administrator@track.adform.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\WPIIXZVH.txt [ Cookie:administrator@fidelity.rotator.hadj7.adjuggler.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\FA875G1T.txt [ Cookie:administrator@adform.net/ ]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\Cookies\9DZWVK00.txt [ Cookie:administrator@virginmedia.com/ ]
C:\DOCUMENTS AND SETTINGS\STEPHEN\Cookies\DBIQQ0H3.txt [ Cookie:stephen@clkads.com/adServe/banners ]
C:\DOCUMENTS AND SETTINGS\STEPHEN\Cookies\P6YBZAZF.txt [ Cookie:stephen@adsonar.com/adserving ]
2nd Scan Log
Generated 05/01/2012 at 11:07 PM
Scan type : Complete Scan
Total Scan Time : 01:35:57
Memory items scanned : 504
Registry items scanned : 35902
File items scanned : 107745
File threats detected : 63
cdn.complexmedianetwork.com [ C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\KUQSZ4L8 ]
ads1.msn.com [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
atdmt.com [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
img-cdn.mediaplex.com [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
interclick.com [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
m.uk.2mdn.net [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
m1.2mdn.net [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
m1.emea.2mdn.net [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
oddcast.com [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
serving-sys.com [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
spe.atdmt.com [ C:\DOCUMENTS AND SETTINGS\DAWN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\RXB76UBJ ]
2mdn.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
ad.uk.doubleclick.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
ads1.msn.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
as-us.falkag.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
atdmt.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
b.ads1.msn.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
broadcast.piximedia.fr [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
cdn5.specificclick.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
core.insightexpressai.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
ds.serving-sys.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
ec.atdmt.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
fr.2mdn.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
gw.callingbanners.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
img-cdn.mediaplex.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
interclick.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
kona.kontera.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
m.uk.2mdn.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
m1.2mdn.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
m1.emea.2mdn.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
media.monster.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
media.mtvnservices.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
media.scanscout.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
media.tattomedia.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
media.tiscali.co.uk [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
media01.kyte.tv [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
media1.break.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
msntest.serving-sys.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
naiadsystems.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
objects.tremormedia.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
oddcast.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
revenue.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
s0.2mdn.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
secure-us.imrworldwide.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
sftrack.searchforce.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
spe.atdmt.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
static.2mdn.net [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
track.webgains.com [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
[You must be registered and logged in to see this link.] [ C:\DOCUMENTS AND SETTINGS\STEPHEN\APPLICATION DATA\MACROMEDIA\FLASH PLAYER\#SHAREDOBJECTS\4EWY72W4 ]
PUP.MyWebSearch
C:\PROGRAM FILES\NETSCAPE\NETSCAPE BROWSER\PLUGINS\NPMYWEBS.DLL
Trojan.Agent/Gen-Nullo[Short]
ZIP ARCHIVE( C:\QOOBOX\QUARANTINE\C\WINDOWS\SYSTEM32\_ARP_.EXE.ZIP )/ARP.EXE.1
ZIP ARCHIVE( C:\QOOBOX\QUARANTINE\C\WINDOWS\SYSTEM32\_SCARDSVR_.EXE.ZIP )/SCARDSVR.EXE.1
ZIP ARCHIVE( C:\QOOBOX\QUARANTINE\C\WINDOWS\SYSTEM32\_SETUP_.EXE.ZIP )/SETUP.EXE.1
C:\SYSTEM VOLUME INFORMATION\_RESTORE{A1FDC60D-0FFC-4EFA-9F97-603332CE802D}\RP787\A0070876.EXE
Trojan.Agent/Gen-FakeAlert
C:\_OTL\MOVEDFILES\04292012_043740\C_DOCUMENTS AND SETTINGS\ALL USERS\APPLICATION DATA\BWNGUKIRPGKBMLB.EXE
wildfly73
Operating System : windows xp Home Edition 2002 service pack 3
Re: Help required smart repair HDD
Post by wildfly73 on Wed 02 May 2012, 8:17 am
Hello, Mbam complete scan log
Malwarebytes' Anti-Malware 1.51.0.1200
Database version: 912050110
02/05/2012 03:47:08
mbam-log-2012-05-02 (03-47-07).txt
Scan type: Full scan (C:\|)
Objects scanned: 416011
Time elapsed: 1 hour(s), 36 minute(s), 45 second(s)
Registry Data Items Infected: 7
Files Infected: 3
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowControlPanel (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowHelp (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowMyComputer (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowMyDocs (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowRun (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowSearch (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoDesktop (PUM.Hidden.Desktop) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
c:\documents and settings\Anthony\my documents\eurogrand casino\_setupcasino[1].exe (Trojan.Agent) -> Quarantined and deleted successfully.
c:\system volume information\_restore{a1fdc60d-0ffc-4efa-9f97-603332ce802d}\RP787\A0070887.dll (PUP.MyWebSearch) -> Quarantined and deleted successfully.
c:\system volume information\_restore{a1fdc60d-0ffc-4efa-9f97-603332ce802d}\RP787\A0070888.exe (Trojan.Agent) -> Quarantined and deleted successfully.
wildfly73
Post by Superdave on Wed 02 May 2012, 9:29 am
Good, we got it. Now we can continue to see if there's anything left.
Link 1
Link 2
Link 3
To prevent your anti-virus application interfering with ComboFix we need to disable it. See here for a tutorial regarding how to do so if you are unsure.
Tech Staff
Tech Staff
Post by wildfly73 on Wed 02 May 2012, 9:25 pm
ComboFix 12-05-01.03 - Stephen 02/05/2012 16:52:15.2.2 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.44.1033.18.511.140 [GMT 1:00]
Running from: c:\documents and settings\Stephen\Desktop\ComboFix.exe
AV: Lavasoft Ad-Watch Live! Anti-Virus *Enabled/Updated* {A1C4F2E0-7FDE-4917-AFAE-013EFC3EDE33}
c:\documents and settings\All Users\Application Data\jL6svp0h5ESLeV
c:\documents and settings\Stephen\My Documents\~WRL3288.tmp
c:\windows\system32\CddbCdda.dll
c:\windows\system32\nsn19A.tmp
((((((((((((((((((((((((( Files Created from 2012-04-02 to 2012-05-02 )))))))))))))))))))))))))))))))
2012-05-02 15:41 . 2012-05-02 15:41 -------- d-----w- c:\windows\SxsCaPendDel
2012-05-02 15:40 . 2012-05-02 15:40 -------- d-----w- c:\windows\LastGood
2012-05-01 19:45 . 2012-05-01 19:45 -------- d-----w- c:\documents and settings\Stephen\Application Data\SUPERAntiSpyware.com
2012-05-01 19:43 . 2012-05-01 19:45 -------- d-----w- c:\program files\SUPERAntiSpyware
2012-05-01 19:43 . 2012-05-01 19:43 -------- d-----w- c:\documents and settings\All Users\Application Data\SUPERAntiSpyware.com
2012-04-29 08:37 . 2012-04-29 08:37 -------- d-----w- C:\_OTL
2012-04-16 19:30 . 2012-04-16 19:30 -------- d-----w- C:\Kontiki
2012-04-07 11:16 . 2012-04-07 11:16 418464 ----a-w- c:\windows\system32\FlashPlayerApp.exe
2012-04-07 11:16 . 2011-06-06 09:22 70304 ----a-w- c:\windows\system32\FlashPlayerCPLApp.cpl
2012-04-04 14:56 . 2011-06-21 19:47 22344 ----a-w- c:\windows\system32\drivers\mbam.sys
2012-03-01 11:01 . 2005-05-21 15:37 916992 ----a-w- c:\windows\system32\wininet.dll
2012-03-01 11:01 . 2005-05-21 15:36 43520 ----a-w- c:\windows\system32\licmgr10.dll
2012-03-01 11:01 . 2005-05-21 15:36 1469440 ------w- c:\windows\system32\inetcpl.cpl
2012-02-29 14:10 . 2005-05-21 15:37 177664 ----a-w- c:\windows\system32\wintrust.dll
2012-02-29 14:10 . 2005-05-21 15:36 148480 ----a-w- c:\windows\system32\imagehlp.dll
2012-02-29 12:17 . 2005-05-21 15:36 385024 ----a-w- c:\windows\system32\html.iec
2012-02-03 09:22 . 2005-05-21 15:37 1860096 ----a-w- c:\windows\system32\win32k.sys
"kdx"="c:\program files\Kontiki\KHost.exe" [2008-02-27 1032376]
"sbitunesagent"="c:\program files\Philips\Philips Songbird\songbirditunesagent.exe" [2011-08-18 266240]
"Symantec PIF AlertEng"="c:\program files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" [2008-01-29 583048]
"SoundMan"="SOUNDMAN.EXE" [2005-04-06 90112]
"PinnacleDriverCheck"="c:\windows\system32\PSDrvCheck.exe" [2004-03-10 406016]
"PCSuiteTrayApplication"="c:\program files\Nokia\Nokia PC Suite 6\LaunchApplication.exe" [2007-06-18 271360]
"LVCOMSX"="c:\windows\system32\LVCOMSX.EXE" [2005-07-19 221184]
"LogitechVideoTray"="c:\program files\Logitech\Video\LogiTray.exe" [2005-06-08 217088]
"LogitechVideoRepair"="c:\program files\Logitech\Video\ISStart.exe" [2005-06-08 458752]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2007-05-08 54840]
"High Definition Audio Property Page Shortcut"="HDAShCut.exe" [2005-01-07 61952]
"CanonSolutionMenu"="c:\program files\Canon\SolutionMenu\CNSLMAIN.exe" [2008-03-11 689488]
"CanonMyPrinter"="c:\program files\Canon\MyPrinter\BJMyPrt.exe" [2008-03-18 1848648]
"ATIPTA"="c:\ati-cpanel\atiptaxx.exe" [2005-01-19 339968]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2010-07-21 141608]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2010-11-29 421888]
"DivXUpdate"="c:\program files\DivX\DivX Update\DivXUpdate.exe" [2011-03-21 1230704]
"Philips Device Listener"="c:\program files\Philips\Philips Songbird Resources\Autolauncher\PhilipsDeviceListener.exe" [2011-08-18 380416]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2011-06-09 254696]
"Nokia.PCSync"="c:\program files\Nokia\Nokia PC Suite 6\PcSync2.exe" [2007-06-19 1241088]
"DWQueuedReporting"="c:\progra~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" [2007-03-13 39264]
Adobe Reader Speed Launch.lnk - c:\program files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2008-4-23 29696]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2004-11-4 258048]
HP Image Zone Fast Start.lnk - c:\program files\HP\Digital Imaging\bin\hpqthb08.exe [2004-11-4 53248]
McAfee Security Scan Plus.lnk - c:\program files\McAfee Security Scan\2.0.181\SSScheduler.exe [2010-1-15 255536]
Microsoft Office.lnk - c:\program files\Microsoft Office\Office10\OSA.EXE [2001-2-13 83360]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2011-07-19 113024]
2011-05-04 17:54 551296 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.DLL
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\securityproviders]
SecurityProviders msapsspc.dll, schannel.dll, digest.dll, msnsspc.dll, zwebauth.dll
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\!SASCORE]
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Kontiki\\KService.exe"=
R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [22/07/2011 17:27 12880]
R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [12/07/2011 22:55 67664]
R2 !SASCORE;SAS Core Service;c:\program files\SUPERAntiSpyware\SASCore.exe [12/08/2011 00:38 116608]
R2 WinDefend;Windows Defender;c:\program files\Windows Defender\MsMpEng.exe [03/11/2006 19:19 13592]
S0 Lbd;Lbd;c:\windows\system32\DRIVERS\Lbd.sys --> c:\windows\system32\DRIVERS\Lbd.sys [?]
S2 AdobeActiveFileMonitor;Adobe Active File Monitor;c:\program files\Adobe\Photoshop Elements 3.0\PhotoshopElementsFileAgent.exe [20/10/2004 04:47 98304]
S2 PhotoshopElementsDeviceConnect;Photoshop Elements Device Connect;c:\program files\Adobe\Photoshop Elements 3.0\PhotoshopElementsDeviceConnect.exe [20/10/2004 03:40 118784]
S3 AdobeFlashPlayerUpdateSvc;Adobe Flash Player Update Service;c:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe [07/04/2012 12:16 253600]
S3 DrvAgent32;DrvAgent32;c:\windows\system32\drivers\DrvAgent32.sys [20/06/2011 19:42 23456]
S3 Lavasoft Kernexplorer;Lavasoft helper driver;\??\c:\program files\Lavasoft\Ad-Aware\KernExplorer.sys --> c:\program files\Lavasoft\Ad-Aware\KernExplorer.sys [?]
S3 McComponentHostService;McAfee Security Scan Component Host Service;c:\program files\McAfee Security Scan\2.0.181\McCHSvc.exe [15/01/2010 13:49 227232]
S3 PIXMCV;JVC Communication PIX-MCV Driver;c:\windows\system32\drivers\pixmcvc.sys [20/09/2005 18:52 32000]
S3 PIXMCVA;JVC PIX-MCV Audio Capture;c:\windows\system32\drivers\pixmcva.sys [20/09/2005 18:53 28057]
S3 PIXMCVV;JVC PIX-MCV Video Capture;c:\windows\system32\drivers\pixmcvv.sys [20/09/2005 18:53 21081]
2012-05-02 c:\windows\Tasks\Adobe Flash Player Updater.job
- c:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe [2012-04-07 11:16]
2012-03-31 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 12:34]
2012-05-02 c:\windows\Tasks\MP Scheduled Scan.job
- c:\program files\Windows Defender\MpCmdRun.exe [2006-11-03 18:20]
IE: Add to AMV Converter... - c:\program files\MP3 Player Utilities 4.17\AMVConverter\grab.html
TCP: DhcpNameServer = 192.168.1.1
Rootkit scan 2012-05-02 17:09
- - - - - - - > 'winlogon.exe'(732)
Completion time: 2012-05-02 17:15:00
ComboFix-quarantined-files.txt 2012-05-02 16:14
ComboFix2.txt 2011-06-22 11:51
Pre-Run: 111,070,990,336 bytes free
Post-Run: 111,572,414,464 bytes free
- - End Of File - - 84644414AD6D7D53D24D3E3423D85A8E
wildfly73
Post by Superdave on Thu 03 May 2012, 6:28 am
Link 1
Link 2
SysProt Antirootkit
Download
SysProt Antirootkit from the link below (you will find it at the bottom
of the page under attachments, or you can get it from one of the
mirrors).
Unzip it into a folder on your desktop.
  • Double click Sysprot.exe to start the program.
  • Click on the Log tab.
  • In the Write to log box select the following items.
    • Process << Selected
    • Kernel Modules << Selected
    • SSDT << Selected
    • Kernel Hooks << Selected
    • IRP Hooks << NOT Selected
    • Ports << NOT Selected
    • Hidden Files << Selected
  • At the bottom of the page
    • Hidden Objects Only << Selected
  • Click on the Create Log button on the bottom right.
  • After a few seconds a new window should appear.
  • Select Scan Root Drive. Click on the Start button.
  • When it is complete a new window will appear to indicate that the scan is finished.
  • The log will be saved automatically in the same folder Sysprot.exe was extracted to. Open the text file and copy/paste the log here.
Tech Staff
Tech Staff
Post by wildfly73 on Thu 03 May 2012, 9:10 pm
Results of screen317's Security Check version 0.99.32
Windows XP Service Pack 3 x86
Internet Explorer 8
Antivirus/Firewall Check:
Windows Firewall Enabled!
avast! Free Antivirus
ESET Online Scanner v3
SUPERAntiSpyware
Windows Defender
McAfee SiteAdvisor
Java(TM) 6 Update 32
Java(TM) 6 Update 2
Java(TM) 6 Update 3
Java(TM) 6 Update 5
Java(TM) 6 Update 7
Java version out of date!
Process Check:
objlist.exe by Laurent
Windows Defender MSMpEng.exe
Windows Defender MsMpEng.exe
AVAST Software Avast AvastSvc.exe
AVAST Software Avast avastUI.exe
wildfly73
Post by Superdave on Fri 04 May 2012, 6:16 am
You can uninstall the following. They are no longer needed.
Java(TM) 6 Update 2
Java(TM) 6 Update 3
Java(TM) 6 Update 5
Java(TM) 6 Update 7
Can you run the other scan?
Tech Staff
Tech Staff
Post by wildfly73 on Sat 05 May 2012, 7:20 am
Yes iv ran the other scan and have the log. I tried posting it 3x's throught yesterday. The problem is when i click to paste the log in this reply box the GeekPolice webpage becomes unresponsive. i use task manager to close GeekPolice webpage and it does but very slowly. Strangely task manager shows two identical unresponsive GeekPolice webpages. hmm.
The log is to large to post here, 3,274 644 characters! So copied it from notepad to a word document. SysProt AntiRootkit Log file sent as attachment.
successfully uninstalled java 2,3,5, & 7.
Last edited by wildfly73 on Sat 05 May 2012, 7:57 am; edited 1 time in total (Reason for editing : addition info)
wildfly73
Post by Superdave on Sat 05 May 2012, 9:47 am
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by wildfly73 on Sat 05 May 2012, 11:13 pm
Hello, results of ESET scan
C:\Documents and Settings\Stephen\Application Data\Sun\Java\Deployment\cache\6.0\12\3af49e4c-1c5ed8e0 Java/Exploit.Agent.NAX trojan cleaned by deleting - quarantined
wildfly73
Post by Superdave on Sun 06 May 2012, 10:04 am
How's your computer working now? Any other issues?
Tech Staff
Tech Staff
Post by wildfly73 on Thu 10 May 2012, 7:03 am
All files have been unhided and have normal running/operation of computer restored. Just one thing of concern. On my desktop a shortcut icon has appeared named SMART_HDD.
Thanks for all your help
wildfly73
Post by Superdave on Thu 10 May 2012, 9:33 am
Just drag it into the Recycle Bin. Let's do some cleanup.
To uninstall ComboFix
To remove all of the tools we used and the files and folders they created do the following:
Double click OTL.exe.
  • Click the CleanUp button.
  • Select Yes when the "Begin cleanup Process?" prompt appears.
Clean out your temporary internet files and temp files.
Download TFC by OldTimer to your desktop.
Double-click TFC.exe to run it.
Note: If you are running on Vista, right-click on the file and choose Run As Administrator
TFC will close all programs when run, so make sure you have saved all your work before you begin.
* Click the Start button to begin the cleaning process.
* Depending on how often you clean temp files, execution time should be anywhere from a few seconds to a minute or two.
* Please let TFC run uninterrupted until it is finished.
Once TFC is finished it should restart your computer. If it does not, please manually restart the computer yourself to ensure a complete cleaning.
If you experience problems running TFC, just abort and run a cleandisk on your C drive.
Looking over your log it seems you don't have any evidence of a third party firewall.
Firewalls protect against hackers and malicious intruders. You need to download a free firewall from one of these reliable vendors.
Remember only install ONE firewall
1) Comodo Personal Firewall (Uncheck during installation "Install Comodo SafeSurf..", Make Comodo my default search provider" and "Make Comodo Search my homepage" and uncheck any HopSurf and/or Ask.com options if you choose this one)
2) Online Armor
3) Agnitum Outpost
4) PC Tools Firewall Plus
If you are using the built-in Windows XP firewall, it is not recommended as it does not block outgoing connections. This means that any malware on your computer is free to "phone home" for more instructions. Simply put, Windows XP contains a mediocre firewall. This firewall is NO replacement for a dedicated software solution. Remember to use only one firewall at the same time.
Use the Secunia Software Inspector to check for out of date software.
•Click Start Now
•Check the box next to Enable thorough system inspection.
•Click Start
•Allow the scan to finish and scroll down to see if any updates are needed.
•Update anything listed.
Go to Microsoft Windows Update and get all critical updates.
SpywareBlaster- Secure your Internet Explorer to make it harder for ActiveX programs to run on your computer. Also stop certain cookies from being added to your computer when running Mozilla based browsers like Firefox.
* Using SpywareBlaster to protect your computer from Spyware and Malware
* If you don't know what ActiveX controls are, see here
Protect yourself against spyware using the Immunize feature in Spybot - Search & Destroy. Guide: Use Spybot's Immunize Feature to prevent spyware infection in real-time. Note: To ensure you have the latest Immunizations always update Spybot - Search & Destroy before Immunizing. Spybot - Search & Destroy FAQ
Safe Surfing!
Tech Staff
Tech Staff
Post by Sponsored content Today at 2:48 am
Page 2 of 2 Previous  1, 2
