[Help] "Media Test failure, check cable"
Post by iHydra on Sat Aug 06, 2011 9:06 pm
Thats the Error code:
Boot from CD:
Intel UNDI, m PXE-2.1 (build 002)
Copyright **BLAH BLAH BLAH**
For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.17 (051202)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE Rom.
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
I have tried everything. Switched my HDD with a Dif. and CD/DVD drive with a dif. one too. Didn't work. Tried different cd's too. didn't work. I'm worried that it might be a motherboard issue.
iHydra
Joined Joined : 2011-08-02
Protection Protection : MBAM Pro, Avast, Comodo
Points Points : 19612
Re: [Help] "Media Test failure, check cable"
Post by makxp77 on Sun Sep 04, 2011 9:21 pm
Are you using SATA or IDE?
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29064
Post by iHydra on Sun Sep 04, 2011 9:31 pm
Man, forgot all about this thread. Anyways, I got this fixed. I hooked it up to my Second PC and Docked it. Booted up to it and installed it. I decided to Reformat it so after I did that it worked. Reason it was giving me the error was because it that drive only reads CD but the Disk of Windows XP Pro was DVD.. and my 2nd (Custom Built) pc had DVD/CD Burner Drive.
Thanks for your time tho,
iHydra
iHydra
Post by makxp77 on Sun Sep 04, 2011 9:39 pm
No problem man Smile
MiKeY
makxp77
Posts Posts : 216
