system goes straight to restore mode
Post by dookie22 on Fri 30 Sep 2011, 9:28 am
I have windows xp and when i turn my computer on it goes straight to the restore mode that it would of you hit ctrl and f11. When I try to restore back to factory settings it just freezes there. everything else I can click and go to except restore to factory settings as it just freezes there. I tried safe mode but it wont go into that.
dookie22
Operating System : XP
Re: system goes straight to restore mode
Post by opaben on Tue 11 Oct 2011, 9:58 pm
Well Dookie,
Can't you choose for "the latest working restorepoint"?and put your system back to yhat point?
if not you might want to try start up from a bootCD, make sure in you boot sequence the CD drive is your 1st boot option and start with Hiren's BootCD, you will find many options such as checking on viruses and maybe you can try to back up your most important data, it comes with a "mini XP" feature but I have never used that before.
you can get it here: http://www.hirensbootcd.org/download/
try to run some test on your system and if nothing else helps you "ll probably have to reinstall windows.
Maybe someone else has a direct solution to this one.
greetings,
Ben
opaben
Operating System : XP pro SP3
