Problem in Adobe Reader x
Post by mandrews on Tue Apr 12, 2011 10:13 am
I have trouble when installing, I keep getting error1321 installer has insufficient previliages to modify. I have looked through another post for another adobe product, but when I go to change something I keep getting access denied. I have also noticed that some of my programs I use are either missing there shortcut or I cannot access them. It seems to have started after loading kepersky. Not sure if it is the problem but i am getting very frustrated with the issue. Please help...
mandrews
Posts Posts : 20
Joined Joined : 2011-02-07
OS OS : Greer, South Carolina
Points Points : 21512
Re: Problem in Adobe Reader x
Post by mandrews on Tue Apr 12, 2011 10:15 am
AND also I have tried uninstalling, I have went into msconfig and clicked the disable all in start up, adobe advise per forum, and i still couldnt do either install or uninstall.
mandrews
Posts Posts : 20
Post by Jan2011 on Tue Apr 12, 2011 1:17 pm
Have you tried uninstalling the program from
Control Panel > Add/Remove Programs (XP) - or -
Control Panel > Programs and Features (Vista)?
Jan2011
Posts Posts : 615
Joined Joined : 2011-01-17
Points Points : 25554
Post by houndmom on Tue Apr 12, 2011 1:47 pm
Hey mandrews, Welcome to GeekPolice!!
This may help:
http://kb2.adobe.com/cps/403/kb403915.html#WinVista
If we have helped you, Please consider helping us,  make a donation.
Helping fight malware.
houndmom
Posts Posts : 1053
Joined Joined : 2010-04-27
OS OS : Windows 7 ultimate
Protection Protection : Bitdefender Total Security 2010
Points Points : 29757
Post by mandrews on Tue Apr 12, 2011 6:19 pm
i tried through add remove, finally found unlocker got it deleted. now trying to load and get error 1303
mandrews
Posts Posts : 20
Post by mandrews on Tue Apr 12, 2011 8:47 pm
ok kaspersky has some corrupted files, error 1317, tried to delete it. And guess what same damn thing cant uninstall do to error. I believe i have something on the system.
mandrews
Posts Posts : 20
Post by houndmom on Tue Apr 12, 2011 9:22 pm
okay in that case, you need further help:
Please read here
Then post in the malware forum here
One of the awesome techs will help you as soon as they can!
houndmom
Posts Posts : 1053
Post by mandrews on Wed Apr 13, 2011 3:54 am
I know they will, if i can get to bring up a report
mandrews
Posts Posts : 20
