panasonic viera tv won't connect to linksys router wirelessly using Lan adapter
Post by mybrtony on Sat Dec 03, 2011 4:39 pm
panasonic viera tv won't connect to linksys router wirelessly using Lan adapter....any help here
mybrtony
Joined Joined : 2011-12-03
Points Points : 18293
Re: panasonic viera tv won't connect to linksys router wirelessly using Lan adapter
Post by ralaspech on Fri Jun 29, 2012 1:26 pm
I'm having the same problem. It says my LAN cable is not connected when it is. I am using an airport express which is linked to my airport extreme.
ralaspech
Joined Joined : 2012-06-29
OS OS : MAC OS
Points Points : 16210
Post by ronlynn on Fri Jun 29, 2012 7:39 pm
try going into network management in poperties on you device left click to do this, go to advanced , there are 2 radio buttons that say find IPS and DNS automatically,click on them click OK click OK again to close all Boxes and now restart your computer ,this should match your IPS to Your DNS ,good luck
ronlynn
Posts Posts : 6
Joined Joined : 2010-08-24
OS OS : vista home basic
Points Points : 22985
