I have SMART HDD virus and need help!
Post by Flightnurse on 30th March 2012, 5:19 am
I got the smart HDD today and have been trying to get rid of it all day..please help!
Flightnurse
Joined Joined : 2012-03-30
OS OS : windows7
Points Points : 17168
Re: I have SMART HDD virus and need help!
Post by Pancake on 30th March 2012, 10:45 pm
Please download Malwarebytes
Alternate link: [You must be registered and logged in to see this link.]
Make sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes Anti-Malware, then click Finish.
If an update is found, it will download and install the latest version.
Once the program has loaded, select "Perform Full Scan", then click Scan.
The scan may take some time to finish,so please be patient.
When the scan is complete, click OK, then Show Results to view the results.
Make sure that everything is checked, and click Remove Selected.
When disinfection is completed, a log will open in Notepad and you may be prompted to Restart. If you are prompted to restart, please allow it to restart your computer. Failure to do this, will cause the infection to still be active on the computer.
Please save the log to a location you will remember.
The log is automatically saved by MBAM and can be viewed by clicking the Logs tab in MBAM.
The log can also be found at C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt or at C:\Program Files\Malwarebytes' Anti-Malware\Logs\log-date.txt
Copy and paste the entire report in your next reply.
If Malwarebytes fails to download please use the following link:
Download Combofix from any of the links below, and save it to your desktop.
When saving ComboFix rename it to PCHelpForum.exe to prevent it from being blocked by malware.
Refer to this image:
To prevent your anti-virus application interfering with ComboFix we need to disable it. See [You must be registered and logged in to see this link.] for a tutorial regarding how to do so if you are unsure.
  • Close any open windows and double click PCHelpForum.exe to run it.
Pancake
Posts Posts : 222
Joined Joined : 2010-03-06
Points Points : 28188
Post by Flightnurse on 3rd April 2012, 2:23 am
I did this and it doesnt discover the virus...it says nothing malicious detected? Anything else you suggest?
Flightnurse
OS OS : windows7
Post by Pancake on 3rd April 2012, 3:02 am
And the Combofix ???
Pancake
Posts Posts : 222
