Had a virus, ran MBAM, rebooted to fix the problem and now it's worse....
Page 2 of 3 Previous  1, 2, 3  Next
Post by MBanks on Mon 09 May 2011, 2:57 pm
Windows sometimes loads now but it will the show the blue screen of death with some text which disappears to quick to read, then reboots. Sometimes it will not even reboot, the screen just turns off and on on my laptop.
When the laptop does decide to load properly I can't load up in safemode to even get the MBAM log to post here!!
Does anyone have any suggestions on what I can do? This has put me in a very bad situation!
Any help is grately appreciated.
Thanks,
Martin
MBanks
Rookie Surfer
Rookie Surfer
Operating System : Windows XP Home Edition SP3
Re: Had a virus, ran MBAM, rebooted to fix the problem and now it's worse....
Post by Gabethebabe on Mon 23 May 2011, 10:55 pm
Just go into windows xp and see what happens. Try normal mode first. Maybe we´re lucky. If not into safe mode. Forget the recovery console for the moment. We might need it later, but not yet.
Look if there is a log c:\combofix.txt and post it if it exists.
Gabethebabe
Tech Advisor
Tech Advisor
Operating System : WIN7 64bit, Ubuntu 12.04 LTS
Post by MBanks on Mon 23 May 2011, 11:04 pm
I loaded it into Safe Mode and ComboFix has immediately started running, so I'm guessing it's finishing off the scan and will the create the log. I'll let you know in a few minutes once it's hopefully completed.
MBanks
Rookie Surfer
Rookie Surfer
Post by Gabethebabe on Mon 23 May 2011, 11:42 pm
This actually looks hopeful
Gabethebabe
Tech Advisor
Tech Advisor
Post by MBanks on Tue 24 May 2011, 12:10 am
ComboFix has been running for a while, it went through a lot of stages, but has now not moved any further in quite some time (25mins +). Here is the last few messages it has come up with on the blue ComboFix screen:
Completed Stage_50
Deleting Files:
C:\Documents and Settings\All Users\Application Data\ECAP\ECap.ini
C:\Documents and Settings\All Users\Application Data\ECAP\GenePccMon.ini
C:\Documents and Settings\Intel\Application Data\Sun\rxls.dll
Deleting Folders:
C:\Documents and Settings\All User\Application Data\ECAP
C:\Documents and Settings\Intel\Windows
And that is as far it has got. Hasn't done anything in a while. Shall I leave it to run overnight? What steps should I take next?
Thanks,
Martin
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Tue 24 May 2011, 12:15 am
Ah, it looks like it's creating the log......fingers crossed!
MBanks
Rookie Surfer
Rookie Surfer
Post by Gabethebabe on Tue 24 May 2011, 12:23 am
*drumroll*
Gabethebabe
Tech Advisor
Tech Advisor
Post by MBanks on Tue 24 May 2011, 12:45 am
ComboFix log:
ComboFix 11-05-22.01 - Intel 05/23/2011 22:08:07.1.1 - x86 MINIMAL
Running from: c:\documents and settings\Intel\Desktop\ComboFix.exe
Command switches used :: c:\documents and settings\Intel\Desktop\WindowsXP-KB310994-SP2-Pro-BootDisk-ENU.exe
c:\documents and settings\All Users\Application Data\ECAP
c:\documents and settings\All Users\Application Data\ECAP\ECap.ini
c:\documents and settings\All Users\Application Data\ECAP\GenePccMon.ini
c:\documents and settings\Intel\Application Data\Sun\rxls.dll
c:\documents and settings\Intel\WINDOWS
((((((((((((((((((((((((( Files Created from 2011-04-23 to 2011-05-23 )))))))))))))))))))))))))))))))
2011-05-23 09:42 . 2011-05-23 09:42 -------- d-----w- C:\_OTL
2011-05-21 05:28 . 2011-05-21 05:28 -------- d-----w- c:\documents and settings\Administrator
2011-05-08 06:30 . 2008-04-14 12:00 221184 ----a-w- c:\windows\system32\wmpns.dll
2011-05-08 06:30 . 2011-05-08 06:30 -------- d-----w- c:\documents and settings\TEMP
2011-05-06 09:36 . 2011-05-06 09:36 -------- d-----w- c:\windows\system32\LogFiles
2011-05-06 09:26 . 2010-11-15 05:50 145504 ----a-w- c:\windows\system32\drivers\cbfs.sys
2011-05-06 09:26 . 2011-05-06 09:26 -------- d-----w- c:\program files\Common Files\Mediafour
2011-05-06 09:26 . 2011-05-06 09:26 -------- d-----w- c:\documents and settings\All Users\Application Data\Mediafour
2011-05-05 13:57 . 2011-05-06 09:26 -------- d-----w- c:\program files\Mediafour
2011-04-27 09:08 . 2011-04-27 09:08 -------- d-----w- c:\program files\7-Zip
------- Sigcheck -------
Cryptography Services Error !!
"Messenger (Yahoo!)"="c:\progra~1\Yahoo!\Messenger\YahooMessenger.exe" [2010-06-01 5252408]
"AsusTray"="c:\program files\EeePC\ACPI\AsTray.exe" [2008-09-17 106496]
"AsusACPIServer"="c:\program files\EeePC\ACPI\AsAcpiSvr.exe" [2008-09-16 593920]
"AsusEPCMonitor"="c:\program files\EeePC\ACPI\AsEPCMon.exe" [2008-05-20 94208]
"RTHDCPL"="RTHDCPL.EXE" [2008-06-13 16871936]
"SoundMan"="SOUNDMAN.EXE" [2006-07-21 86016]
"AlcWzrd"="ALCWZRD.EXE" [2006-05-04 2808832]
"U1_USB"="c:\program files\ASUS\AiGuru U1\AiGuru_U1usb.exe" [2008-04-25 200704]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2006-10-08 98304]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2006-10-08 114688]
"Persistence"="c:\windows\system32\igfxpers.exe" [2006-10-08 94208]
"ETDWare"="c:\program files\Elantech\ETDCtrl.exe" [2009-01-23 416768]
"ACU"="c:\program files\Atheros\ACU.exe" [2007-05-03 376921]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2010-09-08 421888]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2010-09-23 421160]
"autodetect"="c:\windows\system32\SupportAppXL\AutoDect.exe" [2008-08-07 91648]
"VirtualCloneDrive"="c:\program files\Elaborate Bytes\VirtualCloneDrive\VCDDaemon.exe" [2009-06-17 85160]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2011-01-31 35760]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-09-20 932288]
"Malwarebytes' Anti-Malware"="c:\program files\Malwarebytes' Anti-Malware\mbamgui.exe" [2010-12-20 443728]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-05-14 248552]
"DivXUpdate"="c:\program files\DivX\DivX Update\DivXUpdate.exe" [2011-03-21 1230704]
"{914C5BF8-EEDD-4F3A-A8BE-34EE71CF1B29}"="c:\program files\Mediafour\XPlay 3\XPlay.exe" [2010-11-15 300544]
Adobe Gamma Loader.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2010-10-7 113664]
McAfee Security Scan Plus.lnk - c:\program files\McAfee Security Scan\2.0.181\SSScheduler.exe [2010-1-15 255536]
SuperHybridEngine.lnk - c:\program files\Asus\EeePC\Super Hybrid Engine\SuperHybridEngine.exe [2010-10-2 294912]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WudfSvc]
"c:\\Program Files\\Skype\\Plugin Manager\\skypePM.exe"=
R0 MDFSYSNT;MacDrive file system driver; [x]
R0 vbjx;vbjx;c:\windows\System32\drivers\dmecpam.sys [x]
R1 CbFs;CbFs;c:\windows\system32\drivers\cbfs.sys [2010-11-15 145504]
R2 M4iPodWPDService;M4iPodWPDService;c:\program files\Common Files\Mediafour\iPod\M4iPodWPDService.exe [2010-11-15 211968]
R2 MBAMService;MBAMService;c:\program files\Malwarebytes' Anti-Malware\mbamservice.exe [2010-12-20 363344]
R3 massfilter;ZTE Mass Storage Filter Driver;c:\windows\system32\drivers\massfilter.sys [2008-08-12 7680]
R3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [2010-12-20 20952]
R3 McComponentHostService;McAfee Security Scan Component Host Service;c:\program files\McAfee Security Scan\2.0.181\McCHSvc.exe [2010-01-15 227232]
R4 Ialaervnwlrx;Ialaervnwlrx; [x]
FF - ProfilePath - c:\documents and settings\Intel\Application Data\Mozilla\Firefox\Profiles\63op53yi.default\
FF - Ext: Default: {972ce4c6-7e08-4474-a285-3208198ce6fd} - c:\program files\Mozilla Firefox\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
FF - Ext: Skype extension for Firefox: {AB2CE124-6272-4b12-94A9-7303C7397BD1} - c:\program files\Mozilla Firefox\extensions\{AB2CE124-6272-4b12-94A9-7303C7397BD1}
FF - Ext: Java Console: {CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA} - c:\program files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}
FF - Ext: Java Quick Starter: [You must be registered and logged in to see this link.] - c:\program files\Java\jre6\lib\deploy\jqs\ff
FF - Ext: DivX Plus Web Player HTML5 <video>: {23fcfd51-4958-4f00-80a3-ae97e717ed8b} - c:\program files\DivX\DivX Plus Web Player\firefox\html5video
FF - Ext: DivX HiQ: {6904342A-8307-11DF-A508-4AE2DFD72085} - c:\program files\DivX\DivX Plus Web Player\firefox\wpa
FF - Ext: Yahoo! Toolbar: {635abd67-4fe9-1b23-4f01-e679fa7484c1} - %profile%\extensions\{635abd67-4fe9-1b23-4f01-e679fa7484c1}
user_pref(security.warn_viewing_mixed,false);
user_pref(security.warn_viewing_mixed.show_once,false);
FF - user.js: network.cookie.cookieBehavior - 0
FF - user.js: privacy.clearOnShutdown.cookies - false
user_pref(security.warn_submit_insecure,false);
FF - user.js: security.warn_submit_insecure.show_once - false
ShellIconOverlayIdentifiers-MacDrive volume icons - (no file)
SafeBoot-WudfPf
SafeBoot-WudfRd
HKLM_ActiveSetup-{8CCFE231-6643-45D7-8787-3ABA666083C0} - c:\documents and settings\Intel\Application Data\Sun\rxls.dll
Rootkit scan 2011-05-23 23:14
Stealth MBR rootkit/Mebroot/Sinowal/TDL4 detector 0.4.2 by Gmer, [You must be registered and logged in to see this link.]
Windows 5.1.2600 Disk: ST980811AS rev.3.ALC -> Harddisk0\DR0 -> \Device\Ide\IdeDeviceP0T0L0-3
device: opened successfully
user: MBR read successfully
error: Read A device attached to the system is not functioning.
kernel: MBR read successfully
detected disk devices:
detected hooks:
\Driver\atapi DriverStartIo -> 0x86EF553B
user & kernel MBR OK
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe,-101"
"Enabled"=dword:00000001
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe"
@="IFlashBroker4"
"Version"="1.0"
Completion time: 2011-05-23 23:21:20
ComboFix-quarantined-files.txt 2011-05-23 13:21
Pre-Run: 6,501,830,656 bytes free
Post-Run: 6,639,632,384 bytes free
default=multi(0)disk(0)rdisk(0)partition(3)\WINDOWS
multi(0)disk(0)rdisk(0)partition(3)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
- - End Of File - - FB8FFE16F8B54C2F1A985B1D957BE88B
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Tue 24 May 2011, 8:19 pm
Any ideas on what to do next?
MBanks
Rookie Surfer
Rookie Surfer
Post by Gabethebabe on Tue 24 May 2011, 10:38 pm
can you run gmer?
Download GMER Rootkit Scanner from here and save it to your desktop.
Note that it will have a random name.
  • Double click the file to run the tool. It may take a while to load.
  • If it gives you a warning about rootkit activity and asks if you want to run a full scan, click No
  • In the right panel, you will see several boxes that have been checked
  • Make sure this is unchecked: Show All
  • Make sure only your system drive (usually C:\) is checked and uncheck all other drives you might have on your system
  • Click Scan to start the scan
  • When it has finished, click Save and save the log as gmer.txt on your desktop
  • If GMER reports any <--- ROOTKIT entries, don´t take any action. It could be a false positive.
  • Click OK to quit GMER.
  • Please post the contents of gmer.txt into your next reply.
Gabethebabe
Tech Advisor
Tech Advisor
Post by MBanks on Wed 25 May 2011, 8:40 am
I will try this when I get home from work this evening. I will have to run it in Safe Mode, I assume this is ok. Will post the log once it has completed.
Thanks.
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Wed 25 May 2011, 7:30 pm
I followed all the instructions and this is what happened....
The first time I tried to run it the program froze, closed itself.
The second time I had to leave the program running while I went and did some other things, I cam back and the computer had rebooted itself and got as far as the login/password entry stage in normal mode, i entered my password to log in, it loaded then the bluescreen and back to square one of the flashing cursor screen.
I just got home from work and started the laptop up in Safe Mode to try again and the laptop loaded up to windows, but the start bar new loaded or any items from the desktop.
Hopefully I can get it started up in Safe Mode again properly and try running the program again. Let me know if you have any other suggestions, otherwise I'll keep trying to run it until I can post the log.
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Wed 25 May 2011, 7:38 pm
P.S. The "Show All" tick box is greyed out, should that be right? You said to make sure it's not ticked.
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Wed 25 May 2011, 7:47 pm
Just tried it again, the program gets to a certain point the reboots itself with no warning.
What should I do, any ideas?
MBanks
Rookie Surfer
Rookie Surfer
Post by Gabethebabe on Thu 26 May 2011, 11:05 pm
We are going to use the Recovery Console.
  • Please reboot your computer
  • During startup, a boot menu will appear for about 2 seconds
  • Choose the option Microsoft Windows Recovery Console by hitting the down arrow key
  • You will have to enter the Administrator password when prompted.
When you are in the recovery console command prompt type the following
copy c:\windows\system32\drivers\atapi.sys c:\suspectdriver.sys
You should receive a success message. After that type exit and hit enter to reboot back into normal safe mode. Find the file c:\suspectdriver.sys and copy it to your usb drive. Go to a clean computer and submit the file for analysis to [You must be registered and logged in to see this link.]. Copy the report url back here.
  • Please create a new text file in Notepad with the following contents:
    KILLALL::
    File::
    Driver::
    vbjx
  • Save that file as CFScript.txt on your desktop
  • Drag and drop the CFScript.txt onto the ComboFix icon, as shown in the animation below.
  • If done correctly, ComboFix will start and perform specific instructions
  • In doing so, ComboFix may request a reboot
  • Please post the contents of Combofix.txt in your next reply
Gabethebabe
Tech Advisor
Tech Advisor
Post by MBanks on Sat 28 May 2011, 11:24 am
Here is the URL for the report.
I dragged and dropped the as instructed above and then Combofix ran, and it said it needed to reboot, it never started up again, and now pressing the power button does nothing at all
MBanks
Rookie Surfer
Rookie Surfer
The charging light doesn't even come on when the mains power is plugged in.
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Sat 28 May 2011, 11:28 am
Is there anyway to turn on the computer again to see if Combofix and finish and create the log for me to post?
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Sat 28 May 2011, 1:01 pm
False alarm. The power cable had been knocked from the wall and I guess it ran out of battery whilst trying to reboot or it just needed more power than it had.
I managed to start it up again in Safe Mode, Combofix automatically started running, it completed all 50 stages and has now been stuck on....
Deleting Files:
C:\Documents and Settings\Intel\Application Data\Sun\mxd1.txt
...for quite some time. I will leave it running all day and see what happens. Hopefully it will finish the scan and create the log for me to post back.
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Sat 28 May 2011, 1:40 pm
Well, it finished, and created the log, here it is:
ComboFix 11-05-22.01 - Intel 05/28/2011 11:15:51.2.1 - x86 MINIMAL
Command switches used :: c:\documents and settings\Intel\Desktop\CFScript.txt
FILE ::
"c:\windows\System32\drivers\dmecpam.sys"
c:\documents and settings\Intel\Application Data\Sun\mxd1.txt
-------\Service_vbjx
((((((((((((((((((((((((( Files Created from 2011-04-28 to 2011-05-28 )))))))))))))))))))))))))))))))
Rootkit scan 2011-05-28 12:28
detected hooks:
\Driver\atapi DriverStartIo -> 0x86F0853B
@="FlashBroker"
@="IFlashBroker4"
"Version"="1.0"
- - - - - - - > 'explorer.exe'(1968)
c:\windows\system32\msi.dll
Completion time: 2011-05-28 12:36:27 - machine was rebooted
ComboFix-quarantined-files.txt 2011-05-28 02:36
ComboFix2.txt 2011-05-23 13:21
Pre-Run: 6,631,878,656 bytes free
Post-Run: 6,567,243,776 bytes free
- - End Of File - - A5E96741630748558A9136CAD7840C76
I await further instruction. Thank you so much for all your help so far, I really appreciate it
MBanks
Rookie Surfer
Rookie Surfer
Post by Gabethebabe on Sat 28 May 2011, 7:03 pm
Does your computer boot up in normal mode yet? I don´t suppose so, but you never know.
Combofix reported a cryptographic services error. Lets see if we can trouble shoot that.
go to start ==> run and type services.msc and hit enter
The services list should pop up.
Find the Cryptographic services and verify it is running. It probably is not. Rightclick and see if you can start it. Rightclick and and see if you can set its startup type to Automatic, in case it is disabled.
If you are unable to start this service, verify that the Remote Procedure Call (RPC) service is running and starts automatically. If not, try to start it and have it start up automatically. If that works, go back and see if you get Cryptographic service running again (Cryptographic service needs the RPC)
Report back your findings please.
Gabethebabe
Tech Advisor
Tech Advisor
Post by MBanks on Sat 28 May 2011, 7:23 pm
I'll try booting the computer into Normal mode to see what happens after I've made this post.
The services list popped up, I found a service called CryptSvc, I assume that is the one we are looking for.
It's status was continually 'Starting'. When I right click it and go to the properties menu I can see that the start up type is already Automatic, and I can't start it manually, all the buttons are greyed out, I think this could be because it is in a permanent state of 'starting'?
The Remote Procedure Call (RPC) is running (it's status is Started), and it's start up type is Automatic.
I will now try and reboot the computer into normal mode.
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Sat 28 May 2011, 7:31 pm
It loaded to the log in page fine, I entered my password and Windows loaded, it was ok for about 30secs-1min and the the blue screen came up and it restarted.
MBanks
Rookie Surfer
Rookie Surfer
Post by Gabethebabe on Sun 29 May 2011, 1:57 am
Please restart your computer and before Windows starts loading, hit the F8 key a couple of times.
A menu appears with several boot options.
  • Choose Enable Boot Logging and continue to boot
  • After Windows has loaded, open Notepad
  • In Notepad choose File >> Open
  • In the Name field paste the following: c:\windows\ntbtlog.txt
  • Click Open to open the bootlog
  • Copy and paste it into your next reply
Gabethebabe
Tech Advisor
Tech Advisor
Post by MBanks on Sun 29 May 2011, 11:55 am
Here is the ntbtlog...it was pretty hard doing all those instructions quick enough before the blue screen came up, it took a couple of tries but here it is:
It is a fairly long log, however there are a few sections where it is just repeating the same thing over and over, for a VERY long time. So that I can try and fit them all in I have left the repeated line out, using '...' at the end of the line to signify the repition and a '...' a few lines before the log varies again. If you need to see all the repeated lines then I could attach the log as a document for you to see?
Here's the log:
Service Pack 3 5 21 2011 15:27:10.500
Loaded driver \WINDOWS\system32\ntoskrnl.exe
Loaded driver \WINDOWS\system32\hal.dll
Loaded driver \WINDOWS\system32\KDCOM.DLL
Loaded driver \WINDOWS\system32\BOOTVID.dll
Loaded driver ACPI.sys
Loaded driver \WINDOWS\system32\DRIVERS\WMILIB.SYS
Loaded driver pci.sys
Loaded driver isapnp.sys
Loaded driver compbatt.sys
Loaded driver \WINDOWS\system32\DRIVERS\BATTC.SYS
Loaded driver pciide.sys
Loaded driver \WINDOWS\system32\DRIVERS\PCIIDEX.SYS
Loaded driver MountMgr.sys
Loaded driver ftdisk.sys
Loaded driver dmload.sys
Loaded driver dmio.sys
Loaded driver ACPIEC.sys
Loaded driver \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
Loaded driver PartMgr.sys
Loaded driver VolSnap.sys
Loaded driver atapi.sys
Loaded driver disk.sys
Loaded driver \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
Loaded driver fltmgr.sys
Loaded driver sr.sys
Loaded driver PxHelp20.sys
Loaded driver KSecDD.sys
Loaded driver Ntfs.sys
Loaded driver NDIS.sys
Loaded driver Mup.sys
Loaded driver MDFSYSNT.sys
Did not load driver ACPI Uniprocessor PC
Did not load driver Audio Codecs
Did not load driver Legacy Audio Drivers
Did not load driver Media Control Devices
Did not load driver Legacy Video Capture Devices
Did not load driver Video Codecs
Did not load driver WAN Miniport (L2TP)
Did not load driver WAN Miniport (IP)
Did not load driver WAN Miniport (PPPOE)
Did not load driver WAN Miniport (PPTP)
Did not load driver Packet Scheduler Miniport
Did not load driver Direct Parallel
Did not load driver Wireless Intermediate Driver
Did not load driver Intel Processor
Did not load driver Mobile Intel(R) 915GM/GMS,910GML Express Chipset Family
Did not load driver Microsoft ACPI-Compliant Control Method Battery
Did not load driver Microsoft AC Adapter
Did not load driver Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller
Loaded driver \SystemRoot\system32\DRIVERS\HDAudBus.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbuhci.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbehci.sys
Loaded driver \SystemRoot\system32\DRIVERS\i8042prt.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\ETD.sys
Loaded driver \SystemRoot\system32\DRIVERS\mouclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\ASUSACPI.sys
Loaded driver \SystemRoot\system32\DRIVERS\rdpdr.sys
Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys
Loaded driver \SystemRoot\system32\DRIVERS\VClone.sys
Loaded driver \SystemRoot\system32\DRIVERS\swenum.sys
Loaded driver \SystemRoot\system32\DRIVERS\update.sys
Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys
Did not load driver Realtek High Definition Audio
Loaded driver \SystemRoot\system32\DRIVERS\usbhub.sys
Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys
Loaded driver \SystemRoot\system32\DRIVERS\redbook.sys
Loaded driver \SystemRoot\system32\DRIVERS\GEARAspiWDM.sys
Did not load driver \SystemRoot\System32\Drivers\lbrtfdc.SYS
Did not load driver \SystemRoot\System32\Drivers\Fdc.SYS
Did not load driver \SystemRoot\System32\Drivers\Flpydisk.SYS
Did not load driver \SystemRoot\System32\Drivers\Sfloppy.SYS
Did not load driver \SystemRoot\System32\Drivers\i2omgmt.SYS
Did not load driver \SystemRoot\System32\Drivers\Changer.SYS
Did not load driver \SystemRoot\System32\Drivers\Cdaudio.SYS
Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.SYS
Loaded driver \SystemRoot\System32\Drivers\Null.SYS
Loaded driver \SystemRoot\System32\Drivers\Beep.SYS
Loaded driver \SystemRoot\System32\drivers\vga.sys
Did not load driver mnmdd.SYS
Did not load driver RDPCDD.SYS
Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS
Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS
Did not load driver RasAcd.SYS
Did not load driver IPSec.SYS
Did not load driver Tcpip.SYS
Did not load driver NetBT.SYS
Did not load driver AFD.SYS
Did not load driver NetBIOS.SYS
Did not load driver intelppm.SYS
Did not load driver \SystemRoot\System32\Drivers\PCIDump.SYS
Did not load driver WS2IFSL.SYS
Did not load driver Rdbss.SYS
Did not load driver MRxSmb.SYS
Did not load driver \SystemRoot\system32\DRIVERS\imapi.sys
Did not load driver Fips.SYS
Did not load driver ElbyCDIO.SYS
Did not load driver CbFs.SYS
Loaded driver \SystemRoot\system32\DRIVERS\usbccgp.sys
Did not load driver USB Video Device
Loaded driver \SystemRoot\System32\Drivers\Cdfs.SYS
Loaded driver \SystemRoot\system32\DRIVERS\WudfPf.sys
Did not load driver AFD.SYS....
(repeated lines)
...Did not load driver AFD.SYS
Loaded driver \SystemRoot\system32\DRIVERS\USBSTOR.SYS
(more endlessly repeated lines, it really goes on for AGES!!)
I'm running out of character space so I'll continue in new posts.
MBanks
Rookie Surfer
Rookie Surfer
Post by MBanks on Sun 29 May 2011, 12:19 pm
....Did not load driver AFD.SYS
Service Pack 3 5 21 2011 19:22:47.500
MBanks
Rookie Surfer
Rookie Surfer
Post by Sponsored content Today at 1:11 pm
