SQL & Wireless Conflict
Post by Nativetexan2 on Mon Apr 11, 2011 10:50 am
I bought a used computer that a company had on their network. It is running XP Professional and SQL 2000. I wanted to use this computer as the host on my wireless Linksys home network. I reinstalled my wireless router but it says I have no internet connection although I do on the host computer. Do I have to remove the SQL and if so, how do I remove it?
Nativetexan2
OS : Windows 7 Professional
# Likes : 0
Re: SQL & Wireless Conflict
Post by Jan2011 on Sat Apr 16, 2011 10:29 am
I'm not familiar with SQL, but I believe it's just a database.
Since this computer came out of a business environment, it might want to connect to a domain, which is still back at the business location.
I suggest that before tackling the wireless situation that you try to connect with an Ethernet wire to your router. That will eliminate some issues. Once it's established that you can connect using a wired-connection, then work on the wireless.
Note: I am not a tech here, only a user offering an opinion.
Jan2011
OS : xp
# Likes : 0
