Hello :) And a little problem!
Post by Malicius on 8th May 2011, 2:01 am
First of all, thank you all for the service you offer. It's wonderful. Goofy
Second, little thing. I had a problem and I was following the step you said to (OTL, aswMBR, etc.). The problem is that OTL is taking me.. hours.
Is that possible?
It's going from like two hours, and it stucks on a "Manual file Scan - Looking in Folder C:\Users\User\AppData\Local\Application Data\Application Data\Application Data\etc.".
It is checking these files for hours, I don't know if it's normal. I restarted it once, but nothing changed.
Thank you anyway
Malicius
Posts Posts : 5
Joined Joined : 2011-05-07
OS OS : Windows Vista
Points Points : 20491
Re: Hello :) And a little problem!
Post by Buttons on 8th May 2011, 2:06 am
Hi and welcome to GeekPolice! Smile
If you have any problems go ahead and post in the forum below with a description of the problem and what you've done and one of the staff will be able to help you.Smile
http://www.GeekPolice.net/f11-virus-spyware-malware-removal
Buttons
Posts Posts : 869
Joined Joined : 2010-06-11
OS OS : 7 Ultimate x64
Points Points : 26326
Post by houndmom on 9th May 2011, 12:16 am
Hey, Welcome to GeekPolice.net!! Hooray!
If we have helped you, Please consider helping us,  make a donation.
Helping fight malware.
houndmom
Posts Posts : 1053
Joined Joined : 2010-04-27
OS OS : Windows 7 ultimate
Protection Protection : Bitdefender Total Security 2010
Points Points : 29807
Post by HeroLee on 10th June 2011, 9:15 am
Glad to be GeekPolice.net! Bow or Thanks
HeroLee
Posts Posts : 7
Joined Joined : 2011-06-10
OS OS : Windows 7 & Mac
Points Points : 20222
