Problem running recovery on Toshiba laptop
Post by jbrown9805 on 2nd January 2012, 4:39 pm
I have a Toshiba Satellite L455-S5975 laptop that I have replaced the hard drive on. I have the recovery discs from Toshiba from the last time I had to replace the hard driveI am attempting to run the Toshiba Recovery utility to restore to the factory default software using the discs. It goes through disc 1 copying files and it appears to go through disc 2 as well but I eventually get an error that it is unable to copy PREINST9.SWM. I can see the file on the disc on my other PC but when I try to copy it to my flash drive, I get an error that says 'Cannot copy PREINST9: Data Error (cyclic redundancy check).'.
Does this mean that the file is corrupted and I need to get another set of recovery discs or is there something else I am missing?
jbrown9805
Joined Joined : 2012-01-02
OS OS : windows 7
Points Points : 18053
Re: Problem running recovery on Toshiba laptop
Post by Jan2011 on 3rd January 2012, 3:06 pm
Yes - I'd say you have a bad disk. The CRC is a method to verify the integrity of files.
If the problem isn't too bad, you can try copying that disk using another computer which may have a better disk reader. It just might work.
Jan2011
Posts Posts : 617
Joined Joined : 2011-01-17
Points Points : 25625
