connecting to work from home
Post by bonnysmum on Thu May 05, 2011 7:50 pm
I'm trying to connect to work system from home, the message I get is Secure VPN Connection terminated locally by the client. Reason 403 : Unable to contact the security gateway.
bonnysmum
OS : 7
Re: connecting to work from home
Post by Nazzgull on Fri May 06, 2011 12:50 pm
You're using Virtual Private Network ? You probably didn't set gateway property or you didn't enable Incoming VPN Connections . Try doing it one more, you can follow and learn whole process on link bellow :
http://www.sevenforums.com/tutorials/4517-virtual-private-network-vpn-enable-incoming-vpn-connections.html
One more interesting link :
http://www.pcworld.com/article/210562/how_to_set_up_vpn_in_windows_7.html
Regards
OS : Windows 7 Professional
