need help with->DOS/ALUREON.E
Page 1 of 7
Page 1 of 7 • 1, 2, 3, 4, 5, 6, 7
- dannyrNovice
OS : windows xp
Rubies : 2916
NEED HELP WITH --> DOS/ALUREON.E
I CAN NOT ACCESS THE INTERNET FROM THE INFECTED COMPUTER TO RUN THE OTL YOU GUYS NEED THIS VIRUS OR WHATEVER IT IS IS PRETTY NASTY
- SuperdaveSecurity Officer
OS : Windows 8.1 and a dual-boot with XP Home SP3
Anti-Malware : MSE, Windows Defender, Windows firewall
Rubies : 63256
Please try this. Boot your computer in Safe Mode with NetWorking. Download, install and run a scan with MBAM. Reboot in Normal mode and try to run the scan again.
Safe Mode
Safe Mode
- Make sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes Anti-Malware, then click Finish.
- If an update is found, it will download and install the latest version.
- Once the program has loaded, select "Perform Full Scan", then click Scan.
- The scan may take some time to finish,so please be patient.
- When the scan is complete, click OK, then Show Results to view the results.
- Make sure that everything is checked, and click Remove Selected.
- When disinfection is completed, a log will open in Notepad and you may be prompted to Restart. (See Extra Note)
- Please save the log to a location you will remember.
- The log is automatically saved by MBAM and can be viewed by clicking the Logs tab in MBAM.
- Copy and paste the entire report in your next reply.
- dannyrNovice
OS : windows xp
Rubies : 2916
here you go
Malwarebytes' Anti-Malware 1.51.2.1300
www.malwarebytes.org
Database version: 8209
11/25/2011 4:56:26 PM
mbam-log-2011-11-25 (16-56-26).txt
Scan type: Full scan (C:\|)
Objects scanned: 218286
Time elapsed: 45 minute(s), 55 second(s)
Registry Data Items Infected: 7
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowControlPanel (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowHelp (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowMyComputer (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowMyDocs (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowRun (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowSearch (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoDesktop (PUM.Hidden.Desktop) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
Rubies : 63256
SUPERAntiSpyware
Download SuperAntispyware Free Edition (SAS)
* If you encounter any problems while downloading the updates, manually download and unzip them from here
•Scan for tracking cookies
•Please leave the others unchecked
Download DDS from HERE or HERE and save it to your desktop.
Vista users right click on dds and select Run as administrator (you will receive a UAC prompt, please allow it)
* XP users Double click on dds to run it.
* If your antivirus or firewall try to block DDS then please allow it to run.
* When finished DDS will open two (2) logs.
* Save both reports to your desktop.
* The instructions here ask you to attach the Attach.txt.
1) DDS.txt
2) Attach.txt
Instead of attaching, please copy/past both logs into your Thread
Note: DDS will instruct you to post the Attach.txt log as an attachment.
Please just post it as you would any other log by copying and pasting it into the reply.
•Close the program window, and delete the program from your desktop.
Please note: You may have to disable any script protection running if the scan fails to run.
After downloading the tool, disconnect from the internet and disable all antivirus protection.
Run the scan, enable your A/V and reconnect to the internet.
Information on A/V control HERE .Then post your DDS logs. (DDS.txt and Attach.txt )
1) DDS.txt
2) Attach.txt
- dannyrNovice
OS : windows xp
Rubies : 2916
Dave the computer infected can't download from the internet how else can I install sas and dds?
danny r
danny r
Rubies : 63256
If you can't access the internet with your infected computer you will have to download and transfer any programs to the computer you're using now and transfer them to the infected computer with a CD-RW or a USB storage device. I prefer a CD because a storage device can get infected. If you use a storage device hold the shift key down while inserting the USB storage device for about 10 secs. You will also have to transfer the logs you receive back to the good computer using the same method until we can get the computer back on-line.@dannyr wrote:Dave the computer infected can't download from the internet how else can I install sas and dds?
danny r
- dannyrNovice
OS : windows xp
Rubies : 2916
Dave this virus is has the devices with removable storage hidden or disabled so i can't use CD-RW Do you know any tricks before I use USB?
Rubies : 63256
It will work just the same with the USB.@dannyr wrote:Dave this virus is has the devices with removable storage hidden or disabled so i can't use CD-RW Do you know any tricks before I use USB?
- dannyrNovice
OS : windows xp
Rubies : 2916
Yea I know I'm Just Scared of infecting another pc but I will try anyhow, I'm not near the computer now so I will update you monday, Have a good weekend...
- dannyrNovice
OS : windows xp
Rubies : 2916
dave please provide the link to download the updates for sas so i can manually install them to the infected computer
Similar topics
Page 1 of 7
