MS Removal Tool Help
Page 2 of 2 Previous  1, 2
Post by draysmith11 on Tue 22 Nov 2011, 3:16 pm
So my computer started going crazy and said critical had drive failure and some other things, and popped up with the MS removal tool, which I didn't buy or even attempt to look at I just googled the critical hard drive failure and it came back that it was a virus from malware, so I followed the instructions on the read this before you post, post. I downloaded the OTL and copied and pasted the info into the custom scan, and during the scan it got stuck on the mozilla settings and, stopped responding, I tried it again with the same results. I downloaded Malwarebytes' anti-malware and scanned my pc, this of course before I found this site. I will paste the results from that in this post. Hopefully you can help me fix this problem any advice is greatly appreciated. Thanks for your time.
Malwarebytes' Anti-Malware 1.51.2.1300
Database version: 8201
11/20/2011 2:27:13 PM
mbam-log-2011-11-20 (14-27-13).txt
Scan type: Full scan (C:\|D:\|E:\|F:\|G:\|H:\|I:\|)
Objects scanned: 402690
Time elapsed: 1 hour(s), 18 minute(s), 22 second(s)
Registry Keys Infected: 18
Registry Values Infected: 6
Registry Data Items Infected: 7
Files Infected: 3
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{09971cee-01b8-42bc-9d91-456b1faad6be} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256A51-B582-467e-B8D4-7786EDA79AE0} (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{00A6FAF1-072E-44CF-8957-5838F569A31D} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{00A6FAF6-072E-44CF-8957-5838F569A31D} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07B18EA1-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{07B18EA9-A523-4961-B6BB-170DE4475CCA} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{7B9F8C21-46EC-4C0B-8683-E755EF84577A} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{7B9F8C21-46EC-4C0B-8683-E755EF84577A} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{F02FABCB-92DD-475A-98AF-14217BD50746} (Adware.Gamevance) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{F02FABCB-92DD-475A-98AF-14217BD50746} (Adware.Gamevance) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{3462C343-BE19-4143-AF70-CEFB56F46FC6} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{3A421C8F-E238-4AEB-8874-B8B5F2CC4772} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{549B5CA7-4A86-11D7-A4DF-000874180BB3} (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{60E91567-EF8A-4520-BCE2-83ABA5256799} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Trymedia Systems (Adware.TryMedia) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\CouponAlert_2p (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\AppDataLow\gvtl (Adware.GameVance) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\MICROSOFT\INTERNET EXPLORER\MENUEXT\&SEARCH (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks\{7B9F8C21-46EC-4C0B-8683-E755EF84577A} (Adware.MyWebSearch) -> Value: {7B9F8C21-46EC-4C0B-8683-E755EF84577A} -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser\{3462C343-BE19-4143-AF70-CEFB56F46FC6} (Adware.MyWebSearch) -> Value: {3462C343-BE19-4143-AF70-CEFB56F46FC6} -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks\{7b9f8c21-46ec-4c0b-8683-e755ef84577a} (Adware.MyWebSearch) -> Value: {7b9f8c21-46ec-4c0b-8683-e755ef84577a} -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Control Panel\don't load\scui.cpl (Hijack.SecurityCenter) -> Value: scui.cpl -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\MenuExt\&Search\(default) (Adware.MyWebSearch) -> Value: (default) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowControlPanel (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowHelp (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowMyComputer (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowMyDocs (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowRun (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowSearch (PUM.Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoDesktop (PUM.Hidden.Desktop) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
c:\documents and settings\Liz\local settings\Temp\dealiotoolbarinstall.exe (PUP.Dealio.TB) -> Not selected for removal.
c:\system volume information\_restore{106cf321-99a3-4e3a-9103-1bd027606a99}\RP2261\A0226078.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\system volume information\_restore{106cf321-99a3-4e3a-9103-1bd027606a99}\RP2261\A0226084.exe (Adware.TryMedia) -> Quarantined and deleted successfully.
draysmith11
Operating System : xp
Re: MS Removal Tool Help
Post by Gabethebabe on Wed 21 Dec 2011, 6:38 pm
wow
That is weird
We didnīt do anything risky here
You cannot start in safe mode either?
To reboot in safe mode: restart the computer and hit the F8 button a couple of times during rebooting, just before the windows screen appears. In the boot menu that follows, choose Safe Mode Without Networking.
Gabethebabe
Tech Advisor
Tech Advisor
Operating System : WIN7 64bit, Ubuntu 12.04 LTS
Post by draysmith11 on Fri 23 Dec 2011, 7:16 am
I did the reboot in safe mode with networking, and then realized it was to be without networking, so I rebooted the computer without networking and both worked in safe mode. Hopefully we can figure it out whats going on. Thank you.
draysmith11
Post by Gabethebabe on Fri 23 Dec 2011, 6:41 pm
OK so safe mode is working correctly, but normal mode is not?
Some questions
Do you have a windows setup disk that came with this computer?
Do you have access to another computer to download tools and stuff?
Gabethebabe
Tech Advisor
Tech Advisor
Post by Sponsored content Today at 2:54 am
