MS Removal Tool will not be removed
Post new topic   Reply to topic
Post by sf50 on Fri 29 Apr 2011, 11:37 am
Can anyone please help me? The problem is on my wifes pc, I have searched and tried all suggestions including the fix from this forum. It is not possible to access the internet in any mode and introducing malware bytes via usb does not work either. It seems that each time I try a fix it knows what I am trying to do. Obviously I am unable to access this site from my wifes pc so unable to download required software to help you
sf50
Unborn
Unborn
Operating System : xp
Re: MS Removal Tool will not be removed
Post by Belahzur on Sat 30 Apr 2011, 8:32 am
Download OTL by OldTimer to your Desktop.
Manager | Tech Officer
