Not sure what Im infected with but machine lags quite a bit
Post by quinlane06492 on 17th January 2012, 1:54 am
Machine has been running slowly for quite a while. Symantec doesn't find anything, but the last time this happened I had a virus.
Ran OTL but it wouldn't finish the scan, ran for about 10m hanging up on several files and then went unresponsive.
Ran AVG virus scan, two rootkits came up:
"";"C:\ProgramData\Microsoft\Search\Data\Applications\Windows\MSS014ED.log";"Hidden file";"Object is inaccessible."
"";"";"Service function NtMapViewOfSection hook -> 0x870F8338";"Object is inaccessible."
Said they were cleaned but after reboot they were still there on second scan.
MBR:
aswMBR version 0.9.9.1297 Copyright(c) 2011 AVAST Software
Run date: 2012-01-16 20:23:37
20:23:37.111 OS Version: Windows 6.1.7601 Service Pack 1
20:23:37.111 Number of processors: 2 586 0x170A
20:23:37.111 ComputerName: EDS-PC UserName: Ed's
20:27:39.817 Initialize success
20:28:36.452 AVAST engine defs: 12011601
20:28:43.831 Disk 0 (boot) \Device\Harddisk0\DR0 -> \Device\Ide\IAAStorageDevice-1
20:28:43.847 Disk 0 Vendor: TOSHIBA_ FG02 Size: 305245MB BusType: 3
20:28:43.894 Disk 0 MBR read successfully
20:28:43.894 Disk 0 MBR scan
20:28:43.909 Disk 0 Windows VISTA default MBR code
20:28:43.925 Disk 0 Partition 1 80 (A) 27 Hidden NTFS WinRE NTFS 1500 MB offset 2048
20:28:43.940 Disk 0 Partition 2 00 07 HPFS/NTFS NTFS 295547 MB offset 3074048
20:28:43.987 Disk 0 Partition 3 00 17 Hidd HPFS/NTFS NTFS 8197 MB offset 608354304
20:28:44.034 Disk 0 scanning sectors +625141760
20:28:44.159 Disk 0 scanning C:\windows\system32\drivers
20:29:03.084 Service scanning
20:29:03.724 Service SysPlant C:\windows\SYSTEM32\Drivers\SysPlant.sys **LOCKED** 32
20:29:03.740 Service Teefer2 C:\windows\system32\DRIVERS\teefer2.sys **LOCKED** 32
20:29:03.802 Service WPS C:\windows\system32\drivers\wpsdrvnt.sys **LOCKED** 32
20:29:03.802 Service WpsHelper C:\windows\system32\drivers\WpsHelper.sys **LOCKED** 32
20:29:04.333 Modules scanning
20:29:24.051 Disk 0 trace - called modules:
20:29:24.082 ntkrnlpa.exe CLASSPNP.SYS disk.sys iaStor.sys halmacpi.dll
20:29:24.082 1 nt!IofCallDriver -> \Device\Harddisk0\DR0[0x86c08030]
20:29:24.082 3 CLASSPNP.SYS[8b40459e] -> nt!IofCallDriver -> \Device\Ide\IAAStorageDevice-1[0x85df6028]
20:29:26.906 AVAST engine scan C:\windows
20:29:31.071 AVAST engine scan C:\windows\system32
20:32:56.134 AVAST engine scan C:\windows\system32\drivers
20:33:17.756 AVAST engine scan C:\windows\system32\config\systemprofile
20:34:57.218 AVAST engine scan C:\ProgramData
20:41:15.275 Scan finished successfully
20:41:26.851 Disk 0 MBR has been saved successfully to "C:\windows\system32\config\systemprofile\Desktop\MBR.dat"
20:41:26.867 The log file has been saved successfully to "C:\windows\system32\config\systemprofile\Desktop\aswMBR.txt"
Checkup:
Results of screen317's Security Check version 0.99.30
Windows 7 Service Pack 1 x86 (UAC is disabled!)
Internet Explorer 9
Antivirus/Firewall Check:
Windows Firewall Enabled!
AVG 2012
ESET Online Scanner v3
Symantec Endpoint Protection
McAfee Security Scan Plus
WMI entry may not exist for antivirus; attempting automatic update.
Ad-Aware
HijackThis 2.0.2
Java(TM) 6 Update 26
Java version out of date!
Adobe Reader X (10.1.2)
Process Check:
objlist.exe by Laurent
Norton ccSvcHst.exe
Ad-Aware AAWService.exe is disabled!
Ad-Aware AAWTray.exe is disabled!
AVG avgwdsvc.exe
AVG avgrsx.exe
AVG avgnsx.exe
AVG avgemc.exe
Hijack this
Scan saved at 7:55:13 PM, on 1/16/2012
Platform: Unknown Windows (WinNT 6.01.3505 SP1)
MSIE: Internet Explorer v9.00 (9.00.8112.16421)
C:\windows\system32\taskhost.exe
C:\windows\system32\Dwm.exe
C:\windows\Explorer.EXE
C:\Program Files\Symantec\Symantec Endpoint Protection\SmcGui.exe
C:\windows\system32\taskeng.exe
C:\Program Files\TOSHIBA\ConfigFree\NDSTray.exe
C:\Program Files\TOSHIBA\ConfigFree\CFSwMgr.exe
C:\Windows\System32\config\systemprofile\AppData\Local\Google\Chrome\Application\chrome.exe
C:\windows\system32\rundll32.exe
C:\windows\system32\SearchFilterHost.exe
O2 - BHO: HP Print Enhancer - {0347C33E-8762-4905-BF09-768834316C61} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_printenhancer.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll
O2 - BHO: Increase performance and video formats for your HTML5
quinlane06492
Posts Posts : 19
Joined Joined : 2010-10-10
Points Points : 22761
OTL.txt pt 1
Post by quinlane06492 on 17th January 2012, 3:23 pm
OTL logfile created on: 1/16/2012 10:56:42 PM - Run 1
OTL by OldTimer - Version 3.2.31.0 Folder = C:\windows\system32\config\systemprofile\Desktop
Home Premium Edition Service Pack 1 (Version = 6.1.7601) - Type = NTWorkstation
Internet Explorer (Version = 9.0.8112.16421)
2.87 Gb Total Physical Memory | 1.57 Gb Available Physical Memory | 54.67% Memory free
5.74 Gb Paging File | 4.31 Gb Available in Paging File | 75.06% Paging File free
%SystemDrive% = C: | %SystemRoot% = C:\windows | %ProgramFiles% = C:\Program Files
Drive C: | 288.62 Gb Total Space | 111.68 Gb Free Space | 38.70% Space Free | Partition Type: NTFS
Computer Name: EDS-PC | User Name: Ed's | Logged in as Administrator.
PRC - [2012/01/16 19:58:00 | 000,584,192 | ---- | M] (OldTimer Tools) -- C:\Windows\System32\config\systemprofile\Desktop\OTL.com
PRC - [2012/01/03 08:10:42 | 000,063,928 | ---- | M] (Adobe Systems Incorporated) -- C:\Program Files\Common Files\Adobe\ARM\1.0\armsvc.exe
PRC - [2011/12/05 14:17:44 | 024,242,056 | ---- | M] (Dropbox, Inc.) -- C:\Users\Ed's\AppData\Roaming\Dropbox\bin\Dropbox.exe
PRC - [2011/11/28 01:19:04 | 001,229,664 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG2012\avgnsx.exe
PRC - [2011/10/12 06:25:22 | 004,433,248 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG2012\AVGIDSAgent.exe
PRC - [2011/09/08 20:53:26 | 000,743,264 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG2012\avgrsx.exe
PRC - [2011/08/15 06:21:40 | 000,337,760 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG2012\avgcsrvx.exe
PRC - [2011/08/02 06:09:08 | 000,192,776 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG2012\avgwdsvc.exe
PRC - [2011/02/25 00:30:54 | 002,616,320 | ---- | M] (Microsoft Corporation) -- C:\Windows\explorer.exe
PRC - [2010/11/20 07:17:47 | 000,049,152 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\taskhost.exe
PRC - [2009/09/17 18:56:58 | 002,477,304 | ---- | M] (Symantec Corporation) -- C:\Program Files\Symantec\Symantec Endpoint Protection\Rtvscan.exe
PRC - [2009/09/17 18:38:02 | 001,864,888 | ---- | M] (Symantec Corporation) -- C:\Program Files\Symantec\Symantec Endpoint Protection\Smc.exe
PRC - [2009/09/17 18:27:26 | 001,455,432 | ---- | M] (Symantec Corporation) -- C:\Program Files\Symantec\Symantec Endpoint Protection\SmcGui.exe
PRC - [2009/08/11 18:09:54 | 000,185,712 | ---- | M] (TOSHIBA Corporation) -- C:\Program Files\TOSHIBA\TECO\TecoService.exe
PRC - [2009/08/10 21:55:46 | 000,185,712 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\CFIWmxSvcs.exe
PRC - [2009/08/05 16:18:50 | 000,464,224 | ---- | M] (TOSHIBA Corporation) -- C:\Program Files\TOSHIBA\Power Saver\TosCoSrv.exe
PRC - [2009/07/28 22:26:42 | 000,062,848 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\CFSwMgr.exe
PRC - [2009/07/28 17:43:04 | 000,128,344 | ---- | M] (TOSHIBA Corporation) -- C:\Windows\System32\TODDSrv.exe
PRC - [2009/07/13 17:24:00 | 000,304,496 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\NDSTray.exe
PRC - [2009/07/08 20:14:20 | 000,108,392 | ---- | M] (Symantec Corporation) -- C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
PRC - [2009/03/10 20:51:20 | 000,046,448 | ---- | M] (TOSHIBA CORPORATION) -- C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
========== Modules (No Company Name) ==========
MOD - [2012/01/05 04:48:44 | 000,411,120 | ---- | M] () -- C:\Windows\System32\config\systemprofile\AppData\Local\Google\Chrome\Application\16.0.912.75\ppgooglenaclpluginchrome.dll
MOD - [2012/01/05 04:48:43 | 003,767,792 | ---- | M] () -- C:\Windows\System32\config\systemprofile\AppData\Local\Google\Chrome\Application\16.0.912.75\pdf.dll
MOD - [2012/01/05 04:47:19 | 000,122,880 | ---- | M] () -- C:\Windows\System32\config\systemprofile\AppData\Local\Google\Chrome\Application\16.0.912.75\avutil-51.dll
MOD - [2012/01/05 04:47:18 | 000,222,208 | ---- | M] () -- C:\Windows\System32\config\systemprofile\AppData\Local\Google\Chrome\Application\16.0.912.75\avformat-53.dll
MOD - [2012/01/05 04:47:17 | 001,746,432 | ---- | M] () -- C:\Windows\System32\config\systemprofile\AppData\Local\Google\Chrome\Application\16.0.912.75\avcodec-53.dll
MOD - [2012/01/05 02:06:01 | 008,593,056 | ---- | M] () -- C:\Windows\System32\config\systemprofile\AppData\Local\Google\Chrome\Application\16.0.912.75\gcswf32.dll
MOD - [2011/10/05 03:52:30 | 000,756,048 | ---- | M] () -- C:\Program Files\Common Files\microsoft shared\OFFICE12\MSPTLS.DLL
SRV - File not found [Auto | Stopped] -- -- (Lavasoft Ad-Aware Service)
SRV - [2012/01/03 08:10:42 | 000,063,928 | ---- | M] (Adobe Systems Incorporated) [Auto | Running] -- C:\Program Files\Common Files\Adobe\ARM\1.0\armsvc.exe -- (AdobeARMservice)
SRV - [2011/10/12 06:25:22 | 004,433,248 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG2012\AVGIDSAgent.exe -- (AVGIDSAgent)
SRV - [2011/08/02 06:09:08 | 000,192,776 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG2012\avgwdsvc.exe -- (avgwd)
SRV - [2010/02/26 03:00:39 | 001,343,400 | ---- | M] (Microsoft Corporation) [Unknown | Stopped] -- C:\Windows\System32\Wat\WatAdminSvc.exe -- (WatAdminSvc)
SRV - [2010/01/15 07:49:20 | 000,227,232 | ---- | M] (McAfee, Inc.) [On_Demand | Stopped] -- C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe -- (McComponentHostService)
SRV - [2009/09/17 18:56:58 | 002,477,304 | ---- | M] (Symantec Corporation) [Auto | Running] -- C:\Program Files\Symantec\Symantec Endpoint Protection\Rtvscan.exe -- (Symantec AntiVirus)
SRV - [2009/09/17 18:38:02 | 001,864,888 | ---- | M] (Symantec Corporation) [Auto | Running] -- C:\Program Files\Symantec\Symantec Endpoint Protection\Smc.exe -- (SmcService)
SRV - [2009/09/17 17:21:10 | 000,341,320 | ---- | M] (Symantec Corporation) [Disabled | Stopped] -- C:\Program Files\Symantec\Symantec Endpoint Protection\SNAC.EXE -- (SNAC)
SRV - [2009/09/17 15:37:18 | 000,111,960 | ---- | M] (TOSHIBA Corporation) [On_Demand | Stopped] -- C:\Program Files\TOSHIBA\TOSHIBA HDD SSD Alert\TosSmartSrv.exe -- (TOSHIBA HDD SSD Alert Service)
SRV - [2009/08/17 12:48:42 | 000,051,512 | ---- | M] (TOSHIBA Corporation) [On_Demand | Stopped] -- C:\Program Files\TOSHIBA\TOSHIBA Service Station\TMachInfo.exe -- (TMachInfo)
SRV - [2009/08/11 18:09:54 | 000,185,712 | ---- | M] (TOSHIBA Corporation) [Auto | Running] -- C:\Program Files\TOSHIBA\TECO\TecoService.exe -- (TOSHIBA eco Utility Service)
SRV - [2009/08/10 21:55:46 | 000,185,712 | ---- | M] (TOSHIBA CORPORATION) [Auto | Running] -- C:\Program Files\TOSHIBA\ConfigFree\CFIWmxSvcs.exe -- (cfWiMAXService)
SRV - [2009/08/06 19:04:56 | 000,685,424 | ---- | M] (TOSHIBA Corporation) [On_Demand | Stopped] -- C:\Program Files\TOSHIBA\TPHM\TPCHSrv.exe -- (TPCHSrv)
SRV - [2009/08/05 16:18:50 | 000,464,224 | ---- | M] (TOSHIBA Corporation) [Auto | Running] -- C:\Program Files\TOSHIBA\Power Saver\TosCoSrv.exe -- (TosCoSrv)
SRV - [2009/07/28 17:43:04 | 000,128,344 | ---- | M] (TOSHIBA Corporation) [Auto | Running] -- C:\Windows\System32\TODDSrv.exe -- (TODDSrv)
SRV - [2009/07/13 20:16:13 | 000,025,088 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Windows\System32\sensrsvc.dll -- (SensrSvc)
SRV - [2009/07/13 20:15:41 | 000,680,960 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Windows Defender\MpSvc.dll -- (WinDefend)
SRV - [2009/07/13 12:06:15 | 003,093,880 | ---- | M] (Symantec Corporation) [On_Demand | Stopped] -- C:\Program Files\Symantec\LiveUpdate\LuComServer_3_3.EXE -- (LiveUpdate)
SRV - [2009/07/08 20:14:20 | 000,108,392 | ---- | M] (Symantec Corporation) [Auto | Running] -- C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe -- (ccSetMgr)
SRV - [2009/07/08 20:14:20 | 000,108,392 | ---- | M] (Symantec Corporation) [Auto | Running] -- C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe -- (ccEvtMgr)
SRV - [2009/05/22 13:02:20 | 000,250,616 | ---- | M] (WildTangent, Inc.) [On_Demand | Stopped] -- C:\Program Files\TOSHIBA Games\TOSHIBA Game Console\GameConsoleService.exe -- (GameConsoleService)
SRV - [2009/03/10 20:51:20 | 000,046,448 | ---- | M] (TOSHIBA CORPORATION) [Auto | Running] -- C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe -- (ConfigFree Service)
DRV - [2011/11/08 04:00:00 | 000,374,392 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Program Files\Common Files\Symantec Shared\EENGINE\eeCtrl.sys -- (eeCtrl)
DRV - [2011/11/08 04:00:00 | 000,106,104 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Program Files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys -- (EraserUtilRebootDrv)
DRV - [2011/10/07 06:23:48 | 000,230,608 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\Windows\System32\drivers\avgldx86.sys -- (Avgldx86)
DRV - [2011/10/04 06:21:28 | 000,016,720 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\AVGIDSShim.sys -- (AVGIDSShim)
DRV - [2011/09/13 06:30:10 | 000,032,592 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | Boot | Running] -- C:\windows\system32\DRIVERS\avgrkx86.sys -- (Avgrkx86)
DRV - [2011/08/08 06:08:58 | 000,040,016 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | System | Running] -- C:\Windows\System32\drivers\avgmfx86.sys -- (Avgmfx86)
DRV - [2011/08/03 03:00:00 | 001,576,312 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\ProgramData\Symantec\Definitions\VirusDefs\20120116.002\NAVEX15.SYS -- (NAVEX15)
DRV - [2011/08/03 03:00:00 | 000,086,136 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\ProgramData\Symantec\Definitions\VirusDefs\20120116.002\NAVENG.SYS -- (NAVENG)
DRV - [2011/07/11 01:14:38 | 000,295,248 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\Windows\System32\drivers\avgtdix.sys -- (Avgtdix)
DRV - [2011/07/11 01:14:14 | 000,024,272 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\AVGIDSFilter.sys -- (AVGIDSFilter)
DRV - [2011/07/11 01:14:12 | 000,134,736 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\AVGIDSDriver.sys -- (AVGIDSDriver)
DRV - [2011/07/11 01:14:12 | 000,023,120 | ---- | M] (AVG Technologies CZ, s.r.o. ) [Kernel | Boot | Running] -- C:\windows\system32\DRIVERS\AVGIDSEH.Sys -- (AVGIDSEH)
DRV - [2011/06/21 17:46:10 | 000,167,936 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\wpshelper.sys -- (WpsHelper)
DRV - [2010/11/20 05:24:41 | 000,052,224 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\TsUsbFlt.sys -- (TsUsbFlt)
DRV - [2010/11/20 04:59:44 | 000,035,968 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\windows\system32\drivers\WinUsb.sys -- (WinUsb)
DRV - [2009/12/30 13:54:03 | 000,124,976 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\SYMEVENT.SYS -- (SymEvent)
DRV - [2009/09/17 18:38:10 | 000,092,488 | ---- | M] (Symantec Corporation) [Kernel | Disabled | Stopped] -- C:\windows\SYSTEM32\Drivers\SysPlant.sys -- (SysPlant)
DRV - [2009/09/17 18:31:50 | 000,042,312 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Windows\System32\drivers\WPSDRVnt.sys -- (WPS)
DRV - [2009/09/03 16:03:48 | 000,188,080 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\windows\System32\Drivers\SYMTDI.SYS -- (SYMTDI)
DRV - [2009/09/03 16:03:48 | 000,026,416 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Stopped] -- C:\windows\System32\Drivers\SYMREDRV.SYS -- (SYMREDRV)
DRV - [2009/08/28 00:19:22 | 000,859,136 | ---- | M] (Realtek Semiconductor Corporation ) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\rtl8192se.sys -- (rtl8192se)
DRV - [2009/08/26 11:54:38 | 000,421,424 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCDrv.sys -- (SPBBCDrv)
DRV - [2009/08/25 20:05:44 | 000,043,696 | ---- | M] (Symantec Corporation) [Kernel | System | Running] -- C:\Windows\System32\drivers\srtspx.sys -- (SRTSPX)
DRV - [2009/08/25 20:05:42 | 000,320,560 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\srtspl.sys -- (SRTSPL)
DRV - [2009/08/25 20:05:42 | 000,281,648 | ---- | M] (Symantec Corporation) [File_System | System | Running] -- C:\Windows\System32\drivers\srtsp.sys -- (SRTSP)
DRV - [2009/08/05 21:04:04 | 000,171,520 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\RtsUStor.sys -- (RSUSBSTOR)
DRV - [2009/07/30 19:45:56 | 000,022,912 | ---- | M] (TOSHIBA Corporation.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\tdcmdpst.sys -- (tdcmdpst)
DRV - [2009/07/24 17:57:06 | 000,275,536 | ---- | M] (TOSHIBA Corporation) [Kernel | Boot | Running] -- C:\windows\system32\DRIVERS\tos_sps32.sys -- (tos_sps32)
DRV - [2009/07/14 17:28:42 | 000,023,512 | ---- | M] (TOSHIBA Corporation) [Kernel | Boot | Running] -- C:\windows\system32\DRIVERS\TVALZ_O.SYS -- (TVALZ)
DRV - [2009/07/13 19:18:07 | 000,017,920 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\WSDPrint.sys -- (WSDPrintDevice)
DRV - [2009/07/13 18:52:10 | 000,014,336 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\vwifimp.sys -- (vwifimp)
DRV - [2009/07/13 17:13:48 | 001,035,776 | ---- | M] (LSI Corp) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\AGRSM.sys -- (AgereSoftModem)
DRV - [2009/07/13 17:09:17 | 004,194,816 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Stopped] -- C:\windows\system32\drivers\atikmdag.sys -- (atikmdag)
DRV - [2009/07/07 10:53:06 | 000,007,680 | ---- | M] (TOSHIBA Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\FwLnk.sys -- (FwLnk)
DRV - [2009/06/22 19:04:58 | 000,024,064 | ---- | M] (TOSHIBA Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\PGEffect.sys -- (PGEffect)
DRV - [2009/06/19 21:31:08 | 000,012,920 | ---- | M] (TOSHIBA Corporation) [Kernel | Auto | Running] -- C:\Windows\System32\drivers\TVALZFL.sys -- (TVALZFL)
DRV - [2009/05/27 14:31:18 | 000,050,064 | ---- | M] (Symantec Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\Teefer2.sys -- (Teefer2)
DRV - [2007/06/28 07:18:10 | 001,310,720 | ---- | M] (C-Media Inc) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\CM108.sys -- (USBPNPA)
DRV - [2005/08/17 07:45:00 | 000,058,352 | ---- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\sscdbus.sys -- (sscdbus) SAMSUNG USB Composite Device driver (WDM)
DRV - [2005/08/17 06:47:48 | 000,073,696 | ---- | M] (MCCI) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\sscdserd.sys -- (sscdserd) SAMSUNG CDMA Modem Diagnostic Serial Port (WDM)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Search Bar = [You must be registered and logged in to see this link.]
========== FireFox ==========
FF - prefs.js..browser.startup.homepage: "http://www.google.com"
FF - prefs.js..extensions.enabledItems: {3e559c3c-4aad-4168-bd47-e1056298df8e}:1.5.4
FF - prefs.js..extensions.enabledItems: {DDC359D1-844A-42a7-9AA1-88A850A938A8}:1.1.6
FF - prefs.js..extensions.enabledItems: {D4DD63FA-01E4-46a7-B6B1-EDAB7D6AD389}:0.9.6.5
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:7
FF - prefs.js..extensions.enabledItems: {B13721C7-F507-4982-B2E5-502A71474FED}:3.3.0.3971
FF - HKLM\Software\MozillaPlugins\@adobe.com/ShockwavePlayer: C:\windows\system32\Adobe\Director\np32dsw.dll (Adobe Systems, Inc.)
FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=: File not found
FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=1.0: C:\Program Files\iTunes\Mozilla Plugins\npitunes.dll ()
FF - HKLM\Software\MozillaPlugins\@divx.com/DivX Browser Plugin,version=1.0.0: C:\Program Files\DivX\DivX Plus Web Player\npdivx32.dll (DivX, LLC)
FF - HKLM\Software\MozillaPlugins\@divx.com/DivX VOD Helper,version=1.0.0: C:\Program Files\DivX\DivX OVS Helper\npovshelper.dll (DivX, LLC.)
FF - HKLM\Software\MozillaPlugins\@Google.com/GoogleEarthPlugin: C:\Program Files\Google\Google Earth\plugin\npgeplugin.dll (Google)
FF - HKLM\Software\MozillaPlugins\@java.com/JavaPlugin: C:\Program Files\Java\jre6\bin\new_plugin\npjp2.dll (Sun Microsystems, Inc.)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/GENUINE: disabled File not found
FF - HKLM\Software\MozillaPlugins\@Microsoft.com/NpCtrl,version=1.0: c:\Program Files\Microsoft Silverlight\4.0.60831.0\npctrl.dll ( Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3502.0922: C:\Program Files\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3508.1109: C:\Program Files\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@real.com/nppl3260;version=12.0.1.669: c:\program files\real\realplayer\Netscape6\nppl3260.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nprjplug;version=12.0.1.669: c:\program files\real\realplayer\Netscape6\nprjplug.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nprpchromebrowserrecordext;version=12.0.1.669: C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\MozillaPlugins\nprpchromebrowserrecordext.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nprphtml5videoshim;version=12.0.1.669: C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\MozillaPlugins\nprphtml5videoshim.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nprpjplug;version=12.0.1.669: c:\program files\real\realplayer\Netscape6\nprpjplug.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nsJSRealPlayerPlugin;version=: File not found
FF - HKLM\Software\MozillaPlugins\@tools.google.com/Google Update;version=3: C:\Program Files\Google\Update\1.3.21.79\npGoogleUpdate3.dll (Google Inc.)
FF - HKLM\Software\MozillaPlugins\@tools.google.com/Google Update;version=9: C:\Program Files\Google\Update\1.3.21.79\npGoogleUpdate3.dll (Google Inc.)
FF - HKLM\Software\MozillaPlugins\Adobe Reader: C:\Program Files\Adobe\Reader 10.0\Reader\AIR\nppdf32.dll (Adobe Systems Inc.)
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\m3ffxtbr@mywebsearch.com: C:\Program Files\MyWebSearch\bar\firefox\
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{23fcfd51-4958-4f00-80a3-ae97e717ed8b}: C:\Program Files\DivX\DivX Plus Web Player\firefox\html5video [2010/12/29 14:31:39 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{6904342A-8307-11DF-A508-4AE2DFD72085}: C:\Program Files\DivX\DivX Plus Web Player\firefox\wpa [2010/12/29 14:31:40 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\smartwebprinting@hp.com: C:\Program Files\HP\Digital Imaging\Smart Web Printing\MozillaAddOn3 [2011/01/02 19:59:25 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{ABDE892B-13A8-4d1b-88E6-365A6E755758}: C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\Firefox\Ext [2011/10/28 09:38:59 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{1E73965B-8B48-48be-9C8D-68B920ABC1C4}: C:\Program Files\AVG\AVG2012\Firefox4\ [2012/01/16 15:52:34 | 000,000,000 | ---D | M]
File not found (No name found) -- C:\DOCUMENTS AND SETTINGS\ED.ED-7F1CD858D447\APPLICATION DATA\MOVE NETWORKS
File not found (No name found) -- C:\DOCUMENTS AND SETTINGS\ED.ED-7F1CD858D447\APPLICATION DATA\MOZILLA\FIREFOX\PROFILES\674WF58N.DEFAULT\EXTENSIONS\{3E559C3C-4AAD-4168-BD47-E1056298DF8E}
File not found (No name found) -- C:\DOCUMENTS AND SETTINGS\ED.ED-7F1CD858D447\APPLICATION DATA\MOZILLA\FIREFOX\PROFILES\674WF58N.DEFAULT\EXTENSIONS\{463F6CA5-EE3C-4BE1-B7E6-7FEE11953374}
File not found (No name found) -- C:\DOCUMENTS AND SETTINGS\ED.ED-7F1CD858D447\APPLICATION DATA\MOZILLA\FIREFOX\PROFILES\674WF58N.DEFAULT\EXTENSIONS\{D4DD63FA-01E4-46A7-B6B1-EDAB7D6AD389}
File not found (No name found) -- C:\DOCUMENTS AND SETTINGS\ED.ED-7F1CD858D447\APPLICATION DATA\MOZILLA\FIREFOX\PROFILES\674WF58N.DEFAULT\EXTENSIONS\{DDC359D1-844A-42A7-9AA1-88A850A938A8}
[2010/10/18 07:33:07 | 000,000,000 | ---D | M] (Java Quick Starter) -- C:\PROGRAM FILES\JAVA\JRE6\LIB\DEPLOY\JQS\FF
File not found (No name found) -- C:\PROGRAM FILES\MOZILLA FIREFOX\EXTENSIONS\{B13721C7-F507-4982-B2E5-502A71474FED}
File not found (No name found) -- C:\PROGRAM FILES\MOZILLA FIREFOX\EXTENSIONS\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBA}
========== Chrome ==========
CHR - default_search_provider: Google (Enabled)
CHR - default_search_provider: search_url = {google:baseURL}search?{google:RLZ}{google:acceptedSuggestion}{google:originalQueryForSuggestion}{google:searchFieldtrialParameter}{google:instantFieldTrialGroupParameter}sourceid=chrome&ie={inputEncoding}&q={searchTerms}
CHR - default_search_provider: suggest_url = {google:baseSuggestURL}search?{google:searchFieldtrialParameter}{google:instantFieldTrialGroupParameter}client=chrome&hl={language}&q={searchTerms}
CHR - plugin: Shockwave Flash (Disabled) = C:\Users\Ed's\AppData\Local\Google\Chrome\User Data\PepperFlash\11.1.31.203\pepflashplayer.dll
CHR - plugin: Shockwave Flash (Enabled) = C:\Users\Ed's\AppData\Local\Google\Chrome\Application\17.0.963.26\gcswf32.dll
CHR - plugin: Remoting Viewer (Enabled) = internal-remoting-viewer
CHR - plugin: Native Client (Enabled) = C:\Users\Ed's\AppData\Local\Google\Chrome\Application\17.0.963.26\ppGoogleNaClPluginChrome.dll
CHR - plugin: Chrome PDF Viewer (Enabled) = C:\Users\Ed's\AppData\Local\Google\Chrome\Application\17.0.963.26\pdf.dll
CHR - plugin: Microsoft\u00AE Windows Media Player Firefox Plugin (Enabled) = C:\PFiles\Plugins\np-mswmp.dll
CHR - plugin: Adobe Acrobat (Enabled) = C:\Program Files\Adobe\Reader 10.0\Reader\Browser\nppdf32.dll
CHR - plugin: Java Deployment Toolkit 6.0.260.3 (Enabled) = C:\Program Files\Java\jre6\bin\new_plugin\npdeployJava1.dll
CHR - plugin: Java(TM) Platform SE 6 U26 (Enabled) = C:\Program Files\Java\jre6\bin\new_plugin\npjp2.dll
CHR - plugin: QuickTime Plug-in 7.7.1 (Enabled) = C:\Program Files\QuickTime\plugins\npqtplugin.dll
CHR - plugin: QuickTime Plug-in 7.7.1 (Enabled) = C:\Program Files\QuickTime\plugins\npqtplugin2.dll
CHR - plugin: QuickTime Plug-in 7.7.1 (Enabled) = C:\Program Files\QuickTime\plugins\npqtplugin3.dll
CHR - plugin: QuickTime Plug-in 7.7.1 (Enabled) = C:\Program Files\QuickTime\plugins\npqtplugin4.dll
CHR - plugin: QuickTime Plug-in 7.7.1 (Enabled) = C:\Program Files\QuickTime\plugins\npqtplugin5.dll
CHR - plugin: QuickTime Plug-in 7.7.1 (Enabled) = C:\Program Files\QuickTime\plugins\npqtplugin6.dll
CHR - plugin: QuickTime Plug-in 7.7.1 (Enabled) = C:\Program Files\QuickTime\plugins\npqtplugin7.dll
CHR - plugin: Google Talk Plugin (Enabled) = C:\Users\Ed's\AppData\Roaming\Mozilla\plugins\npgoogletalk.dll
CHR - plugin: Google Talk Plugin Video Accelerator (Enabled) = C:\Users\Ed's\AppData\Roaming\Mozilla\plugins\npgtpo3dautoplugin.dll
CHR - plugin: DivX VOD Helper Plug-in (Enabled) = C:\Program Files\DivX\DivX OVS Helper\npovshelper.dll
CHR - plugin: DivX Web Player (Enabled) = C:\Program Files\DivX\DivX Plus Web Player\npdivx32.dll
CHR - plugin: Google Earth Plugin (Enabled) = C:\Program Files\Google\Google Earth\plugin\npgeplugin.dll
CHR - plugin: Google Update (Enabled) = C:\Users\Ed's\AppData\Local\Google\Update\1.3.21.93\npGoogleUpdate3.dll
CHR - plugin: Windows Live\u0099 Photo Gallery (Enabled) = C:\Program Files\Windows Live\Photo Gallery\NPWLPG.dll
CHR - plugin: iTunes Application Detector (Enabled) = C:\Program Files\iTunes\Mozilla Plugins\npitunes.dll
CHR - plugin: RealNetworks(tm) Chrome Background Extension Plug-In (32-bit) (Enabled) = C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\MozillaPlugins\nprpchromebrowserrecordext.dll
CHR - plugin: RealPlayer(tm) HTML5VideoShim Plug-In (32-bit) (Enabled) = C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\MozillaPlugins\nprphtml5videoshim.dll
CHR - plugin: RealPlayer(tm) G2 LiveConnect-Enabled Plug-In (32-bit) (Enabled) = c:\program files\real\realplayer\Netscape6\nppl3260.dll
CHR - plugin: RealPlayer Version Plugin (Enabled) = c:\program files\real\realplayer\Netscape6\nprpjplug.dll
CHR - plugin: Unity Player (Enabled) = C:\Users\Ed's\AppData\LocalLow\Unity\WebPlayer\loader\npUnity3D32.dll
CHR - plugin: Shockwave for Director (Enabled) = C:\windows\system32\Adobe\Director\np32dsw.dll
CHR - plugin: Silverlight Plug-In (Enabled) = c:\Program Files\Microsoft Silverlight\4.0.60831.0\npctrl.dll
CHR - plugin: RealJukebox NS Plugin (Enabled) = c:\program files\real\realplayer\Netscape6\nprjplug.dll
CHR - plugin: Default Plug-in (Enabled) = default_plugin
CHR - Extension: Angry Birds = \Users\Ed's\AppData\Local\Google\Chrome\User Data\Default\Extensions\aknpkdffaafgjchaibgeefbgmgeghloj\1.1.2.1_0\
CHR - Extension: YouTube = \Users\Ed's\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo\4.2.3_0\
CHR - Extension: Google Search = \Users\Ed's\AppData\Local\Google\Chrome\User Data\Default\Extensions\coobgpohoikkiipiblmjeljniedjpjpf\0.0.0.16_0\
CHR - Extension: TinEye Reverse Image Search = \Users\Ed's\AppData\Local\Google\Chrome\User Data\Default\Extensions\haebnnbpedcbhciplfhjjkbafijpncjl\1.1.1_0\
CHR - Extension: Gmail = \Users\Ed's\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia\7_0\
O1 HOSTS File: ([2010/10/12 07:37:10 | 000,000,027 | ---- | M]) - C:\Windows\System32\drivers\etc\hosts
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - No CLSID value found.
O2 - BHO: (RealPlayer Download and Record Plugin for Internet Explorer) - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll (RealPlayer)
O2 - BHO: (DivX Plus Web Player HTML5
quinlane06492
Posts Posts : 19
OTL.txt pt2
Post by quinlane06492 on 17th January 2012, 3:24 pm
< %PROGRAMFILES%\*. >
[2010/07/12 14:12:27 | 000,000,000 | ---D | M] -- C:\Program Files\Acro Software
[2011/10/05 14:01:08 | 000,000,000 | ---D | M] -- C:\Program Files\Adobe
[2011/08/08 11:26:47 | 000,000,000 | ---D | M] -- C:\Program Files\Apple Software Update
[2012/01/16 15:35:46 | 000,000,000 | ---D | M] -- C:\Program Files\AVG
[2011/11/14 15:24:31 | 000,000,000 | ---D | M] -- C:\Program Files\Bonjour
[2010/01/16 11:16:47 | 000,000,000 | ---D | M] -- C:\Program Files\Brother
[2011/07/26 18:46:37 | 000,000,000 | ---D | M] -- C:\Program Files\Cisco Systems
[2011/10/28 09:39:06 | 000,000,000 | ---D | M] -- C:\Program Files\Common Files
[2009/09/03 20:09:56 | 000,000,000 | ---D | M] -- C:\Program Files\Corel
[2011/06/07 18:21:50 | 000,000,000 | ---D | M] -- C:\Program Files\DivX
[2011/07/20 11:08:18 | 000,000,000 | ---D | M] -- C:\Program Files\DVD Maker
[2010/03/23 08:27:59 | 000,000,000 | ---D | M] -- C:\Program Files\DVDVideoSoft
[2011/01/25 13:22:04 | 000,000,000 | ---D | M] -- C:\Program Files\EndNote X2
[2010/10/12 18:43:18 | 000,000,000 | ---D | M] -- C:\Program Files\ESET
[2010/12/14 17:11:15 | 000,000,000 | ---D | M] -- C:\Program Files\FastPCR
[2011/05/20 11:18:14 | 000,000,000 | ---D | M] -- C:\Program Files\Free RAR Extract Frog
[2009/12/30 11:25:07 | 000,000,000 | ---D | M] -- C:\Program Files\FUJIFILM
[2010/03/29 11:58:57 | 000,000,000 | ---D | M] -- C:\Program Files\Garmin
[2011/11/16 15:19:05 | 000,000,000 | ---D | M] -- C:\Program Files\Google
[2010/07/12 14:12:47 | 000,000,000 | ---D | M] -- C:\Program Files\GPLGS
[2010/10/11 10:37:33 | 000,000,000 | ---D | M] -- C:\Program Files\Graboid
[2011/08/14 12:19:25 | 000,000,000 | ---D | M] -- C:\Program Files\GraphPad
[2011/01/02 19:58:58 | 000,000,000 | ---D | M] -- C:\Program Files\HP
[2011/10/04 18:55:53 | 000,000,000 | ---D | M] -- C:\Program Files\Inkscape
[2011/06/07 18:41:48 | 000,000,000 | -H-D | M] -- C:\Program Files\InstallShield Installation Information
[2009/10/21 10:31:31 | 000,000,000 | ---D | M] -- C:\Program Files\Intel
[2011/12/16 16:58:24 | 000,000,000 | ---D | M] -- C:\Program Files\Internet Explorer
[2009/09/03 20:15:31 | 000,000,000 | ---D | M] -- C:\Program Files\Intuit
[2012/01/10 13:14:15 | 000,000,000 | ---D | M] -- C:\Program Files\iPod
[2012/01/10 13:15:37 | 000,000,000 | ---D | M] -- C:\Program Files\iTunes
[2011/07/29 09:02:20 | 000,000,000 | ---D | M] -- C:\Program Files\Java
[2011/10/13 15:07:35 | 000,000,000 | ---D | M] -- C:\Program Files\KnuckleCracker
[2011/08/16 12:08:32 | 000,000,000 | ---D | M] -- C:\Program Files\Lavasoft
[2011/10/04 14:52:32 | 000,000,000 | ---D | M] -- C:\Program Files\LCS Lite
[2011/12/28 14:30:30 | 000,000,000 | ---D | M] -- C:\Program Files\Malwarebytes' Anti-Malware
[2011/10/08 15:06:07 | 000,000,000 | ---D | M] -- C:\Program Files\McAfee Security Scan
[2009/07/14 02:49:30 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Games
[2011/08/28 15:45:18 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Office
[2009/10/21 10:28:10 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Office Suite Activation Assistant
[2011/10/15 02:17:53 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Silverlight
[2009/09/03 20:22:33 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft SQL Server Compact Edition
[2009/12/30 12:05:24 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Visual Studio
[2009/12/30 12:03:14 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Visual Studio 8
[2011/08/14 12:21:19 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Works
[2010/06/29 17:09:49 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft.NET
[2010/07/20 18:11:01 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla ActiveX Control v1.7.12
[2009/12/30 12:05:37 | 000,000,000 | ---D | M] -- C:\Program Files\MSBuild
[2010/11/28 12:59:48 | 000,000,000 | ---D | M] -- C:\Program Files\MSXML 4.0
[2011/08/14 12:22:27 | 000,000,000 | ---D | M] -- C:\Program Files\pDRAW32
[2009/09/03 20:03:15 | 000,000,000 | ---D | M] -- C:\Program Files\PlayReady
[2011/11/14 15:33:00 | 000,000,000 | ---D | M] -- C:\Program Files\QuickTime
[2010/12/04 14:21:58 | 000,000,000 | ---D | M] -- C:\Program Files\RasWin
[2011/10/28 09:39:11 | 000,000,000 | ---D | M] -- C:\Program Files\Real
[2009/10/21 10:41:46 | 000,000,000 | ---D | M] -- C:\Program Files\Realtek
[2009/10/21 10:42:56 | 000,000,000 | ---D | M] -- C:\Program Files\Realtek WLAN Driver
[2009/07/13 23:52:30 | 000,000,000 | ---D | M] -- C:\Program Files\Reference Assemblies
[2011/12/08 13:07:09 | 000,000,000 | ---D | M] -- C:\Program Files\Scaffold 3
[2009/12/15 11:22:26 | 000,000,000 | R--D | M] -- C:\Program Files\Skype
[2011/10/23 11:21:06 | 000,000,000 | ---D | M] -- C:\Program Files\Spotify
[2009/12/30 13:54:04 | 000,000,000 | ---D | M] -- C:\Program Files\Symantec
[2009/10/21 10:41:37 | 000,000,000 | -H-D | M] -- C:\Program Files\Temp
[2011/06/07 18:41:47 | 000,000,000 | ---D | M] -- C:\Program Files\TOSHIBA
[2011/06/07 18:41:47 | 000,000,000 | ---D | M] -- C:\Program Files\TOSHIBA Corporation
[2009/09/03 20:15:22 | 000,000,000 | ---D | M] -- C:\Program Files\TOSHIBA Games
[2010/10/10 16:59:51 | 000,000,000 | ---D | M] -- C:\Program Files\Trend Micro
[2009/07/13 23:53:23 | 000,000,000 | -H-D | M] -- C:\Program Files\Uninstall Information
[2010/07/20 18:10:26 | 000,000,000 | ---D | M] -- C:\Program Files\VideoLAN
[2011/07/20 11:08:13 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Defender
[2011/07/20 11:08:17 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Journal
[2011/04/06 09:39:08 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Live
[2011/07/20 11:08:19 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Mail
[2011/07/20 11:08:18 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Media Player
[2009/07/13 23:52:30 | 000,000,000 | ---D | M] -- C:\Program Files\Windows NT
[2011/07/20 11:08:17 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Photo Viewer
[2011/07/20 11:08:18 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Portable Devices
[2011/07/20 11:08:18 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Sidebar
[2011/09/21 15:13:14 | 000,000,000 | ---D | M] -- C:\Program Files\World of Warcraft
[2011/03/14 22:10:07 | 000,000,000 | ---D | M] -- C:\Program Files\Xvid
[2011/06/07 18:38:36 | 000,000,000 | ---D | M] -- C:\Program Files\Yahoo!
< MD5 for: AGP440.SYS >
[2009/07/13 20:26:15 | 000,053,312 | ---- | M] (Microsoft Corporation) MD5=507812C3054C21CEF746B6EE3D04DD6E -- C:\Windows\ERDNT\cache\AGP440.sys
[2009/07/13 20:26:15 | 000,053,312 | ---- | M] (Microsoft Corporation) MD5=507812C3054C21CEF746B6EE3D04DD6E -- C:\Windows\System32\drivers\AGP440.sys
[2009/07/13 20:26:15 | 000,053,312 | ---- | M] (Microsoft Corporation) MD5=507812C3054C21CEF746B6EE3D04DD6E -- C:\Windows\System32\DriverStore\FileRepository\machine.inf_x86_neutral_a97a2a0d0fbc6696\AGP440.sys
[2009/07/13 20:26:15 | 000,053,312 | ---- | M] (Microsoft Corporation) MD5=507812C3054C21CEF746B6EE3D04DD6E -- C:\Windows\winsxs\x86_machine.inf_31bf3856ad364e35_6.1.7601.17514_none_bc1a57271cf2f285\AGP440.sys
< MD5 for: ATAPI.SYS >
[2009/07/13 20:26:15 | 000,021,584 | ---- | M] (Microsoft Corporation) MD5=338C86357871C167A96AB976519BF59E -- C:\Windows\ERDNT\cache\atapi.sys
[2009/07/13 20:26:15 | 000,021,584 | ---- | M] (Microsoft Corporation) MD5=338C86357871C167A96AB976519BF59E -- C:\Windows\System32\drivers\atapi.sys
[2009/07/13 20:26:15 | 000,021,584 | ---- | M] (Microsoft Corporation) MD5=338C86357871C167A96AB976519BF59E -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_x86_neutral_fab873f3e8a3315c\atapi.sys
[2009/07/13 20:26:15 | 000,021,584 | ---- | M] (Microsoft Corporation) MD5=338C86357871C167A96AB976519BF59E -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.1.7601.17514_none_df3f92057fcbe7a7\atapi.sys
< MD5 for: DISK.SYS >
[2009/07/13 20:20:27 | 000,057,424 | ---- | M] (Microsoft Corporation) MD5=565003F326F99802E68CA78F2A68E9FF -- C:\Windows\System32\drivers\disk.sys
[2009/07/13 20:20:27 | 000,057,424 | ---- | M] (Microsoft Corporation) MD5=565003F326F99802E68CA78F2A68E9FF -- C:\Windows\System32\DriverStore\FileRepository\disk.inf_x86_neutral_b431b61a11f8df6c\disk.sys
[2009/07/13 20:20:27 | 000,057,424 | ---- | M] (Microsoft Corporation) MD5=565003F326F99802E68CA78F2A68E9FF -- C:\Windows\winsxs\x86_disk.inf_31bf3856ad364e35_6.1.7600.16385_none_f99cd807d58018cb\disk.sys
< MD5 for: IASTOR.SYS >
[2009/08/07 07:17:26 | 000,330,264 | ---- | M] (Intel Corporation) MD5=01446278D4563B3013C92830AE6CBB26 -- C:\Program Files\Intel\Intel Matrix Storage Manager\driver\IaStor.sys
[2009/08/07 07:17:26 | 000,330,264 | ---- | M] (Intel Corporation) MD5=01446278D4563B3013C92830AE6CBB26 -- C:\Windows\System32\drivers\iaStor.sys
[2009/08/07 07:17:26 | 000,330,264 | ---- | M] (Intel Corporation) MD5=01446278D4563B3013C92830AE6CBB26 -- C:\Windows\System32\DriverStore\FileRepository\iaahci.inf_x86_neutral_1f2a8fa4448bd5bf\iaStor.sys
[2009/08/07 07:24:14 | 000,408,600 | ---- | M] (Intel Corporation) MD5=BBB3B6DF1ABB0FE35802EDE85CC1C011 -- C:\Program Files\Intel\Intel Matrix Storage Manager\driver64\IaStor.sys
< MD5 for: NETLOGON.DLL >
[2010/11/20 07:20:28 | 000,563,712 | ---- | M] (Microsoft Corporation) MD5=C1809B9907ADEDAF16F50C894100883B -- C:\Windows\System32\netlogon.dll
[2010/11/20 07:20:28 | 000,563,712 | ---- | M] (Microsoft Corporation) MD5=C1809B9907ADEDAF16F50C894100883B -- C:\Windows\winsxs\x86_microsoft-windows-security-netlogon_31bf3856ad364e35_6.1.7601.17514_none_ffbf212e963c0162\netlogon.dll
[2009/07/13 20:16:02 | 000,563,712 | ---- | M] (Microsoft Corporation) MD5=EAA75D9000B71F10EEC04D2AE6C60E81 -- C:\Windows\ERDNT\cache\netlogon.dll
< MD5 for: NVSTOR.SYS >
[2011/03/11 00:39:00 | 000,143,744 | ---- | M] (NVIDIA Corporation) MD5=4380E59A170D88C4F1022EFF6719A8A4 -- C:\Windows\System32\drivers\nvstor.sys
[2011/03/11 00:39:00 | 000,143,744 | ---- | M] (NVIDIA Corporation) MD5=4380E59A170D88C4F1022EFF6719A8A4 -- C:\Windows\System32\DriverStore\FileRepository\nvraid.inf_x86_neutral_0276fc3b3ea60d41\nvstor.sys
[2011/03/11 00:39:00 | 000,143,744 | ---- | M] (NVIDIA Corporation) MD5=4380E59A170D88C4F1022EFF6719A8A4 -- C:\Windows\winsxs\x86_nvraid.inf_31bf3856ad364e35_6.1.7601.17577_none_3ba44e691d6eb11d\nvstor.sys
[2011/03/11 00:28:10 | 000,143,744 | ---- | M] (NVIDIA Corporation) MD5=66D468654A58594F5F3BA63D5AD5B1AF -- C:\Windows\winsxs\x86_nvraid.inf_31bf3856ad364e35_6.1.7601.21680_none_3c1c1942369abb77\nvstor.sys
[2010/11/20 07:30:06 | 000,143,744 | ---- | M] (NVIDIA Corporation) MD5=9283C58EBAA2618F93482EB5DABCEC82 -- C:\Windows\System32\DriverStore\FileRepository\nvraid.inf_x86_neutral_dd659ed032d28a14\nvstor.sys
[2010/11/20 07:30:06 | 000,143,744 | ---- | M] (NVIDIA Corporation) MD5=9283C58EBAA2618F93482EB5DABCEC82 -- C:\Windows\winsxs\x86_nvraid.inf_31bf3856ad364e35_6.1.7601.17514_none_3be22d131d40bd72\nvstor.sys
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install\\LastSuccessTime: 2012-01-13 22:44:19
< hklm\software\clients\startmenuinternet|command /rs >
HKEY_LOCAL_MACHINE\software\clients\startmenuinternet\Google Chrome\InstallInfo\\ShowIconsCommand: "C:\windows\system32\config\systemprofile\AppData\Local\Google\Chrome\Application\chrome.exe" --show-icons [2012/01/05 04:48:46 | 001,047,024 | ---- | M] (Google Inc.)
HKEY_LOCAL_MACHINE\software\clients\startmenuinternet\Google Chrome\InstallInfo\\HideIconsCommand: "C:\windows\system32\config\systemprofile\AppData\Local\Google\Chrome\Application\chrome.exe" --hide-icons [2012/01/05 04:48:46 | 001,047,024 | ---- | M] (Google Inc.)
HKEY_LOCAL_MACHINE\software\clients\startmenuinternet\Google Chrome\InstallInfo\\ReinstallCommand: "C:\windows\system32\config\systemprofile\AppData\Local\Google\Chrome\Application\chrome.exe" --make-default-browser [2012/01/05 04:48:46 | 001,047,024 | ---- | M] (Google Inc.)
HKEY_LOCAL_MACHINE\software\clients\startmenuinternet\Google Chrome\shell\open\command\\: "C:\windows\system32\config\systemprofile\AppData\Local\Google\Chrome\Application\chrome.exe" [2012/01/05 04:48:46 | 001,047,024 | ---- | M] (Google Inc.)
HKEY_LOCAL_MACHINE\software\clients\startmenuinternet\IEXPLORE.EXE\InstallInfo\\ShowIconsCommand: "C:\Windows\System32\ie4uinit.exe" -show [2011/07/20 11:48:30 | 000,074,240 | ---- | M] (Microsoft Corporation)
HKEY_LOCAL_MACHINE\software\clients\startmenuinternet\IEXPLORE.EXE\InstallInfo\\ReinstallCommand: "C:\Windows\System32\ie4uinit.exe" -reinstall [2011/07/20 11:48:30 | 000,074,240 | ---- | M] (Microsoft Corporation)
HKEY_LOCAL_MACHINE\software\clients\startmenuinternet\IEXPLORE.EXE\InstallInfo\\HideIconsCommand: "C:\Windows\System32\ie4uinit.exe" -hide [2011/07/20 11:48:30 | 000,074,240 | ---- | M] (Microsoft Corporation)
HKEY_LOCAL_MACHINE\software\clients\startmenuinternet\IEXPLORE.EXE\shell\naom\command\\: "C:\Program Files\Internet Explorer\iexplore.exe" -extoff [2011/07/20 11:48:31 | 000,748,336 | ---- | M] (Microsoft Corporation)
HKEY_LOCAL_MACHINE\software\clients\startmenuinternet\IEXPLORE.EXE\shell\open\command\\: "C:\Program Files\Internet Explorer\iexplore.exe" [2011/07/20 11:48:31 | 000,748,336 | ---- | M] (Microsoft Corporation)
< hklm\software\clients\startmenuinternet|command /64 /rs >
@Alternate Data Stream - 104 bytes -> C:\ProgramData\TEMP:D1B5B4F1
quinlane06492
Posts Posts : 19
Extras.txt
Post by quinlane06492 on 17th January 2012, 3:25 pm
OTL Extras logfile created on: 1/16/2012 10:56:42 PM - Run 1
.cpl [@ = cplfile] -- C:\windows\System32\control.exe (Microsoft Corporation)
.hlp [@ = hlpfile] -- C:\windows\winhlp32.exe (Microsoft Corporation)
.scr [@ = RasWin.Script] -- C:\Program Files\RasWin\RasWin.exe ()
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
comfile [open] -- "%1" %*
exefile [open] -- "%1" %*
hlpfile [open] -- %SystemRoot%\winhlp32.exe %1 (Microsoft Corporation)
https [open] -- Reg Error: Key error.
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
Directory [AddToPlaylistVLC] -- "C:\Program Files\VideoLAN\VLC\vlc.exe" --started-from-file --playlist-enqueue "%1" ()
Directory [PlayWithVLC] -- "C:\Program Files\VideoLAN\VLC\vlc.exe" --started-from-file --no-playlist-enqueue "%1" ()
Folder [open] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
Folder [explore] -- Reg Error: Value error.
"cval" = 1
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"UpdatesDisableNotify" = 0
"DisableMonitoring" = 1
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
"VistaSp1" = Reg Error: Unknown registry data type -- File not found
"AntiVirusOverride" = 0
"AntiSpywareOverride" = 0
"FirewallOverride" = 0
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\Vol]
"DisableSR" = 0
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
"DisableNotifications" = 0
"EnableFirewall" = 1
"{002B1E90-3241-4D45-8831-E89020F8E7E6}" = EndNote X2
"{008D69EB-70FF-46AB-9C75-924620DF191A}" = TOSHIBA Speech System SR Engine(U.S.) Version1.0
"{01250B8F-D947-4F8A-9408-FE8E3EE2EC92}" = MyToshiba
"{052B4734-CD9B-468F-B25D-D1E136B2C95A}" = Ad-Aware
"{0B0F231F-CE6A-483D-AA23-77B364F75917}" = Windows Live Installer
"{0D795777-9D60-4692-8386-F2B3F2B5E5BF}" = Label@Once 1.0
"{0F367CA3-3B2F-43F9-A44A-25A8EE69E45D}" = Scan
"{0FB630AB-7BD8-40AE-B223-60397D57C3C9}" = Realtek WLAN Driver
"{12B3A009-A080-4619-9A2A-C6DB151D8D67}" = TOSHIBA Assist
"{175F0111-2968-4935-8F70-33108C6A4DE3}" = MarketResearch
"{19BA08F7-C728-469C-8A35-BFBD3633BE08}" = Windows Live Movie Maker
"{1F6AB0E7-8CDD-4B93-8A23-AA9EB2FEFCE4}" = Junk Mail filter update
"{200FEC62-3C34-4D60-9CE8-EC372E01C08F}" = Windows Live SOXE Definitions
"{21A2F5EE-1DC5-488A-BE7E-E526F8C61488}" = DeviceDiscovery
"{26A24AE4-039D-4CA4-87B4-2F83216022FF}" = Java(TM) 6 Update 26
"{28C2DED6-325B-4CC7-983A-1777C8F7FBAB}" = RealUpgrade 1.1
"{2934DCB0-F8EE-11E0-A4A5-B8AC6F97B88E}" = Google Earth Plug-in
"{2EEA7AA4-C203-4b90-A34F-19FB7EF1C81C}" = BufferChm
"{2EFCC193-D915-4CCB-9201-31773A27BC06}" = Symantec Endpoint Protection
"{3336F667-9049-4D46-98B6-4C743EEBC5B1}" = Windows Live Photo Gallery
"{343666E2-A059-48AC-AD67-230BF74E2DB2}" = Apple Application Support
"{34F4D9A4-42C2-4348-BEF4-E553C84549E7}" = Windows Live Photo Gallery
"{35B73650-6899-11DA-6784-00232A9018BE}" = GraphPad Prism 5
"{3A4D5E2D-988D-4ee9-8E7F-3AC200A2B8F5}" = 4500G510nz_Software_Min
"{3B843B38-04B1-4CE6-8888-586273E0F289}" = Quickbooks Financial Center
"{3C3901C5-3455-3E0A-A214-0B093A5070A6}" = Microsoft .NET Framework 4 Client Profile
"{3F9B8A3E-7BE6-4B27-8DF3-C32DD094AD6C}" = Science Lab 2005
"{3FBF6F99-8EC6-41B4-8527-0A32241B5496}" = TOSHIBA Speech System TTS Engine(U.S.) Version1.0
"{43CDF946-F5D9-4292-B006-BA0D92013021}" = WebReg
"{440B915A-0C85-45DB-92AE-75AE14704A64}" = Fax
"{4A70EF07-7F88-4434-BB61-D1DE8AE93DD4}" = SolutionCenter
"{4CBABDFD-49F8-47FD-BE7D-ECDE7270525A}" = Windows Live PIMT Platform
"{53536479-DFB0-47ED-9D10-43F3708C222D}" = TOSHIBA eco Utility
"{5AF550B4-BB67-4E7E-82F1-2C4300279050}" = ToshibaRegistration
"{5B05FF91-F20C-4832-A8DE-E1912639C17C}" = 4500G510nz
"{5CF6EEE9-86B1-3DB6-A07C-8F6C079C39BA}" = Google Talk Plugin
"{5DA0E02F-970B-424B-BF41-513A5018E4C0}" = TOSHIBA Disc Creator
"{5E6F6CF3-BACC-4144-868C-E14622C658F3}" = TOSHIBA Web Camera Application
"{5EE7D259-D137-4438-9A5F-42F432EC0421}" = VC80CRTRedist - 8.0.50727.4053
"{617C36FD-0CBE-4600-84B2-441CEB12FADF}" = TOSHIBA Extended Tiles for Windows Mobility Center
"{61AD15B2-50DB-4686-A739-14FE180D4429}" = Windows Live ID Sign-in Assistant
"{622D7340-9B69-4F36-D0B6-69A07F48DED1}" = Creeper World 2
"{63FF21C9-A810-464F-B60A-3111747B1A6D}" = GPBaseService2
"{641E3749-55CD-DD82-8480-6C95C3A175BA}" = Creeper World 2 Demo
"{682B3E4F-696A-42DE-A41C-4C07EA1678B4}" = Windows Live SOXE
"{68A10D12-0D0F-4212-BDE6-D87FAD32A8FA}" = SmartWebPrinting
"{690879A5-18EF-447B-98D6-B699D51008AB}" = 4500_G510nz_Help
"{6A05FEDF-662E-46BF-8A25-010E3F1C9C69}" = Windows Live UX Platform Language Pack
"{6B2FFB21-AC88-45C3-9A7D-4BB3E744EC91}" = HPSSupply
"{6BBA26E9-AB03-4FE7-831A-3535584CA002}" = Toolbox
"{6C5F3BDC-0A1B-4436-A696-5939629D5C31}" = TOSHIBA DVD PLAYER
"{7059BDA7-E1DB-442C-B7A1-6144596720A4}" = HP Update
"{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}" = Microsoft Visual C++ 2005 Redistributable
"{71DFAA65-77FA-41F3-A748-013B5A8524A3}" = Garmin City Navigator North America NT 2010.30
"{7770E71B-2D43-4800-9CB3-5B6CAAEBEBEA}" = RealNetworks - Microsoft Visual C++ 2008 Runtime
"{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}" = Apple Software Update
"{79155F2B-9895-49D7-8612-D92580E0DE5B}" = Bonjour
"{7BE15435-2D3E-4B58-867F-9C75BED0208C}" = QuickTime
"{7E0E61CC-1C99-429D-BEA7-C4DD5B898D2A}" = HP Officejet 4500 G510n-z
"{80956555-A512-4190-9CAD-B000C36D6B6B}" = Windows Live Messenger
"{8153ED9A-C94A-426E-9880-5E6775C08B62}" = Apple Mobile Device Support
"{8398852A-7B61-4808-8F58-D0A40D1B2CB6}" = AVG 2012
"{84EBDF39-4B33-49D7-A0BD-EB6E2C4E81C1}" = Windows Live Sync
"{8833FFB6-5B0C-4764-81AA-06DFEED9A476}" = Realtek Ethernet Controller Driver
"{8837765B-0D51-470C-87AA-E9687C5B65A9}" = FastPCR
"{8DD46C6A-0056-4FEC-B70A-28BB16A1F11F}" = MSVCRT
"{90120000-0015-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0016-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0019-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001A-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_HOMESTUDENTR_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_HOMESTUDENTR_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_HOMESTUDENTR_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-0044-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00A1-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00BA-0409-0000-0000000FF1CE}" = Microsoft Office Groove MUI (English) 2007
"{90120000-00BA-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0114-0409-0000-0000000FF1CE}" = Microsoft Office Groove Setup Metadata MUI (English) 2007
"{90120000-0114-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0117-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90140000-2005-0000-0000-0000000FF1CE}" = Microsoft Office File Validation Add-In
"{9068B2BE-D93A-4C0A-861C-5E35E2C0E09E}" = Intel® Matrix Storage Manager
"{91120000-0030-0000-0000-0000000FF1CE}" = Microsoft Office Enterprise 2007
"{92A51949-EE4C-466D-AAF0-99E74A49A63F}" = DocMgr
"{92EA4134-10D1-418A-91E1-5A0453131A38}" = Windows Live Movie Maker
"{96AE7E41-E34E-47D0-AC07-1091A8127911}" = Realtek USB 2.0 Card Reader
"{970472D0-F5F9-4158-A6E3-1AE49EFEF2D3}" = Toshiba Application and Driver Installer
"{9B362566-EC1B-4700-BB9C-EC661BDE2175}" = DocProc
"{9D56775A-93F3-44A3-8092-840E3826DE30}" = Windows Live Mail
"{9DECD0F9-D3E8-48B0-A390-1CF09F54E3A4}" = TOSHIBA PC Health Monitor
"{A208044D-A88B-4ACF-AE95-E4F213E6EDC0}" = TOSHIBA Supervisor Password
"{A726AE06-AAA3-43D1-87E3-70F510314F04}" = Windows Live Writer
"{A80FA752-C491-4ED9-ABF0-4278563160B2}" = 32 Bit HP CIO Components Installer
"{A9BDCA6B-3653-467B-AC83-94367DA3BFE3}" = Windows Live Photo Common
"{AAAFC670-569B-4A2F-82B4-42945E0DE3EF}" = Windows Live Writer
"{AAF454FC-82CA-4F29-AB31-6A109485E76E}" = Windows Live Writer
"{AC6569FA-6919-442A-8552-073BE69E247A}" = TOSHIBA Service Station
"{AC76BA86-7AD7-1033-7B44-AA1000000001}" = Adobe Reader X (10.1.2)
"{ACEB2BAF-96DF-48FD-ADD5-43842D4C443D}" = Adobe AIR
"{AE8705FB-E13C-40A9-8A2D-68D6733FBFC2}" = Status
"{AF6D9313-E338-48F0-9B0C-7DE20EDB99CF}" = BioEdit
"{AF844339-2F8A-4593-81B3-9F4C54038C4E}" = Windows Live MIME IFilter
"{B0A3BAA4-9472-4553-9262-28C453AA2B99}" = FastPCR
"{B2455727-ED8F-4643-8A6E-F4AB8DE3633D}" = Network
"{B2544A03-10D0-4E5E-BA69-0362FFC20D18}" = OGA Notifier 2.0.0048.0
"{B65BBB06-1F8E-48F5-8A54-B024A9E15FDF}" = TOSHIBA Recovery Media Creator
"{B7DBF6E8-0D17-4BE4-853B-ACD6EFBD4A1F}" = iTunes
"{BD7204BA-DD64-499E-9B55-6A282CDF4FA4}" = Destinations
"{C43326F5-F135-4551-8270-7F7ABA0462E1}" = HPProductAssistant
"{C57BCDE1-7CB9-467D-B3BA-7E119916CDC1}" = Toshiba Online Backup
"{C66824E4-CBB3-4851-BB3F-E8CFD6350923}" = Windows Live Mail
"{C730E42C-935A-45BB-A0C5-37E5234D111B}" = TOSHIBA Face Recognition
"{CCA5EAAD-92F4-4B7A-B5EE-14294C66AB61}" = PlayReady PC Runtime x86
"{CE95A79E-E4FC-4FFF-8A75-29F04B942FF2}" = Windows Live UX Platform
"{D0387727-C89D-4774-B643-B9333EAA09DE}" = TOSHIBA Hardware Setup
"{D103C4BA-F905-437A-8049-DB24763BBE36}" = Skype™ 4.1
"{D4322448-B6AF-4316-B859-D8A0E84DCB38}" = TOSHIBA HDD/SSD Alert
"{D436F577-1695-4D2F-8B44-AC76C99E0002}" = Windows Live Photo Common
"{D45240D3-B6B3-4FF9-B243-54ECE3E10066}" = Windows Live Communications Platform
"{D8E363A7-88B7-446D-B2C0-E26CE4DC8E54}" = U3Launcher
"{DA84ECBF-4B79-47F2-B34C-95C38484C058}" = Skype Launcher
"{DC0A5F99-FD66-433F-9D3A-05DCBA64BE42}" = TrayApp
"{DDC8BDEE-DCAC-404D-8257-3E8D4B782467}" = Windows Live Writer Resources
"{E09C4DB7-630C-4F06-A631-8EA7239923AF}" = D3DX10
"{E171F5DA-6F17-472D-A223-92468142C5E8}" = AVG 2012
"{E50AE784-FABE-46DA-A1F8-7B6B56DCB22E}" = Microsoft Office Suite Activation Assistant
"{E69992ED-A7F6-406C-9280-1C156417BC49}" = Toshiba Quality Application
"{EB4DF488-AAEF-406F-A341-CB2AAA315B90}" = Windows Live Messenger
"{EE033C1F-443E-41EC-A0E2-559B539A4E4D}" = TOSHIBA Speech System Applications
"{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}" = Microsoft SQL Server 2005 Compact Edition [ENU]
"{F1D336A4-168A-010A-744B-DA8A4AA611DB}" = Creeper World
"{F3529665-D75E-4D6D-98F0-745C78C68E9B}" = TOSHIBA ConfigFree
"{FE044230-9CA5-43F7-9B58-5AC5A28A1F33}" = Windows Live Essentials
"{FEDD27A0-B306-45EF-BF58-B527406B42C8}" = TOSHIBA Value Added Package
"5347-8561-5487-6164" = Scaffold 3 Scaffold_3_00_06
"Adobe AIR" = Adobe AIR
"Adobe Photoshop 6.0" = Adobe Photoshop 6.0
"Adobe Shockwave Player" = Adobe Shockwave Player 11.5
"Adobe SVG Viewer" = Adobe SVG Viewer
"Cisco Connect" = Cisco Connect
"CreeperWorld.BA6B793AB2C9FDD744493F22666C1F8DFA806A5E.1" = Creeper World
"CutePDF Writer Installation" = CutePDF Writer 2.8
"DivX Setup.divx.com" = DivX Setup
"ENTERPRISER" = Microsoft Office Enterprise 2007
"ESET Online Scanner" = ESET Online Scanner v3
"Free 3GP Video Converter_is1" = Free 3GP Video Converter version 3.2
"Free RAR Extract Frog" = Free RAR Extract Frog
"HDMI" = Intel(R) Graphics Media Accelerator Driver
"HijackThis" = HijackThis 2.0.2
"HP Document Manager" = HP Document Manager 2.0
"HP Imaging Device Functions" = HP Imaging Device Functions 13.0
"HP Smart Web Printing" = HP Smart Web Printing 4.5
"HP Solution Center & Imaging Support Tools" = HP Solution Center 13.0
"HPExtendedCapabilities" = HP Customer Participation Program 13.0
"HPOCR" = OCR Software by I.R.I.S. 13.0
"Inkscape" = Inkscape 0.48.2
"InstallShield_{53536479-DFB0-47ED-9D10-43F3708C222D}" = TOSHIBA eco Utility
"InstallShield_{617C36FD-0CBE-4600-84B2-441CEB12FADF}" = TOSHIBA Extended Tiles for Windows Mobility Center
"InstallShield_{C730E42C-935A-45BB-A0C5-37E5234D111B}" = TOSHIBA Face Recognition
"InstallShield_{D4322448-B6AF-4316-B859-D8A0E84DCB38}" = TOSHIBA HDD/SSD Alert
"InstallShield_{FEDD27A0-B306-45EF-BF58-B527406B42C8}" = TOSHIBA Value Added Package
"ISI ResearchSoft - Export Helper" = ISI ResearchSoft - Export Helper
"LiveUpdate" = LiveUpdate 3.3 (Symantec Corporation)
"Malwarebytes' Anti-Malware_is1" = Malwarebytes Anti-Malware version 1.60.0.1800
"McAfee Security Scan" = McAfee Security Scan Plus
"RasWin" = RasWin (remove only)
"RealPlayer 12.0" = RealPlayer
"Shop for HP Supplies" = Shop for HP Supplies
"Spotify" = Spotify
"Uninstall_is1" = Uninstall 1.0.0.1
"VLC media player" = VLC media player 1.1.11
"WildTangent toshiba Master Uninstall" = WildTangent Games
"WinLiveSuite" = Windows Live Essentials
"World of Warcraft" = World of Warcraft
"Xvid_is1" = Xvid 1.2.1 final uninstall
[ Application Events ]
Error - 1/16/2012 7:58:28 PM | Computer Name = Eds-PC | Source = Microsoft-Windows-User Profiles Service | ID = 1505
Description = Windows cannot load the user's profile but has logged you on with
the default profile for the system. DETAIL - Access is denied.
Error - 1/16/2012 8:36:05 PM | Computer Name = Eds-PC | Source = Microsoft-Windows-User Profiles Service | ID = 1505
Error - 1/16/2012 9:05:07 PM | Computer Name = Eds-PC | Source = VSS | ID = 8193
Description =
Error - 1/16/2012 9:24:56 PM | Computer Name = Eds-PC | Source = SescLU | ID = 13
Description = LiveUpdate returned a non-critical error. Available content updates
may have failed to install.
Error - 1/16/2012 9:45:45 PM | Computer Name = Eds-PC | Source = Application Hang | ID = 1002
Description = The program OTL.com version 0.0.0.0 stopped interacting with Windows
and was closed. To see if more information about the problem is available, check
the problem history in the Action Center control panel. Process ID: 120c Start Time:
01ccd4b97a2da615 Termination Time: 21 Application Path: C:\Windows\System32\config\systemprofile\Downloads\OTL.com
Report
Error - 1/16/2012 10:25:14 PM | Computer Name = Eds-PC | Source = Microsoft-Windows-User Profiles Service | ID = 1505
Error - 1/17/2012 12:14:54 AM | Computer Name = Eds-PC | Source = VSS | ID = 8193
Description =
[ OSession Events ]
Error - 4/27/2011 10:24:29 AM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
Description = ID: 6, Application Name: Microsoft Office Outlook, Application Version:
12.0.6550.5003, Microsoft Office Version: 12.0.6425.1000. This session lasted 169758
seconds with 1200 seconds of active time. This session ended with a crash.
Error - 7/1/2011 8:31:33 AM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
Description = ID: 0, Application Name: Microsoft Office Word, Application Version:
12.0.6545.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 38783
seconds with 0 seconds of active time. This session ended with a crash.
Error - 7/13/2011 12:00:28 AM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6557.5001, Microsoft Office Version: 12.0.6425.1000. This session lasted 440061
seconds with 1740 seconds of active time. This session ended with a crash.
Error - 7/18/2011 8:30:11 AM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6557.5001, Microsoft Office Version: 12.0.6425.1000. This session lasted 332412
seconds with 1440 seconds of active time. This session ended with a crash.
Error - 8/15/2011 5:04:16 PM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6545.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 364402
seconds with 22380 seconds of active time. This session ended with a crash.
Error - 8/28/2011 2:57:51 PM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6557.5001, Microsoft Office Version: 12.0.6425.1000. This session lasted 24
Error - 8/28/2011 3:08:39 PM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6557.5001, Microsoft Office Version: 12.0.6425.1000. This session lasted 629
seconds with 60 seconds of active time. This session ended with a crash.
Error - 11/28/2011 12:49:32 PM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6562.5003, Microsoft Office Version: 12.0.6425.1000. This session lasted 75277
Error - 12/31/2011 5:13:10 PM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
Description = ID: 1, Application Name: Microsoft Office Excel, Application Version:
12.0.6654.5003, Microsoft Office Version: 12.0.6425.1000. This session lasted 108
Error - 1/9/2012 7:54:15 AM | Computer Name = Eds-PC | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6545.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 63525
seconds with 25560 seconds of active time. This session ended with a crash.
[ System Events ]
Error - 1/13/2011 8:20:07 PM | Computer Name = Eds-PC | Source = Service Control Manager | ID = 7011
Description = A timeout (30000 milliseconds) was reached while waiting for a transaction
response from the ShellHWDetection service.
Error - 1/13/2011 9:03:35 PM | Computer Name = Eds-PC | Source = Service Control Manager | ID = 7011
response from the Wlansvc service.
Error - 1/15/2011 3:56:15 PM | Computer Name = Eds-PC | Source = bowser | ID = 8003
Description =
Error - 1/16/2011 12:24:25 PM | Computer Name = Eds-PC | Source = BROWSER | ID = 8032
Description =
Error - 1/16/2011 12:51:43 PM | Computer Name = Eds-PC | Source = bowser | ID = 8003
Description =
Error - 1/17/2011 10:57:38 AM | Computer Name = Eds-PC | Source = EventLog | ID = 6008
Description = The previous system shutdown at 2:40:22 PM on ?1/?16/?2011 was unexpected.
Error - 1/17/2011 10:57:39 AM | Computer Name = EDS-PC | Source = BugCheck | ID = 1001
Description =
Error - 1/17/2011 10:58:51 AM | Computer Name = Eds-PC | Source = DCOM | ID = 10016
Description =
Error - 1/17/2011 11:36:02 AM | Computer Name = Eds-PC | Source = DCOM | ID = 10016
Description =
Error - 1/17/2011 3:29:27 PM | Computer Name = Eds-PC | Source = bowser | ID = 8003
Description =
quinlane06492
Posts Posts : 19
Joined Joined : 2010-10-10
Points Points : 22761
Re: Not sure what Im infected with but machine lags quite a bit
Post by quinlane06492 on 17th January 2012, 3:29 pm
Update, Finally got OTL to run by leaving it overnight. At times entering text in word and other fields can be unbearable. Sometimes I can't even see the text Im entering until after Im done typing. The first time I tried to post this the browser went unresponsive about 5 times. I finally just rebooted and decided to try again.
quinlane06492
Posts Posts : 19
Post by quinlane06492 on 19th January 2012, 4:18 pm
bump
quinlane06492
Posts Posts : 19
Post by houndmom on 21st January 2012, 12:08 am
Welcome
Hello, and welcome to GeekPolice.
I'm Houndmom and I will be helping you with your issues.
Please note the following information about the malware forum:
* Only Tech Officers, Global Moderators, Administrators, and Malware Advisors are allowed to give advice on removing malware from your computer.
* From this point on, please do not make any more changes to your computer; such as install/uninstall programs, use special fix tools, delete files, edit the registry, etc. - unless advised by the staff I noted above.
* Please do not ask for help elsewhere (in this site or other sites). Doing so can result in system changes, which may not show up in the logs you post.
* If you have already asked for help somewhere, please post the link to the topic you were helped.
* We try our best to reply quickly, but for any reason we do not reply in two days, do one of two things:
Reply to this topic with the word BUMP, or
see [You must be registered and logged in to see this link.]
* Lastly, keep in mind that we are volunteers, so you do not have to pay for malware removal. Persist in this topic until its close, and your computer is declared clean.
I am a student and need to get approval for each step. I appreciate your patience, and will return with the first step.
If we have helped you, Please consider helping us,  make a [You must be registered and logged in to see this link.].
Helping fight malware.
houndmom
Posts Posts : 1053
Joined Joined : 2010-04-27
OS OS : Windows 7 ultimate
Protection Protection : Bitdefender Total Security 2010
Points Points : 29777
Post by houndmom on 21st January 2012, 2:58 pm
Hello, thanks for waiting.
Please download [You must be registered and logged in to see this link.]. Save it to your desktop:
  • Doubleclick the drweb-cureit.exe file and click Scan to run express scan. Click OK in the pop-up window to allow the scan.
  • This will scan the files currently running in memory and if something is found, click the Yes button when it asks you if you want to cure it. This is only a short scan.
  • Once the short scan has finished, select Complete scan.
  • Click the green arrow at the right, and the scan will start.
  • Click Yes to all if it asks if you want to cure/move the file.
  • When the scan has finished, in the menu, click File and choose Save report list
  • Save the report to your desktop. The report will be called DrWeb.csv
  • Note:this report may need to be renamed to Dr.Web.txt in order to post it on the forum.
  • Please post the Dr.Web.txt report in your next reply
  • Close Dr.Web Cureit.
  • Important! Reboot your computer because it could be possible that files in use will be moved/deleted during reboot.
  • After reboot, post the contents of the log from Dr.Web in your next reply. (You can use Notepad to open the DrWeb.cvs report)
houndmom
Posts Posts : 1053
Post by quinlane06492 on 22nd January 2012, 5:30 pm
So another thing that I neglected to mention before, and I don't know if this is related or not, Windows recently updated and afterward my user accounts were all messed up. The settings were still there, ie in the Users/Ed's folder, but there was no Ed's user account to select on startup.
Anyway, heres the Dr.web.txt:
LaunchHelper.exe;C:\Documents and Settings\Ed's\AppData\Local\Application Data\Real\RealPlayer;Probably DLOADER.Trojan;Incurable.Deleted.;
LaunchHelper.exe;C:\Documents and Settings\Ed's\AppData\Local\Real\RealPlayer;Probably DLOADER.Trojan;Invalid path to file ;
CrucialScan.exe;C:\Documents and Settings\Ed's\Documents\DownThemAll;Trojan.DownLoader4.44749;Deleted.;
LaunchHelper.exe;C:\Users\Ed's\AppData\Local\Real\RealPlayer;Probably DLOADER.Trojan;Invalid path to file ;
GetAd[1].js\JSFile_1[0][eae];C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\8GJZ4N1B\GetAd[1];Probably SCRIPT.Virus;;
GetAd[1].js;C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\8GJZ4N1B;Container contains infected objects;Moved.;
GetAd[1].js;C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\8GJZ4N1B;Probably SCRIPT.Virus;Invalid path to file ;
There were a few others that were moved to quarantine the first time i ran it but I had to quit because the scan was taking too long and I needed to use the computer for work. Do to the user account issue I am somehow locked out of Documents and settings and I can't access the log file.
quinlane06492
Posts Posts : 19
Post by quinlane06492 on 24th January 2012, 7:16 pm
Bump
quinlane06492
Posts Posts : 19
Post by houndmom on 25th January 2012, 12:22 am
I understand this but I also need to see the scan results in their entirety so that I can help you fix it properly. Malware removal done incorrectly can cause your computer to crash. If I don't get all the information I need I can't properly assess the malware infection and how to reverse the affects.
Do you have another computer you could use for work until we can get this one cleaned up?
houndmom
Posts Posts : 1053
Post by quinlane06492 on 25th January 2012, 1:48 pm
ComboFix 12-01-23.02 - SYSTEM 01/25/2012 8:29.2.2 - x86
Microsoft Windows 7 Home Premium 6.1.7601.1.1252.1.1033.18.2940.2049 [GMT -5:00]
Running from: c:\windows\system32\config\systemprofile\Desktop\commy.exe
AV: AVG Anti-Virus Free Edition 2012 *Disabled/Updated* {5A2746B1-DEE9-F85A-FBCD-ADB11639C5F0}
AV: Symantec Endpoint Protection *Disabled/Updated* {88C95A36-8C3B-2F2C-1B8B-30FCCFDC4855}
FW: Symantec Endpoint Protection *Disabled* {B0F2DB13-C654-2E74-30D4-99C9310F0F2E}
SP: AVG Anti-Virus Free Edition 2012 *Disabled/Updated* {E146A755-F8D3-F7D4-C17D-96C36DBE8F4D}
SP: Symantec Endpoint Protection *Disabled/Updated* {33A8BBD2-AA01-20A2-213B-0B8EB45B02E8}
SP: Windows Defender *Disabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
* Created a new restore point
c:\users\Ed's\AppData\Roaming\Local
c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\Adobe Gamma Loader.exe.lnk
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\0.ddi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\1.ddi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\2.ddi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\3.ddi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\4.ddi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\5.ddi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\doctor_who_2005.6x02.day_of_the_moon.hdtv_xvid-fov_ns.avi.ddr
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\doctor_who_2005.6x04.the_doctors_wife.hdtv_xvid-fov_ns.avi(2).ddr
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\doctor_who_2005.6x04.the_doctors_wife.hdtv_xvid-fov_ns.avi.ddr
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\doctor_who_2005.6x05.the_rebel_flesh.hdtv_xvid-fov_ns.avi.ddr
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\doctor_who_2005_2005.6x01.the_impossible_astronaut_part1.hdtv_xvid-fov_ns.avi(2).ddr
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\doctor_who_2005_2005.6x01.the_impossible_astronaut_part1.hdtv_xvid-fov_ns.avi.ddr
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\Inception_Trailer_592.divx.ddr
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\settings.ddi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\Temporary Downloaded Files\doctor_who_2005.6x02.day_of_the_moon.hdtv_xvid-fov_ns.avi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\Temporary Downloaded Files\doctor_who_2005.6x04.the_doctors_wife.hdtv_xvid-fov_ns(2).avi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\Temporary Downloaded Files\doctor_who_2005.6x04.the_doctors_wife.hdtv_xvid-fov_ns.avi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\Temporary Downloaded Files\doctor_who_2005.6x05.the_rebel_flesh.hdtv_xvid-fov_ns.avi
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\Temporary Downloaded Files\doctor_who_2005_2005.6x01.the_impossible_astronaut_part1.hdtv_xvid-fov_ns.avi(2).ddp
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\Temporary Downloaded Files\doctor_who_2005_2005.6x01.the_impossible_astronaut_part1.hdtv_xvid-fov_ns.avi.ddp
c:\users\Ed's\AppData\Roaming\Local\Temp\DDM\Settings\Temporary Downloaded Files\Inception_Trailer_592.divx
c:\users\Ed's\Documents\~WRL0001.tmp
c:\users\Ed's\Documents\~WRL0003.tmp
c:\users\Ed's\Documents\~WRL0420.tmp
c:\users\Ed's\Documents\~WRL0467.tmp
c:\users\Ed's\Documents\~WRL1265.tmp
c:\users\Ed's\Documents\~WRL1817.tmp
c:\users\Ed's\Documents\~WRL2209.tmp
c:\users\Ed's\Documents\~WRL3324.tmp
c:\users\Ed's\Documents\~WRL3586.tmp
c:\users\Ed's\Documents\~WRL3797.tmp
c:\users\Ed's\Documents\A.tmp
((((((((((((((((((((((((( Files Created from 2011-12-25 to 2012-01-25 )))))))))))))))))))))))))))))))
2012-01-25 13:38 . 2012-01-25 13:38 -------- d-----w- c:\users\Public\AppData\Local\temp
2012-01-25 13:38 . 2012-01-25 13:38 -------- d-----w- c:\users\Ed's\AppData\Local\temp
2012-01-25 13:38 . 2012-01-25 13:38 -------- d-----w- c:\users\Default\AppData\Local\temp
2012-01-25 13:38 . 2012-01-25 13:38 -------- d-----w- c:\users\Administrator\AppData\Local\temp
2012-01-24 23:59 . 2012-01-24 23:59 -------- d-----w- C:\found.000
2012-01-22 19:37 . 2012-01-22 19:41 -------- d-----w- c:\program files\SimVector 4.6
2012-01-22 19:36 . 2012-01-22 19:36 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Local\Symantec
2012-01-21 23:15 . 2012-01-21 23:15 -------- d-----w- c:\windows\Profiles
2012-01-21 21:57 . 2012-01-21 21:57 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\inkscape
2012-01-21 15:10 . 2012-01-21 15:52 -------- d-----w- c:\windows\system32\config\systemprofile\DoctorWeb
2012-01-17 20:25 . 2012-01-17 20:25 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Local\WinZip
2012-01-17 20:24 . 2012-01-17 20:25 -------- d-----w- c:\programdata\WinZip
2012-01-16 21:20 . 2012-01-16 21:20 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Local\Apple Computer
2012-01-16 21:18 . 2012-01-16 21:18 -------- d-----w- C:\AVG2012
2012-01-16 20:52 . 2012-01-16 20:52 -------- d--h--w- c:\programdata\Common Files
2012-01-16 20:50 . 2012-01-25 13:11 -------- d-----w- c:\windows\system32\drivers\AVG
2012-01-16 20:50 . 2012-01-17 00:35 -------- d-----w- c:\programdata\AVG2012
2012-01-16 20:35 . 2012-01-16 20:35 -------- d-----w- c:\program files\AVG
2012-01-16 20:31 . 2012-01-16 20:39 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\vlc
2012-01-16 20:30 . 2012-01-25 13:11 -------- d-----w- c:\programdata\MFAData
2012-01-15 15:33 . 2012-01-15 15:33 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\Malwarebytes
2012-01-14 18:32 . 2012-01-14 18:32 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\GraphPad Software
2012-01-13 22:44 . 2011-11-21 10:47 6823496 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{215266E1-66D6-48C4-994A-07E5AF1974C3}\mpengine.dll
2012-01-12 19:58 . 2012-01-25 13:19 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\EndNote
2012-01-12 18:25 . 2012-01-12 18:25 -------- d-----w- c:\users\Default\AppData\Local\Google
2012-01-12 17:56 . 2012-01-21 21:08 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Local\Google
2012-01-12 17:41 . 2012-01-25 13:28 -------- d-----w- c:\users\Ed's_2
2012-01-12 17:23 . 2012-01-12 17:23 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Local\Adobe
2012-01-12 17:02 . 2012-01-12 17:02 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Local\TOSHIBA
2012-01-12 17:00 . 2012-01-25 13:40 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Local\Temp
2012-01-12 17:00 . 2012-01-24 20:26 -------- d-----w- c:\users\TEMP
2012-01-11 17:11 . 2011-11-17 05:38 1288472 ----a-w- c:\windows\system32\ntdll.dll
2012-01-11 17:11 . 2011-11-19 14:01 67072 ----a-w- c:\windows\system32\packager.dll
2012-01-11 17:11 . 2011-10-26 04:32 1328128 ----a-w- c:\windows\system32\quartz.dll
2012-01-11 17:11 . 2011-10-26 04:32 514560 ----a-w- c:\windows\system32\qdvd.dll
2012-01-10 18:14 . 2012-01-10 18:14 -------- d-----w- c:\program files\iPod
2012-01-10 18:14 . 2012-01-10 18:15 -------- d-----w- c:\program files\iTunes
2012-01-09 22:28 . 2012-01-23 19:52 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\Dropbox
2012-01-06 01:01 . 2012-01-10 19:10 -------- d-----r- c:\users\Ed's\Dropbox
2012-01-06 00:57 . 2012-01-11 22:08 -------- d-----w- c:\users\Ed's\AppData\Roaming\Dropbox
2012-01-04 14:08 . 2012-01-04 14:08 -------- d-----w- c:\users\Ed's\AppData\Local\Sunbelt Software
2012-01-03 13:10 . 2012-01-03 13:10 182672 ----a-w- c:\program files\Internet Explorer\Plugins\nppdf32.dll
2012-01-22 00:20 . 2011-07-21 13:59 414368 ----a-w- c:\windows\system32\FlashPlayerCPLApp.cpl
2011-11-24 04:25 . 2011-12-15 14:25 2342912 ----a-w- c:\windows\system32\win32k.sys
2011-11-05 04:26 . 2011-12-15 14:25 2048 ----a-w- c:\windows\system32\tzres.dll
2011-11-03 22:47 . 2011-12-16 15:20 1798144 ----a-w- c:\windows\system32\jscript9.dll
2011-11-03 22:40 . 2011-12-16 15:20 1427456 ----a-w- c:\windows\system32\inetcpl.cpl
2011-11-03 22:39 . 2011-12-16 15:20 1127424 ----a-w- c:\windows\system32\wininet.dll
2011-11-03 22:31 . 2011-12-16 15:20 2382848 ----a-w- c:\windows\system32\mshtml.tlb
"MyTOSHIBA"="c:\program files\TOSHIBA\My Toshiba\MyToshiba.exe" [2009-08-06 264048]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2009-09-02 141848]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2009-09-02 174104]
"Persistence"="c:\windows\system32\igfxpers.exe" [2009-09-02 151064]
"RtHDVCpl"="c:\program files\Realtek\Audio\HDA\RtHDVCpl.exe" [2009-07-29 7625248]
"TPwrMain"="c:\program files\TOSHIBA\Power Saver\TPwrMain.EXE" [2009-08-05 476512]
"HSON"="c:\program files\TOSHIBA\TBS\HSON.exe" [2009-03-09 55160]
"SmoothView"="c:\program files\Toshiba\SmoothView\SmoothView.exe" [2009-07-28 460088]
"00TCrdMain"="c:\program files\TOSHIBA\FlashCards\TCrdMain.exe" [2009-08-05 738616]
"TosWaitSrv"="c:\program files\TOSHIBA\TPHM\TosWaitSrv.exe" [2009-08-07 611672]
"ToshibaServiceStation"="c:\program files\TOSHIBA\TOSHIBA Service Station\ToshibaServiceStation.exe" [2009-08-17 1294136]
"Teco"="c:\program files\TOSHIBA\TECO\Teco.exe" [2009-08-11 1324384]
"TWebCamera"="c:\program files\TOSHIBA\TOSHIBA Web Camera Application\TWebCamera.exe" [2009-08-11 2446648]
"SmartFaceVWatcher"="c:\program files\Toshiba\SmartFaceV\SmartFaceVWatcher.exe" [2009-07-29 163840]
"TosSENotify"="c:\program files\TOSHIBA\TOSHIBA HDD SSD Alert\TosWaitSrv.exe" [2009-09-17 611672]
"NortonOnlineBackupReminder"="c:\program files\TOSHIBA\Toshiba Online Backup\Activation\TobuActivation.exe" [2009-07-16 529256]
"GrooveMonitor"="c:\program files\Microsoft Office\Office12\GrooveMonitor.exe" [2008-10-25 31072]
"ccApp"="c:\program files\Common Files\Symantec Shared\ccApp.exe" [2009-07-09 115560]
"DivX Download Manager"="c:\program files\DivX\DivX Plus Web Player\DDmService.exe" [2010-12-08 63360]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2007-05-08 54840]
"DivXUpdate"="c:\program files\DivX\DivX Update\DivXUpdate.exe" [2011-03-21 1230704]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2011-04-08 254696]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2012-01-03 843712]
"TkBellExe"="c:\program files\Real\RealPlayer\update\realsched.exe" [2011-10-28 273528]
"APSDaemon"="c:\program files\Common Files\Apple\Apple Application Support\APSDaemon.exe" [2011-11-02 59240]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2011-10-24 421888]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2011-12-08 421736]
"AVG_TRAY"="c:\program files\AVG\AVG2012\avgtray.exe" [2011-12-03 2415456]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2009-09-04 39408]
c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
Dropbox.lnk - c:\users\Ed's\AppData\Roaming\Dropbox\bin\Dropbox.exe [2011-12-5 24242056]
desktop (1).ini [2008-9-9 84]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2009-5-21 275768]
"ConsentPromptBehaviorAdmin"= 0 (0x0)
"ConsentPromptBehaviorUser"= 3 (0x3)
"EnableLUA"= 0 (0x0)
"PromptOnSecureDesktop"= 0 (0x0)
BootExecute REG_MULTI_SZ autocheck autochk *\0c:\progra~1\AVG\AVG2012\avgrsx.exe /sync /restart
Security Packages REG_MULTI_SZ kerberos msv1_0 schannel wdigest tspkg pku2u livessp
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ccEvtMgr]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ccSetMgr]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Symantec Antivirus]
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [2011-11-16 136176]
R3 ADM851X;ADM851X USB To Fast Ethernet Adapter;c:\windows\system32\DRIVERS\ADM851X.SYS [x]
R3 AVGIDSAgent;AVGIDSAgent;c:\program files\AVG\AVG2012\AVGIDSAgent.exe [2011-10-12 4433248]
R3 gupdatem;Google Update Service (gupdatem);c:\program files\Google\Update\GoogleUpdate.exe [2011-11-16 136176]
R3 Lavasoft Kernexplorer;Lavasoft helper driver;c:\program files\Lavasoft\Ad-Aware\KernExplorer.sys [x]
R3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\system32\Drivers\RtsUStor.sys [2009-08-06 171520]
R3 RtsUIR;Realtek IR Driver;c:\windows\system32\DRIVERS\Rts516xIR.sys [x]
R3 TdxMrMINI;TdxMrMINI;c:\windows\system32\DRIVERS\TdxMrMini.sys [x]
R3 TdxVGAMINI;TdxVGAMINI;c:\windows\system32\DRIVERS\TdxVgaMini.sys [x]
R3 TdxVGAUSB;TARGUS USB 2.0 VGA DOCK DEVICE(USB);c:\windows\system32\drivers\TdxVGAUSB.sys [x]
R3 TMachInfo;TMachInfo;c:\program files\TOSHIBA\TOSHIBA Service Station\TMachInfo.exe [2009-08-17 51512]
R3 TOSHIBA HDD SSD Alert Service;TOSHIBA HDD SSD Alert Service;c:\program files\TOSHIBA\TOSHIBA HDD SSD Alert\TosSmartSrv.exe [2009-09-17 111960]
R3 TPCHSrv;TPCH Service;c:\program files\TOSHIBA\TPHM\TPCHSrv.exe [2009-08-07 685424]
R3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\tsusbflt.sys [2010-11-20 52224]
R3 USBPNPA;USB PnP Sound Device Interface;c:\windows\system32\drivers\CM108.sys [2007-06-28 1310720]
R3 vwifimp;Microsoft Virtual WiFi Miniport Service;c:\windows\system32\DRIVERS\vwifimp.sys [2009-07-13 14336]
R3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe [2010-02-26 1343400]
S0 AVGIDSEH;AVGIDSEH;c:\windows\system32\DRIVERS\AVGIDSEH.Sys [2011-07-11 23120]
S0 Avgrkx86;AVG Anti-Rootkit Driver;c:\windows\system32\DRIVERS\avgrkx86.sys [2011-09-13 32592]
S1 Avgldx86;AVG AVI Loader Driver;c:\windows\system32\DRIVERS\avgldx86.sys [2011-10-07 230608]
S1 Avgtdix;AVG TDI Driver;c:\windows\system32\DRIVERS\avgtdix.sys [2011-07-11 295248]
S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys [2009-07-13 48128]
S2 AdobeARMservice;Adobe Acrobat Update Service;c:\program files\Common Files\Adobe\ARM\1.0\armsvc.exe [2012-01-03 63928]
S2 avgwd;AVG WatchDog;c:\program files\AVG\AVG2012\avgwdsvc.exe [2011-08-02 192776]
S2 cfWiMAXService;ConfigFree WiMAX Service;c:\program files\TOSHIBA\ConfigFree\CFIWmxSvcs.exe [2009-08-11 185712]
S2 ConfigFree Service;ConfigFree Service;c:\program files\TOSHIBA\ConfigFree\CFSvcs.exe [2009-03-11 46448]
S2 TOSHIBA eco Utility Service;TOSHIBA eco Utility Service;c:\program files\TOSHIBA\TECO\TecoService.exe [2009-08-11 185712]
S2 TVALZFL;TOSHIBA ACPI-Based Value Added Logical and General Purpose Device Filter Driver;c:\windows\system32\DRIVERS\TVALZFL.sys [2009-06-20 12920]
S3 AVGIDSDriver;AVGIDSDriver;c:\windows\system32\DRIVERS\AVGIDSDriver.Sys [2011-07-11 134736]
S3 AVGIDSFilter;AVGIDSFilter;c:\windows\system32\DRIVERS\AVGIDSFilter.Sys [2011-07-11 24272]
S3 AVGIDSShim;AVGIDSShim;c:\windows\system32\DRIVERS\AVGIDSShim.Sys [2011-10-04 16720]
S3 FwLnk;FwLnk Driver;c:\windows\system32\DRIVERS\FwLnk.sys [2009-07-07 7680]
S3 PGEffect;Pangu effect driver;c:\windows\system32\DRIVERS\pgeffect.sys [2009-06-23 24064]
S3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\DRIVERS\Rt86win7.sys [2009-07-31 187392]
S3 rtl8192se;Realtek Wireless LAN 802.11n PCI-E NIC NT Driver;c:\windows\system32\DRIVERS\rtl8192se.sys [2009-08-28 859136]
S3 WSDPrintDevice;WSD Print Support via UMB;c:\windows\system32\DRIVERS\WSDPrint.sys [2009-07-14 17920]
*NewlyCreated* - ERASERUTILDRVI13
*Deregistered* - EraserUtilDrvI13
*Deregistered* - hswd0000416A
HPZ12 REG_MULTI_SZ Pml Driver HPZ12 Net Driver HPZ12
HPService REG_MULTI_SZ HPSLPSVC
hpdevmgmt REG_MULTI_SZ hpqcxs08 hpqddsvc
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{01250B8F-D947-4F8A-9408-FE8E3EE2EC92}]
2009-08-06 16:15 264048 ----a-w- c:\program files\TOSHIBA\My Toshiba\MyToshiba.exe
2012-01-25 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2011-11-16 20:18]
2012-01-25 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2012-01-24 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-1125661894-1930368724-354888347-1000Core.job
- c:\windows\system32\config\systemprofile\AppData\Local\Google\Update\GoogleUpdate.exe [2012-01-12 18:20]
2012-01-25 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-1125661894-1930368724-354888347-1000UA.job
IE: E&xport to Microsoft Excel - c:\progra~1\MIF5BA~1\Office12\EXCEL.EXE/3000
TCP: DhcpNameServer = 75.75.75.75 75.75.76.76
TCP: Interfaces\{DEA18463-8EA8-42A5-9871-7F9C5EAE647C}\175796E6C616E6: DhcpNameServer = 68.87.71.230 68.87.73.246
TCP: Interfaces\{DEA18463-8EA8-42A5-9871-7F9C5EAE647C}\358696E69744F676D27657563747: DhcpNameServer = 192.168.33.1
------- File Associations -------
.scr=RasWin.Script
ShellIconOverlayIdentifiers-{FB314ED9-A251-47B7-93E1-CDD82E34AF8B} - (no file)
ShellIconOverlayIdentifiers-{FB314EDA-A251-47B7-93E1-CDD82E34AF8B} - (no file)
ShellIconOverlayIdentifiers-{FB314EDB-A251-47B7-93E1-CDD82E34AF8B} - (no file)
ShellIconOverlayIdentifiers-{FB314EDC-A251-47B7-93E1-CDD82E34AF8B} - (no file)
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
@Denied: (Full) (Everyone)
Completion time: 2012-01-25 08:42:47
ComboFix-quarantined-files.txt 2012-01-25 13:42
ComboFix2.txt 2010-10-12 12:38
Pre-Run: 129,604,706,304 bytes free
Post-Run: 131,293,696,000 bytes free
- - End Of File - - C14C33760D3FF56DFA405D291DD1B88B
quinlane06492
Posts Posts : 19
Post by houndmom on 1st February 2012, 1:19 am
Sorry for the delay.
  • Click Start
  • Click Start
houndmom
Posts Posts : 1053
Post by quinlane06492 on 1st February 2012, 6:17 pm
# version=7
# iexplore.exe=9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)
# OnlineScanner.ocx=1.0.0.6583
# api_version=3.0.2
# EOSSerial=fe027029e4fca34db4690d000d8cd960
# end=finished
# remove_checked=true
# archives_checked=true
# unwanted_checked=true
# unsafe_checked=true
# antistealth_checked=true
# utc_time=2012-02-01 05:16:19
# local_time=2012-02-01 12:16:19 (-0500, Eastern Standard Time)
# country="United States"
# lang=1033
# osver=6.1.7601 NT Service Pack 1
# compatibility_mode=512 16777215 100 0 41232962 41232962 0 0
# compatibility_mode=1024 16777215 100 0 1238407 1238407 0 0
# compatibility_mode=2560 16777215 100 0 0 0 0 0
# compatibility_mode=5893 16776638 100 94 1237377 79612144 0 0
# compatibility_mode=8192 67108863 100 0 41053955 41053955 0 0
# scanned=229427
# found=1
# cleaned=1
# scan_time=49226
C:\Users\Ed's\Downloads\Unconfirmed 34611.crdownload probably a variant of Win32/Adware.NDUTHJB application (deleted - quarantined) 00000000000000000000000000000000 C
quinlane06492
Posts Posts : 19
Post by houndmom on 7th February 2012, 7:56 pm
Congratulations You are clean!!! Hooray!
Do you have anymore questions??
A few tips to help keep your computer more secure in the future.
Windows Update:
Check in for needed updates. It is very important to make sure that both Internet Explorer and Windows are kept current with the latest critical security patches from Microsoft.
To do this in Windows 7 go to:
Start>>All Programs>>Windows Update
houndmom
Posts Posts : 1053
