Ran Malwarebyte and still having problems
Post by cailinaingeal on Sun 08 May 2011, 3:51 am
I have run Malwarebyte. It did find infected files and I removed them. Now none of my shortcuts on my desktop or quick launch will not work. When I try clicking on a shortcut I get an Open With pop-up.
Malwarebytes' Anti-Malware 1.50
Database version: 6523
Windows 6.0.6002 Service Pack 2
Internet Explorer 9.0.8112.16421
5/6/2011 10:50:41 PM
mbam-log-2011-05-06 (22-50-41).txt
Scan type: Quick scan
Objects scanned: 144204
Time elapsed: 7 minute(s), 24 second(s)
Memory Processes Infected: 1
Registry Keys Infected: 2
Registry Values Infected: 1
Files Infected: 3
c:\Users\Owner\AppData\Local\wyn.exe (Trojan.FakeAlert) -> 3920 -> Unloaded process successfully.
HKEY_CLASSES_ROOT\AppID\GamevanceText.DLL (Adware.GameVance) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\AppDataLow\gvtl (Adware.GameVance) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\.exe\shell\open\command\(default) (Hijack.ExeFile) -> Value: (default) -> Quarantined and deleted successfully.
c:\Users\Owner\AppData\Local\wyn.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\Owner\AppData\Local\Temp\jar_cache1644612214837611026.tmp (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\Owner\local settings\application data\wyn.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
cailinaingeal
Operating System : Vista
Re: Ran Malwarebyte and still having problems
Post by Crush on Sun 08 May 2011, 6:24 am
Download Combofix from any of the links below, and save it to your desktop.
Link 1
Link 2
Link 3
When saving ComboFix rename it to Combo-Fix.exe to prevent it from being blocked by malware.
Refer to this image:
  • To prevent your anti-virus application interfering with ComboFix we need to disable it. See here for a tutorial regarding how to do so if you are unsure.
Note: Please Do NOT mouseclick combofix's window while its running because it may call it to stall.
Crush
Tech Officer
Tech Officer
Post by cailinaingeal on Sun 08 May 2011, 8:12 am
ComboFix 11-05-06.05 - Owner 05/07/2011 16:35:49.1.2 - x86
Microsoft® Windows Vista™ Home Premium 6.0.6002.2.1252.1.1033.18.766.208 [GMT -4:00]
Running from: c:\users\Owner\Desktop\Combo-Fix.exe
SP: Windows Defender *Disabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
c:\drv\TVtuner\Liteon\Resources\_desktop.ini
c:\windows\Downloaded Program Files\f3initialsetup1.0.1.1.inf
c:\windows\Downloaded Program Files\popcaploader.dll
c:\windows\Downloaded Program Files\popcaploader.inf
((((((((((((((((((((((((( Files Created from 2011-04-07 to 2011-05-07 )))))))))))))))))))))))))))))))
2011-05-07 20:51 . 2011-05-07 20:51 -------- d-----w- c:\users\Owner\AppData\Local\temp
2011-05-07 20:51 . 2011-05-07 20:51 -------- d-----w- c:\users\Default\AppData\Local\temp
2011-05-06 12:36 . 2011-04-18 13:15 7071056 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{F3CB149C-CFF0-4FD5-A435-B04F66C1CFD0}\mpengine.dll
2011-04-28 08:51 . 2011-03-03 15:40 28672 ----a-w- c:\windows\system32\Apphlpdm.dll
2011-04-28 08:51 . 2011-03-03 13:35 4240384 ----a-w- c:\windows\system32\GameUXLegacyGDFs.dll
2011-04-28 08:50 . 2011-03-12 21:55 876032 ----a-w- c:\windows\system32\XpsPrint.dll
2011-04-15 03:23 . 2011-02-16 14:02 292864 ----a-w- c:\windows\system32\atmfd.dll
2011-04-15 03:23 . 2011-02-16 16:16 34304 ----a-w- c:\windows\system32\atmlib.dll
2011-04-15 03:23 . 2011-02-22 13:24 213504 ----a-w- c:\windows\system32\drivers\mrxsmb10.sys
2011-04-15 03:23 . 2011-02-22 13:24 79360 ----a-w- c:\windows\system32\drivers\mrxsmb20.sys
2011-04-15 03:23 . 2011-02-22 13:23 69632 ----a-w- c:\windows\system32\drivers\bowser.sys
2011-04-15 03:23 . 2011-02-22 13:23 106496 ----a-w- c:\windows\system32\drivers\mrxsmb.sys
2011-04-15 03:22 . 2011-03-10 17:03 1162240 ----a-w- c:\windows\system32\mfc42u.dll
2011-04-15 03:22 . 2011-03-10 17:03 1136640 ----a-w- c:\windows\system32\mfc42.dll
2011-04-15 03:22 . 2011-02-18 14:03 305152 ----a-w- c:\windows\system32\drivers\srv.sys
2011-04-15 03:22 . 2011-02-18 14:03 146432 ----a-w- c:\windows\system32\drivers\srv2.sys
2011-04-15 03:22 . 2011-02-18 14:03 102400 ----a-w- c:\windows\system32\drivers\srvnet.sys
2011-04-15 03:22 . 2011-03-02 15:44 86528 ----a-w- c:\windows\system32\dnsrslvr.dll
2011-04-15 03:22 . 2009-05-04 09:59 25088 ----a-w- c:\windows\system32\dnscacheugc.exe
2011-04-15 03:22 . 2011-03-03 13:25 2041856 ----a-w- c:\windows\system32\win32k.sys
2011-04-15 03:22 . 2011-03-03 15:42 739328 ----a-w- c:\windows\system32\inetcomm.dll
2011-04-15 03:22 . 2011-03-03 10:50 2409784 ----a-w- c:\program files\Windows Mail\OESpamFilter.dat
2011-04-14 07:39 . 2011-04-14 07:39 103864 ----a-w- c:\program files\Internet Explorer\Plugins\nppdf32.dll
2011-03-03 15:40 . 2011-04-28 08:51 173056 ----a-w- c:\windows\apppatch\AcXtrnal.dll
2011-03-03 15:40 . 2011-04-28 08:51 458752 ----a-w- c:\windows\apppatch\AcSpecfc.dll
2011-03-03 15:40 . 2011-04-28 08:51 542720 ----a-w- c:\windows\apppatch\AcLayers.dll
2011-03-03 15:40 . 2011-04-28 08:51 2159616 ----a-w- c:\windows\apppatch\AcGenral.dll
2011-02-22 14:13 . 2011-03-23 10:48 288768 ----a-w- c:\windows\system32\XpsGdiConverter.dll
2011-02-22 13:33 . 2011-03-23 10:48 1068544 ----a-w- c:\windows\system32\DWrite.dll
2011-02-22 13:33 . 2011-03-23 10:48 797696 ----a-w- c:\windows\system32\FntCache.dll
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{392d065e-4679-4d12-8342-2a2d505fd309}"= "c:\program files\Quizulous2\prxtbQuiz.dll" [2011-01-03 175400]
[HKEY_CLASSES_ROOT\clsid\{392d065e-4679-4d12-8342-2a2d505fd309}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{30F9B915-B755-4826-820B-08FBA6BD249D}]
2011-01-03 15:16 175400 ----a-w- c:\program files\ConduitEngine\prxConduitEngine.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{392d065e-4679-4d12-8342-2a2d505fd309}]
2011-01-03 15:16 175400 ----a-w- c:\program files\Quizulous2\prxtbQuiz.dll
"{30F9B915-B755-4826-820B-08FBA6BD249D}"= "c:\program files\ConduitEngine\prxConduitEngine.dll" [2011-01-03 175400]
[HKEY_CLASSES_ROOT\clsid\{30f9b915-b755-4826-820b-08fba6bd249d}]
"{392D065E-4679-4D12-8342-2A2D505FD309}"= "c:\program files\Quizulous2\prxtbQuiz.dll" [2011-01-03 175400]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2008-01-19 202240]
"RtHDVCpl"="RtHDVCpl.exe" [2007-05-18 4468736]
"Apoint"="c:\program files\Apoint2K\Apoint.exe" [2007-06-06 159744]
"nmapp"="c:\program files\Pure Networks\Network Magic\nmapp.exe" [2006-06-24 1029712]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-12-04 13556256]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2008-12-04 92704]
"Skytel"="Skytel.exe" [2007-05-18 1826816]
"PLFSet"="c:\windows\PLFSet.dll" [2007-04-24 45056]
"GrooveMonitor"="c:\program files\Microsoft Office\Office12\GrooveMonitor.exe" [2008-10-25 31072]
"lxbkbmgr.exe"="c:\program files\Lexmark X1100 Series\lxbkbmgr.exe" [2008-02-28 74408]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2011-01-31 35760]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-09-21 932288]
"Malwarebytes' Anti-Malware (reboot)"="c:\program files\Malwarebytes' Anti-Malware\mbam.exe" [2010-11-29 963976]
@="Driver"
[HKLM\~\startupfolder\C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^Empowering Technology Launcher.lnk]
path=c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\Empowering Technology Launcher.lnk
backup=c:\windows\pss\Empowering Technology Launcher.lnk.CommonStartup
backupExtension=.CommonStartup
[HKLM\~\startupfolder\C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^McAfee Security Scan.lnk]
path=c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\McAfee Security Scan.lnk
backup=c:\windows\pss\McAfee Security Scan.lnk.CommonStartup
[HKLM\~\startupfolder\C:^Users^Owner^AppData^Roaming^Microsoft^Windows^Start Menu^Programs^Startup^OneNote 2007 Screen Clipper and Launcher.lnk]
path=c:\users\Owner\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\OneNote 2007 Screen Clipper and Launcher.lnk
backup=c:\windows\pss\OneNote 2007 Screen Clipper and Launcher.lnk.Startup
backupExtension=.Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Acer Assist Launcher]
2007-02-02 18:05 1261568 ----a-w- c:\program files\Acer Assist\launcher.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Acer Product Registration]
2007-02-02 19:24 3383296 ----a-w- c:\program files\Acer Registration\ACE1.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe ARM]
2010-09-21 03:07 932288 ----a-r- c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe Reader Speed Launcher]
2011-01-31 08:44 35760 ----a-w- c:\program files\Adobe\Reader 9.0\Reader\reader_sl.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\eAudio]
2007-06-11 21:54 1286144 ----a-w- c:\acer\Empowering Technology\eAudio\eAudio.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\eDataSecurity Loader]
2007-04-25 23:33 457216 ----a-w- c:\acer\Empowering Technology\eDataSecurity\eDSLoader.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ehTray.exe]
2008-01-19 07:33 125952 ----a-w- c:\windows\ehome\ehtray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\FaxCenterServer]
2007-06-11 19:28 312240 ----a-w- c:\program files\Lexmark Fax Solutions\fm3032.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\GrooveMonitor]
2008-10-25 16:44 31072 ----a-w- c:\program files\Microsoft Office\Office12\GrooveMonitor.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LManager]
2007-06-27 09:15 752136 ----a-w- c:\progra~1\LAUNCH~1\LManager.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\lxddamon]
2007-04-30 08:19 20480 ----a-w- c:\program files\Lexmark 2500 Series\lxddamon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\lxddmon.exe]
2007-06-11 19:27 291760 ----a-w- c:\program files\Lexmark 2500 Series\lxddmon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PlayMovie]
2007-05-24 20:38 206952 ------w- c:\program files\Acer Arcade Deluxe\Play Movie\PMVService.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PLFSet]
2007-04-24 18:49 45056 ----a-w- c:\windows\PLFSet.dll
2008-11-08 11:57 413696 ----a-w- c:\program files\QuickTime\qttask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Sidebar]
2009-04-11 06:28 1233920 ----a-w- c:\program files\Windows Sidebar\sidebar.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SunJavaUpdateSched]
2009-10-11 09:17 149280 ----a-w- c:\program files\Java\jre6\bin\jusched.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\swg]
2008-05-25 13:44 171448 ----a-w- c:\program files\Google\GoogleToolbarNotifier\1.2.1128.5462\GoogleToolbarNotifier.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\WMPNSCFG]
2008-01-19 07:33 202240 ----a-w- c:\program files\Windows Media Player\wmpnscfg.exe
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 lxddCATSCustConnectService;lxddCATSCustConnectService;c:\windows\system32\spool\DRIVERS\W32X86\3\\lxddserv.exe [2007-05-25 99248]
R3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe [2010-03-18 753504]
S2 {49DE1C67-83F8-4102-99E0-C16DCC7EEC796};{49DE1C67-83F8-4102-99E0-C16DCC7EEC796};c:\program files\Acer Arcade Deluxe\Play Movie\000.fcl [2006-11-02 13560]
S2 Akamai;Akamai NetSession Interface;c:\windows\System32\svchost.exe [2008-01-19 21504]
S2 ALaunchService;ALaunch Service;c:\acer\ALaunch\ALaunchSvc.exe [2007-01-26 50688]
S2 lxbk_device;lxbk_device;c:\windows\system32\lxbkcoms.exe [2008-02-19 537256]
S2 lxdd_device;lxdd_device;c:\windows\system32\lxddcoms.exe [2007-05-25 537520]
S3 enecir;ENE CIR Receiver;c:\windows\system32\DRIVERS\enecir.sys [2007-05-16 32256]
LocalServiceAndNoImpersonation REG_MULTI_SZ FontCache
Akamai REG_MULTI_SZ Akamai
IE: &AIM Toolbar Search - c:\programdata\AIM Toolbar\ieToolbar\resources\en-US\local\search.html
Toolbar-{0C8413C1-FAD1-446C-8584-BE50576F863E} - (no file)
WebBrowser-{0C8413C1-FAD1-446C-8584-BE50576F863E} - (no file)
HKCU-Run-Radio365Agent - (no file)
HKCU-RunServices-go[1] - c:\users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\SGBK38GL\go[1].exe
HKCU-RunServices-VisualStudio - c:\users\owner\appdata\locallow\sun\java\deployment\cache\6.0\54\1a209876-23b01448-n\msvcp71visual.exe
HKCU-RunServices-musiconeBooks - c:\users\Owner\AppData\Local\Microsoft\OneNote\12.0\Backup\Personal Notebook\Booksmovies.exe
HKCU-RunServices-SteinerHandbook - c:\users\Owner\Documents\Battletech\House Books\SteinerHouse.exe
HKCU-RunServices-CalendarOwners - c:\users\Owner\AppData\Local\Microsoft\Windows Calendar\Calendars\CalendarOwners13454.exe
HKCU-RunServices-HouseHandbook - c:\users\owner\documents\battletech\house books\steinerhouse.exe
HKCU-RunServices-FlashFlash - c:\users\owner\appdata\locallow\adobe\shockwave player 11\xtras\download\adobesystemsincorporated\flashasset\flashflash.exe
HKCU-RunServices-StudioStudio - c:\users\owner\appdata\locallow\sun\java\deployment\cache\6.0\46\759e98ee-66c2c11f-n\javafxmsvcp71.exe
HKLM-Run-eRecoveryService - (no file)
MSConfigStartUp-Acer Tour Reminder - c:\acer\AcerTour\Reminder.exe
MSConfigStartUp-ALaunch - c:\acer\ALaunch\AlaunchClient.exe
MSConfigStartUp-SetPanel - c:\acer\APanel\APanel.cmd
AddRemove-AHX-1 - c:\ahx-1\DeIsL1.isu
AddRemove-Galactic Civilizations II - Dread Lords - c:\progra~1\STARDO~1\GalCiv2\UNWISE.EXE
AddRemove-Radio365 2.1 - c:\progra~1\Live365\Radio365\UNWISE.EXE
Rootkit scan 2011-05-07 16:51
Windows 6.0.6002 Service Pack 2 NTFS
[HKEY_LOCAL_MACHINE\system\ControlSet001\Services\{49DE1C67-83F8-4102-99E0-C16DCC7EEC796}]
"ImagePath"="\??\c:\program files\Acer Arcade Deluxe\Play Movie\000.fcl"
@Denied: (A) (Users)
@Denied: (A) (Everyone)
"BlindDial"=dword:00000000
Completion time: 2011-05-07 16:58:15
ComboFix-quarantined-files.txt 2011-05-07 20:57
Pre-Run: 2,742,280,192 bytes free
Post-Run: 2,728,181,760 bytes free
- - End Of File - - 87C4503EB301C6C8987BC3A88C127321
cailinaingeal
Post by Crush on Mon 09 May 2011, 5:16 am
How's the machine running now?
Crush
Tech Officer
Tech Officer
Post by cailinaingeal on Mon 09 May 2011, 5:19 am
Everything seems to be working the way it should and back to normal speed. Thanks so much for your help.
cailinaingeal
Post by Crush on Mon 09 May 2011, 5:42 am
Great to hear we just have some housekeeping to do now.
I see you have Adobe Reader version 9 installed on here, this is old and has holes malware may abuse, we need to close these holes.
Go to Start > Control Panel > Add/Remove Programs and remove the following programs if present.
  • Adobe Reader 9
Then download and install Adobe Reader X from here:
Please download JavaRa from here
  • First, unzip it.
  • Then run JavaRa.
  • This will open JavaRa.
  • Press Remove older versions
  • Press yes to the prompt.
To uninstall ComboFix
Crush
Tech Officer
Tech Officer
Post by cailinaingeal on Mon 09 May 2011, 6:10 am
Housekeeping completed. Thanks!
cailinaingeal
Post by Crush on Mon 09 May 2011, 7:58 am
Happy to help
Crush
Tech Officer
Tech Officer
Post by Sponsored content Today at 9:29 pm
