Big patching Problem
Solved Big patching Problem
Post by Nazzgull on Sat Aug 16, 2008 1:34 pm
I download EA Need for Speed Carbon from EA website. and i have problem, i got some error and this log.
EXP: DEFAULT_INSTALL_DIR
-> DEFAULT_INSTALL_DIR
EXP: "Software\Electronic Arts\Need for Speed Carbon"
-> "Software\Electronic Arts\Need for Speed Carbon"
EXP: "Install Dir"
-> "Install Dir"
EXP: %HKLM("Software\Electronic Arts\Need for Speed Carbon", "Install Dir")%
DEF: DEFAULT_INSTALL_DIR
EXP: SPANISH_INSTALL_DIR
-> SPANISH_INSTALL_DIR
EXP: "Install Dir"
-> "Install Dir"
DEF: SPANISH_INSTALL_DIR
EXP: INSTALL_DIR
-> INSTALL_DIR
EXP: %VAR(DEFAULT_INSTALL_DIR)%
EXP: ""
EXP: %EQ(%VAR(DEFAULT_INSTALL_DIR)%, "")%
-> 1
EXP: %VAR(SPANISH_INSTALL_DIR)%
NUM: 1
-> 1
EXP: %IF(%EQ(%VAR(DEFAULT_INSTALL_DIR)%, "")%, %VAR(SPANISH_INSTALL_DIR)%, %VAR(DEFAULT_INSTALL_DIR)%)%
DEF: INSTALL_DIR
EXP: nfsc_patch.ini
-> nfsc_patch.ini
EXP: Patch
-> Patch
EXP: InstallDirectory
-> InstallDirectory
EXP: INSTALL_DIR
-> INSTALL_DIR
EXP: %VAR(INSTALL_DIR)%
SET: INI: nfsc_patch.ini : Patch : InstallDirectory
Points Points : 40435
Solved Re: Big patching Problem
Post by Doctor Inferno on Sat Aug 16, 2008 1:39 pm
Moved from malware removal support.
Post by Doctor Inferno on Tue Aug 19, 2008 7:32 am
When exactly do you encounter the error? Is it during the installation or when running the game?
What have you tried to resolve the issue?
First, please make sure that you have ended background tasks to prevent program conflicts and free up resources for the game. Please click here for instructions:
http://support.ea.com/cgi-bin/ea.cfg/php/enduser/olh_adp.php?p_faqid=10700
Then empty your Temp folder to prevent file conflicts. Click here for steps on emptying your Temp folder:
http://support.ea.com/cgi-bin/ea.cfg/php/enduser/olh_adp.php?p_faqid=10705
In order to best troubleshoot your issue, I'm going to need additional system information. I need information from a program called dxdiag.exe.
To do this:
Go to Start >> Run.
In the box, type the following: dxdiag
Click "OK"
Click the "Save All Information" button on the first screen of the application.
Then on top of the "Save As" box that pops up, select Desktop (if it's not set to save there already), then click Save.
Finally, post the contents inside, here.
Post by Doctor Inferno on Fri Aug 29, 2008 3:31 am
Have this problem been addressed? Do you need further help?
Post by Nazzgull on Fri Aug 29, 2008 10:26 am
Not work. But you can lock it now. Because i delete game, it's boring.
