MS removal tool - Malwarebytes doesn't fix (also forum posting issues)
Re: MS removal tool - Malwarebytes doesn't fix (also forum posting issues)
Post by Belahzur on Fri May 06, 2011 7:18 pm
One more fix to do, just something I want to be sure of.
    "25565:TCP"=-
    "C:\Documents and Settings\Logan\My Documents\Downloads\Minecraft.exe"=-
I see that you are running FrostWire.
    Adobe Reader 9.1.2
    Java(TM) 6 Update 22
    FrostWire 4.20.7
Updating Java:
  • Click the "Download JRE" button to the right.
  • In the Window that opens, select your platform, check the "agree" box, and click Continue.
  • Then from your desktop double-click on jre-6u25-windows-i586.exe that you downloaded to install the newest version.
Then download and install [You must be registered and logged in to see this link.]
Also, please update Firefox again, update 4.0.1 was released a few days back. How is the machine running now?
Points Points : 245069
Post by logester on Sat May 21, 2011 2:49 am
You should update the instructions to Updating Java a bit.
Download the latest version of Java SE Runtime Environment (JRE) 6 Update 25.
On the new page, check the "agree" box.
After you have agreed, find (you press Ctrl+F and paste) jre-6u25-windows-i586.exe, across from Windows x86 Offline
Click it to download it.
Finally got around to [and figuring out that the instructions needed updating for] updating Java tonight, as I started a new job 2 weeks ago. Since nothing was updated, in the past 2 weeks, I got attacked by a similar virus, Malware Protection. I may have mentioned it before, I forget. It blocks all internet access unless in SafeMode with Networking with a task bar pop up saying W32/Blaster.worm. (However the last time it still popped up in Safe Mode), however Combo-Fix was able to kill it ever time by deleting defender.exe. (however the last time I tried, Combo-Fix had deleted itself saying it was out of date, so I had to re-download it form this thread while in Safe Mode With Networking).
Other than those 3 specific attacks, I have not had any other issues. All 3 attacks seemed to happen late at night [between midnight and 3am Atlantic time] while I had a DragonAge wikia page open. Not sure if it's the site or just the time. The first attack was from a movie streaming site heavily-laden with ads and such.
logester
Posts Posts : 24
Joined Joined : 2011-05-01
Points Points : 20808
