Canon i560 Print Problem
Post by lomado on Thu Apr 28, 2011 3:19 pm
Printer was operating correctly. Closed it, disconnected all cables, and moved it to a new location. Now, only prints text on alternating lines -- prints a 1/4 inch wide line, then there is a 1/4 inch wide blank line; this pattern continues for the entire page. Any thoughts as to what is causing this problem -- and how to fix it ?
lomado
Joined Joined : 2011-04-23
Points Points : 20524
Re: Canon i560 Print Problem
Post by Nazzgull on Fri Apr 29, 2011 11:26 am
You damaged your printer in transporting. I suggest to visit some Service in your town and ask them to fix your printer. This is not something what you can do alone.
Regards
Points Points : 40435
