MS Removal Tool Problem
Post by squitman on 1st May 2011, 2:52 am
Ok heres the deal. I was fallowing your instructions on how to remove the problem
step 1. under my connections tab in Lan Settings, the box for using a proxy server is unchecked. so i moved on
step 2. when pressing f8 the option of starting safe mode isnt there, it shows something about choosing from different drives.
step 3. when i try using the malwarebytes program (the site would't come up so i found another download site) the ms removal says its infected, so i read that you told others to use a OTL program, so i tried that but ms removal also says that is infected Can't Believe It
i am very unsure of what to do please help
if it helps i am using a windows xp system
if you need more info ill try to help if i understand what you need thx!
squitman
Posts Posts : 21
Joined Joined : 2011-05-01
Points Points : 20773
Re: MS Removal Tool Problem
Post by Belahzur on 1st May 2011, 4:52 pm
Points Points : 245079
Post by squitman on 1st May 2011, 5:55 pm
It won't let the program run, it keeps telling me its infected.
squitman
Posts Posts : 21
Post by Belahzur on 2nd May 2011, 4:59 pm
We need to use the RKill Tool by Grinler
  • Please Download Rkill.com. Save it to your Desktop.
  • Before we begin, you should disable your anti-malware softwares you have installed so they do not interfere RKill running as some anti-malware softwares detect RKill as malicious. Please refer to this [You must be registered and logged in to see this link.] if you are not sure how.
  • NOTE: If you are unable to connect to the site to download rkill, then you should download it to a clean computer and copy it to the infected one via a USB flash drive or CDROM.
  • Once it is downloaded, double-click on the rkill.com in order to automatically attempt to stop any processes associated with Rogue programs.
  • Please be patient while the program looks for various malware programs and ends them.
  • When it has finished, the black window will automatically close and you can continue with the next step.
NOTE: If you get a message that rkill is an infection, do not be concerned. This message is just a fake warning given by the rogue program, when it terminates programs that may potentially remove it. If you run into these infections warnings that close Rkill, a trick is to leave the warning on the screen and then run Rkill again. By not closing the warning, this typically will allow you to bypass the malware trying to protect itself so that rkill can terminate the rogue program. So, please try running Rkill until the malware is no longer running. You will then be able to proceed with the rest of the steps.
If you continue having problems running rkill.com, you can download:
[You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
which are renamed copies of rkill.com, and try them instead.
Try using OTL now.
Post by squitman on 5th May 2011, 11:30 am
Extras.Txt
OTL Extras logfile created on: 5/5/2011 7:17:20 AM - Run 1
OTL by OldTimer - Version 3.2.22.3 Folder = C:\Documents and Settings\teresa\Desktop
Windows XP Home Edition Service Pack 2 (Version = 5.1.2600) - Type = NTWorkstation
446.00 Mb Total Physical Memory | 108.00 Mb Available Physical Memory | 24.00% Memory free
2.00 Gb Paging File | 2.00 Gb Available in Paging File | 86.00% Paging File free
Paging file location(s): C:\pagefile.sys 1536 3072 [binary data]
Drive C: | 223.55 Gb Total Space | 40.11 Gb Free Space | 17.94% Space Free | Partition Type: NTFS
Drive D: | 9.34 Gb Total Space | 9.29 Gb Free Space | 99.47% Space Free | Partition Type: NTFS
Computer Name: TERESA-6ADA04CE | User Name: teresa | Logged in as Administrator.
.cpl [@ = cplfile] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
comfile [open] -- "%1" %*
cplfile [cplopen] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
exefile [open] -- "%1" %*
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
"FirstRunDisabled" = 1
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"UpdatesDisableNotify" = 0
"AntiVirusOverride" = 0
"FirewallOverride" = 0
"DisableSR" = 0
"Start" = 0
"Start" = 2
"1900:UDP" = 1900:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22007
"2869:TCP" = 2869:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22008
"10243:TCP" = 10243:TCP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
"10280:UDP" = 10280:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
"10281:UDP" = 10281:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
"10282:UDP" = 10282:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
"10283:UDP" = 10283:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
"10284:UDP" = 10284:UDP:LocalSubNet:Enabled:Windows Media Player Network Sharing Service
"9355:TCP" = 9355:TCP:*:Enabled:bnvenzs
"C:\Program Files\BitTorrent\BitTorrent.exe" = C:\Program Files\BitTorrent\BitTorrent.exe:*:Enabled:BitTorrent -- (BitTorrent, Inc.)
"C:\Program Files\Ares\Ares.exe" = C:\Program Files\Ares\Ares.exe:*:Enabled:Ares p2p for windows
"{26A24AE4-039D-4CA4-87B4-2F83216023FF}" = Java(TM) 6 Update 23
"{72DF62BD-FF36-424E-AA5F-D89BAFF2C249}" = RollerCoaster Tycoon 2
"{76C24F39-B161-498F-BD8B-C64789812D13}_is1" = ConvertXtoDVD 3.0.0.9
"{7E265513-8CDA-4631-B696-F40D983F3B07}_is1" = CDBurnerXP
"{97DF1C46-FCCE-4591-9974-5A12CE667B9D}" = Tournament Maker
"{CC8E0363-B20C-4792-8A1C-8DF5E01B68A6}" = GoGear VIBE Device Manager
"{E623BB3F-F7ED-4148-BEB5-A0D1DB28B4DE}" = Media Converter for Philips
"Adobe Shockwave Player" = Adobe Shockwave Player 11.5
"ATI Display Driver" = ATI Display Driver
"Be Rich 1.00" = Be Rich 1.00
"BigJon PCGames Config Wizard1.1" = BigJon PCGames Config Wizard
"BitTorrent" = BitTorrent
"BitTorrentBar Toolbar" = BitTorrentBar Toolbar
"Casino-Worldwide" = Casino-Worldwide (Remove Only)
"conduitEngine" = Conduit Engine
"Deal or No Deal3.5.x" = Deal or No Deal
"Deal or No Deal3.6.x" = Deal or No Deal
"Eastside UK Free Agent Utility - NHL EHM 2007_is1" = Eastside UK Free Agent Utility v2007.2
"Eastside UK pre-game Editor for NHL EHM 2007_is1" = Eastside UK pre-game Editor v2007.1.7
"Eastside UK saved game Editor for NHL EHM 2007_is1" = Eastside UK saved game Editor v2007.0.4
"Fish Tycoon_is1" = Fish Tycoon
"Swag_Bucks Toolbar" = Swag Bucks Toolbar
"vShare" = vShare Plugin
"WIC" = Windows Imaging Component
"Your Product1.0" = Your Product
[ Application Events ]
Error - 4/26/2011 5:54:21 PM | Computer Name = TERESA-6ADA04CE | Source = crypt32 | ID = 131080
Description = Failed auto update retrieval of third-party root list sequence number
with error: This network connection does not exist.
Error - 4/26/2011 5:57:28 PM | Computer Name = TERESA-6ADA04CE | Source = Application Hang | ID = 1002
Description = Hanging application iexplore.exe, version 8.0.6001.18702, hang module
hungapp, version 0.0.0.0, hang address 0x00000000.
Error - 4/26/2011 5:57:30 PM | Computer Name = TERESA-6ADA04CE | Source = Application Hang | ID = 1002
Error - 4/27/2011 7:24:17 PM | Computer Name = TERESA-6ADA04CE | Source = Application Hang | ID = 1002
Description = Hanging application ehm2007.exe, version 0.0.0.0, hang module hungapp,
Error - 4/29/2011 1:30:52 AM | Computer Name = TERESA-6ADA04CE | Source = Application Hang | ID = 1002
Error - 4/30/2011 4:09:55 PM | Computer Name = TERESA-6ADA04CE | Source = crypt32 | ID = 131080
with error: The server name or address could not be resolved
Error - 4/30/2011 4:09:55 PM | Computer Name = TERESA-6ADA04CE | Source = crypt32 | ID = 131077
Description = Failed auto update retrieval of third-party root certificate from:
[ System Events ]
Error - 5/4/2011 11:52:39 PM | Computer Name = TERESA-6ADA04CE | Source = DCOM | ID = 10005
Description = DCOM got error "%1053" attempting to start the service gupdate with
arguments "/comsvc" in order to run the server: {4EB61BAC-A3B6-4760-9581-655041EF4D69}
Error - 5/4/2011 11:52:40 PM | Computer Name = TERESA-6ADA04CE | Source = Service Control Manager | ID = 7009
Description = Timeout (30000 milliseconds) waiting for the Google Update Service
(gupdate) service to connect.
Error - 5/4/2011 11:52:40 PM | Computer Name = TERESA-6ADA04CE | Source = Service Control Manager | ID = 7000
Description = The Google Update Service (gupdate) service failed to start due to
the following error: %%1053
Error - 5/4/2011 11:52:40 PM | Computer Name = TERESA-6ADA04CE | Source = Service Control Manager | ID = 7034
Description = The IMAPI CD-Burning COM Service service terminated unexpectedly.
It has done this 1 time(s).
Error - 5/4/2011 11:52:57 PM | Computer Name = TERESA-6ADA04CE | Source = Service Control Manager | ID = 7009
Description = Timeout (30000 milliseconds) waiting for the Windows Media Player
Network Sharing Service service to connect.
Error - 5/4/2011 11:52:57 PM | Computer Name = TERESA-6ADA04CE | Source = Service Control Manager | ID = 7000
Description = The Windows Media Player Network Sharing Service service failed to
start due to the following error: %%1053
Error - 5/4/2011 11:57:35 PM | Computer Name = TERESA-6ADA04CE | Source = DCOM | ID = 10010
Description = The server {FBA44040-BD27-4A09-ACC8-C08B7C723DCD} did not register
with DCOM within the required timeout.
Error - 5/5/2011 10:14:43 AM | Computer Name = TERESA-6ADA04CE | Source = DCOM | ID = 10005
Description = DCOM got error "%1058" attempting to start the service BITS with arguments
"" in order to run the server: {4991D34B-80A1-4291-83B6-3328366B9097}
Error - 5/5/2011 10:14:48 AM | Computer Name = TERESA-6ADA04CE | Source = DCOM | ID = 10005
Error - 5/5/2011 10:14:58 AM | Computer Name = TERESA-6ADA04CE | Source = Service Control Manager | ID = 7023
Description = The Shell Support service terminated with the following error: %%1114
squitman
Posts Posts : 21
OTL.Txt
OTL logfile created on: 5/5/2011 7:17:20 AM - Run 1
PRC - [2011/05/01 13:53:23 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\teresa\Desktop\OTL.exe
PRC - [2011/03/24 17:51:18 | 000,400,760 | ---- | M] (BitTorrent, Inc.) -- C:\Program Files\BitTorrent\BitTorrent.exe
PRC - [2010/03/18 12:19:26 | 000,113,152 | ---- | M] (ArcSoft Inc.) -- C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
PRC - [2010/03/04 22:38:00 | 000,071,096 | ---- | M] () -- C:\Program Files\CDBurnerXP\NMSAccessU.exe
PRC - [2009/12/03 13:05:08 | 001,701,224 | ---- | M] (Philips) -- C:\Program Files\Philips\GoGear VIBE Device Manager\GoGear_Vibe_DeviceManager.exe
PRC - [2004/08/04 05:00:00 | 001,032,192 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
MOD - [2011/05/01 13:53:23 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\teresa\Desktop\OTL.exe
MOD - [2004/08/04 05:00:00 | 001,050,624 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2180_x-ww_a84f1ff9\comctl32.dll
SRV - File not found [Disabled | Stopped] -- -- (HidServ)
SRV - File not found [On_Demand | Stopped] -- -- (AppMgmt)
SRV - [2010/03/18 12:19:26 | 000,113,152 | ---- | M] (ArcSoft Inc.) [Auto | Running] -- C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe -- (ACDaemon)
SRV - [2010/03/04 22:38:00 | 000,071,096 | ---- | M] () [Auto | Running] -- C:\Program Files\CDBurnerXP\NMSAccessU.exe -- (NMSAccess)
DRV - [2011/03/13 12:49:40 | 000,004,096 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\04.tmp -- (fabhbuua)
DRV - [2010/09/07 20:20:56 | 006,141,544 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RtkHDAud.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
DRV - [2009/11/18 08:17:00 | 001,395,800 | ---- | M] (Creative Technology Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Monfilt.sys -- (Monfilt)
DRV - [2009/11/18 08:16:00 | 001,691,480 | ---- | M] (Creative) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Ambfilt.sys -- (Ambfilt)
DRV - [2009/11/12 13:48:56 | 000,007,168 | ---- | M] () [File_System | On_Demand | Stopped] -- C:\WINDOWS\System32\drivers\StarOpen.sys -- (StarOpen)
DRV - [2006/06/16 23:09:48 | 001,611,776 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
DRV - [2004/08/03 15:31:34 | 000,020,992 | ---- | M] (Realtek Semiconductor Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RTL8139.sys -- (rtl8139) Realtek RTL8139(A/B/C)
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Secondary Start Pages = [You must be registered and logged in to see this link.] [binary data]
IE - HKCU\..\URLSearchHook: {88c7f2aa-f93f-432c-8f0e-b7d85967a527} - C:\Program Files\BitTorrentBar\tbBitT.dll (Conduit Ltd.)
IE - HKCU\..\URLSearchHook: {8bdea9d6-6f62-45eb-8ee9-8a81af0d2f94} - C:\Program Files\Swag_Bucks\prxtbSwa0.dll (Conduit Ltd.)
FF - HKLM\software\mozilla\Firefox\extensions\\{B728AB94-9BC7-49b7-B76A-422BB31B2FD0}: C:\Program Files\ArcSoft\Media Converter for Philips\Internet Video Downloader\Plugin_FireFox [2011/02/24 19:35:54 | 000,000,000 | ---D | M]
O1 HOSTS File: ([2004/08/04 05:00:00 | 000,000,734 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (vShare Toolbar) - {043C5167-00BB-4324-AF7E-62013FAEDACF} - C:\Program Files\vShare\vshare_toolbar.dll ()
O2 - BHO: (IEPlugin Class) - {11222041-111B-46E3-BD29-EFB2449479B1} - C:\Program Files\ArcSoft\Media Converter for Philips\Internet Video Downloader\ArcURLRecord.dll (ArcSoft, Inc.)
O2 - BHO: (Conduit Engine ) - {30F9B915-B755-4826-820B-08FBA6BD249D} - C:\Program Files\ConduitEngine\prxConduitEngine.dll (Conduit Ltd.)
O2 - BHO: (BitTorrentBar Toolbar) - {88c7f2aa-f93f-432c-8f0e-b7d85967a527} - C:\Program Files\BitTorrentBar\tbBitT.dll (Conduit Ltd.)
O2 - BHO: (Swag Bucks Toolbar) - {8bdea9d6-6f62-45eb-8ee9-8a81af0d2f94} - C:\Program Files\Swag_Bucks\prxtbSwa0.dll (Conduit Ltd.)
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.7.6406.1642\swg.dll (Google Inc.)
O3 - HKLM\..\Toolbar: (vShare Toolbar) - {043C5167-00BB-4324-AF7E-62013FAEDACF} - C:\Program Files\vShare\vshare_toolbar.dll ()
O3 - HKLM\..\Toolbar: (Conduit Engine ) - {30F9B915-B755-4826-820B-08FBA6BD249D} - C:\Program Files\ConduitEngine\prxConduitEngine.dll (Conduit Ltd.)
O3 - HKLM\..\Toolbar: (BitTorrentBar Toolbar) - {88c7f2aa-f93f-432c-8f0e-b7d85967a527} - C:\Program Files\BitTorrentBar\tbBitT.dll (Conduit Ltd.)
O3 - HKLM\..\Toolbar: (Swag Bucks Toolbar) - {8bdea9d6-6f62-45eb-8ee9-8a81af0d2f94} - C:\Program Files\Swag_Bucks\prxtbSwa0.dll (Conduit Ltd.)
O3 - HKCU\..\Toolbar\WebBrowser: (vShare Toolbar) - {043C5167-00BB-4324-AF7E-62013FAEDACF} - C:\Program Files\vShare\vshare_toolbar.dll ()
O3 - HKCU\..\Toolbar\WebBrowser: (BitTorrentBar Toolbar) - {88C7F2AA-F93F-432C-8F0E-B7D85967A527} - C:\Program Files\BitTorrentBar\tbBitT.dll (Conduit Ltd.)
O3 - HKCU\..\Toolbar\WebBrowser: (Swag Bucks Toolbar) - {8BDEA9D6-6F62-45EB-8EE9-8A81AF0D2F94} - C:\Program Files\Swag_Bucks\prxtbSwa0.dll (Conduit Ltd.)
O4 - HKLM..\Run: [ArcSoft Connection Service] C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe (ArcSoft Inc.)
O4 - HKLM..\Run: [KernelFaultCheck] File not found
O4 - HKCU..\Run: [ares] File not found
O4 - HKCU..\Run: [BitTorrent] C:\Program Files\BitTorrent\BitTorrent.exe (BitTorrent, Inc.)
O4 - HKCU..\RunOnce: [aE31002OeLpD31002] File not found
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Philips GoGear VIBE Device Manager.lnk = C:\Program Files\Philips\GoGear VIBE Device Manager\GoGear_Vibe_DeviceManager.exe (Philips)
O8 - Extra context menu item: Google Sidewiki... - C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_D1E1F7ED622A0E5D.dll (Google Inc.)
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} [You must be registered and logged in to see this link.] (WUWebControl Class)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_23)
O16 - DPF: {8F6E7FB2-E56B-4F66-A4E1-9765D2565280} [You must be registered and logged in to see this link.] (WorldWinner ActiveX Launcher Control)
O16 - DPF: {CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_23)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_23)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.2.1
O18 - Protocol\Handler\vsharechrome {3F3A4B8A-86FC-43A4-BB00-6D7EBE9D4484} - C:\Program Files\vShare\vshare_toolbar.dll ()
O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
O24 - Desktop WallPaper: C:\WINDOWS\Web\Wallpaper\Bliss.bmp
O24 - Desktop BackupWallPaper: C:\WINDOWS\Web\Wallpaper\Bliss.bmp
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2011/01/25 00:48:59 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O33 - MountPoints2\{0ee4fd9c-5437-11e0-acfb-001676343fb2}\Shell - "" = AutoRun
O33 - MountPoints2\{0ee4fd9c-5437-11e0-acfb-001676343fb2}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{0ee4fd9c-5437-11e0-acfb-001676343fb2}\Shell\AutoRun\command - "" = C:\WINDOWS\system32\RunDLL32.EXE Shell32.DLL,ShellExec_RunDLL RuNdLl32.EXE .\RECYCLER\S-5-3-42-2819952290-8240758988-879315005-3665\jwgkvsq.vmx,ahaezedrn
O33 - MountPoints2\{afa00f98-404a-11e0-aca1-001676343fb2}\Shell - "" = AutoRun
O33 - MountPoints2\{afa00f98-404a-11e0-aca1-001676343fb2}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{afa00f98-404a-11e0-aca1-001676343fb2}\Shell\AutoRun\command - "" = C:\WINDOWS\system32\RunDLL32.EXE Shell32.DLL,ShellExec_RunDLL RuNdLl32.EXE .\RECYCLER\S-5-3-42-2819952290-8240758988-879315005-3665\jwgkvsq.vmx,ahaezedrn
O33 - MountPoints2\{f089f9cb-32f7-11e0-ac82-001676343fb2}\Shell - "" = AutoRun
O33 - MountPoints2\{f089f9cb-32f7-11e0-ac82-001676343fb2}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{f089f9cb-32f7-11e0-ac82-001676343fb2}\Shell\AutoRun\command - "" = C:\WINDOWS\system32\RunDLL32.EXE Shell32.DLL,ShellExec_RunDLL RuNdLl32.EXE .\RECYCLER\S-5-3-42-2819952290-8240758988-879315005-3665\jwgkvsq.vmx,ahaezedrn
[2011/05/01 13:53:23 | 000,580,608 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\teresa\Desktop\OTL.exe
[2011/04/30 22:32:41 | 000,000,000 | ---D | C] -- C:\WINDOWS\Minidump
[2011/04/30 21:37:30 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\aE31002OeLpD31002
[2011/04/24 08:46:08 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Google
[2011/04/24 00:35:44 | 000,000,000 | ---D | C] -- C:\Documents and Settings\teresa\Application Data\Google
[2011/04/23 23:12:20 | 000,000,000 | ---D | C] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Google
[2011/04/23 23:11:39 | 000,000,000 | ---D | C] -- C:\Documents and Settings\teresa\Local Settings\Application Data\Google
[2011/04/23 23:11:26 | 000,000,000 | ---D | C] -- C:\Program Files\Google
[2011/04/23 23:11:26 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Google
[2011/04/23 23:09:14 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\Adobe
[2011/04/18 19:21:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Canneverbe Limited
[2011/04/18 19:20:59 | 000,000,000 | ---D | C] -- C:\Documents and Settings\teresa\Application Data\Canneverbe Limited
[2011/04/18 19:20:31 | 000,000,000 | ---D | C] -- C:\Program Files\CDBurnerXP
[2011/04/10 02:30:37 | 000,000,000 | ---D | C] -- C:\Documents and Settings\teresa\My Documents\My Received Files
[2011/02/03 16:54:03 | 000,047,360 | ---- | C] (VSO Software) -- C:\Documents and Settings\teresa\Application Data\pcouffin.sys
[1998/04/26 23:00:00 | 000,570,128 | ---- | C] (Microsoft Corporation) -- C:\Program Files\Common Files\DAO350.DLL
[4 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[3 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[2011/05/05 07:21:49 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2011/05/05 07:21:13 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2011/05/05 07:14:34 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2011/05/04 20:49:58 | 001,228,854 | ---- | M] () -- C:\fsqwr.bmp
[2011/04/28 22:17:43 | 000,013,646 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2011/04/26 23:08:53 | 000,161,792 | ---- | M] () -- C:\Documents and Settings\teresa\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2011/04/18 19:20:36 | 000,001,604 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\CDBurnerXP.lnk
[2011/04/18 19:17:22 | 000,000,668 | ---- | M] () -- C:\Documents and Settings\teresa\Application Data\vso_ts_preview.xml
[2011/04/30 22:31:39 | 001,228,854 | ---- | C] () -- C:\fsqwr.bmp
[2011/04/23 23:11:53 | 000,000,886 | ---- | C] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2011/04/23 23:11:51 | 000,000,882 | ---- | C] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2011/04/18 19:20:36 | 000,001,604 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\CDBurnerXP.lnk
[2011/04/18 19:20:36 | 000,001,556 | ---- | C] () -- C:\Documents and Settings\All Users\Start Menu\Programs\CDBurnerXP.lnk
[2011/04/18 19:20:33 | 000,007,168 | ---- | C] () -- C:\WINDOWS\System32\drivers\StarOpen.sys
[2011/03/30 15:20:51 | 000,071,680 | ---- | C] () -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2011/02/25 19:11:32 | 000,000,105 | ---- | C] () -- C:\WINDOWS\gvcasinos.ini
[2011/02/07 13:11:54 | 000,161,792 | ---- | C] () -- C:\Documents and Settings\teresa\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2011/02/03 16:54:19 | 000,000,668 | ---- | C] () -- C:\Documents and Settings\teresa\Application Data\vso_ts_preview.xml
[2011/02/03 16:54:03 | 000,087,608 | ---- | C] () -- C:\Documents and Settings\teresa\Application Data\inst.exe
[2011/02/03 16:54:03 | 000,007,887 | ---- | C] () -- C:\Documents and Settings\teresa\Application Data\pcouffin.cat
[2011/02/03 16:54:03 | 000,001,144 | ---- | C] () -- C:\Documents and Settings\teresa\Application Data\pcouffin.inf
[2011/01/25 17:12:05 | 000,000,664 | ---- | C] () -- C:\WINDOWS\System32\d3d9caps.dat
[2011/01/25 00:52:04 | 000,002,048 | --S- | C] () -- C:\WINDOWS\bootstat.dat
[2011/01/25 00:42:24 | 000,021,640 | ---- | C] () -- C:\WINDOWS\System32\emptyregdb.dat
[2011/01/24 16:29:20 | 000,004,161 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
[2011/01/24 16:27:18 | 000,093,480 | ---- | C] () -- C:\WINDOWS\System32\FNTCACHE.DAT
[2006/04/28 17:05:14 | 000,127,614 | ---- | C] () -- C:\WINDOWS\System32\atiicdxx.dat
[2004/08/04 05:00:00 | 013,107,200 | ---- | C] () -- C:\WINDOWS\System32\oembios.bin
[2004/08/04 05:00:00 | 000,673,088 | ---- | C] () -- C:\WINDOWS\System32\mlang.dat
[2004/08/04 05:00:00 | 000,432,356 | ---- | C] () -- C:\WINDOWS\System32\perfh009.dat
[2004/08/04 05:00:00 | 000,272,128 | ---- | C] () -- C:\WINDOWS\System32\perfi009.dat
[2004/08/04 05:00:00 | 000,218,003 | ---- | C] () -- C:\WINDOWS\System32\dssec.dat
[2004/08/04 05:00:00 | 000,161,750 | RHS- | C] () -- C:\WINDOWS\System32\jjjzqn.dll
[2004/08/04 05:00:00 | 000,067,312 | ---- | C] () -- C:\WINDOWS\System32\perfc009.dat
[2004/08/04 05:00:00 | 000,046,258 | ---- | C] () -- C:\WINDOWS\System32\mib.bin
[2004/08/04 05:00:00 | 000,028,626 | ---- | C] () -- C:\WINDOWS\System32\perfd009.dat
[2004/08/04 05:00:00 | 000,027,440 | ---- | C] () -- C:\WINDOWS\System32\drivers\secdrv.sys
[2004/08/04 05:00:00 | 000,004,569 | ---- | C] () -- C:\WINDOWS\System32\secupd.dat
[2004/08/04 05:00:00 | 000,004,461 | ---- | C] () -- C:\WINDOWS\System32\oembios.dat
[2004/08/04 05:00:00 | 000,001,788 | ---- | C] () -- C:\WINDOWS\System32\Dcache.bin
[2004/08/04 05:00:00 | 000,000,741 | ---- | C] () -- C:\WINDOWS\System32\noise.dat
squitman
Posts Posts : 21
Post by Belahzur on 5th May 2011, 6:34 pm
Please run OTL.exe.
    :OTL
    :commands
    [emptytemp]
    [reboot]
  • Close OTL.exe
Post by squitman on 5th May 2011, 7:45 pm
All processes killed
========== OTL ==========
Registry value HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce\\aE31002OeLpD31002 not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{0ee4fd9c-5437-11e0-acfb-001676343fb2}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{0ee4fd9c-5437-11e0-acfb-001676343fb2}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{0ee4fd9c-5437-11e0-acfb-001676343fb2}\ not found.
File C:\WINDOWS\system32\RunDLL32.EXE Shell32.DLL,ShellExec_RunDLL RuNdLl32.EXE .\RECYCLER\S-5-3-42-2819952290-8240758988-879315005-3665\jwgkvsq.vmx,ahaezedrn not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{afa00f98-404a-11e0-aca1-001676343fb2}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{afa00f98-404a-11e0-aca1-001676343fb2}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{afa00f98-404a-11e0-aca1-001676343fb2}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{f089f9cb-32f7-11e0-ac82-001676343fb2}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{f089f9cb-32f7-11e0-ac82-001676343fb2}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{f089f9cb-32f7-11e0-ac82-001676343fb2}\ not found.
Folder C:\Documents and Settings\All Users\Application Data\aE31002OeLpD31002\ not found.
[EMPTYTEMP]
User: All Users
User: Default User
->Temporary Internet Files folder emptied: 33170 bytes
User: LocalService
->Temp folder emptied: 66016 bytes
->Temporary Internet Files folder emptied: 2718502 bytes
User: NetworkService
->Temp folder emptied: 680950 bytes
->Temporary Internet Files folder emptied: 33237 bytes
User: teresa
->Temp folder emptied: 1356614505 bytes
->Temporary Internet Files folder emptied: 1537850818 bytes
->Java cache emptied: 68691608 bytes
->Flash cache emptied: 196708 bytes
%systemroot% .tmp files removed: 2142714 bytes
%systemroot%\System32 .tmp files removed: 10769 bytes
Windows Temp folder emptied: 17529025 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 65359874 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 2,911.00 mb
OTL by OldTimer - Version 3.2.22.3 log created on 05052011_153018
File\Folder C:\Documents and Settings\teresa\Local Settings\Temp\~DFC392.tmp not found!
File\Folder C:\Documents and Settings\teresa\Local Settings\Temp\~DFCB64.tmp not found!
C:\Documents and Settings\teresa\Local Settings\Temporary Internet Files\Content.IE5\LXFYKD1C\swagbucks_com[4].htm moved successfully.
C:\Documents and Settings\teresa\Local Settings\Temporary Internet Files\Content.IE5\LXFYKD1C\t26931-ms-removal-tool-problem[1].htm moved successfully.
squitman
Posts Posts : 21
Post by Belahzur on 5th May 2011, 7:49 pm
Post by squitman on 5th May 2011, 8:20 pm
Malwarebytes' Anti-Malware 1.50.1.1100
Database version: 6515
5/5/2011 4:16:35 PM
mbam-log-2011-05-05 (16-16-35).txt
Scan type: Quick scan
Objects scanned: 130961
Time elapsed: 4 minute(s), 53 second(s)
Files Infected: 1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL\CheckedValue (PUM.Hijack.System.Hidden) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
c:\WINDOWS\system32\jjjzqn.dll (Net.Worm) -> Delete on reboot.
squitman
Posts Posts : 21
Post by Belahzur on 5th May 2011, 8:27 pm
  • Download combofix from here
Post by squitman on 6th May 2011, 8:18 pm
ComboFix 11-05-06.02 - teresa 05/06/2011 15:48:59.1.2 - x86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.446.234 [GMT -7:00]
Running from: c:\documents and settings\teresa\Desktop\Combo-Fix.exe
c:\documents and settings\teresa\Application Data\inst.exe
c:\documents and settings\teresa\Application Data\PriceGong
c:\documents and settings\teresa\Application Data\PriceGong\Data\1.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\a.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\b.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\c.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\d.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\e.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\f.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\g.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\h.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\i.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\J.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\k.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\l.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\m.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\mru.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\n.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\o.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\p.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\q.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\r.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\s.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\t.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\u.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\v.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\w.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\x.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\y.xml
c:\documents and settings\teresa\Application Data\PriceGong\Data\z.xml
c:\windows\gvcasinos.ini
((((((((((((((((((((((((( Files Created from 2011-04-06 to 2011-05-06 )))))))))))))))))))))))))))))))
2011-05-05 23:04 . 2011-05-05 23:04 -------- d-----w- c:\documents and settings\teresa\Application Data\Malwarebytes
2011-05-05 23:03 . 2010-12-21 01:09 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2011-05-05 23:03 . 2011-05-05 23:03 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2011-05-05 23:03 . 2011-05-05 23:04 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2011-05-05 23:03 . 2010-12-21 01:08 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
2011-05-05 22:30 . 2011-05-05 22:30 -------- d-----w- C:\_OTL
2011-05-01 04:37 . 2011-05-05 14:14 -------- d-----w- c:\documents and settings\All Users\Application Data\aE31002OeLpD31002
2011-04-24 15:46 . 2011-04-26 20:49 -------- d-----w- c:\documents and settings\NetworkService\Local Settings\Application Data\Google
2011-04-24 06:12 . 2011-04-26 20:16 -------- d-----w- c:\documents and settings\LocalService\Local Settings\Application Data\Google
2011-04-24 06:11 . 2011-04-26 14:33 -------- d-----w- c:\documents and settings\teresa\Local Settings\Application Data\Google
2011-04-24 06:11 . 2011-04-24 06:12 -------- d-----w- c:\program files\Google
2011-04-24 06:09 . 2011-04-24 06:17 -------- d-----w- c:\windows\system32\Adobe
2011-04-19 02:21 . 2011-04-19 02:21 -------- d-----w- c:\documents and settings\All Users\Application Data\Canneverbe Limited
2011-04-19 02:20 . 2011-04-19 02:20 -------- d-----w- c:\documents and settings\teresa\Application Data\Canneverbe Limited
2011-04-19 02:20 . 2009-11-12 20:48 7168 ----a-w- c:\windows\system32\drivers\StarOpen.sys
2011-04-19 02:20 . 2011-04-19 02:20 -------- d-----w- c:\program files\CDBurnerXP
1998-04-27 06:00 . 1998-04-27 06:00 570128 ----a-w- c:\program files\Common Files\DAO350.DLL
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{8bdea9d6-6f62-45eb-8ee9-8a81af0d2f94}"= "c:\program files\Swag_Bucks\prxtbSwa0.dll" [2011-01-17 175912]
"{88c7f2aa-f93f-432c-8f0e-b7d85967a527}"= "c:\program files\BitTorrentBar\tbBitT.dll" [2010-12-09 3911776]
[HKEY_CLASSES_ROOT\clsid\{8bdea9d6-6f62-45eb-8ee9-8a81af0d2f94}]
[HKEY_CLASSES_ROOT\clsid\{88c7f2aa-f93f-432c-8f0e-b7d85967a527}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{30F9B915-B755-4826-820B-08FBA6BD249D}]
2011-01-17 14:54 175912 ----a-w- c:\program files\ConduitEngine\prxConduitEngine.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{88c7f2aa-f93f-432c-8f0e-b7d85967a527}]
2010-12-09 20:51 3911776 ----a-w- c:\program files\BitTorrentBar\tbBitT.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{8bdea9d6-6f62-45eb-8ee9-8a81af0d2f94}]
2011-01-17 14:54 175912 ----a-w- c:\program files\Swag_Bucks\prxtbSwa0.dll
"{30F9B915-B755-4826-820B-08FBA6BD249D}"= "c:\program files\ConduitEngine\prxConduitEngine.dll" [2011-01-17 175912]
[HKEY_CLASSES_ROOT\clsid\{30f9b915-b755-4826-820b-08fba6bd249d}]
"{8BDEA9D6-6F62-45EB-8EE9-8A81AF0D2F94}"= "c:\program files\Swag_Bucks\prxtbSwa0.dll" [2011-01-17 175912]
"{88C7F2AA-F93F-432C-8F0E-B7D85967A527}"= "c:\program files\BitTorrentBar\tbBitT.dll" [2010-12-09 3911776]
"BitTorrent"="c:\program files\BitTorrent\BitTorrent.exe" [2011-03-25 400760]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2011-04-24 39408]
"RTHDCPL"="RTHDCPL.EXE" [2010-09-08 19573352]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-05-14 248552]
"ArcSoft Connection Service"="c:\program files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe" [2010-03-18 207360]
Philips GoGear VIBE Device Manager.lnk - c:\program files\Philips\GoGear VIBE Device Manager\GoGear_Vibe_DeviceManager.exe [2011-2-24 1701224]
"c:\\Program Files\\BitTorrent\\BitTorrent.exe"=
"9355:TCP"= 9355:TCP:bnvenzs
S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [4/23/2011 11:11 PM 136176]
S2 pgnmeqn;Shell Support;c:\windows\system32\svchost.exe -k netsvcs [8/4/2004 5:00 AM 14336]
S3 Ambfilt;Ambfilt;c:\windows\system32\drivers\Ambfilt.sys [1/26/2011 4:34 PM 1691480]
S3 fabhbuua;fabhbuua;\??\c:\windows\system32\04.tmp --> c:\windows\system32\04.tmp [?]
S3 gupdatem;Google Update Service (gupdatem);c:\program files\Google\Update\GoogleUpdate.exe [4/23/2011 11:11 PM 136176]
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Svchost - NetSvcs
pgnmeqn
2011-05-06 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2011-04-24 06:11]
2011-05-06 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_D1E1F7ED622A0E5D.dll/cmsidewiki.html
HKCU-Run-ares - c:\program files\Ares\Ares.exe
AddRemove-Be Rich 1.00 - c:\documents and settings\teresa\Desktop\games\Be Rich\Be Rich\Uninstall.exe
Rootkit scan 2011-05-06 16:00
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\fabhbuua]
"ImagePath"="\??\c:\windows\system32\04.tmp"
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10l_ActiveX.exe,-101"
"Enabled"=dword:00000001
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10l_ActiveX.exe"
@="IFlashBroker4"
"Version"="1.0"
- - - - - - - > 'winlogon.exe'(532)
Completion time: 2011-05-06 16:03:29
ComboFix-quarantined-files.txt 2011-05-06 23:03
Pre-Run: 46,766,415,872 bytes free
Post-Run: 46,989,594,624 bytes free
- - End Of File - - 10A0EB84AD706A5B7771AD7A73F64CAE
squitman
Posts Posts : 21
Post by Belahzur on 6th May 2011, 8:24 pm
I see that you are running BitTorrent.
    BitTorrent
    Swag Bucks Toolbar
Next,
  1. Close any open browsers.
    KILLALL::
    File::
    Folder::
    Registry::
    "9355:TCP"=-
    [-HKEY_LOCAL_MACHINE\System\ControlSet001\Services\fabhbuua]
    Driver::
    pgnmeqn
    fabhbuua
    NetSvc::
    pgnmeqn
Post by squitman on 6th May 2011, 10:28 pm
ComboFix 11-05-06.03 - teresa 05/06/2011 18:05:25.2.2 - x86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.446.244 [GMT -7:00]
Command switches used :: c:\documents and settings\teresa\Desktop\CFScript.txt
FILE ::
"c:\program files\Common Files\DAO350.DLL"
c:\documents and settings\All Users\Application Data\aE31002OeLpD31002\aE31002OeLpD31002
-------\Legacy_PGNMEQN
-------\Service_fabhbuua
-------\Service_pgnmeqn
((((((((((((((((((((((((( Files Created from 2011-04-07 to 2011-05-07 )))))))))))))))))))))))))))))))
squitman
Posts Posts : 21
Post by Belahzur on 7th May 2011, 1:30 pm
Run ESET Online Scan
Please do an online scan with [You must be registered and logged in to see this link.]. Please use Internet Explorer as it uses ActiveX.
  • Click on Scan.
Post by squitman on 12th August 2011, 10:01 pm
man its been a while, ok heres the thing i believe that the ms removal thing has been removed but yesterday my computer started to act very slow and these popup things seem to show up that show hello4 on them and now when i try opening internet explorer it just closes before it can load. I am currently in safe mode with networking and this is how i am here now. Im not sure where i should post this and get help so i figured i would put this here and hope for the best thanks.
squitman
Posts Posts : 21
Post by Belahzur on 13th August 2011, 12:25 am
Please download aswMBR from [You must be registered and logged in to see this link.]
  • Save aswMBR.exe to your Desktop
  • Double click aswMBR.exe to run it
  • Click the Scan button to start the scan as illustrated below
Note: Do not take action against any **Rootkit** entries until I have reviewed the log. Often there are [You must be registered and logged in to see this link.]
  • Once the scan finishes click Save log to save the log to your Desktop
  • Copy and paste the contents of aswMBR.txt back here for review
Post by squitman on 13th August 2011, 1:18 am
aswMBR version 0.9.8.978 Copyright(c) 2011 AVAST Software
Run date: 2011-08-12 21:15:56
21:15:56.875 OS Version: Windows 5.1.2600 Service Pack 2
21:15:56.875 Number of processors: 2 586 0x407
21:15:56.875 ComputerName: TERESA-6ADA04CE UserName: teresa
21:16:00.734 Initialize success
21:16:11.609 Disk 0 (boot) \Device\Harddisk0\DR0 -> \Device\Ide\IdeDeviceP3T0L0-9
21:16:11.625 Disk 0 Vendor: Hitachi_HDT725025VLA380 V5DOA7BA Size: 238475MB BusType: 3
21:16:11.640 Device \Driver\atapi -> DriverStartIo 8433331b
21:16:13.671 Disk 0 MBR read successfully
21:16:13.687 Disk 0 MBR scan
21:16:13.703 Disk 0 TDL4@MBR code has been found
21:16:13.718 Disk 0 Windows XP default MBR code found via API
21:16:13.734 Disk 0 MBR hidden
21:16:13.765 Disk 0 MBR [TDL4] **ROOTKIT**
21:16:13.781 Disk 0 trace - called modules:
21:16:13.796 ntoskrnl.exe CLASSPNP.SYS disk.sys >>UNKNOWN [0x843334d0]<<
21:16:13.828 1 nt!IofCallDriver -> \Device\Harddisk0\DR0[0x8437b558]
21:16:13.843 3 CLASSPNP.SYS[f759005b] -> nt!IofCallDriver -> [0x842d0148]
21:16:13.859 \Driver\atapi[0x843cf7c0] -> IRP_MJ_CREATE -> 0x843334d0
21:16:15.906 Scan finished successfully
21:16:54.140 Disk 0 MBR has been saved successfully to "C:\Documents and Settings\teresa\Desktop\MBR.dat"
21:16:54.203 The log file has been saved successfully to "C:\Documents and Settings\teresa\Desktop\aswMBR.txt"
squitman
Posts Posts : 21
Post by squitman on 15th August 2011, 8:05 pm
According to the forum im supposed to bump this after 2 days with no reply Smile
edit: its been 4 days now (any idea what i should do?)
squitman
Posts Posts : 21
Post by squitman on 19th August 2011, 12:19 pm
ok a weeks gone by i hope that means that i can re-bumb it.
any news on what i should do next?
squitman
Posts Posts : 21
Post by Dr Jay on 20th August 2011, 5:15 pm
Not sure where he went...re-run aswMBR and post a log please, so I can verify the infection...
Posts Posts : 13743
Points Points : 302211
Post by squitman on 20th August 2011, 5:46 pm
Run date: 2011-08-20 13:36:48
13:36:48.625 OS Version: Windows 5.1.2600 Service Pack 3
13:36:48.625 Number of processors: 2 586 0x407
13:36:48.625 ComputerName: TERESA-6ADA04CE UserName: teresa
13:38:08.781 Initialize success
13:38:41.578 Disk 0 (boot) \Device\Harddisk0\DR0 -> \Device\Ide\IdeDeviceP3T0L0-9
13:38:41.578 Disk 0 Vendor: Hitachi_HDT725025VLA380 V5DOA7BA Size: 238475MB BusType: 3
13:38:41.578 Device \Driver\atapi -> DriverStartIo 84b2731b
13:38:43.796 Disk 0 MBR read successfully
13:38:43.796 Disk 0 MBR scan
13:38:43.796 Disk 0 Windows XP default MBR code
13:38:44.328 Disk 0 scanning sectors +488392065
13:38:45.218 Disk 0 scanning C:\WINDOWS\system32\drivers
13:40:51.625 Service scanning
13:40:54.750 Modules scanning
13:42:05.359 Disk 0 trace - called modules:
13:42:05.359 ntkrnlpa.exe CLASSPNP.SYS disk.sys >>UNKNOWN [0x84b274d0]<<
13:42:05.359 1 nt!IofCallDriver -> \Device\Harddisk0\DR0[0x84bd0030]
13:42:05.359 3 CLASSPNP.SYS[f74dcfd7] -> nt!IofCallDriver -> [0x84b39810]
13:42:05.531 \Driver\atapi[0x84bcc030] -> IRP_MJ_CREATE -> 0x84b274d0
13:42:05.531 Scan finished successfully
13:43:19.390 Disk 0 MBR has been saved successfully to "C:\Documents and Settings\teresa\Desktop\MBR.dat"
13:43:19.390 The log file has been saved successfully to "C:\Documents and Settings\teresa\Desktop\aswMBR.txt"
edit: I should include that when im not in safe mode, i can hear the sounds of different ads while nothing is open.
squitman
Posts Posts : 21
Post by Dr Jay on 21st August 2011, 5:55 pm
Gotcha...let's check with a different tool...
Please download MBRCheck.exe by a_d_13 from one of the links provided below and save it to your desktop.
  • Double-click on MBRCheck.exe to run it.
  • It will open a black window...please do not fix anything (if it gives you an option).
  • When complete, you should see Done! Press ENTER to exit.... Press Enter on the keyboard.
  • A log named MBRCheck_date_time.txt (i.e. MBRCheck_07.21.10_10.22.51.txt) will appear on the desktop.
  • Please copy and paste the contents of that log in your next reply.
Posts Posts : 13743
Post by squitman on 21st August 2011, 8:08 pm
MBRCheck, version 1.2.3
(c) 2010, AD
Command-line:
Windows Version: Windows XP Home Edition
Windows Information: Service Pack 3 (build 2600)
Logical Drives Mask: 0x0000001d
Kernel Drivers (total 86):
0x804D7000 \WINDOWS\system32\ntoskrnl.exe
0x80700000 \WINDOWS\system32\hal.dll
0x84F5F000 \WINDOWS\system32\KDCOM.DLL
0xF79E3000 \WINDOWS\system32\BOOTVID.dll
0xF7580000 ACPI.sys
0xF7ACF000 \WINDOWS\system32\DRIVERS\WMILIB.SYS
0xF756F000 pci.sys
0xF75CF000 isapnp.sys
0xF7B97000 pciide.sys
0xF784F000 \WINDOWS\system32\DRIVERS\PCIIDEX.SYS
0xF75DF000 MountMgr.sys
0xF7550000 ftdisk.sys
0xF7857000 PartMgr.sys
0xF75EF000 VolSnap.sys
0xF7538000 atapi.sys
0xF75FF000 disk.sys
0xF760F000 \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
0xF7518000 fltmgr.sys
0xF7506000 sr.sys
0xF74EF000 KSecDD.sys
0xF74DC000 WudfPf.sys
0xF744F000 Ntfs.sys
0xF7422000 NDIS.sys
0xF7408000 Mup.sys
0xF7977000 \SystemRoot\system32\DRIVERS\usbohci.sys
0xF739C000 \SystemRoot\system32\DRIVERS\USBPORT.SYS
0xF79A7000 \SystemRoot\system32\DRIVERS\usbehci.sys
0xF763F000 \SystemRoot\system32\DRIVERS\imapi.sys
0xF764F000 \SystemRoot\system32\DRIVERS\cdrom.sys
0xF765F000 \SystemRoot\system32\DRIVERS\redbook.sys
0xF7379000 \SystemRoot\system32\DRIVERS\ks.sys
0xF7351000 \SystemRoot\system32\DRIVERS\HDAudBus.sys
0xF78EF000 \SystemRoot\system32\DRIVERS\RTL8139.SYS
0xF78FF000 \SystemRoot\system32\DRIVERS\fdc.sys
0xF766F000 \SystemRoot\system32\DRIVERS\i8042prt.sys
0xF791F000 \SystemRoot\system32\DRIVERS\mouclass.sys
0xF792F000 \SystemRoot\system32\DRIVERS\kbdclass.sys
0xF767F000 \SystemRoot\system32\DRIVERS\rasl2tp.sys
0xF7A67000 \SystemRoot\system32\DRIVERS\ndistapi.sys
0xF733A000 \SystemRoot\system32\DRIVERS\ndiswan.sys
0xF768F000 \SystemRoot\system32\DRIVERS\raspppoe.sys
0xF769F000 \SystemRoot\system32\DRIVERS\raspptp.sys
0xF797F000 \SystemRoot\system32\DRIVERS\TDI.SYS
0xF7329000 \SystemRoot\system32\DRIVERS\psched.sys
0xF76AF000 \SystemRoot\system32\DRIVERS\msgpc.sys
0xF79AF000 \SystemRoot\system32\DRIVERS\ptilink.sys
0xF79BF000 \SystemRoot\system32\DRIVERS\raspti.sys
0xF76BF000 \SystemRoot\system32\DRIVERS\termdd.sys
0xF7B75000 \SystemRoot\system32\DRIVERS\swenum.sys
0xF72CB000 \SystemRoot\system32\DRIVERS\update.sys
0xF7A7F000 \SystemRoot\system32\DRIVERS\mssmbios.sys
0xF76CF000 \SystemRoot\system32\DRIVERS\usbhub.sys
0xF7B79000 \SystemRoot\system32\DRIVERS\USBD.SYS
0xF76DF000 \SystemRoot\System32\Drivers\NDProxy.SYS
0xF7917000 \SystemRoot\system32\DRIVERS\flpydisk.sys
0xF7B81000 \SystemRoot\System32\Drivers\Fs_Rec.SYS
0xF7BF8000 \SystemRoot\System32\Drivers\Null.SYS
0xF7B85000 \SystemRoot\System32\Drivers\Beep.SYS
0xF7947000 \SystemRoot\System32\drivers\vga.sys
0xF728F000 \SystemRoot\System32\drivers\VIDEOPRT.SYS
0xF7B89000 \SystemRoot\System32\DRIVERS\RDPCDD.sys
0xF7967000 \SystemRoot\System32\Drivers\Msfs.SYS
0xF7987000 \SystemRoot\System32\Drivers\Npfs.SYS
0xF7AB3000 \SystemRoot\system32\DRIVERS\rasacd.sys
0xF725C000 \SystemRoot\system32\DRIVERS\ipsec.sys
0xF7203000 \SystemRoot\system32\DRIVERS\tcpip.sys
0xF71DB000 \SystemRoot\system32\DRIVERS\netbt.sys
0xF71B5000 \SystemRoot\system32\DRIVERS\ipnat.sys
0xF7193000 \SystemRoot\System32\drivers\afd.sys
0xF76FF000 \SystemRoot\system32\DRIVERS\netbios.sys
0xF7168000 \SystemRoot\system32\DRIVERS\rdbss.sys
0xF70F8000 \SystemRoot\system32\DRIVERS\mrxsmb.sys
0xF771F000 \SystemRoot\System32\Drivers\Cdfs.SYS
0xF7018000 \SystemRoot\System32\Drivers\dump_atapi.sys
squitman
Posts Posts : 21
Post by Dr Jay on 22nd August 2011, 8:37 pm
That is not a full log. Please re-run it and post a new log...
Posts Posts : 13743
Post by squitman on 23rd August 2011, 12:39 am
(c) 2010, AD
Command-line:
0xF7580000 ACPI.sys
0xF756F000 pci.sys
0xF75FF000 disk.sys
0xF7506000 sr.sys
0xF744F000 Ntfs.sys
0xF7422000 NDIS.sys
0xF7408000 Mup.sys
0xF795F000 \SystemRoot\system32\DRIVERS\usbohci.sys
0xF798F000 \SystemRoot\system32\DRIVERS\usbehci.sys
0xF78D7000 \SystemRoot\system32\DRIVERS\RTL8139.SYS
0xF78E7000 \SystemRoot\system32\DRIVERS\fdc.sys
0xF7907000 \SystemRoot\system32\DRIVERS\mouclass.sys
0xF7917000 \SystemRoot\system32\DRIVERS\kbdclass.sys
0xF7AB3000 \SystemRoot\system32\DRIVERS\ndistapi.sys
0xF7967000 \SystemRoot\system32\DRIVERS\TDI.SYS
0xF7997000 \SystemRoot\system32\DRIVERS\ptilink.sys
0xF79A7000 \SystemRoot\system32\DRIVERS\raspti.sys
0xF7B31000 \SystemRoot\system32\DRIVERS\swenum.sys
0xF7ACB000 \SystemRoot\system32\DRIVERS\mssmbios.sys
0xF7B35000 \SystemRoot\system32\DRIVERS\USBD.SYS
0xF790F000 \SystemRoot\system32\DRIVERS\flpydisk.sys
0xF7B3D000 \SystemRoot\System32\Drivers\Fs_Rec.SYS
0xF7C0D000 \SystemRoot\System32\Drivers\Null.SYS
0xF7B41000 \SystemRoot\System32\Drivers\Beep.SYS
0xF7937000 \SystemRoot\System32\drivers\vga.sys
0xF7B45000 \SystemRoot\System32\DRIVERS\RDPCDD.sys
0xF7957000 \SystemRoot\System32\Drivers\Msfs.SYS
0xF7977000 \SystemRoot\System32\Drivers\Npfs.SYS
0xF7A5B000 \SystemRoot\system32\DRIVERS\rasacd.sys
0xF7B53000 \SystemRoot\System32\Drivers\dump_WMILIB.SYS
0xBF800000 \SystemRoot\System32\win32k.sys
0xF7A83000 \SystemRoot\System32\drivers\Dxapi.sys
0xF792F000 \SystemRoot\System32\watchdog.sys
0xBF000000 \SystemRoot\System32\drivers\dxg.sys
0xF7C0B000 \SystemRoot\System32\drivers\dxgthk.sys
0xBFF50000 \SystemRoot\System32\framebuf.dll
0xBF012000 \SystemRoot\System32\ATMFD.DLL
0xF6D00000 \SystemRoot\system32\DRIVERS\ndisuio.sys
0xF6AFC000 \SystemRoot\System32\Drivers\Fastfat.SYS
0xF6AA4000 \SystemRoot\system32\DRIVERS\srv.sys
0x7C900000 \WINDOWS\system32\ntdll.dll
Processes (total 17):
0 System Idle Process
4 System
356 C:\WINDOWS\system32\smss.exe
408 csrss.exe
432 C:\WINDOWS\system32\winlogon.exe
480 C:\WINDOWS\system32\services.exe
492 C:\WINDOWS\system32\lsass.exe
644 C:\WINDOWS\system32\svchost.exe
732 svchost.exe
852 C:\WINDOWS\system32\svchost.exe
924 svchost.exe
1004 svchost.exe
1412 C:\WINDOWS\explorer.exe
148 C:\Program Files\Internet Explorer\iexplore.exe
228 C:\Program Files\Internet Explorer\iexplore.exe
320 C:\WINDOWS\system32\ctfmon.exe
1436 C:\Documents and Settings\teresa\Desktop\MBRCheck.exe
\\.\C: --> \\.\PhysicalDrive0 at offset 0x00000000`00007e00 (NTFS)
\\.\D: --> \\.\PhysicalDrive0 at offset 0x00000037`e2e8fc00 (NTFS)
PhysicalDrive0 Model Number: HitachiHDT725025VLA380, Rev: V5DOA7BA
Size Device Name MBR Status
232 GB \\.\PhysicalDrive0 Windows XP MBR code detected
SHA1: DA38B874B7713D1B51CBC449F4EF809B0DEC644A
Done!
squitman
Posts Posts : 21
Joined Joined : 2011-05-01
Points Points : 20773
Re: MS Removal Tool Problem
Post by Dr Jay on 23rd August 2011, 11:20 am
Very good.
Please download MySystem-Search from one of the following links:
  • Save the file to your Desktop.
  • Double-click on mss.exe
  • Allow it to run, and follow the prompts.
  • Once done, it will launch a log.
  • Post it in your next reply.
Note: the logs are long. Please use more than one post, if necessary.
Posts Posts : 13743
Post by squitman on 23rd August 2011, 10:12 pm
MySystem-Search
MSS v1.7
Basic System Information
Username: teresa - Date: 08/23/2011 - Time: 17:48:22
Processor type: x86 Family 15 Model 4 Stepping 7, GenuineIntel
Total processors: 2
Logon Server: \\TERESA-6ADA04CE
CD Emulation Drivers running?
Peer-to-Peer applications?
Security Tools Check
File associations
.exe=exefile
.scr=scrfile
.pif=piffile
.com=ComFile
.bat=batfile
.cmd=cmdfile
.log=txtfile
.txt=txtfile
.reg=regfile
.sys=sysfile
.dll=dllfile
.ini=inifile
.inf=inffile
Running processes
PROCESS PID PRIO PATH
smss.exe 356 Normal C:\WINDOWS\System32\smss.exe
csrss.exe 408 Normal C:\WINDOWS\system32\csrss.exe
winlogon.exe 432 High C:\WINDOWS\system32\winlogon.exe
services.exe 480 Normal C:\WINDOWS\system32\services.exe
lsass.exe 492 Normal C:\WINDOWS\system32\lsass.exe
svchost.exe 648 Normal C:\WINDOWS\system32\svchost.exe
svchost.exe 728 Normal C:\WINDOWS\system32\svchost.exe
svchost.exe 848 Normal C:\WINDOWS\system32\svchost.exe
svchost.exe 924 Normal C:\WINDOWS\system32\svchost.exe
svchost.exe 1012 Normal C:\WINDOWS\system32\svchost.exe
Explorer.EXE 1420 Normal C:\WINDOWS\Explorer.EXE
iexplore.exe 2040 Normal C:\Program Files\internet explorer\iexplore.exe
iexplore.exe 200 Normal C:\Program Files\internet explorer\iexplore.exe
ctfmon.exe 288 Normal C:\WINDOWS\system32\ctfmon.exe
mss.exe 740 Normal C:\Documents and Settings\teresa\Desktop\mss.exe
cmd.exe 1396 Normal C:\WINDOWS\system32\cmd.exe
pv.exe 1400 Normal C:\Documents and Settings\teresa\Desktop\pv.exe
User Profile check
! REG.EXE VERSION 3.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
ProfilesDirectory REG_EXPAND_SZ %SystemDrive%\Documents and Settings
DefaultUserProfile REG_SZ Default User
AllUsersProfile REG_SZ All Users
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-18
Flags REG_DWORD 0xc
State REG_DWORD 0x0
RefCount REG_DWORD 0x1
Sid REG_BINARY 010100000000000512000000
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-19
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\LocalService
Sid REG_BINARY 010100000000000513000000
Flags REG_DWORD 0x9
State REG_DWORD 0x0
CentralProfile REG_SZ
ProfileLoadTimeLow REG_DWORD 0xef4c9c06
ProfileLoadTimeHigh REG_DWORD 0x1cc61dd
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-20
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\NetworkService
Sid REG_BINARY 010100000000000514000000
Flags REG_DWORD 0x9
State REG_DWORD 0x0
ProfileLoadTimeLow REG_DWORD 0xec3c365c
RefCount REG_DWORD 0x2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\S-1-5-21-682003330-1788223648-2146976231-1004
ProfileImagePath REG_EXPAND_SZ %SystemDrive%\Documents and Settings\teresa
Sid REG_BINARY 010500000000000515000000828BA628A020966AE741F87FEC030000
Flags REG_DWORD 0x0
State REG_DWORD 0x100
ProfileLoadTimeLow REG_DWORD 0xf1b15860
RunLogonScriptSync REG_DWORD 0x0
OptimizedLogonStatus REG_DWORD 0xb
Current Scheduled Tasks
PATH: C:\Windows\Tasks
At1.job
At198.job
At199.job
At2.job
At200.job
At201.job
At202.job
At203.job
At204.job
At205.job
At206.job
At207.job
At208.job
At209.job
At210.job
At211.job
At212.job
At213.job
At214.job
At215.job
At216.job
At217.job
At218.job
At219.job
At220.job
At221.job
At3.job
At4.job
desktop.ini
SA.DAT
Windows Drivers and NT-Services
Volume in drive C has no label.
Volume Serial Number is 909E-42D5
08/17/2001 09:59 AM 3,072 audstub.sys
07/17/2004 03:35 PM 67,866 netwlan5.img
07/17/2004 03:36 PM 64,352 ativmc20.cod
07/18/2004 02:55 AM 129,045 cxthsfs2.cty
08/03/2004 06:31 PM 20,992 RTL8139.sys
08/04/2004 02:29 AM 57,856 atinbtxx.sys
08/04/2004 02:29 AM 327,040 ati2mtaa.sys
08/04/2004 02:29 AM 56,623 ati1btxx.sys
08/04/2004 02:29 AM 12,047 ati1pdxx.sys
08/04/2004 02:29 AM 13,824 atinmdxx.sys
08/04/2004 02:29 AM 14,336 atinpdxx.sys
08/04/2004 02:29 AM 52,224 atinraxx.sys
08/04/2004 02:29 AM 11,615 ati1mdxx.sys
08/04/2004 02:29 AM 26,367 ati1snxx.sys
08/04/2004 02:29 AM 13,824 atinttxx.sys
08/04/2004 02:29 AM 28,672 atinsnxx.sys
08/04/2004 02:29 AM 63,663 ati1rvxx.sys
08/04/2004 02:29 AM 104,960 atinrvxx.sys
08/04/2004 02:29 AM 30,671 ati1raxx.sys
08/04/2004 02:29 AM 31,744 atinxbxx.sys
08/04/2004 02:29 AM 36,463 ati1tuxx.sys
08/04/2004 02:29 AM 29,455 ati1xbxx.sys
08/04/2004 02:29 AM 34,735 ati1xsxx.sys
08/04/2004 02:29 AM 63,488 atinxsxx.sys
08/04/2004 02:29 AM 21,343 ati1ttxx.sys
08/04/2004 02:29 AM 73,216 atintuxx.sys
08/04/2004 02:29 AM 452,736 mtxparhm.sys
08/04/2004 02:29 AM 11,295 wadv08nt.sys
08/04/2004 02:29 AM 11,807 wadv07nt.sys
08/04/2004 02:29 AM 11,935 wadv11nt.sys
08/04/2004 02:29 AM 11,871 wadv09nt.sys
08/04/2004 02:29 AM 22,271 watv06nt.sys
08/04/2004 02:29 AM 25,471 watv10nt.sys
08/04/2004 02:29 AM 166,912 s3gnbm.sys
08/04/2004 02:29 AM 1,897,408 nv4_mini.sys
08/04/2004 02:41 AM 1,309,184 mtlstrm.sys
08/04/2004 02:41 AM 126,686 mtlmnt5.sys
08/04/2004 02:41 AM 180,360 ntmtlfax.sys
08/04/2004 02:41 AM 13,776 recagent.sys
08/04/2004 02:41 AM 129,535 slnt7554.sys
08/04/2004 02:41 AM 404,990 slntamr.sys
08/04/2004 02:41 AM 95,424 slnthal.sys
08/04/2004 02:41 AM 13,240 slwdmsup.sys
08/04/2004 02:41 AM 220,032 hsfbs2s2.sys
08/04/2004 02:41 AM 685,056 hsfcxts2.sys
08/04/2004 02:41 AM 1,041,536 hsfdpsp2.sys
08/04/2004 02:41 AM 11,868 mdmxsdk.sys
08/04/2004 08:00 AM 646 gmreadme.txt
08/04/2004 08:00 AM 55,936 nwlnkspx.sys
08/04/2004 08:00 AM 12,160 mouhid.sys
08/04/2004 08:00 AM 125,056 ftdisk.sys
08/04/2004 08:00 AM 12,032 ws2ifsl.sys
08/04/2004 08:00 AM 31,360 atmepvc.sys
08/04/2004 08:00 AM 5,888 rootmdm.sys
08/04/2004 08:00 AM 352,256 atmuni.sys
08/04/2004 08:00 AM 12,032 riodrv.sys
08/04/2004 08:00 AM 12,032 rio8drv.sys
08/04/2004 08:00 AM 11,648 acpiec.sys
08/04/2004 08:00 AM 7,680 mcd.sys
08/04/2004 08:00 AM 58,112 vdmindvd.sys
08/04/2004 08:00 AM 21,376 tsbvcap.sys
08/04/2004 08:00 AM 4,224 beep.sys
08/04/2004 08:00 AM 63,232 nwlnknb.sys
08/04/2004 08:00 AM 51,712 tosdvd.sys
08/04/2004 08:00 AM 4,224 rdpcdd.sys
08/04/2004 08:00 AM 4,736 usbd.sys
08/04/2004 08:00 AM 34,432 rawwan.sys
08/04/2004 08:00 AM 16,512 raspti.sys
08/04/2004 08:00 AM 32,896 ipfltdrv.sys
08/04/2004 08:00 AM 13,952 cbidf2k.sys
08/04/2004 08:00 AM 18,688 cdaudio.sys
08/04/2004 08:00 AM 12,160 fsvga.sys
08/04/2004 08:00 AM 3,456 oprghdlr.sys
08/04/2004 08:00 AM 8,832 rasacd.sys
08/04/2004 08:00 AM 262,528 cinemst2.sys
08/04/2004 08:00 AM 17,792 ptilink.sys
08/04/2004 08:00 AM 11,776 cpqdap01.sys
08/04/2004 08:00 AM 4,352 wmilib.sys
08/04/2004 08:00 AM 7,936 fs_rec.sys
08/04/2004 08:00 AM 4,224 mnmdd.sys
08/04/2004 08:00 AM 12,032 nikedrv.sys
08/04/2004 08:00 AM 14,592 smclib.sys
08/04/2004 08:00 AM 2,944 null.sys
08/04/2004 08:00 AM 3,328 pciide.sys
08/04/2004 08:00 AM 5,888 dmload.sys
08/04/2004 08:00 AM 3,440,660 gm.dls
08/04/2004 08:00 AM 6,784 parvdm.sys
08/04/2004 08:00 AM 12,416 nwlnkflt.sys
08/04/2004 08:00 AM 10,496 dxapi.sys
08/04/2004 08:00 AM 32,512 nwlnkfwd.sys
08/04/2004 08:00 AM 3,328 dxgthk.sys
01/07/2005 09:07 PM 145,920 Hdaudio.sys
10/14/2005 02:10 PM 58,560 ativckxx.vp
02/08/2006 08:44 PM 1,114,674 ativcaxx.cpa
02/08/2006 08:44 PM 929 ativcaxx.vp
06/17/2006 01:40 AM 45,056 ati2erec.dll
06/17/2006 02:09 AM 1,611,776 ati2mtag.sys
06/17/2006 02:55 AM 29,616 ativvpxx.vp
09/28/2006 10:55 PM 77,568 WudfPf.sys
09/28/2006 11:00 PM 82,944 WudfRd.sys
10/19/2006 12:00 AM 38,528 wpdusb.sys
04/13/2008 12:36 PM 144,384 hdaudbus.sys
04/13/2008 12:39 PM 20,480 secdrv.sys
04/13/2008 12:39 PM 142,592 aec.sys
04/13/2008 02:31 PM 35,840 processr.sys
04/13/2008 02:31 PM 42,752 p3.sys
04/13/2008 02:31 PM 36,736 crusoe.sys
04/13/2008 02:31 PM 37,376 amdk6.sys
04/13/2008 02:31 PM 36,352 intelppm.sys
04/13/2008 02:31 PM 37,760 amdk7.sys
04/13/2008 02:32 PM 66,048 udfs.sys
04/13/2008 02:32 PM 19,072 msfs.sys
04/13/2008 02:32 PM 30,848 npfs.sys
04/13/2008 02:32 PM 180,608 mrxdav.sys
04/13/2008 02:32 PM 196,224 rdpdr.sys
04/13/2008 02:32 PM 129,792 fltmgr.sys
04/13/2008 02:33 PM 44,544 fips.sys
04/13/2008 02:36 PM 5,888 smbali.sys
04/13/2008 02:36 PM 187,776 acpi.sys
04/13/2008 02:36 PM 42,368 agp440.sys
04/13/2008 02:36 PM 42,752 alim1541.sys
04/13/2008 02:36 PM 44,928 agpcpq.sys
04/13/2008 02:36 PM 40,960 sisagp.sys
04/13/2008 02:36 PM 43,008 amdagp.sys
04/13/2008 02:36 PM 42,240 viaagp.sys
04/13/2008 02:36 PM 44,672 uagp35.sys
04/13/2008 02:36 PM 46,464 gagp30kx.sys
04/13/2008 02:36 PM 37,248 isapnp.sys
04/13/2008 02:36 PM 63,744 mf.sys
04/13/2008 02:36 PM 120,192 pcmcia.sys
04/13/2008 02:36 PM 79,232 sdbus.sys
04/13/2008 02:36 PM 68,224 pci.sys
04/13/2008 02:36 PM 15,488 mssmbios.sys
04/13/2008 02:36 PM 73,472 sr.sys
04/13/2008 02:38 PM 71,168 dxg.sys
04/13/2008 02:39 PM 384,768 update.sys
04/13/2008 02:39 PM 42,368 mountmgr.sys
04/13/2008 02:39 PM 24,576 kbdclass.sys
04/13/2008 02:39 PM 23,040 mouclass.sys
04/13/2008 02:39 PM 5,376 mspclock.sys
04/13/2008 02:39 PM 4,992 mspqm.sys
04/13/2008 02:39 PM 7,552 mskssrv.sys
04/13/2008 02:39 PM 4,352 swenum.sys
04/13/2008 02:40 PM 80,128 parport.sys
04/13/2008 02:40 PM 15,744 serenum.sys
04/13/2008 02:40 PM 27,392 fdc.sys
04/13/2008 02:40 PM 20,480 flpydisk.sys
04/13/2008 02:40 PM 57,600 redbook.sys
04/13/2008 02:40 PM 24,960 pciidex.sys
04/13/2008 02:40 PM 96,512 atapi.sys
04/13/2008 02:40 PM 96,384 scsiport.sys
04/13/2008 02:40 PM 14,208 diskdump.sys
04/13/2008 02:40 PM 62,976 cdrom.sys
04/13/2008 02:40 PM 36,352 disk.sys
04/13/2008 02:40 PM 11,008 sffp_sd.sys
04/13/2008 02:40 PM 11,904 sffdisk.sys
04/13/2008 02:40 PM 11,392 sfloppy.sys
04/13/2008 02:40 PM 10,240 sffp_mmc.sys
04/13/2008 02:40 PM 19,712 partmgr.sys
04/13/2008 02:40 PM 14,976 tape.sys
04/13/2008 02:40 PM 42,112 imapi.sys
04/13/2008 02:41 PM 52,352 volsnap.sys
04/13/2008 02:43 PM 14,208 wacompen.sys
04/13/2008 02:43 PM 12,672 mutohpen.sys
04/13/2008 02:44 PM 20,992 vga.sys
04/13/2008 02:44 PM 81,664 videoprt.sys
04/13/2008 02:44 PM 153,344 dmio.sys
04/13/2008 02:44 PM 799,744 dmboot.sys
04/13/2008 02:45 PM 52,864 dmusic.sys
04/13/2008 02:45 PM 6,272 splitter.sys
04/13/2008 02:45 PM 172,416 kmixer.sys
04/13/2008 02:45 PM 56,576 swmidi.sys
04/13/2008 02:45 PM 2,944 drmkaud.sys
04/13/2008 02:45 PM 60,160 drmk.sys
04/13/2008 02:45 PM 49,408 stream.sys
04/13/2008 02:45 PM 24,960 hidparse.sys
04/13/2008 02:45 PM 19,200 hidir.sys
04/13/2008 02:45 PM 36,864 hidclass.sys
04/13/2008 02:45 PM 10,368 hidusb.sys
04/13/2008 02:45 PM 15,104 usbscan.sys
04/13/2008 02:45 PM 20,608 usbuhci.sys
04/13/2008 02:45 PM 30,208 usbehci.sys
04/13/2008 02:45 PM 17,152 usbohci.sys
04/13/2008 02:45 PM 143,872 usbport.sys
04/13/2008 02:45 PM 59,520 usbhub.sys
04/13/2008 02:45 PM 26,368 usbstor.sys
04/13/2008 02:45 PM 32,128 usbccgp.sys
04/13/2008 02:45 PM 25,600 usbcamd.sys
04/13/2008 02:45 PM 25,728 usbcamd2.sys
04/13/2008 02:45 PM 15,872 usbintel.sys
04/13/2008 02:46 PM 25,344 sonydcam.sys
04/13/2008 02:46 PM 121,984 usbvideo.sys
04/13/2008 02:46 PM 18,944 bthusb.sys
04/13/2008 02:46 PM 25,600 hidbth.sys
04/13/2008 02:46 PM 36,480 bthprint.sys
04/13/2008 02:46 PM 59,136 rfcomm.sys
04/13/2008 02:46 PM 37,888 bthmodem.sys
04/13/2008 02:46 PM 17,024 bthenum.sys
04/13/2008 02:47 PM 25,856 usbprint.sys
04/13/2008 02:51 PM 60,800 arp1394.sys
04/13/2008 02:51 PM 59,904 atmarpc.sys
04/13/2008 02:51 PM 61,824 nic1394.sys
04/13/2008 02:51 PM 55,808 atmlane.sys
04/13/2008 02:51 PM 101,120 bthpan.sys
04/13/2008 02:53 PM 40,320 nmnt.sys
04/13/2008 02:53 PM 71,552 bridge.sys
04/13/2008 02:53 PM 36,608 ip6fw.sys
04/13/2008 02:54 PM 11,264 irenum.sys
04/13/2008 02:55 PM 14,592 ndisuio.sys
04/13/2008 02:56 PM 12,288 tunmp.sys
04/13/2008 02:56 PM 34,688 netbios.sys
04/13/2008 02:56 PM 88,320 nwlnkipx.sys
04/13/2008 02:56 PM 35,072 msgpc.sys
04/13/2008 02:56 PM 69,120 psched.sys
04/13/2008 02:56 PM 30,592 rndismpx.sys
04/13/2008 02:56 PM 30,592 rndismp.sys
04/13/2008 02:56 PM 12,800 usb8023x.sys
04/13/2008 02:56 PM 12,800 usb8023.sys
04/13/2008 02:57 PM 20,864 ipinip.sys
04/13/2008 02:57 PM 152,832 ipnat.sys
04/13/2008 02:57 PM 34,560 wanarp.sys
04/13/2008 02:57 PM 14,336 asyncmac.sys
04/13/2008 02:57 PM 41,472 raspppoe.sys
04/13/2008 03:00 PM 19,072 tdi.sys
04/13/2008 03:00 PM 30,080 modem.sys
04/13/2008 03:14 PM 63,744 cdfs.sys
04/13/2008 03:14 PM 143,744 fastfat.sys
04/13/2008 03:15 PM 64,512 serial.sys
04/13/2008 03:15 PM 574,976 ntfs.sys
04/13/2008 03:15 PM 60,800 sysaudio.sys
04/13/2008 03:16 PM 49,536 classpnp.sys
04/13/2008 03:16 PM 141,056 ks.sys
04/13/2008 03:17 PM 83,072 wdmaud.sys
04/13/2008 03:18 PM 52,480 i8042prt.sys
04/13/2008 03:19 PM 146,048 portcls.sys
04/13/2008 03:19 PM 75,264 ipsec.sys
04/13/2008 03:19 PM 51,328 rasl2tp.sys
04/13/2008 03:19 PM 48,384 raspptp.sys
04/13/2008 03:20 PM 182,656 ndis.sys
04/13/2008 03:20 PM 91,520 ndiswan.sys
04/13/2008 03:21 PM 162,816 netbt.sys
04/13/2008 03:28 PM 175,744 rdbss.sys
04/13/2008 08:11 PM 4,255 adv01nt5.dll
04/13/2008 08:11 PM 3,967 adv02nt5.dll
04/13/2008 08:11 PM 3,615 adv05nt5.dll
04/13/2008 08:11 PM 3,647 adv07nt5.dll
04/13/2008 08:11 PM 3,135 adv08nt5.dll
04/13/2008 08:11 PM 3,711 adv09nt5.dll
04/13/2008 08:11 PM 3,775 adv11nt5.dll
04/13/2008 08:11 PM 15,423 ch7xxnt5.dll
04/13/2008 08:11 PM 11,359 atv02nt5.dll
04/13/2008 08:11 PM 25,471 atv04nt5.dll
04/13/2008 08:11 PM 14,143 atv06nt5.dll
04/13/2008 08:11 PM 17,279 atv10nt5.dll
04/13/2008 08:11 PM 21,183 atv01nt5.dll
04/13/2008 08:12 PM 3,901 siint5.dll
04/13/2008 08:12 PM 11,325 vchnt5.dll
04/13/2008 08:13 PM 12,040 tdpipe.sys
04/13/2008 08:13 PM 40,840 termdd.sys
04/13/2008 08:13 PM 21,896 tdtcp.sys
05/08/2008 10:02 AM 203,136 rmcast.sys
06/13/2008 07:05 AM 272,128 bthport.sys
06/20/2008 07:51 AM 361,600 tcpip.sys
06/24/2009 07:18 AM 92,928 ksecdd.sys
10/20/2009 12:20 PM 265,728 http.sys
11/12/2009 04:48 PM 7,168 StarOpen.sys
11/18/2009 11:16 AM 1,691,480 Ambfilt.sys
11/18/2009 11:17 AM 1,395,800 Monfilt.sys
02/11/2010 08:02 AM 226,880 tcpip6.sys
09/07/2010 11:20 PM 6,141,544 RtkHDAud.sys
11/02/2010 11:17 AM 40,960 ndproxy.sys
12/20/2010 09:08 PM 20,952 mbam.sys
12/20/2010 09:09 PM 38,224 mbamswissarmy.sys
01/24/2011 07:15 PM disdn
02/03/2011 07:54 PM 47,360 pcouffin.sys
02/16/2011 09:22 AM 138,496 afd.sys
02/17/2011 09:18 AM 357,888 srv.sys
02/24/2011 10:47 PM UMDF
04/21/2011 09:37 AM 105,472 mup.sys
06/24/2011 10:10 AM 139,656 rdpwd.sys
07/08/2011 10:02 AM 10,496 ndistapi.sys
07/15/2011 09:29 AM 456,320 mrxsmb.sys
08/12/2011 01:30 PM etc
08/21/2011 01:31 AM .
08/21/2011 01:31 AM ..
280 File(s) 37,665,216 bytes
5 Dir(s) 28,383,670,272 bytes free
Stealth malware?
Internet Explorer
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main
Default_Page_URL REG_SZ http://go.microsoft.com/fwlink/?LinkId=69157
Default_Search_URL REG_SZ http://go.microsoft.com/fwlink/?LinkId=54896
Search Page REG_SZ http://go.microsoft.com/fwlink/?LinkId=54896
Enable_Disk_Cache REG_SZ yes
Cache_Percent_of_Disk REG_BINARY 0A000000
Delete_Temp_Files_On_Exit REG_SZ yes
Local Page REG_SZ C:\WINDOWS\system32\blank.htm
Anchor_Visitation_Horizon REG_BINARY 01000000
Use_Async_DNS REG_SZ yes
Placeholder_Width REG_BINARY 1A000000
Placeholder_Height REG_BINARY 1A000000
Start Page REG_SZ http://go.microsoft.com/fwlink/?LinkId=69157
CompanyName REG_SZ Microsoft Corporation
Custom_Key REG_SZ MICROSO
Wizard_Version REG_SZ 6.0.2600.0000
FullScreen REG_SZ no
Default_Secondary_Page_URL REG_MULTI_SZ \0
Extensions Off Page REG_SZ about:NoAdd-ons
Security Risk Page REG_SZ about:SecurityRisk
Check_Associations REG_SZ yes
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\ErrorThresholds
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\UrlTemplate
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings
User Agent REG_SZ Mozilla/4.0 (compatible; MSIE 8.0; Win32)
IE5_UA_Backup_Flag REG_SZ 5.0
NoNetAutodial REG_DWORD 0x0
MigrateProxy REG_DWORD 0x1
EmailName REG_SZ IEUser@
AutoConfigProxy REG_SZ wininet.dll
MimeExclusionListForCache REG_SZ multipart/mixed multipart/x-mixed-replace multipart/x-byteranges
WarnOnPost REG_BINARY 01000000
UseSchannelDirectly REG_BINARY 01000000
EnableHttp1_1 REG_DWORD 0x1
PrivacyAdvanced REG_DWORD 0x1
EnableNegotiate REG_DWORD 0x1
ProxyEnable REG_DWORD 0x0
UrlEncoding REG_DWORD 0x0
SecureProtocols REG_DWORD 0x28
PrivDiscUiShown REG_DWORD 0x1
ZonesSecurityUpgrade REG_BINARY F06286E4C6BCCB01
DisableCachingOfSSLPages REG_DWORD 0x0
WarnonZoneCrossing REG_DWORD 0x0
SyncMode5 REG_DWORD 0x4
EnableAutodial REG_BINARY 00000000
WarnonBadCertRecving REG_DWORD 0x1
WarnOnPostRedirect REG_DWORD 0x0
WarnOnHTTPSToHTTPRedirect REG_DWORD 0x1
GlobalUserOffline REG_DWORD 0x0
5 REG_BINARY FBBAFB828C78456DC94A84B1101CB611697BE663E4AA6918D5CCC418CE013BBF19E12B05FB925F08BFAC48988D1C71144663A87FF42377E7705E57FBB31553621A362969E390CF24F557A1B1CF907CABA47D
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
2 REG_BINARY 67454E8B14CD6B1FE72A918DD0BAA1C17C363074CBC7C09556B9E611DACC097E374777ABDF632A70E19CB0399C60BFBA4A135663508B5E88D1A93028AA
7 REG_BINARY 9D4BB6D8DF024B08E95F33F07860676CE7B2
8 REG_BINARY 747E3B615C9D072CB817979B7838F8C8E086C9C5E97D76677D7FDF6E7E91186D842844E71B07F0094BA214F9FD8C094D0C37240B84A40544941DE6A9
maxhttpredirects REG_DWORD 0x270f
1 REG_BINARY 422E4752FC
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Cache
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Connections
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Lockdown_Zones
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\P3P
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Passport
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Protocols
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Url History
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main
NoUpdateCheck REG_DWORD 0x1
NoJITSetup REG_DWORD 0x1
Disable Script Debugger REG_SZ yes
Show_ChannelBand REG_SZ No
Anchor Underline REG_SZ yes
Cache_Update_Frequency REG_SZ Once_Per_Session
Display Inline Images REG_SZ yes
Do404Search REG_BINARY 01000000
Save_Session_History_On_Exit REG_SZ no
Show_FullURL REG_SZ no
Show_StatusBar REG_SZ yes
Show_ToolBar REG_SZ yes
Show_URLinStatusBar REG_SZ yes
Show_URLToolBar REG_SZ yes
Start Page REG_SZ http://ca.msn.com/
Use_DlgBox_Colors REG_SZ yes
Search Page REG_SZ http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
Window_Placement REG_BINARY 2C0000000000000001000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0000000000000000200300003A020000
NotifyDownloadComplete REG_SZ no
XMLHTTP REG_DWORD 0x1
UseClearType REG_SZ yes
Enable Browser Extensions REG_SZ yes
Play_Background_Sounds REG_SZ yes
Play_Animations REG_SZ yes
CompatibilityFlags REG_DWORD 0x0
IE8RunOnceLastShown REG_DWORD 0x1
IE8RunOnceLastShown_TIMESTAMP REG_BINARY E6F1C60C8461CC01
IE8TourShown REG_DWORD 0x1
IE8TourShownTime REG_BINARY BD10E675E7BCCB01
Use Search Asst REG_SZ no
Use FormSuggest REG_SZ no
FormSuggest Passwords REG_SZ yes
FormSuggest PW Ask REG_SZ yes
AutoHide REG_SZ yes
RunOnceHasShown REG_DWORD 0x1
RunOnceComplete REG_DWORD 0x1
Check_Associations REG_SZ no
Error Dlg Displayed On Every Error REG_SZ no
Error Dlg Details Pane Open REG_SZ yes
AlwaysShowMenus REG_DWORD 0x1
SearchControlWidth REG_DWORD 0x12c
DisableScriptDebuggerIE REG_SZ yes
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\Default Feeds
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\WindowsSearch
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Search
SearchAssistant REG_SZ http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchasst.htm
CustomizeSearch REG_SZ http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchcust.htm
{CFBFAE00-17A6-11D0-99CB-00C04FD64497} REG_SZ
{8bdea9d6-6f62-45eb-8ee9-8a81af0d2f94} REG_SZ
{88c7f2aa-f93f-432c-8f0e-b7d85967a527} REG_SZ
{0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} REG_SZ
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects
REG_SZ
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{11222041-111B-46E3-BD29-EFB2449479B1}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{30F9B915-B755-4826-820B-08FBA6BD249D}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{6EBF7485-159F-4bff-A14F-B9E3AAC4465B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{88c7f2aa-f93f-432c-8f0e-b7d85967a527}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{8bdea9d6-6f62-45eb-8ee9-8a81af0d2f94}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{9030D464-4C02-4ABF-8ECC-5164760863C6}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AA58ED58-01DD-4d91-8333-CF10577473F7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AF69DE43-7D58-4638-B6FA-CE66B5AD205D}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{B164E929-A1B6-4A06-B104-2CD0E90A88FF}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{d2ce3e00-f94a-4740-988e-03dc2f38c34f}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E7E6F031-17CE-4C07-BC86-EABFE594F69C}
{8bdea9d6-6f62-45eb-8ee9-8a81af0d2f94} REG_SZ Swag Bucks Toolbar
{30F9B915-B755-4826-820B-08FBA6BD249D} REG_SZ Conduit Engine
{2318C2B1-4965-11d4-9B18-009027A5CD4F} REG_BINARY 00
{8dcb7100-df86-4384-8842-8fa844297b3f} REG_BINARY 00
{0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} REG_SZ McAfee SiteAdvisor
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\MenuExt
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\MenuExt\Google Sidewiki...
Security Center
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center
FirstRunDisabled REG_DWORD 0x1
AntiVirusDisableNotify REG_DWORD 0x0
FirewallDisableNotify REG_DWORD 0x0
UpdatesDisableNotify REG_DWORD 0x0
AntiVirusOverride REG_DWORD 0x0
FirewallOverride REG_DWORD 0x0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\AhnlabAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ComputerAssociatesAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\KasperskyAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\PandaFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SophosAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\SymantecFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TinyFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendAntiVirus
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\TrendFirewall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\ZoneLabsFirewall
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\GloballyOpenPorts
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List
%windir%\system32\sessmgr.exe REG_SZ %windir%\system32\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019
C:\Program Files\Messenger\msmsgs.exe REG_SZ C:\Program Files\Messenger\msmsgs.exe:*:Enabled:Windows Messenger
C:\Program Files\HP\HP Deskjet 1050 J410 series\Bin\USBSetup.exe REG_SZ C:\Program Files\HP\HP Deskjet 1050 J410 series\Bin\USBSetup.exe:LocalSubNet:Enabled:HP Device Setup
Uninstall List
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AddressBook
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe AIR
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Shockwave Player
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ATI Display Driver
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\BFG-Fairway Solitaire
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\BFG-Gold Miner Vegas
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\BFGC
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\BigJon PCGames Config Wizard1.1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Branding
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Casino-Worldwide
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Conduit Engine
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\conduitEngine
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Connection Manager
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Coupon Printer for Windows5.0.0.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Deal or No Deal3.5.x
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Deal or No Deal3.6.x
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DirectAnimation
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DirectDrawEx
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DXM_Runtime
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Eastside UK Free Agent Utility - NHL EHM 2007_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Eastside UK pre-game Editor for NHL EHM 2007_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Eastside UK saved game Editor for NHL EHM 2007_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ESET Online Scanner
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Fairway Solitaire
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Fish Tycoon_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Fontcore
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\GameBiz - The magical years_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HP Photo Creations
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ICW
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IDNMitigationAPIs
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IE40
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IE4Data
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IE5BAKEX
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ie7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ie8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IEData
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\jtceiksgfmbaooaw
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2079403
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2115168
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2229593
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2296011
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2345886
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2347290
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2360937
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2378111_WM9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2387149
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2393802
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2412687
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2419632
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2423089
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2440591
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2443105
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2443685
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2476490
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2478960
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2478971
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2479943
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2481109
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2483185
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2485663
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2503665
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2506212
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2507618
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2507938
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2508272
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2508429
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2509553
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2510531-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2524375
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2535512
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2536276-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2541763
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2544521-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2544893
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2555917
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2559049-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2562937
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2566454
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2567680
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB2570222
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB884016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB884267
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB885353
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB886612
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB887078
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB887626
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB888111WXPSP2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB888656
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB889858
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB891122
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB892130
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB892313
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893240
squitman
Posts Posts : 21
Post by squitman on 23rd August 2011, 10:17 pm
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893241
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB893803
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB895181
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB895316
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB895572
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB897586
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB898549
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB900399
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB902344
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB907658
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB911565
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB911854
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB923561
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB929399
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB939683
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB941569
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB946648
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB950762
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB950974
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951376-v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951748
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB951978
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952004
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952069_WM9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952287
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB952954
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954154_WM11
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954155_WM9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB954550-v5
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB955069
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB955759
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956572
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956744
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956802
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956803
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB956844
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958644
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB958869
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB959426
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960225
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960803
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB960859
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961118
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB961501
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB967715
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB968389
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB969059
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB970238
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB970430
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971029
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971468
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971657
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971737
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB971961-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB972270
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973507
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973540_WM9L
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973687
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973815
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973869
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB973904
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974112
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974318
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974392
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB974571
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975025
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975467
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975558_WM8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975560
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975561
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975562
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB975713
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB976662-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB977816
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB977914
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978037
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978338
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978542
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978601
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978695_WM9
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB978706
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979309
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979402_WM9L
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979482
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979559
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979683
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB979687
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980195
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980218
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980232
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB980436
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB981322
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB981332-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB981793
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB981997
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB982132
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB982381-IE8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\KB982665
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Malwarebytes' Anti-Malware_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\McAfee Security Scan
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft .NET Framework 3.5 SP1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MobileOptionPack
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MPlayer2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSCompPackV1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-Beta1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-Beta2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-KB884016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-RC1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30-RC2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI30a-KB884016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI31-Beta
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MSI31-RC1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\NetMeeting
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\NLSDownlevelMapping
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\OutlookExpress
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PCHealth
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SchedulingAgent
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Swag Bucks Toolbar
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Swag_Bucks Toolbar
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\vShare
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WGA
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WIC
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Windows Media Format Runtime
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Windows Media Player
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Windows XP Service Pack
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WinRAR archiver
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WMCSetup
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WMFDist11
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\wmp11
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Wudf01000
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Your Product1.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{06E6E30D-B498-442F-A943-07DE41D7F785}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{08234a0d-cf39-4dca-99f0-0c5cb496da81}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0840B4D6-7DD1-4187-8523-E6FC0007EFB7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{18455581-E099-4BA8-BC6B-F34B2F06600C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{2318C2B1-4965-11d4-9B18-009027A5CD4F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{26A24AE4-039D-4CA4-87B4-2F83216023FF}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{35ED3F83-4BDC-4c44-8EC6-6A8301C7413A}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4A03706F-666A-4037-7777-5F2748764D10}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4F7177E9-2B54-48B4-AAFD-03FA1F87A542}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{56EA8BC0-3751-4B93-BC9D-6651CC36E5AA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5C90D8CF-F12A-41C6-9007-3B651A1F0D78}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6BE73D27-5ADC-4AD9-B619-8F5188AFCF9F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{72DF62BD-FF36-424E-AA5F-D89BAFF2C249}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{76C24F39-B161-498F-BD8B-C64789812D13}_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{770657D0-A123-3C07-8E44-1C83EC895118}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{787D1A33-A97B-4245-87C0-7174609A540C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7E265513-8CDA-4631-B696-F40D983F3B07}_is1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9559F7CA-5E34-4237-A2D9-D856464AD727}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{97DF1C46-FCCE-4591-9974-5A12CE667B9D}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB300003
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB958483
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB960043
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB975195
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976570
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976578
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976578v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976769
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB976769v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB977354
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB977354v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AC76BA86-7AD7-1033-7B44-AA0000000001}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AFF7E080-1974-45BF-9310-10DE1A1F5ED0}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B95B1BA9-F887-4B3C-8D3A-CCD4C4675120}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB200003
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB2418241
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB2446704
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB2446704v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB2478658
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB2518864
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB2539631
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB431780
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB946922
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB947748
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB949272
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB952137
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB952677
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB953300
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB953990
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB954832
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB956860
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB957541
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB957542
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB957543
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB958129
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB958481
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB960043
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB971111
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB974417
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB976569
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB976576
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB976765v2
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB979909
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB980773
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}.KB983583
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CC8E0363-B20C-4792-8A1C-8DF5E01B68A6}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB2416473
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB350003
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB953595
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB958484
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB960043
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}.KB963707
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E623BB3F-F7ED-4148-BEB5-A0D1DB28B4DE}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E68D186D-6B7B-4AD6-A56F-4C84763349F1}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ECB35FFA-B010-45C5-9AB5-665AC7E27EE2}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}
Adobe Products
! REG.EXE VERSION 3.0
DisplayName REG_SZ Adobe Flash Player 10 ActiveX
Publisher REG_SZ Adobe Systems Incorporated
DisplayVersion REG_SZ 10.1.102.64
HelpLink REG_SZ http://www.adobe.com/go/flashplayer_support/
NoModify REG_DWORD 0x1
NoRepair REG_DWORD 0x1
RequiresIESysFile REG_SZ 4.70.0.1155
URLInfoAbout REG_SZ http://www.adobe.com
URLUpdateInfo REG_SZ http://www.adobe.com/go/getflashplayer/
VersionMajor REG_DWORD 0xa
VersionMinor REG_DWORD 0x1
UninstallString REG_SZ C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_ActiveX.exe -maintain activex
DisplayIcon REG_SZ C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_ActiveX.exe
EstimatedSize REG_DWORD 0x1800
DisplayName REG_SZ Adobe Shockwave Player 11.5
UninstallString REG_SZ "C:\WINDOWS\system32\Adobe\Shockwave 11\uninstaller.exe"
DisplayIcon REG_SZ C:\WINDOWS\system32\Adobe\Shockwave 11\SwInit.exe,0
DisplayVersion REG_SZ 11.5.9.620
HelpLink REG_SZ http://www.adobe.com/support/shockwave
InstallLocation REG_SZ C:\WINDOWS\system32\Adobe
Publisher REG_SZ Adobe Systems, Inc.
URLUpdateInfo REG_SZ http://www.adobe.com/software/shockwaveplayer/index.html
VersionMajor REG_DWORD 0xb
Autorun
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
swg REG_SZ "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
ares REG_SZ "C:\Program Files\Ares\Ares.exe" -h
Bdeqey REG_SZ rundll32.exe "C:\WINDOWS\kbduscl.dll",Startup
ctfmon.exe REG_SZ C:\WINDOWS\system32\ctfmon.exe
RTHDCPL REG_SZ RTHDCPL.EXE
SunJavaUpdateSched REG_SZ "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
ArcSoft Connection Service REG_SZ C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe
HP Software Update REG_SZ C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe
Bing Bar REG_SZ "C:\Program Files\MSN Toolbar\Platform\5.0.1449.0\mswinext.exe"
Microsoft Default Manager REG_SZ "C:\Program Files\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" -resume
Adobe Reader Speed Launcher REG_SZ "C:\Program Files\Adobe\Reader 10.0\Reader\Reader_sl.exe"
Adobe ARM REG_SZ "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
iscpaxneweheclxv REG_SZ C:\WINDOWS\System32\regsvr32.exe /s "C:\WINDOWS\system32\pqbuqgvykvxeol.dll"
bipro REG_SZ rundll32 "C:\WINDOWS\$XNTUninstall643$\fbtil.dll",,Run
Fxehedox REG_SZ rundll32.exe "C:\WINDOWS\ocolivihanofowac.dll",Startup
UserFaultCheck REG_EXPAND_SZ %systemroot%\system32\dumprep 0 -u
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\OptionalComponents
Restrictions - Internet Explorer
HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Control Panel
Restrictions - REGEDIT
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System
Restrictions - Explorer
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoDriveTypeAutoRun REG_DWORD 0x143
NoDriveAutoRun REG_DWORD 0x3ffffff
NoDrives REG_DWORD 0x0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run
DNS Settings
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{020FFB25-A970-413F-9B70-DB8558A65AFC}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{89581583-DC24-49CF-8B7A-B4AA9A2228AA}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{B71FD397-12D3-4E2E-A8C7-2AC3815DBF50}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{D1DB4B87-A849-4170-9A5E-FB80B19CB0C5}
Windows IP Configuration
Host Name . . . . . . . . . . . . : teresa-6ada04ce
Node Type . . . . . . . . . . . . : Broadcast
DNS Suffix Search List. . . . . . : gateway.2wire.net
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . : gateway.2wire.net
Description . . . . . . . . . . . : Realtek RTL8139 Family PCI Fast Ethernet NIC #2
Physical Address. . . . . . . . . : 00-16-76-34-3F-B2
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.2.17
Default Gateway . . . . . . . . . : 192.168.2.1
DHCP Server . . . . . . . . . . . : 192.168.2.1
DNS Servers . . . . . . . . . . . : 192.168.2.1
Lease Obtained. . . . . . . . . . : Tuesday, August 23, 2011 5:45:10 PM
Lease Expires . . . . . . . . . . : Friday, August 26, 2011 5:45:10 PM
AppInit DLLs
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows
Shell Service Object Delay Load
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad
PostBootReminder REG_SZ {7849596a-48ea-486e-8937-a2a3009f31a9}
CDBurn REG_SZ {fbeb8a05-beee-4442-804e-409d6c4515e9}
WebCheck REG_SZ {E6FB5E20-DE35-11CF-9C87-00AA005127ED}
SysTray REG_SZ {35CEC8A3-2BE6-11D2-8773-92E220524153}
WPDShServiceObj REG_SZ {AAA288BA-9A4C-45B0-95D7-94D524869DB5}
Shell Execute Hooks
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks
{AEB6717E-7E19-11d0-97EE-00C04FD91972} REG_SZ
Image File Execution Options
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\apitrap.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\Cleanup.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\cqw32.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\divx.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\divxdec.ax
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DJSMAR00.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRMINST.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\enc98.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EncodeDivXExt.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EncryptPatchVer.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\front.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\fullsoft.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GBROWSER.DLL
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\htmlmarq.ocx
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\htmlmm.ocx
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\install.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ishscan.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ISSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\javai.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\jvm.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\jvm_g.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\main123w.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mngreg32.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\msci_uno.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mscoree.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mscorsvr.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mscorwks.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\msjava.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\mso.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAVOPTRF.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NeVideoFX.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPMLIC.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSWSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\photohse.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PMSTE.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ppw32hlp.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\printhse.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\prwin8.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ps80.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\psdmt.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\qfinder.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\qpw.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\salwrap.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\setup.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\setup32.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\sevinst.exe
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\symlcnet.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\tcore_ebook.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TFDTCTT8.DLL
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ua80.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\udtapi.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ums.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\vb40032.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\vbe6.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\wpwin8.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\xlmlEN.dll
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\xwsetup.EXE
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\Your Image File Name Here without a path
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\_INSTPGM.EXE
Security Providers
Local Security Authority
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa
Authentication Packages REG_MULTI_SZ msv1_0\0\0
Bounds REG_BINARY 0030000000200000
Security Packages REG_MULTI_SZ kerberos\0msv1_0\0schannel\0wdigest\0\0
ImpersonatePrivilegeUpgradeToolHasRun REG_DWORD 0x1
LsaPid REG_DWORD 0x1ec
SecureBoot REG_DWORD 0x1
auditbaseobjects REG_DWORD 0x0
crashonauditfail REG_DWORD 0x0
disabledomaincreds REG_DWORD 0x0
everyoneincludesanonymous REG_DWORD 0x0
fipsalgorithmpolicy REG_DWORD 0x0
forceguest REG_DWORD 0x1
fullprivilegeauditing REG_BINARY 00
limitblankpassworduse REG_DWORD 0x1
lmcompatibilitylevel REG_DWORD 0x0
nodefaultadminowner REG_DWORD 0x1
nolmhash REG_DWORD 0x0
restrictanonymous REG_DWORD 0x0
restrictanonymoussam REG_DWORD 0x1
Notification Packages REG_MULTI_SZ scecli\0\0
enabledcom REG_SZ y
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\AccessProviders
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Audit
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Data
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\GBG
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\JD
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Kerberos
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\msv1_0
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\Skew1
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\SSO
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\SspiCache
AppCert DLLs
App Paths
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\AcroRd32.exe
REG_SZ C:\Program Files\Adobe\Reader 10.0\Reader\AcroRd32.exe
Path REG_SZ C:\Program Files\Adobe\Reader 10.0\Reader\
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\bckgzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\bckgzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\Chart Wars 3.exe
REG_SZ C:\Documents and Settings\teresa\Desktop\games\Chart Wars 3\Chart Wars 3.exe
Path REG_SZ C:\Documents and Settings\teresa\Desktop\games\Chart Wars 3
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\chkrzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\chkrzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\cmmgr32.exe
REG_SZ C:\WINDOWS\system32\cmmgr32.exe
Path REG_SZ C:\WINDOWS\system32
CmstpExtensionDll REG_SZ C:\WINDOWS\system32\cmcfg32.dll
CMInternalVersion REG_SZ 1.2
CmNative REG_DWORD 0x1
ProfilesUpgraded REG_DWORD 0x2
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\combofix.exe
REG_SZ C:\Documents and Settings\teresa\Desktop\Combo-Fix.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\CONF.EXE
REG_SZ C:\Program Files\NetMeeting\conf.exe
Path REG_SZ C:\Program Files\NetMeeting;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\dialer.exe
REG_SZ C:\Program Files\Windows NT\dialer.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\HELPCTR.EXE
REG_EXPAND_SZ %Systemroot%\PCHealth\HelpCtr\Binaries\HelpCtr.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\hrtzzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\hrtzzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\hypertrm.exe
REG_SZ "C:\Program Files\Windows NT\hypertrm.exe"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ICWCONN1.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\ICWCONN1.EXE"
Path REG_SZ C:\Program Files\Internet Explorer\Connection Wizard;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ICWCONN2.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\ICWCONN2.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\IEXPLORE.EXE
REG_SZ C:\Program Files\Internet Explorer\IEXPLORE.EXE
Path REG_SZ C:\Program Files\Internet Explorer;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\INETWIZ.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\INETWIZ.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\install.exe
RunAsOnNonAdminInstall REG_DWORD 0x1
BlockOnTSNonInstallMode REG_DWORD 0x1
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\ISIGNUP.EXE
REG_SZ "C:\Program Files\Internet Explorer\Connection Wizard\ISIGNUP.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\javaws.exe
REG_SZ C:\Program Files\Java\jre6\bin\javaws.exe
Path REG_SZ C:\Program Files\Java\jre6\bin
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\mbam.exe
REG_SZ C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
Path REG_SZ C:\Program Files\Malwarebytes' Anti-Malware
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\migwiz.exe
REG_EXPAND_SZ %SystemRoot%\system32\usmt\migwiz.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\moviemk.exe
REG_SZ C:\Program Files\Movie Maker\moviemk.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\mplayer2.exe
REG_SZ "C:\Program Files\Windows Media Player\mplayer2.exe"
Path REG_SZ "C:\Program Files\Windows Media Player"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MSCONFIG.EXE
REG_EXPAND_SZ %systemroot%\pchealth\helpctr\Binaries\MSCONFIG.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\msimn.exe
REG_EXPAND_SZ %ProgramFiles%\Outlook Express\msimn.exe
Path REG_EXPAND_SZ %ProgramFiles%\Outlook Express
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\msinfo32.exe
REG_SZ C:\Program Files\Common Files\Microsoft Shared\MSInfo\MSInfo32.exe
Path REG_SZ C:\Program Files\Common Files\Microsoft Shared\MSInfo
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\MSMSGS.EXE
Path REG_SZ C:\Program Files\Messenger;
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\pbrush.exe
REG_EXPAND_SZ %SystemRoot%\system32\mspaint.exe
Path REG_EXPAND_SZ %SystemRoot%\system32
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\pinball.exe
REG_SZ C:\Program Files\Windows NT\Pinball\pinball.exe
Path REG_SZ C:\Program Files\Windows NT\Pinball
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\Promotion Wars 1.3.exe
REG_SZ C:\Documents and Settings\teresa\Desktop\games\Promotion Wars 1.3.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\RCT2.EXE
Path REG_SZ C:\Program Files\Infogrames\RollerCoaster Tycoon 2
REG_SZ C:\Program Files\Infogrames\RollerCoaster Tycoon 2\RCT2.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\rvsezm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\rvsezm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\setup.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\shvlzm.exe
REG_SZ C:\Program Files\MSN Gaming Zone\Windows\shvlzm.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\table30.exe
UseShortName REG_SZ
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\tournaments.exe
Path REG_SZ C:\Program Files\ALJ Software\Tournament Maker
REG_SZ C:\Program Files\ALJ Software\Tournament Maker\tournaments.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wab.exe
REG_EXPAND_SZ %ProgramFiles%\Outlook Express\wab.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wabmig.exe
REG_EXPAND_SZ %ProgramFiles%\Outlook Express\wabmig.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\winnt32.exe
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WinRAR.exe
REG_SZ C:\Program Files\WinRAR\WinRAR.exe
Path REG_SZ C:\Program Files\WinRAR
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\wmplayer.exe
REG_SZ C:\Program Files\Windows Media Player\wmplayer.exe
Path REG_SZ C:\Program Files\Windows Media Player
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WORDPAD.EXE
REG_EXPAND_SZ "%ProgramFiles%\Windows NT\Accessories\WORDPAD.EXE"
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\WRITE.EXE
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\app paths\XPSViewer.exe
REG_SZ "c:\WINDOWS\system32\XPSViewer\XPSViewer.exe"
Mozilla
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Firefox
HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla\Firefox\extensions
[You must be registered and logged in to see this link.] REG_EXPAND_SZ C:\Program Files\Java\jre6\lib\deploy\jqs\ff
{20a82645-c095-46ed-80e3-08825760534b} REG_SZ c:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
{B728AB94-9BC7-49b7-B76A-422BB31B2FD0} REG_SZ C:\Program Files\ArcSoft\Media Converter for Philips\Internet Video Downloader\Plugin_FireFox
[You must be registered and logged in to see this link.] REG_SZ C:\Program Files\MSN Toolbar\Platform\5.0.1449.0\Firefox
{B7082FAA-CB62-4872-9106-E42DD88EDE45} REG_SZ C:\Program Files\McAfee\SiteAdvisor
{27182e60-b5f3-411c-b545-b44205977502} REG_SZ C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\firefoxextension\SearchHelperExtension\
{86C2D201-AA1C-4959-85F0-08B2B27B1DC0} REG_SZ C:\Documents and Settings\teresa\Local Settings\Application Data\{86C2D201-AA1C-4959-85F0-08B2B27B1DC0}
Shared Task Scheduler
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler
{438755C2-A8BA-11D1-B96B-00A0C90312E1} REG_SZ Browseui preloader
{8C7461EF-2B13-11d2-BE35-3078302C2030} REG_SZ Component Categories cache daemon
SafeBoot
SafeBootMinimal
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\AppMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Base
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Boot Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Boot file system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\CryptSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\DcomLaunch
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmadmin
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmboot.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmio.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmload.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\dmserver
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\EventLog
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\File system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\HelpSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Netlogon
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PCI Configuration
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PlugPlay
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PNP Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Primary disk
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\RpcSs
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SCSI Class
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sermouse.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sr.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SRService
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\System Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vds
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vga.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vgasave.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WinMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{36FC9E60-C465-11CF-8056-444553540000}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E965-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E967-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E969-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E96A-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E96B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E96F-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E977-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E97B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E97D-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{4D36E980-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{533C5B84-EC70-11D2-9505-00C04F79DEAF}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{71A27CDD-812A-11D0-BEC7-08002BE2092F}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\{745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
SafeBootNetwork
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\AFD
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\AppMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Base
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Boot Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Boot file system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Browser
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\CryptSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\DcomLaunch
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Dhcp
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmadmin
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmboot.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmio.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmload.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\dmserver
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\DnsCache
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\EventLog
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\File system
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\HelpSvc
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\ip6fw.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\ipnat.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\LanmanServer
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\LanmanWorkstation
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\LmHosts
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Messenger
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NDIS
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NDIS Wrapper
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Ndisuio
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetBIOS
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetBIOSGroup
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetBT
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetDDEGroup
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Netlogon
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetMan
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Network
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NetworkProvider
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NtLmSsp
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PCI Configuration
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PlugPlay
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PNP Filter
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PNP_TDI
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Primary disk
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdpcdd.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdpdd.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdpwd.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\rdsessmgr
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\RpcSs
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SCSI Class
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\sermouse.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SharedAccess
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\sr.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SRService
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Streams Drivers
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\System Bus Extender
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\Tcpip
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\TDI
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\tdpipe.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\tdtcp.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\termservice
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\vga.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\vgasave.sys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\WinMgmt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\WZCSVC
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{36FC9E60-C465-11CF-8056-444553540000}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E965-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E967-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E969-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E96A-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E96B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E96F-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E972-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E973-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E974-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E975-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E977-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E97B-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E97D-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{4D36E980-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{71A27CDD-812A-11D0-BEC7-08002BE2092F}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\{745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
squitman
Posts Posts : 21
Joined Joined : 2011-05-01
Points Points : 20773
Re: MS Removal Tool Problem
Post by squitman on 23rd August 2011, 10:26 pm
File Rename Operations - Session
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\FileRenameOperations
Known DLLs - Session
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\KnownDlls
advapi32 REG_SZ advapi32.dll
comdlg32 REG_SZ comdlg32.dll
DllDirectory REG_EXPAND_SZ %SystemRoot%\system32
gdi32 REG_SZ gdi32.dll
imagehlp REG_SZ imagehlp.dll
kernel32 REG_SZ kernel32.dll
lz32 REG_SZ lz32.dll
ole32 REG_SZ ole32.dll
oleaut32 REG_SZ oleaut32.dll
olecli32 REG_SZ olecli32.dll
olecnv32 REG_SZ olecnv32.dll
olesvr32 REG_SZ olesvr32.dll
olethk32 REG_SZ olethk32.dll
rpcrt4 REG_SZ rpcrt4.dll
shell32 REG_SZ shell32.dll
url REG_SZ url.dll
urlmon REG_SZ urlmon.dll
user32 REG_SZ user32.dll
version REG_SZ version.dll
wininet REG_SZ wininet.dll
wldap32 REG_SZ wldap32.dll
Downloaded program files (ActiveX)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{166B1BCA-3F9C-11CF-8075-444553540000}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{6414512B-B978-451D-A0D8-FCFDF33E833C}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{6C6FE41A-0DA6-42A1-9AD8-792026B2B2A7}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{7530BFB8-7293-4D34-9923-61A11451AFC5}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8A94C905-FF9D-43B6-8708-F0F22D22B1CB}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8AD9C840-044E-11D1-B3E9-00805F499D93}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8F6E7FB2-E56B-4F66-A4E1-9765D2565280}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}
PATH: C:\windows\Downloaded Program Files
FP_AX_CAB_INSTALLER.exe
freecell.inf
freecell.ocx
iewwload.inf
iewwload.ocx
OnlineScanner.inf
swdir.inf
swflash.inf
wuweb.inf
wwlaunch.inf
wwlaunch.ocx
Mountpoints
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\A
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\C
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\D
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\E
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{84e83274-28af-11e0-ac70-806d6172696f}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{84e83275-28af-11e0-ac70-fcf229ca9da3}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ab32cdaf-280f-11e0-8ca7-806d6172696f}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{ab32cdb0-280f-11e0-8ca7-806d6172696f}
squitman
Posts Posts : 21
Post by squitman on 23rd August 2011, 10:30 pm
Winlogon
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
AutoRestartShell REG_DWORD 0x1
DefaultDomainName REG_SZ TERESA-6ADA04CE
DefaultUserName REG_SZ teresa
LegalNoticeCaption REG_SZ
LegalNoticeText REG_SZ
PowerdownAfterShutdown REG_SZ 0
ReportBootOk REG_SZ 1
Shell REG_SZ Explorer.exe
ShutdownWithoutLogon REG_SZ 0
System REG_SZ
Userinit REG_SZ C:\WINDOWS\system32\userinit.exe,
VmApplet REG_SZ rundll32 shell32,Control_RunDLL "sysdm.cpl"
SfcQuota REG_DWORD 0xffffffff
allocatecdroms REG_SZ 0
allocatedasd REG_SZ 0
allocatefloppies REG_SZ 0
cachedlogonscount REG_SZ 10
forceunlocklogon REG_DWORD 0x0
passwordexpirywarning REG_DWORD 0xe
scremoveoption REG_SZ 0
AllowMultipleTSSessions REG_DWORD 0x1
UIHost REG_EXPAND_SZ logonui.exe
LogonType REG_DWORD 0x1
Background REG_SZ 0 0 0
DebugServerCommand REG_SZ no
SFCDisable REG_DWORD 0x0
WinStationsDisabled REG_SZ 0
HibernationPreviouslyEnabled REG_DWORD 0x1
ShowLogonOptions REG_DWORD 0x0
AltDefaultUserName REG_SZ teresa
AltDefaultDomainName REG_SZ TERESA-6ADA04CE
LegalNotice Text REG_SZ
ChangePasswordUseKerberos REG_DWORD 0x1
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\GPExtensions
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Credentials
squitman
Posts Posts : 21
Post by Dr Jay on 23rd August 2011, 10:33 pm
Please download [You must be registered and logged in to see this link.]
  • Save it to your desktop.
  • Please double-click OTM to run it. (Note for Vista: Right-click on the file and choose Run As Administrator).
  • Copy the lines in the codebox below to the clipboard by highlighting ALL of them and pressing CTRL C (or, after highlighting, right-click and choose Copy):
    :files
    c:\windows\tasks\at*.job
    :reg
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run]
    "iscpaxneweheclxv"=-
    "bipro"=-
    "Fxehedox"=-
    :Commands
    [emptytemp]
    [purity]
    [Reboot]
  • Return to OTM, right click in the "Paste Instructions for Items to be Moved" window (under the yellow bar) and choose Paste.
  • Copy everything in the Results window (under the green bar) to the clipboard by highlighting ALL of them and pressing CTRL C (or, after highlighting, right-click and choose copy), and paste it in your next reply.
  • Close OTM and reboot your PC.
Note: If a file or folder cannot be moved immediately you may be asked to reboot the machine to finish the move process. If you are asked to reboot the machine choose Yes. In this case, after the reboot, open Notepad (Start->All Programs->Accessories->Notepad), click File->Open, in the File Name box enter *.log and press the Enter key, navigate to the C:\_OTMoveIt\MovedFiles folder, and
open the newest .log file present, and copy/paste the contents of that document back here in your next post.
Posts Posts : 13743
Points Points : 302211
Post by squitman on 23rd August 2011, 10:59 pm
All processes killed
========== FILES ==========
c:\windows\tasks\At1.job moved successfully.
c:\windows\tasks\At198.job moved successfully.
c:\windows\tasks\At199.job moved successfully.
c:\windows\tasks\At2.job moved successfully.
c:\windows\tasks\At200.job moved successfully.
c:\windows\tasks\At201.job moved successfully.
c:\windows\tasks\At202.job moved successfully.
c:\windows\tasks\At203.job moved successfully.
c:\windows\tasks\At204.job moved successfully.
c:\windows\tasks\At205.job moved successfully.
c:\windows\tasks\At206.job moved successfully.
c:\windows\tasks\At207.job moved successfully.
c:\windows\tasks\At208.job moved successfully.
c:\windows\tasks\At209.job moved successfully.
c:\windows\tasks\At210.job moved successfully.
c:\windows\tasks\At211.job moved successfully.
c:\windows\tasks\At212.job moved successfully.
c:\windows\tasks\At213.job moved successfully.
c:\windows\tasks\At214.job moved successfully.
c:\windows\tasks\At215.job moved successfully.
c:\windows\tasks\At216.job moved successfully.
c:\windows\tasks\At217.job moved successfully.
c:\windows\tasks\At218.job moved successfully.
c:\windows\tasks\At219.job moved successfully.
c:\windows\tasks\At220.job moved successfully.
c:\windows\tasks\At221.job moved successfully.
c:\windows\tasks\At3.job moved successfully.
c:\windows\tasks\At4.job moved successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\iscpaxneweheclxv deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\bipro deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\Fxehedox deleted successfully.
[EMPTYTEMP]
User: All Users
User: Default User
->Temporary Internet Files folder emptied: 33170 bytes
->Flash cache emptied: 56466 bytes
User: LocalService
->Temp folder emptied: 65748 bytes
->Temporary Internet Files folder emptied: 835986 bytes
->Flash cache emptied: 1976 bytes
User: NetworkService
->Temp folder emptied: 394578 bytes
->Temporary Internet Files folder emptied: 6717574 bytes
->Java cache emptied: 0 bytes
->Flash cache emptied: 61406 bytes
User: teresa
->Temp folder emptied: 32420409 bytes
->Temporary Internet Files folder emptied: 27046865 bytes
->Java cache emptied: 6746979 bytes
->Flash cache emptied: 1168 bytes
%systemroot% .tmp files removed: 19569 bytes
Windows Temp folder emptied: 90899633 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 39647188 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
RecycleBin emptied: 4297 bytes
Total Files Cleaned = 195.00 mb
OTM by OldTimer - Version 3.1.18.0 log created on 08232011_184328
Files moved on Reboot...
(Is this what you mean?)
squitman
Posts Posts : 21
Post by Dr Jay on 24th August 2011, 1:48 am
Good. How is your computer running?
Posts Posts : 13743
Post by squitman on 24th August 2011, 9:51 pm
it seems fine currently Thank You!
(should ask this now, If another problem occurs should i just post in this topic of should i start a new one?)
squitman
Posts Posts : 21
Post by Dr Jay on 26th August 2011, 12:36 am
Start a new one please. Smile
Posts Posts : 13743
