Norton power eraser problem
Post by bertington on 12th May 2011, 5:23 pm
Ok my helper in my last thread has disappeared. An irl friend suggested combifix and malwarebytes for my ranmit 32 virus, which, along with TDSSKiller.exe, seems to have done some good (my HDD isn't CONSTANTLY making noise anymore, for instance), but I still have massive browser window spam and redirected google pages.
The advice in my last thread was to reformat, which I will be doing in a few weeks, but this is an attempt to fix my pc as bet I can until that time.
After using the above tools, someone suggested I try using this - [You must be registered and logged in to see this link.]
And it has indeed found stuff that the others appear to have missed: Unfortunately when I click "fix" for what it's found, it says "System restore point cannot be created because the windows system restore service is stopped. Use the administrative tools in your control panel to start system restore service and try again."
I can't find the relevant option in control panel Sad tearing
Any ideas!?
bertington
Posts Posts : 32
Joined Joined : 2011-04-14
OS OS : vista 32 bit
Points Points : 21094
Re: Norton power eraser problem
Post by Sneakyone on 13th May 2011, 2:05 am
Please download [You must be registered and logged in to see this link.] to your Desktop. (If you already have it downloaded, then just follow the instructions below).
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.sys
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
Sneakyone
Posts Posts : 2707
Joined Joined : 2010-01-10
Points Points : 56104
Post by bertington on 13th May 2011, 2:37 am
edit: I'm an idiot... One sec, going to do the scan again
bertington
Posts Posts : 32
Post by bertington on 13th May 2011, 2:56 am
Thanks for your reply!
Ok I don't know why but OTL isn't producing an extras file at the end of the scan. I'm definately pasting the text into for the custom scans/fixes though Sad tearing
Here's the OTL file:
OTL logfile created on: 13/05/2011 03:42:32 - Run 2
OTL by OldTimer - Version 3.2.22.3 Folder = C:\Users\Andrew\Downloads
Windows Vista Home Premium Edition Service Pack 1 (Version = 6.0.6001) - Type = NTWorkstation
Internet Explorer (Version = 7.0.6001.18000)
Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
3.00 Gb Total Physical Memory | 2.00 Gb Available Physical Memory | 70.00% Memory free
7.00 Gb Paging File | 6.00 Gb Available in Paging File | 87.00% Paging File free
Drive C: | 69.25 Gb Total Space | 26.05 Gb Free Space | 37.61% Space Free | Partition Type: NTFS
Drive D: | 4.07 Gb Total Space | 0.00 Gb Free Space | 0.00% Space Free | Partition Type: UDF
Drive E: | 298.09 Gb Total Space | 32.90 Gb Free Space | 11.04% Space Free | Partition Type: NTFS
Computer Name: ANDREW-PC | User Name: Andrew | Logged in as Administrator.
PRC - [2011/05/13 03:21:58 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Users\Andrew\Downloads\OTL.exe
PRC - [2010/08/26 02:57:32 | 000,380,928 | ---- | M] (AMD) -- C:\Windows\System32\atieclxx.exe
PRC - [2010/08/26 02:57:04 | 000,176,128 | ---- | M] (AMD) -- C:\Windows\System32\atiesrxx.exe
PRC - [2009/05/18 14:13:50 | 000,185,640 | ---- | M] (TeamViewer GmbH) -- C:\Program Files\TeamViewer\Version4\TeamViewer_Service.exe
PRC - [2008/10/29 07:29:41 | 002,927,104 | ---- | M] (Microsoft Corporation) -- C:\Windows\explorer.exe
PRC - [2007/02/27 15:05:44 | 000,323,989 | ---- | M] (Razer Inc.) -- C:\Program Files\Razer\Krait\razerofa.exe
PRC - [2007/02/16 17:46:20 | 000,295,261 | ---- | M] () -- C:\Program Files\Razer\Krait\razertra.exe
PRC - [2007/02/16 17:44:08 | 000,307,555 | ---- | M] () -- C:\Program Files\Razer\Krait\razerhid.exe
PRC - [2007/01/04 22:38:08 | 000,024,652 | ---- | M] (Viewpoint Corporation) -- C:\Program Files\Viewpoint\Common\ViewpointService.exe
PRC - [2005/08/31 10:46:50 | 001,691,648 | ---- | M] () -- C:\Program Files\NETGEAR\WG311v3\WG311v3.exe
MOD - [2011/05/13 03:21:58 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Users\Andrew\Downloads\OTL.exe
MOD - [2010/08/31 16:39:57 | 001,684,480 | ---- | M] (Microsoft Corporation) -- C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18523_none_5cdd65e20837faf2\comctl32.dll
SRV - [2011/01/11 06:44:10 | 000,407,336 | ---- | M] (Valve Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Steam\SteamService.exe -- (Steam Client Service)
SRV - [2010/08/26 02:57:04 | 000,176,128 | ---- | M] (AMD) [Auto | Running] -- C:\Windows\System32\atiesrxx.exe -- (AMD External Events Utility)
SRV - [2009/08/24 13:16:12 | 000,378,368 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- winhttp.dll -- (WinHttpAutoProxySvc)
SRV - [2009/05/18 14:13:50 | 000,185,640 | ---- | M] (TeamViewer GmbH) [Auto | Running] -- C:\Program Files\TeamViewer\Version4\TeamViewer_Service.exe -- (TeamViewer4)
SRV - [2007/01/04 22:38:08 | 000,024,652 | ---- | M] (Viewpoint Corporation) [Auto | Running] -- C:\Program Files\Viewpoint\Common\ViewpointService.exe -- (Viewpoint Manager Service)
DRV - [2011/01/19 17:47:12 | 000,022,504 | ---- | M] (CPUID) [Kernel | Auto | Running] -- C:\Windows\System32\drivers\cpuz135_x32.sys -- (cpuz135)
DRV - [2010/08/26 04:36:28 | 006,380,032 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\atikmdag.sys -- (atikmdag)
DRV - [2010/08/26 04:36:28 | 006,380,032 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\atikmdag.sys -- (amdkmdag)
DRV - [2010/08/26 02:20:36 | 000,221,696 | ---- | M] (Advanced Micro Devices, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\atikmpag.sys -- (amdkmdap)
DRV - [2010/07/15 13:47:24 | 000,099,344 | ---- | M] (ATI Technologies, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\AtihdLH3.sys -- (AtiHDAudioService)
DRV - [2010/05/06 10:21:36 | 000,105,488 | ---- | M] (ATI Technologies, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\AtiHdmi.sys -- (AtiHdmiService)
DRV - [2009/01/20 15:49:26 | 000,142,848 | ---- | M] (Realtek Corporation ) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\Rtlh86.sys -- (RTL8169)
DRV - [2008/09/19 20:01:51 | 000,016,608 | ---- | M] (Windows (R) 2000 DDK provider) [Kernel | On_Demand | Stopped] -- C:\Windows\gdrv.sys -- (gdrv)
DRV - [2007/10/16 17:14:24 | 000,256,512 | ---- | M] (Marvell Semiconductor, Inc) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\MRVW13B.sys -- (MRV6X32P)
DRV - [2006/09/24 14:28:46 | 000,005,248 | ---- | M] (Windows (R) 2000 DDK provider) [Kernel | Boot | Running] -- C:\Windows\system32\speedfan.sys -- (speedfan)
DRV - [2005/12/07 17:27:52 | 000,013,324 | ---- | M] (Razer (Asia-Pacific) Pte Ltd) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\krait.sys -- (krait03)
DRV - [1996/04/03 20:33:26 | 000,005,248 | ---- | M] () [Kernel | Boot | Running] -- C:\Windows\system32\giveio.sys -- (giveio)
IE - HKLM\..\URLSearchHook: {03402f96-3dc7-4285-bc50-9e81fefafe43} - File not found
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,StartPageCache = 1
IE - HKCU\..\URLSearchHook: {03402f96-3dc7-4285-bc50-9e81fefafe43} - File not found
========== FireFox ==========
FF - prefs.js..browser.search.defaultenginename: "AIM Search"
FF - prefs.js..browser.search.defaulturl: "http://aim.search.aol.com/aol/search?query={searchTerms}&invocationType=tb50-ff-aim-chromesbox-en-us"
FF - prefs.js..browser.search.param.yahoo-fr: "chrf-i3752"
FF - prefs.js..browser.search.param.yahoo-fr-cjkt: "chrf-i3752"
FF - prefs.js..browser.search.selectedEngine: "Dictionary.com"
FF - prefs.js..browser.startup.homepage: "http://www.guardian.co.uk/"
FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}:6.0.24
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:2
FF - prefs.js..extensions.enabledItems: 5
FF - prefs.js..extensions.enabledItems: 3
FF - prefs.js..extensions.enabledItems: 1
FF - prefs.js..keyword.URL: "http://slirsredirect.search.aol.com/redirector/sredir?sredir=2706&invocationType=tb50-ff-aim-ab-en-us&query="
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.19\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2011/05/11 23:24:09 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.19\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2011/05/06 19:51:22 | 000,000,000 | ---D | M]
[2008/09/15 20:07:22 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Andrew\AppData\Roaming\Mozilla\Extensions
[2011/05/12 13:03:12 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Andrew\AppData\Roaming\Mozilla\Firefox\Profiles\u5d9z055.default\extensions
[2010/05/25 20:08:21 | 000,000,000 | ---D | M] (TVU Web Player) -- C:\Users\Andrew\AppData\Roaming\Mozilla\Firefox\Profiles\u5d9z055.default\extensions\firefox@tvunetworks.com
[2010/03/16 02:47:05 | 000,002,275 | ---- | M] () -- C:\Users\Andrew\AppData\Roaming\Mozilla\Firefox\Profiles\u5d9z055.default\searchplugins\aim-search.xml
[2010/04/11 17:54:37 | 000,000,921 | ---- | M] () -- C:\Users\Andrew\AppData\Roaming\Mozilla\Firefox\Profiles\u5d9z055.default\searchplugins\dictionarycom.xml
[2011/05/12 13:03:12 | 000,000,000 | ---D | M] (No name found) -- C:\Program Files\Mozilla Firefox\extensions
[2011/04/14 14:43:29 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
[2009/09/29 00:07:37 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\WINDOWS\MICROSOFT.NET\FRAMEWORK\V3.5\WINDOWS PRESENTATION FOUNDATION\DOTNETASSISTANTEXTENSION
[2011/04/14 14:43:24 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npdeployJava1.dll
[2007/04/16 18:07:12 | 000,180,293 | ---- | M] () -- C:\Program Files\Mozilla Firefox\plugins\npViewpoint.dll
[2011/05/06 19:51:02 | 000,001,538 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\amazon-en-GB.xml
[2011/05/06 19:51:02 | 000,000,947 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\chambers-en-GB.xml
[2011/05/06 19:51:02 | 000,000,769 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\eBay-en-GB.xml
[2011/05/06 19:51:03 | 000,000,831 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\yahoo-en-GB.xml
O1 HOSTS File: ([2011/05/11 23:41:10 | 000,000,027 | ---- | M]) - C:\Windows\System32\drivers\etc\hosts
O2 - BHO: (AIM Toolbar Loader) - {b0cda128-b425-4eef-a174-61a11ac5dbf8} - File not found
O3 - HKLM\..\Toolbar: (AIM Toolbar) - {61539ecd-cc67-4437-a03c-9aaccbd14326} - File not found
O4 - HKLM..\Run: [Adobe Reader Speed Launcher] C:\Program Files\Adobe\Reader 10.0\Reader\Reader_sl.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [ATICustomerCare] C:\Program Files\ATI\ATICustomerCare\ATICustomerCare.exe (Advanced Micro Devices, Inc.)
O4 - HKLM..\Run: [Krait] C:\Program Files\Razer\Krait\razerhid.exe ()
O4 - HKLM..\Run: [StartCCC] C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe (Advanced Micro Devices, Inc.)
O4 - HKCU..\Run: [Steam] C:\Program Files\Steam\steam.exe (Valve Corporation)
O4 - HKCU..\Run: [uTorrent] C:\Program Files\uTorrent\uTorrent.exe (BitTorrent, Inc.)
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableLUA = 0
O9 - Extra Button: PokerStars - {3AD14F0C-ED16-4e43-B6D8-661B03F6A1EF} - File not found
O9 - Extra Button: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - File not found
O9 - Extra 'Tools' menuitem : PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - File not found
O10 - NameSpace_Catalog5\Catalog_Entries\000000000007 [] - C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
O16 - DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} [You must be registered and logged in to see this link.] (BDSCANONLINE Control)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_24)
O16 - DPF: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_24)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_24)
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.254
O18 - Protocol\Filter\application/octet-stream {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/x-complus {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/x-msdownload {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - mscoree.dll (Microsoft Corporation)
O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20 - HKLM Winlogon: UserInit - (C:\Program Files\ngfminbl\vmwysnkc.exe) - File not found
O20 - HKLM Winlogon: GinaDLL - (MrvGINA.dll) - File not found
O24 - Desktop WallPaper: C:\Users\Andrew\AppData\Roaming\Microsoft\Windows Photo Gallery\Windows Photo Gallery Wallpaper.jpg
O24 - Desktop BackupWallPaper: C:\Users\Andrew\AppData\Roaming\Microsoft\Windows Photo Gallery\Windows Photo Gallery Wallpaper.jpg
O29 - HKLM SecurityProviders - (credssp.dll) - credssp.dll (Microsoft Corporation)
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2006/09/18 22:43:36 | 000,000,024 | ---- | M] () - C:\autoexec.bat -- [ NTFS ]
O35 - HKCU\..exefile [open] -- "%1" %*
O37 - HKLM\...com [@ = ComFile] -- "%1" %*
NetSvcs: FastUserSwitchingCompatibility - File not found
NetSvcs: Ias - File not found
NetSvcs: Nla - File not found
NetSvcs: Ntmssvc - File not found
NetSvcs: SRService - File not found
NetSvcs: LogonHours - File not found
NetSvcs: PCAudit - File not found
NetSvcs: helpsvc - File not found
NetSvcs: uploadmgr - File not found
SafeBootMin: AppMgmt - File not found
SafeBootMin: HelpSvc - Service
SafeBootMin: NTDS - File not found
SafeBootMin: sacsvr - Service
SafeBootMin: WinDefend - Service
SafeBootMin: {533C5B84-EC70-11D2-9505-00C04F79DEAF} - Volume shadow copy
SafeBootMin: {6BDD1FC1-810F-11D0-BEC7-08002BE2092F} - IEEE 1394 Bus host controllers
SafeBootMin: {D48179BE-EC20-11D1-B6B8-00C04FA372A7} - SBP2 IEEE 1394 Devices
SafeBootMin: {D94EE5D8-D189-4994-83D2-F68D7D41B0E6} - SecurityDevices
SafeBootNet: AppMgmt - File not found
SafeBootNet: HelpSvc - Service
SafeBootNet: Messenger - Service
SafeBootNet: NTDS - File not found
SafeBootNet: rdsessmgr - Service
SafeBootNet: sacsvr - Service
SafeBootNet: WinDefend - Service
SafeBootNet: {50DD5230-BA8A-11D1-BF5D-0000F805F530} - Smart card readers
SafeBootNet: {533C5B84-EC70-11D2-9505-00C04F79DEAF} - Volume shadow copy
SafeBootNet: {6BDD1FC1-810F-11D0-BEC7-08002BE2092F} - IEEE 1394 Bus host controllers
SafeBootNet: {D48179BE-EC20-11D1-B6B8-00C04FA372A7} - SBP2 IEEE 1394 Devices
SafeBootNet: {D94EE5D8-D189-4994-83D2-F68D7D41B0E6} - SecurityDevices
ActiveX: {03F998B2-0E00-11D3-A498-00104B6EB52E} - Viewpoint Media Player
ActiveX: {08B0E5C0-4FCB-11CF-AAA5-00401C608500} - Java (Sun)
ActiveX: {1B00725B-C455-4DE6-BFB6-AD540AD427CD} - Viewpoint Media Player
ActiveX: {2179C5D3-EBFF-11CF-B6FD-00AA00B4E220} -
ActiveX: {22d6f312-b0f6-11d0-94ab-0080c74c7e95} - C:\Windows\System32\Microsoft
ActiveX: {233C1507-6A77-46A4-9443-F871F945D258} - C:\Windows\System32\Adobe
ActiveX: {2A202491-F00D-11cf-87CC-0020AFEECF20} - Adobe Shockwave Director 11.0
ActiveX: {3C3901C5-3455-3E0A-A214-0B093A5070A6} - .NET Framework
ActiveX: {44BBA840-CC51-11CF-AAFA-00AA00B6015C} - "%ProgramFiles%\Windows Mail\WinMail.exe" OCInstallUserConfigOE
ActiveX: {44BBA848-CC51-11CF-AAFA-00AA00B6015C} -
ActiveX: {4f645220-306d-11d2-995d-00c04f98bbc9} - Microsoft Windows Script 5.7
ActiveX: {6BF52A52-394A-11d3-B153-00C04F79FAA6} - C:\Windows\System32\Microsoft
ActiveX: {73FA19D0-2D75-11D2-995D-00C04F98BBC9} - Web Folders
ActiveX: {7790769C-0471-11d2-AF11-00C04FA35D02} - Address Book 7
ActiveX: {7C028AF8-F614-47B3-82DA-BA94E41B1089} - .NET Framework
ActiveX: {89820200-ECBD-11cf-8B85-00AA005B4383} - C:\Windows\system32\ie4uinit.exe -BaseSettings
ActiveX: {89B4C1CD-B018-4511-B0A1-5476DBF70820} - C:\Windows\system32\Rundll32.exe C:\Windows\system32\mscories.dll,Install
ActiveX: {D27CDB6E-AE6D-11CF-96B8-444553540000} - Adobe Flash Player
ActiveX: >{22d6f312-b0f6-11d0-94ab-0080c74c7e95} - C:\Windows\system32\unregmp2.exe /ShowWMP
ActiveX: >{26923b43-4d38-484f-9b9e-de460746276c} - C:\Windows\system32\ie4uinit.exe -UserIconConfig
ActiveX: >{60B49E34-C7CC-11D0-8953-00A0C90347FF} - RunDLL32 IEDKCS32.DLL,BrandIE4 SIGNUP
Drivers32: aux - wdmaud.drv (Microsoft Corporation)
Drivers32: aux1 - wdmaud.drv (Microsoft Corporation)
Drivers32: aux2 - wdmaud.drv (Microsoft Corporation)
Drivers32: midi - wdmaud.drv (Microsoft Corporation)
Drivers32: midi1 - wdmaud.drv (Microsoft Corporation)
Drivers32: midi2 - wdmaud.drv (Microsoft Corporation)
Drivers32: midimapper - midimap.dll (Microsoft Corporation)
Drivers32: mixer - wdmaud.drv (Microsoft Corporation)
Drivers32: mixer1 - wdmaud.drv (Microsoft Corporation)
Drivers32: mixer2 - wdmaud.drv (Microsoft Corporation)
Drivers32: msacm.imaadpcm - imaadp32.acm (Microsoft Corporation)
Drivers32: msacm.l3acm - C:\Windows\System32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
Drivers32: msacm.msadpcm - msadp32.acm (Microsoft Corporation)
Drivers32: msacm.msg711 - msg711.acm (Microsoft Corporation)
Drivers32: msacm.msgsm610 - msgsm32.acm (Microsoft Corporation)
Drivers32: msacm.siren - sirenacm.dll (Microsoft Corporation)
Drivers32: vidc.cvid - iccvid.dll (Radius Inc.)
Drivers32: vidc.ffds - C:\Program Files\Combined Community Codec Pack\Filters\FFDShow\ff_vfw.dll ()
Drivers32: vidc.i420 - iyuv_32.dll (Microsoft Corporation)
Drivers32: vidc.iyuv - iyuv_32.dll (Microsoft Corporation)
Drivers32: vidc.mrle - msrle32.dll (Microsoft Corporation)
Drivers32: vidc.msvc - msvidc32.dll (Microsoft Corporation)
Drivers32: vidc.uyvy - msyuv.dll (Microsoft Corporation)
Drivers32: vidc.yuy2 - msyuv.dll (Microsoft Corporation)
Drivers32: vidc.yvu9 - tsbyuv.dll (Microsoft Corporation)
Drivers32: vidc.yvyu - msyuv.dll (Microsoft Corporation)
Drivers32: wave - wdmaud.drv (Microsoft Corporation)
Drivers32: wave1 - wdmaud.drv (Microsoft Corporation)
Drivers32: wave2 - wdmaud.drv (Microsoft Corporation)
Drivers32: wavemapper - msacm32.drv (Microsoft Corporation)
CREATERESTOREPOINT
Error creating restore point.
[2011/05/12 14:08:18 | 000,000,000 | ---D | C] -- C:\ProgramData\Norton
[2011/05/12 14:08:13 | 000,000,000 | ---D | C] -- C:\Users\Andrew\AppData\Local\NPE
[2011/05/12 13:49:32 | 000,000,000 | ---D | C] -- C:\Windows\System32\EventProviders
[2011/05/12 00:00:13 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
[2011/05/11 23:42:49 | 000,000,000 | -HSD | C] -- C:\$RECYCLE.BIN
[2011/05/11 23:42:48 | 000,000,000 | ---D | C] -- C:\Windows\temp
[2011/05/11 23:42:48 | 000,000,000 | ---D | C] -- C:\Users\Andrew\AppData\Local\temp
[2011/05/11 23:27:18 | 000,161,792 | ---- | C] (SteelWerX) -- C:\Windows\SWREG.exe
[2011/05/11 23:27:18 | 000,136,704 | ---- | C] (SteelWerX) -- C:\Windows\SWSC.exe
[2011/05/11 23:27:18 | 000,031,232 | ---- | C] (NirSoft) -- C:\Windows\NIRCMD.exe
[2011/05/11 23:27:13 | 000,000,000 | ---D | C] -- C:\Windows\ERDNT
[2011/05/11 23:26:58 | 000,212,480 | ---- | C] (SteelWerX) -- C:\Windows\SWXCACLS.exe
[2011/05/11 23:26:57 | 000,000,000 | ---D | C] -- C:\32788R22FWJFW
[2011/05/11 23:24:48 | 000,000,000 | ---D | C] -- C:\Qoobox
[2011/04/16 17:36:09 | 000,000,000 | ---D | C] -- C:\Users\Andrew\AppData\Local\PackageAware
[2011/04/14 15:01:46 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Adobe
[2011/04/14 14:43:39 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Java
[2011/04/14 14:43:28 | 000,157,472 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\System32\javaws.exe
[2011/04/14 14:43:28 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\System32\javaw.exe
[2011/04/14 14:43:28 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\Windows\System32\java.exe
[2011/04/14 12:31:02 | 000,000,000 | ---D | C] -- C:\Users\Andrew\AppData\Local\ESET
[2011/04/14 01:06:29 | 000,000,000 | ---D | C] -- C:\Users\Andrew\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\HiJackThis
[2011/04/13 20:04:58 | 000,000,000 | ---D | C] -- C:\Program Files\ngfminbl
[31 C:\Users\Andrew\Desktop\*.tmp files -> C:\Users\Andrew\Desktop\*.tmp -> ]
[1 C:\Users\Andrew\Documents\*.tmp files -> C:\Users\Andrew\Documents\*.tmp -> ]
[2011/05/13 02:56:36 | 000,003,712 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0
[2011/05/13 02:56:36 | 000,003,712 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0
[2011/05/12 15:03:07 | 000,611,664 | ---- | M] () -- C:\Windows\System32\perfh009.dat
[2011/05/12 15:03:07 | 000,109,112 | ---- | M] () -- C:\Windows\System32\perfc009.dat
[2011/05/12 14:56:37 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2011/05/12 14:56:35 | 3756,515,328 | -HS- | M] () -- C:\hiberfil.sys
[2011/05/12 14:09:07 | 013,685,357 | ---- | M] () -- C:\Users\Andrew\AppData\Roaming\SMRBackup162.dat
[2011/05/12 03:41:12 | 000,008,505 | -HS- | M] () -- C:\Users\Andrew\Folder.jpg
[2011/05/12 03:41:12 | 000,002,318 | -HS- | M] () -- C:\Users\Andrew\AlbumArtSmall.jpg
[2011/05/12 03:13:01 | 075,657,440 | ---- | M] () -- C:\Users\Andrew\paracast_110508.mp3
[2011/05/11 23:41:10 | 000,000,027 | ---- | M] () -- C:\Windows\System32\drivers\etc\hosts
[2011/05/11 23:25:57 | 000,000,680 | ---- | M] () -- C:\Users\Andrew\AppData\Local\d3d9caps.dat
[2011/05/11 23:22:44 | 249,944,606 | ---- | M] () -- C:\Windows\MEMORY.DMP
[2011/05/11 23:17:00 | 004,346,086 | R--- | M] () -- C:\Users\Andrew\Desktop\ComboFix.exe
[2011/04/26 00:49:21 | 075,657,504 | ---- | M] () -- C:\Users\Andrew\paracast_110424.mp3
[2011/04/21 01:12:07 | 000,092,160 | ---- | M] () -- C:\Users\Andrew\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2011/04/14 19:20:58 | 005,866,654 | ---- | M] () -- C:\Users\Andrew\sex_movie_03.mov
[2011/04/14 18:23:12 | 000,059,082 | ---- | M] () -- C:\Users\Andrew\Martin,_John_-_The_Deluge_-_1834.jpg
[2011/04/14 15:01:55 | 000,001,901 | ---- | M] () -- C:\Users\Public\Desktop\Adobe Reader X.lnk
[2011/04/14 14:43:24 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\System32\deployJava1.dll
[2011/04/14 14:43:24 | 000,157,472 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\System32\javaws.exe
[2011/04/14 14:43:24 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\System32\javaw.exe
[2011/04/14 14:43:24 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\Windows\System32\java.exe
[2011/04/14 14:29:22 | 000,002,052 | ---- | M] () -- C:\Windows\epplauncher.mif
[2011/04/14 01:06:29 | 000,001,950 | ---- | M] () -- C:\Users\Andrew\Desktop\HiJackThis.lnk
[2011/05/12 14:08:47 | 013,685,357 | ---- | C] () -- C:\Users\Andrew\AppData\Roaming\SMRBackup162.dat
[2011/05/12 03:10:26 | 075,657,440 | ---- | C] () -- C:\Users\Andrew\paracast_110508.mp3
[2011/05/11 23:31:26 | 3756,515,328 | -HS- | C] () -- C:\hiberfil.sys
[2011/05/11 23:27:18 | 000,256,512 | ---- | C] () -- C:\Windows\PEV.exe
[2011/05/11 23:27:18 | 000,098,816 | ---- | C] () -- C:\Windows\sed.exe
[2011/05/11 23:27:18 | 000,089,088 | ---- | C] () -- C:\Windows\MBR.exe
[2011/05/11 23:27:18 | 000,080,412 | ---- | C] () -- C:\Windows\grep.exe
[2011/05/11 23:27:18 | 000,068,096 | ---- | C] () -- C:\Windows\zip.exe
[2011/05/11 23:16:40 | 004,346,086 | R--- | C] () -- C:\Users\Andrew\Desktop\ComboFix.exe
[2011/04/26 00:46:22 | 075,657,504 | ---- | C] () -- C:\Users\Andrew\paracast_110424.mp3
[2011/04/14 19:20:49 | 005,866,654 | ---- | C] () -- C:\Users\Andrew\sex_movie_03.mov
[2011/04/14 18:23:11 | 000,059,082 | ---- | C] () -- C:\Users\Andrew\Martin,_John_-_The_Deluge_-_1834.jpg
[2011/04/14 15:01:55 | 000,001,901 | ---- | C] () -- C:\Users\Public\Desktop\Adobe Reader X.lnk
[2011/04/14 15:01:55 | 000,001,804 | ---- | C] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Reader X.lnk
[2011/04/14 11:37:34 | 000,002,052 | ---- | C] () -- C:\Windows\epplauncher.mif
[2011/04/03 06:49:08 | 000,012,682 | -HS- | C] () -- C:\Users\Andrew\AppData\Local\61am7kh612rw85n14158n8334sb5378m1c5h32
[2011/04/03 06:49:08 | 000,012,682 | -HS- | C] () -- C:\ProgramData\61am7kh612rw85n14158n8334sb5378m1c5h32
[2010/10/14 02:36:44 | 000,179,263 | ---- | C] () -- C:\Windows\System32\xlive.dll.cat
[2010/10/12 22:46:31 | 000,000,263 | ---- | C] () -- C:\Windows\System32\gapa.ini
[2010/06/16 14:22:56 | 000,219,348 | ---- | C] () -- C:\Windows\System32\atiicdxx.dat
[2010/06/15 23:28:54 | 000,002,857 | ---- | C] () -- C:\Windows\System32\atipblag.dat
[2010/05/27 17:24:24 | 000,023,040 | ---- | C] () -- C:\Windows\System32\atitmpxx.dll
[2009/12/13 01:13:43 | 000,000,262 | ---- | C] () -- C:\Windows\{789289CA-F73A-4A16-A331-54D498CE069F}_WiseFW.ini
[2009/08/03 16:07:42 | 000,403,816 | ---- | C] () -- C:\Windows\System32\OGACheckControl.dll
[2009/08/03 16:07:42 | 000,230,768 | ---- | C] () -- C:\Windows\System32\OGAEXEC.exe
[2009/05/22 23:34:41 | 000,000,056 | -H-- | C] () -- C:\ProgramData\ezsidmv.dat
[2009/04/27 21:29:41 | 000,000,978 | ---- | C] () -- C:\Windows\eReg.dat
[2009/02/18 18:55:20 | 000,294,912 | ---- | C] () -- C:\Windows\System32\ATIODE.exe
[2009/02/03 21:52:02 | 000,045,056 | ---- | C] () -- C:\Windows\System32\ATIODCLI.exe
[2008/12/21 19:27:22 | 000,092,160 | ---- | C] () -- C:\Users\Andrew\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2008/09/21 16:22:08 | 000,000,280 | ---- | C] () -- C:\Windows\System32\epoPGPsdk.dll.sig
[2008/09/19 20:52:29 | 000,000,376 | ---- | C] () -- C:\Windows\ODBC.INI
[2008/09/19 19:17:12 | 000,000,010 | ---- | C] () -- C:\Windows\GSetup.ini
[2008/09/15 21:40:29 | 000,106,605 | ---- | C] () -- C:\Windows\System32\StructuredQuerySchema.bin
[2008/09/15 21:40:29 | 000,018,904 | ---- | C] () -- C:\Windows\System32\StructuredQuerySchemaTrivial.bin
[2008/09/15 21:21:00 | 000,000,680 | ---- | C] () -- C:\Users\Andrew\AppData\Local\d3d9caps.dat
[2008/09/15 20:11:56 | 000,000,000 | ---- | C] () -- C:\Windows\ativpsrm.bin
[2008/08/01 05:15:27 | 003,107,788 | ---- | C] () -- C:\Windows\System32\atiumdva.dat
[2008/03/06 01:38:44 | 000,090,112 | ---- | C] () -- C:\Windows\System32\atibrtmon.exe
[2007/06/21 07:34:08 | 000,203,328 | R--- | C] () -- C:\Windows\GSetup.exe
[2006/11/02 13:57:28 | 000,067,584 | --S- | C] () -- C:\Windows\bootstat.dat
[2006/11/02 13:47:37 | 000,371,080 | ---- | C] () -- C:\Windows\System32\FNTCACHE.DAT
[2006/11/02 13:35:32 | 000,005,632 | ---- | C] () -- C:\Windows\System32\sysprepMCE.dll
[2006/11/02 11:33:01 | 000,611,664 | ---- | C] () -- C:\Windows\System32\perfh009.dat
[2006/11/02 11:33:01 | 000,287,440 | ---- | C] () -- C:\Windows\System32\perfi009.dat
[2006/11/02 11:33:01 | 000,109,112 | ---- | C] () -- C:\Windows\System32\perfc009.dat
[2006/11/02 11:33:01 | 000,030,674 | ---- | C] () -- C:\Windows\System32\perfd009.dat
[2006/11/02 11:23:21 | 000,215,943 | ---- | C] () -- C:\Windows\System32\dssec.dat
[2006/11/02 09:58:30 | 000,043,131 | ---- | C] () -- C:\Windows\mib.bin
[2006/11/02 09:19:00 | 000,000,741 | ---- | C] () -- C:\Windows\System32\NOISE.DAT
[2006/11/02 08:40:29 | 000,013,750 | ---- | C] () -- C:\Windows\System32\pacerprf.ini
[2006/11/02 08:25:31 | 000,673,088 | ---- | C] () -- C:\Windows\System32\mlang.dat
[2006/05/25 01:22:06 | 000,053,248 | ---- | C] () -- C:\Windows\bdoscandel.exe
[2005/03/01 15:30:20 | 000,000,453 | ---- | C] () -- C:\Windows\bdoscandellang.ini
[2003/01/07 15:05:08 | 000,002,695 | ---- | C] () -- C:\Windows\System32\OUTLPERF.INI
[1996/04/03 20:33:26 | 000,005,248 | ---- | C] () -- C:\Windows\System32\giveio.sys
< %systemroot%\Fonts\*.com >
[2006/11/02 13:37:12 | 000,026,040 | ---- | M] () -- C:\Windows\Fonts\GlobalMonospace.CompositeFont
[2006/11/02 13:37:12 | 000,026,489 | ---- | M] () -- C:\Windows\Fonts\GlobalSansSerif.CompositeFont
[2006/11/02 13:37:12 | 000,029,779 | ---- | M] () -- C:\Windows\Fonts\GlobalSerif.CompositeFont
[2006/11/02 13:37:12 | 000,030,808 | ---- | M] () -- C:\Windows\Fonts\GlobalUserInterface.CompositeFont
< %systemroot%\Fonts\*.dll >
< %systemroot%\Fonts\*.ini >
[2006/09/18 22:37:34 | 000,000,065 | ---- | M] () -- C:\Windows\Fonts\desktop.ini
< %systemroot%\Fonts\*.ini2 >
< %systemroot%\Fonts\*.exe >
< %systemroot%\system32\spool\prtprocs\w32x86\*.* >
[2006/11/02 13:35:48 | 000,022,528 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\spool\prtprocs\w32x86\jnwppr.dll
[2007/04/09 14:23:54 | 000,028,552 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\spool\prtprocs\w32x86\mdippr.dll
< %systemroot%\REPAIR\*.bak1 >
< %systemroot%\REPAIR\*.ini >
< %systemroot%\system32\*.jpg >
< %systemroot%\*.jpg >
< %systemroot%\*.png >
< %systemroot%\*.scr >
< %systemroot%\*._sy >
< %APPDATA%\Adobe\Update\*.* >
< %ALLUSERSPROFILE%\Favorites\*.* >
< %APPDATA%\Microsoft\*.* >
< %PROGRAMFILES%\*.* >
[2008/01/21 03:43:21 | 000,000,174 | -HS- | M] () -- C:\Program Files\desktop.ini
< %APPDATA%\Update\*.* >
< %PROGRAMFILES%\bak. /s >
< %systemroot%\system32\bak. /s >
< %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
< %systemroot%\system32\config\systemprofile\*.dat /x >
< %systemroot%\*.config >
< %systemroot%\system32\*.db >
< %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
[2009/11/24 14:57:48 | 000,047,466 | ---- | M] () -- C:\Users\Andrew\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\attachment.png
[2008/09/16 01:59:56 | 000,000,286 | -HS- | M] () -- C:\Users\Andrew\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\desktop.ini
< %USERPROFILE%\Desktop\*.exe >
< %PROGRAMFILES%\Common Files\*.* >
< %systemroot%\*.src >
< %systemroot%\install\*.* >
< %systemroot%\system32\DLL\*.* >
< %systemroot%\system32\HelpFiles\*.* >
< %systemroot%\system32\rundll\*.* >
< %systemroot%\winn32\*.* >
< %systemroot%\Java\*.* >
< %systemroot%\system32\test\*.* >
< %systemroot%\system32\Rundll32\*.* >
< %systemroot%\AppPatch\Custom\*.* >
< %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
< %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
< %PROGRAMFILES%\Internet Explorer\*.tmp >
< %PROGRAMFILES%\Internet Explorer\*.dat >
< %USERPROFILE%\My Documents\*.exe >
< %USERPROFILE%\*.exe >
< %systemroot%\ADDINS\*.* >
< %systemroot%\assembly\*.bak2 >
< %systemroot%\Config\*.* >
< %systemroot%\REPAIR\*.bak2 >
< %systemroot%\SECURITY\Database\*.sdb /x >
< %systemroot%\SYSTEM\*.bak2 >
< %systemroot%\Web\*.bak2 >
< %systemroot%\Driver Cache\*.* >
< %PROGRAMFILES%\Mozilla Firefox\*.exe >
[2011/05/06 19:51:00 | 000,122,328 | ---- | M] (Mozilla Foundation) -- C:\Program Files\Mozilla Firefox\crashreporter.exe
[2011/05/06 19:51:00 | 000,910,296 | ---- | M] (Mozilla Corporation) -- C:\Program Files\Mozilla Firefox\firefox.exe
[2011/05/06 19:51:03 | 000,246,744 | ---- | M] (Mozilla Foundation) -- C:\Program Files\Mozilla Firefox\updater.exe
< %ProgramFiles%\Microsoft Common\*.* >
< %ProgramFiles%\TinyProxy. >
< %USERPROFILE%\Favorites\*.url /x >
[2008/09/15 21:21:12 | 000,000,402 | -HS- | M] () -- C:\Users\Andrew\Favorites\desktop.ini
< %systemroot%\system32\*.bk >
< %systemroot%\*.te >
< %systemroot%\system32\system32\*.* >
< %ALLUSERSPROFILE%\*.dat /x >
[2011/04/03 07:08:21 | 000,012,682 | -HS- | M] () -- C:\ProgramData\61am7kh612rw85n14158n8334sb5378m1c5h32
< %systemroot%\*. /mp /s >
< %systemroot%\system32\*.dll /lockedfiles >
< %systemroot%\system32\*.exe /lockedfiles >
< %systemroot%\system32\drivers\*.sys /lockedfiles >
< %systemroot%\System32\config\*.sav >
[2008/01/21 04:14:18 | 016,846,848 | ---- | M] () -- C:\Windows\System32\config\COMPONENTS.SAV
[2008/01/21 04:14:08 | 000,106,496 | ---- | M] () -- C:\Windows\System32\config\DEFAULT.SAV
[2008/01/21 04:14:18 | 000,020,480 | ---- | M] () -- C:\Windows\System32\config\SECURITY.SAV
[2006/11/02 11:34:08 | 010,133,504 | ---- | M] () -- C:\Windows\System32\config\SOFTWARE.SAV
[2006/11/02 11:34:08 | 001,826,816 | ---- | M] () -- C:\Windows\System32\config\SYSTEM.SAV
< %systemroot%\system32\*.sys >
[2006/11/02 08:09:42 | 000,009,029 | ---- | M] () -- C:\Windows\System32\ANSI.SYS
[2008/01/21 03:23:54 | 000,247,352 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\clfs.sys
[2006/11/02 08:09:45 | 000,027,097 | ---- | M] () -- C:\Windows\System32\country.sys
[1996/04/03 20:33:26 | 000,005,248 | ---- | M] () -- C:\Windows\System32\giveio.sys
[2006/11/02 08:09:41 | 000,004,768 | ---- | M] () -- C:\Windows\System32\HIMEM.SYS
[2006/11/02 08:09:44 | 000,042,809 | ---- | M] () -- C:\Windows\System32\KEY01.SYS
[2006/11/02 08:09:44 | 000,042,537 | ---- | M] () -- C:\Windows\System32\KEYBOARD.SYS
[2006/11/02 08:09:29 | 000,027,866 | ---- | M] () -- C:\Windows\System32\NTDOS.SYS
[2006/11/02 08:09:35 | 000,029,146 | ---- | M] () -- C:\Windows\System32\NTDOS404.SYS
[2006/11/02 08:09:38 | 000,029,370 | ---- | M] () -- C:\Windows\System32\NTDOS411.SYS
[2006/11/02 08:09:40 | 000,029,274 | ---- | M] () -- C:\Windows\System32\NTDOS412.SYS
[2006/11/02 08:09:31 | 000,029,146 | ---- | M] () -- C:\Windows\System32\NTDOS804.SYS
[2006/11/02 08:09:20 | 000,033,952 | ---- | M] () -- C:\Windows\System32\NTIO.SYS
[2006/11/02 08:09:23 | 000,034,672 | ---- | M] () -- C:\Windows\System32\NTIO404.SYS
[2006/11/02 08:09:24 | 000,035,776 | ---- | M] () -- C:\Windows\System32\NTIO411.SYS
[2006/11/02 08:09:26 | 000,035,536 | ---- | M] () -- C:\Windows\System32\NTIO412.SYS
[2006/11/02 08:09:22 | 000,034,672 | ---- | M] () -- C:\Windows\System32\NTIO804.SYS
[2006/09/24 14:28:46 | 000,005,248 | ---- | M] (Windows (R) 2000 DDK provider) -- C:\Windows\System32\speedfan.sys
[2010/12/31 14:25:17 | 002,038,784 | ---- | M] (Microsoft Corporation) -- C:\Windows\System32\win32k.sys
< %systemroot%\system32\drivers\*.dll >
[2010/08/26 02:19:28 | 000,053,248 | ---- | M] (ATI Technologies Inc.) -- C:\Windows\System32\drivers\ati2erec.dll
< %systemroot%\system32\drivers\*.ini >
< %systemroot%\system32\drivers\*.exe >
< %systemroot%\system32\Spool\prtprocs\w32x86\*.dll >
< %SYSTEMDRIVE%\*.* >
[2006/09/18 22:43:36 | 000,000,024 | ---- | M] () -- C:\autoexec.bat
[2008/01/21 03:24:42 | 000,333,203 | RHS- | M] () -- C:\bootmgr
[2007/01/02 05:10:43 | 000,008,192 | R-S- | M] () -- C:\BOOTSECT.BAK
[2011/05/11 23:42:46 | 000,009,950 | ---- | M] () -- C:\ComboFix.txt
[2006/09/18 22:43:37 | 000,000,010 | ---- | M] () -- C:\config.sys
[2008/09/19 19:39:20 | 000,000,237 | ---- | M] () -- C:\csb.log
[2011/04/03 07:25:00 | 000,000,000 | RHS- | M] () -- C:\IO.SYS
[2010/03/16 02:29:24 | 000,001,110 | -H-- | M] () -- C:\IPH.PH
[2011/04/14 14:47:09 | 000,003,064 | ---- | M] () -- C:\JavaRa.log
[2011/04/03 07:25:00 | 000,000,000 | RHS- | M] () -- C:\MSDOS.SYS
[2011/05/12 14:56:34 | 4070,129,664 | -HS- | M] () -- C:\pagefile.sys
[2008/09/19 19:37:28 | 000,000,477 | ---- | M] () -- C:\RHDSetup.log
[2011/05/12 14:04:23 | 000,058,590 | ---- | M] () -- C:\TDSSKiller.2.5.0.0_12.05.2011_14.02.44_log.txt
[2008/07/26 18:22:44 | 000,000,004 | RHS- | M] () -- C:\WINOS.SYS
< %PROGRAMFILES%\*. >
[2011/04/14 12:54:15 | 000,000,000 | ---D | M] -- C:\Program Files\7-Zip
[2011/04/14 15:01:46 | 000,000,000 | ---D | M] -- C:\Program Files\Adobe
[2008/09/15 21:01:28 | 000,000,000 | ---D | M] -- C:\Program Files\Apple Software Update
[2010/07/03 13:33:43 | 000,000,000 | ---D | M] -- C:\Program Files\ATI
[2010/09/27 01:53:08 | 000,000,000 | ---D | M] -- C:\Program Files\ATI Technologies
[2010/04/08 22:50:11 | 000,000,000 | ---D | M] -- C:\Program Files\Bonjour
[2011/04/14 12:55:02 | 000,000,000 | ---D | M] -- C:\Program Files\Combined Community Codec Pack
[2011/05/11 23:38:55 | 000,000,000 | ---D | M] -- C:\Program Files\Common Files
[2011/04/05 16:13:27 | 000,000,000 | ---D | M] -- C:\Program Files\CPUID
[2010/12/17 13:32:56 | 000,000,000 | -H-D | M] -- C:\Program Files\InstallShield Installation Information
[2008/09/17 19:45:54 | 000,000,000 | ---D | M] -- C:\Program Files\Intel
[2011/04/11 22:58:53 | 000,000,000 | ---D | M] -- C:\Program Files\Internet Explorer
[2010/04/08 22:53:22 | 000,000,000 | ---D | M] -- C:\Program Files\iPod
[2011/05/12 01:11:43 | 000,000,000 | ---D | M] -- C:\Program Files\iTunes
[2011/01/22 18:11:33 | 000,000,000 | ---D | M] -- C:\Program Files\JAM Software
[2010/12/11 14:02:18 | 000,000,000 | ---D | M] -- C:\Program Files\Java
[2011/05/12 01:10:14 | 000,000,000 | ---D | M] -- C:\Program Files\jZip
[2011/05/12 13:56:57 | 000,000,000 | ---D | M] -- C:\Program Files\Malwarebytes' Anti-Malware
[2009/05/22 17:26:51 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft
[2008/09/19 20:51:46 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft ActiveSync
[2006/11/02 13:37:34 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Games
[2011/02/03 05:17:16 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Games for Windows - LIVE
[2009/02/11 09:50:23 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Office
[2011/04/14 11:38:48 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Silverlight
[2008/09/19 20:51:24 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Visual Studio
[2011/04/14 12:58:14 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Works
[2010/07/02 11:48:07 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft.NET
[2011/04/14 12:30:59 | 000,000,000 | ---D | M] -- C:\Program Files\mIRC
[2010/09/08 09:47:10 | 000,000,000 | ---D | M] -- C:\Program Files\Movie Maker
[2011/05/12 14:57:22 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox
[2006/11/02 13:37:34 | 000,000,000 | ---D | M] -- C:\Program Files\MSBuild
[2009/02/11 09:49:53 | 000,000,000 | ---D | M] -- C:\Program Files\MSECache
[2011/04/14 12:58:42 | 000,000,000 | ---D | M] -- C:\Program Files\Mumble
[2009/06/22 19:03:33 | 000,000,000 | ---D | M] -- C:\Program Files\NETGEAR
[2011/05/12 01:10:14 | 000,000,000 | ---D | M] -- C:\Program Files\ngfminbl
[2009/03/08 23:42:39 | 000,000,000 | ---D | M] -- C:\Program Files\Prime95
[2011/05/12 01:10:14 | 000,000,000 | ---D | M] -- C:\Program Files\QuickTime
[2010/04/16 13:57:06 | 000,000,000 | ---D | M] -- C:\Program Files\Razer
[2008/09/19 20:03:17 | 000,000,000 | ---D | M] -- C:\Program Files\Realtek
[2006/11/02 13:37:34 | 000,000,000 | ---D | M] -- C:\Program Files\Reference Assemblies
[2011/04/14 12:58:55 | 000,000,000 | ---D | M] -- C:\Program Files\SopCast
[2011/05/04 18:15:37 | 000,000,000 | ---D | M] -- C:\Program Files\SpeedFan
[2011/05/13 00:40:25 | 000,000,000 | ---D | M] -- C:\Program Files\Steam
[2011/04/14 13:11:34 | 000,000,000 | ---D | M] -- C:\Program Files\TeamSpeak 3 Client
[2009/05/25 23:01:37 | 000,000,000 | ---D | M] -- C:\Program Files\TeamViewer
[2009/08/05 00:50:06 | 000,000,000 | ---D | M] -- C:\Program Files\Trend Micro
[2011/04/14 13:11:41 | 000,000,000 | ---D | M] -- C:\Program Files\TVUPlayer
[2006/11/02 14:01:55 | 000,000,000 | -H-D | M] -- C:\Program Files\Uninstall Information
[2011/04/11 22:59:48 | 000,000,000 | ---D | M] -- C:\Program Files\uTorrent
[2010/04/25 03:15:51 | 000,000,000 | ---D | M] -- C:\Program Files\Veetle
[2011/04/14 12:30:58 | 000,000,000 | ---D | M] -- C:\Program Files\Ventrilo
[2008/09/17 19:30:54 | 000,000,000 | ---D | M] -- C:\Program Files\VideoLAN
[2009/04/20 16:13:28 | 000,000,000 | ---D | M] -- C:\Program Files\Viewpoint
[2008/01/21 03:35:18 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Calendar
[2008/01/21 03:35:15 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Collaboration
[2008/01/21 03:35:09 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Defender
[2008/01/21 03:35:14 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Journal
[2009/05/22 17:26:21 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Live
[2009/05/22 17:26:36 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Live SkyDrive
[2011/04/11 22:58:54 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Mail
[2010/10/12 22:52:39 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Media Player
[2006/11/02 13:37:34 | 000,000,000 | ---D | M] -- C:\Program Files\Windows NT
[2008/01/21 03:35:14 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Photo Gallery
[2008/01/21 03:35:17 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Sidebar
< %appdata%\*.* >
[2009/03/02 18:48:36 | 000,076,407 | ---- | M] () -- C:\Users\Andrew\AppData\Roaming\Smiley.ico
< MD5 for: AGP440.SYS >
[2008/01/21 03:23:01 | 000,056,376 | ---- | M] (Microsoft Corporation) MD5=13F9E33747E6B41A3FF305C37DB0D360 -- C:\Windows\ERDNT\cache\AGP440.sys
[2008/01/21 03:23:01 | 000,056,376 | ---- | M] (Microsoft Corporation) MD5=13F9E33747E6B41A3FF305C37DB0D360 -- C:\Windows\System32\drivers\AGP440.sys
[2008/01/21 03:23:01 | 000,056,376 | ---- | M] (Microsoft Corporation) MD5=13F9E33747E6B41A3FF305C37DB0D360 -- C:\Windows\System32\DriverStore\FileRepository\machine.inf_f750e484\AGP440.sys
[2008/01/21 03:23:01 | 000,056,376 | ---- | M] (Microsoft Corporation) MD5=13F9E33747E6B41A3FF305C37DB0D360 -- C:\Windows\winsxs\x86_machine.inf_31bf3856ad364e35_6.0.6001.18000_none_ba12ed3bbeb0d97a\AGP440.sys
[2008/01/21 03:23:01 | 000,056,376 | ---- | M] (Microsoft Corporation) MD5=13F9E33747E6B41A3FF305C37DB0D360 -- C:\Windows\winsxs\x86_machine.inf_31bf3856ad364e35_6.0.6002.18005_none_bbfe6647bbd2a4c6\AGP440.sys
[2006/11/02 10:49:52 | 000,053,864 | ---- | M] (Microsoft Corporation) MD5=EF23439CDD587F64C2C1B8825CEAD7D8 -- C:\Windows\System32\DriverStore\FileRepository\machine.inf_920a2c1f\AGP440.sys
< MD5 for: ATAPI.SYS >
[2009/04/11 07:32:26 | 000,019,944 | ---- | M] (Microsoft Corporation) MD5=1F05B78AB91C9075565A9D8A4B880BC4 -- C:\Windows\SoftwareDistribution\Download\cd2b15b1a90e884578188440a1660b12\x86_mshdc.inf_31bf3856ad364e35_6.0.6002.18005_none_df23a1261eab99e8\atapi.sys
[2008/01/21 03:23:00 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=2D9C903DC76A66813D350A562DE40ED9 -- C:\Windows\ERDNT\cache\atapi.sys
[2008/01/21 03:23:00 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=2D9C903DC76A66813D350A562DE40ED9 -- C:\Windows\System32\drivers\atapi.sys
[2008/01/21 03:23:00 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=2D9C903DC76A66813D350A562DE40ED9 -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_cc18792d\atapi.sys
[2008/01/21 03:23:00 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=2D9C903DC76A66813D350A562DE40ED9 -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.0.6001.18000_none_dd38281a2189ce9c\atapi.sys
[2006/11/02 10:49:36 | 000,019,048 | ---- | M] (Microsoft Corporation) MD5=4F4FCB8B6EA06784FB6D475B7EC7300F -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_c6c2e699\atapi.sys
< MD5 for: CNGAUDIT.DLL >
[2006/11/02 10:46:03 | 000,011,776 | ---- | M] (Microsoft Corporation) MD5=7F15B4953378C8B5161D65C26D5FED4D -- C:\Windows\ERDNT\cache\cngaudit.dll
[2006/11/02 10:46:03 | 000,011,776 | ---- | M] (Microsoft Corporation) MD5=7F15B4953378C8B5161D65C26D5FED4D -- C:\Windows\System32\cngaudit.dll
[2006/11/02 10:46:03 | 000,011,776 | ---- | M] (Microsoft Corporation) MD5=7F15B4953378C8B5161D65C26D5FED4D -- C:\Windows\winsxs\x86_microsoft-windows-cngaudit-dll_31bf3856ad364e35_6.0.6000.16386_none_e62d292932a96ce6\cngaudit.dll
< MD5 for: DISK.SYS >
[2009/04/11 07:32:31 | 000,053,736 | ---- | M] (Microsoft Corporation) MD5=5D4AEFC3386920236A548271F8F1AF6A -- C:\Windows\SoftwareDistribution\Download\cd2b15b1a90e884578188440a1660b12\x86_disk.inf_31bf3856ad364e35_6.0.6002.18005_none_fbb1faf0714e4ea6\disk.sys
[2008/01/21 03:23:20 | 000,055,352 | ---- | M] (Microsoft Corporation) MD5=64109E623ABD6955C8FB110B592E68B7 -- C:\Windows\System32\drivers\disk.sys
[2008/01/21 03:23:20 | 000,055,352 | ---- | M] (Microsoft Corporation) MD5=64109E623ABD6955C8FB110B592E68B7 -- C:\Windows\System32\DriverStore\FileRepository\disk.inf_90722180\disk.sys
[2008/01/21 03:23:20 | 000,055,352 | ---- | M] (Microsoft Corporation) MD5=64109E623ABD6955C8FB110B592E68B7 -- C:\Windows\winsxs\x86_disk.inf_31bf3856ad364e35_6.0.6001.18000_none_f9c681e4742c835a\disk.sys
[2006/11/02 10:49:51 | 000,052,840 | ---- | M] (Microsoft Corporation) MD5=841AF4C4D41D3E3B2F244E976B0F7963 -- C:\Windows\System32\DriverStore\FileRepository\disk.inf_e0b0b355\disk.sys
< MD5 for: IASTORV.SYS >
[2008/01/21 03:23:23 | 000,235,064 | ---- | M] (Intel Corporation) MD5=54155EA1B0DF185878E0FC9EC3AC3A14 -- C:\Windows\System32\drivers\iaStorV.sys
[2008/01/21 03:23:23 | 000,235,064 | ---- | M] (Intel Corporation) MD5=54155EA1B0DF185878E0FC9EC3AC3A14 -- C:\Windows\System32\DriverStore\FileRepository\iastorv.inf_c9df7691\iaStorV.sys
[2008/01/21 03:23:23 | 000,235,064 | ---- | M] (Intel Corporation) MD5=54155EA1B0DF185878E0FC9EC3AC3A14 -- C:\Windows\winsxs\x86_iastorv.inf_31bf3856ad364e35_6.0.6001.18000_none_af11527887c7fa8f\iaStorV.sys
[2006/11/02 10:51:25 | 000,232,040 | ---- | M] (Intel Corporation) MD5=C957BF4B5D80B46C5017BF0101E6C906 -- C:\Windows\System32\DriverStore\FileRepository\iastorv.inf_37cdafa4\iaStorV.sys
< MD5 for: NETLOGON.DLL >
[2009/04/11 07:28:23 | 000,592,896 | ---- | M] (Microsoft Corporation) MD5=95DAECF0FB120A7B5DA679CC54E37DDE -- C:\Windows\SoftwareDistribution\Download\cd2b15b1a90e884578188440a1660b12\x86_microsoft-windows-security-netlogon_31bf3856ad364e35_6.0.6002.18005_none_ffa3304f351bb3a3\netlogon.dll
[2008/01/21 03:24:05 | 000,592,384 | ---- | M] (Microsoft Corporation) MD5=A8EFC0B6E75B789F7FD3BA5025D4E37F -- C:\Windows\ERDNT\cache\netlogon.dll
[2008/01/21 03:24:05 | 000,592,384 | ---- | M] (Microsoft Corporation) MD5=A8EFC0B6E75B789F7FD3BA5025D4E37F -- C:\Windows\System32\netlogon.dll
[2008/01/21 03:24:05 | 000,592,384 | ---- | M] (Microsoft Corporation) MD5=A8EFC0B6E75B789F7FD3BA5025D4E37F -- C:\Windows\winsxs\x86_microsoft-windows-security-netlogon_31bf3856ad364e35_6.0.6001.18000_none_fdb7b74337f9e857\netlogon.dll
< MD5 for: NVSTOR.SYS >
[2006/11/02 10:50:13 | 000,040,040 | ---- | M] (NVIDIA Corporation) MD5=9E0BA19A28C498A6D323D065DB76DFFC -- C:\Windows\System32\DriverStore\FileRepository\nvraid.inf_733654ff\nvstor.sys
[2008/01/21 03:23:21 | 000,045,112 | ---- | M] (NVIDIA Corporation) MD5=ABED0C09758D1D97DB0042DBB2688177 -- C:\Windows\System32\drivers\nvstor.sys
[2008/01/21 03:23:21 | 000,045,112 | ---- | M] (NVIDIA Corporation) MD5=ABED0C09758D1D97DB0042DBB2688177 -- C:\Windows\System32\DriverStore\FileRepository\nvraid.inf_31c3d71d\nvstor.sys
[2008/01/21 03:23:21 | 000,045,112 | ---- | M] (NVIDIA Corporation) MD5=ABED0C09758D1D97DB0042DBB2688177 -- C:\Windows\winsxs\x86_nvraid.inf_31bf3856ad364e35_6.0.6001.18000_none_39dac327befea467\nvstor.sys
< MD5 for: SCECLI.DLL >
[2008/01/21 03:24:50 | 000,177,152 | ---- | M] (Microsoft Corporation) MD5=28B84EB538F7E8A0FE8B9299D591E0B9 -- C:\Windows\ERDNT\cache\scecli.dll
[2008/01/21 03:24:50 | 000,177,152 | ---- | M] (Microsoft Corporation) MD5=28B84EB538F7E8A0FE8B9299D591E0B9 -- C:\Windows\System32\scecli.dll
[2008/01/21 03:24:50 | 000,177,152 | ---- | M] (Microsoft Corporation) MD5=28B84EB538F7E8A0FE8B9299D591E0B9 -- C:\Windows\winsxs\x86_microsoft-windows-s..urationengineclient_31bf3856ad364e35_6.0.6001.18000_none_380de25bd91b6f12\scecli.dll
[2009/04/11 07:28:24 | 000,177,152 | ---- | M] (Microsoft Corporation) MD5=8FC182167381E9915651267044105EE1 -- C:\Windows\SoftwareDistribution\Download\cd2b15b1a90e884578188440a1660b12\x86_microsoft-windows-s..urationengineclient_31bf3856ad364e35_6.0.6002.18005_none_39f95b67d63d3a5e\scecli.dll
< MD5 for: USBSTOR.SYS >
[2008/01/21 03:23:24 | 000,055,296 | ---- | M] (Microsoft Corporation) MD5=87BA6B83C5D19B69160968D07D6E2982 -- C:\Windows\System32\drivers\USBSTOR.SYS
[2008/01/21 03:23:24 | 000,055,296 | ---- | M] (Microsoft Corporation) MD5=87BA6B83C5D19B69160968D07D6E2982 -- C:\Windows\System32\DriverStore\FileRepository\usbstor.inf_b9f18584\USBSTOR.SYS
[2008/01/21 03:23:24 | 000,055,296 | ---- | M] (Microsoft Corporation) MD5=87BA6B83C5D19B69160968D07D6E2982 -- C:\Windows\winsxs\x86_usbstor.inf_31bf3856ad364e35_6.0.6001.18000_none_48864eb697d31b43\USBSTOR.SYS
[2009/04/11 05:42:55 | 000,065,536 | ---- | M] (Microsoft Corporation) MD5=BE3DA31C191BC222D9AD503C5224F2AD -- C:\Windows\SoftwareDistribution\Download\cd2b15b1a90e884578188440a1660b12\x86_usbstor.inf_31bf3856ad364e35_6.0.6002.18005_none_4a71c7c294f4e68f\USBSTOR.SYS
[2006/11/02 09:55:05 | 000,054,784 | ---- | M] (Microsoft Corporation) MD5=FDBAABF07244C60B0F4E0A6E71A107C6 -- C:\Windows\System32\DriverStore\FileRepository\usbstor.inf_bb2778a0\USBSTOR.SYS
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install\\LastSuccessTime: 2011-04-13 18:33:48
bertington
Posts Posts : 32
Post by Sneakyone on 13th May 2011, 3:49 am
Please run OTL.exe.
    :OTL
    :reg
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]
    "Userinit"="C:\Windows\System32\userinit.exe,"
    :commands
    [emptytemp]
    [resethosts]
  • Close OTL.exe
Sneakyone
Posts Posts : 2707
Post by bertington on 13th May 2011, 4:13 pm
Thanks again for the response!
combodix.txt (which seems to be identical to the log that popped up after the scan finished:
ComboFix 11-05-11.01 - Andrew 13/05/2011 17:00:23.2.2 - x86
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.44.1033.18.3582.2654 [GMT 1:00]
Running from: c:\users\Andrew\Desktop\commy.exe
SP: Windows Defender *Disabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
c:\windows\system32\arp.exe
((((((((((((((((((((((((( Files Created from 2011-04-13 to 2011-05-13 )))))))))))))))))))))))))))))))
2011-05-13 16:04 . 2011-05-13 16:04 -------- d-----w- c:\users\Andrew\AppData\Local\temp
2011-05-13 16:04 . 2011-05-13 16:04 -------- d-----w- c:\users\Default\AppData\Local\temp
2011-05-13 15:14 . 2011-05-13 15:14 -------- d-----w- C:\_OTL
2011-05-12 13:08 . 2011-05-12 13:08 -------- d-----w- c:\programdata\Norton
2011-05-12 13:08 . 2011-05-12 13:12 -------- d-----w- c:\users\Andrew\AppData\Local\NPE
2011-05-12 12:49 . 2011-05-12 12:49 -------- d-----w- c:\windows\system32\EventProviders
2011-05-11 23:00 . 2011-05-12 12:56 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2011-04-16 16:36 . 2011-04-16 16:36 -------- d-----w- c:\users\Andrew\AppData\Local\PackageAware
2011-04-14 14:01 . 2011-04-14 14:01 -------- d-----w- c:\program files\Common Files\Adobe
2011-04-14 13:43 . 2011-04-14 13:43 -------- d-----w- c:\program files\Common Files\Java
2011-04-14 11:31 . 2011-04-14 11:31 -------- d-----w- c:\users\Andrew\AppData\Local\ESET
2011-04-14 00:06 . 2011-04-14 00:06 388096 ----a-r- c:\users\Andrew\AppData\Roaming\Microsoft\Installer\{45A66726-69BC-466B-A7A4-12FCBA4883D7}\HiJackThis.exe
2011-04-14 13:43 . 2010-12-11 13:02 472808 ----a-w- c:\windows\system32\deployJava1.dll
2011-03-15 04:05 . 2011-04-02 01:21 6792528 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{B2A3BC4F-447A-4CB4-991A-C0BC7371BBE5}\mpengine.dll
"Sidebar"="c:\program files\Windows Sidebar\sidebar.exe" [2008-01-21 1233920]
"Steam"="c:\program files\Steam\steam.exe" [2010-11-17 1242448]
"uTorrent"="c:\program files\uTorrent\uTorrent.exe" [2011-04-03 399736]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2008-01-21 202240]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2010-03-17 421888]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2010-03-26 142120]
"Krait"="c:\program files\Razer\Krait\razerhid.exe" [2007-02-16 307555]
"ATICustomerCare"="c:\program files\ATI\ATICustomerCare\ATICustomerCare.exe" [2010-03-04 311296]
"StartCCC"="c:\program files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" [2010-08-25 98304]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-10-29 249064]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 10.0\Reader\Reader_sl.exe" [2011-01-30 35736]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-11-10 932288]
NETGEAR WG311v3 Smart Wizard.lnk - c:\program files\NETGEAR\WG311v3\WG311v3.exe [2005-8-31 1691648]
"EnableLUA"= 0 (0x0)
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Svc\S-1-5-21-3680316882-2675168402-2279185747-1000]
"EnableNotificationsRef"=dword:00000001
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe [2010-03-18 753504]
S2 AMD External Events Utility;AMD External Events Utility;c:\windows\system32\atiesrxx.exe [2010-08-26 176128]
S2 cpuz135;cpuz135;c:\windows\system32\drivers\cpuz135_x32.sys [2011-01-19 22504]
S2 TeamViewer4;TeamViewer 4;c:\program files\TeamViewer\Version4\TeamViewer_Service.exe [2009-05-18 185640]
S2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [2007-01-04 24652]
S3 amdkmdag;amdkmdag;c:\windows\system32\DRIVERS\atikmdag.sys [2010-08-26 6380032]
S3 amdkmdap;amdkmdap;c:\windows\system32\DRIVERS\atikmpag.sys [2010-08-26 221696]
S3 AtiHDAudioService;ATI Function Driver for HD Audio Service;c:\windows\system32\drivers\AtihdLH3.sys [2010-07-15 99344]
S3 krait03;Razer krait USB Filter Driver;c:\windows\system32\Drivers\krait.sys [2005-12-07 13324]
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} - [You must be registered and logged in to see this link.]
FF - ProfilePath - c:\users\Andrew\AppData\Roaming\Mozilla\Firefox\Profiles\u5d9z055.default\
FF - prefs.js: browser.search.selectedEngine - Dictionary.com
FF - Ext: Default: {972ce4c6-7e08-4474-a285-3208198ce6fd} - c:\program files\Mozilla Firefox\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
FF - Ext: Java Console: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA} - c:\program files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
FF - Ext: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension
FF - Ext: TVU Web Player: [You must be registered and logged in to see this link.] - %profile%\extensions\firefox@tvunetworks.com
FF - user.js: network.cookie.cookieBehavior - 0
FF - user.js: privacy.clearOnShutdown.cookies - false
FF - user.js: security.warn_viewing_mixed - false
FF - user.js: security.warn_viewing_mixed.show_once - false
FF - user.js: security.warn_submit_insecure - false
FF - user.js: security.warn_submit_insecure.show_once - false
Rootkit scan 2011-05-13 17:04
Windows 6.0.6001 Service Pack 1 NTFS
Completion time: 2011-05-13 17:05:16
ComboFix-quarantined-files.txt 2011-05-13 16:05
ComboFix2.txt 2011-05-11 22:42
Pre-Run: 28,475,281,408 bytes free
Post-Run: 28,443,373,568 bytes free
- - End Of File - - 62A4269AF664008FF6DE47DCF7D5F893
bertington
Posts Posts : 32
Joined Joined : 2011-04-14
OS OS : vista 32 bit
Points Points : 21094
Re: Norton power eraser problem
Post by Sneakyone on 13th May 2011, 8:16 pm
Are you getting help from here as well? [You must be registered and logged in to see this link.]
I ask that you keep it limited to this thread while we are working.
  • Click Start
  • Click Start
Sneakyone
Posts Posts : 2707
Joined Joined : 2010-01-10
Points Points : 56104
Post by bertington on 14th May 2011, 7:14 pm
WOW!!! Ok after doing that last combifix scan (I think that's the second, but mayb the third), the virus apparently decided to strike back by blocking me from this site!? How the hell did it know to do that!? It also blocked any website with the word microsoft in it, along with any bleepingcomputer.com URLs..... wow.
I eventually got some help from here - [You must be registered and logged in to see this link.]
Which has at least now let me get back on this thread.
Thanks for the help, I didn't just go MIA. The thread you linked to is this one I think, but I was asking for help in reformatting my pc in another thread, but I'm just trying to fix it atm, this is the only thread I'm using I promise!!
bertington
Posts Posts : 32
Post by bertington on 14th May 2011, 8:19 pm
OK the scan's completed, I asked it to delete the files it could. Some of them it couldn't delete...
Log file:
# version=7
# iexplore.exe=7.00.6000.16386 (vista_rtm.061101-2205)
# OnlineScanner.ocx=1.0.0.6427
# api_version=3.0.2
# EOSSerial=228e7675fd34bc45a5225d5d6521a790
# end=finished
# remove_checked=true
# archives_checked=true
# unwanted_checked=true
# unsafe_checked=true
# antistealth_checked=true
# utc_time=2011-05-14 08:12:37
# local_time=2011-05-14 09:12:37 (+0000, GMT Daylight Time)
# country="United Kingdom"
# lang=1033
# osver=6.0.6001 NT Service Pack 1
# compatibility_mode=512 16777215 100 0 55970960 55970960 0 0
# compatibility_mode=5892 16776574 66 100 3693478 142933494 0 0
# compatibility_mode=8192 67108863 100 0 129 129 0 0
# scanned=178933
# found=350
# cleaned=336
# scan_time=3191
C:\Program Files\Adobe\Reader 10.0\ReadMe.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Adobe\Reader 10.0\Reader\ccme_base.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Adobe\Reader 10.0\Reader\cryptocme2.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Adobe\Reader 10.0\Reader\Legal\ENU\license.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\de\welcome_generic.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\de\welcome_generic_small.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\en-US\welcome_generic.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\en-US\welcome_generic_small.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\es\welcome_generic.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\es\welcome_generic_small.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\fr\welcome_generic.html Win32/Ramnit.A virus (unable to clean) 00000000000000000000000000000000 I
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\fr\welcome_generic_small.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\pt-BR\welcome_generic.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Branding\Welcome\pt-BR\welcome_generic_small.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_en-US_FMV.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_en-US_generic.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_en-US_MR9600_MOB.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_en-US_MR9700_MOB.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_en-US_R9600_DSK.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_en-US_R9700_DSK.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_en-US_R9800_DSK.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_en-US_RX800_DSK.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_FMV.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_FMV_small.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_generic.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcome_generic_small.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\Welcome\en-US\welcom_en-US_cycle.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\Apple\Apple Application Support\WebKit.resources\inspector\inspector.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Bears.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Garden.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Green Bubbles.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Hand Prints.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Orange Circles.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Peacock.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Roses.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Shades of Blue.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Soft Blue.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Common Files\microsoft shared\Stationery\Stars.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\iTunes\iTunesHelpermgr.exe Win32/Ramnit.A virus (unable to clean) 00000000000000000000000000000000 I
C:\Program Files\iTunes\iTunesmgr.exe Win32/Ramnit.A virus (unable to clean) 00000000000000000000000000000000 I
C:\Program Files\Java\jre6\Welcome.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Java\jre6\bin\dt_socket.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Java\jre6\bin\ioser12.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Java\jre6\bin\java_crw_demo.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_cs-cz.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_de-de.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_en-us.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_es-es.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_fr-fr.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_it-it.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_ja-jp.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_ko-kr.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_nb-no.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_nl-nl.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_pl-pl.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_pt-br.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Help_ru-ru.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_cs-cz.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_de-de.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_en-us.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_es-es.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_fr-fr.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_it-it.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_ja-jp.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_ko-kr.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_nb-no.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_nl-nl.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_pl-pl.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_pt-br.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Games for Windows - LIVE\Client\Help\Http_error_ru-ru.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\INTLBAND.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\ACREADME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\INDEX.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\INREADME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\OFREADME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\OLREADME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\PBREADME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\PPREADME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\PVREADME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\TOUR.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\WDREADME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\1033\XLREADME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\AccessWeb\CLNTWRAP.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\HTML\context.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\SAMPLES\Analyze Sales.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\SAMPLES\Employees.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\SAMPLES\Review Orders.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\SAMPLES\Review Products.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\SAMPLES\Sales.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\VS Runtime\1033\EMPTY.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\OFFICE11\VS Runtime\1033\HelpWatermark.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\CURRENCY.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\DADSHIRT.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\JUDGESCH.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\JUNGLE.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\NOTEBOOK.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\OFFISUPP.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\PAWPRINT.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\PINELUMB.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\SEAMARBL.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Stationery\1033\TECHTOOL.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Microsoft Office\Templates\MseNewFileItems\HTMLPAGE.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Mozilla Firefox\defaults\profile\bookmarks.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Mozilla Firefox\res\hiddenWindow.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\MSECache\O2007Cnv\1033\README.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\ngfminbl\vmwysnkc.exe Win32/Ramnit.A virus (unable to clean) 00000000000000000000000000000000 I
C:\Program Files\QuickTime\QuickTime Read Me.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\QuickTime\QTSystem\QTCF.dll Win32/Ramnit.H virus (error while cleaning) 00000000000000000000000000000000 I
C:\Program Files\Razer\Krait\razerhid.exe Win32/Ramnit.H virus (error while cleaning) 00000000000000000000000000000000 I
C:\Program Files\Razer\Krait\razerhidmgr.exe Win32/Ramnit.A virus (unable to clean) 00000000000000000000000000000000 I
C:\Program Files\Razer\Krait\razerlan.dll Win32/Ramnit.H virus (error while cleaning) 00000000000000000000000000000000 I
C:\Program Files\Razer\Krait\razerofa.exe Win32/Ramnit.H virus (error while cleaning) 00000000000000000000000000000000 I
C:\Program Files\Razer\Krait\razerofamgr.exe Win32/Ramnit.A virus (unable to clean) 00000000000000000000000000000000 I
C:\Program Files\Razer\Krait\razertra.exe Win32/Ramnit.H virus (error while cleaning) 00000000000000000000000000000000 I
C:\Program Files\Razer\Krait\razertramgr.exe Win32/Ramnit.A virus (unable to clean) 00000000000000000000000000000000 I
C:\Program Files\SopCast\adv\clips\18CA426D-7B6D-2F41-FCE2-93B1157CCB67\index.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\53FAEDB4-9206-0A0A-6185-3FE87F746365\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\54AA7341-FB3F-2750-C038-4906A1C923AA\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\59D3CDB3-5B26-2EB4-729D-EF4CAB22F95B\index.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\68D83996-BEB7-2C08-454B-50F66D75CD0E\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\72B2951C-64B6-BE0D-0E10-4FE8371CD0A0\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\75850311-B208-6DC9-EB63-A59D46BDBBC1\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\82AED070-D3C5-4B8B-E80D-FB1AAF91015E\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\854A1DBA-8EBC-1EBB-775F-C7DCFCBE92CA\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\8A4395D3-0F56-143C-09D4-FB9E584AEA60\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\A1757DB2-F068-EB6A-4228-3A9EA3519CCB\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\D957E741-3FB1-FCFE-9524-CCF1EB1DA723\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\EB0865ED-04AC-EF36-424C-D42922944F94\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\clips\EE067279-16A4-84A3-33F8-B273AB5A44F2\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\default\home.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\SopCast\adv\default\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\Public\Account.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\Public\ssa_english.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\Public\ssa_french.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\Public\ssa_german.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\Public\ssa_italian.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\Public\ssa_russian.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\Public\ssa_spanish.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\day of defeat\DEMOPLAYER.DLL Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\day of defeat\voice_miles.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\day of defeat\voice_speex.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\day of defeat\platform\servers\serverbrowser.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\day of defeat\platform\Steam\cached\offline_english.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\day of defeat source\dod\resource\maphtml\dod_colmar_english.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\day of defeat source\dod\resource\maphtml\dod_jagd_english.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\day of defeat source\dod\resource\maphtml\dod_palermo_english.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\half-life\DemoPlayer.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\half-life\voice_miles.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\half-life\voice_speex.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\half-life\ns\fmod.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\half-life\ns\cl_dlls\client.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\half-life\ns\dlls\ns.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\half-life\platform\servers\serverbrowser.dll Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Steam\steamapps\horn_\half-life\platform\Steam\cached\OFFLINE_ENGLISH.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\BINDS.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\CHANNEL.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\DEVICE-LOGITECH-G15.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\DEVICE-LOGITECH-G19.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\DEVICE-LOGITECH-G35.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\DEVICE-OVERLAY.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\GRPTRGCMD.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\GRPTRGEDITOR.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\grptrgvoice.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\main.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\RANK.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\RECORD.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\server.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\SETUP.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\setupbinds.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\SETUPEVENTS.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\setupglobal.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\SETUPMISC.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\SETUPNETWORK.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\SETUPOVERLAY.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\setupspeech.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\setupvoice.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\setupvoicetraining.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\sfx.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\srvprop.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\user.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\usereditor-admin.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\usereditor-chanadmin.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\usereditor-chanauth.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\usereditor-display.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\usereditor-info.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\usereditor-network.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\USEREDITOR-TRANSMIT.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\USEREDITOR.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\Ventrilo\Doc\USEROPTIONS.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\http\FLASH.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\http\INDEX.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\http\MOSAIC.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\http\VLM.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\http\VLM_EXPORT.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\lua\http\FLASH.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\lua\http\INDEX.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\lua\http\MOSAIC.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\lua\http\VLM.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Program Files\VideoLAN\VLC\lua\http\VLM_EXPORT.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\acccore\plugins\{64613142-4B62-7879-6563-337541545364}\INVITE.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\acccore\plugins\{64613142-4B62-7879-6563-337541545364}\MULTIPLAYER.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\acccore\plugins\{64613142-4B62-7879-6563-337541545364}\PLUGIN.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\acccore\plugins\{64613142-4B62-7879-6563-337541545364}\SINGLEPLAYER.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\acccore\plugins\{64653137-6737-6936-486A-3566764D7375}\PLUGIN.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\acccore\plugins\{64653150-6D73-7770-5F76-636F6D57765A}\PLUGIN.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\acccore\plugins\{64653157-664A-4542-6A4C-6A39334B3934}\PLUGIN.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\local\SEARCH.HTML Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\plugins\STATUS.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\rss\RSS.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\ABOUT.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\ADDBUDDYBUTTON.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\ADDCUSTOMBUTTON.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\BUTTONS_FRAME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\CLEARPRINTS_CONFIRM.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\DEFAULTSEARCH.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\DROPCUSTOMBUTTON.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\FIRSTTIMEPAGE.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\FOOTPRINTS_FRAME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\LATEST.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\OLDERVERSION.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\OPTIONS_FRAME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\POPUPS_FRAME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\PREFERENCES.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\RENAMECUSTOMBUTTON.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\RESETTOOLBAR.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AIM Toolbar\ieToolbar\resources\en-US\ui\SEARCH_FRAME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\AIMANI.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\AREYOUSURE.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\CANCELEDINSTALL.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\CANCELINGINSTALL.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\CLOSERUNNING.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\CONGRATS1.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\CONGRATS2.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\CONGRATS3.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\CONGRATS4.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\ERROR_FAILEDDISKSPACECHECK.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\EULA.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\EXISTNEWERVERSION.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\INSTALLINGPROGRESS.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\LEGAL.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\LEGALAGREEMENT.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\NOQUALIFY.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\NOTHINGTODO.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\PREPARING.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\PRIVACY.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\PRIVACYPOLICY.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\PRODUCTDETECTED.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\QQERR.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\REBOOTPENDING.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\TOS.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\TUNESERR.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4426\html\WARNING.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4469\html\AIMANI.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4469\html\EULA.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4469\html\LEGAL.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4469\html\PRIVACY.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL Downloads\SUD4469\html\TOS.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL OCP\AIM\Storage\All Users\SUDS_BBC2683C\CACHE\4469.2.4\AIMANI.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL OCP\AIM\Storage\All Users\SUDS_BBC2683C\CACHE\4469.2.4\EULA.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL OCP\AIM\Storage\All Users\SUDS_BBC2683C\CACHE\4469.2.4\LEGAL.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL OCP\AIM\Storage\All Users\SUDS_BBC2683C\CACHE\4469.2.4\PRIVACY.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\AOL OCP\AIM\Storage\All Users\SUDS_BBC2683C\CACHE\4469.2.4\TOS.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\ProgramData\Skype\Plugins\Plugins\F57B48ADF2224F088EDD1A2B9BAD84E8\PICKGAME.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Bears.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Garden.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Green Bubbles.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Hand Prints.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Orange Circles.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Peacock.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Roses.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Shades of Blue.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Soft Blue.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\Microsoft\Windows Mail\Stationery\Stars.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\temp\RarSFX0\nircmd.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\temp\RarSFX0\nircmdc.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\temp\RarSFX0\pev.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\temp\RarSFX0\swreg.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\temp\RarSFX0\userinit.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\temp\RarSFX0\winlogon.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\temp\RarSFX0\nird\iexplore.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\temp\RarSFX0\procs\explorer.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\temp\RarSFX0\procs\iexplore.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\VirtualStore\Program Files\SopCast\adv\clips\854A1DBA-8EBC-1EBB-775F-C7DCFCBE92CA\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Local\VirtualStore\Program Files\SopCast\adv\clips\A1757DB2-F068-EB6A-4228-3A9EA3519CCB\index.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\CasinoOnNet\Login\media\ChatPage\ChangePass_default.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\CasinoOnNet\Login\media\ChatPage\default.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\CasinoOnNet\Login\media\ChatPage\responseLiveLauncher.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\CasinoOnNet\Login\media\ChatPage\responseLiveScriptletLauncher.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\CasinoOnNet\Login\media\ChatPage\responseLiveStartApp.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\vmwysnkc.exe Win32/Ramnit.A virus (unable to clean) 00000000000000000000000000000000 I
C:\Users\Andrew\AppData\Roaming\Mozilla\Firefox\Profiles\u5d9z055.default\bookmarks.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\PacificPoker\casinopoker\Login\media\ChatPage\default.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\PacificPoker\casinopoker\Login\media\ChatPage\responseLiveLauncher.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\PacificPoker\casinopoker\Login\media\ChatPage\responseLiveScriptletLauncher.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\PacificPoker\casinopoker\Login\media\ChatPage\responseLiveStartApp.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\aHpFb2JpNVlic2JHOE1lYmNkUFZ3d255dFBFPQ==\channel.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\aHpFb2JpNVlic2JHOE1lYmNkUFZ3d255dFBFPQ==\server.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\d2NqTmFZUmNMVG1kUHZoV0lXOFo2d2xXR0pvPQ==\channel.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\MFpmMnEreFBaTU1wejNnbGxxcHYwR3JiNFZNPQ==\channel.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\MFpmMnEreFBaTU1wejNnbGxxcHYwR3JiNFZNPQ==\server.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\Q3hPTHc2ZXYrTXVuMEJtNSsxTi9ySkR3S3RJPQ==\channel.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\TVFBTlV6SlUxQmRONTJzdldqT0owcXI3T0xNPQ==\channel.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\TVFBTlV6SlUxQmRONTJzdldqT0owcXI3T0xNPQ==\server.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\UFgyL3JDZGp3ZmVDWjRYMkRFMEhHN3JDOE8wPQ==\channel.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\UFgyL3JDZGp3ZmVDWjRYMkRFMEhHN3JDOE8wPQ==\server.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\UGVwRmxvZHMvVmNxSTN2N0hzRFdROUdIWDNBPQ==\channel.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\UGVwRmxvZHMvVmNxSTN2N0hzRFdROUdIWDNBPQ==\server.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\AppData\Roaming\TS3Client\chats\WktkL0pSSnRlZmgzOE91TGc3NU9lSldQYTdFPQ==\channel.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\1031.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\106.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\2100.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\2445.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\2446.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\2523.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\2579.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\299.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\405.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\4081.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\663.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\create.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\frostwire-4.21.1.windows(2).exe Win32/OpenCandy application (deleted - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\frostwire-4.21.1.windows.exe Win32/OpenCandy application (deleted - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\historical.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\ms5332.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\News.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\OTL.exe Win32/Ramnit.H virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\The Something Awful Forums(2).htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\The Something Awful Forums(3).htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\The Something Awful Forums.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\cd.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\config.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\connect.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\CONTACT.HTM Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\errmess.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\errors.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\install.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\modem.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\modem2.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\modem3.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\network.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\network2.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\other.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\pfaults.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\tapi.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\tourn.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\vendors.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\vidsound.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
C:\Users\Andrew\Downloads\EA Games\Command & Conquer The First Decade\Command & Conquer(tm) Tiberian Sun(tm)\SUN\HTML\wol.htm Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
E:\Torrents\The Flashbulb - Soundtrack To A Vacant Life (mp3)\Please_read.html Win32/Ramnit.A virus (cleaned - quarantined) 00000000000000000000000000000000 C
${Memory} Win32/Ramnit.H virus 00000000000000000000000000000000 I
bertington
Posts Posts : 32
Post by Sneakyone on 16th May 2011, 12:26 am
Yeah, just as me, Crush, and Belahzur suspected. Ramnit has infected legit files. It is best to just reformat without any executable backups at this point.
Backup any important files that are not .exe, .dll, .scr, .com, .html, .rar, .zip, etc.
Sneakyone
Posts Posts : 2707
Post by bertington on 16th May 2011, 12:55 am
Ok, thanks for your help Smile
bertington
Posts Posts : 32
Post by Sneakyone on 16th May 2011, 12:57 am
No problem, you're welcome. I wish there was a way to remove it, but almost every program on your computer is infected.
If you need any more help please let me know.
Sneakyone
Posts Posts : 2707
Post by bertington on 16th May 2011, 1:52 am
Lol, yeah I was wondering what it was doing when the HDD was making noise 24/7 for the past week or so. Thanks again, I'll bump the thread if I need anymore help!
bertington
Posts Posts : 32
Post by Sneakyone on 17th May 2011, 11:41 pm
Alrighty, sorry we are unable to clean this type of virus. If you need any help setting up a defense against it please let me know. Smile
Sneakyone
Posts Posts : 2707
