Had a virus, ran MBAM, rebooted to fix the problem and now it's worse....
Page 1 of 2 1, 2  Next
Post by MBanks on Mon May 09, 2011 3:57 am
Windows sometimes loads now but it will the show the blue screen of death with some text which disappears to quick to read, then reboots. Sometimes it will not even reboot, the screen just turns off and on on my laptop.
When the laptop does decide to load properly I can't load up in safemode to even get the MBAM log to post here!!
Does anyone have any suggestions on what I can do? This has put me in a very bad situation!
Any help is grately appreciated.
Thanks,
Martin
MBanks
Posts Posts : 92
Joined Joined : 2010-09-15
OS OS : Windows XP Home Edition SP3
Points Points : 24084
Re: Had a virus, ran MBAM, rebooted to fix the problem and now it's worse....
Post by Gabethebabe on Mon May 09, 2011 9:26 am
Hi there Martin!
I am Gabethebabe and I will be helping you with this issue. Before we start some general remarks/rules:
  • Whilst Iīm helping you, please follow my instructions carefully and do not experiment on your own or accept help from other persons.
  • Feel free to ask questions! Especially if my instructions are not clear. Iīm here to help, not confuse you.
  • I will try and respond quickly, but please understand I do have a real life (job, wife, 3 kids, kinky hobbies).
  • Stick with me till the end. If your computer starts running better, doesnīt mean it is clean yet!
A couple of questions:
1) You are on Windows XP, right? Do you have a Windows XP setup disk (or can you get one from anywhere?
2) What parts of the bott process go well, which startup screens do you see and where exactly does it fail?
Gabethebabe
Posts Posts : 1568
Joined Joined : 2010-03-07
OS OS : Win7
Points Points : 38218
Post by Gabethebabe on Thu May 12, 2011 6:07 am
Any update on this? Do you still require my assistance?
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Tue May 17, 2011 11:20 pm
Sorry, I still require your assistance!! When I used this forum before I got an email when someone had replied to a post and that didn't happen this time, guess I didn't click in some tick box!
OK, so now I'm back I'll be checking the site to see if you've replied. I'm at work now so I'll do my best to answer those questions...
1) I am on Win XP, and I don't have a start up CD or a CD drive. The laptop with the problem is an EeePC netbook which came with Windows installed and doesn't have a CD drive.
2) The booting up process either:
a)lets windows start up, I enter my password windows loads and then after a while the computer comes up with the blue screen error message which is too quick to read, then reboots. Sometimes this reboot with do the same thing, get to Windows and then blue screen again.....or.....it will power off, try to restart and then the laptop screen will just turn on and off in a loop without the computer restarting. The typing cursor shows up in the top left corner showing that it's trying to turn on.
Any help to get this problem fix would be a HUGE bonus as there is still important data on there that I need to retrieve!! And also having my computer working again would be more than benificial!
I hope can help,
Regards,
Martin.
MBanks
Posts Posts : 92
Post by MBanks on Tue May 17, 2011 11:21 pm
P.S. I just found the watch this topic button so I shouldn't be slow at replying anymore!
MBanks
Posts Posts : 92
Post by Gabethebabe on Wed May 18, 2011 6:37 am
OK, Iīm going to fire off some questions here.
  • Have you tried to boot to [You must be registered and logged in to see this link.]?
  • It appears that pressing F9 during boot process will provide you with EeePC recovery options that are built into the EeePC. Is that correct? Watch out that if it does, the restore to factory settings will erase all your data. What options do you find for your computer?
  • Since you donīt have a CD, I suppose you are able to boot from an USB stick. Can you verify that? Iīve found some info that you need to press F2 to enter BIOS and in BIOS you can change boot device sequence. I suppose removable drive is one of them?
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Wed May 18, 2011 10:34 am
I tried to reboot to Last Know Configuration, however when I select the shut down button it gives me no other options as the link suggests, it just shuts down, or restarts.
I tried pressing F9 and also tried to start in safe mode however I've had no luck with these. At the moment it hardly even loads up, it just gets stuck and the screen turning on and off.
I managed to get it to open BIOS just now, and the boot options I have are:
ATAPI CD-ROM
HDD: PM-ST980811AS
Revmovable Dev.
I'm guessing that the removable device is the USB stick.
I managed to snap a quick photo of the blue screen before it restarted and this is what is says:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again follow these steps:
Check to make sure you have adequate disk space. If a driver is identified in the stop message, disable the driver or check with the manufacturer for driver updates. Try changing video adapters.
Check with your hardware vendor for any BIOS updates. Disable any BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Start Up Options, and then select Safe Mode.
Technical Information:
*** STOP: 0x0000008E (0xC0000005,0xF73F571D,0xA95CA570,0x00000000)
*** atapi.sys - Address F73F571D base at F73EB000, DateStamp 4802539d
Beginning of dump of physical memory
Physical memory dump complete
Contact your system administrator or tech support group for further assistance.
And that's the end of the message on the blue screen. I haven't done anything that it suggests as I will wait for your next suggestion to see if this blue screen message sheds any light on the problem for you.
Thanks,
Martin.
MBanks
Posts Posts : 92
Post by Gabethebabe on Wed May 18, 2011 11:48 am
Have you tried to find the EeePC recovery options? Is there a system restore that you can get to?
Can you try and create the OTLPE usb drive, as described [You must be registered and logged in to see this link.] and see if you can boot from it?
If it does, proceed with the following:
  • Finally you should see the REATOGO-X-PE desktop. Find the OTLPE icon and double click it to run OTLPE
  • Answer Yes and OK to all prompts
  • Ensure the option Automatically Load All Remaining Users is checked
  • OTL should now start. Set the option Drivers to Non-Microsoft
  • Copy and paste the following text into the Custom Scans/Fixes field:
    /md5start
    atapi.sys
    iastor.sys
    ndis.sys
    userinit.exe
    winlogon.exe
    /md5stop
  • Click Run Scan to start the scan
  • When finished, a log file C:\OTL.txt will be created
  • Please post the contents of the file in your next reply
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Wed May 18, 2011 9:32 pm
I can't get into the Eeepc Recvoery options, I also disabled the boot booster in BIOS to see if that would help open the Eeepc recovery options, however when it reboots and I hold down F9 nothing happens.
I can't seem to open anything in Windows before the laptop reboots so i can't open any System Restore.
I will try creating the USB stick to boot from when at work. I can create it on another PC without affecting/damaging that PC before I use the USB to boot from on the broken laptop...is that right? As I will not be able to create the USB stick on the broken laptop as it won't give me long enough to use the computer to create it. I do not want to effect/damage the computer I will create the USB boot drive on either as I can't afford for that to happen at work and I have no other option.
Thanks for your help, I await your response before creating the USB boot drive.
Martin
MBanks
Posts Posts : 92
Post by Gabethebabe on Thu May 19, 2011 6:33 am
Creating the USB boot stick is completely safe and you indeed need to do that on a working computer.
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Thu May 19, 2011 10:48 am
I created the USB boot stick with no problems, I started up in BIOS in the broken laptop and changed the boot disk to the USB key, however when it now boots up it goes to a black screen and says:
Remove disks or other media
Press any key to restart.
If I don't take out the USB and press a key it just boots into windows normally.
If I take the key out and press any key it just starts up into Windows normally.
Where could I be going wrong, or is it the laptops problem?
MBanks
Posts Posts : 92
Post by Gabethebabe on Thu May 19, 2011 11:21 am
Looks like the USB is not bootable ...
Can you try the USB boot disk on another computer?
If it doesnīt work on another computer either, probably the USB boot disk was not properly created.
A quick summary to make sure I get it all right
- You are unable to get to desktop in normal mode in any of the existing user profiles
- The same as above for Windows safe mode
- If you try Last Known Good Configuration, you cannot boot either.
Both safe mode and Last Known Good Configuration are available in the advanced boot menu, press F8 during startup, before Windows starts to load, to get to the advanced boot menu.
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Thu May 19, 2011 1:34 pm
I will try the USB boot on another computer when I can, I followed the instructions EXACTLY as they were worded on the website as I want to get this exactly right so that I can get my laptop working ASAP and so that I don't break anything any further by getting something wrong. But I will get back to you when I've tried it on something else.
I can get to the desktop sometimes on the broken laptop in the only user profile I have on it, however it's not long after loading that the blue screen appears and it restarts.
It won't load into safe more for some reason, pressing the F8 key for safe mode, or the F9 key for the Eeepc mode does nothing.
I will try these all again, however I am away tomorrow and will not be able to try until Sunday at the earliest. Thank you so much for all your help so far, I hope we can sort this out!
Martin
MBanks
Posts Posts : 92
Post by Gabethebabe on Fri May 20, 2011 8:45 am
You cannot get to safe mode? Make sure you start jamming the F8 key when your computer is booting and still showing BIOS messages. It must be done BEFORE you get the first "Windows loading" screen.
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Sun May 22, 2011 9:59 am
I had some time to try and work with the laptop.
I eventually managed to get it to start up in Safe Mode and I managed to copy off some of my data that I need. However I'd still like to fix the laptop without having to format it if possible.
I tried F9 over and over again to see if I could get it to load into the Eeepc recovery mode but with no luck.
I managed to use F8 to bring up the different options of Safe Mode again and noticed that it had the Last Known Configuration option under it too, so I loaded Windows using that option. It loaded, I left the computer on without doing anything, and like before, within a couple of minutes the blue screen came up with the same message and the laptop tried to restart.
What would you suggest next? Should I try and System Restore in normal safe mode? or something else entirely?
Thanks,
Martin.
MBanks
Posts Posts : 92
Post by Gabethebabe on Sun May 22, 2011 4:28 pm
The Eeepc recovery mode is probably only accessible if you see some message during bootup. E.g. "Press [KEY] for recovery options". If you do not see such a message, it means that there are no recovery options available.
You have been able to get the computer running in safe mode. That is good news. Lets see if we can get some of our tools running.
Please download OTL by OldTimer from [You must be registered and logged in to see this link.] and save it to your desktop.
  • The Extra Registry setting should be Use Safelist
  • Copy and paste the following text into the Custom Scans/Fixes box:
netsvcs
msconfig
safebootminimal
safebootnetwork
activex
drivers32
%SYSTEMDRIVE%\*.*
%PROGRAMFILES%\*.
/md5start
atapi.sys
explorer.exe
iastor.sys
userinit.exe
winlogon.exe
/md5stop
  • Click the Run Scan button and allow it to run.
  • It will produce two logs for you, OTL.txt and Extras.txt. Please post both logs in this thread.
  • You may need multiple posts to get it all.
You will probably need to download otl.exe from a clean computer and copy it to the problem computerīs desktop with an USB drive.
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Mon May 23, 2011 8:45 am
OK, so I ran OTL and here are the logs....
OTL Log:
OTL logfile created on: 5/23/2011 6:00:00 PM - Run 1
OTL by OldTimer - Version 3.2.23.0 Folder = C:\Documents and Settings\Intel\Desktop
Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
Internet Explorer (Version = 7.0.5730.13)
1015.05 Mb Total Physical Memory | 836.39 Mb Available Physical Memory | 82.40% Memory free
2.39 Gb Paging File | 2.32 Gb Available in Paging File | 97.27% Paging File free
Paging file location(s): C:\pagefile.sys 1524 3048 [binary data]
Drive C: | 39.99 Gb Total Space | 6.03 Gb Free Space | 15.07% Space Free | Partition Type: NTFS
Drive D: | 34.49 Gb Total Space | 1.60 Gb Free Space | 4.65% Space Free | Partition Type: NTFS
Computer Name: EPC | User Name: Intel | Logged in as Administrator.
Boot Mode: SafeMode | Scan Mode: Current user
PRC - [2011/05/23 07:23:00 | 000,580,096 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Intel\Desktop\OTL.exe
PRC - [2008/07/03 21:38:24 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
MOD - [2011/05/23 07:23:00 | 000,580,096 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Intel\Desktop\OTL.exe
MOD - [2008/04/14 06:12:52 | 001,054,208 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
SRV - File not found [Disabled | Stopped] -- -- (Ialaervnwlrx)
SRV - File not found [Disabled | Stopped] -- -- (HidServ)
SRV - [2010/12/20 18:38:58 | 000,363,344 | ---- | M] (Malwarebytes Corporation) [Auto | Stopped] -- C:\Program Files\Malwarebytes' Anti-Malware\mbamservice.exe -- (MBAMService)
SRV - [2010/11/15 15:50:58 | 000,211,968 | ---- | M] (Mediafour Corporation) [Auto | Stopped] -- C:\Program Files\Common Files\Mediafour\iPod\M4iPodWPDService.exe -- (M4iPodWPDService)
SRV - [2010/01/15 22:49:20 | 000,227,232 | ---- | M] (McAfee, Inc.) [On_Demand | Stopped] -- C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe -- (McComponentHostService)
SRV - [2008/11/10 06:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) [Auto | Stopped] -- C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe -- (YahooAUService)
SRV - [2007/05/03 18:12:40 | 000,364,629 | ---- | M] (Atheros) [Auto | Stopped] -- C:\WINDOWS\system32\acs.exe -- (ACS)
DRV - [2010/12/20 18:38:40 | 000,020,952 | ---- | M] (Malwarebytes Corporation) [File_System | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mbam.sys -- (MBAMProtector)
DRV - [2010/11/15 15:50:56 | 000,145,504 | ---- | M] (EldoS Corporation) [Kernel | System | Stopped] -- C:\WINDOWS\system32\drivers\cbfs.sys -- (CbFs)
DRV - [2009/09/28 13:02:18 | 000,259,176 | ---- | M] (Mediafour Corporation) [File_System | Boot | Stopped] -- C:\WINDOWS\System32\drivers\MDFSYSNT.SYS -- (MDFSYSNT)
DRV - [2008/08/12 11:00:54 | 000,007,680 | ---- | M] (ZTE Incorporated) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\massfilter.sys -- (massfilter)
DRV - [2008/06/14 01:41:16 | 004,754,944 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\RtkHDAud.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
DRV - [2008/04/19 06:35:22 | 000,103,936 | ---- | M] (ZTE Incorporated) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ZTEusbser6k.sys -- (ZTEusbser6k)
DRV - [2008/04/19 06:35:22 | 000,103,936 | ---- | M] (ZTE Incorporated) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ZTEusbnmea.sys -- (ZTEusbnmea)
DRV - [2008/04/19 06:35:22 | 000,103,936 | ---- | M] (ZTE Incorporated) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ZTEusbmdm6k.sys -- (ZTEusbmdm6k)
DRV - [2008/04/08 16:29:28 | 000,010,752 | ---- | M] (ASUSTeK Computer Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ASUSACPI.SYS -- (AsusACPI)
DRV - [2008/03/12 04:07:00 | 000,036,864 | ---- | M] (Atheros Communications, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\l1e51x86.sys -- (L1e)
DRV - [2007/05/02 19:30:58 | 000,546,976 | ---- | M] (Atheros Communications, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ar5211.sys -- (AR5211)
DRV - [2007/03/28 20:22:20 | 000,057,024 | ---- | M] (Atheros Communications, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\wsimd.sys -- (WSIMD)
========== FireFox ==========
FF - prefs.js..browser.search.param.yahoo-fr: "chrf-ytbm"
FF - prefs.js..browser.search.param.yahoo-fr-cjkt: "chrf-ytbm"
FF - prefs.js..browser.search.param.yahoo-type: "${8}"
FF - prefs.js..browser.startup.homepage: "[You must be registered and logged in to see this link.]
FF - prefs.js..extensions.enabledItems: {635abd67-4fe9-1b23-4f01-e679fa7484c1}:2.1.1.20091029021655
FF - prefs.js..extensions.enabledItems: {AB2CE124-6272-4b12-94A9-7303C7397BD1}:4.2.0.5198
FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}:6.0.23
FF - prefs.js..extensions.enabledItems: {23fcfd51-4958-4f00-80a3-ae97e717ed8b}:2.1.1.94
FF - prefs.js..extensions.enabledItems: {6904342A-8307-11DF-A508-4AE2DFD72085}:2.1.1.94
FF - HKLM\software\mozilla\Firefox\extensions\\{23fcfd51-4958-4f00-80a3-ae97e717ed8b}: C:\Program Files\DivX\DivX Plus Web Player\firefox\html5video [2011/04/07 23:03:11 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\extensions\\{6904342A-8307-11DF-A508-4AE2DFD72085}: C:\Program Files\DivX\DivX Plus Web Player\firefox\wpa [2011/04/07 23:03:12 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.17\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2011/04/30 14:05:14 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.17\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2011/04/30 14:05:14 | 000,000,000 | ---D | M]
[2010/10/02 16:39:42 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Intel\Application Data\Mozilla\Extensions
[2011/05/06 18:48:07 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Intel\Application Data\Mozilla\Firefox\Profiles\63op53yi.default\extensions
[2010/10/03 10:29:47 | 000,000,000 | ---D | M] (Yahoo! Toolbar) -- C:\Documents and Settings\Intel\Application Data\Mozilla\Firefox\Profiles\63op53yi.default\extensions\{635abd67-4fe9-1b23-4f01-e679fa7484c1}
[2011/05/06 18:48:07 | 000,000,000 | ---D | M] (No name found) -- C:\Program Files\Mozilla Firefox\extensions
[2010/10/06 17:58:03 | 000,000,000 | ---D | M] (Skype extension for Firefox) -- C:\Program Files\Mozilla Firefox\extensions\{AB2CE124-6272-4b12-94A9-7303C7397BD1}
[2011/01/29 08:49:01 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}
[2011/04/07 23:03:11 | 000,000,000 | ---D | M] (DivX Plus Web Player HTML5 <video>) -- C:\PROGRAM FILES\DIVX\DIVX PLUS WEB PLAYER\FIREFOX\HTML5VIDEO
[2011/04/07 23:03:12 | 000,000,000 | ---D | M] (DivX HiQ) -- C:\PROGRAM FILES\DIVX\DIVX PLUS WEB PLAYER\FIREFOX\WPA
[2010/10/02 16:33:32 | 000,000,000 | ---D | M] (Java Quick Starter) -- C:\PROGRAM FILES\JAVA\JRE6\LIB\DEPLOY\JQS\FF
[2010/11/12 19:23:06 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npdeployJava1.dll
Hosts file not found
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - No CLSID value found.
O2 - BHO: (DivX Plus Web Player HTML5
MBanks
Posts Posts : 92
Post by MBanks on Mon May 23, 2011 8:54 am
Sorry if there is any overlap of code, it said I had characters remaining when I pasted it section by section but it's cut some off so here is more of it....
MBanks
Posts Posts : 92
Post by MBanks on Mon May 23, 2011 8:56 am
I don't know what's going on with this post....I copy and pasted in loads of the code for the last post and it's only put in that tiny bit!!?!?!
MBanks
Posts Posts : 92
Post by Gabethebabe on Mon May 23, 2011 9:20 am
[You must be registered and logged in to see this link.] wrote:I don't know what's going on with this post....I copy and pasted in loads of the code for the last post and it's only put in that tiny bit!!?!?!
some weird forum error. If you click the quote button of you own post, you will see it is all there.
Looking at your logs. bbl
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Mon May 23, 2011 9:34 am
Ah, ok, I'll try and post the Extras Log now then:
OTL Extras logfile created on: 5/23/2011 6:00:00 PM - Run 1
.cpl [@ = cplfile] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
.url [@ = InternetShortcut] -- rundll32.exe ieframe.dll,OpenURL %l
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
comfile [open] -- "%1" %*
cplfile [cplopen] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
exefile [open] -- "%1" %*
InternetShortcut [open] -- rundll32.exe ieframe.dll,OpenURL %l
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
Directory [AddToPlaylistVLC] -- "C:\Program Files\VideoLAN\VLC\vlc.exe" --started-from-file --playlist-enqueue "%1" ()
Directory [PlayWithVLC] -- "C:\Program Files\VideoLAN\VLC\vlc.exe" --started-from-file --no-playlist-enqueue "%1" ()
"FirstRunDisabled" = 1
"AntiVirusOverride" = 0
"FirewallOverride" = 0
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"UpdatesDisableNotify" = 0
"DisableSR" = 0
"Start" = 0
"Start" = 2
"EnableFirewall" = 1
"DoNotAllowExceptions" = 0
"1900:TCP" = 1900:TCP:LocalSubNet:Enabled:UDP 1900
"C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" = C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe:*:Enabled:Yahoo! Messenger -- (Yahoo! Inc.)
"{0990B5DF-92C3-4AD6-A18D-BF3ADF311240}" = Super Hybrid Engine
"{19F5658D-92E8-4A08-8657-D38ABB1574B2}" = Asus ACPI Driver
"{1F698102-5739-441E-96F0-74F4EA540F06}" = Atheros Ethernet Utility
"{26A24AE4-039D-4CA4-87B4-2F83216020FF}" = Java(TM) 6 Update 23
"{28006915-2739-4EBE-B5E8-49B25D32EB33}" = Atheros Client Installation Program
"{2CE5A2E7-3437-4CE7-BCF4-85ED6EEFF9E4}" = iTunes
"{3108C217-BE83-42E4-AE9E-A56A2A92E549}" = Atheros Communications Inc.(R) AR8121/AR8113/AR8114 Gigabit/Fast Ethernet Driver
"{3175E049-F9A9-4A3D-8F19-AC9FB04514D1}" = Windows Live Communications Platform
"{31851B85-C98E-44DE-8750-9843BCD63963}" = Adobe After Effects 5.5
"{45338B07-A236-4270-9A77-EBB4115517B5}" = Windows Live Sign-in Assistant
"{4539863D-69F5-457B-901A-6A36C46AB2BD}" = XPlay 3
"{474F25F5-BDC9-40E5-B1B6-F6BF23FC106F}" = Windows Live Essentials
"{587178E7-B1DF-494E-9838-FA4DD36E873C}" = ASUSUpdate for Eee PC
"{5A13987D-55F4-4271-A40E-76AC9B1B38FD}" = OpenOffice.org 3.2
"{5EE7D259-D137-4438-9A5F-42F432EC0421}" = VC80CRTRedist - 8.0.50727.4053
"{6E4DAE31-7CF3-441A-B6E5-B014D63C80CD}" = Eee Instant Key
"{85E3CFBC-9B1B-470C-AF72-54EACA0F1322}" = ECAP
"{93D34EE3-99B3-4DB1-8B0A-0A657466F90D}" = Telstra Turbo Connection Manager
"{9559F7CA-5E34-4237-A2D9-D856464AD727}" = Project64 1.6
"{981029E0-7FC9-4CF3-AB39-6F133621921A}" = Skype Toolbars
"{9811A185-3D3D-11D6-9E14-00036D172B00}" = Adobe MPEG Encoder
"{A1F66FC9-11EE-4F2F-98C9-16F8D1E69FB7}" = Segoe UI
"{AC76BA86-7AD7-1033-7B44-A94000000001}" = Adobe Reader 9.4.3
"{B194272D-1F92-46DF-99EB-8D5CE91CB4EC}" = Adobe AIR
"{B57EAFF2-D6EE-4C6C-9175-ED9F17BFC1BC}" = Windows Live Messenger
"{BDCF27CA-BFC4-4F49-8D24-A925C9505AB8}" = Windows Rights Management Client with Service Pack 2
"{C41300B9-185D-475E-BFEC-39EF732F19B1}" = Apple Software Update
"{CCA1EEA3-555E-4D05-AC46-4B49C6C5D887}" = Apple Mobile Device Support
"{D0B9F312-2CAC-4EB0-AF68-E9D6C88935A7}" = AiGuru U1
"{D103C4BA-F905-437A-8049-DB24763BBE36}" = Skype™ 4.2
"{DAEAFD68-BB4A-4507-A241-C8804D2EA66D}" = Apple Application Support
"{E6158D07-2637-4ECF-B576-37C489669174}" = Windows Live Call
"{E7004147-2CCA-431C-AA05-2AB166B9785D}" = QuickTime
"{EC905264-BCFE-423B-9C42-C3A106266790}" = Windows Rights Management Client Backwards Compatibility SP2
"{EFB21DE7-8C19-4A88-BB28-A766E16493BC}" = Adobe Photoshop CS
"{FF1C31AE-0CDC-40CE-AB85-406F8B70D643}" = Bonjour
"7-Zip" = 7-Zip 9.20
"Ableton Live_is1" = Ableton Live v6.0.3
"Adobe AIR" = Adobe AIR
"Adobe Premiere 6.5" = Adobe Premiere 6.5
"ASIO4ALL" = ASIO4ALL
"DivX Setup.divx.com" = DivX Setup
"Elantech" = ETDWare PS/2-x86 7.0.4.3 WHQL
"HDMI" = Intel(R) Graphics Media Accelerator Driver
"McAfee Security Scan" = McAfee Security Scan Plus
"Microsoft Silverlight" = Microsoft Silverlight
"Mozilla Firefox (3.6.17)" = Mozilla Firefox (3.6.17)
"RarZilla Free Unrar" = RarZilla Free Unrar
"RNCompiler 6.0" = Advanced RealMedia Export Plug-in for Premiere 6.0
"ScummVM_is1" = ScummVM 1.2.0
"ST6UNST #1" = Address Book
"Vimeo Video Downloader_is1" = Vimeo Video Downloader 3.17
"VirtualCloneDrive" = VirtualCloneDrive
"VLC media player" = VLC media player 1.1.5
"Windows Rights Management Client" = Windows Rights Management Client with Service Pack 2
"Windows Rights Management Client Backwards" = Windows Rights Management Client Backwards Compatibility SP2
"Wudf01009" = Microsoft User-Mode Driver Framework Feature Pack 1.9
"Yahoo! Software Update" = Yahoo! Software Update
"Yahoo!7 Messenger" = Yahoo!7 Messenger
[ Application Events ]
Error - 2/1/2011 7:08:40 PM | Computer Name = EPC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: Continuously busy for more than a second
Description = Task Scheduling Error: m->NextScheduledEvent 3859
Description = Task Scheduling Error: m->NextScheduledSPRetry 3859
Error - 2/2/2011 5:47:43 AM | Computer Name = EPC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: m->NextScheduledEvent 3172
Description = Task Scheduling Error: m->NextScheduledSPRetry 3172
Error - 2/2/2011 6:15:45 AM | Computer Name = EPC | Source = Bonjour Service | ID = 100
Description = 248: ERROR: read_msg errno 10054 (An existing connection was forcibly
closed by the remote host.)
Error - 2/3/2011 5:28:23 AM | Computer Name = EPC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: m->NextScheduledEvent 3219
Description = Task Scheduling Error: m->NextScheduledSPRetry 3219
[ System Events ]
Error - 5/22/2011 3:34:13 AM | Computer Name = EPC | Source = Service Control Manager | ID = 7001
Description = The Bonjour Service service depends on the TCP/IP Protocol Driver
service which failed to start because of the following error: %%31
Description = The IPSEC Services service depends on the IPSEC driver service which
Error - 5/22/2011 3:34:13 AM | Computer Name = EPC | Source = Service Control Manager | ID = 7026
AFD CbFs ElbyCDIO Fips intelppm IPSec MDFSYSNT MRxSmb NetBIOS NetBT RasAcd Rdbss Tcpip
Error - 5/22/2011 5:13:06 AM | Computer Name = EPC | Source = DCOM | ID = 10005
Description = DCOM got error "%1084" attempting to start the service netman with
arguments "" in order to run the server: {BA126AE5-2166-11D1-B1D0-00805FC1270E}
Error - 5/22/2011 5:13:14 AM | Computer Name = EPC | Source = DCOM | ID = 10005
Description = DCOM got error "%1084" attempting to start the service EventSystem
with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
Error - 5/22/2011 5:40:29 AM | Computer Name = EPC | Source = Service Control Manager | ID = 7022
Description = The M4iPodWPDService service hung on starting.
Error - 5/23/2011 3:49:35 AM | Computer Name = EPC | Source = DCOM | ID = 10005
Error - 5/23/2011 3:49:40 AM | Computer Name = EPC | Source = DCOM | ID = 10005
Error - 5/23/2011 3:51:54 AM | Computer Name = EPC | Source = DCOM | ID = 10005
Description = DCOM got error "%1084" attempting to start the service StiSvc with
arguments "" in order to run the server: {A1F4E726-8CF1-11D1-BF92-0060081ED811}
Error - 5/23/2011 3:52:37 AM | Computer Name = EPC | Source = DCOM | ID = 10005
Thanks for taking a look Smile I hope we can sort it!
MBanks
Posts Posts : 92
Post by Gabethebabe on Mon May 23, 2011 9:35 am
  • Please run OTL.exe again
  • Under the Custom Scans/Fixes box at the bottom, copy and paste in the following:
:files
C:\WINDOWS\Tasks\Eqhricgkht.job
C:\WINDOWS\Tasks\Odjkrgccrh.job
C:\WINDOWS\Tasks\Tddcnjakch.job
C:\WINDOWS\System32\rasauto6.dll
C:\WINDOWS\System32\dplayl.dll
:otl
O4 - HKLM..\Run: [] File not found
O33 - MountPoints2\{2440d391-cecd-11df-be11-00235411e6aa}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{2440d391-cecd-11df-be11-00235411e6aa}\Shell\AutoRun\command - "" = G:\DARKAN\\\sharic.exe
O33 - MountPoints2\{2440d391-cecd-11df-be11-00235411e6aa}\Shell\explore\command - "" = G:\DARKAN\\\\sharic.exe
O33 - MountPoints2\{2440d391-cecd-11df-be11-00235411e6aa}\Shell\open\command - "" = G:\DARKAN\\\\sharic.exe
O33 - MountPoints2\{79a2273e-ce24-11df-be0a-00235411e6aa}\Shell\AutoRun\command - "" = F:\goga/sekulac.exe
O33 - MountPoints2\{79a2273e-ce24-11df-be0a-00235411e6aa}\Shell\Explore\command - "" = F:\goga/sekulac.exe
O33 - MountPoints2\{79a2273e-ce24-11df-be0a-00235411e6aa}\Shell\Open\command - "" = F:\goga/sekulac.exe
O33 - MountPoints2\{a3e86527-16d6-11e0-bede-00235411e6aa}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{a3e86527-16d6-11e0-bede-00235411e6aa}\Shell\AutoRun\command - "" = G:\danisampopila\\\basdobro.exe
O33 - MountPoints2\{a3e86527-16d6-11e0-bede-00235411e6aa}\Shell\explore\command - "" = G:\danisampopila\\\basdobro.exe
O33 - MountPoints2\{a3e86527-16d6-11e0-bede-00235411e6aa}\Shell\Install\command - "" = G:\danisampopila\\\basdobro.exe
O33 - MountPoints2\{a3e86527-16d6-11e0-bede-00235411e6aa}\Shell\open\command - "" = G:\danisampopila\\\basdobro.exe
O33 - MountPoints2\{ba8067a6-d2d4-11df-be25-00235411e6aa}\Shell\AutoRun\command - "" = F:\
O33 - MountPoints2\{ba8067a6-d2d4-11df-be25-00235411e6aa}\Shell\Explore\command - "" = F:\goga/sekulac.exe
O33 - MountPoints2\{ba8067a6-d2d4-11df-be25-00235411e6aa}\Shell\Open\command - "" = F:\
O33 - MountPoints2\{ccdc789c-2846-11e0-bf18-00235411e6aa}\Shell - "" = AutoRun
O33 - MountPoints2\{ccdc789c-2846-11e0-bf18-00235411e6aa}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{ccdc789c-2846-11e0-bf18-00235411e6aa}\Shell\AutoRun\command - "" = C:\WINDOWS\system32\RunDLL32.EXE Shell32.DLL,ShellExec_RunDLL RuNdLl32.EXE .\RECYCLER\S-5-3-42-2819952290-8240758988-879315005-3665\jwgkvsq.vmx,ahaezedrn
:commands
[resethosts]
[reboot]
  • Then click the Run Fix button at the top.
  • Allow it to run. It may take some time and you may see some things happen to your desktop - this is normal.
  • If it asks to reboot the computer, allow it to reboot.
  • If the program freezes, and the computer fails to reboot - let me know.
  • Finally, post the contents of the log. (Located at C:\_OTL\Moved Files)
Hopefully that went well.
Now that you managed to get OTL running, lets try an even more powerful tool and see if we get lucky!
Time to use ComboFix by sUBs, a powerful tool that you are advised not to run without supervision of a trained malware helper. Please visit [You must be registered and logged in to see this link.] and read the tutorial on using ComboFix very carefully. After that download the tool and save it to your desktop.
Doubleclick ComboFix.exe to run the tool. Please post its log back here.
(if you donīt have www opn the problem computer, obviously use the usb flash disk trick again).
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Mon May 23, 2011 9:52 am
I copy and pasted the Fix and ran it, it took no time and all and then tried to reboot. If failed to reboot and just did the screen turning on and off again.
I managed to get it to start in Safe Mode after a couple of tries.
Here are the results of the log:
========== FILES ==========
C:\WINDOWS\Tasks\Eqhricgkht.job moved successfully.
C:\WINDOWS\Tasks\Odjkrgccrh.job moved successfully.
C:\WINDOWS\Tasks\Tddcnjakch.job moved successfully.
C:\WINDOWS\System32\rasauto6.dll moved successfully.
C:\WINDOWS\System32\dplayl.dll moved successfully.
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4efb-9B51-7695ECA05670}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{02478D38-C3F9-4efb-9B51-7695ECA05670}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\ deleted successfully.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{2440d391-cecd-11df-be11-00235411e6aa}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{2440d391-cecd-11df-be11-00235411e6aa}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{2440d391-cecd-11df-be11-00235411e6aa}\ not found.
File G:\DARKAN\\\sharic.exe not found.
File G:\DARKAN\\\\sharic.exe not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{79a2273e-ce24-11df-be0a-00235411e6aa}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{79a2273e-ce24-11df-be0a-00235411e6aa}\ not found.
File F:\goga/sekulac.exe not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{79a2273e-ce24-11df-be0a-00235411e6aa}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{a3e86527-16d6-11e0-bede-00235411e6aa}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{a3e86527-16d6-11e0-bede-00235411e6aa}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{a3e86527-16d6-11e0-bede-00235411e6aa}\ not found.
File G:\danisampopila\\\basdobro.exe not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ba8067a6-d2d4-11df-be25-00235411e6aa}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{ba8067a6-d2d4-11df-be25-00235411e6aa}\ not found.
Item F:\ is whitelisted and cannot be moved.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ba8067a6-d2d4-11df-be25-00235411e6aa}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ccdc789c-2846-11e0-bf18-00235411e6aa}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{ccdc789c-2846-11e0-bf18-00235411e6aa}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ccdc789c-2846-11e0-bf18-00235411e6aa}\ not found.
File C:\WINDOWS\system32\RunDLL32.EXE Shell32.DLL,ShellExec_RunDLL RuNdLl32.EXE .\RECYCLER\S-5-3-42-2819952290-8240758988-879315005-3665\jwgkvsq.vmx,ahaezedrn not found.
HOSTS file reset successfully
OTL by OldTimer - Version 3.2.23.0 log created on 05232011_194217
Shall I now run ComboFix and post the log?
MBanks
Posts Posts : 92
Post by Gabethebabe on Mon May 23, 2011 10:41 am
yes
I donīt suppose you can boot to normal mode yet?
high % probability of glorious blue screens while running combofix on your instable system, but OK. Install the recovery console when prompted by Combofix - very important.
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Mon May 23, 2011 11:48 am
I installed the recovery console, ran combofix...it said it found something, I think it was a Rootbot or Rootfix (sorry I can't remember exactly) and said it may take longer, it then said it needed to reboot because of the Rootthing. It tried to reboot but got stuck on the black screen with the flashing white line.
I have managed to get it to load up whilst pressing F8, I selected Safe Mode and now the scree has 3 other options:
Microsofy Recovery Console
do not select this [debugger enabled]
Microsoft Windows XP Professional.
Which one should I select, I don't think Combofix finished, as it said it needed restarting. Please let me know further instructions on what to do.
Many thanks,
Martin
MBanks
Posts Posts : 92
Post by Gabethebabe on Mon May 23, 2011 11:55 am
Just go into windows xp and see what happens. Try normal mode first. Maybe weīre lucky. If not into safe mode. Forget the recovery console for the moment. We might need it later, but not yet.
Look if there is a log c:\combofix.txt and post it if it exists.
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Mon May 23, 2011 12:04 pm
I loaded it into Safe Mode and ComboFix has immediately started running, so I'm guessing it's finishing off the scan and will the create the log. I'll let you know in a few minutes once it's hopefully completed.
MBanks
Posts Posts : 92
Post by Gabethebabe on Mon May 23, 2011 12:42 pm
This actually looks hopeful
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Mon May 23, 2011 1:10 pm
ComboFix has been running for a while, it went through a lot of stages, but has now not moved any further in quite some time (25mins +). Here is the last few messages it has come up with on the blue ComboFix screen:
Completed Stage_50
Deleting Files:
C:\Documents and Settings\All Users\Application Data\ECAP\ECap.ini
C:\Documents and Settings\All Users\Application Data\ECAP\GenePccMon.ini
C:\Documents and Settings\Intel\Application Data\Sun\rxls.dll
Deleting Folders:
C:\Documents and Settings\All User\Application Data\ECAP
C:\Documents and Settings\Intel\Windows
And that is as far it has got. Hasn't done anything in a while. Shall I leave it to run overnight? What steps should I take next?
Thanks,
Martin
MBanks
Posts Posts : 92
Post by MBanks on Mon May 23, 2011 1:15 pm
Ah, it looks like it's creating the log......fingers crossed!
MBanks
Posts Posts : 92
Post by Gabethebabe on Mon May 23, 2011 1:23 pm
*drumroll*
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Mon May 23, 2011 1:45 pm
ComboFix log:
ComboFix 11-05-22.01 - Intel 05/23/2011 22:08:07.1.1 - x86 MINIMAL
Running from: c:\documents and settings\Intel\Desktop\ComboFix.exe
Command switches used :: c:\documents and settings\Intel\Desktop\WindowsXP-KB310994-SP2-Pro-BootDisk-ENU.exe
c:\documents and settings\All Users\Application Data\ECAP
c:\documents and settings\All Users\Application Data\ECAP\ECap.ini
c:\documents and settings\All Users\Application Data\ECAP\GenePccMon.ini
c:\documents and settings\Intel\Application Data\Sun\rxls.dll
c:\documents and settings\Intel\WINDOWS
((((((((((((((((((((((((( Files Created from 2011-04-23 to 2011-05-23 )))))))))))))))))))))))))))))))
2011-05-23 09:42 . 2011-05-23 09:42 -------- d-----w- C:\_OTL
2011-05-21 05:28 . 2011-05-21 05:28 -------- d-----w- c:\documents and settings\Administrator
2011-05-08 06:30 . 2008-04-14 12:00 221184 ----a-w- c:\windows\system32\wmpns.dll
2011-05-08 06:30 . 2011-05-08 06:30 -------- d-----w- c:\documents and settings\TEMP
2011-05-06 09:36 . 2011-05-06 09:36 -------- d-----w- c:\windows\system32\LogFiles
2011-05-06 09:26 . 2010-11-15 05:50 145504 ----a-w- c:\windows\system32\drivers\cbfs.sys
2011-05-06 09:26 . 2011-05-06 09:26 -------- d-----w- c:\program files\Common Files\Mediafour
2011-05-06 09:26 . 2011-05-06 09:26 -------- d-----w- c:\documents and settings\All Users\Application Data\Mediafour
2011-05-05 13:57 . 2011-05-06 09:26 -------- d-----w- c:\program files\Mediafour
2011-04-27 09:08 . 2011-04-27 09:08 -------- d-----w- c:\program files\7-Zip
------- Sigcheck -------
Cryptography Services Error !!
"Messenger (Yahoo!)"="c:\progra~1\Yahoo!\Messenger\YahooMessenger.exe" [2010-06-01 5252408]
"AsusTray"="c:\program files\EeePC\ACPI\AsTray.exe" [2008-09-17 106496]
"AsusACPIServer"="c:\program files\EeePC\ACPI\AsAcpiSvr.exe" [2008-09-16 593920]
"AsusEPCMonitor"="c:\program files\EeePC\ACPI\AsEPCMon.exe" [2008-05-20 94208]
"RTHDCPL"="RTHDCPL.EXE" [2008-06-13 16871936]
"SoundMan"="SOUNDMAN.EXE" [2006-07-21 86016]
"AlcWzrd"="ALCWZRD.EXE" [2006-05-04 2808832]
"U1_USB"="c:\program files\ASUS\AiGuru U1\AiGuru_U1usb.exe" [2008-04-25 200704]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2006-10-08 98304]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2006-10-08 114688]
"Persistence"="c:\windows\system32\igfxpers.exe" [2006-10-08 94208]
"ETDWare"="c:\program files\Elantech\ETDCtrl.exe" [2009-01-23 416768]
"ACU"="c:\program files\Atheros\ACU.exe" [2007-05-03 376921]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2010-09-08 421888]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2010-09-23 421160]
"autodetect"="c:\windows\system32\SupportAppXL\AutoDect.exe" [2008-08-07 91648]
"VirtualCloneDrive"="c:\program files\Elaborate Bytes\VirtualCloneDrive\VCDDaemon.exe" [2009-06-17 85160]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2011-01-31 35760]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-09-20 932288]
"Malwarebytes' Anti-Malware"="c:\program files\Malwarebytes' Anti-Malware\mbamgui.exe" [2010-12-20 443728]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-05-14 248552]
"DivXUpdate"="c:\program files\DivX\DivX Update\DivXUpdate.exe" [2011-03-21 1230704]
"{914C5BF8-EEDD-4F3A-A8BE-34EE71CF1B29}"="c:\program files\Mediafour\XPlay 3\XPlay.exe" [2010-11-15 300544]
Adobe Gamma Loader.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2010-10-7 113664]
McAfee Security Scan Plus.lnk - c:\program files\McAfee Security Scan\2.0.181\SSScheduler.exe [2010-1-15 255536]
SuperHybridEngine.lnk - c:\program files\Asus\EeePC\Super Hybrid Engine\SuperHybridEngine.exe [2010-10-2 294912]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WudfSvc]
"c:\\Program Files\\Skype\\Plugin Manager\\skypePM.exe"=
R0 MDFSYSNT;MacDrive file system driver; [x]
R0 vbjx;vbjx;c:\windows\System32\drivers\dmecpam.sys [x]
R1 CbFs;CbFs;c:\windows\system32\drivers\cbfs.sys [2010-11-15 145504]
R2 M4iPodWPDService;M4iPodWPDService;c:\program files\Common Files\Mediafour\iPod\M4iPodWPDService.exe [2010-11-15 211968]
R2 MBAMService;MBAMService;c:\program files\Malwarebytes' Anti-Malware\mbamservice.exe [2010-12-20 363344]
R3 massfilter;ZTE Mass Storage Filter Driver;c:\windows\system32\drivers\massfilter.sys [2008-08-12 7680]
R3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [2010-12-20 20952]
R3 McComponentHostService;McAfee Security Scan Component Host Service;c:\program files\McAfee Security Scan\2.0.181\McCHSvc.exe [2010-01-15 227232]
R4 Ialaervnwlrx;Ialaervnwlrx; [x]
FF - ProfilePath - c:\documents and settings\Intel\Application Data\Mozilla\Firefox\Profiles\63op53yi.default\
FF - Ext: Default: {972ce4c6-7e08-4474-a285-3208198ce6fd} - c:\program files\Mozilla Firefox\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
FF - Ext: Skype extension for Firefox: {AB2CE124-6272-4b12-94A9-7303C7397BD1} - c:\program files\Mozilla Firefox\extensions\{AB2CE124-6272-4b12-94A9-7303C7397BD1}
FF - Ext: Java Console: {CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA} - c:\program files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}
FF - Ext: Java Quick Starter: [You must be registered and logged in to see this link.] - c:\program files\Java\jre6\lib\deploy\jqs\ff
FF - Ext: DivX Plus Web Player HTML5 <video>: {23fcfd51-4958-4f00-80a3-ae97e717ed8b} - c:\program files\DivX\DivX Plus Web Player\firefox\html5video
FF - Ext: DivX HiQ: {6904342A-8307-11DF-A508-4AE2DFD72085} - c:\program files\DivX\DivX Plus Web Player\firefox\wpa
FF - Ext: Yahoo! Toolbar: {635abd67-4fe9-1b23-4f01-e679fa7484c1} - %profile%\extensions\{635abd67-4fe9-1b23-4f01-e679fa7484c1}
user_pref(security.warn_viewing_mixed,false);
user_pref(security.warn_viewing_mixed.show_once,false);
FF - user.js: network.cookie.cookieBehavior - 0
FF - user.js: privacy.clearOnShutdown.cookies - false
user_pref(security.warn_submit_insecure,false);
FF - user.js: security.warn_submit_insecure.show_once - false
ShellIconOverlayIdentifiers-MacDrive volume icons - (no file)
SafeBoot-WudfPf
SafeBoot-WudfRd
HKLM_ActiveSetup-{8CCFE231-6643-45D7-8787-3ABA666083C0} - c:\documents and settings\Intel\Application Data\Sun\rxls.dll
Rootkit scan 2011-05-23 23:14
Stealth MBR rootkit/Mebroot/Sinowal/TDL4 detector 0.4.2 by Gmer, [You must be registered and logged in to see this link.]
Windows 5.1.2600 Disk: ST980811AS rev.3.ALC -> Harddisk0\DR0 -> \Device\Ide\IdeDeviceP0T0L0-3
device: opened successfully
user: MBR read successfully
error: Read A device attached to the system is not functioning.
kernel: MBR read successfully
detected disk devices:
detected hooks:
\Driver\atapi DriverStartIo -> 0x86EF553B
user & kernel MBR OK
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe,-101"
"Enabled"=dword:00000001
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe"
@="IFlashBroker4"
"Version"="1.0"
Completion time: 2011-05-23 23:21:20
ComboFix-quarantined-files.txt 2011-05-23 13:21
Pre-Run: 6,501,830,656 bytes free
Post-Run: 6,639,632,384 bytes free
default=multi(0)disk(0)rdisk(0)partition(3)\WINDOWS
multi(0)disk(0)rdisk(0)partition(3)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
- - End Of File - - FB8FFE16F8B54C2F1A985B1D957BE88B
MBanks
Posts Posts : 92
Post by MBanks on Tue May 24, 2011 9:19 am
Any ideas on what to do next?
MBanks
Posts Posts : 92
Post by Gabethebabe on Tue May 24, 2011 11:38 am
can you run gmer?
Download GMER Rootkit Scanner from [You must be registered and logged in to see this link.] and save it to your desktop.
Note that it will have a random name.
  • Double click the file to run the tool. It may take a while to load.
  • If it gives you a warning about rootkit activity and asks if you want to run a full scan, click No
  • In the right panel, you will see several boxes that have been checked
  • Make sure this is unchecked: Show All
  • Make sure only your system drive (usually C:\) is checked and uncheck all other drives you might have on your system
  • Click Scan to start the scan
  • When it has finished, click Save and save the log as gmer.txt on your desktop
  • If GMER reports any <--- ROOTKIT entries, donīt take any action. It could be a false positive.
  • Click OK to quit GMER.
  • Please post the contents of gmer.txt into your next reply.
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Tue May 24, 2011 9:40 pm
I will try this when I get home from work this evening. I will have to run it in Safe Mode, I assume this is ok. Will post the log once it has completed.
Thanks.
MBanks
Posts Posts : 92
Post by MBanks on Wed May 25, 2011 8:30 am
I followed all the instructions and this is what happened....
The first time I tried to run it the program froze, closed itself.
The second time I had to leave the program running while I went and did some other things, I cam back and the computer had rebooted itself and got as far as the login/password entry stage in normal mode, i entered my password to log in, it loaded then the bluescreen and back to square one of the flashing cursor screen.
I just got home from work and started the laptop up in Safe Mode to try again and the laptop loaded up to windows, but the start bar new loaded or any items from the desktop.
Hopefully I can get it started up in Safe Mode again properly and try running the program again. Let me know if you have any other suggestions, otherwise I'll keep trying to run it until I can post the log.
MBanks
Posts Posts : 92
Post by MBanks on Wed May 25, 2011 8:38 am
P.S. The "Show All" tick box is greyed out, should that be right? You said to make sure it's not ticked.
MBanks
Posts Posts : 92
Post by MBanks on Wed May 25, 2011 8:47 am
Just tried it again, the program gets to a certain point the reboots itself with no warning.
What should I do, any ideas?
MBanks
Posts Posts : 92
Post by Gabethebabe on Thu May 26, 2011 12:05 pm
We are going to use the Recovery Console.
  • Please reboot your computer
  • During startup, a boot menu will appear for about 2 seconds
  • Choose the option Microsoft Windows Recovery Console by hitting the down arrow key
  • You will have to enter the Administrator password when prompted.
When you are in the recovery console command prompt type the following
copy c:\windows\system32\drivers\atapi.sys c:\suspectdriver.sys
You should receive a success message. After that type exit and hit enter to reboot back into normal safe mode. Find the file c:\suspectdriver.sys and copy it to your usb drive. Go to a clean computer and submit the file for analysis to [You must be registered and logged in to see this link.]. Copy the report url back here.
  • Please create a new text file in Notepad with the following contents:
    KILLALL::
    File::
    Driver::
    vbjx
  • Save that file as CFScript.txt on your desktop
  • Drag and drop the CFScript.txt onto the ComboFix icon, as shown in the animation below.
  • If done correctly, ComboFix will start and perform specific instructions
  • In doing so, ComboFix may request a reboot
  • Please post the contents of Combofix.txt in your next reply
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Sat May 28, 2011 12:24 am
Here is the URL for the report.
I dragged and dropped the as instructed above and then Combofix ran, and it said it needed to reboot, it never started up again, and now pressing the power button does nothing at all Sad tearing
MBanks
Posts Posts : 92
The charging light doesn't even come on when the mains power is plugged in.
MBanks
Posts Posts : 92
Post by MBanks on Sat May 28, 2011 12:28 am
Is there anyway to turn on the computer again to see if Combofix and finish and create the log for me to post?
MBanks
Posts Posts : 92
Post by MBanks on Sat May 28, 2011 2:01 am
False alarm. The power cable had been knocked from the wall and I guess it ran out of battery whilst trying to reboot or it just needed more power than it had.
I managed to start it up again in Safe Mode, Combofix automatically started running, it completed all 50 stages and has now been stuck on....
Deleting Files:
C:\Documents and Settings\Intel\Application Data\Sun\mxd1.txt
...for quite some time. I will leave it running all day and see what happens. Hopefully it will finish the scan and create the log for me to post back.
MBanks
Posts Posts : 92
Post by MBanks on Sat May 28, 2011 2:40 am
Well, it finished, and created the log, here it is:
ComboFix 11-05-22.01 - Intel 05/28/2011 11:15:51.2.1 - x86 MINIMAL
Command switches used :: c:\documents and settings\Intel\Desktop\CFScript.txt
FILE ::
"c:\windows\System32\drivers\dmecpam.sys"
c:\documents and settings\Intel\Application Data\Sun\mxd1.txt
-------\Service_vbjx
((((((((((((((((((((((((( Files Created from 2011-04-28 to 2011-05-28 )))))))))))))))))))))))))))))))
Rootkit scan 2011-05-28 12:28
detected hooks:
\Driver\atapi DriverStartIo -> 0x86F0853B
@="FlashBroker"
@="IFlashBroker4"
"Version"="1.0"
- - - - - - - > 'explorer.exe'(1968)
c:\windows\system32\msi.dll
Completion time: 2011-05-28 12:36:27 - machine was rebooted
ComboFix-quarantined-files.txt 2011-05-28 02:36
ComboFix2.txt 2011-05-23 13:21
Pre-Run: 6,631,878,656 bytes free
Post-Run: 6,567,243,776 bytes free
- - End Of File - - A5E96741630748558A9136CAD7840C76
I await further instruction. Thank you so much for all your help so far, I really appreciate it Smile
MBanks
Posts Posts : 92
Post by Gabethebabe on Sat May 28, 2011 8:03 am
Does your computer boot up in normal mode yet? I donīt suppose so, but you never know.
Combofix reported a cryptographic services error. Lets see if we can trouble shoot that.
go to start ==> run and type services.msc and hit enter
The services list should pop up.
Find the Cryptographic services and verify it is running. It probably is not. Rightclick and see if you can start it. Rightclick and and see if you can set its startup type to Automatic, in case it is disabled.
If you are unable to start this service, verify that the Remote Procedure Call (RPC) service is running and starts automatically. If not, try to start it and have it start up automatically. If that works, go back and see if you get Cryptographic service running again (Cryptographic service needs the RPC)
Report back your findings please.
Gabethebabe
Posts Posts : 1568
OS OS : Win7
Post by MBanks on Sat May 28, 2011 8:23 am
I'll try booting the computer into Normal mode to see what happens after I've made this post.
The services list popped up, I found a service called CryptSvc, I assume that is the one we are looking for.
It's status was continually 'Starting'. When I right click it and go to the properties menu I can see that the start up type is already Automatic, and I can't start it manually, all the buttons are greyed out, I think this could be because it is in a permanent state of 'starting'?
The Remote Procedure Call (RPC) is running (it's status is Started), and it's start up type is Automatic.
I will now try and reboot the computer into normal mode.
MBanks
Posts Posts : 92
Joined Joined : 2010-09-15
OS OS : Windows XP Home Edition SP3
Points Points : 24084
Re: Had a virus, ran MBAM, rebooted to fix the problem and now it's worse....
Post by MBanks on Sat May 28, 2011 8:31 am
It loaded to the log in page fine, I entered my password and Windows loaded, it was ok for about 30secs-1min and the the blue screen came up and it restarted.
MBanks
Posts Posts : 92
Post by Gabethebabe on Sat May 28, 2011 2:57 pm
Please restart your computer and before Windows starts loading, hit the F8 key a couple of times.
A menu appears with several boot options.
  • Choose Enable Boot Logging and continue to boot
  • After Windows has loaded, open Notepad
  • In Notepad choose File >> Open
  • In the Name field paste the following: c:\windows\ntbtlog.txt
  • Click Open to open the bootlog
  • Copy and paste it into your next reply
Gabethebabe
Posts Posts : 1568
Joined Joined : 2010-03-07
OS OS : Win7
Points Points : 38218
Post by MBanks on Sun May 29, 2011 12:55 am
Here is the ntbtlog...it was pretty hard doing all those instructions quick enough before the blue screen came up, it took a couple of tries but here it is:
It is a fairly long log, however there are a few sections where it is just repeating the same thing over and over, for a VERY long time. So that I can try and fit them all in I have left the repeated line out, using '...' at the end of the line to signify the repition and a '...' a few lines before the log varies again. If you need to see all the repeated lines then I could attach the log as a document for you to see?
Here's the log:
Service Pack 3 5 21 2011 15:27:10.500
Loaded driver \WINDOWS\system32\ntoskrnl.exe
Loaded driver \WINDOWS\system32\hal.dll
Loaded driver \WINDOWS\system32\KDCOM.DLL
Loaded driver \WINDOWS\system32\BOOTVID.dll
Loaded driver ACPI.sys
Loaded driver \WINDOWS\system32\DRIVERS\WMILIB.SYS
Loaded driver pci.sys
Loaded driver isapnp.sys
Loaded driver compbatt.sys
Loaded driver \WINDOWS\system32\DRIVERS\BATTC.SYS
Loaded driver pciide.sys
Loaded driver \WINDOWS\system32\DRIVERS\PCIIDEX.SYS
Loaded driver MountMgr.sys
Loaded driver ftdisk.sys
Loaded driver dmload.sys
Loaded driver dmio.sys
Loaded driver ACPIEC.sys
Loaded driver \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
Loaded driver PartMgr.sys
Loaded driver VolSnap.sys
Loaded driver atapi.sys
Loaded driver disk.sys
Loaded driver \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
Loaded driver fltmgr.sys
Loaded driver sr.sys
Loaded driver PxHelp20.sys
Loaded driver KSecDD.sys
Loaded driver Ntfs.sys
Loaded driver NDIS.sys
Loaded driver Mup.sys
Loaded driver MDFSYSNT.sys
Did not load driver ACPI Uniprocessor PC
Did not load driver Audio Codecs
Did not load driver Legacy Audio Drivers
Did not load driver Media Control Devices
Did not load driver Legacy Video Capture Devices
Did not load driver Video Codecs
Did not load driver WAN Miniport (L2TP)
Did not load driver WAN Miniport (IP)
Did not load driver WAN Miniport (PPPOE)
Did not load driver WAN Miniport (PPTP)
Did not load driver Packet Scheduler Miniport
Did not load driver Direct Parallel
Did not load driver Wireless Intermediate Driver
Did not load driver Intel Processor
Did not load driver Mobile Intel(R) 915GM/GMS,910GML Express Chipset Family
Did not load driver Microsoft ACPI-Compliant Control Method Battery
Did not load driver Microsoft AC Adapter
Did not load driver Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller
Loaded driver \SystemRoot\system32\DRIVERS\HDAudBus.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbuhci.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbehci.sys
Loaded driver \SystemRoot\system32\DRIVERS\i8042prt.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\ETD.sys
Loaded driver \SystemRoot\system32\DRIVERS\mouclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\ASUSACPI.sys
Loaded driver \SystemRoot\system32\DRIVERS\rdpdr.sys
Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys
Loaded driver \SystemRoot\system32\DRIVERS\VClone.sys
Loaded driver \SystemRoot\system32\DRIVERS\swenum.sys
Loaded driver \SystemRoot\system32\DRIVERS\update.sys
Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys
Did not load driver Realtek High Definition Audio
Loaded driver \SystemRoot\system32\DRIVERS\usbhub.sys
Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys
Loaded driver \SystemRoot\system32\DRIVERS\redbook.sys
Loaded driver \SystemRoot\system32\DRIVERS\GEARAspiWDM.sys
Did not load driver \SystemRoot\System32\Drivers\lbrtfdc.SYS
Did not load driver \SystemRoot\System32\Drivers\Fdc.SYS
Did not load driver \SystemRoot\System32\Drivers\Flpydisk.SYS
Did not load driver \SystemRoot\System32\Drivers\Sfloppy.SYS
Did not load driver \SystemRoot\System32\Drivers\i2omgmt.SYS
Did not load driver \SystemRoot\System32\Drivers\Changer.SYS
Did not load driver \SystemRoot\System32\Drivers\Cdaudio.SYS
Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.SYS
Loaded driver \SystemRoot\System32\Drivers\Null.SYS
Loaded driver \SystemRoot\System32\Drivers\Beep.SYS
Loaded driver \SystemRoot\System32\drivers\vga.sys
Did not load driver mnmdd.SYS
Did not load driver RDPCDD.SYS
Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS
Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS
Did not load driver RasAcd.SYS
Did not load driver IPSec.SYS
Did not load driver Tcpip.SYS
Did not load driver NetBT.SYS
Did not load driver AFD.SYS
Did not load driver NetBIOS.SYS
Did not load driver intelppm.SYS
Did not load driver \SystemRoot\System32\Drivers\PCIDump.SYS
Did not load driver WS2IFSL.SYS
Did not load driver Rdbss.SYS
Did not load driver MRxSmb.SYS
Did not load driver \SystemRoot\system32\DRIVERS\imapi.sys
Did not load driver Fips.SYS
Did not load driver ElbyCDIO.SYS
Did not load driver CbFs.SYS
Loaded driver \SystemRoot\system32\DRIVERS\usbccgp.sys
Did not load driver USB Video Device
Loaded driver \SystemRoot\System32\Drivers\Cdfs.SYS
Loaded driver \SystemRoot\system32\DRIVERS\WudfPf.sys
Did not load driver AFD.SYS....
(repeated lines)
...Did not load driver AFD.SYS
Loaded driver \SystemRoot\system32\DRIVERS\USBSTOR.SYS
(more endlessly repeated lines, it really goes on for AGES!!)
I'm running out of character space so I'll continue in new posts.
MBanks
Posts Posts : 92
Post by MBanks on Sun May 29, 2011 1:19 am
....Did not load driver AFD.SYS
Service Pack 3 5 21 2011 19:22:47.500
MBanks
Posts Posts : 92
Page 1 of 2 1, 2  Next
