Help with Minidumps from BSOD - XP Home, sp3
Post by Keen Witte on 14th February 2012, 5:27 am
My XP Home SP3 continues to get random BSOD's, it will be ok for hours and/or 30 minutes and poof. The Error codes I get are headed by 0x00000050. Next set of 4 - 0x numbers stays the same for the last 3 sets, the 1st changes. Last 4 examples are:
0X00000050
(0x8B91B000, 0x00000001, 0x80541678, 0x00000000) and
(0xB43EB000, 0x00000001, 0x80541678, 0x00000000) and
(0xB287B000, 0x00000001, 0x80541678, 0x00000000) and
(0xB3316000, 0x00000001, 0x80541678, 0x00000000)
Two (2) of the associated mini dumps are at:
https://skydrive.live.com/#cid=786A5682C795A834&id=786A5682C795A834!105
The 1st and last were simply not there. I have no idea why not.
I have XP Professional 64 bit on a separate hard drive. It has been running without error with all the non 64 bit drivers the same.
Have 4, 1gig sticks of RAM, ran extended Memtest on all 4 without any errors. Did them all singly, then as pairs, then as a total set.
GPA Student tried to help, that thread can be found at:
http://www.GeekPolice.net/t28498-bsod-help#196407
Hoping that starting a new thread will help.
Searching microsoft suppost for 0x50 errors has lead to fixes for Backdoor virus/worm, memory issues, etc, etc - none of which help.
Keen Witte
Posts Posts : 6
Joined Joined : 2012-01-30
OS OS : xp home
Points Points : 17816
Re: Help with Minidumps from BSOD - XP Home, sp3
Post by Jan2011 on 17th February 2012, 1:15 pm
Hi, me again, I know your RAM passed memtest. I don't trust memtest 100%. I think I suggested pulling a memory stick or two and run that way for a while.
Jan2011
Posts Posts : 617
Joined Joined : 2011-01-17
Points Points : 25625
