will not print
will not print
Post by jrlong54 on Tue Oct 11, 2011 10:34 am
Hi I have a lot of data I want to print off that is in a my documents folder also on a memory stick. As I have not got a printer I hoped to get the 27 pages printed at a freinds house or a internet cafe, have tried both and been told that it wont print the data as its in a diff format. WPS. The lady in the internet cafe said that it would have to be changed to another, as you can tell I am not good with computers and wps means nothing to me. Can anybody help as I do not want to lose the data and need to print it off.
Windows Vista, if you can help make the insructions idiot proof. many thanks Jeff.
jrlong54
OS : vista
# Likes : 0
Re: will not print
Post by Jan2011 on Thu Oct 13, 2011 8:42 am
Sounds like the program that you used to create the files is not installed on your friend's computer or at the Internet cafe.
What program did you use to create the files? The ACT file extension is commonly associtated with ACT. ACT is not a program typically installed on general use computer.
Jan2011
OS : xp
# Likes : 0
