Possible Ramnit virus - PLEASE HELP!!!!
Post by smithy882 on 15th April 2011, 10:10 am
This is my first time on here, so please bear with me.
Whilst browing the internet last night it decided to freeze, so i turned the computer off and re-started it. I re-started internet explorer but about every 5 seconds a trojan or malware popped up through Avast (there were loads popping up). I realised something wasnt right so i run a full scan through avast but it didnt pick anything up,. As i was running the scan the avast carried on popping up with trojans and malware, and i noticed some of them were saying Ramnit WIN32. The scan finished and no infections were picked up. This morning i turned the computer back on and double clicked on the interent explorer icon but the internet will not even load now, nothing the egg timer appears for a second then nothing.
If you have any idea of what i can do i would be very grateful.
Many thanks.
smithy882
Joined Joined : 2011-04-15
Points Points : 20663
Re: Possible Ramnit virus - PLEASE HELP!!!!
Post by Belahzur on 16th April 2011, 12:51 am
Points Points : 245111
