need help with->DOS/ALUREON.E
Page 3 of 3 Previous  1, 2, 3
Post by dannyr on Sat 26 Nov 2011, 5:56 am
NEED HELP WITH --> DOS/ALUREON.E
I CAN NOT ACCESS THE INTERNET FROM THE INFECTED COMPUTER TO RUN THE OTL YOU GUYS NEED THIS VIRUS OR WHATEVER IT IS IS PRETTY NASTY
dannyr
Operating System : windows xp
Re: need help with->DOS/ALUREON.E
Post by dannyr on Thu 08 Dec 2011, 8:44 am
that worked i have internet now
dannyr
Post by Superdave on Thu 08 Dec 2011, 10:59 am
Please go to Jotti's malware scan
(If more than one file needs scanned they must be done separately and links posted for each one)
* Copy the file path in the below Code box:
c:\windows\system32\drivers\42227559.sys
* At the upload site, click once inside the window next to Browse.
* Press Ctrl+V on the keyboard (both at the same time) to paste the file path into the window.
* Next click Submit file
* Your file will possibly be entered into a queue which normally takes less than a minute to clear.
* This will perform a scan across multiple different virus scanning engines.
* Important: Wait for all of the scanning engines to complete.
* Once the scan is finished, Copy and then Paste the link in the address bar into your next reply.
Tech Staff
Tech Staff
Post by dannyr on Thu 08 Dec 2011, 11:05 am
dannyr
Post by dannyr on Thu 08 Dec 2011, 11:09 am
dannyr
Post by Superdave on Fri 09 Dec 2011, 6:29 am
ESET OnlineScan
•Click the button.
•Check
•Click the button.
•Check
•Push the Start button.
•Push the button.
•Push
Tech Staff
Tech Staff
Post by dannyr on Sat 10 Dec 2011, 4:04 am
dave right after I install it hangs and never comes back
dannyr
Post by Superdave on Sat 10 Dec 2011, 5:07 am
Ok. Let's try this one.
Run the F-Secure Online Scanner for Viruses, Spyware and Rootkits.
Note: This Scanner is for Internet Explorer Only!
•Click on Online Services and then Online Scanner
•Accept the License Agreement.
•Once the ActiveX installs,Click Full System Scan
•Once the download completes,the scan will begin automatically.
•The scan will take some time to finish,so please be patient.
•When the scan completes, click the Automatic cleaning (recommended) button.
•Click the Show Report button and Copy&Paste the entire report in your next reply.
Tech Staff
Tech Staff
Post by dannyr on Sat 10 Dec 2011, 6:04 am
Scanning Report
Friday, December 9, 2011 13:17:24 - 14:04:16
Computer name: BYPC3
Scanning type: Scan system for malware, spyware and rootkits
Target: C:\
No malware found
Statistics
Scanned:
Files: 43687
System: 2914
Not scanned: 9
Actions:
Disinfected: 0
Renamed: 0
Deleted: 0
Not cleaned: 0
Submitted: 0
Files not scanned:
C:\PAGEFILE.SYS
C:\WINDOWS\SYSTEM32\CONFIG\DEFAULT
C:\WINDOWS\SYSTEM32\CONFIG\SAM
C:\WINDOWS\SYSTEM32\CONFIG\SECURITY
C:\WINDOWS\SYSTEM32\CONFIG\SOFTWARE
C:\WINDOWS\SYSTEM32\CONFIG\SYSTEM
C:\WINDOWS\$NTUNINSTALLKB17754$\3151057633
C:\DOCUMENTS AND SETTINGS\BRIDGE\LOCAL SETTINGS\TEMP\HSPERFDATA_BRIDGE\2000
C:\DOCUMENTS AND SETTINGS\BRIDGE\APPLICATION DATA\SUN\JAVA\DEPLOYMENT\CACHE\6.0\39\F0CF627-4D4353D6
Options
Scanning engines:
Scanning options:
Scan defined files: COM EXE SYS OV? BIN SCR DLL SHS HTM HTML HTT VBS JS INF VXD DO? XL? RTF CPL WIZ HTA PP? PWZ P?T MSO PIF . ACM ASP AX CNV CSC DRV INI MDB MPD MPP MPT OBD OBT OCX PCI TLB TSP WBK WBT WPC WSH VWP WML BOO HLP TD0 TT6 MSG ASD JSE VBE WSC CHM EML PRC SHB LNK WSF {* PDF ZL? XML XXX ANI AVB BAT CMD JOB LSP MAP MHT MIF PHP POT SWF WMF NWS TAR
Use advanced heuristics
Copyright © 1998-2009 Product support | Send virus sample to F-Secure
F-Secure assumes no responsibility for material created or published by third parties that F-Secure World Wide Web pages have a link to. Unless you have clearly stated otherwise, by submitting material to any of our servers, for example by E-mail or via our F-Secure's CGI E-mail, you agree that the material you make available may be published in the F-Secure World Wide Pages or hard-copy publications. You will reach F-Secure public web site by clicking on underlined links. While doing this, your access will be logged to our private access statistics with your domain name. This information will not be given to any third party. You agree not to take action against us in relation to material that you submit. Unless you have clearly stated otherwise, by submitting material you warrant that F-Secure may incorporate any concepts described in it in the F-Secure products/publications without liability.
dannyr
Post by Superdave on Sat 10 Dec 2011, 10:21 am
Well, that looks good. How's your computer working now? Any other issues?
Tech Staff
Tech Staff
Post by dannyr on Sun 11 Dec 2011, 2:28 am
everything seems normal
dannyr
Post by Superdave on Sun 11 Dec 2011, 6:01 am
Ok. Let's do some cleanup.
* Click START then RUN - Vista users press the Windows Key and the R keys together for the Run box.
* Now type blackpudding.bat /uninstall in the runbox
* Make sure there's a space between blackpudding.bat and /Uninstall
* Then hit Enter
* The above procedure will:
* Delete the following:
* ComboFix and its associated files and folders.
* Reset the clock settings.
* Hide file extensions, if required.
* Hide System/Hidden files, if required.
* Set a new, clean Restore Point.
To remove all of the tools we used and the files and folders they created do the following:
Double click OTL.exe.
  • Click the CleanUp button.
  • Select Yes when the "Begin cleanup Process?" prompt appears.
Clean out your temporary internet files and temp files.
Download TFC by OldTimer to your desktop.
Double-click TFC.exe to run it.
Note: If you are running on Vista, right-click on the file and choose Run As Administrator
TFC will close all programs when run, so make sure you have saved all your work before you begin.
* Click the Start button to begin the cleaning process.
* Depending on how often you clean temp files, execution time should be anywhere from a few seconds to a minute or two.
* Please let TFC run uninterrupted until it is finished.
Once TFC is finished it should restart your computer. If it does not, please manually restart the computer yourself to ensure a complete cleaning.
Looking over your log it seems you don't have any evidence of a third party firewall.
Firewalls protect against hackers and malicious intruders. You need to download a free firewall from one of these reliable vendors.
Remember only install ONE firewall
1) Comodo Personal Firewall (Uncheck during installation "Install Comodo SafeSurf..", Make Comodo my default search provider" and "Make Comodo Search my homepage" and uncheck any HopSurf and/or Ask.com options if you choose this one)
2) Online Armor
3) Agnitum Outpost
4) PC Tools Firewall Plus
If you are using the built-in Windows XP firewall, it is not recommended as it does not block outgoing connections. This means that any malware on your computer is free to "phone home" for more instructions. Simply put, Windows XP contains a mediocre firewall. This firewall is NO replacement for a dedicated software solution. Remember to use only one firewall at the same time.
Go to Microsoft Windows Update and get all critical updates.
SpywareBlaster- Secure your Internet Explorer to make it harder for ActiveX programs to run on your computer. Also stop certain cookies from being added to your computer when running Mozilla based browsers like Firefox.
* Using SpywareBlaster to protect your computer from Spyware and Malware
* If you don't know what ActiveX controls are, see here
Protect yourself against spyware using the Immunize feature in Spybot - Search & Destroy. Guide: Use Spybot's Immunize Feature to prevent spyware infection in real-time. Note: To ensure you have the latest Immunizations always update Spybot - Search & Destroy before Immunizing. Spybot - Search & Destroy FAQ
Safe Surfing!
Tech Staff
Tech Staff
Post by Sponsored content Today at 2:25 am
