No internet through ethernet cable connection
Post by Voods on Fri 20 Jan 2012, 9:17 am
I have been having issues getting a connection when hardwired to my network.
I have no problems connecting through the wireless connection.
When connecting using the ethernet cable I am able to:
Ping internet addresses
Trace RT through to the internet with a fixed ip adress
It shows connected, with limited access
Partly works with a static ip address
It will not let me pick a DHCP address
I have been using this computer, with this particular OS installed for over a year now, and suddenly been presented with these issues.
My Windows has come up as being not genuine, but this is false.
I have tried to a repair using the disc, but I am only presented with the option of a fresh install, whereas on previous occasions, I have seen an option to do a repair.
I have done full scans, using MBAM, SuperAntiSpyware. Spyware Blaster is up to date, and my Eset is fully up to date, with no infections shown after a scan.
I have even scanned using Sophos.
I know the issue is not hardware related, as I have loaded another disk on the same laptop, and with no issues.
I have also done a sfc scan, with no issues. I've renewed my ip address too, reset the router.
I'm stumped!
Any ideas?
Voods
Senior Surfer
Senior Surfer
Operating System : Windows 7 Professional
Re: No internet through ethernet cable connection
Post by Nazzgull on Fri 20 Jan 2012, 9:46 am
Hi Voods,
Did you manage your Internet Protocol Version 4 (TCP/IPv4) in past ?
Regards,
Visit us on social networks : GeekPolice on Facebook! - GeekPolice on Twitter!
Tech Advisor
Tech Advisor
Operating System : Windows 7 Professional 64bit
Post by Voods on Fri 20 Jan 2012, 10:35 am
Hi there
Yes I did, no issues
Regards
Dave
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Fri 20 Jan 2012, 10:57 am
Did you know that you have to manually set IP Address on Computer with Internet Connection available, and 2nd computer which is connected to main need to be "Obtain IP address automatically". Everything else is fine, as I can read from post above.
Regards,
Tech Advisor
Tech Advisor
Post by Voods on Fri 20 Jan 2012, 9:25 pm
I am aware of that..
But it is set up for DHCP address here.
All 4 of my other computers are set up exactly the same here, and with no issues whatsoever.
I can only think of a piece of software that maybe causing the problem, or possibly a rootkit? I can't visit all websites normally, I get redirected on some Google searches too, when the page actually loads. It doesn't happen every time though, (through wireless)
Can it be to do with my Windows OS showing as not genuine? Surely that couldn't terminate my internet access?
Regards
Dave
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Fri 20 Jan 2012, 10:17 pm
Hi Dave,
  • Start > Run > CMD
IPCONFIG /ALL >C:\RESULT.TXT
  • Open C:\RESULT.TXT with Notepad and copy/paste the entire results here.
Regards
Tech Advisor
Tech Advisor
Post by Voods on Fri 20 Jan 2012, 10:23 pm
Windows IP Configuration
Host Name . . . . . . . . . . . . : voodoo-PC
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controller #2
Physical Address. . . . . . . . . : 00-21-70-DF-C5-9D
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::f06a:ca2b:3e7e:e139%45(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.20(Preferred)
Default Gateway . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 1023418736
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-15-30-CD-0C-00-21-70-DF-C5-9D
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Connection
Physical Address. . . . . . . . . : 00-1F-3C-CA-5D-AA
DHCP Enabled. . . . . . . . . . . : Yes
Tunnel adapter isatap.{483F3E33-C511-4DA6-8D30-A573F90C25E4}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.{9FA3F7FB-F01F-46D4-BC03-7EE3AA56F4F9}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Fri 20 Jan 2012, 10:35 pm
This looks like normal Log, I have only a little suggestion on a line
Download Farbar Service Scanner (FSS) and run it on the computer with the issue.
  • Check the following options:
    • Internet Services
    • Windows Firewall
    • System Restore
    • Security Center
    • Windows Update
  • Press "Scan" button.
  • It will create a log (FSS.txt).
  • Please copy/paste the log to your reply.
Tech Advisor
Tech Advisor
Post by Voods on Fri 20 Jan 2012, 10:42 pm
Farbar Service Scanner Version: 18-01-2012 01
Ran by voodoo (administrator) on 20-01-2012 at 11:42:06
Microsoft Windows 7 Professional Service Pack 1 (X86)
Boot Mode: Normal
Internet Services:
Connection Status:
Localhost is accessible.
LAN connected.
Google IP is accessible.
Yahoo IP is accessible.
Windows Firewall:
Firewall Disabled Policy:
"EnableFirewall"=DWORD:0
System Restore:
SDRSVC Service is not running. Checking service configuration:
The start type of SDRSVC service is OK.
The ImagePath of SDRSVC service is OK.
The ServiceDll of SDRSVC service is OK.
VSS Service is not running. Checking service configuration:
The start type of VSS service is OK.
The ImagePath of VSS service is OK.
System Restore Disabled Policy:
Security Center:
Windows Update:
File Check:
C:\Windows\system32\nsisvc.dll => MD5 is legit
C:\Windows\system32\Drivers\nsiproxy.sys => MD5 is legit
C:\Windows\system32\dhcpcore.dll => MD5 is legit
C:\Windows\system32\Drivers\afd.sys => MD5 is legit
C:\Windows\system32\Drivers\tdx.sys => MD5 is legit
C:\Windows\system32\Drivers\tcpip.sys => MD5 is legit
C:\Windows\system32\dnsrslvr.dll => MD5 is legit
C:\Windows\system32\mpssvc.dll => MD5 is legit
C:\Windows\system32\bfe.dll => MD5 is legit
C:\Windows\system32\Drivers\mpsdrv.sys => MD5 is legit
C:\Windows\system32\SDRSVC.dll => MD5 is legit
C:\Windows\system32\vssvc.exe => MD5 is legit
C:\Windows\system32\wscsvc.dll => MD5 is legit
C:\Windows\system32\wbem\WMIsvc.dll => MD5 is legit
C:\Windows\system32\wuaueng.dll => MD5 is legit
C:\Windows\system32\qmgr.dll => MD5 is legit
C:\Windows\system32\es.dll => MD5 is legit
C:\Windows\system32\cryptsvc.dll => MD5 is legit
C:\Windows\system32\svchost.exe => MD5 is legit
C:\Windows\system32\rpcss.dll => MD5 is legit
**** End of log ****
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Fri 20 Jan 2012, 11:00 pm
Everything looks fine. Okay, lets reset net log.
Go to Start > Run > CMD and type next commands, after each one press Enter.
  • netsh int ip reset reset.log
  • netsh winsock reset catalog
Please restart your computer and let me know if your problem is solved.
Regards,
Nazzgul
Tech Advisor
Tech Advisor
Post by Voods on Fri 20 Jan 2012, 11:18 pm
Hi
This still hasn't foxed the issue.
When clicking the Network/internet access icon in the taskbar, it comes up with
No internet access
Unidentified Network
The exclamation mark is still over the network icon
Will it help if I give a report of some kind from another computer to compare the two?
I have a fresh install on another laptop of the same OS
I know a fresh install would be the easiest option, but, it's taken time to get my laptop setup exactly how I want it.
Regards
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Fri 20 Jan 2012, 11:37 pm
It's normally to see Unidentified Network, I had same with my LAN connectivity with Windows XP. But that thing with No Internet Access is our main problem.
Would you mind to turn router off from power, turn off modem, and unplug all cables, turn off all your PCs, and wait about 5 minutes before plugging all again. Disable connections before last step.
It might be a router issue or cable maybe, lets begin from that. Because it looks like you don't have software problem.
Tech Advisor
Tech Advisor
More info included
Post by Voods on Sat 21 Jan 2012, 12:03 am
Hi there
I have done all that, still to no avail. It's as if no connection what so ever can be detected, through the ethernet.
The troubleshooter doesn't detect any problem either.
It has to be something on my disk, because when I put a different disk in on this same laptop, there is no issue what so ever. I orginally thought my network adapter may be faulty.
Regards
Edit: Now, I have no connection, not even limited connection as previously, at the start of my dilemma!
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Sat 21 Jan 2012, 5:46 am
Okay.
Please do ipconfig command from post above again, and post me resuts.
Regards
Tech Advisor
Tech Advisor
Post by Voods on Sun 22 Jan 2012, 12:40 am
Link-local IPv6 Address . . . . . : fe80::f06a:ca2b:3e7e:e139%44(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.225.57(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Link-local IPv6 Address . . . . . : fe80::5f6:bcfc:b65d:dd90%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.7(Preferred)
Lease Obtained. . . . . . . . . . : 21 January 2012 13:20:22
Lease Expires . . . . . . . . . . : 22 January 2012 13:20:22
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 184557372
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:3887:5e0:3f57:fef8(Preferred)
Link-local IPv6 Address . . . . . : fe80::3887:5e0:3f57:fef8%11(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Sun 22 Jan 2012, 2:13 am
Check this line :
Default Gateway . . . . . . . . . : missing!
You probably didn't configure it well. Try to set Gateway manually in your Internet and Connection page.
Tech Advisor
Tech Advisor
Post by Voods on Sun 22 Jan 2012, 3:24 am
Hi
I may wrong, but with me using DHCP, i've never never needed to set the gateway or other such settings. I've always set it to discover the addresses automatically.
I have tried to set up a unique static IP address, and I do get limited connectivity..
Regards
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Sun 22 Jan 2012, 4:05 am
Ah, right, I always forget you're doing DHCP, and not only LAN..
Please read article from bellow:
http://www.computing.net/answers/windows-2003/no-gateway-to-my-clients-/4611.html
This also, it might help you to solve a problem.
http://technet.microsoft.com/en-us/library/cc958929.aspx
Tech Advisor
Tech Advisor
Post by Voods on Sun 22 Jan 2012, 5:45 am
I've installed the RSAT tools, and set the router option in the DHCP Scope options as mentioned in that post, still to no avail.
I've booted in safe mode with networking and still no joy.
I tried booting with a linux disk, and I have no problems.
So it must some kind of software issue, rather than incorrect settings, well I think, either that or I have a nasty infection, one that's deeper in the system, that my usual programs haven't detected.
This has happened in the past. Is there any chance this could be moved to the malware forum, and have somebody check it over, possibly for some kind of rootkit?
I've exhausted all options I can think of, and on the advice you have given me.
Regards
Dave
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Sun 22 Jan 2012, 6:19 am
Hi Dave,
Thanks for letting me know. We can not be sure what is it, but you should open a new post in Virus, Spyware & Malware Removal forum.
Let them more space, we already made 2 pages of this topic
It could be a malware, but it is also possible that you're Windows installation is bad.
Regards,
Tech Advisor
Tech Advisor
Post by Voods on Sun 22 Jan 2012, 6:28 am
Hi
Thanks for all the assistance.
Just an update, I tried connecting again in Safe mode with networking after the last changes I made, I can now connect, with no issues.
So I don't know if this will help in anyway to solving the issue.
I really am perplexed!
Regards
Dave
Voods
Senior Surfer
Senior Surfer
Post by Nazzgull on Sun 22 Jan 2012, 7:33 am
Hi again Dave,
In Safe Mode your computer run limited number of services just to making Windows useful. So, It might be some of software you installed on your computer normally or a malware.
I suggest you to take a step in searching for malware and removal process with our Technical Staff.
Regards,
Tech Advisor
Tech Advisor
Post by Sponsored content Today at 4:10 pm
