wireless home network
Post by mrnalley on Mon Dec 05, 2011 5:08 pm
My dad will be getting cable internet soon and i am going to set up a wireless network for him but heres my question: He only has laptops is it necessary to leave a PC wired to the wireless router for the internet to work or could i do the initial setup wired to one of the laptops and then unhook it and be done with it?
mrnalley
Posts Posts : 7
Joined Joined : 2009-05-16
OS OS : XP, Windows 7
Points Points : 27625
Re: wireless home network
Post by Buttons on Wed Dec 07, 2011 4:50 am
Hi Smile
No it is not. Smile The only requirements are that you have the router plugged into the modem. Most routers will require you to temporarily plug your computer into the router with the modem unplugged during setup then plugging the modem in after setup. Smile After that you should be good to go. Smile Usually you get a quick guide(a paper you unfold with 5 steps or something short with pictures) which will guide you through it. Smile
Feel free to post back if you have any questions during setup. Smile
Buttons
Posts Posts : 869
Joined Joined : 2010-06-11
OS OS : 7 Ultimate x64
Points Points : 26286
