Not sure if Virus--help
Post by uvita on Sat 18 Jun 2011, 2:11 am
First of all thanks to everyone who have helped me whenever I have needed it.
Second, my computer last week when I started it, it will load but I have a sidebar that had stopped working and would freeze. Everytime it does this, I would not be able to use any application , nor would my kaspersky internet security work nor can I shut or restart computer. I would then have to shut it manually and after doing this few times, computer had said that windows needed repair and so left it. After about hr it worked normally.
Now after a week...I was just on a very trusted and secure site only, then Kaspersky updated and when I went to close browser after cleaning cache... my kaspersky stopped working and I had to manually shut computer down...when I restarted it asked to start normally which I told it too but it started checking my files. After that was done, it started normally and when it loaded...it gave me a kaspersky box saying some report needed to be send to kaspersky lab which I told too and then checked report of kaspersky. This is where when I looked I saw a file in Kaspersky in program files called self defense(had enabled it in my security so that will block any attempt of virus etc) that was denied action by kaspersky but next to it says modify. And now whenever I start firefox the CPU usage of firefox is 28-34 ( and all I have is one window open and no tabs no nothing else or some times more or less. Overall CPU usage is more than 40%. Please help. The fan is working alot since this happened. Also firefox takes a few minutes for any page to open even if its google page.
I don't know what that means
uvita
Rookie Surfer
Rookie Surfer
Operating System : Windows Vista with Media Edition
Re: Not sure if Virus--help
Post by Sneakyone on Tue 21 Jun 2011, 2:53 pm
Please download OTL to your Desktop. (If you already have it downloaded, then just follow the instructions below).
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.sys
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
Sneakyone
Tech Officer
Tech Officer
Post by uvita on Thu 23 Jun 2011, 4:31 pm
ok will do so and post.
Also one thing I noticed is that there is an ielowutil.exe file showing up on task manager past few days. And that plug in container for firefox that shows up more than once in task manager making web browser slow. I then will have to manually delete all but one and then web browsers work almost fast.
uvita
Rookie Surfer
Rookie Surfer
Post by uvita on Fri 24 Jun 2011, 3:47 pm
here is the log file:
OTL logfile created on: 6/23/2011 10:10:06 PM - Run 1
OTL by OldTimer - Version 3.2.24.1 Folder = C:\Users\Deepa\Desktop
64bit-Windows Vista Home Premium Edition Service Pack 2 (Version = 6.0.6002) - Type = NTWorkstation
Internet Explorer (Version = 8.0.6001.19088)
3.96 Gb Total Physical Memory | 2.22 Gb Available Physical Memory | 56.17% Memory free
8.12 Gb Paging File | 6.11 Gb Available in Paging File | 75.18% Paging File free
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files (x86)
Drive C: | 298.09 Gb Total Space | 213.97 Gb Free Space | 71.78% Space Free | Partition Type: NTFS
Computer Name: DEEPA-PC | User Name: Deepa | Logged in as Administrator.
Boot Mode: Normal | Scan Mode: Current user | Include 64bit Scans
PRC - [2011/06/23 21:30:31 | 000,579,072 | ---- | M] (OldTimer Tools) -- C:\Users\Deepa\Desktop\OTL.exe
PRC - [2011/06/23 07:32:05 | 000,924,632 | ---- | M] (Mozilla Corporation) -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe
PRC - [2011/06/18 22:04:24 | 000,273,544 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files (x86)\Real\RealPlayer\Update\realsched.exe
PRC - [2010/11/02 22:06:06 | 000,365,336 | ---- | M] (Kaspersky Lab ZAO) -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 2011\avp.exe
PRC - [2010/03/10 14:26:48 | 000,189,728 | ---- | M] (Protexis Inc.) -- c:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe
MOD - [2011/06/23 21:30:31 | 000,579,072 | ---- | M] (OldTimer Tools) -- C:\Users\Deepa\Desktop\OTL.exe
MOD - [2010/08/31 10:43:52 | 001,686,016 | ---- | M] (Microsoft Corporation) -- C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll
SRV:64bit: - [2008/06/02 12:44:18 | 000,031,744 | ---- | M] () [Auto | Running] -- C:\Windows\SysNative\WLTRYSVC.EXE -- (wltrysvc)
SRV:64bit: - [2008/01/20 21:47:32 | 000,383,544 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Windows Defender\MpSvc.dll -- (WinDefend)
SRV - [2010/11/02 22:06:06 | 000,365,336 | ---- | M] (Kaspersky Lab ZAO) [Auto | Running] -- C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 2011\avp.exe -- (AVP)
SRV - [2010/03/18 14:16:28 | 000,130,384 | ---- | M] (Microsoft Corporation) [Auto | Stopped] -- C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe -- (clr_optimization_v4.0.30319_32)
SRV - [2010/03/10 14:26:48 | 000,189,728 | ---- | M] (Protexis Inc.) [Auto | Running] -- c:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe -- (PSI_SVC_2)
SRV - [2009/03/29 22:42:16 | 000,066,368 | ---- | M] (Microsoft Corporation) [Disabled | Stopped] -- C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe -- (clr_optimization_v2.0.50727_32)
DRV:64bit: - [2011/05/09 21:39:16 | 000,556,120 | ---- | M] (Kaspersky Lab) [File_System | System | Running] -- C:\Windows\SysNative\DRIVERS\klif.sys -- (KLIF)
DRV:64bit: - [2010/08/25 20:36:04 | 010,611,552 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\igdkmd64.sys -- (igfx)
DRV:64bit: - [2010/06/09 16:44:00 | 000,011,864 | ---- | M] (Kaspersky Lab ZAO) [Kernel | System | Running] -- C:\Windows\SysNative\DRIVERS\kl2.sys -- (kl2)
DRV:64bit: - [2010/06/09 16:43:56 | 000,460,888 | ---- | M] (Kaspersky Lab ZAO) [Kernel | Boot | Running] -- C:\Windows\SysNative\DRIVERS\kl1.sys -- (KL1)
DRV:64bit: - [2010/04/22 18:07:36 | 000,027,736 | ---- | M] (Kaspersky Lab ZAO) [Kernel | System | Running] -- C:\Windows\SysNative\DRIVERS\klim6.sys -- (KLIM6)
DRV:64bit: - [2010/03/08 11:03:36 | 000,067,104 | ---- | M] (ITE Tech. Inc. ) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\itecir.sys -- (itecir)
DRV:64bit: - [2009/11/02 19:27:10 | 000,022,544 | ---- | M] (Kaspersky Lab) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\klmouflt.sys -- (klmouflt)
DRV:64bit: - [2009/05/18 13:17:08 | 000,034,152 | ---- | M] (GEAR Software Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\GEARAspiWDM.sys -- (GEARAspiWDM)
DRV:64bit: - [2009/04/10 23:03:34 | 000,111,104 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\sdbus.sys -- (sdbus)
DRV:64bit: - [2009/03/08 18:06:00 | 000,319,840 | ---- | M] (Creative Technology Ltd.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\OA001Vid.sys -- (OA001Vid)
DRV:64bit: - [2009/03/06 08:33:58 | 000,159,840 | ---- | M] (Creative Technology Ltd.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\OA001Ufd.sys -- (OA001Ufd)
DRV:64bit: - [2008/07/24 19:40:26 | 000,199,728 | ---- | M] (Alps Electric Co., Ltd.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\Apfiltr.sys -- (ApfiltrService)
DRV:64bit: - [2008/06/02 12:44:16 | 000,022,520 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\BCM42RLY.sys -- (BCM42RLY)
DRV:64bit: - [2008/06/02 12:44:14 | 001,374,712 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\bcmwl664.sys -- (BCM43XX)
DRV:64bit: - [2008/05/06 16:06:00 | 000,014,464 | ---- | M] (Western Digital Technologies) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\DRIVERS\wdcsam64.sys -- (WDC_SAM)
DRV:64bit: - [2008/02/24 03:40:04 | 000,239,104 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\DRIVERS\k57nd60a.sys -- (k57nd60a) Broadcom NetLink (TM)
DRV:64bit: - [2008/02/21 11:24:20 | 000,062,976 | ---- | M] (REDC) [Kernel | Auto | Running] -- C:\Windows\SysNative\DRIVERS\rimmpx64.sys -- (rimmptsk)
DRV:64bit: - [2007/12/19 17:44:44 | 000,209,424 | ---- | M] (AMD Technologies Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\SysNative\drivers\ahcix64s.sys -- (ahcix64s)
DRV:64bit: - [2007/07/27 20:45:52 | 000,057,856 | ---- | M] (REDC) [Kernel | Auto | Running] -- C:\Windows\SysNative\DRIVERS\rixdpx64.sys -- (rismxdp)
DRV:64bit: - [2007/07/26 21:33:54 | 000,055,296 | ---- | M] (REDC) [Kernel | Auto | Running] -- C:\Windows\SysNative\DRIVERS\rimspx64.sys -- (rimsptsk)
DRV:64bit: - [2006/09/18 16:36:24 | 000,000,308 | ---- | M] () [File_System | On_Demand | Running] -- C:\Windows\SysNative\Wbem\ntfs.mof -- (Ntfs)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache AcceptLangs = en-us
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache_TIMESTAMP = EC 9A 5A B2 93 F1 CB 01 [binary data]
========== FireFox ==========
FF - prefs.js..browser.startup.homepage: "http://www.google.com/"
FF - prefs.js..network.proxy.type: 0
FF - HKLM\software\mozilla\Firefox\Extensions\\{23fcfd51-4958-4f00-80a3-ae97e717ed8b}: C:\Program Files (x86)\DivX\DivX Plus Web Player\firefox\html5video [2011/05/14 21:29:48 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\{6904342A-8307-11DF-A508-4AE2DFD72085}: C:\Program Files (x86)\DivX\DivX Plus Web Player\firefox\wpa [2011/05/14 21:29:48 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\virtualKeyboard@kaspersky.ru: C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 2011\FFExt\virtualKeyboard@kaspersky.ru [2011/05/31 11:02:40 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\KavAntiBanner@Kaspersky.ru: C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 2011\FFExt\KavAntiBanner@kaspersky.ru [2011/05/31 11:02:38 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\linkfilter@kaspersky.ru: C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 2011\FFExt\linkfilter@kaspersky.ru [2011/05/31 11:02:39 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\{ABDE892B-13A8-4d1b-88E6-365A6E755758}: C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\Firefox\Ext [2011/06/18 22:05:01 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 5.0\extensions\\Components: C:\Program Files (x86)\Mozilla Firefox\components [2011/06/23 07:32:06 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 5.0\extensions\\Plugins: C:\Program Files (x86)\Mozilla Firefox\plugins [2011/06/18 22:05:40 | 000,000,000 | ---D | M]
[2011/04/03 20:37:25 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Deepa\AppData\Roaming\Mozilla\Extensions
[2011/05/10 16:25:53 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Deepa\AppData\Roaming\Mozilla\Firefox\Profiles\8cfu2zko.default\extensions
[2011/05/31 11:02:51 | 000,000,000 | ---D | M] (No name found) -- C:\Program Files (x86)\Mozilla Firefox\extensions
[2011/05/09 21:41:26 | 000,000,000 | ---D | M] (Anti-Banner) -- C:\Program Files (x86)\Mozilla Firefox\extensions\KavAntiBanner@kaspersky.ru_bak
[2011/05/09 21:41:12 | 000,000,000 | ---D | M] (Kaspersky URL Advisor) -- C:\Program Files (x86)\Mozilla Firefox\extensions\linkfilter@kaspersky.ru_bak
File not found (No name found) --
[2011/03/10 17:57:53 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\WINDOWS\MICROSOFT.NET\FRAMEWORK\V3.5\WINDOWS PRESENTATION FOUNDATION\DOTNETASSISTANTEXTENSION
[2011/06/23 07:32:05 | 000,142,296 | ---- | M] (Mozilla Foundation) -- C:\Program Files (x86)\Mozilla Firefox\components\browsercomps.dll
[2010/01/01 03:00:00 | 000,002,252 | ---- | M] () -- C:\Program Files (x86)\Mozilla Firefox\searchplugins\bing.xml
O1 HOSTS File: ([2006/09/18 16:37:24 | 000,000,761 | ---- | M]) - C:\Windows\SysNative\drivers\etc\Hosts
O1 - Hosts: ::1 localhost
O2:64bit: - BHO: (IEVkbdBHO Class) - {59273AB4-E7D3-40F9-A1A8-6FA9CCA1862C} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 2011\x64\ievkbd.dll (Kaspersky Lab ZAO)
O2:64bit: - BHO: (FilterBHO Class) - {E33CF602-D945-461A-83F0-819F76A199F8} - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 2011\x64\klwtbbho.dll (Kaspersky Lab ZAO)
O2 - BHO: (RealPlayer Download and Record Plugin for Internet Explorer) - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll (RealPlayer)
O2 - BHO: (DivX Plus Web Player HTML5
uvita
Rookie Surfer
Rookie Surfer
Post by uvita on Fri 24 Jun 2011, 3:48 pm
Here is the Extras Txt:
OTL Extras logfile created on: 6/23/2011 10:10:06 PM - Run 1
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\]
.url[@ = InternetShortcut] -- C:\Windows\SysNative\rundll32.exe (Microsoft Corporation)
.cpl [@ = cplfile] -- C:\Windows\SysWow64\control.exe (Microsoft Corporation)
.html [@ = FirefoxHTML] -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe (Mozilla Corporation)
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\\shell\[command]\command]
batfile [open] -- "%1" %* File not found
cmdfile [open] -- "%1" %* File not found
comfile [open] -- "%1" %* File not found
exefile [open] -- "%1" %* File not found
InternetShortcut [open] -- "C:\Windows\System32\rundll32.exe" "C:\Windows\System32\ieframe.dll",OpenURL %l (Microsoft Corporation)
InternetShortcut [print] -- "C:\Windows\System32\rundll32.exe" "C:\Windows\System32\mshtml.dll",PrintHTML "%1" (Microsoft Corporation)
piffile [open] -- "%1" %* File not found
scrfile [config] -- "%1" File not found
scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l File not found
scrfile [open] -- "%1" /S File not found
Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1 File not found
Directory [AddToPlaylistVLC] -- "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" --started-from-file --playlist-enqueue "%1" ()
Directory [Browse with Corel PaintShop Photo Pro X3] -- "c:\Program Files (x86)\Corel\Corel PaintShop Photo Pro\X3\PSPClassic\Corel Paint Shop Pro Photo.exe" "%L" (Corel, Inc.)
Directory [PlayWithVLC] -- "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" --started-from-file --no-playlist-enqueue "%1" ()
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
"cval" = 1
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
"AntiVirusOverride" = 0
"AntiSpywareOverride" = 0
"FirewallOverride" = 0
"VistaSp1" = 9F 9E 16 8C DC 5B C8 01 [binary data]
"VistaSp2" = DB 7B 2F 4A 5D DF CB 01 [binary data]
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\Vol]
"DisableMonitoring" = 1
"oobe_av" = 1
"EnableFirewall" = 0
"DisableNotifications" = 0
========== Vista Active Open Ports Exception List ==========
"{2A043C2C-C5D9-4348-8C69-CB58D65BF4E4}" = lport=6004 | protocol=17 | dir=in | app=c:\program files (x86)\microsoft office\office12\outlook.exe |
========== Vista Active Application Exception List ==========
"{096B0931-C10E-4A83-827E-6579E3D71367}" = dir=in | app=c:\program files (x86)\itunes\itunes.exe |
"{11F867B3-03C7-43D8-8D16-02ACF588F695}" = protocol=6 | dir=in | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
"{35E1E870-6F95-4511-9681-24F88E63AE1C}" = protocol=6 | dir=in | app=c:\program files (x86)\microsoft office\office12\groove.exe |
"{6EA3BE16-DD3E-4475-8AD8-6FF7FAE90EA3}" = protocol=17 | dir=in | app=c:\program files (x86)\bonjour\mdnsresponder.exe |
"{92C14780-BD8C-4E1D-8D35-4103DF823897}" = protocol=17 | dir=in | app=c:\program files (x86)\microsoft office\office12\onenote.exe |
"{E067678F-8224-4260-8DDD-F03DB7CBE8D0}" = protocol=17 | dir=in | app=c:\program files (x86)\microsoft office\office12\groove.exe |
"{F2292D4B-82B9-4875-83B9-2E408264156F}" = protocol=6 | dir=in | app=c:\program files (x86)\bonjour\mdnsresponder.exe |
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
"{071c9b48-7c32-4621-a0ac-3f809523288f}" = Microsoft Visual C++ 2005 Redistributable (x64)
"{8BB347A7-68B5-4E46-9FCC-17F6172BA9E1}" = Share64
"{8F473675-D702-45F9-8EBC-342B40C17BF5}" = Apple Mobile Device Support
"{90120000-002A-0000-1000-0000000FF1CE}" = Microsoft Office Office 64-bit Components 2007
"{90120000-002A-0409-1000-0000000FF1CE}" = Microsoft Office Shared 64-bit MUI (English) 2007
"{90120000-0116-0409-1000-0000000FF1CE}" = Microsoft Office Shared 64-bit Setup Metadata MUI (English) 2007
"{9545E9DB-6F4C-4404-BF25-E221BE8B44C5}" = iTunes
"{9AF0B106-56F1-461B-A270-95BC1682E282}" = Broadcom Gigabit NetLink Controller
"{9F72EF8B-AEC9-4CA5-B483-143980AFD6FD}" = Dell Touchpad
"{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}" = Microsoft Visual C++ 2005 Redistributable (x64)
"{B6E3757B-5E77-3915-866A-CCFC4B8D194C}" = Microsoft Visual C++ 2005 ATL Update kb973923 - x64 8.0.50727.4053
"{E4F5E48E-7155-4CF9-88CD-7F377EC9AC54}" = Bonjour
"{F5B09CFD-F0B2-36AF-8DF4-1DF6B63FC7B4}" = Microsoft .NET Framework 4 Client Profile
"Broadcom 802.11b Network Adapter" = Dell Wireless WLAN Card Utility
"Creative OA001" = Integrated Webcam Driver (1.06.03.0309)
"_{AA902C31-B49D-4608-BCCF-2519EB77722D}" = Corel VideoStudio Pro X4
"_{DEAEB5DB-04FA-489D-94EF-8600898B93EE}" = Corel PaintShop Photo Pro X3
"{28C2DED6-325B-4CC7-983A-1777C8F7FBAB}" = RealUpgrade 1.1
"{2DC94AFD-A6E2-4AB4-9132-4A3F8E07B386}" = Apple Application Support
"{2F8BA3FD-1FA9-4279-B696-712ABB12F09F}" = SmartSound Quicktracks 5
"{3990E632-42C3-4A25-ADFF-1101E3D6DD47}" = VSClassic
"{42929F0F-CE14-47AF-9FC7-FF297A603021}" = Dell Resource CD
"{57752979-A1C9-4C02-856B-FBB27AC4E02C}" = QuickTime
"{59F6A514-9813-47A3-948C-8A155460CC2A}" = RICOH R5C83x/84x Flash Media Controller Driver Ver.3.54.05
"{5EE7D259-D137-4438-9A5F-42F432EC0421}" = VC80CRTRedist - 8.0.50727.4053
"{669C7BD8-DAA2-49B6-966C-F1E2AAE6B17E}" = Cisco PEAP Module
"{66F1F013-008F-4875-B283-5A814B820347}" = Kaspersky Internet Security 2011
"{6D3963B0-E13B-4FC3-B0FF-506A304BB043}" = Cisco EAP-FAST Module
"{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}" = Microsoft Visual C++ 2005 Redistributable
"{7770E71B-2D43-4800-9CB3-5B6CAAEBEBEA}" = RealNetworks - Microsoft Visual C++ 2008 Runtime
"{83770D14-21B9-44B3-8689-F7B523F94560}" = Cisco LEAP Module
"{90120000-0015-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0016-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0019-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001A-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_ENTERPRISE_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_ENTERPRISE_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_ENTERPRISE_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-002A-0000-1000-0000000FF1CE}_ENTERPRISE_{E64BA721-2310-4B55-BE5A-2925F9706192}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-002A-0409-1000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0030-0000-0000-0000000FF1CE}" = Microsoft Office Enterprise 2007
"{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{90120000-0044-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00A1-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00BA-0409-0000-0000000FF1CE}" = Microsoft Office Groove MUI (English) 2007
"{90120000-00BA-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0114-0409-0000-0000000FF1CE}" = Microsoft Office Groove Setup Metadata MUI (English) 2007
"{90120000-0114-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0116-0409-1000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0117-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{9BE518E6-ECC6-35A9-88E4-87755C07200F}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
"{A567895C-1D23-48ED-BE83-FB3ED7D30442}" = IPM_VS_Pro
"{AA902C31-B49D-4608-BCCF-2519EB77722D}" = ICA
"{B0125BEB-6731-43FA-88DA-B64D7BD3AD2D}" = VSPro
"{B84ECBE1-6ED5-4E86-B4AB-DF46D342411F}" = Share
"{B87FAC24-973D-4A4F-AFC4-555FB95B32DB}" = PureHD
"{B8A2869E-30CA-40C5-9CF8-BD7354E57EF8}" = SmartSound Common Data
"{C41300B9-185D-475E-BFEC-39EF732F19B1}" = Apple Software Update
"{C4778408-3268-45CE-AE15-772D1739A1F1}" = VIO
"{C6017EEA-9E51-4129-84BA-EFA9520E69D8}" = Common
"{CC4C7E9B-4B26-4D8D-8076-40CF708A9FA4}" = Contents
"{D07F85DE-22F1-4FB4-B3D1-402FD22C4870}" = DeviceIO
"{D68897FC-7E8D-4849-819A-726B2489713C}" = ISCOM
"{D8D9BCF5-0F5F-4D3F-8427-64B7632F93BE}" = Setup
"{DE4BF4BE-3CDC-43B5-BBDA-DDDA73103111}" = Corel PaintShop Photo Pro X3
"{DE612A3D-0DCC-4055-BB6A-0036F31158A0}" = Setup
"{DE8B9311-ADE7-4EDE-B121-326CAA3D225D}" = PSPPContent
"{DE99075E-7D25-4B96-B32E-BFE6FBFAA644}" = IPM_PSP_CL
"{DEAEB5DB-04FA-489D-94EF-8600898B93EE}" = ICA
"{DEF1928A-FC01-48E7-A7E6-4651D42EF6A1}" = PSPPRO_DCRAW
"{DEF8C145-CC4F-4DAA-AD5C-E707C07AEE50}" = IPM_PSP_COM
"{E38C00D0-A68B-4318-A8A6-F7D4B5B1DF0E}" = Windows Media Encoder 9 Series
"{F6BB6248-C507-46FE-8A35-1B16F35E0441}" = ITECIR
"Bejeweled 2 Deluxe 1.0" = Bejeweled 2 Deluxe 1.0
"DivX Setup.divx.com" = DivX Setup
"ENTERPRISE" = Microsoft Office Enterprise 2007
"InstallShield_{2F8BA3FD-1FA9-4279-B696-712ABB12F09F}" = SmartSound Quicktracks 5
"InstallShield_{B8A2869E-30CA-40C5-9CF8-BD7354E57EF8}" = SmartSound Common Data
"InstallWIX_{66F1F013-008F-4875-B283-5A814B820347}" = Kaspersky Internet Security 2011
"Mozilla Firefox 5.0 (x86 en-US)" = Mozilla Firefox 5.0 (x86 en-US)
"RealPlayer 12.0" = RealPlayer
"VLC media player" = VLC media player 1.1.9
"Windows Media Encoder 9" = Windows Media Encoder 9 Series
"Xilisoft Video Converter Ultimate" = Xilisoft Video Converter Ultimate
"Google Chrome" = Google Chrome
[ Application Events ]
Error - 6/23/2011 10:01:33 PM | Computer Name = Deepa-PC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: m->NextScheduledSPRetry 2569555
Error - 6/23/2011 10:01:34 PM | Computer Name = Deepa-PC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: Continuously busy for more than a second
Description = Task Scheduling Error: m->NextScheduledEvent 2570725
Description = Task Scheduling Error: m->NextScheduledSPRetry 2570725
Error - 6/23/2011 10:10:04 PM | Computer Name = Deepa-PC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: m->NextScheduledEvent 1295
Description = Task Scheduling Error: m->NextScheduledSPRetry 1295
Error - 6/23/2011 10:10:28 PM | Computer Name = Deepa-PC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: m->NextScheduledEvent 24508
Description = Task Scheduling Error: m->NextScheduledSPRetry 24508
[ Broadcom Wireless LAN Events ]
Error - 4/4/2011 11:46:41 AM | Computer Name = Deepa-PC | Source = WLAN-Tray | ID = 0
Description = 10:46:41, Mon, Apr 04, 11 Error - User "" does not have administrative
privileges on this system
Error - 5/11/2011 12:50:14 AM | Computer Name = Deepa-PC | Source = WLAN-Tray | ID = 0
Description = 23:50:14, Tue, May 10, 11 Error - User "" does not have administrative
Error - 5/18/2011 1:52:33 AM | Computer Name = Deepa-PC | Source = WLAN-Tray | ID = 0
Description = 00:52:33, Wed, May 18, 11 Error - User "" does not have administrative
Error - 5/23/2011 1:45:29 AM | Computer Name = Deepa-PC | Source = WLAN-Tray | ID = 0
Description = 00:45:29, Mon, May 23, 11 Error - User "" does not have administrative
Error - 5/26/2011 1:54:57 AM | Computer Name = Deepa-PC | Source = WLAN-Tray | ID = 0
Description = 00:54:57, Thu, May 26, 11 Error - User "" does not have administrative
Error - 6/6/2011 8:37:09 AM | Computer Name = Deepa-PC | Source = WLAN-Tray | ID = 0
Description = 07:37:09, Mon, Jun 06, 11 Error - User "" does not have administrative
Error - 6/10/2011 5:04:08 PM | Computer Name = Deepa-PC | Source = WLAN-Tray | ID = 0
Description = 16:04:08, Fri, Jun 10, 11 Error - User "" does not have administrative
Error - 6/14/2011 12:32:27 AM | Computer Name = Deepa-PC | Source = WLAN-Tray | ID = 0
Description = 23:32:27, Mon, Jun 13, 11 Error - User "" does not have administrative
Error - 6/22/2011 1:31:08 AM | Computer Name = Deepa-PC | Source = WLAN-Tray | ID = 0
Description = 00:31:08, Wed, Jun 22, 11 Error - User "" does not have administrative
[ System Events ]
Error - 6/21/2011 8:15:17 AM | Computer Name = Deepa-PC | Source = Application Popup | ID = 1060
Description = \SystemRoot\system32\DRIVERS\netbios.sys has been blocked from loading
due to incompatibility with this system. Please contact your software vendor for
a compatible version of the driver.
Error - 6/21/2011 8:16:37 AM | Computer Name = Deepa-PC | Source = Service Control Manager | ID = 7026
Description =
Error - 6/21/2011 11:35:48 AM | Computer Name = Deepa-PC | Source = Application Popup | ID = 1060
Error - 6/21/2011 11:36:59 AM | Computer Name = Deepa-PC | Source = Service Control Manager | ID = 7026
Description =
Error - 6/22/2011 8:54:17 AM | Computer Name = Deepa-PC | Source = Application Popup | ID = 1060
Error - 6/22/2011 8:56:20 AM | Computer Name = Deepa-PC | Source = Service Control Manager | ID = 7022
Description =
Error - 6/22/2011 8:56:20 AM | Computer Name = Deepa-PC | Source = Service Control Manager | ID = 7026
Description =
Error - 6/23/2011 8:07:06 AM | Computer Name = Deepa-PC | Source = Application Popup | ID = 1060
Error - 6/23/2011 8:09:05 AM | Computer Name = Deepa-PC | Source = Service Control Manager | ID = 7022
Description =
Error - 6/23/2011 8:09:06 AM | Computer Name = Deepa-PC | Source = Service Control Manager | ID = 7026
Description =
uvita
Rookie Surfer
Rookie Surfer
Post by Sneakyone on Fri 24 Jun 2011, 5:31 pm
Please download DDS by sUBs from BleepingComputer.com or Forospyware.com and save it to your Desktop.
Note: Before scanning, make sure all other running programs are closed. There shouldn't be any scheduled antivirus scans running while the scan is being performed. Do not use your computer for anything else during the scan.
  • A small box will open, with an explanation about the tool. No input is needed, the scan is running.
  • Notepad will open with the results, click Yes to the Optional_Scan
  • Please follow the instructions that pop up for posting the results.
  • Close the program window, and delete the program from your Desktop.
Sneakyone
Tech Officer
Tech Officer
Post by uvita on Sat 25 Jun 2011, 12:39 am
DDS (Ver_2011-06-23.01) - NTFSAMD64
Internet Explorer: 8.0.6001.19088
Run by Deepa at 8:18:19 on 2011-06-24
Microsoft® Windows Vista™ Home Premium 6.0.6002.2.1252.1.1033.18.4054.2390 [GMT -5:00]
AV: Kaspersky Internet Security *Enabled/Updated* {56547CC9-C9B2-849D-8FEF-A496150D6A06}
SP: Windows Defender *Enabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
SP: Kaspersky Internet Security *Enabled/Updated* {ED359D2D-EF88-8B13-B55F-9FE46E8A20BB}
FW: Kaspersky Internet Security *Enabled* {6E6FFDEC-83DD-85C5-A4B0-0DA3EBDE2D7D}
C:\Windows\system32\wininit.exe
C:\Windows\system32\lsm.exe
C:\Windows\system32\svchost.exe -k DcomLaunch
C:\Windows\system32\svchost.exe -k rpcss
C:\Windows\System32\svchost.exe -k secsvcs
C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted
C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted
C:\Windows\system32\svchost.exe -k netsvcs
C:\Windows\system32\svchost.exe -k GPSvcGroup
C:\Windows\system32\SLsvc.exe
C:\Windows\system32\svchost.exe -k LocalService
C:\Windows\system32\svchost.exe -k NetworkService
C:\Windows\System32\WLTRYSVC.EXE
C:\Windows\System32\bcmwltry.exe
C:\Windows\system32\WLANExt.exe
C:\Windows\System32\spoolsv.exe
C:\Windows\system32\svchost.exe -k LocalServiceNoNetwork
C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
C:\Windows\system32\taskeng.exe
C:\Program Files (x86)\Bonjour\mDNSResponder.exe
C:\Windows\system32\svchost.exe -k NetworkServiceNetworkRestricted
C:\Windows\System32\svchost.exe -k WerSvcGroup
C:\Windows\system32\SearchIndexer.exe
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Program Files\Windows Defender\MSASCui.exe
C:\Windows\System32\igfxtray.exe
C:\Windows\System32\hkcmd.exe
C:\Windows\System32\igfxpers.exe
C:\Program Files\DellTPad\Apoint.exe
C:\Windows\System32\WLTRAY.EXE
C:\Program Files\Windows Sidebar\sidebar.exe
C:\Windows\system32\igfxsrvc.exe
C:\Program Files (x86)\iTunes\iTunesHelper.exe
C:\Program Files\DellTPad\ApMsgFwd.exe
C:\Program Files (x86)\iPod\bin\iPodService.exe
C:\Windows\system32\wbem\unsecapp.exe
C:\Windows\system32\wbem\wmiprvse.exe
C:\Program Files\DellTPad\HidFind.exe
C:\Program Files\DellTPad\Apntex.exe
C:\Windows\Microsoft.Net\Framework64\v3.0\WPF\PresentationFontCache.exe
C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation
C:\Windows\SysWOW64\cmd.exe
C:\Windows\SysWOW64\cscript.exe
mWinlogon: Userinit=userinit.exe
BHO: RealPlayer Download and Record Plugin for Internet Explorer: {3049c3e9-b461-4bc5-8870-4c09146192ca} - C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll
BHO: DivX Plus Web Player HTML5
uvita
Rookie Surfer
Rookie Surfer
Post by uvita on Sat 25 Jun 2011, 12:45 am
don't know how to attach the zipped attach.
uvita
Rookie Surfer
Rookie Surfer
Post by Sneakyone on Sun 26 Jun 2011, 4:40 pm
Please download ComboFix from BleepingComputer.com
Alternate link: GeeksToGo.com
Alternate link: Forospyware.com
Sneakyone
Tech Officer
Tech Officer
Post by uvita on Tue 28 Jun 2011, 4:56 pm
here it is:
ComboFix 11-06-27.01 - Deepa 06/28/2011 0:33.1.2 - x64
Microsoft® Windows Vista™ Home Premium 6.0.6002.2.1252.1.1033.18.4054.2436 [GMT -5:00]
Running from: c:\users\Deepa\Desktop\commy.exe
AV: Kaspersky Internet Security *Disabled/Updated* {56547CC9-C9B2-849D-8FEF-A496150D6A06}
FW: Kaspersky Internet Security *Disabled* {6E6FFDEC-83DD-85C5-A4B0-0DA3EBDE2D7D}
SP: Kaspersky Internet Security *Disabled/Updated* {ED359D2D-EF88-8B13-B55F-9FE46E8A20BB}
SP: Windows Defender *Disabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
c:\users\Deepa\videos\Silverlight.exe
c:\windows\UA000106.DLL
((((((((((((((((((((((((( Files Created from 2011-05-28 to 2011-06-28 )))))))))))))))))))))))))))))))
2011-06-28 05:30 . 2011-06-28 05:30 -------- d-----w- C:\32788R22FWJFW
2011-06-24 12:47 . 2011-06-07 17:10 8873296 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{FC9496F5-ECD1-4098-813C-80B040EC978A}\mpengine.dll
2011-06-19 03:05 . 2011-06-19 03:05 -------- d-----w- c:\program files (x86)\Common Files\xing shared
2011-06-19 03:04 . 2011-06-19 03:05 -------- d-----w- c:\program files (x86)\Real
2011-06-16 14:58 . 2011-05-02 17:16 739328 ----a-w- c:\windows\SysWow64\inetcomm.dll
2011-06-16 14:58 . 2011-05-02 17:13 975360 ----a-w- c:\windows\system32\inetcomm.dll
2011-06-04 02:46 . 2011-06-04 02:46 -------- d-----w- c:\programdata\WindowsSearch
2011-06-01 16:37 . 2011-06-01 16:37 -------- d-----w- c:\users\Default\AppData\Local\Microsoft Help
2011-05-31 17:01 . 2011-06-17 13:19 -------- d-----w- c:\program files (x86)\Microsoft Silverlight
2011-05-30 13:53 . 2011-05-30 14:03 -------- d-----w- c:\programdata\Protexis
2011-05-30 13:53 . 2011-05-30 14:04 -------- d-----w- c:\users\Deepa\AppData\Roaming\Ulead Systems
2011-05-30 13:49 . 2011-05-30 13:49 -------- d-----w- c:\programdata\eSellerate
2011-05-30 13:48 . 2011-05-30 13:49 -------- d-----w- c:\program files (x86)\SmartSound Software
2011-05-30 13:48 . 2011-05-30 13:49 -------- d-----w- c:\programdata\SmartSound Software Inc
2011-05-30 13:47 . 2011-05-31 12:59 -------- d--h--w- c:\windows\msdownld.tmp
2011-05-30 13:46 . 2011-05-30 13:46 -------- d-----w- c:\programdata\InterVideo
2011-05-30 13:46 . 2001-09-06 05:18 225280 ----a-w- c:\program files (x86)\Common Files\InstallShield\IScript\IScript.dll
2011-05-30 13:46 . 2001-09-06 05:14 176128 ----a-w- c:\program files (x86)\Common Files\InstallShield\engine\6\Intel 32\iuser.dll
2011-05-30 13:46 . 2001-09-06 05:13 32768 ----a-w- c:\program files (x86)\Common Files\InstallShield\engine\6\Intel 32\objectps.dll
2011-05-30 13:46 . 2001-09-06 05:18 77824 ----a-w- c:\program files (x86)\Common Files\InstallShield\engine\6\Intel 32\ctor.dll
2011-05-30 13:39 . 2011-05-30 13:39 -------- d-----w- c:\program files (x86)\Common Files\Ulead Systems
2011-05-30 13:32 . 2002-07-26 17:07 614532 ----a-w- c:\program files (x86)\Common Files\InstallShield\engine\6\Intel 32\IKernel.exe
2011-06-27 14:48 . 2011-05-10 06:03 2828 --sha-w- c:\programdata\KGyGaAvL.sys
2011-06-21 12:18 . 2011-05-17 13:32 404640 ----a-w- c:\windows\SysWow64\FlashPlayerCPLApp.cpl
2011-05-25 00:14 . 2011-03-10 22:46 270720 ------w- c:\windows\system32\MpSigStub.exe
2011-05-10 06:07 . 2011-05-10 06:03 88 --sh--r- c:\programdata\0FE459EF6D.sys
"Sidebar"="c:\program files\Windows Sidebar\sidebar.exe" [2009-04-11 1555968]
"Corel Photo Downloader"="c:\program files (x86)\Common Files\Corel\Corel PhotoDownloader\Corel Photo Downloader.exe" [2010-07-28 526992]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
"QuickTime Task"="c:\program files (x86)\QuickTime\QTTask.exe" [2010-11-29 421888]
"iTunesHelper"="c:\program files (x86)\iTunes\iTunesHelper.exe" [2011-03-07 421160]
"AVP"="c:\program files (x86)\Kaspersky Lab\Kaspersky Internet Security 2011\avp.exe" [2010-11-03 365336]
"GrooveMonitor"="c:\program files (x86)\Microsoft Office\Office12\GrooveMonitor.exe" [2008-10-25 31072]
"DivXUpdate"="c:\program files (x86)\DivX\DivX Update\DivXUpdate.exe" [2011-03-21 1230704]
"TkBellExe"="c:\program files (x86)\Real\RealPlayer\Update\realsched.exe" [2011-06-19 273544]
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\windows]
"AppInit_DLLs"=c:\progra~2\KASPER~1\KASPER~1\sbhook.dll
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\drivers32]
"aux1"=wdmaud.drv
@="Driver"
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\KasperskyAntiVirus]
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
R3 WDC_SAM;WD SCSI Pass Thru driver;c:\windows\system32\DRIVERS\wdcsam64.sys [x]
R3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\Microsoft.NET\Framework64\v4.0.30319\WPF\WPFFontCache_v0400.exe [2010-03-18 1020768]
R4 ahcix64s;ahcix64s;c:\windows\system32\drivers\ahcix64s.sys [x]
S1 kl2;kl2;c:\windows\system32\DRIVERS\kl2.sys [x]
S1 KLIM6;Kaspersky Anti-Virus NDIS 6 Filter;c:\windows\system32\DRIVERS\klim6.sys [x]
S3 itecir;ITECIR Infrared Receiver;c:\windows\system32\DRIVERS\itecir.sys [x]
S3 k57nd60a;Broadcom NetLink (TM) Gigabit Ethernet - NDIS 6.0;c:\windows\system32\DRIVERS\k57nd60a.sys [x]
S3 klmouflt;Kaspersky Lab KLMOUFLT;c:\windows\system32\DRIVERS\klmouflt.sys [x]
S3 OA001Ufd;Creative Camera OA001 Upper Filter Driver;c:\windows\system32\DRIVERS\OA001Ufd.sys [x]
S3 OA001Vid;Creative Camera OA001 Function Driver;c:\windows\system32\DRIVERS\OA001Vid.sys [x]
2011-06-27 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-2504574272-3988817967-4150786661-1000Core.job
- c:\users\Deepa\AppData\Local\Google\Update\GoogleUpdate.exe [2011-04-04 01:54]
2011-06-28 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-2504574272-3988817967-4150786661-1000UA.job
2011-06-28 c:\windows\Tasks\User_Feed_Synchronization-{4CA2E4C6-A30B-4CEF-96B5-166A4E1D069E}.job
- c:\windows\system32\msfeedssync.exe [2011-06-16 04:32]
--------- x86-64 -----------
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2010-08-26 161304]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2010-08-26 386584]
"Persistence"="c:\windows\system32\igfxpers.exe" [2010-08-26 415256]
"Apoint"="c:\program files\DellTPad\Apoint.exe" [2008-08-02 272896]
"Broadcom Wireless Manager UI"="c:\windows\system32\WLTRAY.exe" [2008-06-02 3863040]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
"LoadAppInit_DLLs"=0x1
"AppInit_DLLs"=c:\progra~2\KASPER~1\KASPER~1\x64\sbhook64.dll
uLocal Page = c:\windows\system32\blank.htm
mLocal Page = c:\windows\SysWOW64\blank.htm
IE: Add to Anti-Banner - c:\program files (x86)\Kaspersky Lab\Kaspersky Internet Security 2011\ie_banner_deny.htm
IE: E&xport to Microsoft Excel - c:\progra~2\MICROS~1\Office12\EXCEL.EXE/3000
TCP: DhcpNameServer = 192.168.1.254
CLSID: {603d3801-bd81-11d0-a3a5-00c04fd706ec} - %SystemRoot%\SysWow64\browseui.dll
FF - ProfilePath - c:\users\Deepa\AppData\Roaming\Mozilla\Firefox\Profiles\4puw4zrc.default\
FF - prefs.js: network.proxy.type - 0
Wow6432Node-HKLM-Run-Corel File Shell Monitor - c:\program files (x86)\Corel\Corel PaintShop Photo Pro\X3\PSPClassic\CorelIOMonitor.exe
HKLM-Run-Windows Defender - c:\program files (x86)\Windows Defender\MSASCui.exe
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{0BE09CC1-42E0-11DD-AE16-0800200C9A66}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil10a.exe,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{0BE09CC1-42E0-11DD-AE16-0800200C9A66}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{0BE09CC1-42E0-11DD-AE16-0800200C9A66}\LocalServer32]
@="c:\\Windows\\SysWow64\\Macromed\\Flash\\FlashUtil10a.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{0BE09CC1-42E0-11DD-AE16-0800200C9A66}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
@="Shockwave Flash Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
@="c:\\Windows\\SysWow64\\Macromed\\Flash\\Flash10a.ocx"
"ThreadingModel"="Apartment"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
@="ShockwaveFlash.ShockwaveFlash.10"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
@="c:\\Windows\\SysWow64\\Macromed\\Flash\\Flash10a.ocx, 1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
@="{D27CDB6B-AE6D-11cf-96B8-444553540000}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="ShockwaveFlash.ShockwaveFlash"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
@="Macromedia Flash Factory Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
@="FlashFactory.FlashFactory.1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="FlashFactory.FlashFactory"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{DDF4CE26-4BDA-42BC-B0F0-0E75243AD285}]
@="IFlashBroker2"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{DDF4CE26-4BDA-42BC-B0F0-0E75243AD285}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{DDF4CE26-4BDA-42BC-B0F0-0E75243AD285}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{D27CDB6B-AE6D-11CF-96B8-444553540000}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{D27CDB6B-AE6D-11CF-96B8-444553540000}\1.0]
@="Shockwave Flash"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9}\1.0]
@="FlashBroker"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes]
"SymbolicLinkValue"=hex(6):5c,00,52,00,45,00,47,00,49,00,53,00,54,00,52,00,59,
00,5c,00,4d,00,41,00,43,00,48,00,49,00,4e,00,45,00,5c,00,53,00,4f,00,46,00,\
c:\program files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
c:\program files (x86)\Bonjour\mDNSResponder.exe
c:\program files (x86)\Common Files\Protexis\License Service\PsiService_2.exe
Completion time: 2011-06-28 00:52:13 - machine was rebooted
ComboFix-quarantined-files.txt 2011-06-28 05:52
Pre-Run: 229,064,728,576 bytes free
Post-Run: 229,127,671,808 bytes free
- - End Of File - - 4D5F673FCF5F699444FA2EBC75AD0F1C
uvita
Rookie Surfer
Rookie Surfer
Post by Sneakyone on Wed 29 Jun 2011, 7:47 am
Please download Malwarebytes Anti-Malware from Here.
  • Make sure a checkmark is placed next to Update Malwarebytes Anti-Malware and Launch Malwarebytes Anti-Malware, then click Finish.
  • When disinfection is completed, a log will open in Notepad and you may be prompted to Restart.(See Extra Note)
  • Copy&Paste the entire report in your next reply.
Sneakyone
Tech Officer
Tech Officer
Post by uvita on Sat 16 Jul 2011, 2:56 pm
ok...here it is:
Malwarebytes' Anti-Malware 1.51.1.1800
Database version: 7155
Windows 6.0.6002 Service Pack 2
Internet Explorer 8.0.6001.19088
7/15/2011 8:29:21 PM
mbam-log-2011-07-15 (20-29-21).txt
Scan type: Quick scan
Objects scanned: 166173
Time elapsed: 3 minute(s), 46 second(s)
uvita
Rookie Surfer
Rookie Surfer
Post by Sneakyone on Sat 16 Jul 2011, 3:18 pm
Please run a free online scan with the ESET Online Scanner
  • Click Start
  • Click Start
Sneakyone
Tech Officer
Tech Officer
Post by Sponsored content Today at 1:13 am
