Recovery Issue after Virus removal
Post by CamiAnne on 17th April 2011, 2:47 am
My I can't see my files (pictures, Microsoft Word documents, 'favorites' files, etc.) they're there if you search for them through the 'start' qeue but when I click on the favorites bar or the main file icon they aren't there. This happened after I removed the Windows Protection Virus with Maleware Bytes' Anti-Ware after I had deleted the trojans from the virus vault and restarted my computer as a part of the deletion process about five minutes ago. I can't seem to figure out how to get files (or atleast the icons I suppose) back, what should I do?
CamiAnne
Joined Joined : 2011-04-17
Points Points : 20663
Re: Recovery Issue after Virus removal
Post by CamiAnne on 17th April 2011, 2:51 am
Nevermind! I went to the folder and layout options and re-adjusted the settings to my old ones there.
CamiAnne
