Help with finding CPU and RAM
Solved Help with finding CPU and RAM
Post by miksta on 13th August 2008, 6:44 pm
I just went to frys to get a new graphics card a new processor and more ram. When i got one i found out the only one of the 3 that worked for my mobo was the graphics card ><. So i need help finding a processor and 2gb's of ram on Frys that my mobo supports.
Mobo Information
Thanks,
Michael B.
miksta
Joined Joined : 2008-08-13
Points Points : 30410
Solved Re: Help with finding CPU and RAM
Post by Digitalocksmith on 14th August 2008, 9:06 am
RAM support: 2x 184-pin DDR-400/333 SDRAMs, Upto 2GB (Dual channel)
GP Reccommend: Go for 2 x 1gig sticks of DDR400 PC3200 (184 pin) of a brand in your choice.(my preference is corsair or kingston)
CPU support: Socket 939 support AMD Athlon 64 FX/ Athlon 64 X2 Dual-Core/ Athlon 64 processor, FSB 2000/1600/1200/800/400 MT/s
GP Reccommend: Athlon 64 X2 Dual-Core!
Good Luck!
Digitalocksmith
Posts Posts : 625
Joined Joined : 2007-12-22
Points Points : 48961
